[mapguide-commits] r8722 - branches/2.6/vagrant
svn_mapguide at osgeo.org
Mon Jul 27 06:02:13 PDT 2015
Author: jng
Date: 2015-07-27 06:02:13 -0700 (Mon, 27 Jul 2015)
New Revision: 8722
branches/2.6/vagrant/build.bat
branches/2.6/vagrant/verify.bat
Turn off 64-bit builds as there we don't build 2.6.x for x64 on Linux.
Modified: branches/2.6/vagrant/build.bat
--- branches/2.6/vagrant/build.bat 2015-07-27 12:57:21 UTC (rev 8721)
+++ branches/2.6/vagrant/build.bat 2015-07-27 13:02:13 UTC (rev 8722)
@@ -11,13 +11,13 @@
IF "%MG_SVN_UPDATE_SOURCES%"=="" SET MG_SVN_UPDATE_SOURCES=1
IF "%BUILD_UBUNTU_32%"=="" SET BUILD_UBUNTU_32=1
-IF "%BUILD_UBUNTU_64%"=="" SET BUILD_UBUNTU_64=1
+IF "%BUILD_UBUNTU_64%"=="" SET BUILD_UBUNTU_64=0
IF "%BUILD_CENTOS_32%"=="" SET BUILD_CENTOS_32=1
-IF "%BUILD_CENTOS_64%"=="" SET BUILD_CENTOS_64=1
+IF "%BUILD_CENTOS_64%"=="" SET BUILD_CENTOS_64=0
IF "%TEARDOWN_UBUNTU_32%"=="" SET TEARDOWN_UBUNTU_32=1
-IF "%TEARDOWN_UBUNTU_64%"=="" SET TEARDOWN_UBUNTU_64=1
+IF "%TEARDOWN_UBUNTU_64%"=="" SET TEARDOWN_UBUNTU_64=0
IF "%TEARDOWN_CENTOS_32%"=="" SET TEARDOWN_CENTOS_32=1
-IF "%TEARDOWN_CENTOS_64%"=="" SET TEARDOWN_CENTOS_64=1
+IF "%TEARDOWN_CENTOS_64%"=="" SET TEARDOWN_CENTOS_64=0
SET ROOT=%CD%
SET COMPONENT=
echo **************** Build Summary *********************
Modified: branches/2.6/vagrant/verify.bat
--- branches/2.6/vagrant/verify.bat 2015-07-27 12:57:21 UTC (rev 8721)
+++ branches/2.6/vagrant/verify.bat 2015-07-27 13:02:13 UTC (rev 8722)
@@ -16,9 +16,9 @@
IF "%DOWNLOAD_HOST%"=="" SET DOWNLOAD_HOST=192.168.0.6
IF "%MG_DIST_DIR%"=="" SET MG_DIST_DIR=builds30
IF "%VERIFY_UBUNTU_32%"=="" SET VERIFY_UBUNTU_32=1
-IF "%VERIFY_UBUNTU_64%"=="" SET VERIFY_UBUNTU_64=1
+IF "%VERIFY_UBUNTU_64%"=="" SET VERIFY_UBUNTU_64=0
IF "%VERIFY_CENTOS_32%"=="" SET VERIFY_CENTOS_32=1
-IF "%VERIFY_CENTOS_64%"=="" SET VERIFY_CENTOS_64=1
+IF "%VERIFY_CENTOS_64%"=="" SET VERIFY_CENTOS_64=0
echo **************** Verify Summary *********************
echo Download Host is: %DOWNLOAD_HOST%
More information about the mapguide-commits
