[mapguide-commits] r8561 - in trunk/Tools/Maestro/Maestro.Editors:	. Generic LayerDefinition/Vector/Scales
    svn_mapguide at osgeo.org
    Thu Mar  5 05:30:21 PST 2015
Author: jng
Date: 2015-03-05 05:30:21 -0800 (Thu, 05 Mar 2015)
New Revision: 8561
   trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorDialog.cs
   trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.Designer.cs
   trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.cs
   trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.resx
   trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs
   trunk/Tools/Maestro/Maestro.Editors/Strings.resx
#2544: Fix inability to edit composite symbolization as XML
#2540: Support exporting inline symbol definitions in composite symbolizations to external symbols
Modified: trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorDialog.cs
--- trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorDialog.cs	2015-03-05 12:54:30 UTC (rev 8560)
+++ trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorDialog.cs	2015-03-05 13:30:21 UTC (rev 8561)
@@ -24,6 +24,7 @@
 using System;
 using System.IO;
 using System.Windows.Forms;
+using System.Xml;
 using System.Xml.Schema;
 #pragma warning disable 1591
@@ -44,6 +45,7 @@
         internal XmlEditorDialog()
             InitializeComponent();
+            this.OnlyValidateWellFormedness = false;
             _ed = new XmlEditorCtrl();
             _ed.Validator = new XmlValidationCallback(ValidateXml);
             _ed.Dock = DockStyle.Fill;
@@ -138,7 +140,26 @@
         private void ValidateXml(out string[] errors, out string[] warnings)
-            XmlValidator.ValidateResourceXmlContent(this.XmlContent, this.XsdPath, out errors, out warnings);
+            if (this.OnlyValidateWellFormedness)
+                errors = new string[0];
+                warnings = new string[0];
+                //Test for well-formedness
+                try
+                    XmlDocument doc = new XmlDocument();
+                    doc.LoadXml(this.XmlContent);
+                catch (XmlException ex)
+                    errors = new string[] { ex.Message };
+            else
+                XmlValidator.ValidateResourceXmlContent(this.XmlContent, this.XsdPath, out errors, out warnings);
         private void btnCancel_Click(object sender, EventArgs e)
@@ -164,5 +185,7 @@
         public event EventHandler ResourceChanged;
+        public bool OnlyValidateWellFormedness { get; set; }
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.Designer.cs	2015-03-05 12:54:30 UTC (rev 8560)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.Designer.cs	2015-03-05 13:30:21 UTC (rev 8561)
@@ -48,6 +48,7 @@
             this.toolStripSeparator4 = new System.Windows.Forms.ToolStripSeparator();
             this.inlineSimpleSymbolToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
             this.btnDelete = new System.Windows.Forms.ToolStripButton();
+            this.btnSaveExternal = new System.Windows.Forms.ToolStripButton();
             this.toolStripSeparator2 = new System.Windows.Forms.ToolStripSeparator();
             this.btnEditInstanceProperties = new System.Windows.Forms.ToolStripButton();
             this.btnEditComponent = new System.Windows.Forms.ToolStripButton();
@@ -114,6 +115,7 @@
             this.toolStrip1.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
             this.btnAdd,
             this.btnDelete,
+            this.btnSaveExternal,
             this.toolStripSeparator2,
             this.btnEditInstanceProperties,
             this.btnEditComponent});
@@ -220,6 +222,13 @@
             this.btnDelete.Name = "btnDelete";
             this.btnDelete.Click += new System.EventHandler(this.btnDelete_Click);
+            // btnSaveExternal
+            resources.ApplyResources(this.btnSaveExternal, "btnSaveExternal");
+            this.btnSaveExternal.Image = global::Maestro.Editors.Properties.Resources.disk;
+            this.btnSaveExternal.Name = "btnSaveExternal";
+            this.btnSaveExternal.Click += new System.EventHandler(this.btnSaveExternal_Click);
             // toolStripSeparator2
             this.toolStripSeparator2.Name = "toolStripSeparator2";
@@ -425,5 +434,6 @@
         private System.Windows.Forms.ToolStripDropDownButton btnEditProperty;
         private System.Windows.Forms.ToolStripMenuItem viaEditorToolStripMenuItem;
         private System.Windows.Forms.ToolStripMenuItem viaExpressionEditorToolStripMenuItem;
+        private System.Windows.Forms.ToolStripButton btnSaveExternal;
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.cs	2015-03-05 12:54:30 UTC (rev 8560)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.cs	2015-03-05 13:30:21 UTC (rev 8561)
@@ -236,7 +236,7 @@
             li.Tag = symRef;
             var sym = GetSymbolDefinition(symRef);
-            if (li.ImageIndex == 0)
+            if (symRef.Reference.Type == SymbolInstanceType.Reference)
                 li.Text = sym.Name + " (" + ((ISymbolInstanceReferenceLibrary)symRef.Reference).ResourceId + ")";
             else
                 li.Text = sym.Name + " (" + Strings.InlineSymbolDefinition + ")";
@@ -320,11 +320,13 @@
                 //Now add available parameters
                 PopulateAvailableParameters(symRef, sym);
+                btnSaveExternal.Enabled = (symRef.Reference.Type == SymbolInstanceType.Inline);
                 btnEditInstanceProperties.Enabled = true;
                 btnEditComponent.Enabled = true;
             else
+                btnSaveExternal.Enabled = false;
                 btnEditInstanceProperties.Enabled = false;
                 btnEditComponent.Enabled = false;
@@ -386,6 +388,7 @@
             string xml = _comp.ToXml();
             XmlEditorDialog diag = new XmlEditorDialog();
+            diag.OnlyValidateWellFormedness = true;
             diag.XmlContent = xml;
             if (diag.ShowDialog() == System.Windows.Forms.DialogResult.OK)
@@ -774,5 +777,28 @@
             var instance = _comp.CreateInlineSimpleSymbol(ssym);
             AddInstance(instance, true);
+        private void btnSaveExternal_Click(object sender, EventArgs e)
+            if (lstInstances.SelectedItems.Count == 1)
+                var it = lstInstances.SelectedItems[0];
+                ISymbolInstance symRef = (ISymbolInstance)it.Tag;
+                if (symRef.Reference.Type == SymbolInstanceType.Inline)
+                    var sym = ((ISymbolInstanceReferenceInline)symRef.Reference).SymbolDefinition;
+                    using (var picker = new ResourcePicker(_edSvc.CurrentConnection, ResourceTypes.SymbolDefinition.ToString(), ResourcePickerMode.SaveResource))
+                        if (picker.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+                            sym.SetSchemaAttributes();
+                            _edSvc.CurrentConnection.ResourceService.SaveResourceAs(sym, picker.ResourceID);
+                            MessageBox.Show(string.Format(Maestro.Editors.Strings.SymbolExported, picker.ResourceID));
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.resx
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.resx	2015-03-05 12:54:30 UTC (rev 8560)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.resx	2015-03-05 13:30:21 UTC (rev 8561)
@@ -123,7 +123,7 @@
   </data>
   <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
   <data name="btnClose.Location" type="System.Drawing.Point, System.Drawing">
-    <value>368, 527</value>
+    <value>397, 527</value>
   </data>
   <data name="btnClose.Size" type="System.Drawing.Size, System.Drawing">
     <value>75, 23</value>
@@ -163,7 +163,7 @@
     <value>3, 41</value>
   </data>
   <data name="lstInstances.Size" type="System.Drawing.Size, System.Drawing">
-    <value>425, 82</value>
+    <value>454, 82</value>
   </data>
   <data name="lstInstances.TabIndex" type="System.Int32, mscorlib">
     <value>1</value>
@@ -264,6 +264,18 @@
   <data name="btnDelete.Text" xml:space="preserve">
     <value>Delete</value>
   </data>
+  <data name="btnSaveExternal.Enabled" type="System.Boolean, mscorlib">
+    <value>False</value>
+  </data>
+  <data name="btnSaveExternal.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+    <value>Magenta</value>
+  </data>
+  <data name="btnSaveExternal.Size" type="System.Drawing.Size, System.Drawing">
+    <value>60, 22</value>
+  </data>
+  <data name="btnSaveExternal.Text" xml:space="preserve">
+    <value>Export</value>
+  </data>
   <data name="toolStripSeparator2.Size" type="System.Drawing.Size, System.Drawing">
     <value>6, 25</value>
   </data>
@@ -295,7 +307,7 @@
     <value>3, 16</value>
   </data>
   <data name="toolStrip1.Size" type="System.Drawing.Size, System.Drawing">
-    <value>425, 25</value>
+    <value>454, 25</value>
   </data>
   <data name="toolStrip1.TabIndex" type="System.Int32, mscorlib">
     <value>0</value>
@@ -319,7 +331,7 @@
     <value>12, 12</value>
   </data>
   <data name="grpComponents.Size" type="System.Drawing.Size, System.Drawing">
-    <value>431, 126</value>
+    <value>460, 126</value>
   </data>
   <data name="grpComponents.TabIndex" type="System.Int32, mscorlib">
     <value>0</value>
@@ -349,7 +361,7 @@
   </data>
   <data name="grdOverrides.Size" type="System.Drawing.Size, System.Drawing">
-    <value>425, 261</value>
+    <value>454, 261</value>
   </data>
   <data name="grdOverrides.TabIndex" type="System.Int32, mscorlib">
     <value>1</value>
@@ -442,7 +454,7 @@
   </data>
   <data name="toolStrip2.Size" type="System.Drawing.Size, System.Drawing">
   </data>
   <data name="toolStrip2.TabIndex" type="System.Int32, mscorlib">
     <value>0</value>
@@ -466,7 +478,7 @@
     <value>12, 141</value>
   </data>
   <data name="grpProperties.Size" type="System.Drawing.Size, System.Drawing">
-    <value>431, 305</value>
+    <value>460, 305</value>
   </data>
   <data name="grpProperties.TabIndex" type="System.Int32, mscorlib">
     <value>2</value>
@@ -523,7 +535,7 @@
     <value>19, 19</value>
   </data>
   <data name="symPreview.Size" type="System.Drawing.Size, System.Drawing">
-    <value>393, 36</value>
+    <value>422, 36</value>
   </data>
   <data name="symPreview.TabIndex" type="System.Int32, mscorlib">
     <value>0</value>
@@ -544,7 +556,7 @@
     <value>12, 452</value>
   </data>
   <data name="grpPreview.Size" type="System.Drawing.Size, System.Drawing">
-    <value>431, 69</value>
+    <value>460, 69</value>
   </data>
   <data name="grpPreview.TabIndex" type="System.Int32, mscorlib">
     <value>1</value>
@@ -592,7 +604,7 @@
     <value>True</value>
   </metadata>
   <data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
-    <value>455, 562</value>
+    <value>484, 562</value>
   </data>
   <data name="$this.StartPosition" type="System.Windows.Forms.FormStartPosition, System.Windows.Forms">
     <value>CenterParent</value>
@@ -684,6 +696,12 @@
   <data name=">>btnDelete.Type" xml:space="preserve">
     <value>System.Windows.Forms.ToolStripButton, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
+  <data name=">>btnSaveExternal.Name" xml:space="preserve">
+    <value>btnSaveExternal</value>
+  </data>
+  <data name=">>btnSaveExternal.Type" xml:space="preserve">
+    <value>System.Windows.Forms.ToolStripButton, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
   <data name=">>toolStripSeparator2.Name" xml:space="preserve">
     <value>toolStripSeparator2</value>
   </data>
Modified: trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs	2015-03-05 12:54:30 UTC (rev 8560)
+++ trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs	2015-03-05 13:30:21 UTC (rev 8561)
@@ -2774,6 +2774,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Symbol exported to: {0}.
+        /// </summary>
+        internal static string SymbolExported {
+            get {
+                return ResourceManager.GetString("SymbolExported", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to <image>.
         /// </summary>
         internal static string SymbolGraphicsImagePlaceholder {
Modified: trunk/Tools/Maestro/Maestro.Editors/Strings.resx
--- trunk/Tools/Maestro/Maestro.Editors/Strings.resx	2015-03-05 12:54:30 UTC (rev 8560)
+++ trunk/Tools/Maestro/Maestro.Editors/Strings.resx	2015-03-05 13:30:21 UTC (rev 8561)
@@ -1712,4 +1712,7 @@
   <data name="LinkedTileSetNote" xml:space="preserve">
     <value>The Map Definition's coordinate system and extents have been replaced with the ones from the linked tile set</value>
   </data>
+  <data name="SymbolExported" xml:space="preserve">
+    <value>Symbol exported to: {0}</value>
+  </data>
 </root>
More information about the mapguide-commits
