[mapguide-commits] r8597 - in trunk/Tools/Vagrant: centos/test_x64 centos/test_x86 scripts ubuntu ubuntu/test_x64 ubuntu/test_x86
svn_mapguide at osgeo.org
Sat Mar 28 01:44:45 PDT 2015
Author: jng
Date: 2015-03-28 01:44:45 -0700 (Sat, 28 Mar 2015)
New Revision: 8597
Added:
trunk/Tools/Vagrant/ubuntu/test_x64/
trunk/Tools/Vagrant/ubuntu/test_x64/Vagrantfile
trunk/Tools/Vagrant/ubuntu/test_x64/provision.sh
trunk/Tools/Vagrant/ubuntu/test_x86/
trunk/Tools/Vagrant/ubuntu/test_x86/Vagrantfile
trunk/Tools/Vagrant/ubuntu/test_x86/provision.sh
trunk/Tools/Vagrant/centos/test_x64/provision.sh
trunk/Tools/Vagrant/centos/test_x86/provision.sh
trunk/Tools/Vagrant/scripts/mginstallubuntu.sh
#2554: Add headless install option for Ubuntu install script
#2520: Vagrant environment updates
- Add smoke test vagrantfiles for Ubuntu
Modified: trunk/Tools/Vagrant/centos/test_x64/provision.sh
--- trunk/Tools/Vagrant/centos/test_x64/provision.sh 2015-03-27 17:14:06 UTC (rev 8596)
+++ trunk/Tools/Vagrant/centos/test_x64/provision.sh 2015-03-28 08:44:45 UTC (rev 8597)
@@ -11,4 +11,6 @@
chmod +x smoke_test.sh
chmod +x mginstallcentos.sh
sudo -E ./mginstallcentos.sh
+echo Wait 10s before running smoke test
+sleep 10s
sudo -E ./smoke_test.sh
\ No newline at end of file
Modified: trunk/Tools/Vagrant/centos/test_x86/provision.sh
--- trunk/Tools/Vagrant/centos/test_x86/provision.sh 2015-03-27 17:14:06 UTC (rev 8596)
+++ trunk/Tools/Vagrant/centos/test_x86/provision.sh 2015-03-28 08:44:45 UTC (rev 8597)
@@ -11,4 +11,6 @@
+sleep 10s
Modified: trunk/Tools/Vagrant/scripts/mginstallubuntu.sh
--- trunk/Tools/Vagrant/scripts/mginstallubuntu.sh 2015-03-27 17:14:06 UTC (rev 8596)
+++ trunk/Tools/Vagrant/scripts/mginstallubuntu.sh 2015-03-28 08:44:45 UTC (rev 8597)
@@ -35,25 +35,124 @@
httpd_port=8008
tomcat_port=8009
+fdo_provider_choice=""
# Must have root
if [[ $EUID -ne 0 ]]; then
echo "You must run this script with superuser privileges"
exit 1
fi
+while [ $# -gt 0 ]; do # Until you run out of parameters...
+ case "$1" in
+ -headless|--headless)
+ HEADLESS=1
+ #shift
+ -with-sdf|--with-sdf)
+ fdo_provider_choice="$fdo_provider_choice sdf"
+ #shift
+ -with-shp|--with-shp)
+ fdo_provider_choice="$fdo_provider_choice shp"
+ #shift
+ -with-sqlite|--with-sqlite)
+ fdo_provider_choice="$fdo_provider_choice sqlite"
+ #shift
+ -with-gdal|--with-gdal)
+ fdo_provider_choice="$fdo_provider_choice gdal"
+ #shift
+ -with-ogr|--with-ogr)
+ fdo_provider_choice="$fdo_provider_choice ogr"
+ #shift
+ -with-kingoracle|--with-kingoracle)
+ fdo_provider_choice="$fdo_provider_choice kingoracle"
+ #shift
+ -with-wfs|--with-wfs)
+ fdo_provider_choice="$fdo_provider_choice wfs"
+ #shift
+ -with-wms|--with-wms)
+ fdo_provider_choice="$fdo_provider_choice wms"
+ #shift
+ -server-ip|--server-ip)
+ server_ip="$2"
+ webtier_server_ip="$2"
+ shift
+ -admin-port|--admin-port)
+ admin_port=$2
+ shift
+ -client-port|--client-port)
+ client_port=$2
+ shift
+ -site-port|--site-port)
+ site_port=$2
+ shift
+ -httpd-port|--httpd-port)
+ httpd_port=$2
+ shift
+ -tomcat-port|--tomcat-port)
+ tomcat_port=$2
+ shift
+ -help|--help)
+ echo "Usage: $0 (options)"
+ echo "Options:"
+ echo " --headless [Install headlessly (skip UI)]"
+ echo " --with-sdf [Include SDF Provider]"
+ echo " --with-shp [Include SHP Provider]"
+ echo " --with-sqlite [Include SQLite Provider]"
+ echo " --with-gdal [Include GDAL Provider]"
+ echo " --with-ogr [Include OGR Provider]"
+ echo " --with-kingoracle [Include King Oracle Provider]"
+ echo " --with-wfs [Include WFS Provider]"
+ echo " --with-wms [Include WMS Provider]"
+ echo " --server-ip [Server IP, default: 127.0.0.1]"
+ echo " --admin-port [Admin Server Port, default: 2810]"
+ echo " --client-port [Client Server Port, default: 2811]"
+ echo " --site-port [Site Server Port, default: 2812]"
+ echo " --httpd-port [HTTPD port, default: 8008]"
+ echo " --tomcat-port [Tomcat Port, default: 8009]"
+ exit
+ esac
+ shift # Check next set of parameters.
+done
+if [ "$HEADLESS" != "1" ]
+then
# Install required packages
apt-get -y install dialog libexpat1 libssl1.0.0 odbcinst unixodbc libcurl3 libxslt1.1
+else
+# Install required packages
+apt-get -y install libexpat1 libssl1.0.0 odbcinst unixodbc libcurl3 libxslt1.1
+fi
DIALOG=${DIALOG=dialog}
main()
- dialog_welcome
- dialog_fdo_provider
- dialog_server
- dialog_webtier
- #dialog_coordsys
- #dump_configuration
+ if [ "$HEADLESS" != "1" ]
+ then
+ dialog_welcome
+ dialog_fdo_provider
+ dialog_server
+ dialog_webtier
+ #dialog_coordsys
+ else
+ dump_configuration
+ fi
install_fdo
install_mapguide_packages
post_install
Added: trunk/Tools/Vagrant/ubuntu/test_x64/Vagrantfile
--- trunk/Tools/Vagrant/ubuntu/test_x64/Vagrantfile (rev 0)
+++ trunk/Tools/Vagrant/ubuntu/test_x64/Vagrantfile 2015-03-28 08:44:45 UTC (rev 8597)
@@ -0,0 +1,123 @@
+# -*- mode: ruby -*-
+# vi: set ft=ruby :
+# Vagrantfile API/syntax version. Don't touch unless you know what you're doing!
+VAGRANTFILE_API_VERSION = "2"
+Vagrant.configure(VAGRANTFILE_API_VERSION) do |config|
+ # All Vagrant configuration is done here. The most common configuration
+ # options are documented and commented below. For a complete reference,
+ # please see the online documentation at vagrantup.com.
+ # Every Vagrant virtual environment requires a box to build off of.
+ config.vm.box = "ubuntu12-amd64"
+ # The url from where the 'config.vm.box' box will be fetched if it
+ # doesn't already exist on the user's system.
+ # config.vm.box_url = "http://domain.com/path/to/above.box"
+ # Create a forwarded port mapping which allows access to a specific port
+ # within the machine from a port on the host machine. In the example below,
+ # accessing "localhost:8080" will access port 80 on the guest machine.
+ # config.vm.network :forwarded_port, guest: 80, host: 8080
+ # Create a private network, which allows host-only access to the machine
+ # using a specific IP.
+ # config.vm.network :private_network, ip: "192.168.33.10"
+ # Create a public network, which generally matched to bridged network.
+ # Bridged networks make the machine appear as another physical device on
+ # your network.
+ # config.vm.network :public_network
+ # If true, then any SSH connections made will enable agent forwarding.
+ # Default value: false
+ # config.ssh.forward_agent = true
+ # Share an additional folder to the guest VM. The first argument is
+ # the path on the host to the actual folder. The second argument is
+ # the path on the guest to mount the folder. And the optional third
+ # argument is a set of non-required options.
+ config.vm.synced_folder "../../sources", "/mapguide_sources"
+ # Provider-specific configuration so you can fine-tune various
+ # backing providers for Vagrant. These expose provider-specific options.
+ # Example for VirtualBox:
+ # config.vm.provider :virtualbox do |vb|
+ # # Don't boot with headless mode
+ # vb.gui = true
+ # # Use VBoxManage to customize the VM. For example to change memory:
+ # vb.customize ["modifyvm", :id, "--memory", "1024"]
+ # end
+ # View the documentation for the provider you're using for more
+ # information on available options.
+ # Enable provisioning with Puppet stand alone. Puppet manifests
+ # are contained in a directory path relative to this Vagrantfile.
+ # You will need to create the manifests directory and a manifest in
+ # the file vagrant-mapguide-ubuntu-precise32.pp in the manifests_path directory.
+ # An example Puppet manifest to provision the message of the day:
+ # # group { "puppet":
+ # # ensure => "present",
+ # # File { owner => 0, group => 0, mode => 0644 }
+ # # file { '/etc/motd':
+ # # content => "Welcome to your Vagrant-built virtual machine!
+ # # Managed by Puppet.\n"
+ # config.vm.provision :puppet do |puppet|
+ # puppet.manifests_path = "manifests"
+ # puppet.manifest_file = "site.pp"
+ # end
+ # Enable provisioning with chef solo, specifying a cookbooks path, roles
+ # path, and data_bags path (all relative to this Vagrantfile), and adding
+ # some recipes and/or roles.
+ # config.vm.provision :chef_solo do |chef|
+ # chef.cookbooks_path = "../my-recipes/cookbooks"
+ # chef.roles_path = "../my-recipes/roles"
+ # chef.data_bags_path = "../my-recipes/data_bags"
+ # chef.add_recipe "mysql"
+ # chef.add_role "web"
+ # # You may also specify custom JSON attributes:
+ # chef.json = { :mysql_password => "foo" }
+ # end
+ # Enable provisioning with chef server, specifying the chef server URL,
+ # and the path to the validation key (relative to this Vagrantfile).
+ # The Opscode Platform uses HTTPS. Substitute your organization for
+ # ORGNAME in the URL and validation key.
+ # If you have your own Chef Server, use the appropriate URL, which may be
+ # HTTP instead of HTTPS depending on your configuration. Also change the
+ # validation key to validation.pem.
+ # config.vm.provision :chef_client do |chef|
+ # chef.chef_server_url = "https://api.opscode.com/organizations/ORGNAME"
+ # chef.validation_key_path = "ORGNAME-validator.pem"
+ # end
+ # If you're using the Opscode platform, your validator client is
+ # ORGNAME-validator, replacing ORGNAME with your organization name.
+ # If you have your own Chef Server, the default validation client name is
+ # chef-validator, unless you changed the configuration.
+ # chef.validation_client_name = "ORGNAME-validator"
+ config.vm.provision "shell",
+ privileged: false,
+ path: "provision.sh",
+ args: "#{ENV['DOWNLOAD_HOST']}"
+end
Added: trunk/Tools/Vagrant/ubuntu/test_x64/provision.sh
--- trunk/Tools/Vagrant/ubuntu/test_x64/provision.sh (rev 0)
+++ trunk/Tools/Vagrant/ubuntu/test_x64/provision.sh 2015-03-28 08:44:45 UTC (rev 8597)
@@ -0,0 +1,15 @@
+#!/bin/bash
+DOWNLOAD_HOST=$1
+echo Download host is: $DOWNLOAD_HOST
+wget "http://$DOWNLOAD_HOST/builds/Sheboygan.mgp"
+wget "http://$DOWNLOAD_HOST/builds/smoke_test.sh"
+sudo mv Sheboygan.mgp /tmp/
+wget "http://$DOWNLOAD_HOST/builds/ubuntu_x64/mginstallubuntu.sh"
+sed -i 's/URL="http:\/\/download/URL_OLD="http:\/\/download/g' mginstallubuntu.sh
+sed -i 's/#URL="http:\/\/192.168.0.5\/downloads\/ubuntu12"/URL="http:\/\/'"$DOWNLOAD_HOST"'\/builds\/ubuntu_x64"/g' mginstallubuntu.sh
+chmod +x smoke_test.sh
+chmod +x mginstallubuntu.sh
+sudo ./mginstallubuntu.sh --headless --with-sdf --with-shp --with-ogr --with-gdal --with-sqlite
+sleep 10s
+sudo ./smoke_test.sh
Added: trunk/Tools/Vagrant/ubuntu/test_x86/Vagrantfile
--- trunk/Tools/Vagrant/ubuntu/test_x86/Vagrantfile (rev 0)
+++ trunk/Tools/Vagrant/ubuntu/test_x86/Vagrantfile 2015-03-28 08:44:45 UTC (rev 8597)
@@ -0,0 +1,123 @@
+ config.vm.box = "ubuntu12-i386"
+ # your network.
+ # vb.gui = true
+ # end
+ # end
+ # end
+ # end
+end
Added: trunk/Tools/Vagrant/ubuntu/test_x86/provision.sh
--- trunk/Tools/Vagrant/ubuntu/test_x86/provision.sh (rev 0)
+++ trunk/Tools/Vagrant/ubuntu/test_x86/provision.sh 2015-03-28 08:44:45 UTC (rev 8597)
@@ -0,0 +1,15 @@
+#!/bin/bash
+DOWNLOAD_HOST=$1
+wget "http://$DOWNLOAD_HOST/builds/ubuntu_x86/mginstallubuntu.sh"
+sed -i 's/#URL="http:\/\/192.168.0.5\/downloads\/ubuntu12"/URL="http:\/\/'"$DOWNLOAD_HOST"'\/builds\/ubuntu_x86"/g' mginstallubuntu.sh
+sleep 10s
More information about the mapguide-commits
