[mapguide-commits] r8608 - in sandbox/adsk/3.0m: Common/MapGuideCommon Common/MapGuideCommon/MapLayer Common/MapGuideCommon/Resources Server/src/UnitTesting UnitTest/WebTier/DotNet/TestCommon UnitTest/WebTier/DotNet/TestMapGuideApi UnitTest/WebTier/DotNet/TestMapGuideApi/ExternalTests UnitTest/WebTier/DotNet/TestMapGuideApi/Properties UnitTest/WebTier/DotNet/TestMapGuideApi/Resources UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc Web/src/DotNetUnmanagedApi/MapGuideCommon Web/src/MapGuideApi
svn_mapguide at osgeo.org
Tue Mar 31 19:05:14 PDT 2015
Author: hubu
Date: 2015-03-31 19:05:13 -0700 (Tue, 31 Mar 2015)
New Revision: 8608
Added:
sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/ExternalTests/MapTests.cs
sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/
sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_BaseMap.mdf
sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_BaseMap.tsd
sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_LinkedTileSet.mdf
sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_XYZ.tsd
Removed:
sandbox/adsk/3.0m/Common/MapGuideCommon/MapGuideCommon.vcxproj.filters
sandbox/adsk/3.0m/Common/MapGuideCommon/MapLayer/Map.cpp
sandbox/adsk/3.0m/Common/MapGuideCommon/Resources/mapguide_en.res
sandbox/adsk/3.0m/Server/src/UnitTesting/TestTileService.cpp
sandbox/adsk/3.0m/Server/src/UnitTesting/TestTileService.h
sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestCommon/Assert.cs
sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTests.cs
sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Properties/Resources.Designer.cs
sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Properties/Resources.resx
sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/TestMapGuideApi.csproj
sandbox/adsk/3.0m/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonApiGen.xml
sandbox/adsk/3.0m/Web/src/MapGuideApi/MapGuideApiGen.xml
Merge #2538 to sandbox/adsk/3.0m branch.
Modified: sandbox/adsk/3.0m/Common/MapGuideCommon/MapGuideCommon.vcxproj.filters
--- sandbox/adsk/3.0m/Common/MapGuideCommon/MapGuideCommon.vcxproj.filters 2015-03-30 02:48:29 UTC (rev 8607)
+++ sandbox/adsk/3.0m/Common/MapGuideCommon/MapGuideCommon.vcxproj.filters 2015-04-01 02:05:13 UTC (rev 8608)
@@ -397,7 +397,9 @@
<ClCompile Include="Exception\UnknownTileProviderException.cpp">
<Filter>Exception</Filter>
</ClCompile>
- <ClCompile Include="Exception\UnsupportedTileProviderException.cpp" />
+ <ClCompile Include="Exception\UnsupportedTileProviderException.cpp">
+ <Filter>Exception</Filter>
+ </ClCompile>
</ItemGroup>
<ItemGroup>
<ClInclude Include="MapLayer\Layer.h">
@@ -776,7 +778,9 @@
<ClInclude Include="Exception\UnknownTileProviderException.h">
</ClInclude>
- <ClInclude Include="Exception\UnsupportedTileProviderException.h" />
+ <ClInclude Include="Exception\UnsupportedTileProviderException.h">
+ </ClInclude>
</ItemGroup>
<ItemGroup>
<ResourceCompile Include="MapGuideCommon.rc" />
Modified: sandbox/adsk/3.0m/Common/MapGuideCommon/MapLayer/Map.cpp
--- sandbox/adsk/3.0m/Common/MapGuideCommon/MapLayer/Map.cpp 2015-03-30 02:48:29 UTC (rev 8607)
+++ sandbox/adsk/3.0m/Common/MapGuideCommon/MapLayer/Map.cpp 2015-04-01 02:05:13 UTC (rev 8608)
@@ -222,6 +222,18 @@
m_center = gf.CreatePoint(coordCenter);
+ else //Both CSes match, so just set map/data extents and center as normal from the Map Definition
+ const Box2D& extent = mdef->GetExtents();
+ Ptr<MgCoordinate> lowerLeft = gf.CreateCoordinateXY(extent.GetMinX(), extent.GetMinY());
+ Ptr<MgCoordinate> upperRight = gf.CreateCoordinateXY(extent.GetMaxX(), extent.GetMaxY());
+ m_mapExtent = new MgEnvelope(lowerLeft, upperRight);
+ m_dataExtent = new MgEnvelope(lowerLeft, upperRight);
+ Ptr<MgCoordinate> coordCenter = gf.CreateCoordinateXY(extent.GetMinX() + (extent.GetMaxX() - extent.GetMinX()) / 2,
+ extent.GetMinY() + (extent.GetMaxY() - extent.GetMinY()) / 2);
+ m_center = gf.CreatePoint(coordCenter);
m_backColor = mdef->GetBackgroundColor();
m_tileSetId = SAFE_ADDREF((MgResourceIdentifier*)tileSetDefId);
Modified: sandbox/adsk/3.0m/Common/MapGuideCommon/Resources/mapguide_en.res
--- sandbox/adsk/3.0m/Common/MapGuideCommon/Resources/mapguide_en.res 2015-03-30 02:48:29 UTC (rev 8607)
+++ sandbox/adsk/3.0m/Common/MapGuideCommon/Resources/mapguide_en.res 2015-04-01 02:05:13 UTC (rev 8608)
@@ -146,7 +146,9 @@
MgUnauthorizedAccessException = Unauthorized access.
MgUnclassifiedException = Problem:\nThe application encountered a problem and could not finish the operation you just requested properly.\n\nSolution:\nIf it\'s the first time you met this problem, try again or restart the application / session; otherwise, describe the steps to reproduce this problem to the server administrator for suggestions.
MgUnderflowException = Underflow exception.
+MgUnknownTileProviderException = Unknown Tile Provider: %1
MgUnsupportedProviderThreadModelException = The FDO provider thread model is not supported.
+MgUnsupportedTileProviderException = Unsupported Tile Provider: %1
MgUriFormatException = Uri format exception.
MgUserNotFoundException = The specified user was not found: %1
MgXmlException = An XML exception occurred.
Modified: sandbox/adsk/3.0m/Server/src/UnitTesting/TestTileService.cpp
--- sandbox/adsk/3.0m/Server/src/UnitTesting/TestTileService.cpp 2015-03-30 02:48:29 UTC (rev 8607)
+++ sandbox/adsk/3.0m/Server/src/UnitTesting/TestTileService.cpp 2015-04-01 02:05:13 UTC (rev 8608)
@@ -15,6 +15,7 @@
// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#include "SAX2Parser.h"
#include "MapGuideCommon.h"
#include "TestTileService.h"
#include "../UnitTesting/CppUnitExtensions.h"
@@ -1474,6 +1475,93 @@
+void TestTileService::TestCase_MgMap_LinkedSameCS()
+ try
+ STRING mapName = L"TestCase_MgMap_Linked";
+ Ptr<MgMap> map = CreateMapLinked2(mapName);
+ //Bounds should be that of the tile set
+ Ptr<MgEnvelope> extents = map->GetMapExtent();
+ CPPUNIT_ASSERT(NULL != extents.p);
+ Ptr<MgEnvelope> dataExtents = map->GetDataExtent();
+ CPPUNIT_ASSERT(NULL != dataExtents.p);
+ Ptr<MgCoordinate> ll = extents->GetLowerLeftCoordinate();
+ Ptr<MgCoordinate> ur = extents->GetUpperRightCoordinate();
+ CPPUNIT_ASSERT_DOUBLES_EQUAL(-87.797866013831, ll->GetX(), 0.000000000001);
+ CPPUNIT_ASSERT_DOUBLES_EQUAL(43.686857862181, ll->GetY(), 0.000000000001);
+ CPPUNIT_ASSERT_DOUBLES_EQUAL(-87.664527771869, ur->GetX(), 0.000000000001);
+ CPPUNIT_ASSERT_DOUBLES_EQUAL(43.803796220613, ur->GetY(), 0.000000000001);
+ Ptr<MgResourceIdentifier> tsId = map->GetTileSetDefinition();
+ CPPUNIT_ASSERT(NULL != (MgResourceIdentifier*)tsId);
+ CPPUNIT_ASSERT(L"Library://UnitTests/TileSets/Sheboygan.TileSetDefinition" == tsId->ToString());
+ Ptr<MgLayerGroupCollection> groups = map->GetLayerGroups();
+ for (INT32 i = 0; i < groups->GetCount(); i++)
+ Ptr<MgLayerGroup> group = groups->GetItem(i);
+ CPPUNIT_ASSERT(MgLayerGroupType::BaseMapFromTileSet == group->GetLayerGroupType());
+ // Initialize service objects.
+ MgServiceManager* serviceManager = MgServiceManager::GetInstance();
+ Ptr<MgServerSiteService> svcSite = dynamic_cast<MgServerSiteService*>(serviceManager->RequestService(MgServiceType::SiteService));
+ Ptr<MgResourceService> svcRes = dynamic_cast<MgResourceService*>(serviceManager->RequestService(MgServiceType::ResourceService));
+ assert(svcSite != NULL);
+ assert(svcRes != NULL);
+ // Set the current MgUserInformation
+ // This must be done before calling CreateSession()
+ Ptr<MgUserInformation> userInfo = new MgUserInformation(
+ L"Administrator", L"admin");
+ userInfo->SetLocale(TEST_LOCALE);
+ MgUserInformation::SetCurrentUserInfo(userInfo);
+ STRING session = svcSite->CreateSession();
+ Ptr<MgResourceIdentifier> mapStateId = new MgResourceIdentifier(MgRepositoryType::Session, session, L"", map->GetName(), MgResourceType::Map);
+ map->Save(svcRes, mapStateId);
+ map = NULL;
+ Ptr<MgSiteConnection> siteConn = new MgSiteConnection();
+ userInfo = new MgUserInformation(session);
+ siteConn->Open(userInfo);
+ map = new MgMap(siteConn);
+ map->Open(mapName);
+ //Re-check. All should be the same
+ extents = map->GetMapExtent();
+ ll = extents->GetLowerLeftCoordinate();
+ ur = extents->GetUpperRightCoordinate();
+ tsId = map->GetTileSetDefinition();
+ groups = map->GetLayerGroups();
+ svcSite->DestroySession(session);
+ catch (MgException* e)
+ STRING message = e->GetDetails(TEST_LOCALE);
+ SAFE_RELEASE(e);
+ CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+ catch (...)
+ throw;
void TestTileService::TestCase_MgMapFromXYZTileSetStrict()
try
@@ -1686,6 +1774,70 @@
return map;
+MgMap* TestTileService::CreateMapLinked2(CREFSTRING mapName)
+ // set a default name if not supplied
+ STRING name = (mapName.empty()) ? L"UnitTestBaseMapLinked" : mapName;
+ Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/LinkedTileSet.MapDefinition");
+ // Parse the Map Definition and modify it so it matches its linked tile set
+ Ptr<MgResourceService> resSvc = dynamic_cast<MgResourceService*>(m_siteConnection->CreateService(MgServiceType::ResourceService));
+ MdfModel::MapDefinition* mdf = MgMapBase::GetMapDefinition(resSvc, mdfres);
+ MdfModel::TileSetSource* tsRef = mdf->GetTileSetSource();
+ Ptr<MgResourceIdentifier> tileSetId = new MgResourceIdentifier(tsRef->GetResourceId());
+ Ptr<MgByteReader> reader = resSvc->GetResourceContent(tileSetId);
+ Ptr<MgByteSink> sink = new MgByteSink(reader);
+ Ptr<MgByte> bytes = sink->ToBuffer();
+ MdfParser::SAX2Parser parser;
+ parser.ParseString((const char*)bytes->Bytes(), bytes->GetLength());
+ CPPUNIT_ASSERT(parser.GetSucceeded());
+ MdfModel::TileSetDefinition* tsd = parser.DetachTileSetDefinition();
+ // Update coordinate systems to match
+ STRING csWkt;
+ MdfModel::NameStringPairCollection* params = tsd->GetTileStoreParameters()->GetParameters();
+ for (INT32 i = 0; i < params->GetCount(); i++)
+ MdfModel::NameStringPair* pair = params->GetAt(i);
+ if (pair->GetName() == L"CoordinateSystem")
+ csWkt = pair->GetValue();
+ mdf->SetCoordinateSystem(csWkt);
+ break;
+ // Fix up extents too
+ mdf->SetExtents(tsd->GetExtents());
+ // Save back out to XML
+ MdfModel::Version ver(3, 0, 0);
+ std::string mbXml = parser.SerializeToXML(mdf, &ver);
+ Ptr<MgByteSource> source = new MgByteSource((BYTE_ARRAY_IN)mbXml.c_str(), (INT32)mbXml.length());
+ Ptr<MgByteReader> content = source->GetReader();
+ mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/LinkedTileSet2.MapDefinition");
+ resSvc->SetResource(mdfres, content, NULL);
+ // make a runtime map from our changed map definition
+ MgMap* map = new MgMap(m_siteConnection);
+ map->Create(mdfres, name);
+ // set the view
+ Ptr<MgCoordinate> coordNewCenter = new MgCoordinateXY(-87.723636, 43.715015);
+ Ptr<MgPoint> ptNewCenter = new MgPoint(coordNewCenter);
+ map->SetViewCenter(ptNewCenter);
+ map->SetDisplayDpi(96);
+ map->SetDisplayWidth(1024);
+ map->SetDisplayHeight(1024);
+ // render at a scale of 1:12500
+ map->SetViewScale(12500.0);
+ return map;
// returns a random integer in the range 0 to n-1
INT32 TestTileService::Rand(INT32 n)
Modified: sandbox/adsk/3.0m/Server/src/UnitTesting/TestTileService.h
--- sandbox/adsk/3.0m/Server/src/UnitTesting/TestTileService.h 2015-03-30 02:48:29 UTC (rev 8607)
+++ sandbox/adsk/3.0m/Server/src/UnitTesting/TestTileService.h 2015-04-01 02:05:13 UTC (rev 8608)
@@ -24,10 +24,10 @@
CPPUNIT_TEST_SUITE(TestTileService);
CPPUNIT_TEST(TestStart); // This must be the very first unit test
CPPUNIT_TEST(TestCase_GetTileProviders);
CPPUNIT_TEST(TestCase_MgMap_Inline);
CPPUNIT_TEST(TestCase_MgMap_Linked);
+ CPPUNIT_TEST(TestCase_MgMap_LinkedSameCS);
CPPUNIT_TEST(TestCase_MgMapFromXYZTileSetStrict);
CPPUNIT_TEST(TestCase_MgMapFromXYZTileSetLoose);
CPPUNIT_TEST(TestCase_MgMapFromTileSet);
@@ -38,7 +38,6 @@
CPPUNIT_TEST(TestCase_GetTileLinked);
CPPUNIT_TEST(TestCase_GetTileXYZ);
CPPUNIT_TEST(TestCase_ClearCacheLinked);
CPPUNIT_TEST(TestEnd); // This must be the very last unit test
CPPUNIT_TEST_SUITE_END();
@@ -54,6 +53,7 @@
void TestCase_GetTileProviders();
void TestCase_MgMap_Inline();
void TestCase_MgMap_Linked();
+ void TestCase_MgMap_LinkedSameCS();
void TestCase_MgMapFromXYZTileSetStrict();
void TestCase_MgMapFromXYZTileSetLoose();
void TestCase_MgMapFromTileSet();
@@ -68,6 +68,7 @@
private:
MgMap* CreateMap(CREFSTRING mapName = L"");
MgMap* CreateMapLinked(CREFSTRING mapName = L"");
+ MgMap* CreateMapLinked2(CREFSTRING mapName = L"");
INT32 Rand(INT32 n);
private:
Modified: sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestCommon/Assert.cs
--- sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestCommon/Assert.cs 2015-03-30 02:48:29 UTC (rev 8607)
+++ sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestCommon/Assert.cs 2015-04-01 02:05:13 UTC (rev 8608)
@@ -79,5 +79,10 @@
if (!double.IsNaN(value))
throw new AssertException("Double is a number. Expected: NaN");
+ public static void Fail(string msg)
+ throw new AssertException(msg);
Copied: sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/ExternalTests/MapTests.cs (from rev 8548, trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/ExternalTests/MapTests.cs)
--- sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/ExternalTests/MapTests.cs (rev 0)
+++ sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/ExternalTests/MapTests.cs 2015-04-01 02:05:13 UTC (rev 8608)
@@ -0,0 +1,145 @@
+using OSGeo.MapGuide.Test.Common;
+using System;
+using System.Collections.Generic;
+using System.Linq;
+using System.Text;
+using System.Threading.Tasks;
+namespace OSGeo.MapGuide.Test.Web.ExternalTests
+ public abstract class ExternalTestBase : IExternalTest
+ protected static void LoadResource(MgResourceService resSvc, string resIdStr, string path)
+ MgResourceIdentifier resId = new MgResourceIdentifier(resIdStr);
+ MgByteSource bs = new MgByteSource(path);
+ MgByteReader br = bs.GetReader();
+ resSvc.SetResource(resId, br, null);
+ protected static void LoadResourceData(MgResourceService resSvc, string resIdStr, string dataName, string dataType, string path)
+ resSvc.SetResourceData(resId, dataName, dataType, br);
+ public abstract void Execute(IPlatformFactory factory, ITestLogger logger);
+ public class LinkedTileSetMapTest : ExternalTestBase
+ public override void Execute(IPlatformFactory factory, ITestLogger logger)
+ try
+ MgResourceService resSvc = (MgResourceService)factory.CreateService(MgServiceType.ResourceService);
+ var root = "../../TestData/TileService/";
+ LoadResource(resSvc, "Library://UnitTests/Data/RoadCenterLines.FeatureSource", root + "UT_RoadCenterLines.fs");
+ LoadResourceData(resSvc, "Library://UnitTests/Data/RoadCenterLines.FeatureSource", "UT_RoadCenterLines.sdf", MgResourceDataType.File, root + "UT_RoadCenterLines.sdf");
+ LoadResource(resSvc, "Library://UnitTests/Layers/RoadCenterLines.LayerDefinition", root + "UT_RoadCenterLines.ldf");
+ LoadResource(resSvc, "Library://UnitTests/Data/VotingDistricts.FeatureSource", root + "UT_VotingDistricts.fs");
+ LoadResourceData(resSvc, "Library://UnitTests/Data/VotingDistricts.FeatureSource", "UT_VotingDistricts.sdf", MgResourceDataType.File, root + "UT_VotingDistricts.sdf");
+ LoadResource(resSvc, "Library://UnitTests/Layers/VotingDistricts.LayerDefinition", root + "UT_VotingDistricts.ldf");
+ LoadResource(resSvc, "Library://UnitTests/Data/Parcels.FeatureSource", root + "UT_Parcels.fs");
+ LoadResourceData(resSvc, "Library://UnitTests/Data/Parcels.FeatureSource", "UT_Parcels.sdf", MgResourceDataType.File, root + "UT_Parcels.sdf");
+ LoadResource(resSvc, "Library://UnitTests/Layers/Parcels.LayerDefinition", root + "UT_Parcels.ldf");
+ byte[] tsd = Properties.Resources.UT_XYZ;
+ MgByteSource sourceTSD = new MgByteSource(tsd, tsd.Length);
+ MgByteReader contentTSD = sourceTSD.GetReader();
+ MgResourceIdentifier resTSD = new MgResourceIdentifier("Library://UnitTests/TileSets/Test.TileSetDefinition");
+ resSvc.SetResource(resTSD, contentTSD, null);
+ string mdf = Encoding.UTF8.GetString(Properties.Resources.UT_BaseMap);
+ mdf = string.Format(mdf, resTSD.ToString());
+ byte[] mdfBytes = Encoding.UTF8.GetBytes(mdf);
+ MgByteSource sourceMDF = new MgByteSource(mdfBytes, mdfBytes.Length);
+ MgByteReader contentMDF = sourceMDF.GetReader();
+ MgResourceIdentifier resMDF = new MgResourceIdentifier("Library://UnitTests/Maps/LinkedTileSet.MapDefinition");
+ resSvc.SetResource(resMDF, contentMDF, null);
+ //This should throw because making a MgMap from a Map Defintion that links to a XYZ tile set
+ //is not supported
+ MgMapBase map = factory.CreateMap(resMDF);
+ Assert.Fail("Expected MgUnsupportedTileProviderException to be thrown");
+ catch (MgUnsupportedTileProviderException)
+ public class TestTicket2538 : ExternalTestBase
+ //For a map definition that links to a default provider tile set and both have the same coordinate
+ //system, it should be using the map definition's extents and we should not have null extents or view
+ //center
+ MgCoordinateSystemFactory csFactory = new MgCoordinateSystemFactory();
+ string csWkt = csFactory.ConvertCoordinateSystemCodeToWkt("LL84");
+ string tsd = Encoding.UTF8.GetString(Properties.Resources.UT_BaseMapTileSet);
+ tsd = string.Format(tsd, csWkt, -87.5, 43.5, -86.5, 44.5);
+ byte[] tsdBytes = Encoding.UTF8.GetBytes(tsd);
+ MgByteSource sourceTSD = new MgByteSource(tsdBytes, tsdBytes.Length);
+ string mdf = Encoding.UTF8.GetString(Properties.Resources.UT_LinkedTileSet);
+ mdf = string.Format(mdf, csWkt, -87.0, 43.0, -86.0, 44.0, resTSD.ToString());
+ MgEnvelope extent = map.GetMapExtent();
+ Assert.IsNotNull(extent);
+ Assert.IsNotNull(map.MapExtent);
+ MgPoint center = map.GetViewCenter();
+ Assert.IsNotNull(center);
+ Assert.IsNotNull(map.ViewCenter);
+ MgCoordinate ll = extent.GetLowerLeftCoordinate();
+ MgCoordinate ur = extent.GetUpperRightCoordinate();
+ Assert.IsNotNull(ll);
+ Assert.IsNotNull(ur);
+ Assert.AreEqual(-87.0, ll.X);
+ Assert.AreEqual(43.0, ll.Y);
+ Assert.AreEqual(-86.0, ur.X);
+ Assert.AreEqual(44.0, ur.Y);
Modified: sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTests.cs
--- sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTests.cs 2015-03-30 02:48:29 UTC (rev 8607)
+++ sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTests.cs 2015-04-01 02:05:13 UTC (rev 8608)
@@ -18,7 +18,7 @@
var types = typeof(MapGuideTests).Assembly.GetTypes();
foreach (var type in types)
- if (typeof(IExternalTest).IsAssignableFrom(type) && type.IsClass)
+ if (typeof(IExternalTest).IsAssignableFrom(type) && type.IsClass && !type.IsAbstract)
var test = (IExternalTest)Activator.CreateInstance(type);
try
Modified: sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Properties/Resources.Designer.cs
--- sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Properties/Resources.Designer.cs 2015-03-30 02:48:29 UTC (rev 8607)
+++ sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Properties/Resources.Designer.cs 2015-04-01 02:05:13 UTC (rev 8608)
@@ -1,7 +1,7 @@
// <auto-generated>
// This code was generated by a tool.
-// Runtime Version:4.0.30319.18444
+// Runtime Version:4.0.30319.34209
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
@@ -81,5 +81,45 @@
return ResourceManager.GetString("ResourceHeaderTemplate", resourceCulture);
+ /// <summary>
+ /// Looks up a localized resource of type System.Byte[].
+ /// </summary>
+ internal static byte[] UT_BaseMap {
+ get {
+ object obj = ResourceManager.GetObject("UT_BaseMap", resourceCulture);
+ return ((byte[])(obj));
+ /// <summary>
+ /// </summary>
+ internal static byte[] UT_BaseMapTileSet {
+ get {
+ object obj = ResourceManager.GetObject("UT_BaseMapTileSet", resourceCulture);
+ /// <summary>
+ /// </summary>
+ internal static byte[] UT_LinkedTileSet {
+ get {
+ object obj = ResourceManager.GetObject("UT_LinkedTileSet", resourceCulture);
+ /// <summary>
+ /// </summary>
+ internal static byte[] UT_XYZ {
+ get {
+ object obj = ResourceManager.GetObject("UT_XYZ", resourceCulture);
Modified: sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Properties/Resources.resx
--- sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Properties/Resources.resx 2015-03-30 02:48:29 UTC (rev 8607)
+++ sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Properties/Resources.resx 2015-04-01 02:05:13 UTC (rev 8608)
@@ -119,6 +119,18 @@
</resheader>
<assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<data name="ResourceHeaderTemplate" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\ResourceHeaderTemplate.txt;System.String, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
+ <value>..\Resources\ResourceHeaderTemplate.txt;System.String, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;iso-8859-1</value>
</data>
+ <data name="UT_XYZ" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\Misc\UT_XYZ.tsd;System.Byte[], mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name="UT_BaseMap" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\Misc\UT_BaseMap.mdf;System.Byte[], mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name="UT_LinkedTileSet" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\Misc\UT_LinkedTileSet.mdf;System.Byte[], mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name="UT_BaseMapTileSet" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\Misc\UT_BaseMap.tsd;System.Byte[], mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
</root>
\ No newline at end of file
Deleted: sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_BaseMap.mdf
--- trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_BaseMap.mdf 2015-02-19 11:38:33 UTC (rev 8548)
+++ sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_BaseMap.mdf 2015-04-01 02:05:13 UTC (rev 8608)
@@ -1,15 +0,0 @@
-<?xml version="1.0" encoding="UTF-8"?>
-<MapDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="MapDefinition-3.0.0.xsd" version="3.0.0">
- <Name>Base Map</Name>
- <CoordinateSystem>GEOGCS["LL84",DATUM["WGS 84",SPHEROID["WGS 84",6378137,298.25722293287],TOWGS84[0,0,0,0,0,0,0]],PRIMEM["Greenwich",0],UNIT["Degrees",0.01745329252]]</CoordinateSystem>
- <Extents>
- <MinX>-87.79786601383196</MinX>
- <MaxX>-87.66452777186925</MaxX>
- <MinY>43.6868578621819</MinY>
- <MaxY>43.8037962206133</MaxY>
- </Extents>
- <BackgroundColor>FFF7E1D2</BackgroundColor>
- <TileSetSource>
- <ResourceId>{0}</ResourceId>
- </TileSetSource>
-</MapDefinition>
Copied: sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_BaseMap.mdf (from rev 8548, trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_BaseMap.mdf)
--- sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_BaseMap.mdf (rev 0)
@@ -0,0 +1,15 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<MapDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="MapDefinition-3.0.0.xsd" version="3.0.0">
+ <Name>Base Map</Name>
+ <CoordinateSystem>GEOGCS["LL84",DATUM["WGS 84",SPHEROID["WGS 84",6378137,298.25722293287],TOWGS84[0,0,0,0,0,0,0]],PRIMEM["Greenwich",0],UNIT["Degrees",0.01745329252]]</CoordinateSystem>
+ <Extents>
+ <MinX>-87.79786601383196</MinX>
+ <MaxX>-87.66452777186925</MaxX>
+ <MinY>43.6868578621819</MinY>
+ <MaxY>43.8037962206133</MaxY>
+ </Extents>
+ <BackgroundColor>FFF7E1D2</BackgroundColor>
+ <TileSetSource>
+ <ResourceId>{0}</ResourceId>
+ </TileSetSource>
+</MapDefinition>
Deleted: sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_BaseMap.tsd
--- trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_BaseMap.tsd 2015-02-19 11:38:33 UTC (rev 8548)
+++ sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_BaseMap.tsd 2015-04-01 02:05:13 UTC (rev 8608)
@@ -1,59 +0,0 @@
-<TileSetDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="TileSetDefinition-3.0.0.xsd">
- <TileStoreParameters>
- <TileProvider>Default</TileProvider>
- <Parameter>
- <Name>TilePath</Name>
- <Value>%MG_TILE_CACHE_PATH%</Value>
- </Parameter>
- <Parameter>
- <Name>TileWidth</Name>
- <Value>256</Value>
- </Parameter>
- <Parameter>
- <Name>TileHeight</Name>
- </Parameter>
- <Parameter>
- <Name>TileFormat</Name>
- <Value>PNG</Value>
- </Parameter>
- <Parameter>
- <Name>FiniteScaleList</Name>
- <Value>200000,100000,50000,25000,12500,6250,3125,1562.5,781.25,390.625</Value>
- </Parameter>
- <Parameter>
- <Name>CoordinateSystem</Name>
- <Value>{0}</Value>
- </Parameter>
- </TileStoreParameters>
- <Extents>
- <MinX>{1}</MinX>
- <MaxX>{3}</MaxX>
- <MinY>{2}</MinY>
- <MaxY>{4}</MaxY>
- </Extents>
- <BaseMapLayerGroup>
- <Name>BaseLayers</Name>
- <Visible>true</Visible>
- <ShowInLegend>true</ShowInLegend>
- <ExpandInLegend>true</ExpandInLegend>
- <LegendLabel>Base Layers</LegendLabel>
- <BaseMapLayer>
- <Name>Parcels</Name>
- <ResourceId>Library://UnitTests/Layers/Parcels.LayerDefinition</ResourceId>
- <Selectable>true</Selectable>
- <LegendLabel>Parcels</LegendLabel>
- <ExpandInLegend>false</ExpandInLegend>
- </BaseMapLayer>
- <BaseMapLayer>
- <Name>VotingDistricts</Name>
- <ResourceId>Library://UnitTests/Layers/VotingDistricts.LayerDefinition</ResourceId>
- <LegendLabel>Voting Districts</LegendLabel>
- </BaseMapLayer>
- </BaseMapLayerGroup>
-</TileSetDefinition>
Copied: sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_BaseMap.tsd (from rev 8548, trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_BaseMap.tsd)
--- sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_BaseMap.tsd (rev 0)
@@ -0,0 +1,59 @@
+<TileSetDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="TileSetDefinition-3.0.0.xsd">
+ <TileStoreParameters>
+ <TileProvider>Default</TileProvider>
+ <Parameter>
+ <Name>TilePath</Name>
+ <Value>%MG_TILE_CACHE_PATH%</Value>
+ </Parameter>
+ <Parameter>
+ <Name>TileWidth</Name>
+ <Value>256</Value>
+ </Parameter>
+ <Parameter>
+ <Name>TileHeight</Name>
+ </Parameter>
+ <Parameter>
+ <Name>TileFormat</Name>
+ <Value>PNG</Value>
+ </Parameter>
+ <Parameter>
+ <Name>FiniteScaleList</Name>
+ <Value>200000,100000,50000,25000,12500,6250,3125,1562.5,781.25,390.625</Value>
+ </Parameter>
+ <Parameter>
+ <Name>CoordinateSystem</Name>
+ <Value>{0}</Value>
+ </Parameter>
+ </TileStoreParameters>
+ <Extents>
+ <MinX>{1}</MinX>
+ <MaxX>{3}</MaxX>
+ <MinY>{2}</MinY>
+ <MaxY>{4}</MaxY>
+ </Extents>
+ <BaseMapLayerGroup>
+ <Name>BaseLayers</Name>
+ <Visible>true</Visible>
+ <ShowInLegend>true</ShowInLegend>
+ <ExpandInLegend>true</ExpandInLegend>
+ <LegendLabel>Base Layers</LegendLabel>
+ <BaseMapLayer>
+ <Name>Parcels</Name>
+ <ResourceId>Library://UnitTests/Layers/Parcels.LayerDefinition</ResourceId>
+ <Selectable>true</Selectable>
+ <LegendLabel>Parcels</LegendLabel>
+ <ExpandInLegend>false</ExpandInLegend>
+ </BaseMapLayer>
+ <BaseMapLayer>
+ <Name>VotingDistricts</Name>
+ <ResourceId>Library://UnitTests/Layers/VotingDistricts.LayerDefinition</ResourceId>
+ <LegendLabel>Voting Districts</LegendLabel>
+ </BaseMapLayer>
+ </BaseMapLayerGroup>
+</TileSetDefinition>
Deleted: sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_LinkedTileSet.mdf
--- trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_LinkedTileSet.mdf 2015-02-19 11:38:33 UTC (rev 8548)
+++ sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_LinkedTileSet.mdf 2015-04-01 02:05:13 UTC (rev 8608)
@@ -1,15 +0,0 @@
- <Name>Base Map linked to Tile Set</Name>
- <CoordinateSystem>{0}</CoordinateSystem>
- <Extents>
- <MinX>{1}</MinX>
- <MaxX>{3}</MaxX>
- <MinY>{2}</MinY>
- <MaxY>{4}</MaxY>
- </Extents>
- <TileSetSource>
- <ResourceId>{5}</ResourceId>
- </TileSetSource>
-</MapDefinition>
Copied: sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_LinkedTileSet.mdf (from rev 8548, trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_LinkedTileSet.mdf)
--- sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_LinkedTileSet.mdf (rev 0)
@@ -0,0 +1,15 @@
+ <Name>Base Map linked to Tile Set</Name>
+ <CoordinateSystem>{0}</CoordinateSystem>
+ <Extents>
+ <MinX>{1}</MinX>
+ <MaxX>{3}</MaxX>
+ <MinY>{2}</MinY>
+ <MaxY>{4}</MaxY>
+ </Extents>
+ <TileSetSource>
+ <ResourceId>{5}</ResourceId>
+ </TileSetSource>
+</MapDefinition>
Deleted: sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_XYZ.tsd
--- trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_XYZ.tsd 2015-02-19 11:38:33 UTC (rev 8548)
+++ sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_XYZ.tsd 2015-04-01 02:05:13 UTC (rev 8608)
@@ -1,43 +0,0 @@
- <TileProvider>XYZ</TileProvider>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- <Extents>
- </Extents>
- <BaseMapLayer>
- </BaseMapLayer>
- <BaseMapLayer>
- </BaseMapLayer>
Copied: sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_XYZ.tsd (from rev 8548, trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_XYZ.tsd)
--- sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/Resources/Misc/UT_XYZ.tsd (rev 0)
@@ -0,0 +1,43 @@
+ <TileProvider>XYZ</TileProvider>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Extents>
+ </Extents>
+ <BaseMapLayer>
+ </BaseMapLayer>
+ <BaseMapLayer>
+ </BaseMapLayer>
Modified: sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/TestMapGuideApi.csproj
--- sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/TestMapGuideApi.csproj 2015-03-30 02:48:29 UTC (rev 8607)
+++ sandbox/adsk/3.0m/UnitTest/WebTier/DotNet/TestMapGuideApi/TestMapGuideApi.csproj 2015-04-01 02:05:13 UTC (rev 8608)
@@ -11,6 +11,21 @@
<AssemblyName>OSGeo.MapGuide.Test.Web</AssemblyName>
<TargetFrameworkVersion>v4.5</TargetFrameworkVersion>
<FileAlignment>512</FileAlignment>
+ <IsWebBootstrapper>false</IsWebBootstrapper>
+ <PublishUrl>publish\</PublishUrl>
+ <Install>true</Install>
+ <InstallFrom>Disk</InstallFrom>
+ <UpdateEnabled>false</UpdateEnabled>
+ <UpdateMode>Foreground</UpdateMode>
+ <UpdateInterval>7</UpdateInterval>
+ <UpdateIntervalUnits>Days</UpdateIntervalUnits>
+ <UpdatePeriodically>false</UpdatePeriodically>
+ <UpdateRequired>false</UpdateRequired>
+ <MapFileExtensions>true</MapFileExtensions>
+ <ApplicationRevision>0</ApplicationRevision>
+ <ApplicationVersion>1.0.0.%2a</ApplicationVersion>
+ <UseApplicationTrust>false</UseApplicationTrust>
+ <BootstrapperEnabled>true</BootstrapperEnabled>
</PropertyGroup>
<PropertyGroup Condition="'$(Configuration)|$(Platform)' == 'Debug|x64'">
<DebugSymbols>true</DebugSymbols>
@@ -81,6 +96,7 @@
<Compile Include="DrawingService\DrawingServiceOperationExecutor.cs" />
<Compile Include="DrawingService\Operations.cs" />
<Compile Include="ExternalTests\CollectionTests.cs" />
+ <Compile Include="ExternalTests\MapTests.cs" />
<Compile Include="ExternalTests\RenderingServiceTests.cs" />
<Compile Include="ExternalTests\ResourceServiceTests.cs" />
<Compile Include="MapGuideTests.cs" />
@@ -113,8 +129,37 @@
</EmbeddedResource>
</ItemGroup>
<ItemGroup>
+ <None Include="Resources\Misc\UT_BaseMap.tsd" />
+ <None Include="Resources\Misc\UT_XYZ.tsd" />
<None Include="Resources\ResourceHeaderTemplate.txt" />
</ItemGroup>
+ <ItemGroup>
+ <None Include="Resources\Misc\UT_BaseMap.mdf">
+ <CopyToOutputDirectory>Always</CopyToOutputDirectory>
+ </None>
+ </ItemGroup>
+ <ItemGroup>
+ <BootstrapperPackage Include=".NETFramework,Version=v4.5">
+ <Visible>False</Visible>
+ <ProductName>Microsoft .NET Framework 4.5 %28x86 and x64%29</ProductName>
+ </BootstrapperPackage>
+ <BootstrapperPackage Include="Microsoft.Net.Client.3.5">
+ <ProductName>.NET Framework 3.5 SP1 Client Profile</ProductName>
+ <Install>false</Install>
+ <BootstrapperPackage Include="Microsoft.Net.Framework.3.5.SP1">
+ <ProductName>.NET Framework 3.5 SP1</ProductName>
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="Resources\Misc\UT_LinkedTileSet.mdf">
+ </None>
+ </ItemGroup>
<Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
<PropertyGroup>
<PreBuildEvent>call "$(SolutionDir)prebuild.bat" "$(ConfigurationName)" "$(PlatformName)"</PreBuildEvent>
Modified: sandbox/adsk/3.0m/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonApiGen.xml
--- sandbox/adsk/3.0m/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonApiGen.xml 2015-03-30 02:48:29 UTC (rev 8607)
+++ sandbox/adsk/3.0m/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonApiGen.xml 2015-04-01 02:05:13 UTC (rev 8608)
@@ -135,6 +135,8 @@
<Header path="../../../../Common/MapGuideCommon/Exception/SessionExpiredException.h" />
<Header path="../../../../Common/MapGuideCommon/Exception/SessionNotFoundException.h" />
<Header path="../../../../Common/MapGuideCommon/Exception/UnauthorizedAccessException.h" />
+ <Header path="../../../../Common/MapGuideCommon/Exception/UnknownTileProviderException.h" />
+ <Header path="../../../../Common/MapGuideCommon/Exception/UnsupportedTileProviderException.h" />
<Header path="../../../../Common/MapGuideCommon/Exception/UriFormatException.h" />
<Header path="../../../../Common/MapGuideCommon/Services/DrawingService.h" />
Modified: sandbox/adsk/3.0m/Web/src/MapGuideApi/MapGuideApiGen.xml
--- sandbox/adsk/3.0m/Web/src/MapGuideApi/MapGuideApiGen.xml 2015-03-30 02:48:29 UTC (rev 8607)
+++ sandbox/adsk/3.0m/Web/src/MapGuideApi/MapGuideApiGen.xml 2015-04-01 02:05:13 UTC (rev 8608)
@@ -401,6 +401,8 @@
<Header path="../../../Common/MapGuideCommon/Exception/SessionExpiredException.h" />
<Header path="../../../Common/MapGuideCommon/Exception/SessionNotFoundException.h" />
<Header path="../../../Common/MapGuideCommon/Exception/UnauthorizedAccessException.h" />
+ <Header path="../../../Common/MapGuideCommon/Exception/UnknownTileProviderException.h" />
+ <Header path="../../../Common/MapGuideCommon/Exception/UnsupportedTileProviderException.h" />
<Header path="../../../Common/MapGuideCommon/Exception/UriFormatException.h" />
<Header path="../../../Common/MapGuideCommon/Services/DrawingService.h" />
More information about the mapguide-commits
