[mapguide-commits] r8644 - in sandbox/jng/diet/Server/src: Core PostBuild
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri May 1 07:58:53 PDT 2015
Author: jng
Date: 2015-05-01 07:58:52 -0700 (Fri, 01 May 2015)
New Revision: 8644
   sandbox/jng/diet/Server/src/Core/serverconfig.ini
   sandbox/jng/diet/Server/src/PostBuild/PostBuild.mak
Fix and simplify PostBuild.mak to work in our new tree layout. Also change default MentorDictionaryPath to allow for command-line unit test or IDE debug/run without modifying serverconfig.ini. Debug/run without modifying serverconfig.ini assumes the following layout:
 * A checkout of MgDev is in $WORKING_COPY\MgDev
 * A checkout of Oem is in $WORKING_COPY\Oem
Modified: sandbox/jng/diet/Server/src/Core/serverconfig.ini
--- sandbox/jng/diet/Server/src/Core/serverconfig.ini	2015-05-01 13:07:49 UTC (rev 8643)
+++ sandbox/jng/diet/Server/src/Core/serverconfig.ini	2015-05-01 14:58:52 UTC (rev 8644)
@@ -100,7 +100,7 @@
 MachineIp                          = 127.0.0.1
 MaxLogFileSize                     = 1024
 MaxLogFileSizeEnabled              = 0
-MentorDictionaryPath               = ../../../Oem/CsMap/Dictionaries/
+MentorDictionaryPath               = ../../../../Oem/CsMap/Dictionaries/
 MentorUserDictionaryPath           =
 PreCacheMaps                       =
 Renderer                           = AGG
Modified: sandbox/jng/diet/Server/src/PostBuild/PostBuild.mak
--- sandbox/jng/diet/Server/src/PostBuild/PostBuild.mak	2015-05-01 13:07:49 UTC (rev 8643)
+++ sandbox/jng/diet/Server/src/PostBuild/PostBuild.mak	2015-05-01 14:58:52 UTC (rev 8644)
@@ -1,118 +1,43 @@
-..\..\bin\debug\MgFoundationd.dll : ..\..\..\Common\bin\debug\MgFoundationd.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug\MgFoundationd.dll ..\..\bin\debug\
+CopyBinariesDebug:
+    xcopy /r /d /y ..\..\..\Common\bin\debug\*.* "..\..\bin\debug\"
+    xcopy /r /d /y $(MG_OEM_ACE_BIN_DIR)\ACEd.dll "..\..\bin\debug\"
+    xcopy /r /d /y $(MG_OEM_ACE_BIN_DIR)\ACEd.pdb "..\..\bin\debug\"
+    xcopy /r /d /y $(MG_OEM_GD_BIN_DIR)\gd.dll "..\..\bin\debug\"
+    xcopy /r /d /y $(MG_OEM_GD_BIN_DIR)\gd.pdb "..\..\bin\debug\"
+    xcopy /r /d /y $(MG_OEM_GEOS_BIN_DIR)\GEOSd.dll "..\..\bin\debug\"
+    xcopy /r /d /y $(MG_OEM_GEOS_BIN_DIR)\GEOSd.pdb "..\..\bin\debug\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\libdb48d.dll "..\..\bin\debug\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\libdb48d.pdb "..\..\bin\debug\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\libdbxml25d.dll "..\..\bin\debug\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\libdbxml25d.pdb "..\..\bin\debug\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\xqilla24d.dll "..\..\bin\debug\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\xqilla24d.pdb "..\..\bin\debug\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\xerces-c_3_1mgD.dll "..\..\bin\debug\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\xerces-c_3_1mgD.pdb "..\..\bin\debug\"
+    xcopy /r /d /y ..\..\src\Core\serverconfig.ini "..\..\bin\debug\"
-..\..\bin\debug\MgFoundationd.pdb : ..\..\..\Common\bin\debug\MgFoundationd.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug\MgFoundationd.pdb ..\..\bin\debug\
-..\..\bin\debug\MgPlatformBased.dll : ..\..\..\Common\bin\debug\MgPlatformBased.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug\MgPlatformBased.dll ..\..\bin\debug\
-..\..\bin\debug\MgPlatformBased.pdb : ..\..\..\Common\bin\debug\MgPlatformBased.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug\MgPlatformBased.pdb ..\..\bin\debug\
-..\..\bin\debug\MgGeometryd.dll : ..\..\..\Common\bin\debug\MgGeometryd.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug\MgGeometryd.dll ..\..\bin\debug\
-..\..\bin\debug\MgGeometryd.pdb : ..\..\..\Common\bin\debug\MgGeometryd.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug\MgGeometryd.pdb ..\..\bin\debug\
-..\..\bin\debug\MgMapGuideCommond.dll : ..\..\..\Common\bin\debug\MgMapGuideCommond.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug\MgMapGuideCommond.dll ..\..\bin\debug\
-..\..\bin\debug\MgMapGuideCommond.pdb : ..\..\..\Common\bin\debug\MgMapGuideCommond.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug\MgMapGuideCommond.pdb ..\..\bin\debug\
-..\..\bin\debug\MgMdfModeld.dll : ..\..\..\Common\bin\debug\MgMdfModeld.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug\MgMdfModeld.dll ..\..\bin\debug\
-..\..\bin\debug\MgMdfModeld.pdb : ..\..\..\Common\bin\debug\MgMdfModeld.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug\MgMdfModeld.pdb ..\..\bin\debug\
-..\..\bin\debug\MgMdfParserd.dll : ..\..\..\Common\bin\debug\MgMdfParserd.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug\MgMdfParserd.dll ..\..\bin\debug\
-..\..\bin\debug\MgMdfParserd.pdb : ..\..\..\Common\bin\debug\MgMdfParserd.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug\MgMdfParserd.pdb ..\..\bin\debug\
-..\..\bin\debug\MgStylizationd.dll : ..\..\..\Common\bin\debug\MgStylizationd.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug\MgStylizationd.dll ..\..\bin\debug\
-..\..\bin\debug\MgStylizationd.pdb : ..\..\..\Common\bin\debug\MgStylizationd.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug\MgStylizationd.pdb ..\..\bin\debug\
-..\..\bin\debug\MgRenderersd.dll : ..\..\..\Common\bin\debug\MgRenderersd.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug\MgRenderersd.dll ..\..\bin\debug\
-..\..\bin\debug\MgRenderersd.pdb : ..\..\..\Common\bin\debug\MgRenderersd.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug\MgRenderersd.pdb ..\..\bin\debug\
-..\..\bin\debug\ACEd.dll : ..\..\..\Oem\ACE\ACE_wrappers\lib\debug\ACEd.dll
-    xcopy /r /d /y ..\..\..\Oem\ACE\ACE_wrappers\lib\debug\ACEd.dll ..\..\bin\debug\
-..\..\bin\debug\ACEd.pdb : ..\..\..\Oem\ACE\ACE_wrappers\lib\debug\ACEd.pdb
-    xcopy /r /d /y ..\..\..\Oem\ACE\ACE_wrappers\lib\debug\ACEd.pdb ..\..\bin\debug\
-..\..\bin\debug\gd.dll : ..\..\..\Oem\gd\build\win32\gd\Debug\gd.dll
-    xcopy /r /d /y ..\..\..\Oem\gd\build\win32\gd\Debug\gd.dll ..\..\bin\debug\
-..\..\bin\debug\gd.pdb : ..\..\..\Oem\gd\build\win32\gd\Debug\gd.pdb
-    xcopy /r /d /y ..\..\..\Oem\gd\build\win32\gd\Debug\gd.pdb ..\..\bin\debug\
-..\..\bin\debug\GEOSd.dll : ..\..\..\Oem\geos\VisualStudio\Debug\GEOSd.dll
-    xcopy /r /d /y ..\..\..\Oem\geos\VisualStudio\Debug\GEOSd.dll ..\..\bin\debug\
-..\..\bin\debug\GEOSd.pdb : ..\..\..\Oem\geos\VisualStudio\Debug\GEOSd.pdb
-    xcopy /r /d /y ..\..\..\Oem\geos\VisualStudio\Debug\GEOSd.pdb ..\..\bin\debug\
-..\..\bin\debug\libdb48d.dll : ..\..\..\Oem\dbxml\bin\debug\libdb48d.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\debug\libdb48d.dll ..\..\bin\debug\
-..\..\bin\debug\libdb48d.pdb : ..\..\..\Oem\dbxml\bin\debug\libdb48d.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\debug\libdb48d.pdb ..\..\bin\debug\
-..\..\bin\debug\libdbxml25d.dll : ..\..\..\Oem\dbxml\bin\debug\libdbxml25d.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\debug\libdbxml25d.dll ..\..\bin\debug\
-..\..\bin\debug\libdbxml25d.pdb : ..\..\..\Oem\dbxml\bin\debug\libdbxml25d.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\debug\libdbxml25d.pdb ..\..\bin\debug\
-..\..\bin\debug\xqilla24d.dll : ..\..\..\Oem\dbxml\bin\debug\xqilla24d.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\debug\xqilla24d.dll ..\..\bin\debug\
-..\..\bin\debug\xqilla24d.pdb : ..\..\..\Oem\dbxml\bin\debug\xqilla24d.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\debug\xqilla24d.pdb ..\..\bin\debug\
-..\..\bin\debug\xerces-c_3_1mgD.dll : ..\..\..\Oem\dbxml\bin\debug\xerces-c_3_1mgD.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\debug\xerces-c_3_1mgD.dll ..\..\bin\debug\
-..\..\bin\debug\xerces-c_3_1mgD.pdb : ..\..\..\Oem\dbxml\bin\debug\xerces-c_3_1mgD.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\debug\xerces-c_3_1mgD.pdb ..\..\bin\debug\
-..\..\bin\debug\serverconfig.ini : ..\..\src\Core\serverconfig.ini
-    xcopy /r /d /y ..\..\src\Core\serverconfig.ini ..\..\bin\debug\
-CopyFdoComponentsDebug : ..\..\..\Oem\FDO\*.*
+CopyFdoComponentsDebug:
     if NOT EXIST ..\..\bin\debug\FDO\nul mkdir ..\..\bin\debug\FDO
-    xcopy /r /d /y /s ..\..\..\Oem\FDO\bin\Release ..\..\bin\debug\FDO\
+    xcopy /r /d /y /s $(MG_OEM_FDO_ROOT)\bin\Release ..\..\bin\debug\FDO\
-CopyFdoProvidersDebug : ..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml
-    xcopy /r /d /y "..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml" ..\..\bin\debug\FDO\
+CopyFdoProvidersDebug:
+    xcopy /r /d /y "$(MG_OEM_FDO_ROOT)\ProviderList\ServerCommunity\providers.xml" ..\..\bin\debug\FDO\
-CopySchemaDebug : ..\..\..\Common\Schema\*.xsd
+CopySchemaDebug:
     if NOT EXIST ..\..\bin\debug\Schema\nul mkdir ..\..\bin\debug\Schema
     xcopy /r /d /y ..\..\..\Common\Schema\*.xsd ..\..\bin\debug\Schema
-CopyResourcesDebug : ..\..\..\Common\MapGuideCommon\Resources\mapguide_en.res
+CopyResourcesDebug:
     if NOT EXIST ..\..\bin\debug\Resources\nul mkdir ..\..\bin\debug\Resources
     xcopy /r /d /y "..\..\..\Common\MapGuideCommon\Resources\mapguide_en.res" ..\..\bin\debug\Resources\
-CopyOgcFilesDebug : ..\..\src\wms\*.awd ..\..\src\wfs\*.awd
+CopyOgcFilesDebug:
     if NOT EXIST ..\..\bin\debug\wms\nul mkdir ..\..\bin\debug\wms
     xcopy /r /d /y "..\..\src\wms\*.awd"       ..\..\bin\debug\wms
     if NOT EXIST ..\..\bin\debug\wfs\nul mkdir ..\..\bin\debug\wfs
     xcopy /r /d /y "..\..\src\wfs\*.awd"       ..\..\bin\debug\wfs
-CreatePathsDebug :
+CreatePathsDebug:
     if NOT EXIST ..\..\bin\debug\Logs\nul mkdir ..\..\bin\debug\Logs
     if NOT EXIST ..\..\bin\debug\Packages\nul mkdir ..\..\bin\debug\Packages
     if NOT EXIST ..\..\bin\debug\Temp\nul mkdir ..\..\bin\debug\Temp
@@ -126,269 +51,55 @@
     if NOT EXIST ..\..\bin\debug\Repositories\Site\nul mkdir ..\..\bin\debug\Repositories\Site
     if NOT EXIST ..\..\bin\debug\Repositories\TileCache\nul mkdir ..\..\bin\debug\Repositories\TileCache
-debug : ..\..\bin\debug\MgFoundationd.dll \
-        ..\..\bin\debug\MgFoundationd.pdb \
-        ..\..\bin\debug\MgGeometryd.dll \
-        ..\..\bin\debug\MgGeometryd.pdb \
-        ..\..\bin\debug\MgPlatformBased.dll \
-        ..\..\bin\debug\MgPlatformBased.pdb \
-        ..\..\bin\debug\MgMapGuideCommond.dll \
-        ..\..\bin\debug\MgMapGuideCommond.pdb \
-        ..\..\bin\debug\MgMdfModeld.dll \
-        ..\..\bin\debug\MgMdfModeld.pdb \
-        ..\..\bin\debug\MgMdfParserd.dll \
-        ..\..\bin\debug\MgMdfParserd.pdb \
-        ..\..\bin\debug\MgStylizationd.dll \
-        ..\..\bin\debug\MgStylizationd.pdb \
-        ..\..\bin\debug\MgRenderersd.dll \
-        ..\..\bin\debug\MgRenderersd.pdb \
-        ..\..\bin\debug\ACEd.dll \
-        ..\..\bin\debug\ACEd.pdb \
-        ..\..\bin\debug\gd.dll \
-        ..\..\bin\debug\gd.pdb \
-        ..\..\bin\debug\GEOSd.dll \
-        ..\..\bin\debug\GEOSd.pdb \
-        ..\..\bin\debug\libdb48d.dll \
-        ..\..\bin\debug\libdb48d.pdb \
-        ..\..\bin\debug\libdbxml25d.dll \
-        ..\..\bin\debug\libdbxml25d.pdb \
-        ..\..\bin\debug\xqilla24d.dll \
-        ..\..\bin\debug\xqilla24d.pdb \
-        ..\..\bin\debug\xerces-c_3_1mgD.dll \
-        ..\..\bin\debug\xerces-c_3_1mgD.pdb \
-        ..\..\bin\debug\serverconfig.ini \
-        ..\..\bin\UnitTestFiles\LibraryRepositoryContent.xml \
-        ..\..\bin\UnitTestFiles\SampleRepositoryHeader.xml \
-        ..\..\bin\UnitTestFiles\SampleRepositoryContent.xml \
-        ..\..\bin\UnitTestFiles\TEST.LayerDefinition \
-        ..\..\bin\UnitTestFiles\TEST.FeatureSource \
-        ..\..\bin\UnitTestFiles\TEST.sdf \
-        ..\..\bin\UnitTestFiles\UT_BaseMap.mdf \
-        ..\..\bin\UnitTestFiles\UT_BaseMap.tsd \
-        ..\..\bin\UnitTestFiles\UT_XYZ.tsd \
-        ..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf \
-        ..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf \
-        ..\..\bin\UnitTestFiles\UT_Parcels.fs \
-        ..\..\bin\UnitTestFiles\UT_Parcels.ldf \
-        ..\..\bin\UnitTestFiles\UT_Parcels.sdf \
-        ..\..\bin\UnitTestFiles\UT_RoadCenterLines.fs \
-        ..\..\bin\UnitTestFiles\UT_RoadCenterLines.ldf \
-        ..\..\bin\UnitTestFiles\UT_RoadCenterLines.sdf \
-        ..\..\bin\UnitTestFiles\UT_VotingDistricts.fs \
-        ..\..\bin\UnitTestFiles\UT_VotingDistricts.ldf \
-        ..\..\bin\UnitTestFiles\UT_VotingDistrictsFunctions.ldf \
-        ..\..\bin\UnitTestFiles\UT_VotingDistricts.sdf \
-        ..\..\bin\UnitTestFiles\UT_AllElements.pl \
-        ..\..\bin\UnitTestFiles\UT_NoLegend.pl \
-        ..\..\bin\UnitTestFiles\UT_SymbolMart.sl \
-        ..\..\bin\UnitTestFiles\UT_Symbols.dwf \
-        ..\..\bin\UnitTestFiles\UT_SheboyganWithWatermark.mdf \
-        ..\..\bin\UnitTestFiles\UT_PoweredByMapGuide.wdf \
-        ..\..\bin\UnitTestFiles\UT_Sheboygan.mdf \
-        ..\..\bin\UnitTestFiles\UT_Sheboygan_833.mdf \
-        ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.sdf \
-        ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.fs \
-        ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.ldf \
-        ..\..\bin\UnitTestFiles\UT_Rail.sdf \
-        ..\..\bin\UnitTestFiles\UT_Rail.fs \
-        ..\..\bin\UnitTestFiles\UT_Rail.ldf \
-        ..\..\bin\UnitTestFiles\UT_Rail.wdf \
-        ..\..\bin\UnitTestFiles\UT_Rail_Watermark.ldf \
-        ..\..\bin\UnitTestFiles\UT_MultiCTS.ldf \
-        ..\..\bin\UnitTestFiles\UT_MultiCTSWithTheme.ldf \
-        ..\..\bin\UnitTestFiles\UT_MultiFTS.ldf \
-        ..\..\bin\UnitTestFiles\UT_MultiFTSSingleCTS.ldf \
-        ..\..\bin\UnitTestFiles\UT_MultiFTSWithTheme.ldf \
-        ..\..\bin\UnitTestFiles\UT_SingleFTSMultiCTS.ldf \
-        ..\..\bin\UnitTestFiles\UT_RotatedPointStyles.ldf \
-        ..\..\bin\UnitTestFiles\Sheboygan_Parcels.FeatureSource \
-        ..\..\bin\UnitTestFiles\Sheboygan_Parcels.sdf \
-        ..\..\bin\UnitTestFiles\Sheboygan_BuildingOutlines.FeatureSource \
-        ..\..\bin\UnitTestFiles\Sheboygan_BuildingOutlines.sdf \
-        ..\..\bin\UnitTestFiles\Sheboygan_VotingDistricts.FeatureSource \
-        ..\..\bin\UnitTestFiles\Sheboygan_VotingDistricts.sdf \
-        ..\..\bin\UnitTestFiles\Empty.FeatureSource \
-        ..\..\bin\UnitTestFiles\Empty.sdf \
-        ..\..\bin\UnitTestFiles\World.mgp \
-        ..\..\bin\UnitTestFiles\World_Countries.sdf \
-        ..\..\bin\UnitTestFiles\Shuttle.zip \
-        ..\..\bin\UnitTestFiles\test.dwf \
-        ..\..\bin\UnitTestFiles\SpaceShip.dwf \
-        ..\..\bin\UnitTestFiles\MapGuideDrawingSource.xml \
-        ..\..\bin\UnitTestFiles\SpaceShipDrawingSource.xml \
-        ..\..\bin\UnitTestFiles\Redding_Parcels.FeatureSource \
-        ..\..\bin\UnitTestFiles\Redding_Parcels.shp \
-        ..\..\bin\UnitTestFiles\Redding_Parcels.dbf \
-        ..\..\bin\UnitTestFiles\Redding_Parcels.shx \
-        ..\..\bin\UnitTestFiles\1.1.1.mgd \
-        ..\..\bin\UnitTestFiles\epsgcodes.txt \
-        ..\..\bin\UnitTestFiles\ogcwkts.txt \
-        ..\..\bin\UnitTestFiles\UT_GetMapKmlResult.txt \
-        ..\..\bin\UnitTestFiles\UT_GetLayerKmlResult.txt \
-        ..\..\bin\UnitTestFiles\UT_GetFeaturesKmlResult.txt \
-        ..\..\bin\UnitTestFiles\TESTChainedInner1ToManyJoin.FeatureSource \
-        ..\..\bin\UnitTestFiles\MdfTestMap.mdf \
-        ..\..\bin\UnitTestFiles\MdfTestTypeStyles.ldf \
-        ..\..\bin\UnitTestFiles\MdfTestCompoundSymbol.sd \
-        ..\..\bin\UnitTestFiles\MdfTestSimpleSymbol.sd \
-        ..\..\bin\UnitTestFiles\areasymbol.sd \
-        ..\..\bin\UnitTestFiles\linesymbol.sd \
-        ..\..\bin\UnitTestFiles\symbol.sd \
-        ..\..\bin\UnitTestFiles\symbolp.sd \
-        ..\..\bin\UnitTestFiles\MTYP1500a.sd \
-        ..\..\bin\UnitTestFiles\UT_SymbologyLines.fs \
-        ..\..\bin\UnitTestFiles\UT_SymbologyLines.ldf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyLines.mdf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyLines.sdf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyLinesCrossTick.ldf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyLinesCrossTick.mdf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyPoints.fs \
-        ..\..\bin\UnitTestFiles\UT_SymbologyPoints.ldf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyPoints.mdf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyPoints.sdf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyPointsParam.ldf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyPointsParam.mdf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyRoads.fs \
-        ..\..\bin\UnitTestFiles\UT_SymbologyRoads.ldf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyRoads.mdf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyRoads.sdf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyParcels.ldf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyPolygons.mdf \
-        ..\..\bin\UnitTestFiles\UT_Annotation1.ldf \
-        ..\..\bin\UnitTestFiles\UT_Annotation1.mdf \
-        ..\..\bin\UnitTestFiles\UT_Annotation2.ldf \
-        ..\..\bin\UnitTestFiles\UT_Annotation2.mdf \
-        ..\..\bin\UnitTestFiles\UT_Annotation3.ldf \
-        ..\..\bin\UnitTestFiles\UT_Annotation3.mdf \
-        ..\..\bin\UnitTestFiles\SavePointTest.sqlite \
-        ..\..\bin\UnitTestFiles\SavePointTest.FeatureSource \
-        ..\..\bin\UnitTestFiles\UT_Parcels_SQLite_Join.FeatureSource \
-        ..\..\bin\UnitTestFiles\UT_FdoJoin.FeatureSource \
-        ..\..\bin\UnitTestFiles\ParcelsJoinTest.sqlite \
-        ..\..\bin\UnitTestFiles\JoinTest.sqlite \
-        CopyFdoComponentsDebug \
-        CopyFdoProvidersDebug \
-        CopySchemaDebug \
-        CopyResourcesDebug \
-        CreatePathsDebug \
-        CopyOgcFilesDebug
+debug: CopyBinariesDebug \
+       CopyTestData \
+       CopyFdoComponentsDebug \
+       CopyFdoProvidersDebug \
+       CopySchemaDebug \
+       CopyResourcesDebug \
+       CreatePathsDebug \
+       CopyOgcFilesDebug
+CopyBinariesDebug64:
+    xcopy /r /d /y ..\..\..\Common\bin\debug64\*.* "..\..\bin\debug64\"
+    xcopy /r /d /y $(MG_OEM_ACE_BIN_DIR)\ACEd.dll "..\..\bin\debug64\"
+    xcopy /r /d /y $(MG_OEM_ACE_BIN_DIR)\ACEd.pdb "..\..\bin\debug64\"
+    xcopy /r /d /y $(MG_OEM_GD_BIN_DIR)\gd.dll "..\..\bin\debug64\"
+    xcopy /r /d /y $(MG_OEM_GD_BIN_DIR)\gd.pdb "..\..\bin\debug64\"
+    xcopy /r /d /y $(MG_OEM_GEOS_BIN_DIR)\GEOSd.dll "..\..\bin\debug64\"
+    xcopy /r /d /y $(MG_OEM_GEOS_BIN_DIR)\GEOSd.pdb "..\..\bin\debug64\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\libdb48d.dll "..\..\bin\debug64\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\libdb48d.pdb "..\..\bin\debug64\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\libdbxml25d.dll "..\..\bin\debug64\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\libdbxml25d.pdb "..\..\bin\debug64\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\xqilla24d.dll "..\..\bin\debug64\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\xqilla24d.pdb "..\..\bin\debug64\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\xerces-c_3_1mgD.dll "..\..\bin\debug64\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\xerces-c_3_1mgD.pdb "..\..\bin\debug64\"
+    xcopy /r /d /y ..\..\src\Core\serverconfig.ini "..\..\bin\debug64\"
-..\..\bin\debug64\MgFoundationd.dll : ..\..\..\Common\bin\debug64\MgFoundationd.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug64\MgFoundationd.dll ..\..\bin\debug64\
-..\..\bin\debug64\MgFoundationd.pdb : ..\..\..\Common\bin\debug64\MgFoundationd.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug64\MgFoundationd.pdb ..\..\bin\debug64\
-..\..\bin\debug64\MgPlatformBased.dll : ..\..\..\Common\bin\debug64\MgPlatformBased.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug64\MgPlatformBased.dll ..\..\bin\debug64\
-..\..\bin\debug64\MgPlatformBased.pdb : ..\..\..\Common\bin\debug64\MgPlatformBased.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug64\MgPlatformBased.pdb ..\..\bin\debug64\
-..\..\bin\debug64\MgGeometryd.dll : ..\..\..\Common\bin\debug64\MgGeometryd.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug64\MgGeometryd.dll ..\..\bin\debug64\
-..\..\bin\debug64\MgGeometryd.pdb : ..\..\..\Common\bin\debug64\MgGeometryd.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug64\MgGeometryd.pdb ..\..\bin\debug64\
-..\..\bin\debug64\MgMapGuideCommond.dll : ..\..\..\Common\bin\debug64\MgMapGuideCommond.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug64\MgMapGuideCommond.dll ..\..\bin\debug64\
-..\..\bin\debug64\MgMapGuideCommond.pdb : ..\..\..\Common\bin\debug64\MgMapGuideCommond.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug64\MgMapGuideCommond.pdb ..\..\bin\debug64\
-..\..\bin\debug64\MgMdfModeld.dll : ..\..\..\Common\bin\debug64\MgMdfModeld.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug64\MgMdfModeld.dll ..\..\bin\debug64\
-..\..\bin\debug64\MgMdfModeld.pdb : ..\..\..\Common\bin\debug64\MgMdfModeld.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug64\MgMdfModeld.pdb ..\..\bin\debug64\
-..\..\bin\debug64\MgMdfParserd.dll : ..\..\..\Common\bin\debug64\MgMdfParserd.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug64\MgMdfParserd.dll ..\..\bin\debug64\
-..\..\bin\debug64\MgMdfParserd.pdb : ..\..\..\Common\bin\debug64\MgMdfParserd.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug64\MgMdfParserd.pdb ..\..\bin\debug64\
-..\..\bin\debug64\MgStylizationd.dll : ..\..\..\Common\bin\debug64\MgStylizationd.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug64\MgStylizationd.dll ..\..\bin\debug64\
-..\..\bin\debug64\MgStylizationd.pdb : ..\..\..\Common\bin\debug64\MgStylizationd.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug64\MgStylizationd.pdb ..\..\bin\debug64\
-..\..\bin\debug64\MgRenderersd.dll : ..\..\..\Common\bin\debug64\MgRenderersd.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug64\MgRenderersd.dll ..\..\bin\debug64\
-..\..\bin\debug64\MgRenderersd.pdb : ..\..\..\Common\bin\debug64\MgRenderersd.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug64\MgRenderersd.pdb ..\..\bin\debug64\
-..\..\bin\debug64\ACEd.dll : ..\..\..\Oem\ACE\ACE_wrappers\lib64\debug\ACEd.dll
-    xcopy /r /d /y ..\..\..\Oem\ACE\ACE_wrappers\lib64\debug\ACEd.dll ..\..\bin\debug64\
-..\..\bin\debug64\ACEd.pdb : ..\..\..\Oem\ACE\ACE_wrappers\lib64\debug\ACEd.pdb
-    xcopy /r /d /y ..\..\..\Oem\ACE\ACE_wrappers\lib64\debug\ACEd.pdb ..\..\bin\debug64\
-..\..\bin\debug64\gd.dll : ..\..\..\Oem\gd\build\win32\gd\debug64\gd.dll
-    xcopy /r /d /y ..\..\..\Oem\gd\build\win32\gd\debug64\gd.dll ..\..\bin\debug64\
-..\..\bin\debug64\gd.pdb : ..\..\..\Oem\gd\build\win32\gd\debug64\gd.pdb
-    xcopy /r /d /y ..\..\..\Oem\gd\build\win32\gd\debug64\gd.pdb ..\..\bin\debug64\
-..\..\bin\debug64\GEOSd.dll : ..\..\..\Oem\geos\VisualStudio\Debug64\GEOSd.dll
-    xcopy /r /d /y ..\..\..\Oem\geos\VisualStudio\Debug64\GEOSd.dll ..\..\bin\debug64\
-..\..\bin\debug64\GEOSd.pdb : ..\..\..\Oem\geos\VisualStudio\Debug64\GEOSd.pdb
-    xcopy /r /d /y ..\..\..\Oem\geos\VisualStudio\Debug64\GEOSd.pdb ..\..\bin\debug64\
-..\..\bin\debug64\libdb48d.dll : ..\..\..\Oem\dbxml\bin64\debug\libdb48d.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\debug\libdb48d.dll ..\..\bin\debug64\
-..\..\bin\debug64\libdb48d.pdb : ..\..\..\Oem\dbxml\bin64\debug\libdb48d.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\debug\libdb48d.pdb ..\..\bin\debug64\
-..\..\bin\debug64\libdbxml25d.dll : ..\..\..\Oem\dbxml\bin64\debug\libdbxml25d.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\debug\libdbxml25d.dll ..\..\bin\debug64\
-..\..\bin\debug64\libdbxml25d.pdb : ..\..\..\Oem\dbxml\bin64\debug\libdbxml25d.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\debug\libdbxml25d.pdb ..\..\bin\debug64\
-..\..\bin\debug64\xqilla24d.dll : ..\..\..\Oem\dbxml\bin64\debug\xqilla24d.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\debug\xqilla24d.dll ..\..\bin\debug64\
-..\..\bin\debug64\xqilla24d.pdb : ..\..\..\Oem\dbxml\bin64\debug\xqilla24d.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\debug\xqilla24d.pdb ..\..\bin\debug64\
-..\..\bin\debug64\xerces-c_3_1mgD.dll : ..\..\..\Oem\dbxml\bin64\debug\xerces-c_3_1mgD.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\debug\xerces-c_3_1mgD.dll ..\..\bin\debug64\
-..\..\bin\debug64\xerces-c_3_1mgD.pdb : ..\..\..\Oem\dbxml\bin64\debug\xerces-c_3_1mgD.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\debug\xerces-c_3_1mgD.pdb ..\..\bin\debug64\
-..\..\bin\debug64\serverconfig.ini : ..\..\src\Core\serverconfig.ini
-    xcopy /r /d /y ..\..\src\Core\serverconfig.ini ..\..\bin\debug64\
-CopyFdoComponentsDebug64 : ..\..\..\Oem\FDO\*.*
+CopyFdoComponentsDebug64:
     if NOT EXIST ..\..\bin\debug64\FDO\nul mkdir ..\..\bin\debug64\FDO
-    xcopy /r /d /y /s ..\..\..\Oem\FDO\bin\release64 ..\..\bin\debug64\FDO\
+    xcopy /r /d /y /s $(MG_OEM_FDO_ROOT)\bin\release64 ..\..\bin\debug64\FDO\
-CopyFdoProvidersDebug64 : ..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml
-    xcopy /r /d /y "..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml" ..\..\bin\debug64\FDO\
+CopyFdoProvidersDebug64:
+    xcopy /r /d /y "$(MG_OEM_FDO_ROOT)\ProviderList\ServerCommunity\providers.xml" ..\..\bin\debug64\FDO\
-CopySchemaDebug64 : ..\..\..\Common\Schema\*.xsd
+CopySchemaDebug64:
     if NOT EXIST ..\..\bin\debug64\Schema\nul mkdir ..\..\bin\debug64\Schema
     xcopy /r /d /y ..\..\..\Common\Schema\*.xsd ..\..\bin\debug64\Schema
-CopyResourcesDebug64 : ..\..\..\Common\MapGuideCommon\Resources\mapguide_en.res
+CopyResourcesDebug64:
     if NOT EXIST ..\..\bin\debug64\Resources\nul mkdir ..\..\bin\debug64\Resources
     xcopy /r /d /y "..\..\..\Common\MapGuideCommon\Resources\mapguide_en.res" ..\..\bin\debug64\Resources\
-CopyOgcFilesDebug64 : ..\..\src\wms\*.awd ..\..\src\wfs\*.awd
+CopyOgcFilesDebug64:
     if NOT EXIST ..\..\bin\debug64\wms\nul mkdir ..\..\bin\debug64\wms
     xcopy /r /d /y "..\..\src\wms\*.awd"       ..\..\bin\debug64\wms
     if NOT EXIST ..\..\bin\debug64\wfs\nul mkdir ..\..\bin\debug64\wfs
     xcopy /r /d /y "..\..\src\wfs\*.awd"       ..\..\bin\debug64\wfs
-CreatePathsDebug64 :
+CreatePathsDebug64:
     if NOT EXIST ..\..\bin\debug64\Logs\nul mkdir ..\..\bin\debug64\Logs
     if NOT EXIST ..\..\bin\debug64\Packages\nul mkdir ..\..\bin\debug64\Packages
     if NOT EXIST ..\..\bin\debug64\Temp\nul mkdir ..\..\bin\debug64\Temp
@@ -402,269 +113,55 @@
     if NOT EXIST ..\..\bin\debug64\Repositories\Site\nul mkdir ..\..\bin\debug64\Repositories\Site
     if NOT EXIST ..\..\bin\debug64\Repositories\TileCache\nul mkdir ..\..\bin\debug64\Repositories\TileCache
-debug64 : ..\..\bin\debug64\MgFoundationd.dll \
-        ..\..\bin\debug64\MgFoundationd.pdb \
-        ..\..\bin\debug64\MgGeometryd.dll \
-        ..\..\bin\debug64\MgGeometryd.pdb \
-        ..\..\bin\debug64\MgPlatformBased.dll \
-        ..\..\bin\debug64\MgPlatformBased.pdb \
-        ..\..\bin\debug64\MgMapGuideCommond.dll \
-        ..\..\bin\debug64\MgMapGuideCommond.pdb \
-        ..\..\bin\debug64\MgMdfModeld.dll \
-        ..\..\bin\debug64\MgMdfModeld.pdb \
-        ..\..\bin\debug64\MgMdfParserd.dll \
-        ..\..\bin\debug64\MgMdfParserd.pdb \
-        ..\..\bin\debug64\MgStylizationd.dll \
-        ..\..\bin\debug64\MgStylizationd.pdb \
-        ..\..\bin\debug64\MgRenderersd.dll \
-        ..\..\bin\debug64\MgRenderersd.pdb \
-        ..\..\bin\debug64\ACEd.dll \
-        ..\..\bin\debug64\ACEd.pdb \
-        ..\..\bin\debug64\gd.dll \
-        ..\..\bin\debug64\gd.pdb \
-        ..\..\bin\debug64\GEOSd.dll \
-        ..\..\bin\debug64\GEOSd.pdb \
-        ..\..\bin\debug64\libdb48d.dll \
-        ..\..\bin\debug64\libdb48d.pdb \
-        ..\..\bin\debug64\libdbxml25d.dll \
-        ..\..\bin\debug64\libdbxml25d.pdb \
-        ..\..\bin\debug64\xqilla24d.dll \
-        ..\..\bin\debug64\xqilla24d.pdb \
-        ..\..\bin\debug64\xerces-c_3_1mgD.dll \
-        ..\..\bin\debug64\xerces-c_3_1mgD.pdb \
-        ..\..\bin\debug64\serverconfig.ini \
-        CopyFdoComponentsDebug64 \
-        CopyFdoProvidersDebug64 \
-        CopySchemaDebug64 \
-        CopyResourcesDebug64 \
-        CreatePathsDebug64 \
-        CopyOgcFilesDebug64
+debug64: CopyBinaresDebug64 \
+         CopyTestData \
+         CopyFdoComponentsDebug64 \
+         CopyFdoProvidersDebug64 \
+         CopySchemaDebug64 \
+         CopyResourcesDebug64 \
+         CreatePathsDebug64 \
+         CopyOgcFilesDebug64
+CopyBinariesRelease:
+    xcopy /r /d /y ..\..\..\Common\bin\release\*.* "..\..\bin\release\"
+    xcopy /r /d /y $(MG_OEM_ACE_BIN_DIR)\ACE.dll "..\..\bin\release\"
+    xcopy /r /d /y $(MG_OEM_ACE_BIN_DIR)\ACE.pdb "..\..\bin\release\"
+    xcopy /r /d /y $(MG_OEM_GD_BIN_DIR)\gd.dll "..\..\bin\release\"
+    xcopy /r /d /y $(MG_OEM_GD_BIN_DIR)\gd.pdb "..\..\bin\release\"
+    xcopy /r /d /y $(MG_OEM_GEOS_BIN_DIR)\GEOS.dll "..\..\bin\release\"
+    xcopy /r /d /y $(MG_OEM_GEOS_BIN_DIR)\GEOS.pdb "..\..\bin\release\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\libdb48.dll "..\..\bin\release\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\libdb48.pdb "..\..\bin\release\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\libdbxml25.dll "..\..\bin\release\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\libdbxml25.pdb "..\..\bin\release\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\xqilla24.dll "..\..\bin\release\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\xqilla24.pdb "..\..\bin\release\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\xerces-c_3_1mg.dll "..\..\bin\release\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\xerces-c_3_1mg.pdb "..\..\bin\release\"
+    xcopy /r /d /y ..\..\src\Core\serverconfig.ini "..\..\bin\release\"
-..\..\bin\release\MgFoundation.dll : ..\..\..\Common\bin\release\MgFoundation.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release\MgFoundation.dll ..\..\bin\release\
-..\..\bin\release\MgFoundation.pdb : ..\..\..\Common\bin\release\MgFoundation.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release\MgFoundation.pdb ..\..\bin\release\
-..\..\bin\release\MgPlatformBase.dll : ..\..\..\Common\bin\release\MgPlatformBase.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release\MgPlatformBase.dll ..\..\bin\release\
-..\..\bin\release\MgPlatformBase.pdb : ..\..\..\Common\bin\release\MgPlatformBase.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release\MgPlatformBase.pdb ..\..\bin\release\
-..\..\bin\release\MgGeometry.dll : ..\..\..\Common\bin\release\MgGeometry.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release\MgGeometry.dll ..\..\bin\release\
-..\..\bin\release\MgGeometry.pdb : ..\..\..\Common\bin\release\MgGeometry.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release\MgGeometry.pdb ..\..\bin\release\
-..\..\bin\release\MgMapGuideCommon.dll : ..\..\..\Common\bin\release\MgMapGuideCommon.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release\MgMapGuideCommon.dll ..\..\bin\release\
-..\..\bin\release\MgMapGuideCommon.pdb : ..\..\..\Common\bin\release\MgMapGuideCommon.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release\MgMapGuideCommon.pdb ..\..\bin\release\
-..\..\bin\release\MgMdfModel.dll : ..\..\..\Common\bin\release\MgMdfModel.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release\MgMdfModel.dll ..\..\bin\release\
-..\..\bin\release\MgMdfModel.pdb : ..\..\..\Common\bin\release\MgMdfModel.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release\MgMdfModel.pdb ..\..\bin\release\
-..\..\bin\release\MgMdfParser.dll : ..\..\..\Common\bin\release\MgMdfParser.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release\MgMdfParser.dll ..\..\bin\release\
-..\..\bin\release\MgMdfParser.pdb : ..\..\..\Common\bin\release\MgMdfParser.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release\MgMdfParser.pdb ..\..\bin\release\
-..\..\bin\release\MgStylization.dll : ..\..\..\Common\bin\release\MgStylization.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release\MgStylization.dll ..\..\bin\release\
-..\..\bin\release\MgStylization.pdb : ..\..\..\Common\bin\release\MgStylization.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release\MgStylization.pdb ..\..\bin\release\
-..\..\bin\release\MgRenderers.dll : ..\..\..\Common\bin\release\MgRenderers.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release\MgRenderers.dll ..\..\bin\release\
-..\..\bin\release\MgRenderers.pdb : ..\..\..\Common\bin\release\MgRenderers.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release\MgRenderers.pdb ..\..\bin\release\
-..\..\bin\release\ACE.dll : ..\..\..\Oem\ACE\ACE_wrappers\lib\release\ACE.dll
-    xcopy /r /d /y ..\..\..\Oem\ACE\ACE_wrappers\lib\release\ACE.dll ..\..\bin\release\
-..\..\bin\release\ACE.pdb : ..\..\..\Oem\ACE\ACE_wrappers\lib\release\ACE.pdb
-    xcopy /r /d /y ..\..\..\Oem\ACE\ACE_wrappers\lib\release\ACE.pdb ..\..\bin\release\
-..\..\bin\release\gd.dll : ..\..\..\Oem\gd\build\win32\gd\Release\gd.dll
-    xcopy /r /d /y ..\..\..\Oem\gd\build\win32\gd\Release\gd.dll ..\..\bin\release\
-..\..\bin\release\gd.pdb : ..\..\..\Oem\gd\build\win32\gd\Release\gd.pdb
-    xcopy /r /d /y ..\..\..\Oem\gd\build\win32\gd\Release\gd.pdb ..\..\bin\release\
-..\..\bin\release\GEOS.dll : ..\..\..\Oem\geos\VisualStudio\Release\GEOS.dll
-    xcopy /r /d /y ..\..\..\Oem\geos\VisualStudio\Release\GEOS.dll ..\..\bin\release\
-..\..\bin\release\GEOS.pdb : ..\..\..\Oem\geos\VisualStudio\Release\GEOS.pdb
-    xcopy /r /d /y ..\..\..\Oem\geos\VisualStudio\Release\GEOS.pdb ..\..\bin\release\
-..\..\bin\release\libdb48.dll : ..\..\..\Oem\dbxml\bin\release\libdb48.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\release\libdb48.dll ..\..\bin\release\
-..\..\bin\release\libdb48.pdb : ..\..\..\Oem\dbxml\bin\release\libdb48.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\release\libdb48.pdb ..\..\bin\release\
-..\..\bin\release\libdbxml25.dll : ..\..\..\Oem\dbxml\bin\release\libdbxml25.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\release\libdbxml25.dll ..\..\bin\release\
-..\..\bin\release\libdbxml25.pdb : ..\..\..\Oem\dbxml\bin\release\libdbxml25.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\release\libdbxml25.pdb ..\..\bin\release\
-..\..\bin\release\xqilla24.dll : ..\..\..\Oem\dbxml\bin\release\xqilla24.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\release\xqilla24.dll ..\..\bin\release\
-..\..\bin\release\xqilla24.pdb : ..\..\..\Oem\dbxml\bin\release\xqilla24.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\release\xqilla24.pdb ..\..\bin\release\
-..\..\bin\release\xerces-c_3_1mg.dll : ..\..\..\Oem\dbxml\bin\release\xerces-c_3_1mg.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\release\xerces-c_3_1mg.dll ..\..\bin\release\
-..\..\bin\release\xerces-c_3_1mg.pdb : ..\..\..\Oem\dbxml\bin\release\xerces-c_3_1mg.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\release\xerces-c_3_1mg.pdb ..\..\bin\release\
-..\..\bin\release\serverconfig.ini : ..\..\src\Core\serverconfig.ini
-    xcopy /r /d /y ..\..\src\Core\serverconfig.ini ..\..\bin\release\
-CopyFdoComponentsRelease : ..\..\..\Oem\FDO\*.*
+CopyFdoComponentsRelease:
     if NOT EXIST ..\..\bin\release\FDO\nul mkdir ..\..\bin\release\FDO
-    xcopy /r /d /y /s ..\..\..\Oem\FDO\bin\Release ..\..\bin\release\FDO\
+    xcopy /r /d /y /s $(MG_OEM_FDO_ROOT)\bin\Release ..\..\bin\release\FDO\
-CopyFdoProvidersRelease : ..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml
-    xcopy /r /d /y "..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml" ..\..\bin\release\FDO\
+CopyFdoProvidersRelease:
+    xcopy /r /d /y "$(MG_OEM_FDO_ROOT)\ProviderList\ServerCommunity\providers.xml" ..\..\bin\release\FDO\
-CopySchemaRelease : ..\..\..\Common\Schema\*.xsd
+CopySchemaRelease:
     if NOT EXIST ..\..\bin\release\Schema\nul mkdir ..\..\bin\release\Schema
     xcopy /r /d /y ..\..\..\Common\Schema\*.xsd ..\..\bin\release\Schema
-CopyResourcesRelease : ..\..\..\Common\MapGuideCommon\Resources\mapguide_en.res
+CopyResourcesRelease:
     if NOT EXIST ..\..\bin\release\Resources\nul mkdir ..\..\bin\release\Resources
     xcopy /r /d /y "..\..\..\Common\MapGuideCommon\Resources\mapguide_en.res" ..\..\bin\release\Resources\
-CopyOgcFilesRelease : ..\..\src\wms\*.awd ..\..\src\wfs\*.awd
+CopyOgcFilesRelease:
     if NOT EXIST ..\..\bin\release\wms\nul mkdir ..\..\bin\release\wms
     xcopy /r /d /y "..\..\src\wms\*.awd"         ..\..\bin\release\wms
     if NOT EXIST ..\..\bin\release\wfs\nul mkdir ..\..\bin\release\wfs
     xcopy /r /d /y "..\..\src\wfs\*.awd"         ..\..\bin\release\wfs
-CreatePathsRelease :
+CreatePathsRelease:
     if NOT EXIST ..\..\bin\release\Logs\nul mkdir ..\..\bin\release\Logs
     if NOT EXIST ..\..\bin\release\Packages\nul mkdir ..\..\bin\release\Packages
     if NOT EXIST ..\..\bin\release\Temp\nul mkdir ..\..\bin\release\Temp
@@ -678,269 +175,55 @@
     if NOT EXIST ..\..\bin\release\Repositories\Site\nul mkdir ..\..\bin\release\Repositories\Site
     if NOT EXIST ..\..\bin\release\Repositories\TileCache\nul mkdir ..\..\bin\release\Repositories\TileCache
-release : ..\..\bin\release\MgFoundation.dll \
-          ..\..\bin\release\MgFoundation.pdb \
-          ..\..\bin\release\MgGeometry.dll \
-          ..\..\bin\release\MgGeometry.pdb \
-          ..\..\bin\release\MgPlatformBase.dll \
-          ..\..\bin\release\MgPlatformBase.pdb \
-          ..\..\bin\release\MgMapGuideCommon.dll \
-          ..\..\bin\release\MgMapGuideCommon.pdb \
-          ..\..\bin\release\MgMdfModel.dll \
-          ..\..\bin\release\MgMdfModel.pdb \
-          ..\..\bin\release\MgMdfParser.dll \
-          ..\..\bin\release\MgMdfParser.pdb \
-          ..\..\bin\release\MgStylization.dll \
-          ..\..\bin\release\MgStylization.pdb \
-          ..\..\bin\release\MgRenderers.dll \
-          ..\..\bin\release\MgRenderers.pdb \
-          ..\..\bin\release\ACE.dll \
-          ..\..\bin\release\ACE.pdb \
-          ..\..\bin\release\gd.dll \
-          ..\..\bin\release\gd.pdb \
-          ..\..\bin\release\GEOS.dll \
-          ..\..\bin\release\GEOS.pdb \
-          ..\..\bin\release\libdb48.dll \
-          ..\..\bin\release\libdb48.pdb \
-          ..\..\bin\release\libdbxml25.dll \
-          ..\..\bin\release\libdbxml25.pdb \
-          ..\..\bin\release\xqilla24.dll \
-          ..\..\bin\release\xqilla24.pdb \
-          ..\..\bin\release\xerces-c_3_1mg.dll \
-          ..\..\bin\release\xerces-c_3_1mg.pdb \
-          ..\..\bin\release\serverconfig.ini \
-          CopyFdoComponentsRelease \
-          CopyFdoProvidersRelease \
-          CopySchemaRelease \
-          CopyResourcesRelease \
-          CreatePathsRelease \
-          CopyOgcFilesRelease
+release: CopyBinariesRelease \
+         CopyTestData \
+         CopyFdoComponentsRelease \
+         CopyFdoProvidersRelease \
+         CopySchemaRelease \
+         CopyResourcesRelease \
+         CreatePathsRelease \
+         CopyOgcFilesRelease
+CopyBinariesRelease64:
+    xcopy /r /d /y ..\..\..\Common\bin\release64\*.* "..\..\bin\release64\"
+    xcopy /r /d /y $(MG_OEM_ACE_BIN_DIR)\ACE.dll "..\..\bin\release64\"
+    xcopy /r /d /y $(MG_OEM_ACE_BIN_DIR)\ACE.pdb "..\..\bin\release64\"
+    xcopy /r /d /y $(MG_OEM_GD_BIN_DIR)\gd.dll "..\..\bin\release64\"
+    xcopy /r /d /y $(MG_OEM_GD_BIN_DIR)\gd.pdb "..\..\bin\release64\"
+    xcopy /r /d /y $(MG_OEM_GEOS_BIN_DIR)\GEOS.dll "..\..\bin\release64\"
+    xcopy /r /d /y $(MG_OEM_GEOS_BIN_DIR)\GEOS.pdb "..\..\bin\release64\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\libdb48.dll "..\..\bin\release64\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\libdb48.pdb "..\..\bin\release64\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\libdbxml25.dll "..\..\bin\release64\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\libdbxml25.pdb "..\..\bin\release64\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\xqilla24.dll "..\..\bin\release64\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\xqilla24.pdb "..\..\bin\release64\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\xerces-c_3_1mg.dll "..\..\bin\release64\"
+    xcopy /r /d /y $(MG_OEM_DBXML_BIN_DIR)\xerces-c_3_1mg.pdb "..\..\bin\release64\"
+    xcopy /r /d /y ..\..\src\Core\serverconfig.ini "..\..\bin\release64\"
-..\..\bin\release64\MgFoundation.dll : ..\..\..\Common\bin\release64\MgFoundation.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release64\MgFoundation.dll ..\..\bin\release64\
-..\..\bin\release64\MgFoundation.pdb : ..\..\..\Common\bin\release64\MgFoundation.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release64\MgFoundation.pdb ..\..\bin\release64\
-..\..\bin\release64\MgPlatformBase.dll : ..\..\..\Common\bin\release64\MgPlatformBase.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release64\MgPlatformBase.dll ..\..\bin\release64\
-..\..\bin\release64\MgPlatformBase.pdb : ..\..\..\Common\bin\release64\MgPlatformBase.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release64\MgPlatformBase.pdb ..\..\bin\release64\
-..\..\bin\release64\MgGeometry.dll : ..\..\..\Common\bin\release64\MgGeometry.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release64\MgGeometry.dll ..\..\bin\release64\
-..\..\bin\release64\MgGeometry.pdb : ..\..\..\Common\bin\release64\MgGeometry.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release64\MgGeometry.pdb ..\..\bin\release64\
-..\..\bin\release64\MgMapGuideCommon.dll : ..\..\..\Common\bin\release64\MgMapGuideCommon.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release64\MgMapGuideCommon.dll ..\..\bin\release64\
-..\..\bin\release64\MgMapGuideCommon.pdb : ..\..\..\Common\bin\release64\MgMapGuideCommon.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release64\MgMapGuideCommon.pdb ..\..\bin\release64\
-..\..\bin\release64\MgMdfModel.dll : ..\..\..\Common\bin\release64\MgMdfModel.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release64\MgMdfModel.dll ..\..\bin\release64\
-..\..\bin\release64\MgMdfModel.pdb : ..\..\..\Common\bin\release64\MgMdfModel.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release64\MgMdfModel.pdb ..\..\bin\release64\
-..\..\bin\release64\MgMdfParser.dll : ..\..\..\Common\bin\release64\MgMdfParser.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release64\MgMdfParser.dll ..\..\bin\release64\
-..\..\bin\release64\MgMdfParser.pdb : ..\..\..\Common\bin\release64\MgMdfParser.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release64\MgMdfParser.pdb ..\..\bin\release64\
-..\..\bin\release64\MgStylization.dll : ..\..\..\Common\bin\release64\MgStylization.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release64\MgStylization.dll ..\..\bin\release64\
-..\..\bin\release64\MgStylization.pdb : ..\..\..\Common\bin\release64\MgStylization.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release64\MgStylization.pdb ..\..\bin\release64\
-..\..\bin\release64\MgRenderers.dll : ..\..\..\Common\bin\release64\MgRenderers.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release64\MgRenderers.dll ..\..\bin\release64\
-..\..\bin\release64\MgRenderers.pdb : ..\..\..\Common\bin\release64\MgRenderers.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release64\MgRenderers.pdb ..\..\bin\release64\
-..\..\bin\release64\ACE.dll : ..\..\..\Oem\ACE\ACE_wrappers\lib64\release\ACE.dll
-    xcopy /r /d /y ..\..\..\Oem\ACE\ACE_wrappers\lib64\release\ACE.dll ..\..\bin\release64\
-..\..\bin\release64\ACE.pdb : ..\..\..\Oem\ACE\ACE_wrappers\lib64\release\ACE.pdb
-    xcopy /r /d /y ..\..\..\Oem\ACE\ACE_wrappers\lib64\release\ACE.pdb ..\..\bin\release64\
-..\..\bin\release64\gd.dll : ..\..\..\Oem\gd\build\win32\gd\release64\gd.dll
-    xcopy /r /d /y ..\..\..\Oem\gd\build\win32\gd\release64\gd.dll ..\..\bin\release64\
-..\..\bin\release64\gd.pdb : ..\..\..\Oem\gd\build\win32\gd\release64\gd.pdb
-    xcopy /r /d /y ..\..\..\Oem\gd\build\win32\gd\release64\gd.pdb ..\..\bin\release64\
-..\..\bin\release64\GEOS.dll : ..\..\..\Oem\geos\VisualStudio\Release64\GEOS.dll
-    xcopy /r /d /y ..\..\..\Oem\geos\VisualStudio\Release64\GEOS.dll ..\..\bin\release64\
-..\..\bin\release64\GEOS.pdb : ..\..\..\Oem\geos\VisualStudio\Release64\GEOS.pdb
-    xcopy /r /d /y ..\..\..\Oem\geos\VisualStudio\Release64\GEOS.pdb ..\..\bin\release64\
-..\..\bin\release64\libdb48.dll : ..\..\..\Oem\dbxml\bin64\release\libdb48.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\release\libdb48.dll ..\..\bin\release64\
-..\..\bin\release64\libdb48.pdb : ..\..\..\Oem\dbxml\bin64\release\libdb48.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\release\libdb48.pdb ..\..\bin\release64\
-..\..\bin\release64\libdbxml25.dll : ..\..\..\Oem\dbxml\bin64\release\libdbxml25.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\release\libdbxml25.dll ..\..\bin\release64\
-..\..\bin\release64\libdbxml25.pdb : ..\..\..\Oem\dbxml\bin64\release\libdbxml25.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\release\libdbxml25.pdb ..\..\bin\release64\
-..\..\bin\release64\xqilla24.dll : ..\..\..\Oem\dbxml\bin64\release\xqilla24.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\release\xqilla24.dll ..\..\bin\release64\
-..\..\bin\release64\xqilla24.pdb : ..\..\..\Oem\dbxml\bin64\release\xqilla24.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\release\xqilla24.pdb ..\..\bin\release64\
-..\..\bin\release64\xerces-c_3_1mg.dll : ..\..\..\Oem\dbxml\bin64\release\xerces-c_3_1mg.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\release\xerces-c_3_1mg.dll ..\..\bin\release64\
-..\..\bin\release64\xerces-c_3_1mg.pdb : ..\..\..\Oem\dbxml\bin64\release\xerces-c_3_1mg.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\release\xerces-c_3_1mg.pdb ..\..\bin\release64\
-..\..\bin\release64\serverconfig.ini : ..\..\src\Core\serverconfig.ini
-    xcopy /r /d /y ..\..\src\Core\serverconfig.ini ..\..\bin\release64\
-CopyFdoComponentsRelease64 : ..\..\..\Oem\FDO\*.*
+CopyFdoComponentsRelease64:
     if NOT EXIST ..\..\bin\release64\FDO\nul mkdir ..\..\bin\release64\FDO
-    xcopy /r /d /y /s ..\..\..\Oem\FDO\bin\release64 ..\..\bin\release64\FDO\
+    xcopy /r /d /y /s $(MG_OEM_FDO_ROOT)\bin\release64 ..\..\bin\release64\FDO\
-CopyFdoProvidersRelease64 : ..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml
-    xcopy /r /d /y "..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml" ..\..\bin\release64\FDO\
+CopyFdoProvidersRelease64:
+    xcopy /r /d /y "$(MG_OEM_FDO_ROOT)\ProviderList\ServerCommunity\providers.xml" ..\..\bin\release64\FDO\
-CopySchemaRelease64 : ..\..\..\Common\Schema\*.xsd
+CopySchemaRelease64:
     if NOT EXIST ..\..\bin\release64\Schema\nul mkdir ..\..\bin\release64\Schema
     xcopy /r /d /y ..\..\..\Common\Schema\*.xsd ..\..\bin\release64\Schema
-CopyResourcesRelease64 : ..\..\..\Common\MapGuideCommon\Resources\mapguide_en.res
+CopyResourcesRelease64:
     if NOT EXIST ..\..\bin\release64\Resources\nul mkdir ..\..\bin\release64\Resources
     xcopy /r /d /y "..\..\..\Common\MapGuideCommon\Resources\mapguide_en.res" ..\..\bin\release64\Resources\
-CopyOgcFilesRelease64 : ..\..\src\wms\*.awd ..\..\src\wfs\*.awd
+CopyOgcFilesRelease64:
     if NOT EXIST ..\..\bin\release64\wms\nul mkdir ..\..\bin\release64\wms
     xcopy /r /d /y "..\..\src\wms\*.awd"         ..\..\bin\release64\wms
     if NOT EXIST ..\..\bin\release64\wfs\nul mkdir ..\..\bin\release64\wfs
     xcopy /r /d /y "..\..\src\wfs\*.awd"         ..\..\bin\release64\wfs
-CreatePathsRelease64 :
+CreatePathsRelease64:
     if NOT EXIST ..\..\bin\release64\Logs\nul mkdir ..\..\bin\release64\Logs
     if NOT EXIST ..\..\bin\release64\Packages\nul mkdir ..\..\bin\release64\Packages
     if NOT EXIST ..\..\bin\release64\Temp\nul mkdir ..\..\bin\release64\Temp
@@ -954,186 +237,16 @@
     if NOT EXIST ..\..\bin\release64\Repositories\Site\nul mkdir ..\..\bin\release64\Repositories\Site
     if NOT EXIST ..\..\bin\release64\Repositories\TileCache\nul mkdir ..\..\bin\release64\Repositories\TileCache
-release64 : ..\..\bin\release64\MgFoundation.dll \
-          ..\..\bin\release64\MgFoundation.pdb \
-          ..\..\bin\release64\MgGeometry.dll \
-          ..\..\bin\release64\MgGeometry.pdb \
-          ..\..\bin\release64\MgPlatformBase.dll \
-          ..\..\bin\release64\MgPlatformBase.pdb \
-          ..\..\bin\release64\MgMapGuideCommon.dll \
-          ..\..\bin\release64\MgMapGuideCommon.pdb \
-          ..\..\bin\release64\MgMdfModel.dll \
-          ..\..\bin\release64\MgMdfModel.pdb \
-          ..\..\bin\release64\MgMdfParser.dll \
-          ..\..\bin\release64\MgMdfParser.pdb \
-          ..\..\bin\release64\MgStylization.dll \
-          ..\..\bin\release64\MgStylization.pdb \
-          ..\..\bin\release64\MgRenderers.dll \
-          ..\..\bin\release64\MgRenderers.pdb \
-          ..\..\bin\release64\ACE.dll \
-          ..\..\bin\release64\ACE.pdb \
-          ..\..\bin\release64\gd.dll \
-          ..\..\bin\release64\gd.pdb \
-          ..\..\bin\release64\GEOS.dll \
-          ..\..\bin\release64\GEOS.pdb \
-          ..\..\bin\release64\libdb48.dll \
-          ..\..\bin\release64\libdb48.pdb \
-          ..\..\bin\release64\libdbxml25.dll \
-          ..\..\bin\release64\libdbxml25.pdb \
-          ..\..\bin\release64\xqilla24.dll \
-          ..\..\bin\release64\xqilla24.pdb \
-          ..\..\bin\release64\xerces-c_3_1mg.dll \
-          ..\..\bin\release64\xerces-c_3_1mg.pdb \
-          ..\..\bin\release64\serverconfig.ini \
-          CopyFdoComponentsRelease64 \
-          CopyFdoProvidersRelease64 \
-          CopySchemaRelease64 \
-          CopyResourcesRelease64 \
-          CreatePathsRelease64 \
-          CopyOgcFilesRelease64
+release64: CopyBinariesRelease64 \
+           CopyTestData \
+           CopyFdoComponentsRelease64 \
+           CopyFdoProvidersRelease64 \
+           CopySchemaRelease64 \
+           CopyResourcesRelease64 \
+           CreatePathsRelease64 \
+           CopyOgcFilesRelease64
-cleandebug:
-    if EXIST ..\..\bin\debug\MgFoundationd.dll               del /F ..\..\bin\debug\MgFoundationd.dll
-    if EXIST ..\..\bin\debug\MgFoundationd.pdb               del /F ..\..\bin\debug\MgFoundationd.pdb
-    if EXIST ..\..\bin\debug\MgGeometryd.dll                 del /F ..\..\bin\debug\MgGeometryd.dll
-    if EXIST ..\..\bin\debug\MgGeometryd.pdb                 del /F ..\..\bin\debug\MgGeometryd.pdb
-    if EXIST ..\..\bin\debug\MgPlatformBased.dll             del /F ..\..\bin\debug\MgPlatformBased.dll
-    if EXIST ..\..\bin\debug\MgPlatformBased.pdb             del /F ..\..\bin\debug\MgPlatformBased.pdb
-    if EXIST ..\..\bin\debug\MgMapGuideCommond.dll           del /F ..\..\bin\debug\MgMapGuideCommond.dll
-    if EXIST ..\..\bin\debug\MgMapGuideCommond.pdb           del /F ..\..\bin\debug\MgMapGuideCommond.pdb
-    if EXIST ..\..\bin\debug\MgMdfModeld.dll                 del /F ..\..\bin\debug\MgMdfModeld.dll
-    if EXIST ..\..\bin\debug\MgMdfModeld.pdb                 del /F ..\..\bin\debug\MgMdfModeld.pdb
-    if EXIST ..\..\bin\debug\MgMdfParserd.dll                del /F ..\..\bin\debug\MgMdfParserd.dll
-    if EXIST ..\..\bin\debug\MgMdfParserd.pdb                del /F ..\..\bin\debug\MgMdfParserd.pdb
-    if EXIST ..\..\bin\debug\MgStylizationd.dll              del /F ..\..\bin\debug\MgStylizationd.dll
-    if EXIST ..\..\bin\debug\MgStylizationd.pdb              del /F ..\..\bin\debug\MgStylizationd.pdb
-    if EXIST ..\..\bin\debug\MgRenderersd.dll                del /F ..\..\bin\debug\MgRenderersd.dll
-    if EXIST ..\..\bin\debug\MgRenderersd.pdb                del /F ..\..\bin\debug\MgRenderersd.pdb
-    if EXIST ..\..\bin\debug\ACEd.dll                        del /F ..\..\bin\debug\ACEd.dll
-    if EXIST ..\..\bin\debug\ACEd.pdb                        del /F ..\..\bin\debug\ACEd.pdb
-    if EXIST ..\..\bin\debug\gd.dll                          del /F ..\..\bin\debug\gd.dll
-    if EXIST ..\..\bin\debug\gd.pdb                          del /F ..\..\bin\debug\gd.pdb
-    if EXIST ..\..\bin\debug\GEOSd.dll                       del /F ..\..\bin\debug\GEOSd.dll
-    if EXIST ..\..\bin\debug\GEOSd.pdb                       del /F ..\..\bin\debug\GEOSd.pdb
-    if EXIST ..\..\bin\debug\libdb48d.dll                    del /F ..\..\bin\debug\libdb48d.dll
-    if EXIST ..\..\bin\debug\libdb48d.pdb                    del /F ..\..\bin\debug\libdb48d.pdb
-    if EXIST ..\..\bin\debug\libdbxml25d.dll                 del /F ..\..\bin\debug\libdbxml25d.dll
-    if EXIST ..\..\bin\debug\libdbxml25d.pdb                 del /F ..\..\bin\debug\libdbxml25d.pdb
-    if EXIST ..\..\bin\debug\xqilla24d.dll                   del /F ..\..\bin\debug\xqilla24d.dll
-    if EXIST ..\..\bin\debug\xqilla24d.pdb                   del /F ..\..\bin\debug\xqilla24d.pdb
-    if EXIST ..\..\bin\debug\xerces-c_3_1mgD.dll             del /F ..\..\bin\debug\xerces-c_3_1mgD.dll
-    if EXIST ..\..\bin\debug\xerces-c_3_1mgD.pdb             del /F ..\..\bin\debug\xerces-c_3_1mgD.pdb
-    if EXIST ..\..\bin\debug\serverconfig.ini                del /F ..\..\bin\debug\serverconfig.ini
+cleantestdata:
     if EXIST ..\..\bin\UnitTestFiles\LibraryRepositoryContent.xml   del /F ..\..\bin\UnitTestFiles\LibraryRepositoryContent.xml
     if EXIST ..\..\bin\UnitTestFiles\SampleRepositoryHeader.xml     del /F ..\..\bin\UnitTestFiles\SampleRepositoryHeader.xml
     if EXIST ..\..\bin\UnitTestFiles\SampleRepositoryContent.xml    del /F ..\..\bin\UnitTestFiles\SampleRepositoryContent.xml
@@ -1142,7 +255,7 @@
     if EXIST ..\..\bin\UnitTestFiles\TEST.sdf                       del /F ..\..\bin\UnitTestFiles\TEST.sdf
     if EXIST ..\..\bin\UnitTestFiles\UT_BaseMap.mdf                 del /F ..\..\bin\UnitTestFiles\UT_BaseMap.mdf
     if EXIST ..\..\bin\UnitTestFiles\UT_BaseMap.tsd                 del /F ..\..\bin\UnitTestFiles\UT_BaseMap.tsd
-    if EXIST ..\..\bin\UnitTestFiles\UT_XYZ.tsd                        del /F ..\..\bin\UnitTestFiles\UT_XYZ.tsd
+    if EXIST ..\..\bin\UnitTestFiles\UT_XYZ.tsd                     del /F ..\..\bin\UnitTestFiles\UT_XYZ.tsd
     if EXIST ..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf           del /F ..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf
     if EXIST ..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf        del /F ..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf
     if EXIST ..\..\bin\UnitTestFiles\UT_Parcels.fs                  del /F ..\..\bin\UnitTestFiles\UT_Parcels.fs
@@ -1240,13 +353,51 @@
     if EXIST ..\..\bin\UnitTestFiles\SavePointTest.sqlite           del /F ..\..\bin\UnitTestFiles\SavePointTest.sqlite
     if EXIST ..\..\bin\UnitTestFiles\SavePointTest.FeatureSource    del /F ..\..\bin\UnitTestFiles\SavePointTest.FeatureSource
     if EXIST ..\..\bin\UnitTestFiles\UT_Parcels_SQLite_Join.FeatureSource    del /F ..\..\bin\UnitTestFiles\UT_Parcels_SQLite_Join.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\UT_FdoJoin.FeatureSource        del /F ..\..\bin\UnitTestFiles\UT_FdoJoin.FeatureSource
+    if EXIST ..\..\bin\UnitTestFiles\UT_FdoJoin.FeatureSource       del /F ..\..\bin\UnitTestFiles\UT_FdoJoin.FeatureSource
     if EXIST ..\..\bin\UnitTestFiles\ParcelsJoinTest.sqlite         del /F ..\..\bin\UnitTestFiles\ParcelsJoinTest.sqlite
     if EXIST ..\..\bin\UnitTestFiles\JoinTest.sqlite                del /F ..\..\bin\UnitTestFiles\JoinTest.FeatureSource
+cleandebug: cleantestdata \
+			cleanbinariesrelease
+cleandebug:
+    if EXIST ..\..\bin\debug\MgFoundationd.dll               del /F ..\..\bin\debug\MgFoundationd.dll
+    if EXIST ..\..\bin\debug\MgFoundationd.pdb               del /F ..\..\bin\debug\MgFoundationd.pdb
+    if EXIST ..\..\bin\debug\MgGeometryd.dll                 del /F ..\..\bin\debug\MgGeometryd.dll
+    if EXIST ..\..\bin\debug\MgGeometryd.pdb                 del /F ..\..\bin\debug\MgGeometryd.pdb
+    if EXIST ..\..\bin\debug\MgPlatformBased.dll             del /F ..\..\bin\debug\MgPlatformBased.dll
+    if EXIST ..\..\bin\debug\MgPlatformBased.pdb             del /F ..\..\bin\debug\MgPlatformBased.pdb
+    if EXIST ..\..\bin\debug\MgMapGuideCommond.dll           del /F ..\..\bin\debug\MgMapGuideCommond.dll
+    if EXIST ..\..\bin\debug\MgMapGuideCommond.pdb           del /F ..\..\bin\debug\MgMapGuideCommond.pdb
+    if EXIST ..\..\bin\debug\MgMdfModeld.dll                 del /F ..\..\bin\debug\MgMdfModeld.dll
+    if EXIST ..\..\bin\debug\MgMdfModeld.pdb                 del /F ..\..\bin\debug\MgMdfModeld.pdb
+    if EXIST ..\..\bin\debug\MgMdfParserd.dll                del /F ..\..\bin\debug\MgMdfParserd.dll
+    if EXIST ..\..\bin\debug\MgMdfParserd.pdb                del /F ..\..\bin\debug\MgMdfParserd.pdb
+    if EXIST ..\..\bin\debug\MgStylizationd.dll              del /F ..\..\bin\debug\MgStylizationd.dll
+    if EXIST ..\..\bin\debug\MgStylizationd.pdb              del /F ..\..\bin\debug\MgStylizationd.pdb
+    if EXIST ..\..\bin\debug\MgRenderersd.dll                del /F ..\..\bin\debug\MgRenderersd.dll
+    if EXIST ..\..\bin\debug\MgRenderersd.pdb                del /F ..\..\bin\debug\MgRenderersd.pdb
+    if EXIST ..\..\bin\debug\ACEd.dll                        del /F ..\..\bin\debug\ACEd.dll
+    if EXIST ..\..\bin\debug\ACEd.pdb                        del /F ..\..\bin\debug\ACEd.pdb
+    if EXIST ..\..\bin\debug\gd.dll                          del /F ..\..\bin\debug\gd.dll
+    if EXIST ..\..\bin\debug\gd.pdb                          del /F ..\..\bin\debug\gd.pdb
+    if EXIST ..\..\bin\debug\GEOSd.dll                       del /F ..\..\bin\debug\GEOSd.dll
+    if EXIST ..\..\bin\debug\GEOSd.pdb                       del /F ..\..\bin\debug\GEOSd.pdb
+    if EXIST ..\..\bin\debug\libdb48d.dll                    del /F ..\..\bin\debug\libdb48d.dll
+    if EXIST ..\..\bin\debug\libdb48d.pdb                    del /F ..\..\bin\debug\libdb48d.pdb
+    if EXIST ..\..\bin\debug\libdbxml25d.dll                 del /F ..\..\bin\debug\libdbxml25d.dll
+    if EXIST ..\..\bin\debug\libdbxml25d.pdb                 del /F ..\..\bin\debug\libdbxml25d.pdb
+    if EXIST ..\..\bin\debug\xqilla24d.dll                   del /F ..\..\bin\debug\xqilla24d.dll
+    if EXIST ..\..\bin\debug\xqilla24d.pdb                   del /F ..\..\bin\debug\xqilla24d.pdb
+    if EXIST ..\..\bin\debug\xerces-c_3_1mgD.dll             del /F ..\..\bin\debug\xerces-c_3_1mgD.dll
+    if EXIST ..\..\bin\debug\xerces-c_3_1mgD.pdb             del /F ..\..\bin\debug\xerces-c_3_1mgD.pdb
+    if EXIST ..\..\bin\debug\serverconfig.ini                del /F ..\..\bin\debug\serverconfig.ini
     del /F   ..\..\bin\debug\*.ilk
+cleandebug64: cleantestdata \
+		      cleanbinariesrelease64
-cleandebug64:
+cleanbinariesdebug64:
     if EXIST ..\..\bin\debug64\MgFoundationd.dll               del /F ..\..\bin\debug64\MgFoundationd.dll
     if EXIST ..\..\bin\debug64\MgFoundationd.pdb               del /F ..\..\bin\debug64\MgFoundationd.pdb
     if EXIST ..\..\bin\debug64\MgGeometryd.dll                 del /F ..\..\bin\debug64\MgGeometryd.dll
@@ -1278,119 +429,12 @@
     if EXIST ..\..\bin\debug64\xerces-c_3_1mgD.dll             del /F ..\..\bin\debug64\xerces-c_3_1mgD.dll
     if EXIST ..\..\bin\debug64\xerces-c_3_1mgD.pdb             del /F ..\..\bin\debug64\xerces-c_3_1mgD.pdb
     if EXIST ..\..\bin\debug64\serverconfig.ini                del /F ..\..\bin\debug64\serverconfig.ini
-    if EXIST ..\..\bin\UnitTestFiles\LibraryRepositoryContent.xml   del /F ..\..\bin\UnitTestFiles\LibraryRepositoryContent.xml
-    if EXIST ..\..\bin\UnitTestFiles\SampleRepositoryHeader.xml     del /F ..\..\bin\UnitTestFiles\SampleRepositoryHeader.xml
-    if EXIST ..\..\bin\UnitTestFiles\SampleRepositoryContent.xml    del /F ..\..\bin\UnitTestFiles\SampleRepositoryContent.xml
-    if EXIST ..\..\bin\UnitTestFiles\TEST.LayerDefinition           del /F ..\..\bin\UnitTestFiles\TEST.LayerDefinition
-    if EXIST ..\..\bin\UnitTestFiles\TEST.FeatureSource             del /F ..\..\bin\UnitTestFiles\TEST.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\TEST.sdf                       del /F ..\..\bin\UnitTestFiles\TEST.sdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_BaseMap.mdf                 del /F ..\..\bin\UnitTestFiles\UT_BaseMap.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_BaseMap.tsd                 del /F ..\..\bin\UnitTestFiles\UT_BaseMap.tsd
-    if EXIST ..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf           del /F ..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf        del /F ..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Parcels.fs                  del /F ..\..\bin\UnitTestFiles\UT_Parcels.fs
-    if EXIST ..\..\bin\UnitTestFiles\UT_Parcels.ldf                 del /F ..\..\bin\UnitTestFiles\UT_Parcels.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Parcels.sdf                 del /F ..\..\bin\UnitTestFiles\UT_Parcels.sdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_RoadCenterLines.fs          del /F ..\..\bin\UnitTestFiles\UT_RoadCenterLines.fs
-    if EXIST ..\..\bin\UnitTestFiles\UT_RoadCenterLines.ldf         del /F ..\..\bin\UnitTestFiles\UT_RoadCenterLines.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_RoadCenterLines.sdf         del /F ..\..\bin\UnitTestFiles\UT_RoadCenterLines.sdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_VotingDistricts.fs          del /F ..\..\bin\UnitTestFiles\UT_VotingDistricts.fs
-    if EXIST ..\..\bin\UnitTestFiles\UT_VotingDistricts.ldf         del /F ..\..\bin\UnitTestFiles\UT_VotingDistricts.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_VotingDistrictsFunctions.ldf del /F ..\..\bin\UnitTestFiles\UT_VotingDistrictsFunctions.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_VotingDistricts.sdf         del /F ..\..\bin\UnitTestFiles\UT_VotingDistricts.sdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_AllElements.pl              del /F ..\..\bin\UnitTestFiles\UT_AllElements.pl
-    if EXIST ..\..\bin\UnitTestFiles\UT_NoLegend.pl                 del /F ..\..\bin\UnitTestFiles\UT_NoLegend.pl
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbolMart.sl               del /F ..\..\bin\UnitTestFiles\UT_SymbolMart.sl
-    if EXIST ..\..\bin\UnitTestFiles\UT_Symbols.dwf                 del /F ..\..\bin\UnitTestFiles\UT_Symbols.dwf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SheboyganWithWatermark.mdf  del /F ..\..\bin\UnitTestFiles\UT_SheboyganWithWatermark.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_PoweredByMapGuide.wdf       del /F ..\..\bin\UnitTestFiles\UT_PoweredByMapGuide.wdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Sheboygan.mdf               del /F ..\..\bin\UnitTestFiles\UT_Sheboygan.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Sheboygan_833.mdf           del /F ..\..\bin\UnitTestFiles\UT_Sheboygan_833.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.sdf    del /F ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.sdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.fs     del /F ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.fs
-    if EXIST ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.ldf    del /F ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Rail.sdf                    del /F ..\..\bin\UnitTestFiles\UT_Rail.sdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Rail.fs                     del /F ..\..\bin\UnitTestFiles\UT_Rail.fs
-    if EXIST ..\..\bin\UnitTestFiles\UT_Rail.ldf                    del /F ..\..\bin\UnitTestFiles\UT_Rail.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Rail.wdf                    del /F ..\..\bin\UnitTestFiles\UT_Rail.wdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Rail_Watermark.ldf          del /F ..\..\bin\UnitTestFiles\UT_Rail_Watermark.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_MultiCTS.ldf                del /F ..\..\bin\UnitTestFiles\UT_MultiCTS.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_MultiCTSWithTheme.ldf       del /F ..\..\bin\UnitTestFiles\UT_MultiCTSWithTheme.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_MultiFTS.ldf                del /F ..\..\bin\UnitTestFiles\UT_MultiFTS.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_MultiFTSSingleCTS.ldf       del /F ..\..\bin\UnitTestFiles\UT_MultiFTSSingleCTS.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_MultiFTSWithTheme.ldf       del /F ..\..\bin\UnitTestFiles\UT_MultiFTSWithTheme.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SingleFTSMultiCTS.ldf  del /F ..\..\bin\UnitTestFiles\UT_SingleFTSMultiCTS.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_RotatedPointStyles.ldf      del /F ..\..\bin\UnitTestFiles\UT_RotatedPointStyles.ldf
-    if EXIST ..\..\bin\UnitTestFiles\Sheboygan_Parcels.FeatureSource del /F ..\..\bin\UnitTestFiles\Sheboygan_Parcels.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\Sheboygan_Parcels.sdf          del /F ..\..\bin\UnitTestFiles\Sheboygan_Parcels.sdf
-    if EXIST ..\..\bin\UnitTestFiles\Sheboygan_BuildingOutlines.FeatureSource del /F ..\..\bin\UnitTestFiles\Sheboygan_BuildingOutlines.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\Sheboygan_BuildingOutlines.sdf del /F ..\..\bin\UnitTestFiles\Sheboygan_BuildingOutlines.sdf
-    if EXIST ..\..\bin\UnitTestFiles\Sheboygan_VotingDistricts.FeatureSource del /F ..\..\bin\UnitTestFiles\Sheboygan_VotingDistricts.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\Sheboygan_VotingDistricts.sdf  del /F ..\..\bin\UnitTestFiles\Sheboygan_VotingDistricts.sdf
-    if EXIST ..\..\bin\UnitTestFiles\Empty.FeatureSource            del /F ..\..\bin\UnitTestFiles\Empty.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\Empty.sdf                      del /F ..\..\bin\UnitTestFiles\Empty.sdf
-    if EXIST ..\..\bin\UnitTestFiles\World.mgp                      del /F ..\..\bin\UnitTestFiles\World.mgp
-    if EXIST ..\..\bin\UnitTestFiles\World_Countries.sdf            del /F ..\..\bin\UnitTestFiles\World_Countries.sdf
-    if EXIST ..\..\bin\UnitTestFiles\Shuttle.zip                    del /F ..\..\bin\UnitTestFiles\Shuttle.zip
-    if EXIST ..\..\bin\UnitTestFiles\test.dwf                       del /F ..\..\bin\UnitTestFiles\test.dwf
-    if EXIST ..\..\bin\UnitTestFiles\SpaceShip.dwf                  del /F ..\..\bin\UnitTestFiles\SpaceShip.dwf
-    if EXIST ..\..\bin\UnitTestFiles\MapGuideDrawingSource.xml      del /F ..\..\bin\UnitTestFiles\MapGuideDrawingSource.xml
-    if EXIST ..\..\bin\UnitTestFiles\SpaceShipDrawingSource.xml     del /F ..\..\bin\UnitTestFiles\SpaceShipDrawingSource.xml
-    if EXIST ..\..\bin\UnitTestFiles\Redding_Parcels.FeatureSource  del /F ..\..\bin\UnitTestFiles\Redding_Parcels.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\Redding_Parcels.shp            del /F ..\..\bin\UnitTestFiles\Redding_Parcels.shp
-    if EXIST ..\..\bin\UnitTestFiles\Redding_Parcels.dbf            del /F ..\..\bin\UnitTestFiles\Redding_Parcels.dbf
-    if EXIST ..\..\bin\UnitTestFiles\Redding_Parcels.shx            del /F ..\..\bin\UnitTestFiles\Redding_Parcels.shx
-    if EXIST ..\..\bin\UnitTestFiles\1.1.1.mgd                      del /F ..\..\bin\UnitTestFiles\1.1.1.mgd
-    if EXIST ..\..\bin\UnitTestFiles\epsgcodes.txt                  del /F ..\..\bin\UnitTestFiles\epsgcodes.txt
-    if EXIST ..\..\bin\UnitTestFiles\ogcwkts.txt                    del /F ..\..\bin\UnitTestFiles\ogcwkts.txt
-    if EXIST ..\..\bin\UnitTestFiles\UT_GetMapKmlResult.txt         del /F ..\..\bin\UnitTestFiles\UT_GetMapKmlResult.txt
-    if EXIST ..\..\bin\UnitTestFiles\UT_GetLayerKmlResult.txt       del /F ..\..\bin\UnitTestFiles\UT_GetLayerKmlResult.txt
-    if EXIST ..\..\bin\UnitTestFiles\UT_GetFeaturesKmlResult.txt    del /F ..\..\bin\UnitTestFiles\UT_GetFeaturesKmlResult.txt
-    if EXIST ..\..\bin\UnitTestFiles\TESTChainedInner1ToManyJoin.FeatureSource del /F ..\..\bin\UnitTestFiles\TESTChainedInner1ToManyJoin.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\MdfTestMap.mdf                 del /F ..\..\bin\UnitTestFiles\MdfTestMap.mdf
-    if EXIST ..\..\bin\UnitTestFiles\MdfTestTypeStyles.ldf          del /F ..\..\bin\UnitTestFiles\MdfTestTypeStyles.ldf
-    if EXIST ..\..\bin\UnitTestFiles\MdfTestCompoundSymbol.sd       del /F ..\..\bin\UnitTestFiles\MdfTestCompoundSymbol.sd
-    if EXIST ..\..\bin\UnitTestFiles\MdfTestSimpleSymbol.sd         del /F ..\..\bin\UnitTestFiles\MdfTestSimpleSymbol.sd
-    if EXIST ..\..\bin\UnitTestFiles\areasymbol.sd                  del /F ..\..\bin\UnitTestFiles\areasymbol.sd
-    if EXIST ..\..\bin\UnitTestFiles\linesymbol.sd                  del /F ..\..\bin\UnitTestFiles\linesymbol.sd
-    if EXIST ..\..\bin\UnitTestFiles\symbol.sd                      del /F ..\..\bin\UnitTestFiles\symbol.sd
-    if EXIST ..\..\bin\UnitTestFiles\symbolp.sd                     del /F ..\..\bin\UnitTestFiles\symbolp.sd
-    if EXIST ..\..\bin\UnitTestFiles\MTYP1500a.sd                   del /F ..\..\bin\UnitTestFiles\MTYP1500a.sd
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyLines.fs           del /F ..\..\bin\UnitTestFiles\UT_SymbologyLines.fs
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyLines.ldf          del /F ..\..\bin\UnitTestFiles\UT_SymbologyLines.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyLines.mdf          del /F ..\..\bin\UnitTestFiles\UT_SymbologyLines.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyLines.sdf          del /F ..\..\bin\UnitTestFiles\UT_SymbologyLines.sdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyLinesCrossTick.ldf del /F ..\..\bin\UnitTestFiles\UT_SymbologyLinesCrossTick.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyLinesCrossTick.mdf del /F ..\..\bin\UnitTestFiles\UT_SymbologyLinesCrossTick.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyPoints.fs          del /F ..\..\bin\UnitTestFiles\UT_SymbologyPoints.fs
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyPoints.ldf         del /F ..\..\bin\UnitTestFiles\UT_SymbologyPoints.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyPoints.mdf         del /F ..\..\bin\UnitTestFiles\UT_SymbologyPoints.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyPoints.sdf         del /F ..\..\bin\UnitTestFiles\UT_SymbologyPoints.sdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyPointsParam.ldf    del /F ..\..\bin\UnitTestFiles\UT_SymbologyPointsParam.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyPointsParam.mdf    del /F ..\..\bin\UnitTestFiles\UT_SymbologyPointsParam.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyRoads.fs           del /F ..\..\bin\UnitTestFiles\UT_SymbologyRoads.fs
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyRoads.ldf          del /F ..\..\bin\UnitTestFiles\UT_SymbologyRoads.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyRoads.mdf          del /F ..\..\bin\UnitTestFiles\UT_SymbologyRoads.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyRoads.sdf          del /F ..\..\bin\UnitTestFiles\UT_SymbologyRoads.sdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyParcels.ldf        del /F ..\..\bin\UnitTestFiles\UT_SymbologyParcels.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyPolygons.mdf       del /F ..\..\bin\UnitTestFiles\UT_SymbologyPolygons.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Annotation1.ldf             del /F ..\..\bin\UnitTestFiles\UT_Annotation1.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Annotation1.mdf             del /F ..\..\bin\UnitTestFiles\UT_Annotation1.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Annotation2.ldf             del /F ..\..\bin\UnitTestFiles\UT_Annotation2.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Annotation2.mdf             del /F ..\..\bin\UnitTestFiles\UT_Annotation2.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Annotation3.ldf             del /F ..\..\bin\UnitTestFiles\UT_Annotation3.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Annotation3.mdf             del /F ..\..\bin\UnitTestFiles\UT_Annotation3.mdf
-    if EXIST ..\..\bin\UnitTestFiles\SavePointTest.sqlite           del /F ..\..\bin\UnitTestFiles\SavePointTest.sqlite
-    if EXIST ..\..\bin\UnitTestFiles\SavePointTest.FeatureSource    del /F ..\..\bin\UnitTestFiles\SavePointTest.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\UT_Parcels_SQLite_Join.FeatureSource    del /F ..\..\bin\UnitTestFiles\UT_Parcels_SQLite_Join.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\ParcelsJoinTest.sqlite         del /F ..\..\bin\UnitTestFiles\ParcelsJoinTest.sqlite
-    if EXIST ..\..\bin\UnitTestFiles\JoinTest.sqlite                del /F ..\..\bin\UnitTestFiles\JoinTest.FeatureSource
     del /F   ..\..\bin\debug64\*.ilk
+cleanrelease: cleantestdata \
-cleanrelease:
+cleanbinariesrelease:
     if EXIST ..\..\bin\release\MgFoundation.dll              del /F ..\..\bin\release\MgFoundation.dll
     if EXIST ..\..\bin\release\MgFoundation.pdb              del /F ..\..\bin\release\MgFoundation.pdb
     if EXIST ..\..\bin\release\MgGeometry.dll                del /F ..\..\bin\release\MgGeometry.dll
@@ -1422,117 +466,11 @@
     if EXIST ..\..\bin\release\xerces-c_3_1mg.dll            del /F ..\..\bin\release\xerces-c_3_1mg.dll
     if EXIST ..\..\bin\release\xerces-c_3_1mg.pdb            del /F ..\..\bin\release\xerces-c_3_1mg.pdb
     if EXIST ..\..\bin\release\serverconfig.ini              del /F ..\..\bin\release\serverconfig.ini
+cleanrelease64: cleantestdata \
-cleanrelease64:
+cleanbinariesrelease64:
     if EXIST ..\..\bin\release64\MgFoundation.dll              del /F ..\..\bin\release64\MgFoundation.dll
     if EXIST ..\..\bin\release64\MgFoundation.pdb              del /F ..\..\bin\release64\MgFoundation.pdb
     if EXIST ..\..\bin\release64\MgGeometry.dll                del /F ..\..\bin\release64\MgGeometry.dll
@@ -1564,2276 +502,115 @@
     if EXIST ..\..\bin\release64\xerces-c_3_1mg.dll            del /F ..\..\bin\release64\xerces-c_3_1mg.dll
     if EXIST ..\..\bin\release64\xerces-c_3_1mg.pdb            del /F ..\..\bin\release64\xerces-c_3_1mg.pdb
     if EXIST ..\..\bin\release64\serverconfig.ini              del /F ..\..\bin\release64\serverconfig.ini
-..\..\bin\debug(v100)\MgFoundationd.dll : ..\..\..\Common\bin\debug(v100)\MgFoundationd.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)\MgFoundationd.dll ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\MgFoundationd.pdb : ..\..\..\Common\bin\debug(v100)\MgFoundationd.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)\MgFoundationd.pdb ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\MgPlatformBased.dll : ..\..\..\Common\bin\debug(v100)\MgPlatformBased.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)\MgPlatformBased.dll ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\MgPlatformBased.pdb : ..\..\..\Common\bin\debug(v100)\MgPlatformBased.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)\MgPlatformBased.pdb ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\MgGeometryd.dll : ..\..\..\Common\bin\debug(v100)\MgGeometryd.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)\MgGeometryd.dll ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\MgGeometryd.pdb : ..\..\..\Common\bin\debug(v100)\MgGeometryd.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)\MgGeometryd.pdb ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\MgMapGuideCommond.dll : ..\..\..\Common\bin\debug(v100)\MgMapGuideCommond.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)\MgMapGuideCommond.dll ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\MgMapGuideCommond.pdb : ..\..\..\Common\bin\debug(v100)\MgMapGuideCommond.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)\MgMapGuideCommond.pdb ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\MgMdfModeld.dll : ..\..\..\Common\bin\debug(v100)\MgMdfModeld.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)\MgMdfModeld.dll ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\MgMdfModeld.pdb : ..\..\..\Common\bin\debug(v100)\MgMdfModeld.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)\MgMdfModeld.pdb ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\MgMdfParserd.dll : ..\..\..\Common\bin\debug(v100)\MgMdfParserd.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)\MgMdfParserd.dll ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\MgMdfParserd.pdb : ..\..\..\Common\bin\debug(v100)\MgMdfParserd.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)\MgMdfParserd.pdb ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\MgStylizationd.dll : ..\..\..\Common\bin\debug(v100)\MgStylizationd.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)\MgStylizationd.dll ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\MgStylizationd.pdb : ..\..\..\Common\bin\debug(v100)\MgStylizationd.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)\MgStylizationd.pdb ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\MgRenderersd.dll : ..\..\..\Common\bin\debug(v100)\MgRenderersd.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)\MgRenderersd.dll ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\MgRenderersd.pdb : ..\..\..\Common\bin\debug(v100)\MgRenderersd.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)\MgRenderersd.pdb ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\ACEd.dll : ..\..\..\Oem\ACE\ACE_wrappers\lib\debug(v100)\ACEd.dll
-    xcopy /r /d /y ..\..\..\Oem\ACE\ACE_wrappers\lib\debug(v100)\ACEd.dll ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\ACEd.pdb : ..\..\..\Oem\ACE\ACE_wrappers\lib\debug(v100)\ACEd.pdb
-    xcopy /r /d /y ..\..\..\Oem\ACE\ACE_wrappers\lib\debug(v100)\ACEd.pdb ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\gd.dll : ..\..\..\Oem\gd\build\win32\gd\debug(v100)\gd.dll
-    xcopy /r /d /y ..\..\..\Oem\gd\build\win32\gd\debug(v100)\gd.dll ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\gd.pdb : ..\..\..\Oem\gd\build\win32\gd\debug(v100)\gd.pdb
-    xcopy /r /d /y ..\..\..\Oem\gd\build\win32\gd\debug(v100)\gd.pdb ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\GEOSd.dll : ..\..\..\Oem\geos\VisualStudio\debug(v100)\GEOSd.dll
-    xcopy /r /d /y ..\..\..\Oem\geos\VisualStudio\debug(v100)\GEOSd.dll ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\GEOSd.pdb : ..\..\..\Oem\geos\VisualStudio\debug(v100)\GEOSd.pdb
-    xcopy /r /d /y ..\..\..\Oem\geos\VisualStudio\debug(v100)\GEOSd.pdb ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\libdb48d.dll : ..\..\..\Oem\dbxml\bin\debug(v100)\libdb48d.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\debug(v100)\libdb48d.dll ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\libdb48d.pdb : ..\..\..\Oem\dbxml\bin\debug(v100)\libdb48d.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\debug(v100)\libdb48d.pdb ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\libdbxml25d.dll : ..\..\..\Oem\dbxml\bin\debug(v100)\libdbxml25d.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\debug(v100)\libdbxml25d.dll ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\libdbxml25d.pdb : ..\..\..\Oem\dbxml\bin\debug(v100)\libdbxml25d.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\debug(v100)\libdbxml25d.pdb ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\xqilla24d.dll : ..\..\..\Oem\dbxml\bin\debug(v100)\xqilla24d.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\debug(v100)\xqilla24d.dll ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\xqilla24d.pdb : ..\..\..\Oem\dbxml\bin\debug(v100)\xqilla24d.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\debug(v100)\xqilla24d.pdb ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\xerces-c_3_1mgD.dll : ..\..\..\Oem\dbxml\bin\debug(v100)\xerces-c_3_1mgD.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\debug(v100)\xerces-c_3_1mgD.dll ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\xerces-c_3_1mgD.pdb : ..\..\..\Oem\dbxml\bin\debug(v100)\xerces-c_3_1mgD.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\debug(v100)\xerces-c_3_1mgD.pdb ..\..\bin\debug(v100)\
-..\..\bin\debug(v100)\serverconfig.ini : ..\..\src\Core\serverconfig.ini
-    xcopy /r /d /y ..\..\src\Core\serverconfig.ini ..\..\bin\debug(v100)\
-CopyFdoComponentsdebug(v100) : ..\..\..\Oem\FDO\*.*
-    if NOT EXIST ..\..\bin\debug(v100)\FDO\nul mkdir ..\..\bin\debug(v100)\FDO
-    xcopy /r /d /y /s ..\..\..\Oem\FDO\bin\release ..\..\bin\debug(v100)\FDO\
-CopyFdoProvidersdebug(v100) : ..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml
-    xcopy /r /d /y "..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml" ..\..\bin\debug(v100)\FDO\
-CopySchemadebug(v100) : ..\..\..\Common\Schema\*.xsd
-    if NOT EXIST ..\..\bin\debug(v100)\Schema\nul mkdir ..\..\bin\debug(v100)\Schema
-    xcopy /r /d /y ..\..\..\Common\Schema\*.xsd ..\..\bin\debug(v100)\Schema
-CopyResourcesdebug(v100) : ..\..\..\Common\MapGuideCommon\Resources\mapguide_en.res
-    if NOT EXIST ..\..\bin\debug(v100)\Resources\nul mkdir ..\..\bin\debug(v100)\Resources
-    xcopy /r /d /y "..\..\..\Common\MapGuideCommon\Resources\mapguide_en.res" ..\..\bin\debug(v100)\Resources\
-CopyOgcFilesdebug(v100) : ..\..\src\wms\*.awd ..\..\src\wfs\*.awd
-    if NOT EXIST ..\..\bin\debug(v100)\wms\nul mkdir ..\..\bin\debug(v100)\wms
-    xcopy /r /d /y "..\..\src\wms\*.awd"       ..\..\bin\debug(v100)\wms
-    if NOT EXIST ..\..\bin\debug(v100)\wfs\nul mkdir ..\..\bin\debug(v100)\wfs
-    xcopy /r /d /y "..\..\src\wfs\*.awd"       ..\..\bin\debug(v100)\wfs
-CreatePathsdebug(v100) :
-    if NOT EXIST ..\..\bin\debug(v100)\Logs\nul mkdir ..\..\bin\debug(v100)\Logs
-    if NOT EXIST ..\..\bin\debug(v100)\Packages\nul mkdir ..\..\bin\debug(v100)\Packages
-    if NOT EXIST ..\..\bin\debug(v100)\Temp\nul mkdir ..\..\bin\debug(v100)\Temp
-    if NOT EXIST ..\..\bin\debug(v100)\Repositories\nul mkdir ..\..\bin\debug(v100)\Repositories
-    if NOT EXIST ..\..\bin\debug(v100)\Repositories\Library\nul mkdir ..\..\bin\debug(v100)\Repositories\Library
-    if NOT EXIST ..\..\bin\debug(v100)\Repositories\Library\DataFiles\nul mkdir ..\..\bin\debug(v100)\Repositories\Library\DataFiles
-    if NOT EXIST ..\..\bin\debug(v100)\Repositories\Session\nul mkdir ..\..\bin\debug(v100)\Repositories\Session
-    if NOT EXIST ..\..\bin\debug(v100)\Repositories\Session\DataFiles\nul mkdir ..\..\bin\debug(v100)\Repositories\Session\DataFiles
-    if NOT EXIST ..\..\bin\debug(v100)\Repositories\Site\nul mkdir ..\..\bin\debug(v100)\Repositories\Site
-    if NOT EXIST ..\..\bin\debug(v100)\Repositories\TileCache\nul mkdir ..\..\bin\debug(v100)\Repositories\TileCache
-debug(v100) : ..\..\bin\debug(v100)\MgFoundationd.dll \
-        ..\..\bin\debug(v100)\MgFoundationd.pdb \
-        ..\..\bin\debug(v100)\MgGeometryd.dll \
-        ..\..\bin\debug(v100)\MgGeometryd.pdb \
-        ..\..\bin\debug(v100)\MgPlatformBased.dll \
-        ..\..\bin\debug(v100)\MgPlatformBased.pdb \
-        ..\..\bin\debug(v100)\MgMapGuideCommond.dll \
-        ..\..\bin\debug(v100)\MgMapGuideCommond.pdb \
-        ..\..\bin\debug(v100)\MgMdfModeld.dll \
-        ..\..\bin\debug(v100)\MgMdfModeld.pdb \
-        ..\..\bin\debug(v100)\MgMdfParserd.dll \
-        ..\..\bin\debug(v100)\MgMdfParserd.pdb \
-        ..\..\bin\debug(v100)\MgStylizationd.dll \
-        ..\..\bin\debug(v100)\MgStylizationd.pdb \
-        ..\..\bin\debug(v100)\MgRenderersd.dll \
-        ..\..\bin\debug(v100)\MgRenderersd.pdb \
-        ..\..\bin\debug(v100)\ACEd.dll \
-        ..\..\bin\debug(v100)\ACEd.pdb \
-        ..\..\bin\debug(v100)\gd.dll \
-        ..\..\bin\debug(v100)\gd.pdb \
-        ..\..\bin\debug(v100)\GEOSd.dll \
-        ..\..\bin\debug(v100)\GEOSd.pdb \
-        ..\..\bin\debug(v100)\libdb48d.dll \
-        ..\..\bin\debug(v100)\libdb48d.pdb \
-        ..\..\bin\debug(v100)\libdbxml25d.dll \
-        ..\..\bin\debug(v100)\libdbxml25d.pdb \
-        ..\..\bin\debug(v100)\xqilla24d.dll \
-        ..\..\bin\debug(v100)\xqilla24d.pdb \
-        ..\..\bin\debug(v100)\xerces-c_3_1mgD.dll \
-        ..\..\bin\debug(v100)\xerces-c_3_1mgD.pdb \
-        ..\..\bin\debug(v100)\serverconfig.ini \
-        ..\..\bin\UnitTestFiles\LibraryRepositoryContent.xml \
-        ..\..\bin\UnitTestFiles\SampleRepositoryHeader.xml \
-        ..\..\bin\UnitTestFiles\SampleRepositoryContent.xml \
-        ..\..\bin\UnitTestFiles\TEST.LayerDefinition \
-        ..\..\bin\UnitTestFiles\TEST.FeatureSource \
-        ..\..\bin\UnitTestFiles\TEST.sdf \
-        ..\..\bin\UnitTestFiles\UT_BaseMap.mdf \
-        ..\..\bin\UnitTestFiles\UT_BaseMap.tsd \
-        ..\..\bin\UnitTestFiles\UT_XYZ.tsd \
-        ..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf \
-        ..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf \
-        ..\..\bin\UnitTestFiles\UT_Parcels.fs \
-        ..\..\bin\UnitTestFiles\UT_Parcels.ldf \
-        ..\..\bin\UnitTestFiles\UT_Parcels.sdf \
-        ..\..\bin\UnitTestFiles\UT_RoadCenterLines.fs \
-        ..\..\bin\UnitTestFiles\UT_RoadCenterLines.ldf \
-        ..\..\bin\UnitTestFiles\UT_RoadCenterLines.sdf \
-        ..\..\bin\UnitTestFiles\UT_VotingDistricts.fs \
-        ..\..\bin\UnitTestFiles\UT_VotingDistricts.ldf \
-        ..\..\bin\UnitTestFiles\UT_VotingDistrictsFunctions.ldf \
-        ..\..\bin\UnitTestFiles\UT_VotingDistricts.sdf \
-        ..\..\bin\UnitTestFiles\UT_AllElements.pl \
-        ..\..\bin\UnitTestFiles\UT_NoLegend.pl \
-        ..\..\bin\UnitTestFiles\UT_SymbolMart.sl \
-        ..\..\bin\UnitTestFiles\UT_Symbols.dwf \
-        ..\..\bin\UnitTestFiles\UT_SheboyganWithWatermark.mdf \
-        ..\..\bin\UnitTestFiles\UT_PoweredByMapGuide.wdf \
-        ..\..\bin\UnitTestFiles\UT_Sheboygan.mdf \
-        ..\..\bin\UnitTestFiles\UT_Sheboygan_833.mdf \
-        ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.sdf \
-        ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.fs \
-        ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.ldf \
-        ..\..\bin\UnitTestFiles\UT_Rail.sdf \
-        ..\..\bin\UnitTestFiles\UT_Rail.fs \
-        ..\..\bin\UnitTestFiles\UT_Rail.ldf \
-        ..\..\bin\UnitTestFiles\UT_Rail.wdf \
-        ..\..\bin\UnitTestFiles\UT_Rail_Watermark.ldf \
-        ..\..\bin\UnitTestFiles\Sheboygan_Parcels.FeatureSource \
-        ..\..\bin\UnitTestFiles\Sheboygan_Parcels.sdf \
-        ..\..\bin\UnitTestFiles\Sheboygan_BuildingOutlines.FeatureSource \
-        ..\..\bin\UnitTestFiles\Sheboygan_BuildingOutlines.sdf \
-        ..\..\bin\UnitTestFiles\Sheboygan_VotingDistricts.FeatureSource \
-        ..\..\bin\UnitTestFiles\Sheboygan_VotingDistricts.sdf \
-        ..\..\bin\UnitTestFiles\Empty.FeatureSource \
-        ..\..\bin\UnitTestFiles\Empty.sdf \
-        ..\..\bin\UnitTestFiles\World.mgp \
-        ..\..\bin\UnitTestFiles\World_Countries.sdf \
-        ..\..\bin\UnitTestFiles\Shuttle.zip \
-        ..\..\bin\UnitTestFiles\test.dwf \
-        ..\..\bin\UnitTestFiles\SpaceShip.dwf \
-        ..\..\bin\UnitTestFiles\MapGuideDrawingSource.xml \
-        ..\..\bin\UnitTestFiles\SpaceShipDrawingSource.xml \
-        ..\..\bin\UnitTestFiles\Redding_Parcels.FeatureSource \
-        ..\..\bin\UnitTestFiles\Redding_Parcels.shp \
-        ..\..\bin\UnitTestFiles\Redding_Parcels.dbf \
-        ..\..\bin\UnitTestFiles\Redding_Parcels.shx \
-        ..\..\bin\UnitTestFiles\1.1.1.mgd \
-        ..\..\bin\UnitTestFiles\epsgcodes.txt \
-        ..\..\bin\UnitTestFiles\ogcwkts.txt \
-        ..\..\bin\UnitTestFiles\UT_GetMapKmlResult.txt \
-        ..\..\bin\UnitTestFiles\UT_GetLayerKmlResult.txt \
-        ..\..\bin\UnitTestFiles\UT_GetFeaturesKmlResult.txt \
-        ..\..\bin\UnitTestFiles\TESTChainedInner1ToManyJoin.FeatureSource \
-        ..\..\bin\UnitTestFiles\MdfTestMap.mdf \
-        ..\..\bin\UnitTestFiles\MdfTestTypeStyles.ldf \
-        ..\..\bin\UnitTestFiles\MdfTestCompoundSymbol.sd \
-        ..\..\bin\UnitTestFiles\MdfTestSimpleSymbol.sd \
-        ..\..\bin\UnitTestFiles\areasymbol.sd \
-        ..\..\bin\UnitTestFiles\linesymbol.sd \
-        ..\..\bin\UnitTestFiles\symbol.sd \
-        ..\..\bin\UnitTestFiles\symbolp.sd \
-        ..\..\bin\UnitTestFiles\MTYP1500a.sd \
-        ..\..\bin\UnitTestFiles\UT_SymbologyLines.fs \
-        ..\..\bin\UnitTestFiles\UT_SymbologyLines.ldf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyLines.mdf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyLines.sdf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyLinesCrossTick.ldf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyLinesCrossTick.mdf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyPoints.fs \
-        ..\..\bin\UnitTestFiles\UT_SymbologyPoints.ldf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyPoints.mdf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyPoints.sdf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyPointsParam.ldf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyPointsParam.mdf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyRoads.fs \
-        ..\..\bin\UnitTestFiles\UT_SymbologyRoads.ldf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyRoads.mdf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyRoads.sdf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyParcels.ldf \
-        ..\..\bin\UnitTestFiles\UT_SymbologyPolygons.mdf \
-        ..\..\bin\UnitTestFiles\UT_Annotation1.ldf \
-        ..\..\bin\UnitTestFiles\UT_Annotation1.mdf \
-        ..\..\bin\UnitTestFiles\UT_Annotation2.ldf \
-        ..\..\bin\UnitTestFiles\UT_Annotation2.mdf \
-        ..\..\bin\UnitTestFiles\UT_Annotation3.ldf \
-        ..\..\bin\UnitTestFiles\UT_Annotation3.mdf \
-        ..\..\bin\UnitTestFiles\SavePointTest.sqlite \
-        ..\..\bin\UnitTestFiles\SavePointTest.FeatureSource \
-        ..\..\bin\UnitTestFiles\UT_Parcels_SQLite_Join.FeatureSource \
-        ..\..\bin\UnitTestFiles\UT_FdoJoin.FeatureSource \
-        ..\..\bin\UnitTestFiles\ParcelsJoinTest.sqlite \
-        ..\..\bin\UnitTestFiles\JoinTest.sqlite \
-        CopyFdoComponentsdebug(v100) \
-        CopyFdoProvidersdebug(v100) \
-        CopySchemadebug(v100) \
-        CopyResourcesdebug(v100) \
-        CreatePathsdebug(v100) \
-        CopyOgcFilesdebug(v100)
-..\..\bin\debug(v100)64\MgFoundationd.dll : ..\..\..\Common\bin\debug(v100)64\MgFoundationd.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)64\MgFoundationd.dll ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\MgFoundationd.pdb : ..\..\..\Common\bin\debug(v100)64\MgFoundationd.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)64\MgFoundationd.pdb ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\MgPlatformBased.dll : ..\..\..\Common\bin\debug(v100)64\MgPlatformBased.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)64\MgPlatformBased.dll ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\MgPlatformBased.pdb : ..\..\..\Common\bin\debug(v100)64\MgPlatformBased.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)64\MgPlatformBased.pdb ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\MgGeometryd.dll : ..\..\..\Common\bin\debug(v100)64\MgGeometryd.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)64\MgGeometryd.dll ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\MgGeometryd.pdb : ..\..\..\Common\bin\debug(v100)64\MgGeometryd.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)64\MgGeometryd.pdb ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\MgMapGuideCommond.dll : ..\..\..\Common\bin\debug(v100)64\MgMapGuideCommond.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)64\MgMapGuideCommond.dll ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\MgMapGuideCommond.pdb : ..\..\..\Common\bin\debug(v100)64\MgMapGuideCommond.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)64\MgMapGuideCommond.pdb ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\MgMdfModeld.dll : ..\..\..\Common\bin\debug(v100)64\MgMdfModeld.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)64\MgMdfModeld.dll ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\MgMdfModeld.pdb : ..\..\..\Common\bin\debug(v100)64\MgMdfModeld.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)64\MgMdfModeld.pdb ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\MgMdfParserd.dll : ..\..\..\Common\bin\debug(v100)64\MgMdfParserd.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)64\MgMdfParserd.dll ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\MgMdfParserd.pdb : ..\..\..\Common\bin\debug(v100)64\MgMdfParserd.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)64\MgMdfParserd.pdb ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\MgStylizationd.dll : ..\..\..\Common\bin\debug(v100)64\MgStylizationd.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)64\MgStylizationd.dll ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\MgStylizationd.pdb : ..\..\..\Common\bin\debug(v100)64\MgStylizationd.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)64\MgStylizationd.pdb ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\MgRenderersd.dll : ..\..\..\Common\bin\debug(v100)64\MgRenderersd.dll
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)64\MgRenderersd.dll ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\MgRenderersd.pdb : ..\..\..\Common\bin\debug(v100)64\MgRenderersd.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\debug(v100)64\MgRenderersd.pdb ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\ACEd.dll : ..\..\..\Oem\ACE\ACE_wrappers\lib64\debug(v100)\ACEd.dll
-    xcopy /r /d /y ..\..\..\Oem\ACE\ACE_wrappers\lib64\debug(v100)\ACEd.dll ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\ACEd.pdb : ..\..\..\Oem\ACE\ACE_wrappers\lib64\debug(v100)\ACEd.pdb
-    xcopy /r /d /y ..\..\..\Oem\ACE\ACE_wrappers\lib64\debug(v100)\ACEd.pdb ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\gd.dll : ..\..\..\Oem\gd\build\win32\gd\debug(v100)64\gd.dll
-    xcopy /r /d /y ..\..\..\Oem\gd\build\win32\gd\debug(v100)64\gd.dll ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\gd.pdb : ..\..\..\Oem\gd\build\win32\gd\debug(v100)64\gd.pdb
-    xcopy /r /d /y ..\..\..\Oem\gd\build\win32\gd\debug(v100)64\gd.pdb ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\GEOSd.dll : ..\..\..\Oem\geos\VisualStudio\debug(v100)64\GEOSd.dll
-    xcopy /r /d /y ..\..\..\Oem\geos\VisualStudio\debug(v100)64\GEOSd.dll ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\GEOSd.pdb : ..\..\..\Oem\geos\VisualStudio\debug(v100)64\GEOSd.pdb
-    xcopy /r /d /y ..\..\..\Oem\geos\VisualStudio\debug(v100)64\GEOSd.pdb ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\libdb48d.dll : ..\..\..\Oem\dbxml\bin64\debug(v100)\libdb48d.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\debug(v100)\libdb48d.dll ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\libdb48d.pdb : ..\..\..\Oem\dbxml\bin64\debug(v100)\libdb48d.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\debug(v100)\libdb48d.pdb ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\libdbxml25d.dll : ..\..\..\Oem\dbxml\bin64\debug(v100)\libdbxml25d.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\debug(v100)\libdbxml25d.dll ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\libdbxml25d.pdb : ..\..\..\Oem\dbxml\bin64\debug(v100)\libdbxml25d.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\debug(v100)\libdbxml25d.pdb ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\xqilla24d.dll : ..\..\..\Oem\dbxml\bin64\debug(v100)\xqilla24d.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\debug(v100)\xqilla24d.dll ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\xqilla24d.pdb : ..\..\..\Oem\dbxml\bin64\debug(v100)\xqilla24d.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\debug(v100)\xqilla24d.pdb ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\xerces-c_3_1mgD.dll : ..\..\..\Oem\dbxml\bin64\debug(v100)\xerces-c_3_1mgD.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\debug(v100)\xerces-c_3_1mgD.dll ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\xerces-c_3_1mgD.pdb : ..\..\..\Oem\dbxml\bin64\debug(v100)\xerces-c_3_1mgD.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\debug(v100)\xerces-c_3_1mgD.pdb ..\..\bin\debug(v100)64\
-..\..\bin\debug(v100)64\serverconfig.ini : ..\..\src\Core\serverconfig.ini
-    xcopy /r /d /y ..\..\src\Core\serverconfig.ini ..\..\bin\debug(v100)64\
-CopyFdoComponentsdebug(v100)64 : ..\..\..\Oem\FDO\*.*
-    if NOT EXIST ..\..\bin\debug(v100)64\FDO\nul mkdir ..\..\bin\debug(v100)64\FDO
-    xcopy /r /d /y /s ..\..\..\Oem\FDO\bin\release64 ..\..\bin\debug(v100)64\FDO\
-CopyFdoProvidersdebug(v100)64 : ..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml
-    xcopy /r /d /y "..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml" ..\..\bin\debug(v100)64\FDO\
-CopySchemadebug(v100)64 : ..\..\..\Common\Schema\*.xsd
-    if NOT EXIST ..\..\bin\debug(v100)64\Schema\nul mkdir ..\..\bin\debug(v100)64\Schema
-    xcopy /r /d /y ..\..\..\Common\Schema\*.xsd ..\..\bin\debug(v100)64\Schema
-CopyResourcesdebug(v100)64 : ..\..\..\Common\MapGuideCommon\Resources\mapguide_en.res
-    if NOT EXIST ..\..\bin\debug(v100)64\Resources\nul mkdir ..\..\bin\debug(v100)64\Resources
-    xcopy /r /d /y "..\..\..\Common\MapGuideCommon\Resources\mapguide_en.res" ..\..\bin\debug(v100)64\Resources\
-CopyOgcFilesdebug(v100)64 : ..\..\src\wms\*.awd ..\..\src\wfs\*.awd
-    if NOT EXIST ..\..\bin\debug(v100)64\wms\nul mkdir ..\..\bin\debug(v100)64\wms
-    xcopy /r /d /y "..\..\src\wms\*.awd"       ..\..\bin\debug(v100)64\wms
-    if NOT EXIST ..\..\bin\debug(v100)64\wfs\nul mkdir ..\..\bin\debug(v100)64\wfs
-    xcopy /r /d /y "..\..\src\wfs\*.awd"       ..\..\bin\debug(v100)64\wfs
-CreatePathsdebug(v100)64 :
-    if NOT EXIST ..\..\bin\debug(v100)64\Logs\nul mkdir ..\..\bin\debug(v100)64\Logs
-    if NOT EXIST ..\..\bin\debug(v100)64\Packages\nul mkdir ..\..\bin\debug(v100)64\Packages
-    if NOT EXIST ..\..\bin\debug(v100)64\Temp\nul mkdir ..\..\bin\debug(v100)64\Temp
-    if NOT EXIST ..\..\bin\debug(v100)64\Repositories\nul mkdir ..\..\bin\debug(v100)64\Repositories
-    if NOT EXIST ..\..\bin\debug(v100)64\Repositories\Library\nul mkdir ..\..\bin\debug(v100)64\Repositories\Library
-    if NOT EXIST ..\..\bin\debug(v100)64\Repositories\Library\DataFiles\nul mkdir ..\..\bin\debug(v100)64\Repositories\Library\DataFiles
-    if NOT EXIST ..\..\bin\debug(v100)64\Repositories\Session\nul mkdir ..\..\bin\debug(v100)64\Repositories\Session
-    if NOT EXIST ..\..\bin\debug(v100)64\Repositories\Session\DataFiles\nul mkdir ..\..\bin\debug(v100)64\Repositories\Session\DataFiles
-    if NOT EXIST ..\..\bin\debug(v100)64\Repositories\Site\nul mkdir ..\..\bin\debug(v100)64\Repositories\Site
-    if NOT EXIST ..\..\bin\debug(v100)64\Repositories\TileCache\nul mkdir ..\..\bin\debug(v100)64\Repositories\TileCache
-debug(v100)64 : ..\..\bin\debug(v100)64\MgFoundationd.dll \
-        ..\..\bin\debug(v100)64\MgFoundationd.pdb \
-        ..\..\bin\debug(v100)64\MgGeometryd.dll \
-        ..\..\bin\debug(v100)64\MgGeometryd.pdb \
-        ..\..\bin\debug(v100)64\MgPlatformBased.dll \
-        ..\..\bin\debug(v100)64\MgPlatformBased.pdb \
-        ..\..\bin\debug(v100)64\MgMapGuideCommond.dll \
-        ..\..\bin\debug(v100)64\MgMapGuideCommond.pdb \
-        ..\..\bin\debug(v100)64\MgMdfModeld.dll \
-        ..\..\bin\debug(v100)64\MgMdfModeld.pdb \
-        ..\..\bin\debug(v100)64\MgMdfParserd.dll \
-        ..\..\bin\debug(v100)64\MgMdfParserd.pdb \
-        ..\..\bin\debug(v100)64\MgStylizationd.dll \
-        ..\..\bin\debug(v100)64\MgStylizationd.pdb \
-        ..\..\bin\debug(v100)64\MgRenderersd.dll \
-        ..\..\bin\debug(v100)64\MgRenderersd.pdb \
-        ..\..\bin\debug(v100)64\ACEd.dll \
-        ..\..\bin\debug(v100)64\ACEd.pdb \
-        ..\..\bin\debug(v100)64\gd.dll \
-        ..\..\bin\debug(v100)64\gd.pdb \
-        ..\..\bin\debug(v100)64\GEOSd.dll \
-        ..\..\bin\debug(v100)64\GEOSd.pdb \
-        ..\..\bin\debug(v100)64\libdb48d.dll \
-        ..\..\bin\debug(v100)64\libdb48d.pdb \
-        ..\..\bin\debug(v100)64\libdbxml25d.dll \
-        ..\..\bin\debug(v100)64\libdbxml25d.pdb \
-        ..\..\bin\debug(v100)64\xqilla24d.dll \
-        ..\..\bin\debug(v100)64\xqilla24d.pdb \
-        ..\..\bin\debug(v100)64\xerces-c_3_1mgD.dll \
-        ..\..\bin\debug(v100)64\xerces-c_3_1mgD.pdb \
-        ..\..\bin\debug(v100)64\serverconfig.ini \
-        CopyFdoComponentsdebug(v100)64 \
-        CopyFdoProvidersdebug(v100)64 \
-        CopySchemadebug(v100)64 \
-        CopyResourcesdebug(v100)64 \
-        CreatePathsdebug(v100)64 \
-        CopyOgcFilesdebug(v100)64
-..\..\bin\release(v100)\MgFoundation.dll : ..\..\..\Common\bin\release(v100)\MgFoundation.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)\MgFoundation.dll ..\..\bin\release(v100)\
-..\..\bin\release(v100)\MgFoundation.pdb : ..\..\..\Common\bin\release(v100)\MgFoundation.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)\MgFoundation.pdb ..\..\bin\release(v100)\
-..\..\bin\release(v100)\MgPlatformBase.dll : ..\..\..\Common\bin\release(v100)\MgPlatformBase.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)\MgPlatformBase.dll ..\..\bin\release(v100)\
-..\..\bin\release(v100)\MgPlatformBase.pdb : ..\..\..\Common\bin\release(v100)\MgPlatformBase.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)\MgPlatformBase.pdb ..\..\bin\release(v100)\
-..\..\bin\release(v100)\MgGeometry.dll : ..\..\..\Common\bin\release(v100)\MgGeometry.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)\MgGeometry.dll ..\..\bin\release(v100)\
-..\..\bin\release(v100)\MgGeometry.pdb : ..\..\..\Common\bin\release(v100)\MgGeometry.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)\MgGeometry.pdb ..\..\bin\release(v100)\
-..\..\bin\release(v100)\MgMapGuideCommon.dll : ..\..\..\Common\bin\release(v100)\MgMapGuideCommon.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)\MgMapGuideCommon.dll ..\..\bin\release(v100)\
-..\..\bin\release(v100)\MgMapGuideCommon.pdb : ..\..\..\Common\bin\release(v100)\MgMapGuideCommon.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)\MgMapGuideCommon.pdb ..\..\bin\release(v100)\
-..\..\bin\release(v100)\MgMdfModel.dll : ..\..\..\Common\bin\release(v100)\MgMdfModel.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)\MgMdfModel.dll ..\..\bin\release(v100)\
-..\..\bin\release(v100)\MgMdfModel.pdb : ..\..\..\Common\bin\release(v100)\MgMdfModel.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)\MgMdfModel.pdb ..\..\bin\release(v100)\
-..\..\bin\release(v100)\MgMdfParser.dll : ..\..\..\Common\bin\release(v100)\MgMdfParser.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)\MgMdfParser.dll ..\..\bin\release(v100)\
-..\..\bin\release(v100)\MgMdfParser.pdb : ..\..\..\Common\bin\release(v100)\MgMdfParser.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)\MgMdfParser.pdb ..\..\bin\release(v100)\
-..\..\bin\release(v100)\MgStylization.dll : ..\..\..\Common\bin\release(v100)\MgStylization.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)\MgStylization.dll ..\..\bin\release(v100)\
-..\..\bin\release(v100)\MgStylization.pdb : ..\..\..\Common\bin\release(v100)\MgStylization.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)\MgStylization.pdb ..\..\bin\release(v100)\
-..\..\bin\release(v100)\MgRenderers.dll : ..\..\..\Common\bin\release(v100)\MgRenderers.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)\MgRenderers.dll ..\..\bin\release(v100)\
-..\..\bin\release(v100)\MgRenderers.pdb : ..\..\..\Common\bin\release(v100)\MgRenderers.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)\MgRenderers.pdb ..\..\bin\release(v100)\
-..\..\bin\release(v100)\ACE.dll : ..\..\..\Oem\ACE\ACE_wrappers\lib\release(v100)\ACE.dll
-    xcopy /r /d /y ..\..\..\Oem\ACE\ACE_wrappers\lib\release(v100)\ACE.dll ..\..\bin\release(v100)\
-..\..\bin\release(v100)\ACE.pdb : ..\..\..\Oem\ACE\ACE_wrappers\lib\release(v100)\ACE.pdb
-    xcopy /r /d /y ..\..\..\Oem\ACE\ACE_wrappers\lib\release(v100)\ACE.pdb ..\..\bin\release(v100)\
-..\..\bin\release(v100)\gd.dll : ..\..\..\Oem\gd\build\win32\gd\release(v100)\gd.dll
-    xcopy /r /d /y ..\..\..\Oem\gd\build\win32\gd\release(v100)\gd.dll ..\..\bin\release(v100)\
-..\..\bin\release(v100)\gd.pdb : ..\..\..\Oem\gd\build\win32\gd\release(v100)\gd.pdb
-    xcopy /r /d /y ..\..\..\Oem\gd\build\win32\gd\release(v100)\gd.pdb ..\..\bin\release(v100)\
-..\..\bin\release(v100)\GEOS.dll : ..\..\..\Oem\geos\VisualStudio\release(v100)\GEOS.dll
-    xcopy /r /d /y ..\..\..\Oem\geos\VisualStudio\release(v100)\GEOS.dll ..\..\bin\release(v100)\
-..\..\bin\release(v100)\GEOS.pdb : ..\..\..\Oem\geos\VisualStudio\release(v100)\GEOS.pdb
-    xcopy /r /d /y ..\..\..\Oem\geos\VisualStudio\release(v100)\GEOS.pdb ..\..\bin\release(v100)\
-..\..\bin\release(v100)\libdb48.dll : ..\..\..\Oem\dbxml\bin\release(v100)\libdb48.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\release(v100)\libdb48.dll ..\..\bin\release(v100)\
-..\..\bin\release(v100)\libdb48.pdb : ..\..\..\Oem\dbxml\bin\release(v100)\libdb48.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\release(v100)\libdb48.pdb ..\..\bin\release(v100)\
-..\..\bin\release(v100)\libdbxml25.dll : ..\..\..\Oem\dbxml\bin\release(v100)\libdbxml25.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\release(v100)\libdbxml25.dll ..\..\bin\release(v100)\
-..\..\bin\release(v100)\libdbxml25.pdb : ..\..\..\Oem\dbxml\bin\release(v100)\libdbxml25.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\release(v100)\libdbxml25.pdb ..\..\bin\release(v100)\
-..\..\bin\release(v100)\xqilla24.dll : ..\..\..\Oem\dbxml\bin\release(v100)\xqilla24.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\release(v100)\xqilla24.dll ..\..\bin\release(v100)\
-..\..\bin\release(v100)\xqilla24.pdb : ..\..\..\Oem\dbxml\bin\release(v100)\xqilla24.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\release(v100)\xqilla24.pdb ..\..\bin\release(v100)\
-..\..\bin\release(v100)\xerces-c_3_1mg.dll : ..\..\..\Oem\dbxml\bin\release(v100)\xerces-c_3_1mg.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\release(v100)\xerces-c_3_1mg.dll ..\..\bin\release(v100)\
-..\..\bin\release(v100)\xerces-c_3_1mg.pdb : ..\..\..\Oem\dbxml\bin\release(v100)\xerces-c_3_1mg.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin\release(v100)\xerces-c_3_1mg.pdb ..\..\bin\release(v100)\
-..\..\bin\release(v100)\serverconfig.ini : ..\..\src\Core\serverconfig.ini
-    xcopy /r /d /y ..\..\src\Core\serverconfig.ini ..\..\bin\release(v100)\
-CopyFdoComponentsrelease(v100) : ..\..\..\Oem\FDO\*.*
-    if NOT EXIST ..\..\bin\release(v100)\FDO\nul mkdir ..\..\bin\release(v100)\FDO
-    xcopy /r /d /y /s ..\..\..\Oem\FDO\bin\release ..\..\bin\release(v100)\FDO\
-CopyFdoProvidersrelease(v100) : ..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml
-    xcopy /r /d /y "..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml" ..\..\bin\release(v100)\FDO\
-CopySchemarelease(v100) : ..\..\..\Common\Schema\*.xsd
-    if NOT EXIST ..\..\bin\release(v100)\Schema\nul mkdir ..\..\bin\release(v100)\Schema
-    xcopy /r /d /y ..\..\..\Common\Schema\*.xsd ..\..\bin\release(v100)\Schema
-CopyResourcesrelease(v100) : ..\..\..\Common\MapGuideCommon\Resources\mapguide_en.res
-    if NOT EXIST ..\..\bin\release(v100)\Resources\nul mkdir ..\..\bin\release(v100)\Resources
-    xcopy /r /d /y "..\..\..\Common\MapGuideCommon\Resources\mapguide_en.res" ..\..\bin\release(v100)\Resources\
-CopyOgcFilesrelease(v100) : ..\..\src\wms\*.awd ..\..\src\wfs\*.awd
-    if NOT EXIST ..\..\bin\release(v100)\wms\nul mkdir ..\..\bin\release(v100)\wms
-    xcopy /r /d /y "..\..\src\wms\*.awd"         ..\..\bin\release(v100)\wms
-    if NOT EXIST ..\..\bin\release(v100)\wfs\nul mkdir ..\..\bin\release(v100)\wfs
-    xcopy /r /d /y "..\..\src\wfs\*.awd"         ..\..\bin\release(v100)\wfs
-CreatePathsrelease(v100) :
-    if NOT EXIST ..\..\bin\release(v100)\Logs\nul mkdir ..\..\bin\release(v100)\Logs
-    if NOT EXIST ..\..\bin\release(v100)\Packages\nul mkdir ..\..\bin\release(v100)\Packages
-    if NOT EXIST ..\..\bin\release(v100)\Temp\nul mkdir ..\..\bin\release(v100)\Temp
-    if NOT EXIST ..\..\bin\release(v100)\Repositories\nul mkdir ..\..\bin\release(v100)\Repositories
-    if NOT EXIST ..\..\bin\release(v100)\Repositories\Library\nul mkdir ..\..\bin\release(v100)\Repositories\Library
-    if NOT EXIST ..\..\bin\release(v100)\Repositories\Library\DataFiles\nul mkdir ..\..\bin\release(v100)\Repositories\Library\DataFiles
-    if NOT EXIST ..\..\bin\release(v100)\Repositories\Session\nul mkdir ..\..\bin\release(v100)\Repositories\Session
-    if NOT EXIST ..\..\bin\release(v100)\Repositories\Session\DataFiles\nul mkdir ..\..\bin\release(v100)\Repositories\Session\DataFiles
-    if NOT EXIST ..\..\bin\release(v100)\Repositories\Site\nul mkdir ..\..\bin\release(v100)\Repositories\Site
-    if NOT EXIST ..\..\bin\release(v100)\Repositories\TileCache\nul mkdir ..\..\bin\release(v100)\Repositories\TileCache
-release(v100) : ..\..\bin\release(v100)\MgFoundation.dll \
-          ..\..\bin\release(v100)\MgFoundation.pdb \
-          ..\..\bin\release(v100)\MgGeometry.dll \
-          ..\..\bin\release(v100)\MgGeometry.pdb \
-          ..\..\bin\release(v100)\MgPlatformBase.dll \
-          ..\..\bin\release(v100)\MgPlatformBase.pdb \
-          ..\..\bin\release(v100)\MgMapGuideCommon.dll \
-          ..\..\bin\release(v100)\MgMapGuideCommon.pdb \
-          ..\..\bin\release(v100)\MgMdfModel.dll \
-          ..\..\bin\release(v100)\MgMdfModel.pdb \
-          ..\..\bin\release(v100)\MgMdfParser.dll \
-          ..\..\bin\release(v100)\MgMdfParser.pdb \
-          ..\..\bin\release(v100)\MgStylization.dll \
-          ..\..\bin\release(v100)\MgStylization.pdb \
-          ..\..\bin\release(v100)\MgRenderers.dll \
-          ..\..\bin\release(v100)\MgRenderers.pdb \
-          ..\..\bin\release(v100)\ACE.dll \
-          ..\..\bin\release(v100)\ACE.pdb \
-          ..\..\bin\release(v100)\gd.dll \
-          ..\..\bin\release(v100)\gd.pdb \
-          ..\..\bin\release(v100)\GEOS.dll \
-          ..\..\bin\release(v100)\GEOS.pdb \
-          ..\..\bin\release(v100)\libdb48.dll \
-          ..\..\bin\release(v100)\libdb48.pdb \
-          ..\..\bin\release(v100)\libdbxml25.dll \
-          ..\..\bin\release(v100)\libdbxml25.pdb \
-          ..\..\bin\release(v100)\xqilla24.dll \
-          ..\..\bin\release(v100)\xqilla24.pdb \
-          ..\..\bin\release(v100)\xerces-c_3_1mg.dll \
-          ..\..\bin\release(v100)\xerces-c_3_1mg.pdb \
-          ..\..\bin\release(v100)\serverconfig.ini \
-          CopyFdoComponentsrelease(v100) \
-          CopyFdoProvidersrelease(v100) \
-          CopySchemarelease(v100) \
-          CopyResourcesrelease(v100) \
-          CreatePathsrelease(v100) \
-          CopyOgcFilesrelease(v100)
-..\..\bin\release(v100)64\MgFoundation.dll : ..\..\..\Common\bin\release(v100)64\MgFoundation.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)64\MgFoundation.dll ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\MgFoundation.pdb : ..\..\..\Common\bin\release(v100)64\MgFoundation.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)64\MgFoundation.pdb ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\MgPlatformBase.dll : ..\..\..\Common\bin\release(v100)64\MgPlatformBase.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)64\MgPlatformBase.dll ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\MgPlatformBase.pdb : ..\..\..\Common\bin\release(v100)64\MgPlatformBase.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)64\MgPlatformBase.pdb ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\MgGeometry.dll : ..\..\..\Common\bin\release(v100)64\MgGeometry.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)64\MgGeometry.dll ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\MgGeometry.pdb : ..\..\..\Common\bin\release(v100)64\MgGeometry.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)64\MgGeometry.pdb ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\MgMapGuideCommon.dll : ..\..\..\Common\bin\release(v100)64\MgMapGuideCommon.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)64\MgMapGuideCommon.dll ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\MgMapGuideCommon.pdb : ..\..\..\Common\bin\release(v100)64\MgMapGuideCommon.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)64\MgMapGuideCommon.pdb ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\MgMdfModel.dll : ..\..\..\Common\bin\release(v100)64\MgMdfModel.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)64\MgMdfModel.dll ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\MgMdfModel.pdb : ..\..\..\Common\bin\release(v100)64\MgMdfModel.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)64\MgMdfModel.pdb ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\MgMdfParser.dll : ..\..\..\Common\bin\release(v100)64\MgMdfParser.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)64\MgMdfParser.dll ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\MgMdfParser.pdb : ..\..\..\Common\bin\release(v100)64\MgMdfParser.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)64\MgMdfParser.pdb ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\MgStylization.dll : ..\..\..\Common\bin\release(v100)64\MgStylization.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)64\MgStylization.dll ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\MgStylization.pdb : ..\..\..\Common\bin\release(v100)64\MgStylization.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)64\MgStylization.pdb ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\MgRenderers.dll : ..\..\..\Common\bin\release(v100)64\MgRenderers.dll
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)64\MgRenderers.dll ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\MgRenderers.pdb : ..\..\..\Common\bin\release(v100)64\MgRenderers.pdb
-    xcopy /r /d /y ..\..\..\Common\bin\release(v100)64\MgRenderers.pdb ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\ACE.dll : ..\..\..\Oem\ACE\ACE_wrappers\lib64\release(v100)\ACE.dll
-    xcopy /r /d /y ..\..\..\Oem\ACE\ACE_wrappers\lib64\release(v100)\ACE.dll ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\ACE.pdb : ..\..\..\Oem\ACE\ACE_wrappers\lib64\release(v100)\ACE.pdb
-    xcopy /r /d /y ..\..\..\Oem\ACE\ACE_wrappers\lib64\release(v100)\ACE.pdb ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\gd.dll : ..\..\..\Oem\gd\build\win32\gd\release(v100)64\gd.dll
-    xcopy /r /d /y ..\..\..\Oem\gd\build\win32\gd\release(v100)64\gd.dll ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\gd.pdb : ..\..\..\Oem\gd\build\win32\gd\release(v100)64\gd.pdb
-    xcopy /r /d /y ..\..\..\Oem\gd\build\win32\gd\release(v100)64\gd.pdb ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\GEOS.dll : ..\..\..\Oem\geos\VisualStudio\release(v100)64\GEOS.dll
-    xcopy /r /d /y ..\..\..\Oem\geos\VisualStudio\release(v100)64\GEOS.dll ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\GEOS.pdb : ..\..\..\Oem\geos\VisualStudio\release(v100)64\GEOS.pdb
-    xcopy /r /d /y ..\..\..\Oem\geos\VisualStudio\release(v100)64\GEOS.pdb ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\libdb48.dll : ..\..\..\Oem\dbxml\bin64\release(v100)\libdb48.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\release(v100)\libdb48.dll ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\libdb48.pdb : ..\..\..\Oem\dbxml\bin64\release(v100)\libdb48.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\release(v100)\libdb48.pdb ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\libdbxml25.dll : ..\..\..\Oem\dbxml\bin64\release(v100)\libdbxml25.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\release(v100)\libdbxml25.dll ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\libdbxml25.pdb : ..\..\..\Oem\dbxml\bin64\release(v100)\libdbxml25.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\release(v100)\libdbxml25.pdb ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\xqilla24.dll : ..\..\..\Oem\dbxml\bin64\release(v100)\xqilla24.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\release(v100)\xqilla24.dll ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\xqilla24.pdb : ..\..\..\Oem\dbxml\bin64\release(v100)\xqilla24.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\release(v100)\xqilla24.pdb ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\xerces-c_3_1mg.dll : ..\..\..\Oem\dbxml\bin64\release(v100)\xerces-c_3_1mg.dll
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\release(v100)\xerces-c_3_1mg.dll ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\xerces-c_3_1mg.pdb : ..\..\..\Oem\dbxml\bin64\release(v100)\xerces-c_3_1mg.pdb
-    xcopy /r /d /y ..\..\..\Oem\dbxml\bin64\release(v100)\xerces-c_3_1mg.pdb ..\..\bin\release(v100)64\
-..\..\bin\release(v100)64\serverconfig.ini : ..\..\src\Core\serverconfig.ini
-    xcopy /r /d /y ..\..\src\Core\serverconfig.ini ..\..\bin\release(v100)64\
-CopyFdoComponentsrelease(v100)64 : ..\..\..\Oem\FDO\*.*
-    if NOT EXIST ..\..\bin\release(v100)64\FDO\nul mkdir ..\..\bin\release(v100)64\FDO
-    xcopy /r /d /y /s ..\..\..\Oem\FDO\bin\release64 ..\..\bin\release(v100)64\FDO\
-CopyFdoProvidersrelease(v100)64 : ..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml
-    xcopy /r /d /y "..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml" ..\..\bin\release(v100)64\FDO\
-CopySchemarelease(v100)64 : ..\..\..\Common\Schema\*.xsd
-    if NOT EXIST ..\..\bin\release(v100)64\Schema\nul mkdir ..\..\bin\release(v100)64\Schema
-    xcopy /r /d /y ..\..\..\Common\Schema\*.xsd ..\..\bin\release(v100)64\Schema
-CopyResourcesrelease(v100)64 : ..\..\..\Common\MapGuideCommon\Resources\mapguide_en.res
-    if NOT EXIST ..\..\bin\release(v100)64\Resources\nul mkdir ..\..\bin\release(v100)64\Resources
-    xcopy /r /d /y "..\..\..\Common\MapGuideCommon\Resources\mapguide_en.res" ..\..\bin\release(v100)64\Resources\
-CopyOgcFilesrelease(v100)64 : ..\..\src\wms\*.awd ..\..\src\wfs\*.awd
-    if NOT EXIST ..\..\bin\release(v100)64\wms\nul mkdir ..\..\bin\release(v100)64\wms
-    xcopy /r /d /y "..\..\src\wms\*.awd"         ..\..\bin\release(v100)64\wms
-    if NOT EXIST ..\..\bin\release(v100)64\wfs\nul mkdir ..\..\bin\release(v100)64\wfs
-    xcopy /r /d /y "..\..\src\wfs\*.awd"         ..\..\bin\release(v100)64\wfs
-CreatePathsrelease(v100)64 :
-    if NOT EXIST ..\..\bin\release(v100)64\Logs\nul mkdir ..\..\bin\release(v100)64\Logs
-    if NOT EXIST ..\..\bin\release(v100)64\Packages\nul mkdir ..\..\bin\release(v100)64\Packages
-    if NOT EXIST ..\..\bin\release(v100)64\Temp\nul mkdir ..\..\bin\release(v100)64\Temp
-    if NOT EXIST ..\..\bin\release(v100)64\Repositories\nul mkdir ..\..\bin\release(v100)64\Repositories
-    if NOT EXIST ..\..\bin\release(v100)64\Repositories\Library\nul mkdir ..\..\bin\release(v100)64\Repositories\Library
-    if NOT EXIST ..\..\bin\release(v100)64\Repositories\Library\DataFiles\nul mkdir ..\..\bin\release(v100)64\Repositories\Library\DataFiles
-    if NOT EXIST ..\..\bin\release(v100)64\Repositories\Session\nul mkdir ..\..\bin\release(v100)64\Repositories\Session
-    if NOT EXIST ..\..\bin\release(v100)64\Repositories\Session\DataFiles\nul mkdir ..\..\bin\release(v100)64\Repositories\Session\DataFiles
-    if NOT EXIST ..\..\bin\release(v100)64\Repositories\Site\nul mkdir ..\..\bin\release(v100)64\Repositories\Site
-    if NOT EXIST ..\..\bin\release(v100)64\Repositories\TileCache\nul mkdir ..\..\bin\release(v100)64\Repositories\TileCache
-release(v100)64 : ..\..\bin\release(v100)64\MgFoundation.dll \
-          ..\..\bin\release(v100)64\MgFoundation.pdb \
-          ..\..\bin\release(v100)64\MgGeometry.dll \
-          ..\..\bin\release(v100)64\MgGeometry.pdb \
-          ..\..\bin\release(v100)64\MgPlatformBase.dll \
-          ..\..\bin\release(v100)64\MgPlatformBase.pdb \
-          ..\..\bin\release(v100)64\MgMapGuideCommon.dll \
-          ..\..\bin\release(v100)64\MgMapGuideCommon.pdb \
-          ..\..\bin\release(v100)64\MgMdfModel.dll \
-          ..\..\bin\release(v100)64\MgMdfModel.pdb \
-          ..\..\bin\release(v100)64\MgMdfParser.dll \
-          ..\..\bin\release(v100)64\MgMdfParser.pdb \
-          ..\..\bin\release(v100)64\MgStylization.dll \
-          ..\..\bin\release(v100)64\MgStylization.pdb \
-          ..\..\bin\release(v100)64\MgRenderers.dll \
-          ..\..\bin\release(v100)64\MgRenderers.pdb \
-          ..\..\bin\release(v100)64\ACE.dll \
-          ..\..\bin\release(v100)64\ACE.pdb \
-          ..\..\bin\release(v100)64\gd.dll \
-          ..\..\bin\release(v100)64\gd.pdb \
-          ..\..\bin\release(v100)64\GEOS.dll \
-          ..\..\bin\release(v100)64\GEOS.pdb \
-          ..\..\bin\release(v100)64\libdb48.dll \
-          ..\..\bin\release(v100)64\libdb48.pdb \
-          ..\..\bin\release(v100)64\libdbxml25.dll \
-          ..\..\bin\release(v100)64\libdbxml25.pdb \
-          ..\..\bin\release(v100)64\xqilla24.dll \
-          ..\..\bin\release(v100)64\xqilla24.pdb \
-          ..\..\bin\release(v100)64\xerces-c_3_1mg.dll \
-          ..\..\bin\release(v100)64\xerces-c_3_1mg.pdb \
-          ..\..\bin\release(v100)64\serverconfig.ini \
-          CopyFdoComponentsrelease(v100)64 \
-          CopyFdoProvidersrelease(v100)64 \
-          CopySchemarelease(v100)64 \
-          CopyResourcesrelease(v100)64 \
-          CreatePathsrelease(v100)64 \
-          CopyOgcFilesrelease(v100)64
-cleandebug(v100):
-    if EXIST ..\..\bin\debug(v100)\MgFoundationd.dll               del /F ..\..\bin\debug(v100)\MgFoundationd.dll
-    if EXIST ..\..\bin\debug(v100)\MgFoundationd.pdb               del /F ..\..\bin\debug(v100)\MgFoundationd.pdb
-    if EXIST ..\..\bin\debug(v100)\MgGeometryd.dll                 del /F ..\..\bin\debug(v100)\MgGeometryd.dll
-    if EXIST ..\..\bin\debug(v100)\MgGeometryd.pdb                 del /F ..\..\bin\debug(v100)\MgGeometryd.pdb
-    if EXIST ..\..\bin\debug(v100)\MgPlatformBased.dll             del /F ..\..\bin\debug(v100)\MgPlatformBased.dll
-    if EXIST ..\..\bin\debug(v100)\MgPlatformBased.pdb             del /F ..\..\bin\debug(v100)\MgPlatformBased.pdb
-    if EXIST ..\..\bin\debug(v100)\MgMapGuideCommond.dll           del /F ..\..\bin\debug(v100)\MgMapGuideCommond.dll
-    if EXIST ..\..\bin\debug(v100)\MgMapGuideCommond.pdb           del /F ..\..\bin\debug(v100)\MgMapGuideCommond.pdb
-    if EXIST ..\..\bin\debug(v100)\MgMdfModeld.dll                 del /F ..\..\bin\debug(v100)\MgMdfModeld.dll
-    if EXIST ..\..\bin\debug(v100)\MgMdfModeld.pdb                 del /F ..\..\bin\debug(v100)\MgMdfModeld.pdb
-    if EXIST ..\..\bin\debug(v100)\MgMdfParserd.dll                del /F ..\..\bin\debug(v100)\MgMdfParserd.dll
-    if EXIST ..\..\bin\debug(v100)\MgMdfParserd.pdb                del /F ..\..\bin\debug(v100)\MgMdfParserd.pdb
-    if EXIST ..\..\bin\debug(v100)\MgStylizationd.dll              del /F ..\..\bin\debug(v100)\MgStylizationd.dll
-    if EXIST ..\..\bin\debug(v100)\MgStylizationd.pdb              del /F ..\..\bin\debug(v100)\MgStylizationd.pdb
-    if EXIST ..\..\bin\debug(v100)\MgRenderersd.dll                del /F ..\..\bin\debug(v100)\MgRenderersd.dll
-    if EXIST ..\..\bin\debug(v100)\MgRenderersd.pdb                del /F ..\..\bin\debug(v100)\MgRenderersd.pdb
-    if EXIST ..\..\bin\debug(v100)\ACEd.dll                        del /F ..\..\bin\debug(v100)\ACEd.dll
-    if EXIST ..\..\bin\debug(v100)\ACEd.pdb                        del /F ..\..\bin\debug(v100)\ACEd.pdb
-    if EXIST ..\..\bin\debug(v100)\gd.dll                          del /F ..\..\bin\debug(v100)\gd.dll
-    if EXIST ..\..\bin\debug(v100)\gd.pdb                          del /F ..\..\bin\debug(v100)\gd.pdb
-    if EXIST ..\..\bin\debug(v100)\GEOSd.dll                       del /F ..\..\bin\debug(v100)\GEOSd.dll
-    if EXIST ..\..\bin\debug(v100)\GEOSd.pdb                       del /F ..\..\bin\debug(v100)\GEOSd.pdb
-    if EXIST ..\..\bin\debug(v100)\libdb48d.dll                    del /F ..\..\bin\debug(v100)\libdb48d.dll
-    if EXIST ..\..\bin\debug(v100)\libdb48d.pdb                    del /F ..\..\bin\debug(v100)\libdb48d.pdb
-    if EXIST ..\..\bin\debug(v100)\libdbxml25d.dll                 del /F ..\..\bin\debug(v100)\libdbxml25d.dll
-    if EXIST ..\..\bin\debug(v100)\libdbxml25d.pdb                 del /F ..\..\bin\debug(v100)\libdbxml25d.pdb
-    if EXIST ..\..\bin\debug(v100)\xqilla24d.dll                   del /F ..\..\bin\debug(v100)\xqilla24d.dll
-    if EXIST ..\..\bin\debug(v100)\xqilla24d.pdb                   del /F ..\..\bin\debug(v100)\xqilla24d.pdb
-    if EXIST ..\..\bin\debug(v100)\xerces-c_3_1mgD.dll             del /F ..\..\bin\debug(v100)\xerces-c_3_1mgD.dll
-    if EXIST ..\..\bin\debug(v100)\xerces-c_3_1mgD.pdb             del /F ..\..\bin\debug(v100)\xerces-c_3_1mgD.pdb
-    if EXIST ..\..\bin\debug(v100)\serverconfig.ini                del /F ..\..\bin\debug(v100)\serverconfig.ini
-    if EXIST ..\..\bin\UnitTestFiles\UT_XYZ.tsd                        del /F ..\..\bin\UnitTestFiles\UT_XYZ.tsd
-    if EXIST ..\..\bin\UnitTestFiles\UT_FdoJoin.FeatureSource        del /F ..\..\bin\UnitTestFiles\UT_FdoJoin.FeatureSource
-    del /F   ..\..\bin\debug(v100)\*.ilk
-cleandebug(v100)64:
-    if EXIST ..\..\bin\debug(v100)64\MgFoundationd.dll               del /F ..\..\bin\debug(v100)64\MgFoundationd.dll
-    if EXIST ..\..\bin\debug(v100)64\MgFoundationd.pdb               del /F ..\..\bin\debug(v100)64\MgFoundationd.pdb
-    if EXIST ..\..\bin\debug(v100)64\MgGeometryd.dll                 del /F ..\..\bin\debug(v100)64\MgGeometryd.dll
-    if EXIST ..\..\bin\debug(v100)64\MgGeometryd.pdb                 del /F ..\..\bin\debug(v100)64\MgGeometryd.pdb
-    if EXIST ..\..\bin\debug(v100)64\MgPlatformBased.dll             del /F ..\..\bin\debug(v100)64\MgPlatformBased.dll
-    if EXIST ..\..\bin\debug(v100)64\MgPlatformBased.pdb             del /F ..\..\bin\debug(v100)64\MgPlatformBased.pdb
-    if EXIST ..\..\bin\debug(v100)64\MgMapGuideCommond.dll           del /F ..\..\bin\debug(v100)64\MgMapGuideCommond.dll
-    if EXIST ..\..\bin\debug(v100)64\MgMapGuideCommond.pdb           del /F ..\..\bin\debug(v100)64\MgMapGuideCommond.pdb
-    if EXIST ..\..\bin\debug(v100)64\MgMdfModeld.dll                 del /F ..\..\bin\debug(v100)64\MgMdfModeld.dll
-    if EXIST ..\..\bin\debug(v100)64\MgMdfModeld.pdb                 del /F ..\..\bin\debug(v100)64\MgMdfModeld.pdb
-    if EXIST ..\..\bin\debug(v100)64\MgMdfParserd.dll                del /F ..\..\bin\debug(v100)64\MgMdfParserd.dll
-    if EXIST ..\..\bin\debug(v100)64\MgMdfParserd.pdb                del /F ..\..\bin\debug(v100)64\MgMdfParserd.pdb
-    if EXIST ..\..\bin\debug(v100)64\MgStylizationd.dll              del /F ..\..\bin\debug(v100)64\MgStylizationd.dll
-    if EXIST ..\..\bin\debug(v100)64\MgStylizationd.pdb              del /F ..\..\bin\debug(v100)64\MgStylizationd.pdb
-    if EXIST ..\..\bin\debug(v100)64\MgRenderersd.dll                del /F ..\..\bin\debug(v100)64\MgRenderersd.dll
-    if EXIST ..\..\bin\debug(v100)64\MgRenderersd.pdb                del /F ..\..\bin\debug(v100)64\MgRenderersd.pdb
-    if EXIST ..\..\bin\debug(v100)64\ACEd.dll                        del /F ..\..\bin\debug(v100)64\ACEd.dll
-    if EXIST ..\..\bin\debug(v100)64\ACEd.pdb                        del /F ..\..\bin\debug(v100)64\ACEd.pdb
-    if EXIST ..\..\bin\debug(v100)64\gd.dll                          del /F ..\..\bin\debug(v100)64\gd.dll
-    if EXIST ..\..\bin\debug(v100)64\gd.pdb                          del /F ..\..\bin\debug(v100)64\gd.pdb
-    if EXIST ..\..\bin\debug(v100)64\GEOSd.dll                       del /F ..\..\bin\debug(v100)64\GEOSd.dll
-    if EXIST ..\..\bin\debug(v100)64\GEOSd.pdb                       del /F ..\..\bin\debug(v100)64\GEOSd.pdb
-    if EXIST ..\..\bin\debug(v100)64\libdb48d.dll                    del /F ..\..\bin\debug(v100)64\libdb48d.dll
-    if EXIST ..\..\bin\debug(v100)64\libdb48d.pdb                    del /F ..\..\bin\debug(v100)64\libdb48d.pdb
-    if EXIST ..\..\bin\debug(v100)64\libdbxml25d.dll                 del /F ..\..\bin\debug(v100)64\libdbxml25d.dll
-    if EXIST ..\..\bin\debug(v100)64\libdbxml25d.pdb                 del /F ..\..\bin\debug(v100)64\libdbxml25d.pdb
-    if EXIST ..\..\bin\debug(v100)64\xqilla24d.dll                   del /F ..\..\bin\debug(v100)64\xqilla24d.dll
-    if EXIST ..\..\bin\debug(v100)64\xqilla24d.pdb                   del /F ..\..\bin\debug(v100)64\xqilla24d.pdb
-    if EXIST ..\..\bin\debug(v100)64\xerces-c_3_1mgD.dll             del /F ..\..\bin\debug(v100)64\xerces-c_3_1mgD.dll
-    if EXIST ..\..\bin\debug(v100)64\xerces-c_3_1mgD.pdb             del /F ..\..\bin\debug(v100)64\xerces-c_3_1mgD.pdb
-    if EXIST ..\..\bin\debug(v100)64\serverconfig.ini                del /F ..\..\bin\debug(v100)64\serverconfig.ini
-    if EXIST ..\..\bin\UnitTestFiles\LibraryRepositoryContent.xml   del /F ..\..\bin\UnitTestFiles\LibraryRepositoryContent.xml
-    if EXIST ..\..\bin\UnitTestFiles\SampleRepositoryHeader.xml     del /F ..\..\bin\UnitTestFiles\SampleRepositoryHeader.xml
-    if EXIST ..\..\bin\UnitTestFiles\SampleRepositoryContent.xml    del /F ..\..\bin\UnitTestFiles\SampleRepositoryContent.xml
-    if EXIST ..\..\bin\UnitTestFiles\TEST.LayerDefinition           del /F ..\..\bin\UnitTestFiles\TEST.LayerDefinition
-    if EXIST ..\..\bin\UnitTestFiles\TEST.FeatureSource             del /F ..\..\bin\UnitTestFiles\TEST.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\TEST.sdf                       del /F ..\..\bin\UnitTestFiles\TEST.sdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_BaseMap.mdf                 del /F ..\..\bin\UnitTestFiles\UT_BaseMap.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_BaseMap.tsd                 del /F ..\..\bin\UnitTestFiles\UT_BaseMap.tsd
-    if EXIST ..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf           del /F ..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf        del /F ..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Parcels.fs                  del /F ..\..\bin\UnitTestFiles\UT_Parcels.fs
-    if EXIST ..\..\bin\UnitTestFiles\UT_Parcels.ldf                 del /F ..\..\bin\UnitTestFiles\UT_Parcels.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Parcels.sdf                 del /F ..\..\bin\UnitTestFiles\UT_Parcels.sdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_RoadCenterLines.fs          del /F ..\..\bin\UnitTestFiles\UT_RoadCenterLines.fs
-    if EXIST ..\..\bin\UnitTestFiles\UT_RoadCenterLines.ldf         del /F ..\..\bin\UnitTestFiles\UT_RoadCenterLines.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_RoadCenterLines.sdf         del /F ..\..\bin\UnitTestFiles\UT_RoadCenterLines.sdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_VotingDistricts.fs          del /F ..\..\bin\UnitTestFiles\UT_VotingDistricts.fs
-    if EXIST ..\..\bin\UnitTestFiles\UT_VotingDistricts.ldf         del /F ..\..\bin\UnitTestFiles\UT_VotingDistricts.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_VotingDistrictsFunctions.ldf del /F ..\..\bin\UnitTestFiles\UT_VotingDistrictsFunctions.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_VotingDistricts.sdf         del /F ..\..\bin\UnitTestFiles\UT_VotingDistricts.sdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_AllElements.pl              del /F ..\..\bin\UnitTestFiles\UT_AllElements.pl
-    if EXIST ..\..\bin\UnitTestFiles\UT_NoLegend.pl                 del /F ..\..\bin\UnitTestFiles\UT_NoLegend.pl
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbolMart.sl               del /F ..\..\bin\UnitTestFiles\UT_SymbolMart.sl
-    if EXIST ..\..\bin\UnitTestFiles\UT_Symbols.dwf                 del /F ..\..\bin\UnitTestFiles\UT_Symbols.dwf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SheboyganWithWatermark.mdf  del /F ..\..\bin\UnitTestFiles\UT_SheboyganWithWatermark.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_PoweredByMapGuide.wdf       del /F ..\..\bin\UnitTestFiles\UT_PoweredByMapGuide.wdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Sheboygan.mdf               del /F ..\..\bin\UnitTestFiles\UT_Sheboygan.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Sheboygan_833.mdf           del /F ..\..\bin\UnitTestFiles\UT_Sheboygan_833.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.sdf    del /F ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.sdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.fs     del /F ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.fs
-    if EXIST ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.ldf    del /F ..\..\bin\UnitTestFiles\UT_HydrographicPolygons.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Rail.sdf                    del /F ..\..\bin\UnitTestFiles\UT_Rail.sdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Rail.fs                     del /F ..\..\bin\UnitTestFiles\UT_Rail.fs
-    if EXIST ..\..\bin\UnitTestFiles\UT_Rail.ldf                    del /F ..\..\bin\UnitTestFiles\UT_Rail.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Rail.wdf                    del /F ..\..\bin\UnitTestFiles\UT_Rail.wdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Rail_Watermark.ldf          del /F ..\..\bin\UnitTestFiles\UT_Rail_Watermark.ldf
-    if EXIST ..\..\bin\UnitTestFiles\Sheboygan_Parcels.FeatureSource del /F ..\..\bin\UnitTestFiles\Sheboygan_Parcels.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\Sheboygan_Parcels.sdf          del /F ..\..\bin\UnitTestFiles\Sheboygan_Parcels.sdf
-    if EXIST ..\..\bin\UnitTestFiles\Sheboygan_BuildingOutlines.FeatureSource del /F ..\..\bin\UnitTestFiles\Sheboygan_BuildingOutlines.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\Sheboygan_BuildingOutlines.sdf del /F ..\..\bin\UnitTestFiles\Sheboygan_BuildingOutlines.sdf
-    if EXIST ..\..\bin\UnitTestFiles\Sheboygan_VotingDistricts.FeatureSource del /F ..\..\bin\UnitTestFiles\Sheboygan_VotingDistricts.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\Sheboygan_VotingDistricts.sdf  del /F ..\..\bin\UnitTestFiles\Sheboygan_VotingDistricts.sdf
-    if EXIST ..\..\bin\UnitTestFiles\Empty.FeatureSource            del /F ..\..\bin\UnitTestFiles\Empty.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\Empty.sdf                      del /F ..\..\bin\UnitTestFiles\Empty.sdf
-    if EXIST ..\..\bin\UnitTestFiles\World.mgp                      del /F ..\..\bin\UnitTestFiles\World.mgp
-    if EXIST ..\..\bin\UnitTestFiles\World_Countries.sdf            del /F ..\..\bin\UnitTestFiles\World_Countries.sdf
-    if EXIST ..\..\bin\UnitTestFiles\Shuttle.zip                    del /F ..\..\bin\UnitTestFiles\Shuttle.zip
-    if EXIST ..\..\bin\UnitTestFiles\test.dwf                       del /F ..\..\bin\UnitTestFiles\test.dwf
-    if EXIST ..\..\bin\UnitTestFiles\SpaceShip.dwf                  del /F ..\..\bin\UnitTestFiles\SpaceShip.dwf
-    if EXIST ..\..\bin\UnitTestFiles\MapGuideDrawingSource.xml      del /F ..\..\bin\UnitTestFiles\MapGuideDrawingSource.xml
-    if EXIST ..\..\bin\UnitTestFiles\SpaceShipDrawingSource.xml     del /F ..\..\bin\UnitTestFiles\SpaceShipDrawingSource.xml
-    if EXIST ..\..\bin\UnitTestFiles\Redding_Parcels.FeatureSource  del /F ..\..\bin\UnitTestFiles\Redding_Parcels.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\Redding_Parcels.shp            del /F ..\..\bin\UnitTestFiles\Redding_Parcels.shp
-    if EXIST ..\..\bin\UnitTestFiles\Redding_Parcels.dbf            del /F ..\..\bin\UnitTestFiles\Redding_Parcels.dbf
-    if EXIST ..\..\bin\UnitTestFiles\Redding_Parcels.shx            del /F ..\..\bin\UnitTestFiles\Redding_Parcels.shx
-    if EXIST ..\..\bin\UnitTestFiles\1.1.1.mgd                      del /F ..\..\bin\UnitTestFiles\1.1.1.mgd
-    if EXIST ..\..\bin\UnitTestFiles\epsgcodes.txt                  del /F ..\..\bin\UnitTestFiles\epsgcodes.txt
-    if EXIST ..\..\bin\UnitTestFiles\ogcwkts.txt                    del /F ..\..\bin\UnitTestFiles\ogcwkts.txt
-    if EXIST ..\..\bin\UnitTestFiles\UT_GetMapKmlResult.txt         del /F ..\..\bin\UnitTestFiles\UT_GetMapKmlResult.txt
-    if EXIST ..\..\bin\UnitTestFiles\UT_GetLayerKmlResult.txt       del /F ..\..\bin\UnitTestFiles\UT_GetLayerKmlResult.txt
-    if EXIST ..\..\bin\UnitTestFiles\UT_GetFeaturesKmlResult.txt    del /F ..\..\bin\UnitTestFiles\UT_GetFeaturesKmlResult.txt
-    if EXIST ..\..\bin\UnitTestFiles\TESTChainedInner1ToManyJoin.FeatureSource del /F ..\..\bin\UnitTestFiles\TESTChainedInner1ToManyJoin.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\MdfTestMap.mdf                 del /F ..\..\bin\UnitTestFiles\MdfTestMap.mdf
-    if EXIST ..\..\bin\UnitTestFiles\MdfTestTypeStyles.ldf          del /F ..\..\bin\UnitTestFiles\MdfTestTypeStyles.ldf
-    if EXIST ..\..\bin\UnitTestFiles\MdfTestCompoundSymbol.sd       del /F ..\..\bin\UnitTestFiles\MdfTestCompoundSymbol.sd
-    if EXIST ..\..\bin\UnitTestFiles\MdfTestSimpleSymbol.sd         del /F ..\..\bin\UnitTestFiles\MdfTestSimpleSymbol.sd
-    if EXIST ..\..\bin\UnitTestFiles\areasymbol.sd                  del /F ..\..\bin\UnitTestFiles\areasymbol.sd
-    if EXIST ..\..\bin\UnitTestFiles\linesymbol.sd                  del /F ..\..\bin\UnitTestFiles\linesymbol.sd
-    if EXIST ..\..\bin\UnitTestFiles\symbol.sd                      del /F ..\..\bin\UnitTestFiles\symbol.sd
-    if EXIST ..\..\bin\UnitTestFiles\symbolp.sd                     del /F ..\..\bin\UnitTestFiles\symbolp.sd
-    if EXIST ..\..\bin\UnitTestFiles\MTYP1500a.sd                   del /F ..\..\bin\UnitTestFiles\MTYP1500a.sd
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyLines.fs           del /F ..\..\bin\UnitTestFiles\UT_SymbologyLines.fs
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyLines.ldf          del /F ..\..\bin\UnitTestFiles\UT_SymbologyLines.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyLines.mdf          del /F ..\..\bin\UnitTestFiles\UT_SymbologyLines.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyLines.sdf          del /F ..\..\bin\UnitTestFiles\UT_SymbologyLines.sdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyLinesCrossTick.ldf del /F ..\..\bin\UnitTestFiles\UT_SymbologyLinesCrossTick.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyLinesCrossTick.mdf del /F ..\..\bin\UnitTestFiles\UT_SymbologyLinesCrossTick.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyPoints.fs          del /F ..\..\bin\UnitTestFiles\UT_SymbologyPoints.fs
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyPoints.ldf         del /F ..\..\bin\UnitTestFiles\UT_SymbologyPoints.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyPoints.mdf         del /F ..\..\bin\UnitTestFiles\UT_SymbologyPoints.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyPoints.sdf         del /F ..\..\bin\UnitTestFiles\UT_SymbologyPoints.sdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyPointsParam.ldf    del /F ..\..\bin\UnitTestFiles\UT_SymbologyPointsParam.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyPointsParam.mdf    del /F ..\..\bin\UnitTestFiles\UT_SymbologyPointsParam.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyRoads.fs           del /F ..\..\bin\UnitTestFiles\UT_SymbologyRoads.fs
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyRoads.ldf          del /F ..\..\bin\UnitTestFiles\UT_SymbologyRoads.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyRoads.mdf          del /F ..\..\bin\UnitTestFiles\UT_SymbologyRoads.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyRoads.sdf          del /F ..\..\bin\UnitTestFiles\UT_SymbologyRoads.sdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyParcels.ldf        del /F ..\..\bin\UnitTestFiles\UT_SymbologyParcels.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_SymbologyPolygons.mdf       del /F ..\..\bin\UnitTestFiles\UT_SymbologyPolygons.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Annotation1.ldf             del /F ..\..\bin\UnitTestFiles\UT_Annotation1.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Annotation1.mdf             del /F ..\..\bin\UnitTestFiles\UT_Annotation1.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Annotation2.ldf             del /F ..\..\bin\UnitTestFiles\UT_Annotation2.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Annotation2.mdf             del /F ..\..\bin\UnitTestFiles\UT_Annotation2.mdf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Annotation3.ldf             del /F ..\..\bin\UnitTestFiles\UT_Annotation3.ldf
-    if EXIST ..\..\bin\UnitTestFiles\UT_Annotation3.mdf             del /F ..\..\bin\UnitTestFiles\UT_Annotation3.mdf
-    if EXIST ..\..\bin\UnitTestFiles\SavePointTest.sqlite           del /F ..\..\bin\UnitTestFiles\SavePointTest.sqlite
-    if EXIST ..\..\bin\UnitTestFiles\SavePointTest.FeatureSource    del /F ..\..\bin\UnitTestFiles\SavePointTest.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\UT_Parcels_SQLite_Join.FeatureSource    del /F ..\..\bin\UnitTestFiles\UT_Parcels_SQLite_Join.FeatureSource
-    if EXIST ..\..\bin\UnitTestFiles\ParcelsJoinTest.sqlite         del /F ..\..\bin\UnitTestFiles\ParcelsJoinTest.sqlite
-    if EXIST ..\..\bin\UnitTestFiles\JoinTest.sqlite                del /F ..\..\bin\UnitTestFiles\JoinTest.FeatureSource
-    del /F   ..\..\bin\debug(v100)64\*.ilk
-cleanrelease(v100):
-    if EXIST ..\..\bin\release(v100)\MgFoundation.dll              del /F ..\..\bin\release(v100)\MgFoundation.dll
-    if EXIST ..\..\bin\release(v100)\MgFoundation.pdb              del /F ..\..\bin\release(v100)\MgFoundation.pdb
-    if EXIST ..\..\bin\release(v100)\MgGeometry.dll                del /F ..\..\bin\release(v100)\MgGeometry.dll
-    if EXIST ..\..\bin\release(v100)\MgGeometry.pdb                del /F ..\..\bin\release(v100)\MgGeometry.pdb
-    if EXIST ..\..\bin\release(v100)\MgPlatformBase.dll            del /F ..\..\bin\release(v100)\MgPlatformBase.dll
-    if EXIST ..\..\bin\release(v100)\MgPlatformBase.pdb            del /F ..\..\bin\release(v100)\MgPlatformBase.pdb
-    if EXIST ..\..\bin\release(v100)\MgMapGuideCommon.dll          del /F ..\..\bin\release(v100)\MgMapGuideCommon.dll
-    if EXIST ..\..\bin\release(v100)\MgMapGuideCommon.pdb          del /F ..\..\bin\release(v100)\MgMapGuideCommon.pdb
-    if EXIST ..\..\bin\release(v100)\MgMdfModel.dll                del /F ..\..\bin\release(v100)\MgMdfModel.dll
-    if EXIST ..\..\bin\release(v100)\MgMdfModel.pdb                del /F ..\..\bin\release(v100)\MgMdfModel.pdb
-    if EXIST ..\..\bin\release(v100)\MgMdfParser.dll               del /F ..\..\bin\release(v100)\MgMdfParser.dll
-    if EXIST ..\..\bin\release(v100)\MgMdfParser.pdb               del /F ..\..\bin\release(v100)\MgMdfParser.pdb
-    if EXIST ..\..\bin\release(v100)\MgStylization.dll             del /F ..\..\bin\release(v100)\MgStylization.dll
-    if EXIST ..\..\bin\release(v100)\MgStylization.pdb             del /F ..\..\bin\release(v100)\MgStylization.pdb
-    if EXIST ..\..\bin\release(v100)\MgRenderers.dll               del /F ..\..\bin\release(v100)\MgRenderers.dll
-    if EXIST ..\..\bin\release(v100)\MgRenderers.pdb               del /F ..\..\bin\release(v100)\MgRenderers.pdb
-    if EXIST ..\..\bin\release(v100)\ACE.dll                       del /F ..\..\bin\release(v100)\ACE.dll
-    if EXIST ..\..\bin\release(v100)\ACE.pdb                       del /F ..\..\bin\release(v100)\ACE.pdb
-    if EXIST ..\..\bin\release(v100)\gd.dll                        del /F ..\..\bin\release(v100)\gd.dll
-    if EXIST ..\..\bin\release(v100)\gd.pdb                        del /F ..\..\bin\release(v100)\gd.pdb
-    if EXIST ..\..\bin\release(v100)\GEOS.dll                      del /F ..\..\bin\release(v100)\GEOS.dll
-    if EXIST ..\..\bin\release(v100)\GEOS.pdb                      del /F ..\..\bin\release(v100)\GEOS.pdb
-    if EXIST ..\..\bin\release(v100)\libdb48.dll                   del /F ..\..\bin\release(v100)\libdb48.dll
-    if EXIST ..\..\bin\release(v100)\libdb48.pdb                   del /F ..\..\bin\release(v100)\libdb48.pdb
-    if EXIST ..\..\bin\release(v100)\libdbxml25.dll                del /F ..\..\bin\release(v100)\libdbxml25.dll
-    if EXIST ..\..\bin\release(v100)\libdbxml25.pdb                del /F ..\..\bin\release(v100)\libdbxml25.pdb
-    if EXIST ..\..\bin\release(v100)\xqilla24.dll                  del /F ..\..\bin\release(v100)\xqilla24.dll
-    if EXIST ..\..\bin\release(v100)\xqilla24.pdb                  del /F ..\..\bin\release(v100)\xqilla24.pdb
-    if EXIST ..\..\bin\release(v100)\xerces-c_3_1mg.dll            del /F ..\..\bin\release(v100)\xerces-c_3_1mg.dll
-    if EXIST ..\..\bin\release(v100)\xerces-c_3_1mg.pdb            del /F ..\..\bin\release(v100)\xerces-c_3_1mg.pdb
-    if EXIST ..\..\bin\release(v100)\serverconfig.ini              del /F ..\..\bin\release(v100)\serverconfig.ini
-cleanrelease(v100)64:
-    if EXIST ..\..\bin\release(v100)64\MgFoundation.dll              del /F ..\..\bin\release(v100)64\MgFoundation.dll
-    if EXIST ..\..\bin\release(v100)64\MgFoundation.pdb              del /F ..\..\bin\release(v100)64\MgFoundation.pdb
-    if EXIST ..\..\bin\release(v100)64\MgGeometry.dll                del /F ..\..\bin\release(v100)64\MgGeometry.dll
-    if EXIST ..\..\bin\release(v100)64\MgGeometry.pdb                del /F ..\..\bin\release(v100)64\MgGeometry.pdb
-    if EXIST ..\..\bin\release(v100)64\MgPlatformBase.dll            del /F ..\..\bin\release(v100)64\MgPlatformBase.dll
-    if EXIST ..\..\bin\release(v100)64\MgPlatformBase.pdb            del /F ..\..\bin\release(v100)64\MgPlatformBase.pdb
-    if EXIST ..\..\bin\release(v100)64\MgMapGuideCommon.dll          del /F ..\..\bin\release(v100)64\MgMapGuideCommon.dll
-    if EXIST ..\..\bin\release(v100)64\MgMapGuideCommon.pdb          del /F ..\..\bin\release(v100)64\MgMapGuideCommon.pdb
-    if EXIST ..\..\bin\release(v100)64\MgMdfModel.dll                del /F ..\..\bin\release(v100)64\MgMdfModel.dll
-    if EXIST ..\..\bin\release(v100)64\MgMdfModel.pdb                del /F ..\..\bin\release(v100)64\MgMdfModel.pdb
-    if EXIST ..\..\bin\release(v100)64\MgMdfParser.dll               del /F ..\..\bin\release(v100)64\MgMdfParser.dll
-    if EXIST ..\..\bin\release(v100)64\MgMdfParser.pdb               del /F ..\..\bin\release(v100)64\MgMdfParser.pdb
-    if EXIST ..\..\bin\release(v100)64\MgStylization.dll             del /F ..\..\bin\release(v100)64\MgStylization.dll
-    if EXIST ..\..\bin\release(v100)64\MgStylization.pdb             del /F ..\..\bin\release(v100)64\MgStylization.pdb
-    if EXIST ..\..\bin\release(v100)64\MgRenderers.dll               del /F ..\..\bin\release(v100)64\MgRenderers.dll
-    if EXIST ..\..\bin\release(v100)64\MgRenderers.pdb               del /F ..\..\bin\release(v100)64\MgRenderers.pdb
-    if EXIST ..\..\bin\release(v100)64\ACE.dll                       del /F ..\..\bin\release(v100)64\ACE.dll
-    if EXIST ..\..\bin\release(v100)64\ACE.pdb                       del /F ..\..\bin\release(v100)64\ACE.pdb
-    if EXIST ..\..\bin\release(v100)64\gd.dll                        del /F ..\..\bin\release(v100)64\gd.dll
-    if EXIST ..\..\bin\release(v100)64\gd.pdb                        del /F ..\..\bin\release(v100)64\gd.pdb
-    if EXIST ..\..\bin\release(v100)64\GEOS.dll                      del /F ..\..\bin\release(v100)64\GEOS.dll
-    if EXIST ..\..\bin\release(v100)64\GEOS.pdb                      del /F ..\..\bin\release(v100)64\GEOS.pdb
-    if EXIST ..\..\bin\release(v100)64\libdb48.dll                   del /F ..\..\bin\release(v100)64\libdb48.dll
-    if EXIST ..\..\bin\release(v100)64\libdb48.pdb                   del /F ..\..\bin\release(v100)64\libdb48.pdb
-    if EXIST ..\..\bin\release(v100)64\libdbxml25.dll                del /F ..\..\bin\release(v100)64\libdbxml25.dll
-    if EXIST ..\..\bin\release(v100)64\libdbxml25.pdb                del /F ..\..\bin\release(v100)64\libdbxml25.pdb
-    if EXIST ..\..\bin\release(v100)64\xqilla24.dll                  del /F ..\..\bin\release(v100)64\xqilla24.dll
-    if EXIST ..\..\bin\release(v100)64\xqilla24.pdb                  del /F ..\..\bin\release(v100)64\xqilla24.pdb
-    if EXIST ..\..\bin\release(v100)64\xerces-c_3_1mg.dll            del /F ..\..\bin\release(v100)64\xerces-c_3_1mg.dll
-    if EXIST ..\..\bin\release(v100)64\xerces-c_3_1mg.pdb            del /F ..\..\bin\release(v100)64\xerces-c_3_1mg.pdb
-    if EXIST ..\..\bin\release(v100)64\serverconfig.ini              del /F ..\..\bin\release(v100)64\serverconfig.ini
-"..\..\..\UnitTest\TestData\ResourceService\LibraryRepositoryContent.xml" :
-"..\..\..\UnitTest\TestData\ResourceService\SampleRepositoryHeader.xml" :
-"..\..\..\UnitTest\TestData\ResourceService\SampleRepositoryContent.xml" :
-"..\..\..\UnitTest\TestData\ResourceService\Shuttle.zip" :
-"..\..\..\UnitTest\TestData\DrawingService\test.dwf" :
-"..\..\..\UnitTest\TestData\DrawingService\SpaceShip.dwf" :
-"..\..\..\UnitTest\TestData\DrawingService\MapGuideDrawingSource.xml" :
-"..\..\..\UnitTest\TestData\DrawingService\SpaceShipDrawingSource.xml" :
-"..\..\..\UnitTest\TestData\ResourceService\World_Countries.sdf" :
-"..\..\..\UnitTest\TestData\ResourceService\TEST.LayerDefinition" :
-"..\..\..\UnitTest\TestData\FeatureService\SDF\TEST.FeatureSource" :
-"..\..\..\UnitTest\TestData\FeatureService\SDF\TEST.sdf" :
-"..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_Parcels.FeatureSource" :
-"..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_Parcels.sdf" :
-"..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_BuildingOutlines.FeatureSource" :
-"..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_BuildingOutlines.sdf" :
-"..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_VotingDistricts.FeatureSource" :
-"..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_VotingDistricts.sdf" :
-"..\..\..\UnitTest\TestData\FeatureService\SDF\Empty.FeatureSource" :
-"..\..\..\UnitTest\TestData\FeatureService\SDF\Empty.sdf" :
-"..\..\..\UnitTest\TestData\FeatureService\SDF\TESTChainedInner1ToManyJoin.FeatureSource" :
-"..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.FeatureSource" :
-"..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.shp" :
-"..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.dbf" :
-"..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.shx" :
-"..\..\..\UnitTest\TestData\MappingService\UT_AllElements.pl" :
-"..\..\..\UnitTest\TestData\MappingService\UT_NoLegend.pl" :
-"..\..\..\UnitTest\TestData\MappingService\UT_SymbolMart.sl" :
-"..\..\..\UnitTest\TestData\MappingService\UT_Symbols.dwf" :
-"..\..\..\UnitTest\TestData\MappingService\UT_SheboyganWithWatermark.mdf" :
-"..\..\..\UnitTest\TestData\MappingService\UT_PoweredByMapGuide.wdf" :
-"..\..\..\UnitTest\TestData\MappingService\UT_Sheboygan.mdf" :
-"..\..\..\UnitTest\TestData\MappingService\UT_Sheboygan_833.mdf" :
-"..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.sdf" :
-"..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.fs" :
-"..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.ldf" :
-"..\..\..\UnitTest\TestData\MappingService\UT_Rail.sdf" :
-"..\..\..\UnitTest\TestData\MappingService\UT_Rail.fs" :
-"..\..\..\UnitTest\TestData\MappingService\UT_Rail.ldf" :
-"..\..\..\UnitTest\TestData\MappingService\UT_Rail.wdf" :
-"..\..\..\UnitTest\TestData\MappingService\UT_Rail_Watermark.ldf" :
-"..\..\..\UnitTestFiles\UT_MultiCTS.ldf" :
-"..\..\..\UnitTestFiles\UT_MultiCTSWithTheme.ldf" :
-"..\..\..\UnitTestFiles\UT_MultiFTS.ldf" :
-"..\..\..\UnitTestFiles\UT_MultiFTSSingleCTS.ldf" :
-"..\..\..\UnitTestFiles\UT_MultiFTSWithTheme.ldf" :
-"..\..\..\UnitTestFiles\UT_SingleFTSMultiCTS.ldf" :
-"..\..\..\UnitTest\TestData\MappingService\UT_RotatedPointStyles.ldf" :
-"..\..\..\UnitTest\TestData\TileService\UT_BaseMap.mdf" :
-"..\..\..\UnitTest\TestData\TileService\UT_BaseMap.tsd" :
-"..\..\..\UnitTest\TestData\TileService\UT_XYZ.tsd" :
-"..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSet.mdf" :
-"..\..\..\UnitTest\TestData\TileService\UT_StylizationFuncs.mdf" :
-"..\..\..\UnitTest\TestData\TileService\UT_Parcels.fs" :
-"..\..\..\UnitTest\TestData\TileService\UT_Parcels.ldf" :
-"..\..\..\UnitTest\TestData\TileService\UT_Parcels.sdf" :
-"..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.fs" :
-"..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.ldf" :
-"..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.sdf" :
-"..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.fs" :
-"..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.ldf" :
-"..\..\..\UnitTest\TestData\TileService\UT_VotingDistrictsFunctions.ldf" :
-"..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.sdf" :
-"..\..\..\UnitTest\TestData\ServerAdmin\1.1.1.mgd" :
-"..\..\..\UnitTest\TestData\CoordinateSystems\epsgcodes.txt" :
-"..\..\..\UnitTest\TestData\CoordinateSystems\ogcwkts.txt" :
-"..\..\..\UnitTest\TestData\KmlService\UT_GetMapKmlResult.txt" :
-"..\..\..\UnitTest\TestData\KmlService\UT_GetLayerKmlResult.txt" :
-"..\..\..\UnitTest\TestData\KmlService\UT_GetFeaturesKmlResult.txt" :
-"..\..\..\UnitTest\TestData\MdfModel\MdfTestMap.mdf" :
-"..\..\..\UnitTest\TestData\MdfModel\MdfTestTypeStyles.ldf" :
-"..\..\..\UnitTest\TestData\MdfModel\MdfTestCompoundSymbol.sd" :
-"..\..\..\UnitTest\TestData\MdfModel\MdfTestSimpleSymbol.sd" :
-"..\..\..\UnitTest\TestData\Symbology\areasymbol.sd" :
-"..\..\..\UnitTest\TestData\Symbology\linesymbol.sd" :
-"..\..\..\UnitTest\TestData\Symbology\symbol.sd" :
-"..\..\..\UnitTest\TestData\Symbology\symbolp.sd" :
-"..\..\..\UnitTest\TestData\Symbology\MTYP1500a.sd" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.fs" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.ldf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.mdf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.sdf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLinesCrossTick.ldf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLinesCrossTick.mdf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.fs" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.ldf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.mdf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.sdf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPointsParam.ldf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPointsParam.mdf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.fs" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.ldf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.mdf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.sdf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyParcels.ldf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPolygons.mdf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_Annotation1.ldf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_Annotation1.mdf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_Annotation2.ldf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_Annotation2.mdf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_Annotation3.ldf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_Annotation3.mdf" :
-"..\..\..\UnitTest\TestData\Symbology\UT_Parcels_SQLite_Join.FeatureSource" :
-"..\..\..\UnitTest\TestData\Symbology\UT_FdoJoin.FeatureSource" :
-"..\..\..\UnitTest\TestData\Symbology\ParcelsJoinTest.sqlite" :
-"..\..\..\UnitTest\TestData\Symbology\JoinTest.sqlite" :
-..\..\bin\UnitTestFiles\LibraryRepositoryContent.xml : "..\..\..\UnitTest\TestData\ResourceService\LibraryRepositoryContent.xml"
+CopyTestData:
     if NOT EXIST ..\..\bin\UnitTestFiles\nul mkdir ..\..\bin\UnitTestFiles
-    if EXIST "..\..\..\UnitTest\TestData\ResourceService\LibraryRepositoryContent.xml" xcopy /r /d /y "..\..\..\UnitTest\TestData\ResourceService\LibraryRepositoryContent.xml" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\SampleRepositoryHeader.xml : "..\..\..\UnitTest\TestData\ResourceService\SampleRepositoryHeader.xml"
-    if NOT EXIST ..\..\bin\UnitTestFiles\nul mkdir ..\..\bin\UnitTestFiles
-    if EXIST "..\..\..\UnitTest\TestData\ResourceService\SampleRepositoryHeader.xml" xcopy /r /d /y "..\..\..\UnitTest\TestData\ResourceService\SampleRepositoryHeader.xml" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\SampleRepositoryContent.xml : "..\..\..\UnitTest\TestData\ResourceService\SampleRepositoryContent.xml"
-    if EXIST "..\..\..\UnitTest\TestData\ResourceService\SampleRepositoryContent.xml" xcopy /r /d /y "..\..\..\UnitTest\TestData\ResourceService\SampleRepositoryContent.xml" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\Shuttle.zip : "..\..\..\UnitTest\TestData\ResourceService\Shuttle.zip"
-    if EXIST "..\..\..\UnitTest\TestData\ResourceService\Shuttle.zip" xcopy /r /d /y "..\..\..\UnitTest\TestData\ResourceService\Shuttle.zip" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\test.dwf : "..\..\..\UnitTest\TestData\DrawingService\test.dwf"
-    if EXIST "..\..\..\UnitTest\TestData\DrawingService\test.dwf" xcopy /r /d /y "..\..\..\UnitTest\TestData\DrawingService\test.dwf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\SpaceShip.dwf : "..\..\..\UnitTest\TestData\DrawingService\SpaceShip.dwf"
-    if EXIST "..\..\..\UnitTest\TestData\DrawingService\SpaceShip.dwf" xcopy /r /d /y "..\..\..\UnitTest\TestData\DrawingService\SpaceShip.dwf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\MapGuideDrawingSource.xml : "..\..\..\UnitTest\TestData\DrawingService\MapGuideDrawingSource.xml"
-    if EXIST "..\..\..\UnitTest\TestData\DrawingService\MapGuideDrawingSource.xml" xcopy /r /d /y "..\..\..\UnitTest\TestData\DrawingService\MapGuideDrawingSource.xml" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\SpaceShipDrawingSource.xml : "..\..\..\UnitTest\TestData\DrawingService\SpaceShipDrawingSource.xml"
-    if EXIST "..\..\..\UnitTest\TestData\DrawingService\SpaceShipDrawingSource.xml" xcopy /r /d /y "..\..\..\UnitTest\TestData\DrawingService\SpaceShipDrawingSource.xml" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\World.mgp : "..\..\..\UnitTest\TestData\ResourceService\Shuttle.zip"
-    if EXIST "..\..\..\UnitTest\TestData\ResourceService\Shuttle.zip" copy /y "..\..\..\UnitTest\TestData\ResourceService\Shuttle.zip" ..\..\bin\UnitTestFiles\World.mgp
-..\..\bin\UnitTestFiles\World_Countries.sdf : "..\..\..\UnitTest\TestData\ResourceService\World_Countries.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\ResourceService\World_Countries.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\ResourceService\World_Countries.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\TEST.LayerDefinition : "..\..\..\UnitTest\TestData\ResourceService\TEST.LayerDefinition"
-    if EXIST "..\..\..\UnitTest\TestData\ResourceService\TEST.LayerDefinition" xcopy /r /d /y "..\..\..\UnitTest\TestData\ResourceService\TEST.LayerDefinition" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\TEST.FeatureSource : "..\..\..\UnitTest\TestData\FeatureService\SDF\TEST.FeatureSource"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\TEST.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\TEST.FeatureSource" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\TEST.sdf : "..\..\..\UnitTest\TestData\FeatureService\SDF\TEST.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\TEST.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\TEST.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\Sheboygan_Parcels.FeatureSource : "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_Parcels.FeatureSource"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_Parcels.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_Parcels.FeatureSource" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\Sheboygan_Parcels.sdf : "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_Parcels.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_Parcels.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_Parcels.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\Sheboygan_BuildingOutlines.FeatureSource : "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_BuildingOutlines.FeatureSource"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_BuildingOutlines.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_BuildingOutlines.FeatureSource" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\Sheboygan_BuildingOutlines.sdf : "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_BuildingOutlines.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_BuildingOutlines.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_BuildingOutlines.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\Sheboygan_VotingDistricts.FeatureSource : "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_VotingDistricts.FeatureSource"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_VotingDistricts.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_VotingDistricts.FeatureSource" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\Sheboygan_VotingDistricts.sdf : "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_VotingDistricts.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_VotingDistricts.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_VotingDistricts.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\TESTChainedInner1ToManyJoin.FeatureSource : "..\..\..\UnitTest\TestData\FeatureService\SDF\TESTChainedInner1ToManyJoin.FeatureSource"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\TESTChainedInner1ToManyJoin.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\TESTChainedInner1ToManyJoin.FeatureSource" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\Empty.FeatureSource : "..\..\..\UnitTest\TestData\FeatureService\SDF\Empty.FeatureSource"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\Empty.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\Empty.FeatureSource" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\Empty.sdf : "..\..\..\UnitTest\TestData\FeatureService\SDF\Empty.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\Empty.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\Empty.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\Redding_Parcels.FeatureSource : "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.FeatureSource"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.FeatureSource" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\Redding_Parcels.shp : "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.shp"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.shp" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.shp" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\Redding_Parcels.dbf : "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.dbf"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.dbf" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.dbf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\Redding_Parcels.shx : "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.shx"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.shx" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.shx" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_AllElements.pl : "..\..\..\UnitTest\TestData\MappingService\UT_AllElements.pl"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_AllElements.pl" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_AllElements.pl" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_NoLegend.pl : "..\..\..\UnitTest\TestData\MappingService\UT_NoLegend.pl"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_NoLegend.pl" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_NoLegend.pl" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbolMart.sl : "..\..\..\UnitTest\TestData\MappingService\UT_SymbolMart.sl"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_SymbolMart.sl" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_SymbolMart.sl" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Symbols.dwf : "..\..\..\UnitTest\TestData\MappingService\UT_Symbols.dwf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_Symbols.dwf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_Symbols.dwf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SheboyganWithWatermark.mdf : "..\..\..\UnitTest\TestData\MappingService\UT_SheboyganWithWatermark.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_SheboyganWithWatermark.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_SheboyganWithWatermark.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_PoweredByMapGuide.wdf : "..\..\..\UnitTest\TestData\MappingService\UT_PoweredByMapGuide.wdf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_PoweredByMapGuide.wdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_PoweredByMapGuide.wdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Sheboygan.mdf : "..\..\..\UnitTest\TestData\MappingService\UT_Sheboygan.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_Sheboygan.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_Sheboygan.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Sheboygan_833.mdf : "..\..\..\UnitTest\TestData\MappingService\UT_Sheboygan_833.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_Sheboygan_833.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_Sheboygan_833.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_HydrographicPolygons.sdf : "..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_HydrographicPolygons.fs : "..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.fs"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.fs" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.fs" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_HydrographicPolygons.ldf : "..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Rail.sdf : "..\..\..\UnitTest\TestData\MappingService\UT_Rail.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_Rail.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_Rail.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Rail.fs : "..\..\..\UnitTest\TestData\MappingService\UT_Rail.fs"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_Rail.fs" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_Rail.fs" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Rail.ldf : "..\..\..\UnitTest\TestData\MappingService\UT_Rail.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_Rail.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_Rail.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Rail.wdf : "..\..\..\UnitTest\TestData\MappingService\UT_Rail.wdf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_Rail.wdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_Rail.wdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Rail_Watermark.ldf : "..\..\..\UnitTest\TestData\MappingService\UT_Rail_Watermark.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_Rail_Watermark.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_Rail_Watermark.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_MultiCTS.ldf : "..\..\..\UnitTest\TestData\MappingService\UT_MultiCTS.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_MultiCTS.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_MultiCTS.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_MultiCTSWithTheme.ldf : "..\..\..\UnitTest\TestData\MappingService\UT_MultiCTSWithTheme.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_MultiCTSWithTheme.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_MultiCTSWithTheme.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_MultiFTS.ldf : "..\..\..\UnitTest\TestData\MappingService\UT_MultiFTS.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_MultiFTS.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_MultiFTS.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_MultiFTSSingleCTS.ldf : "..\..\..\UnitTest\TestData\MappingService\UT_MultiFTSSingleCTS.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_MultiFTSSingleCTS.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_MultiFTSSingleCTS.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_MultiFTSWithTheme.ldf : "..\..\..\UnitTest\TestData\MappingService\UT_MultiFTSWithTheme.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_MultiFTSWithTheme.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_MultiFTSWithTheme.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SingleFTSMultiCTS.ldf : "..\..\..\UnitTest\TestData\MappingService\UT_SingleFTSMultiCTS.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_SingleFTSMultiCTS.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_SingleFTSMultiCTS.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_RotatedPointStyles.ldf : "..\..\..\UnitTest\TestData\MappingService\UT_RotatedPointStyles.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_RotatedPointStyles.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_RotatedPointStyles.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_BaseMap.mdf : "..\..\..\UnitTest\TestData\TileService\UT_BaseMap.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_BaseMap.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_BaseMap.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_BaseMap.tsd : "..\..\..\UnitTest\TestData\TileService\UT_BaseMap.tsd"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_BaseMap.tsd" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_BaseMap.tsd" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_XYZ.tsd : "..\..\..\UnitTest\TestData\TileService\UT_XYZ.tsd"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_XYZ.tsd" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_XYZ.tsd" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf : "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSet.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSet.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSet.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf : "..\..\..\UnitTest\TestData\TileService\UT_StylizationFuncs.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_StylizationFuncs.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_StylizationFuncs.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Parcels.fs : "..\..\..\UnitTest\TestData\TileService\UT_Parcels.fs"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_Parcels.fs" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_Parcels.fs" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Parcels.ldf : "..\..\..\UnitTest\TestData\TileService\UT_Parcels.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_Parcels.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_Parcels.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Parcels.sdf : "..\..\..\UnitTest\TestData\TileService\UT_Parcels.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_Parcels.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_Parcels.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_RoadCenterLines.fs : "..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.fs"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.fs" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.fs" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_RoadCenterLines.ldf : "..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_RoadCenterLines.sdf : "..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_VotingDistricts.fs : "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.fs"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.fs" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.fs" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_VotingDistricts.ldf : "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_VotingDistrictsFunctions.ldf : "..\..\..\UnitTest\TestData\TileService\UT_VotingDistrictsFunctions.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_VotingDistrictsFunctions.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_VotingDistrictsFunctions.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_VotingDistricts.sdf : "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\1.1.1.mgd : "..\..\..\UnitTest\TestData\ServerAdmin\1.1.1.mgd"
-    if EXIST "..\..\..\UnitTest\TestData\ServerAdmin\1.1.1.mgd" xcopy /r /d /y "..\..\..\UnitTest\TestData\ServerAdmin\1.1.1.mgd" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\epsgcodes.txt : "..\..\..\UnitTest\TestData\CoordinateSystems\epsgcodes.txt"
-    if EXIST "..\..\..\UnitTest\TestData\CoordinateSystems\epsgcodes.txt" xcopy /r /d /y "..\..\..\UnitTest\TestData\CoordinateSystems\epsgcodes.txt" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\ogcwkts.txt : "..\..\..\UnitTest\TestData\CoordinateSystems\ogcwkts.txt"
-    if EXIST "..\..\..\UnitTest\TestData\CoordinateSystems\ogcwkts.txt" xcopy /r /d /y "..\..\..\UnitTest\TestData\CoordinateSystems\ogcwkts.txt" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_GetMapKmlResult.txt : "..\..\..\UnitTest\TestData\KmlService\UT_GetMapKmlResult.txt"
-    if EXIST "..\..\..\UnitTest\TestData\KmlService\UT_GetMapKmlResult.txt" xcopy /r /d /y "..\..\..\UnitTest\TestData\KmlService\UT_GetMapKmlResult.txt" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_GetLayerKmlResult.txt : "..\..\..\UnitTest\TestData\KmlService\UT_GetLayerKmlResult.txt"
-    if EXIST "..\..\..\UnitTest\TestData\KmlService\UT_GetLayerKmlResult.txt" xcopy /r /d /y "..\..\..\UnitTest\TestData\KmlService\UT_GetLayerKmlResult.txt" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_GetFeaturesKmlResult.txt : "..\..\..\UnitTest\TestData\KmlService\UT_GetFeaturesKmlResult.txt"
-    if EXIST "..\..\..\UnitTest\TestData\KmlService\UT_GetFeaturesKmlResult.txt" xcopy /r /d /y "..\..\..\UnitTest\TestData\KmlService\UT_GetFeaturesKmlResult.txt" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\MdfTestMap.mdf : "..\..\..\UnitTest\TestData\MdfModel\MdfTestMap.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\MdfModel\MdfTestMap.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MdfModel\MdfTestMap.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\MdfTestTypeStyles.ldf : "..\..\..\UnitTest\TestData\MdfModel\MdfTestTypeStyles.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\MdfModel\MdfTestTypeStyles.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MdfModel\MdfTestTypeStyles.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\MdfTestCompoundSymbol.sd : "..\..\..\UnitTest\TestData\MdfModel\MdfTestCompoundSymbol.sd"
-    if EXIST "..\..\..\UnitTest\TestData\MdfModel\MdfTestCompoundSymbol.sd" xcopy /r /d /y "..\..\..\UnitTest\TestData\MdfModel\MdfTestCompoundSymbol.sd" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\MdfTestSimpleSymbol.sd : "..\..\..\UnitTest\TestData\MdfModel\MdfTestSimpleSymbol.sd"
-    if EXIST "..\..\..\UnitTest\TestData\MdfModel\MdfTestSimpleSymbol.sd" xcopy /r /d /y "..\..\..\UnitTest\TestData\MdfModel\MdfTestSimpleSymbol.sd" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\areasymbol.sd : "..\..\..\UnitTest\TestData\Symbology\areasymbol.sd"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\areasymbol.sd" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\areasymbol.sd" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\linesymbol.sd : "..\..\..\UnitTest\TestData\Symbology\linesymbol.sd"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\linesymbol.sd" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\linesymbol.sd" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\symbol.sd : "..\..\..\UnitTest\TestData\Symbology\symbol.sd"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\symbol.sd" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\symbol.sd" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\symbolp.sd : "..\..\..\UnitTest\TestData\Symbology\symbolp.sd"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\symbolp.sd" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\symbolp.sd" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\MTYP1500a.sd : "..\..\..\UnitTest\TestData\Symbology\MTYP1500a.sd"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\MTYP1500a.sd" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\MTYP1500a.sd" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyLines.fs : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.fs"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.fs" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.fs" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyLines.ldf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyLines.mdf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyLines.sdf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyLinesCrossTick.ldf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLinesCrossTick.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLinesCrossTick.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLinesCrossTick.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyLinesCrossTick.mdf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLinesCrossTick.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLinesCrossTick.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLinesCrossTick.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyPoints.fs : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.fs"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.fs" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.fs" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyPoints.ldf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyPoints.mdf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyPoints.sdf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyPointsParam.ldf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPointsParam.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPointsParam.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPointsParam.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyPointsParam.mdf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPointsParam.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPointsParam.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPointsParam.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyRoads.fs : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.fs"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.fs" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.fs" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyRoads.ldf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyRoads.mdf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyRoads.sdf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.sdf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.sdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyParcels.ldf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyParcels.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyParcels.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyParcels.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_SymbologyPolygons.mdf : "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPolygons.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPolygons.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPolygons.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Annotation1.ldf : "..\..\..\UnitTest\TestData\Symbology\UT_Annotation1.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_Annotation1.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_Annotation1.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Annotation1.mdf : "..\..\..\UnitTest\TestData\Symbology\UT_Annotation1.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_Annotation1.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_Annotation1.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Annotation2.ldf : "..\..\..\UnitTest\TestData\Symbology\UT_Annotation2.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_Annotation2.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_Annotation2.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Annotation2.mdf : "..\..\..\UnitTest\TestData\Symbology\UT_Annotation2.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_Annotation2.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_Annotation2.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Annotation3.ldf : "..\..\..\UnitTest\TestData\Symbology\UT_Annotation3.ldf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_Annotation3.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_Annotation3.ldf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Annotation3.mdf : "..\..\..\UnitTest\TestData\Symbology\UT_Annotation3.mdf"
-    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_Annotation3.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_Annotation3.mdf" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\SavePointTest.sqlite : "..\..\..\UnitTest\TestData\FeatureService\SQLite\SavePointTest.sqlite"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SQLite\SavePointTest.sqlite" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SQLite\SavePointTest.sqlite" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\SavePointTest.FeatureSource : "..\..\..\UnitTest\TestData\FeatureService\SQLite\SavePointTest.FeatureSource"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SQLite\SavePointTest.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SQLite\SavePointTest.FeatureSource" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_Parcels_SQLite_Join.FeatureSource : "..\..\..\UnitTest\TestData\FeatureService\SQLite\UT_Parcels_SQLite_Join.FeatureSource"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SQLite\UT_Parcels_SQLite_Join.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SQLite\UT_Parcels_SQLite_Join.FeatureSource" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\UT_FdoJoin.FeatureSource : "..\..\..\UnitTest\TestData\FeatureService\SQLite\UT_FdoJoin.FeatureSource"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SQLite\UT_FdoJoin.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SQLite\UT_FdoJoin.FeatureSource" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\ParcelsJoinTest.sqlite : "..\..\..\UnitTest\TestData\FeatureService\SQLite\ParcelsJoinTest.sqlite"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SQLite\ParcelsJoinTest.sqlite" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SQLite\ParcelsJoinTest.sqlite" ..\..\bin\UnitTestFiles\
-..\..\bin\UnitTestFiles\JoinTest.sqlite : "..\..\..\UnitTest\TestData\FeatureService\SQLite\JoinTest.sqlite"
-    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SQLite\JoinTest.sqlite" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SQLite\JoinTest.sqlite" ..\..\bin\UnitTestFiles\
+    if EXIST "..\..\..\UnitTest\TestData\ResourceService\LibraryRepositoryContent.xml" xcopy /r /d /y "..\..\..\UnitTest\TestData\ResourceService\LibraryRepositoryContent.xml" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\ResourceService\SampleRepositoryHeader.xml" xcopy /r /d /y "..\..\..\UnitTest\TestData\ResourceService\SampleRepositoryHeader.xml" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\ResourceService\SampleRepositoryContent.xml" xcopy /r /d /y "..\..\..\UnitTest\TestData\ResourceService\SampleRepositoryContent.xml" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\ResourceService\Shuttle.zip" xcopy /r /d /y "..\..\..\UnitTest\TestData\ResourceService\Shuttle.zip" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\DrawingService\test.dwf" xcopy /r /d /y "..\..\..\UnitTest\TestData\DrawingService\test.dwf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\DrawingService\SpaceShip.dwf" xcopy /r /d /y "..\..\..\UnitTest\TestData\DrawingService\SpaceShip.dwf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\DrawingService\MapGuideDrawingSource.xml" xcopy /r /d /y "..\..\..\UnitTest\TestData\DrawingService\MapGuideDrawingSource.xml" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\DrawingService\SpaceShipDrawingSource.xml" xcopy /r /d /y "..\..\..\UnitTest\TestData\DrawingService\SpaceShipDrawingSource.xml" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\ResourceService\Shuttle.zip" copy /y "..\..\..\UnitTest\TestData\ResourceService\Shuttle.zip" "..\..\bin\UnitTestFiles\"World.mgp
+    if EXIST "..\..\..\UnitTest\TestData\ResourceService\World_Countries.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\ResourceService\World_Countries.sdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\ResourceService\TEST.LayerDefinition" xcopy /r /d /y "..\..\..\UnitTest\TestData\ResourceService\TEST.LayerDefinition" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\TEST.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\TEST.FeatureSource" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\TEST.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\TEST.sdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_Parcels.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_Parcels.FeatureSource" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_Parcels.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_Parcels.sdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_BuildingOutlines.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_BuildingOutlines.FeatureSource" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_BuildingOutlines.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_BuildingOutlines.sdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_VotingDistricts.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_VotingDistricts.FeatureSource" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_VotingDistricts.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\Sheboygan_VotingDistricts.sdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\TESTChainedInner1ToManyJoin.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\TESTChainedInner1ToManyJoin.FeatureSource" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\Empty.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\Empty.FeatureSource" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SDF\Empty.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SDF\Empty.sdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.FeatureSource" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.shp" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.shp" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.dbf" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.dbf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.shx" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SHP\Redding_Parcels.shx" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_AllElements.pl" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_AllElements.pl" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_NoLegend.pl" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_NoLegend.pl" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_SymbolMart.sl" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_SymbolMart.sl" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_Symbols.dwf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_Symbols.dwf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_SheboyganWithWatermark.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_SheboyganWithWatermark.mdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_PoweredByMapGuide.wdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_PoweredByMapGuide.wdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_Sheboygan.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_Sheboygan.mdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_Sheboygan_833.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_Sheboygan_833.mdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.sdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.fs" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.fs" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_HydrographicPolygons.ldf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_Rail.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_Rail.sdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_Rail.fs" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_Rail.fs" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_Rail.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_Rail.ldf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_Rail.wdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_Rail.wdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_Rail_Watermark.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_Rail_Watermark.ldf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_MultiCTS.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_MultiCTS.ldf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_MultiCTSWithTheme.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_MultiCTSWithTheme.ldf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_MultiFTS.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_MultiFTS.ldf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_MultiFTSSingleCTS.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_MultiFTSSingleCTS.ldf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_MultiFTSWithTheme.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_MultiFTSWithTheme.ldf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_SingleFTSMultiCTS.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_SingleFTSMultiCTS.ldf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MappingService\UT_RotatedPointStyles.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MappingService\UT_RotatedPointStyles.ldf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_BaseMap.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_BaseMap.mdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_BaseMap.tsd" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_BaseMap.tsd" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_XYZ.tsd" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_XYZ.tsd" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSet.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSet.mdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_StylizationFuncs.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_StylizationFuncs.mdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_Parcels.fs" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_Parcels.fs" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_Parcels.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_Parcels.ldf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_Parcels.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_Parcels.sdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.fs" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.fs" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.ldf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.sdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.fs" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.fs" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.ldf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_VotingDistrictsFunctions.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_VotingDistrictsFunctions.ldf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.sdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\ServerAdmin\1.1.1.mgd" xcopy /r /d /y "..\..\..\UnitTest\TestData\ServerAdmin\1.1.1.mgd" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\CoordinateSystems\epsgcodes.txt" xcopy /r /d /y "..\..\..\UnitTest\TestData\CoordinateSystems\epsgcodes.txt" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\CoordinateSystems\ogcwkts.txt" xcopy /r /d /y "..\..\..\UnitTest\TestData\CoordinateSystems\ogcwkts.txt" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\KmlService\UT_GetMapKmlResult.txt" xcopy /r /d /y "..\..\..\UnitTest\TestData\KmlService\UT_GetMapKmlResult.txt" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\KmlService\UT_GetLayerKmlResult.txt" xcopy /r /d /y "..\..\..\UnitTest\TestData\KmlService\UT_GetLayerKmlResult.txt" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\KmlService\UT_GetFeaturesKmlResult.txt" xcopy /r /d /y "..\..\..\UnitTest\TestData\KmlService\UT_GetFeaturesKmlResult.txt" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MdfModel\MdfTestMap.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MdfModel\MdfTestMap.mdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MdfModel\MdfTestTypeStyles.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\MdfModel\MdfTestTypeStyles.ldf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MdfModel\MdfTestCompoundSymbol.sd" xcopy /r /d /y "..\..\..\UnitTest\TestData\MdfModel\MdfTestCompoundSymbol.sd" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\MdfModel\MdfTestSimpleSymbol.sd" xcopy /r /d /y "..\..\..\UnitTest\TestData\MdfModel\MdfTestSimpleSymbol.sd" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\areasymbol.sd" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\areasymbol.sd" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\linesymbol.sd" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\linesymbol.sd" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\symbol.sd" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\symbol.sd" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\symbolp.sd" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\symbolp.sd" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\MTYP1500a.sd" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\MTYP1500a.sd" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.fs" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.fs" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.ldf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.mdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLines.sdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLinesCrossTick.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLinesCrossTick.ldf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLinesCrossTick.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyLinesCrossTick.mdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.fs" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.fs" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.ldf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.mdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPoints.sdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPointsParam.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPointsParam.ldf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPointsParam.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPointsParam.mdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.fs" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.fs" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.ldf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.mdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyRoads.sdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyParcels.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyParcels.ldf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPolygons.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_SymbologyPolygons.mdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_Annotation1.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_Annotation1.ldf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_Annotation1.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_Annotation1.mdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_Annotation2.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_Annotation2.ldf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_Annotation2.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_Annotation2.mdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_Annotation3.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_Annotation3.ldf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\Symbology\UT_Annotation3.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\Symbology\UT_Annotation3.mdf" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SQLite\SavePointTest.sqlite" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SQLite\SavePointTest.sqlite" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SQLite\SavePointTest.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SQLite\SavePointTest.FeatureSource" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SQLite\UT_Parcels_SQLite_Join.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SQLite\UT_Parcels_SQLite_Join.FeatureSource" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SQLite\UT_FdoJoin.FeatureSource" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SQLite\UT_FdoJoin.FeatureSource" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SQLite\ParcelsJoinTest.sqlite" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SQLite\ParcelsJoinTest.sqlite" "..\..\bin\UnitTestFiles\"
+    if EXIST "..\..\..\UnitTest\TestData\FeatureService\SQLite\JoinTest.sqlite" xcopy /r /d /y "..\..\..\UnitTest\TestData\FeatureService\SQLite\JoinTest.sqlite" "..\..\bin\UnitTestFiles\"
More information about the mapguide-commits mailing list
