[mapguide-commits] r8922 - sandbox/adsk/3.1n/Server/src/Services/Feature
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Apr 15 01:56:29 PDT 2016
Author: hubu
Date: 2016-04-15 01:56:29 -0700 (Fri, 15 Apr 2016)
New Revision: 8922
   sandbox/adsk/3.1n/Server/src/Services/Feature/SelectCommand.cpp
   sandbox/adsk/3.1n/Server/src/Services/Feature/SelectCommand.h
Some providers such as Sqlite provider, CreateCommand(FdoCommandType_Select) will return a extended select command. So we need to check if it is really a extended select command before using it.
Modified: sandbox/adsk/3.1n/Server/src/Services/Feature/SelectCommand.cpp
--- sandbox/adsk/3.1n/Server/src/Services/Feature/SelectCommand.cpp	2016-04-15 08:26:53 UTC (rev 8921)
+++ sandbox/adsk/3.1n/Server/src/Services/Feature/SelectCommand.cpp	2016-04-15 08:56:29 UTC (rev 8922)
@@ -50,7 +50,7 @@
     // For SDF/SHP providers, they do not support ordering. But, they can support ordering through the FdoIExtendedSelect
     // command, provided that only a single property is being ordered on. So if it is the case that normal ordering is
     // not supported, we should try for extended select if the conditions are met.
-    bool bTryExtendedSelect = false;
+    m_bUseExtendedSelect = false;
     if (NULL != options)
         Ptr<MgStringCollection> orderProps = options->GetOrderingProperties();
@@ -65,7 +65,7 @@
                     if (FdoCommandType_ExtendedSelect == cmds[i] && orderProps->GetCount() == 1)
-                        bTryExtendedSelect = true;
+                        m_bUseExtendedSelect = true;
                         break;
@@ -74,7 +74,7 @@
     // Create FdoISelect command
-    if (bTryExtendedSelect)
+    if (m_bUseExtendedSelect)
         m_command = (FdoIExtendedSelect*)fdoConn->CreateCommand(FdoCommandType_ExtendedSelect);
     else
         m_command = (FdoISelect*)fdoConn->CreateCommand(FdoCommandType_Select);
@@ -219,7 +219,7 @@
     CHECKNULL((FdoISelect*)m_command, L"MgSelectCommand.Execute");
     FdoIExtendedSelect* extSelect = dynamic_cast<FdoIExtendedSelect*>(m_command.p);
-    if (NULL != extSelect)
+    if (m_bUseExtendedSelect && NULL != extSelect)
         FdoPtr<FdoIScrollableFeatureReader> scReader = extSelect->ExecuteScrollable();
         CHECKNULL((FdoIScrollableFeatureReader*)scReader, L"MgSelectCommand.Execute");
Modified: sandbox/adsk/3.1n/Server/src/Services/Feature/SelectCommand.h
--- sandbox/adsk/3.1n/Server/src/Services/Feature/SelectCommand.h	2016-04-15 08:26:53 UTC (rev 8921)
+++ sandbox/adsk/3.1n/Server/src/Services/Feature/SelectCommand.h	2016-04-15 08:56:29 UTC (rev 8922)
@@ -80,6 +80,7 @@
     FdoPtr<FdoFilter> m_filter;
     MgFdoFilterCollection* GetSubFilters();
+    bool m_bUseExtendedSelect;
 #endif
More information about the mapguide-commits mailing list
