[mapguide-commits] r8724 - branches/2.6/MgDev
svn_mapguide at osgeo.org
Mon Jul 27 16:48:56 PDT 2015
Author: jng
Date: 2015-07-27 16:48:55 -0700 (Mon, 27 Jul 2015)
New Revision: 8724
branches/2.6/MgDev/configure.in
Version bump
Modified: branches/2.6/MgDev/configure.in
--- branches/2.6/MgDev/configure.in 2015-07-27 13:27:14 UTC (rev 8723)
+++ branches/2.6/MgDev/configure.in 2015-07-27 23:48:55 UTC (rev 8724)
@@ -4,7 +4,7 @@
# Variables
# Following are the makefile directories
-AC_INIT(mapguide,2.6.0,http://mapguide.osgeo.org)
+AC_INIT(mapguide,2.6.1,http://mapguide.osgeo.org)
AC_CONFIG_SRCDIR(configure.in)
AM_INIT_AUTOMAKE
AM_INIT_AUTOMAKE([1.9 tar-pax])
@@ -85,7 +85,7 @@
AC_SUBST(httpd_src)
dnl *******************************************************
-dnl FDO 3.9.0 Configuration
+dnl FDO 3.9.1 Configuration
dnl Include / lib paths
# custom Fdo path specification
@@ -96,9 +96,9 @@
[custom_inc=DEFAULT])
if test $custom_inc = "DEFAULT"; then
- map_fdo_include="/usr/local/fdo-3.9.0/include"
+ map_fdo_include="/usr/local/fdo-3.9.1/include"
if test -d $map_fdo_include; then
- AC_MSG_NOTICE([Building with default location of FDO include files at /usr/local/fdo-3.9.0/include])
+ AC_MSG_NOTICE([Building with default location of FDO include files at /usr/local/fdo-3.9.1/include])
else
AC_MSG_ERROR([the default FDO include path $map_fdo_include is not a valid directory. Please use the custom option])
fi
@@ -118,9 +118,9 @@
[custom_lib=DEFAULT])
if test $custom_lib = "DEFAULT"; then
- map_fdo_lib="/usr/local/fdo-3.9.0/lib"
+ map_fdo_lib="/usr/local/fdo-3.9.1/lib"
if test -d $map_fdo_lib; then
- AC_MSG_NOTICE([Building with default location of FDO libraries at /usr/local/fdo-3.9.0/lib])
+ AC_MSG_NOTICE([Building with default location of FDO libraries at /usr/local/fdo-3.9.1/lib])
else
AC_MSG_ERROR([the default FDO lib path $map_fdo_lib is not a valid directory. Please use the custom option])
fi
@@ -132,7 +132,7 @@
AC_MSG_ERROR([the specified FDO library path $custom_lib is not a valid directory])
fi
fi
-map_fdo_nls="/usr/local/fdo-3.9.0/nls/%N"
+map_fdo_nls="/usr/local/fdo-3.9.1/nls/%N"
AC_SUBST(map_fdo_include)
AC_SUBST(map_fdo_lib)
AC_SUBST(map_fdo_nls)
More information about the mapguide-commits
