[mapguide-commits] r8661 - in sandbox/jng: diet diet_oem
svn_mapguide at osgeo.org
Wed May 13 04:40:43 PDT 2015
Author: jng
Date: 2015-05-13 04:40:43 -0700 (Wed, 13 May 2015)
New Revision: 8661
Added:
sandbox/jng/diet_oem/build_oem.sh
Removed:
sandbox/jng/diet/build_oem.sh
Move build_oem.sh to buildpack tree
Deleted: sandbox/jng/diet/build_oem.sh
--- sandbox/jng/diet/build_oem.sh 2015-05-12 11:49:43 UTC (rev 8660)
+++ sandbox/jng/diet/build_oem.sh 2015-05-13 11:40:43 UTC (rev 8661)
@@ -1,691 +0,0 @@
-#! /bin/bash
-# MapGuide Open Source build script.
-# Initialization
-echo "MapGuide Open Source build script for OEM components"
-INSTALLDIR=/usr/local/mapguideopensource
-CLEAN_FLAG=0
-BUILD_CPU=32
-BUILD_CONFIG=release
-while [ $# -gt 0 ]; do # Until you run out of parameters...
- case "$1" in
- -prefix|--prefix)
- INSTALLDIR="$2"
- shift
- -clean|--clean)
- CLEAN_FLAG=1
- shift
- -build|--build)
- BUILD_CPU=$2
- shift
- -config|--config)
- BUILD_CONFIG=$2
- shift
- -help|--help)
- echo "Usage: $0 (options)"
- echo "Options:"
- echo " --prefix [installation directory]"
- echo " --clean [clean all objects and binaries in Oem]"
- echo " --build [32(default)|64]"
- echo " --config [release(default)|debug]"
- echo " --help [Display usage]"
- exit
- esac
- shift # Check next set of parameters.
-done
-echo "OEM Build Initialization ............................"
-echo "Oem Libraries will be installed at: ${INSTALLDIR}"
-LIB_NAME=""
-# Generic Functions
-check_build()
- error=$?
- if [ $error -ne 0 ]; then
- echo "$LIB_NAME: Error build failed ($error)................."
- exit $error
- fi
-check_clean()
- error=$?
- echo "$LIB_NAME: Error clean failed ($error)................."
- exit $error
- fi
-# Build Apache/PHP
-# Notes: none
-init_linuxapt()
- LIB_NAME="Apache/PHP/Tomcat"
-build_linuxapt()
- pushd LinuxApt
- ./build_apt.sh --prefix "${INSTALLDIR}" --with-tomcat
- check_build
- popd
-clean_linuxapt()
- echo "Nothing to clean for LinuxApt"
-# Build ACE 6.2.6
-# Notes: none
-init_ace()
- LIB_NAME="ACE 6.2.6"
- ace_buildbits=32
- ace_debug=0
- ace_optimize=1
- if [ $BUILD_CONFIG = "debug" ]; then
- ace_debug=1
- ace_optimize=0
- chmod +x bin/*.sh
- fi
- if [ $BUILD_CPU -eq 64 ]; then
- ace_buildbits=64
- fi
-build_ace()
- pushd ACE/ACE_wrappers
- ACE_PATH="${PWD}"
- pushd ace
- env ACE_ROOT="${ACE_PATH}" make buildbits=$ace_buildbits debug=$ace_debug optimize=$ace_optimize
- check_build
- popd
- popd
-clean_ace()
- ACE_PATH="${PWD}"
- pushd ace
- env ACE_ROOT="${ACE_PATH}" make clean buildbits=$ace_buildbits debug=$ace_debug optimize=$ace_optimize
- check_clean
- popd
- popd
-# Build DWFCORE 1.0
-# Notes: none
-init_dwfcore()
- LIB_NAME="DWFCORE 1.0"
- pushd DWFTK/develop/global/build/gnu/dwfcore
- if [ $CLEAN_FLAG -eq 0 ]; then
- sh ./build_setup.sh
- fi
- popd
-build_dwfcore()
- pushd DWFTK/develop/global/src/dwfcore
- aclocal
- libtoolize --copy --force
- automake --add-missing --copy
- autoconf
- sh ./configure --disable-optimized --enable-silent-rules --prefix="${INSTALLDIR}"
- else
- sh ./configure --enable-optimized --enable-silent-rules --prefix="${INSTALLDIR}"
- fi
- make
- check_build
- popd
-clean_dwfcore()
- make clean
- check_clean
- popd
-# Build DWFTOOLKIT 7.7
-# Notes: none
-init_dwftk()
- LIB_NAME="DWFTK 7.7"
- pushd DWFTK/develop/global/build/gnu/dwftoolkit
- fi
- popd
-build_dwftk()
- aclocal
- autoconf
- else
- fi
- make
- check_build
- popd
-clean_dwftk()
- make clean
- check_clean
- popd
-# Build GEOS 3.4.2
-# Notes: none
-init_geos()
- LIB_NAME="GEOS 3.4.2"
-build_geos()
- pushd geos
- # For this version of GEOS, don't run the aclocal/libtoolize/automake/autoconf quartet as we normally do, as it
- # may produce an unusable configure script. Just run autoreconf to regenerate the configure script from configure.in
- autoreconf
- sh ./configure --with-pic --enable-silent-rules --prefix="${INSTALLDIR}"
- else
- sh ./configure --enable-silent-rules --prefix="${INSTALLDIR}"
- fi
- make
- # The check build is disabled as the build will fail with automake version < 2.59
- check_build
- popd
-clean_geos()
- pushd geos
- make clean
- check_clean
- popd
-# Build SWIGEx 1.0
-# Notes: none
-init_swigex()
- LIB_NAME="SWIGEx 1.0"
-build_swigex()
- pushd SWIGEx
- mkdir -p Linux/obj/release
- make
- check_build
- popd
-clean_swigex()
- pushd SWIGEx
- # Note: the qmake system is required to regenerate the Makefile.
- # This is disabled.
- # make clean
- # check_clean
- popd
-# Build BDBXML
-# Notes: none
-init_bdbxml()
- LIB_NAME="BDBXML"
-build_bdbxml()
- # Need to force regen of the correct xerces config header before building dbxml proper
- pushd dbxml/xerces-c-src
- sh ./configure
- popd
- # Also need to check and set executable flag for s_paths
- pushd dbxml/dbxml/dist
- chmod +x s_paths
- popd
- pushd dbxml
- sh ./buildall.sh --enable-debug
- else
- sh ./buildall.sh
- fi
- check_build
- popd
-clean_bdbxml()
- pushd dbxml
- sh ./buildall.sh --clean
- check_clean
- popd
-# Build CPPUNIT 1.9.14
-# Notes: none
-init_cppunit()
- LIB_NAME="CPPUNIT 1.9.14"
-build_cppunit()
- pushd CppUnit-1.9.14
- # Force regen of configure to cover our bases
- aclocal -I config
- autoconf
- automake --add-missing --copy --force-missing
- # -ldl is to prevent undefined reference to dlsym/dlopen/dlclose
- sh ./configure --enable-silent-rules --prefix="${INSTALLDIR}" LDFLAGS="-ldl"
- make
- check_build
- popd
-clean_cppunit()
- make clean
- check_clean
- popd
-# Build IMake 1.0
-# Notes: none
-init_imake()
- LIB_NAME="IMake 1.0"
-build_imake()
- pushd ../BuildTools/WebTools/IMake
- mkdir -p Linux/obj/debug
- make
- check_build
- popd
-clean_imake()
- # Note: does not support clean as qmake is needed to regenerate the Makefile.
- # make clean
- # check_clean
- popd
-# Build ZLIB 1.2.3
-# Notes: none
-init_zlib()
- LIB_NAME="ZLIB 1.2.3"
-build_zlib()
- pushd gd/zlib
- sh ./configure
- make
- check_build
- popd
-clean_zlib()
- pushd gd/zlib
- make clean
- check_clean
- popd
-# Build LIBPNG 1.2.8
-# Notes: none
-init_libpng()
- LIB_NAME="LIBPNG 1.2.8"
-build_libpng()
- pushd gd/lpng
- cp scripts/makefile.std makefile
- #Inject -fPIC to CFLAGS for 64-bit
- sed 's/^CFLAGS=/CFLAGS= -fPIC -m64 /g' makefile > makefile64
- make -fmakefile64
- else
- make
- fi
- check_build
- popd
-clean_libpng()
- pushd gd/lpng
- make clean
- check_clean
- popd
-# Build JPEG 6b
-# Notes: none
-init_jpeg()
- LIB_NAME="JPEG 6b"
-build_jpeg()
- pushd gd/jpeg
- # A jconfig.h that is not modifed by ./configure will trip up make, so nuke it first
- rm -f jconfig.h
- sh ./configure --enable-static --disable-shared
- #--with-pic does nothing (probably ancient configure script), so do some sed trickery
- #to inject this flag. Know a better way? Enlighten us :)
- sed 's/^CFLAGS=/CFLAGS= -fPIC -m64 /g' Makefile > Makefile64
- make -fMakefile64
- else
- make
- fi
- check_build
- popd
-clean_jpeg()
- pushd gd/jpeg
- make clean
- check_clean
- popd
-# Build FREETYPE 2.1.10
-# Notes: none
-init_freetype()
- LIB_NAME="FREETYPE 2.1.10"
-build_freetype()
- pushd gd/freetype
- sh ./configure --enable-static --disable-shared --with-pic
- else
- fi
- make
- check_build
- popd
-clean_freetype()
- pushd gd/freetype
- make clean
- check_clean
- popd
-# Build GD 2.0.33
-# Notes: none
-init_gd()
- LIB_NAME="GD 2.0.33"
-build_gd()
- pushd gd/gd
- sh ./configure --enable-static --disable-shared --without-fontconfig --enable-silent-rules --with-pic
- else
- fi
- make
- check_build
- popd
-clean_gd()
- pushd gd/gd
- make clean
- check_clean
- popd
-# Build AGG 2.4
-# Notes: none
-init_agg()
- LIB_NAME="AGG 2.4"
-build_agg()
- pushd agg-2.4
- make EXTRACXXFLAGS="-fPIC -m64"
- else
- make
- fi
- check_build
- popd
-clean_agg()
- pushd agg-2.4
- make clean
- check_clean
- popd
-# Build JSON
-# Notes: none
-init_json()
- LIB_NAME="JSON"
-build_json()
- pushd jsoncpp
- # Use system scons
- scons platform=linux-gcc
- popd
-clean_json()
- pushd jsoncpp
- rm -rf lib buildscons dist
- popd
-# Build CSMAP
-# Notes: none
-init_csmap()
- LIB_NAME="CSMAP"
-build_csmap()
- pushd CsMap
- mkdir -p .libs
- pushd Source
- make -fLibrary.mak PROCESSOR=x64
- else
- make -fLibrary.mak PROCESSOR=x86
- fi
- cp ../lib47/Linux$BUILD_CPU/CsMap.a ../.libs/libCsmap.a
- popd
- pushd Dictionaries
- make -fCompiler.mak PROCESSOR=x64
- else
- make -fCompiler.mak PROCESSOR=x86
- fi
- popd
- check_build
- popd
-clean_csmap()
- pushd CsMap/Source
- make clean -fLibrary.mak PROCESSOR=x64
- else
- make clean -fLibrary.mak PROCESSOR=x86
- fi
- check_clean
- popd
-# Build Fusion
-# Notes: requires Apache Ant
-init_fusion()
- LIB_NAME="Fusion"
-build_fusion()
- pushd fusion
- ant prepare
- ant compress
- popd
-clean_fusion()
- pushd fusion
- ant clean
- popd
-# Script loop
-pushd Oem
-for lib in linuxapt fusion ace dwfcore dwftk geos bdbxml cppunit imake zlib libpng jpeg freetype gd agg json csmap;
-do
- echo "$lib: Initialization..........................."
- init_"$lib"
- if test "$CLEAN_FLAG" = "1"; then
- echo "$lib: Clean ....................................."
- clean_"$lib"
- echo "$lib: Clean Successful .........................."
- else
- echo "$lib: Configure/Build ..........................."
- build_"$lib"
- echo "$lib: Build Successful .........................."
- fi
-done
-popd
Copied: sandbox/jng/diet_oem/build_oem.sh (from rev 8660, sandbox/jng/diet/build_oem.sh)
--- sandbox/jng/diet_oem/build_oem.sh (rev 0)
+++ sandbox/jng/diet_oem/build_oem.sh 2015-05-13 11:40:43 UTC (rev 8661)
@@ -0,0 +1,691 @@
+#! /bin/bash
+# MapGuide Open Source build script.
+# Initialization
+echo "MapGuide Open Source build script for OEM components"
+INSTALLDIR=/usr/local/mapguideopensource
+CLEAN_FLAG=0
+BUILD_CPU=32
+BUILD_CONFIG=release
+while [ $# -gt 0 ]; do # Until you run out of parameters...
+ case "$1" in
+ -prefix|--prefix)
+ INSTALLDIR="$2"
+ shift
+ -clean|--clean)
+ CLEAN_FLAG=1
+ shift
+ -build|--build)
+ BUILD_CPU=$2
+ shift
+ -config|--config)
+ BUILD_CONFIG=$2
+ shift
+ -help|--help)
+ echo "Usage: $0 (options)"
+ echo "Options:"
+ echo " --prefix [installation directory]"
+ echo " --clean [clean all objects and binaries in Oem]"
+ echo " --build [32(default)|64]"
+ echo " --config [release(default)|debug]"
+ echo " --help [Display usage]"
+ exit
+ esac
+ shift # Check next set of parameters.
+done
+echo "OEM Build Initialization ............................"
+echo "Oem Libraries will be installed at: ${INSTALLDIR}"
+LIB_NAME=""
+# Generic Functions
+check_build()
+ error=$?
+ if [ $error -ne 0 ]; then
+ echo "$LIB_NAME: Error build failed ($error)................."
+ exit $error
+ fi
+check_clean()
+ error=$?
+ echo "$LIB_NAME: Error clean failed ($error)................."
+ exit $error
+ fi
+# Build Apache/PHP
+# Notes: none
+init_linuxapt()
+ LIB_NAME="Apache/PHP/Tomcat"
+build_linuxapt()
+ pushd LinuxApt
+ ./build_apt.sh --prefix "${INSTALLDIR}" --with-tomcat
+ check_build
+ popd
+clean_linuxapt()
+ echo "Nothing to clean for LinuxApt"
+# Build ACE 6.2.6
+# Notes: none
+init_ace()
+ LIB_NAME="ACE 6.2.6"
+ ace_buildbits=32
+ ace_debug=0
+ ace_optimize=1
+ if [ $BUILD_CONFIG = "debug" ]; then
+ ace_debug=1
+ ace_optimize=0
+ chmod +x bin/*.sh
+ fi
+ if [ $BUILD_CPU -eq 64 ]; then
+ ace_buildbits=64
+ fi
+build_ace()
+ pushd ACE/ACE_wrappers
+ ACE_PATH="${PWD}"
+ pushd ace
+ env ACE_ROOT="${ACE_PATH}" make buildbits=$ace_buildbits debug=$ace_debug optimize=$ace_optimize
+ check_build
+ popd
+ popd
+clean_ace()
+ ACE_PATH="${PWD}"
+ pushd ace
+ env ACE_ROOT="${ACE_PATH}" make clean buildbits=$ace_buildbits debug=$ace_debug optimize=$ace_optimize
+ check_clean
+ popd
+ popd
+# Build DWFCORE 1.0
+# Notes: none
+init_dwfcore()
+ LIB_NAME="DWFCORE 1.0"
+ pushd DWFTK/develop/global/build/gnu/dwfcore
+ if [ $CLEAN_FLAG -eq 0 ]; then
+ sh ./build_setup.sh
+ fi
+ popd
+build_dwfcore()
+ pushd DWFTK/develop/global/src/dwfcore
+ aclocal
+ libtoolize --copy --force
+ automake --add-missing --copy
+ autoconf
+ sh ./configure --disable-optimized --enable-silent-rules --prefix="${INSTALLDIR}"
+ else
+ sh ./configure --enable-optimized --enable-silent-rules --prefix="${INSTALLDIR}"
+ fi
+ make
+ check_build
+ popd
+clean_dwfcore()
+ make clean
+ check_clean
+ popd
+# Build DWFTOOLKIT 7.7
+# Notes: none
+init_dwftk()
+ LIB_NAME="DWFTK 7.7"
+ pushd DWFTK/develop/global/build/gnu/dwftoolkit
+ fi
+ popd
+build_dwftk()
+ aclocal
+ autoconf
+ else
+ fi
+ make
+ check_build
+ popd
+clean_dwftk()
+ make clean
+ check_clean
+ popd
+# Build GEOS 3.4.2
+# Notes: none
+init_geos()
+ LIB_NAME="GEOS 3.4.2"
+build_geos()
+ pushd geos
+ # For this version of GEOS, don't run the aclocal/libtoolize/automake/autoconf quartet as we normally do, as it
+ # may produce an unusable configure script. Just run autoreconf to regenerate the configure script from configure.in
+ autoreconf
+ sh ./configure --with-pic --enable-silent-rules --prefix="${INSTALLDIR}"
+ else
+ sh ./configure --enable-silent-rules --prefix="${INSTALLDIR}"
+ fi
+ make
+ # The check build is disabled as the build will fail with automake version < 2.59
+ check_build
+ popd
+clean_geos()
+ pushd geos
+ make clean
+ check_clean
+ popd
+# Build SWIGEx 1.0
+# Notes: none
+init_swigex()
+ LIB_NAME="SWIGEx 1.0"
+build_swigex()
+ pushd SWIGEx
+ mkdir -p Linux/obj/release
+ make
+ check_build
+ popd
+clean_swigex()
+ pushd SWIGEx
+ # Note: the qmake system is required to regenerate the Makefile.
+ # This is disabled.
+ # make clean
+ # check_clean
+ popd
+# Build BDBXML
+# Notes: none
+init_bdbxml()
+ LIB_NAME="BDBXML"
+build_bdbxml()
+ # Need to force regen of the correct xerces config header before building dbxml proper
+ pushd dbxml/xerces-c-src
+ sh ./configure
+ popd
+ # Also need to check and set executable flag for s_paths
+ pushd dbxml/dbxml/dist
+ chmod +x s_paths
+ popd
+ pushd dbxml
+ sh ./buildall.sh --enable-debug
+ else
+ sh ./buildall.sh
+ fi
+ check_build
+ popd
+clean_bdbxml()
+ pushd dbxml
+ sh ./buildall.sh --clean
+ check_clean
+ popd
+# Build CPPUNIT 1.9.14
+# Notes: none
+init_cppunit()
+ LIB_NAME="CPPUNIT 1.9.14"
+build_cppunit()
+ pushd CppUnit-1.9.14
+ # Force regen of configure to cover our bases
+ aclocal -I config
+ autoconf
+ automake --add-missing --copy --force-missing
+ # -ldl is to prevent undefined reference to dlsym/dlopen/dlclose
+ sh ./configure --enable-silent-rules --prefix="${INSTALLDIR}" LDFLAGS="-ldl"
+ make
+ check_build
+ popd
+clean_cppunit()
+ make clean
+ check_clean
+ popd
+# Build IMake 1.0
+# Notes: none
+init_imake()
+ LIB_NAME="IMake 1.0"
+build_imake()
+ pushd ../BuildTools/WebTools/IMake
+ mkdir -p Linux/obj/debug
+ make
+ check_build
+ popd
+clean_imake()
+ # Note: does not support clean as qmake is needed to regenerate the Makefile.
+ # make clean
+ # check_clean
+ popd
+# Build ZLIB 1.2.3
+# Notes: none
+init_zlib()
+ LIB_NAME="ZLIB 1.2.3"
+build_zlib()
+ pushd gd/zlib
+ sh ./configure
+ make
+ check_build
+ popd
+clean_zlib()
+ pushd gd/zlib
+ make clean
+ check_clean
+ popd
+# Build LIBPNG 1.2.8
+# Notes: none
+init_libpng()
+ LIB_NAME="LIBPNG 1.2.8"
+build_libpng()
+ pushd gd/lpng
+ cp scripts/makefile.std makefile
+ #Inject -fPIC to CFLAGS for 64-bit
+ sed 's/^CFLAGS=/CFLAGS= -fPIC -m64 /g' makefile > makefile64
+ make -fmakefile64
+ else
+ make
+ fi
+ check_build
+ popd
+clean_libpng()
+ pushd gd/lpng
+ make clean
+ check_clean
+ popd
+# Build JPEG 6b
+# Notes: none
+init_jpeg()
+ LIB_NAME="JPEG 6b"
+build_jpeg()
+ pushd gd/jpeg
+ # A jconfig.h that is not modifed by ./configure will trip up make, so nuke it first
+ rm -f jconfig.h
+ sh ./configure --enable-static --disable-shared
+ #--with-pic does nothing (probably ancient configure script), so do some sed trickery
+ #to inject this flag. Know a better way? Enlighten us :)
+ sed 's/^CFLAGS=/CFLAGS= -fPIC -m64 /g' Makefile > Makefile64
+ make -fMakefile64
+ else
+ make
+ fi
+ check_build
+ popd
+clean_jpeg()
+ pushd gd/jpeg
+ make clean
+ check_clean
+ popd
+# Build FREETYPE 2.1.10
+# Notes: none
+init_freetype()
+ LIB_NAME="FREETYPE 2.1.10"
+build_freetype()
+ pushd gd/freetype
+ sh ./configure --enable-static --disable-shared --with-pic
+ else
+ fi
+ make
+ check_build
+ popd
+clean_freetype()
+ pushd gd/freetype
+ make clean
+ check_clean
+ popd
+# Build GD 2.0.33
+# Notes: none
+init_gd()
+ LIB_NAME="GD 2.0.33"
+build_gd()
+ pushd gd/gd
+ sh ./configure --enable-static --disable-shared --without-fontconfig --enable-silent-rules --with-pic
+ else
+ fi
+ make
+ check_build
+ popd
+clean_gd()
+ pushd gd/gd
+ make clean
+ check_clean
+ popd
+# Build AGG 2.4
+# Notes: none
+init_agg()
+ LIB_NAME="AGG 2.4"
+build_agg()
+ pushd agg-2.4
+ make EXTRACXXFLAGS="-fPIC -m64"
+ else
+ make
+ fi
+ check_build
+ popd
+clean_agg()
+ pushd agg-2.4
+ make clean
+ check_clean
+ popd
+# Build JSON
+# Notes: none
+init_json()
+ LIB_NAME="JSON"
+build_json()
+ pushd jsoncpp
+ # Use system scons
+ scons platform=linux-gcc
+ popd
+clean_json()
+ pushd jsoncpp
+ rm -rf lib buildscons dist
+ popd
+# Build CSMAP
+# Notes: none
+init_csmap()
+ LIB_NAME="CSMAP"
+build_csmap()
+ pushd CsMap
+ mkdir -p .libs
+ pushd Source
+ make -fLibrary.mak PROCESSOR=x64
+ else
+ make -fLibrary.mak PROCESSOR=x86
+ fi
+ cp ../lib47/Linux$BUILD_CPU/CsMap.a ../.libs/libCsmap.a
+ popd
+ pushd Dictionaries
+ make -fCompiler.mak PROCESSOR=x64
+ else
+ make -fCompiler.mak PROCESSOR=x86
+ fi
+ popd
+ check_build
+ popd
+clean_csmap()
+ pushd CsMap/Source
+ make clean -fLibrary.mak PROCESSOR=x64
+ else
+ make clean -fLibrary.mak PROCESSOR=x86
+ fi
+ check_clean
+ popd
+# Build Fusion
+# Notes: requires Apache Ant
+init_fusion()
+ LIB_NAME="Fusion"
+build_fusion()
+ pushd fusion
+ ant prepare
+ ant compress
+ popd
+clean_fusion()
+ pushd fusion
+ ant clean
+ popd
+# Script loop
+pushd Oem
+for lib in linuxapt fusion ace dwfcore dwftk geos bdbxml cppunit imake zlib libpng jpeg freetype gd agg json csmap;
+do
+ echo "$lib: Initialization..........................."
+ init_"$lib"
+ if test "$CLEAN_FLAG" = "1"; then
+ echo "$lib: Clean ....................................."
+ clean_"$lib"
+ echo "$lib: Clean Successful .........................."
+ else
+ echo "$lib: Configure/Build ..........................."
+ build_"$lib"
+ echo "$lib: Build Successful .........................."
+ fi
+done
+popd
Property changes on: sandbox/jng/diet_oem/build_oem.sh
___________________________________________________________________
Added: svn:executable
Added: svn:mergeinfo
+ /branches/2.4/MgDev/build_oem.sh:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/branches/2.6/MgDev/build_oem.sh:8276-8286,8288-8292,8297,8299,8301,8303,8314-8315,8318,8335,8340,8354-8355,8365,8373
/sandbox/adsk/3.0m/build_oem.sh:8563,8584,8607,8625
/sandbox/jng/convenience_apis/build_oem.sh:8262-8268,8271-8363
/sandbox/jng/createruntimemap/build_oem.sh:7486-7555
/sandbox/jng/dwftk/build_oem.sh:8321-8324,8328-8329,8331,8352
/sandbox/jng/geos34x/build_oem.sh:8256-8259
/sandbox/jng/tiling/build_oem.sh:8174-8208
/sandbox/jng/v30/build_oem.sh:8212-8227
/sandbox/rfc94/build_oem.sh:5099-5163
Added: svn:eol-style
+ native
More information about the mapguide-commits
