[mapguide-commits] r8571 - trunk/MgDev/Common/MapGuideCommon/Controller
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Mar 11 09:01:18 PDT 2015
Author: jng
Date: 2015-03-11 09:01:17 -0700 (Wed, 11 Mar 2015)
New Revision: 8571
   trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp
#2526: Fix MgUnclassifiedException when doing a QUERYMAPFEATURES with PERSIST=0
Reviewed by Walt Welton-Lair
Modified: trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp
--- trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp	2015-03-11 14:12:16 UTC (rev 8570)
+++ trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp	2015-03-11 16:01:17 UTC (rev 8571)
@@ -278,17 +278,26 @@
     // Call the C++ API, regardless of bitmask as any part of the mask will require information from this API
     featureInfo = service->QueryFeatures(map, layerNames, selectionGeometry, selectionVariant, featureFilter, maxFeatures, layerAttributeFilter);
+    Ptr<MgSelection> selection;
+    if (NULL != featureInfo.p)
+        selection = featureInfo->GetSelection();
+    bool bSetMap = true;
+    if (!selection)
+        selection = new MgSelection(map);
+        bSetMap = false;
     if (persist)
         //save the selection set in the session repository
-        Ptr<MgSelection> selection;
-        if (NULL != featureInfo.p)
-            selection = featureInfo->GetSelection();
-        if(!selection)
-            selection = new MgSelection(map);
         selection->Save(resourceService, mapName);
-        newSelection = SAFE_ADDREF(selection.p);
+    newSelection = SAFE_ADDREF(selection.p);
+    if (bSetMap)
         //Needed for GetLayers() to work below
         newSelection->SetMap(map);
More information about the mapguide-commits mailing list
