[mapguide-commits] r8929 - in branches/3.0/vagrant: centos/x64 centos/x86 scripts ubuntu/x64 ubuntu/x86
svn_mapguide at osgeo.org
Thu Apr 21 05:07:58 PDT 2016
Author: jng
Date: 2016-04-21 05:07:58 -0700 (Thu, 21 Apr 2016)
New Revision: 8929
branches/3.0/vagrant/centos/x64/Vagrantfile
branches/3.0/vagrant/centos/x86/Vagrantfile
branches/3.0/vagrant/scripts/provision_centos.sh
branches/3.0/vagrant/scripts/provision_ubuntu.sh
branches/3.0/vagrant/ubuntu/x64/Vagrantfile
branches/3.0/vagrant/ubuntu/x86/Vagrantfile
3.0 vagrant build environment changes:
- Parameterize MG/FDO unit tests switches
Modified: branches/3.0/vagrant/centos/x64/Vagrantfile
--- branches/3.0/vagrant/centos/x64/Vagrantfile 2016-04-21 05:20:56 UTC (rev 8928)
+++ branches/3.0/vagrant/centos/x64/Vagrantfile 2016-04-21 12:07:58 UTC (rev 8929)
@@ -119,5 +119,5 @@
config.vm.provision "shell",
privileged: false,
path: "provision_centos.sh",
- args: [4, 0, 0, 3, 0, 1, "4.0", "3.0", "amd64", "Final", "centos6"]
+ args: [4, 0, 0, 3, 0, 1, "4.0", "3.0", "amd64", "Final", "centos6", 1, 1]
end
Modified: branches/3.0/vagrant/centos/x86/Vagrantfile
--- branches/3.0/vagrant/centos/x86/Vagrantfile 2016-04-21 05:20:56 UTC (rev 8928)
+++ branches/3.0/vagrant/centos/x86/Vagrantfile 2016-04-21 12:07:58 UTC (rev 8929)
@@ -119,5 +119,5 @@
privileged: false,
- args: [4, 0, 0, 3, 0, 1, "4.0", "3.0", "i386", "Final", "centos6"]
+ args: [4, 0, 0, 3, 0, 1, "4.0", "3.0", "i386", "Final", "centos6", 1, 1]
end
Modified: branches/3.0/vagrant/scripts/provision_centos.sh
--- branches/3.0/vagrant/scripts/provision_centos.sh 2016-04-21 05:20:56 UTC (rev 8928)
+++ branches/3.0/vagrant/scripts/provision_centos.sh 2016-04-21 12:07:58 UTC (rev 8929)
@@ -24,6 +24,8 @@
# $9 - architecture (i386|amd64)
# $10 - release label (eg. Beta1, RC1, Final)
# $11 - distro label (eg. centos6, ubuntu12) - Optional
+# $12 - Run FDO tests (1|0)
+# $13 - Run MapGuide tests (1|0)
PROVISION_START_TIME=`date +%s`
@@ -40,6 +42,8 @@
echo " 9 - ${9}"
echo " 10 - ${10}"
echo " 11 - ${11}"
+echo " 12 - ${12}"
+echo " 13 - ${13}"
echo "*****************************************************"
# FDO version
@@ -62,6 +66,9 @@
MG_DISTRO=${DISTRO}
UBUNTU=0
+TEST_FDO_FLAG=${12}
+TEST_MG_FLAG=${13}
FDO_PLATFORM=
if [ "${MG_ARCH}" = "amd64" ]; then
FDO_PLATFORM=64
@@ -116,6 +123,14 @@
HAVE_MAPGUIDE=0
MG_UNIT_TEST=0
FDO_UNIT_TEST=0
+if [ "${TEST_FDO_FLAG}" = "1" ]; then
+ FDO_UNIT_TEST=1
+fi
+if [ "${TEST_MG_FLAG}" = "1" ]; then
+ MG_UNIT_TEST=1
+fi
MAKE_FDO_SDK=0
SCRIPT_ROOT=~/scripts
FDO_SRC_ROOT=~/fdo/branches
@@ -145,6 +160,8 @@
echo "Build target: ${MG_DISTRO} - ${MG_ARCH}"
echo "Release Label: ${MG_RELEASE_LABEL}"
echo "FDO Distro label: ${FDO_DISTRO}"
+echo "Running FDO Tests: ${FDO_UNIT_TEST}"
+echo "Running MapGuide Tests: ${MG_UNIT_TEST}"
echo "Checking directories"
echo "********************************************************************************"
@@ -244,16 +261,20 @@
sudo rm providers.xml
sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_gdal_unit_test.log
check_test
- BUILD_COMPONENT="Unit Test OGR Provider"
- cd $SCRIPT_ROOT/fdo_build_area/Providers/OGR/Src/UnitTest
- sudo rm providers.xml
- sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_ogr_unit_test.log
- check_test
- BUILD_COMPONENT="Unit Test WMS Provider"
- cd $SCRIPT_ROOT/fdo_build_area/Providers/WMS/Src/UnitTest
- sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_wms_unit_test.log
- check_test
+ # Depending on what version we're building, OGR unit tests may not exist
+ if [ -d "$SCRIPT_ROOT/fdo_build_area/Providers/OGR/Src/UnitTest" ];
+ then
+ BUILD_COMPONENT="Unit Test OGR Provider"
+ cd $SCRIPT_ROOT/fdo_build_area/Providers/OGR/Src/UnitTest
+ sudo rm providers.xml
+ sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_ogr_unit_test.log
+ check_test
+ fi
+ # BUILD_COMPONENT="Unit Test WMS Provider"
+ # cd $SCRIPT_ROOT/fdo_build_area/Providers/WMS/Src/UnitTest
+ # sudo rm providers.xml
+ # sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_wms_unit_test.log
+ # check_test
fi
if [ $MG_UNIT_TEST -eq 1 ];
then
Modified: branches/3.0/vagrant/scripts/provision_ubuntu.sh
--- branches/3.0/vagrant/scripts/provision_ubuntu.sh 2016-04-21 05:20:56 UTC (rev 8928)
+++ branches/3.0/vagrant/scripts/provision_ubuntu.sh 2016-04-21 12:07:58 UTC (rev 8929)
@@ -24,6 +24,8 @@
@@ -40,6 +42,8 @@
echo " 9 - ${9}"
echo " 10 - ${10}"
echo " 11 - ${11}"
+echo " 12 - ${12}"
+echo " 13 - ${13}"
# FDO version
@@ -62,6 +66,9 @@
MG_DISTRO=${DISTRO}
UBUNTU=1
+TEST_MG_FLAG=${13}
FDO_PLATFORM=
FDO_PLATFORM=64
HAVE_MAPGUIDE=0
MG_UNIT_TEST=0
FDO_UNIT_TEST=0
+ FDO_UNIT_TEST=1
+fi
+ MG_UNIT_TEST=1
+fi
MAKE_FDO_SDK=0
@@ -145,6 +160,8 @@
@@ -247,16 +264,20 @@
check_test
- check_test
- check_test
+ then
+ check_test
+ fi
+ # check_test
fi
then
Modified: branches/3.0/vagrant/ubuntu/x64/Vagrantfile
--- branches/3.0/vagrant/ubuntu/x64/Vagrantfile 2016-04-21 05:20:56 UTC (rev 8928)
+++ branches/3.0/vagrant/ubuntu/x64/Vagrantfile 2016-04-21 12:07:58 UTC (rev 8929)
@@ -119,5 +119,5 @@
privileged: false,
path: "provision_ubuntu.sh",
- args: [4, 0, 0, 3, 0, 1, "4.0", "3.0", "amd64", "Final", "ubuntu12"]
+ args: [4, 0, 0, 3, 0, 1, "4.0", "3.0", "amd64", "Final", "ubuntu12", 1, 1]
end
Modified: branches/3.0/vagrant/ubuntu/x86/Vagrantfile
--- branches/3.0/vagrant/ubuntu/x86/Vagrantfile 2016-04-21 05:20:56 UTC (rev 8928)
+++ branches/3.0/vagrant/ubuntu/x86/Vagrantfile 2016-04-21 12:07:58 UTC (rev 8929)
@@ -119,5 +119,5 @@
privileged: false,
- args: [4, 0, 0, 3, 0, 1, "4.0", "3.0", "i386", "Final", "ubuntu12"]
+ args: [4, 0, 0, 3, 0, 1, "4.0", "3.0", "i386", "Final", "ubuntu12", 1, 1]
end
More information about the mapguide-commits
