[mapguide-commits] r8579 - in trunk/Tools/Maestro/Maestro.Editors: . Common TileSetDefinition
svn_mapguide at osgeo.org
Sun Mar 15 08:36:33 PDT 2015
Author: jng
Date: 2015-03-15 08:36:33 -0700 (Sun, 15 Mar 2015)
New Revision: 8579
trunk/Tools/Maestro/Maestro.Editors/Common/IExpressionEditor.cs
trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Strings.resx
trunk/Tools/Maestro/Maestro.Editors/TileSetDefinition/LayerStructureCtrl.cs
- Revert expression editor implementation selection
- Do not allow MgCooker to be invoked for non-Default tile sets
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/IExpressionEditor.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/IExpressionEditor.cs 2015-03-15 14:36:51 UTC (rev 8578)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/IExpressionEditor.cs 2015-03-15 15:36:33 UTC (rev 8579)
@@ -88,8 +88,7 @@
public static IExpressionEditor Create()
- //if (Platform.IsRunningOnMono)
- if (true)
+ if (Platform.IsRunningOnMono)
return new MonoCompatibleExpressionEditor();
else
return new ExpressionEditor();
Modified: trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs 2015-03-15 14:36:51 UTC (rev 8578)
+++ trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs 2015-03-15 15:36:33 UTC (rev 8579)
@@ -1922,6 +1922,15 @@
/// <summary>
+ /// Looks up a localized string similar to MgCooker only works with Tile Sets using the 'Default' tile provider.
+ /// </summary>
+ internal static string MgCookerIncompatibleTileSet {
+ get {
+ return ResourceManager.GetString("MgCookerIncompatibleTileSet", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Missing column "{0}".
/// </summary>
internal static string MissingColumnError {
Modified: trunk/Tools/Maestro/Maestro.Editors/Strings.resx
--- trunk/Tools/Maestro/Maestro.Editors/Strings.resx 2015-03-15 14:36:51 UTC (rev 8578)
+++ trunk/Tools/Maestro/Maestro.Editors/Strings.resx 2015-03-15 15:36:33 UTC (rev 8579)
@@ -1718,4 +1718,7 @@
<data name="SavedTileSet" xml:space="preserve">
<value>Saved tile set to: {0}</value>
</data>
+ <data name="MgCookerIncompatibleTileSet" xml:space="preserve">
+ <value>MgCooker only works with Tile Sets using the 'Default' tile provider</value>
+ </data>
</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Editors/TileSetDefinition/LayerStructureCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/TileSetDefinition/LayerStructureCtrl.cs 2015-03-15 14:36:51 UTC (rev 8578)
+++ trunk/Tools/Maestro/Maestro.Editors/TileSetDefinition/LayerStructureCtrl.cs 2015-03-15 15:36:33 UTC (rev 8579)
@@ -195,6 +195,12 @@
return;
+ if (_tsd.TileStoreParameters.TileProvider != "Default") //NOXLATE
+ MessageBox.Show(Maestro.Editors.Strings.MgCookerIncompatibleTileSet);
+ return;
var conn = _edSvc.CurrentConnection;
//HACK: Can't support other connection types beyond HTTP atm
if (!conn.ProviderName.ToLower().Contains("maestro.http"))
More information about the mapguide-commits
