[mapguide-commits] r8816 - trunk/MgDev
svn_mapguide at osgeo.org
Sat Nov 7 07:39:46 PST 2015
Author: jng
Date: 2015-11-07 07:39:46 -0800 (Sat, 07 Nov 2015)
New Revision: 8816
trunk/MgDev/build.bat
trunk/MgDev/setenvironment.bat
trunk/MgDev/setenvironment64.bat
Update build.bat and setenvironment[64].bat to match current build environment
Modified: trunk/MgDev/build.bat
--- trunk/MgDev/build.bat 2015-11-07 15:35:03 UTC (rev 8815)
+++ trunk/MgDev/build.bat 2015-11-07 15:39:46 UTC (rev 8816)
@@ -188,7 +188,7 @@
if "%errorlevel%"=="1" goto error
rem CsMap is not in Oem.sln, so we need to build that separately
echo [build]: Building Oem - CSMap
-%MSBUILD% %MG_OEM%\CsMap\VC110\OpenSource.sln
+%MSBUILD% %MG_OEM%\CsMap\VC140\OpenSource.sln
if "%TYPECOMPONENT%"=="oem" goto quit
if "%TYPECOMPONENT%"=="server" goto quit
Modified: trunk/MgDev/setenvironment.bat
--- trunk/MgDev/setenvironment.bat 2015-11-07 15:35:03 UTC (rev 8815)
+++ trunk/MgDev/setenvironment.bat 2015-11-07 15:39:46 UTC (rev 8816)
@@ -85,7 +85,7 @@
rem running
rem ==================================================
-IF "%JAVA_HOME%" == "" SET JAVA_HOME=C:\Program Files (x86)\Java\jdk1.7.0_71
+IF "%JAVA_HOME%" == "" SET JAVA_HOME=C:\Program Files (x86)\Java\jdk1.7.0_80
IF "%DOXYGEN%" == "" SET DOXYGEN=%MG_DEV%\BuildTools\doxygen
IF "%GNUWIN32%" == "" SET GNUWIN32=C:\Program Files (x86)\GnuWin32\bin
IF "%SEVENZ%" == "" SET SEVENZ=%MG_DEV%\BuildTools\WebTools\7-Zip
Modified: trunk/MgDev/setenvironment64.bat
--- trunk/MgDev/setenvironment64.bat 2015-11-07 15:35:03 UTC (rev 8815)
+++ trunk/MgDev/setenvironment64.bat 2015-11-07 15:39:46 UTC (rev 8816)
@@ -90,7 +90,7 @@
rem running
-IF "%JAVA_HOME%" == "" SET JAVA_HOME=C:\Program Files\Java\jdk1.7.0_71
+IF "%JAVA_HOME%" == "" SET JAVA_HOME=C:\Program Files\Java\jdk1.7.0_80
IF "%DOXYGEN%" == "" SET DOXYGEN=C:\Program Files\doxygen\bin
More information about the mapguide-commits
