[mapguide-commits] r8935 - in branches/3.0/vagrant: . scripts
svn_mapguide at osgeo.org
Sat Apr 30 11:03:10 PDT 2016
Author: jng
Date: 2016-04-30 11:03:10 -0700 (Sat, 30 Apr 2016)
New Revision: 8935
branches/3.0/vagrant/
branches/3.0/vagrant/scripts/build.sh
branches/3.0/vagrant/scripts/build_fdo.sh
branches/3.0/vagrant/scripts/provision_centos.sh
branches/3.0/vagrant/scripts/provision_ubuntu.sh
3.0 vagrant build environment changes:
- Use FDO_HOME and MG_HOME instead of hard-coding and assuming the home directory is /home/vagrant. In the provisioning scripts, these vars are set to `pwd` before invoking the build scripts
- Parameterize the vagrant and source directories in provisioning scripts
- Wrap all server tests using the timeout utility, guaranteeing us an upper bound on test execution (any process exceeding the alotted execution time is killed by the utility). This allows us to safely re-enable the tile/resource service tests for mgserver without fear of hung execution (which these tests have a propensity of exhibiting)
- Similarly, add a check function specific for server tests that will properly check for the return code of the original mgserver test invocation. This return code was swallowed up by tee piping the stdout output. The $PIPESTATUS variable contains the original return code. If we determine it is because the timeout utility killed the process (=124), we can output the appropriate warning.
Property changes on: branches/3.0/vagrant
___________________________________________________________________
Modified: svn:ignore
- builds
+ builds
.vscode
Added: svn:mergeinfo
+ /trunk/Tools/Vagrant:8932
Modified: branches/3.0/vagrant/scripts/build.sh
--- branches/3.0/vagrant/scripts/build.sh 2016-04-30 18:01:24 UTC (rev 8934)
+++ branches/3.0/vagrant/scripts/build.sh 2016-04-30 18:03:10 UTC (rev 8935)
@@ -29,7 +29,11 @@
# Use LOCALSVN=1 if you want to build from an existing copy instead of building
# from an export (saves bandwidth and faster)
LOCALSVN=1
-SVNROOT=/home/vagrant
+SVNROOT=$HOME
+if [ "$MG_HOME" != "" ]; then
+ SVNROOT=$MG_HOME
+fi
#SVNROOT="svn://svn.bld.mgproto.net"
#SVNROOT="http://svn.osgeo.org"
SVNRELPATH=/mapguide/branches/${MG_VER_MAJOR}.${MG_VER_MINOR}/MgDev
Modified: branches/3.0/vagrant/scripts/build_fdo.sh
--- branches/3.0/vagrant/scripts/build_fdo.sh 2016-04-30 18:01:24 UTC (rev 8934)
+++ branches/3.0/vagrant/scripts/build_fdo.sh 2016-04-30 18:03:10 UTC (rev 8935)
@@ -132,7 +132,11 @@
PRESERVE_BUILD_ROOT=1
CMAKE=0
-MY_HOME_DIR=/home/vagrant
+MY_HOME_DIR=$HOME
+if [ "$FDO_HOME" != "" ]; then
+ MY_HOME_DIR=$FDO_HOME
+fi
FDO_SRC=${MY_HOME_DIR}/fdo/branches/${FDO_VER_MAJOR}.${FDO_VER_MINOR}
if [ "${FDO_BRANCH}" = "trunk" ]; then
FDO_SRC=${MY_HOME_DIR}/fdo/trunk
Modified: branches/3.0/vagrant/scripts/provision_centos.sh
--- branches/3.0/vagrant/scripts/provision_centos.sh 2016-04-30 18:01:24 UTC (rev 8934)
+++ branches/3.0/vagrant/scripts/provision_centos.sh 2016-04-30 18:03:10 UTC (rev 8935)
@@ -26,6 +26,8 @@
# $11 - distro label (eg. centos6, ubuntu12) - Optional
# $12 - Run FDO tests (1|0)
# $13 - Run MapGuide tests (1|0)
+# $14 - Vagrant folder [default: /vagrant]
+# $15 - Source folder [default: /mapguide_sources]
PROVISION_START_TIME=`date +%s`
@@ -44,6 +46,8 @@
echo " 11 - ${11}"
echo " 12 - ${12}"
echo " 13 - ${13}"
+echo " 14 - ${14:-/vagrant}"
+echo " 15 - ${15:-/mapguide_sources}"
echo "*****************************************************"
# FDO version
@@ -69,6 +73,12 @@
TEST_FDO_FLAG=${12}
TEST_MG_FLAG=${13}
+MOUNT_DIR=${14:-/vagrant}
+SOURCES_DIR=${15:-/mapguide_sources}
+MG_HOME=`pwd`
+FDO_HOME=`pwd`
FDO_PLATFORM=
if [ "${MG_ARCH}" = "amd64" ]; then
FDO_PLATFORM=64
@@ -92,6 +102,8 @@
export UBUNTU
export FDO_DISTRO
export MG_DISTRO
+export FDO_HOME
+export MG_HOME
BUILD_COMPONENT=
check_build()
@@ -102,22 +114,36 @@
exit $error
fi
-check_test()
+check_webtier_test()
error=$?
if [ $error -ne 0 ]; then
echo "[warning]: ${BUILD_COMPONENT} - Unit Tests failed ($error)"
- echo "[warning]: ${BUILD_COMPONENT} - Unit Tests failed ($error)" >> ~/unit_test_status.log
+ echo "[warning]: ${BUILD_COMPONENT} - Unit Tests failed ($error)" >> $MG_HOME/unit_test_status.log
fi
+check_server_test()
+ # As this will be called after a test command that is piped to tee, we need to read from $PIPESTATUS
+ error=$PIPESTATUS
+ if [ $error -ne 0 ]; then
+ if [ $error -eq 124 ]; then # Test timed out
+ echo "[warning]: ${BUILD_COMPONENT} - Unit tests failed to complete within the alotted time period. Test logs/results may or may not have been saved"
+ echo "[warning]: ${BUILD_COMPONENT} - Unit tests failed to complete within the alotted time period. Test logs/results may or may not have been saved" >> $MG_HOME/unit_test_status.log
+ else
+ fi
+ fi
if hash scons 2>/dev/null; then
echo [provision]: We have scons
else
echo [provision]: We do not have scons. Installing it
- sudo rpm -Uvh /mapguide_sources/scons-2.3.0-1.noarch.rpm
+ sudo rpm -Uvh $SOURCES_DIR/scons-2.3.0-1.noarch.rpm
check_build
fi
-cd ~
+cd $MG_HOME
HAVE_FDO=0
HAVE_FDO_LIBS=0
HAVE_MAPGUIDE=0
@@ -132,18 +158,18 @@
fi
MAKE_FDO_SDK=0
-SCRIPT_ROOT=~/scripts
-FDO_SRC_ROOT=~/fdo/branches
+SCRIPT_ROOT=$MG_HOME/scripts
+FDO_SRC_ROOT=$MG_HOME/fdo/branches
FDO_SRC_DIR=${FDO_BRANCH}
FDO_SRC=$FDO_SRC_ROOT/$FDO_SRC_DIR
- FDO_SRC_ROOT=~/fdo
+ FDO_SRC_ROOT=$MG_HOME/fdo
fi
-FDO_LIB_SRC=~/fdo_rdbms_thirdparty
-MG_SRC_ROOT=~/mapguide/branches/${MG_BRANCH}
+FDO_LIB_SRC=$MG_HOME/fdo_rdbms_thirdparty
+MG_SRC_ROOT=$MG_HOME/mapguide/branches/${MG_BRANCH}
if [ "${MG_BRANCH}" = "trunk" ]; then
- MG_SRC_ROOT=~/mapguide/trunk
+ MG_SRC_ROOT=$MG_HOME/mapguide/trunk
fi
MG_SRC=$MG_SRC_ROOT/MgDev
FDO_TARBALL=fdo-checkout-${FDO_BRANCH}.tar.gz
@@ -183,155 +209,166 @@
else
echo [provision]: Copy atomic.h
sudo mkdir -p /usr/include/asm
- sudo cp /mapguide_sources/atomic.h /usr/include/asm
+ sudo cp $SOURCES_DIR/atomic.h /usr/include/asm
fi
echo [provision]: Clean line endings
-sudo dos2unix /vagrant/*.sh
-sudo dos2unix /vagrant/*.pl
-sudo dos2unix /vagrant/*.txt
+sudo dos2unix $MOUNT_DIR/*.sh
+sudo dos2unix $MOUNT_DIR/*.pl
+sudo dos2unix $MOUNT_DIR/*.txt
echo [provision]: Copying shell scripts
mkdir -p $SCRIPT_ROOT
-cp -f /vagrant/*.sh $SCRIPT_ROOT
-cp -f /vagrant/*.pl $SCRIPT_ROOT
-cp -f /vagrant/*.txt $SCRIPT_ROOT
+cp -f $MOUNT_DIR/*.sh $SCRIPT_ROOT
+cp -f $MOUNT_DIR/*.pl $SCRIPT_ROOT
+cp -f $MOUNT_DIR/*.txt $SCRIPT_ROOT
cd $SCRIPT_ROOT
if [ $HAVE_FDO_LIBS -eq 0 ];
then
echo [provision]: Extracting FDO thirdparty libs
- tar -zxf /mapguide_sources/fdo_rdbms_thirdparty.tar.gz -C ~
+ tar -zxf $SOURCES_DIR/fdo_rdbms_thirdparty.tar.gz -C $MG_HOME
fi
if [ $HAVE_FDO -eq 0 ];
then
echo [provision]: Extracting FDO working copy
mkdir -p $FDO_SRC_ROOT
- tar -zxf /mapguide_sources/$FDO_TARBALL -C $FDO_SRC_ROOT
+ tar -zxf $SOURCES_DIR/$FDO_TARBALL -C $FDO_SRC_ROOT
fi
if [ $HAVE_MAPGUIDE -eq 0 ];
then
echo [provision]: Extracting MapGuide working copy
mkdir -p $MG_SRC_ROOT
- tar -zxf /mapguide_sources/$MG_TARBALL -C $MG_SRC_ROOT
+ tar -zxf $SOURCES_DIR/$MG_TARBALL -C $MG_SRC_ROOT
fi
-if [ -d /mapguide_sources/patches/fdo ];
+if [ -d $SOURCES_DIR/patches/fdo ];
then
echo [provision]: Applying FDO source patches
- cp -R /mapguide_sources/patches/fdo/* $FDO_SRC
+ cp -R $SOURCES_DIR/patches/fdo/* $FDO_SRC
fi
-if [ -d /mapguide_sources/patches/mapguide ];
+if [ -d $SOURCES_DIR/patches/mapguide ];
then
echo [provision]: Applying MapGuide source patches
- cp -R /mapguide_sources/patches/mapguide/* $MG_SRC
+ cp -R $SOURCES_DIR/patches/mapguide/* $MG_SRC
fi
echo [provision]: Making sure swig is executable
chmod +x $MG_SRC/Oem/SWIGEx/Linux/swig
-cd ~/scripts
+cd $MG_HOME/scripts
BUILD_COMPONENT="FDO"
-sudo -E ./build_fdo.sh 2>&1 | tee ~/fdo_build.log
+sudo -E ./build_fdo.sh 2>&1 | tee $MG_HOME/fdo_build.log
check_build
BUILD_COMPONENT="MapGuide"
-sudo -E ./build.sh 2>&1 | tee ~/mapguide_build.log
+sudo -E ./build.sh 2>&1 | tee $MG_HOME/mapguide_build.log
check_build
FDO_REV=`svn info $FDO_SRC | perl revnum.pl`
MG_REV=`svn info $MG_SRC | perl revnum.pl`
-> ~/unit_test_status.log
+> $MG_HOME/unit_test_status.log
if [ $FDO_UNIT_TEST -eq 1 ];
then
echo [provision]: Unit test FDO
BUILD_COMPONENT="Unit Test FDO Core"
cd $SCRIPT_ROOT/fdo_build_area/Fdo/UnitTest
- sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_core_unit_test.log
- check_test
+ sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee $MG_HOME/fdo_core_unit_test.log
+ check_test_generic
BUILD_COMPONENT="Unit Test SHP Provider"
cd $SCRIPT_ROOT/fdo_build_area/Providers/SHP/Src/UnitTest
sudo rm providers.xml
- sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_shp_unit_test.log
- check_test
+ sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee $MG_HOME/fdo_shp_unit_test.log
BUILD_COMPONENT="Unit Test SDF Provider"
cd $SCRIPT_ROOT/fdo_build_area/Providers/SDF/Src/UnitTest
- sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_sdf_unit_test.log
- check_test
+ sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee $MG_HOME/fdo_sdf_unit_test.log
BUILD_COMPONENT="Unit Test SQLite Provider"
cd $SCRIPT_ROOT/fdo_build_area/Providers/SQLite/Src/UnitTest
- sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_sqlite_unit_test.log
- check_test
+ sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee $MG_HOME/fdo_sqlite_unit_test.log
BUILD_COMPONENT="Unit Test GDAL Provider"
cd $SCRIPT_ROOT/fdo_build_area/Providers/GDAL/Src/UnitTest
- sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_gdal_unit_test.log
- check_test
+ sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee $MG_HOME/fdo_gdal_unit_test.log
# Depending on what version we're building, OGR unit tests may not exist
if [ -d "$SCRIPT_ROOT/fdo_build_area/Providers/OGR/Src/UnitTest" ];
then
BUILD_COMPONENT="Unit Test OGR Provider"
cd $SCRIPT_ROOT/fdo_build_area/Providers/OGR/Src/UnitTest
- sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_ogr_unit_test.log
- check_test
+ sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee $MG_HOME/fdo_ogr_unit_test.log
fi
# BUILD_COMPONENT="Unit Test WMS Provider"
# cd $SCRIPT_ROOT/fdo_build_area/Providers/WMS/Src/UnitTest
# sudo rm providers.xml
- # sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_wms_unit_test.log
- # check_test
+ # sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee $MG_HOME/fdo_wms_unit_test.log
+ # check_test_generic
fi
if [ $MG_UNIT_TEST -eq 1 ];
then
echo [provision]: Unit test MapGuide
BUILD_COMPONENT="Unit Test MapGuide Server"
- # HACK: Tile and Resource Service tests are known to freeze our VMs when driven by vagrant (why? who knows?
- # All we know is that those tests involve threads)
- # So test everything *but* the above services. If required, this can be tested under a manually controlled
- # VM
+ # HACK: Due to unforeseen threading issues or gremlins, none of the server unit tests here
+ # are guaranteed to complete and have a possibility of hanging
# build the individual targets that would comprise "make check" sans execution of unittest.sh
cd $SCRIPT_ROOT/mgdev/Server/src/UnitTesting
sudo make libMgUnitTesting.la
cd $SCRIPT_ROOT/mgdev/Server/src/Core
sudo make unittest.sh
- # Run the test suites individually except for TileService/ResourceService for reasons already stated
- for comp in CoordinateSystem FeatureService Geometry KmlService LogManager MappingService MdfModel Misc Performance RenderingService ServerAdminService ServerManager ServiceManager SiteManager SiteService ProfilingService TransformMesh
+ # As CoordinateSystem will run longer than the others, run this separately with its own timeout
+ for comp in CoordinateSystem
do
- sudo -E ./mgserver test $comp UnitTestResults_${comp}.xml 2>&1 | tee ~/mapguide_${comp}_unit_test.log
- check_test
+ BUILD_COMPONENT="Unit Test MapGuide Server ($comp)"
+ sudo -E timeout 20m ./mgserver test $comp UnitTestResults_${comp}.xml 2>&1 | tee $MG_HOME/mapguide_${comp}_unit_test.log
+ check_server_test
if [ -f UnitTestResults_${comp}.xml ]; then
- sudo mv UnitTestResults_${comp}.xml ~/UnitTestResults_${comp}.xml
+ sudo mv UnitTestResults_${comp}.xml $MG_HOME/UnitTestResults_${comp}.xml
fi
done
+ # Run the rest
+ for comp in CoordinateSystem FeatureService Geometry KmlService LogManager MappingService TileService ResourceService MdfModel Misc Performance RenderingService ServerAdminService ServerManager ServiceManager SiteManager SiteService ProfilingService TransformMesh
+ do
+ sudo -E timeout 5m ./mgserver test $comp UnitTestResults_${comp}.xml 2>&1 | tee $MG_HOME/mapguide_${comp}_unit_test.log
+ check_server_test
+ if [ -f UnitTestResults_${comp}.xml ]; then
+ fi
+ done
- sudo -E ./run_tests.sh --prefix ${MG_INST_PATH} --with-php --with-java --logpath ~
+ BUILD_COMPONENT="Unit Test MapGuide Web Tier ($comp)"
+ sudo -E ./run_tests.sh --prefix ${MG_INST_PATH} --with-php --with-java --logpath $MG_HOME
fi
cd $SCRIPT_ROOT
echo [provision]: Make output dir
-sudo mkdir -p /vagrant/build
+sudo mkdir -p $MOUNT_DIR/build
echo [provision]: Copy log files to output dir
-sudo mv -f ~/*.log /vagrant/build
+sudo mv -f $MG_HOME/*.log $MOUNT_DIR/build
echo [provision]: Copy tarballs to output dir
-sudo cp bin/*.tar.xz /vagrant/build
-sudo cp fdosdk-${FDO_DISTRO}-${MG_ARCH}-${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}_${FDO_REV}.tar.xz /vagrant/build
+sudo cp bin/*.tar.xz $MOUNT_DIR/build
+sudo cp fdosdk-${FDO_DISTRO}-${MG_ARCH}-${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}_${FDO_REV}.tar.xz $MOUNT_DIR/build
if [ $MAKE_FDO_SDK -eq 1 ]; then
echo [provision]: Copy FDO SDK for Ubuntu builds
# Copy SDK also to sources, so Ubuntu can pick it up
- sudo rm -f /mapguide_sources/fdosdk*.tar.xz
- sudo cp fdosdk-${FDO_DISTRO}-${MG_ARCH}-${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}_${FDO_REV}.tar.xz /mapguide_sources
+ sudo rm -f $SOURCES_DIR/fdosdk*.tar.xz
+ sudo cp fdosdk-${FDO_DISTRO}-${MG_ARCH}-${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}_${FDO_REV}.tar.xz $SOURCES_DIR
# Record file name so Ubuntu knows what tarball to extract from
- sudo echo fdosdk-${FDO_DISTRO}-${MG_ARCH}-${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}_${FDO_REV}.tar.xz > /mapguide_sources/fdosdk_filename
- sudo echo ${FDO_REV} > /mapguide_sources/fdosdk_rev
+ sudo echo fdosdk-${FDO_DISTRO}-${MG_ARCH}-${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}_${FDO_REV}.tar.xz > $SOURCES_DIR/fdosdk_filename
+ sudo echo ${FDO_REV} > $SOURCES_DIR/fdosdk_rev
# Export filelist to Ubuntu can deb package this SDK if needed
- sudo cp -R $SCRIPT_ROOT/fdo_build_area/install/filelist /mapguide_sources
+ sudo cp -R $SCRIPT_ROOT/fdo_build_area/install/filelist $SOURCES_DIR
fi
echo [provision]: Copy unit test logs to output dir
-if [ -f "~/unit_test_status.log" ]; then
- sudo mv ~/unit_test_status.log /vagrant/build/unit_test_status.log
+if [ -f "$MG_HOME/unit_test_status.log" ]; then
+ sudo mv $MG_HOME/unit_test_status.log $MOUNT_DIR/build/unit_test_status.log
fi
-if ls ~/fdo_*_unit_test.log 1> /dev/null 2>&1; then
- sudo mv ~/fdo_*_unit_test.log /vagrant/build
+if ls $MG_HOME/fdo_*_unit_test.log 1> /dev/null 2>&1; then
+ sudo mv $MG_HOME/fdo_*_unit_test.log $MOUNT_DIR/build
else
echo [provision]: No FDO unit test result files found. If FDO_UNIT_TEST is 0 [value is ${FDO_UNIT_TEST}], this can be safely ignored
fi
-if ls ~/UnitTestResults_*.xml 1> /dev/null 2>&1; then
- sudo mv ~/UnitTestResults_*.xml /vagrant/build
+if ls $MG_HOME/UnitTestResults_*.xml 1> /dev/null 2>&1; then
+ sudo mv $MG_HOME/UnitTestResults_*.xml $MOUNT_DIR/build
else
echo [provision]: No MapGuide unit test result files found. If MG_UNIT_TEST is 0 [value is ${MG_UNIT_TEST}], this can be safely ignored
fi
@@ -342,27 +379,27 @@
fi
echo [provision]: Stamping install script
-sudo cp /vagrant/mginstallcentos.sh /vagrant/build/mginstallcentos.sh
-sudo cp /vagrant/mguninstallcentos.sh /vagrant/build/mguninstallcentos.sh
-sudo sed -i 's/URL_PART="centos"/URL_PART='"$DISTNAME"'/g' /vagrant/build/mginstallcentos.sh
-sudo sed -i 's/MGRELEASELABEL="ReleaseLabel"/MGRELEASELABEL='"$MG_RELEASE_LABEL"'/g' /vagrant/build/mginstallcentos.sh
-sudo sed -i 's/FDO_ARCH=i386/FDO_ARCH='"$MG_ARCH"'/g' /vagrant/build/mginstallcentos.sh
-sudo sed -i 's/MG_ARCH=i386/MG_ARCH='"$MG_ARCH"'/g' /vagrant/build/mginstallcentos.sh
-sudo sed -i 's/FDOVER_REV=0/FDOVER_REV='"$FDO_REV"'/g' /vagrant/build/mginstallcentos.sh
-sudo sed -i 's/MGVER_REV=0/MGVER_REV='"$MG_REV"'/g' /vagrant/build/mginstallcentos.sh
-sudo sed -i 's/FDOVER_MAJOR=0/FDOVER_MAJOR='"$FDO_VER_MAJOR"'/g' /vagrant/build/mginstallcentos.sh
-sudo sed -i 's/FDOVER_MINOR=0/FDOVER_MINOR='"$FDO_VER_MINOR"'/g' /vagrant/build/mginstallcentos.sh
-sudo sed -i 's/FDOVER_POINT=0/FDOVER_POINT='"$FDO_VER_REV"'/g' /vagrant/build/mginstallcentos.sh
-sudo sed -i 's/MGVER_MAJOR=0/MGVER_MAJOR='"$MG_VER_MAJOR"'/g' /vagrant/build/mginstallcentos.sh
-sudo sed -i 's/MGVER_MINOR=0/MGVER_MINOR='"$MG_VER_MINOR"'/g' /vagrant/build/mginstallcentos.sh
-sudo sed -i 's/MGVER_POINT=0/MGVER_POINT='"$MG_VER_REV"'/g' /vagrant/build/mginstallcentos.sh
+sudo cp $MOUNT_DIR/mginstallcentos.sh $MOUNT_DIR/build/mginstallcentos.sh
+sudo cp $MOUNT_DIR/mguninstallcentos.sh $MOUNT_DIR/build/mguninstallcentos.sh
+sudo sed -i 's/URL_PART="centos"/URL_PART='"$DISTNAME"'/g' $MOUNT_DIR/build/mginstallcentos.sh
+sudo sed -i 's/MGRELEASELABEL="ReleaseLabel"/MGRELEASELABEL='"$MG_RELEASE_LABEL"'/g' $MOUNT_DIR/build/mginstallcentos.sh
+sudo sed -i 's/FDO_ARCH=i386/FDO_ARCH='"$MG_ARCH"'/g' $MOUNT_DIR/build/mginstallcentos.sh
+sudo sed -i 's/MG_ARCH=i386/MG_ARCH='"$MG_ARCH"'/g' $MOUNT_DIR/build/mginstallcentos.sh
+sudo sed -i 's/FDOVER_REV=0/FDOVER_REV='"$FDO_REV"'/g' $MOUNT_DIR/build/mginstallcentos.sh
+sudo sed -i 's/MGVER_REV=0/MGVER_REV='"$MG_REV"'/g' $MOUNT_DIR/build/mginstallcentos.sh
+sudo sed -i 's/FDOVER_MAJOR=0/FDOVER_MAJOR='"$FDO_VER_MAJOR"'/g' $MOUNT_DIR/build/mginstallcentos.sh
+sudo sed -i 's/FDOVER_MINOR=0/FDOVER_MINOR='"$FDO_VER_MINOR"'/g' $MOUNT_DIR/build/mginstallcentos.sh
+sudo sed -i 's/FDOVER_POINT=0/FDOVER_POINT='"$FDO_VER_REV"'/g' $MOUNT_DIR/build/mginstallcentos.sh
+sudo sed -i 's/MGVER_MAJOR=0/MGVER_MAJOR='"$MG_VER_MAJOR"'/g' $MOUNT_DIR/build/mginstallcentos.sh
+sudo sed -i 's/MGVER_MINOR=0/MGVER_MINOR='"$MG_VER_MINOR"'/g' $MOUNT_DIR/build/mginstallcentos.sh
+sudo sed -i 's/MGVER_POINT=0/MGVER_POINT='"$MG_VER_REV"'/g' $MOUNT_DIR/build/mginstallcentos.sh
echo [provision]: Stamping variables to uninstall script
-sudo sed -i 's/FDOVER_MAJOR=0/FDOVER_MAJOR='"$FDO_VER_MAJOR"'/g' /vagrant/build/mguninstallcentos.sh
-sudo sed -i 's/FDOVER_MINOR=0/FDOVER_MINOR='"$FDO_VER_MINOR"'/g' /vagrant/build/mguninstallcentos.sh
-sudo sed -i 's/FDOVER_POINT=0/FDOVER_POINT='"$FDO_VER_REV"'/g' /vagrant/build/mguninstallcentos.sh
-sudo sed -i 's/MGVER_MAJOR=0/MGVER_MAJOR='"$MG_VER_MAJOR"'/g' /vagrant/build/mguninstallcentos.sh
-sudo sed -i 's/MGVER_MINOR=0/MGVER_MINOR='"$MG_VER_MINOR"'/g' /vagrant/build/mguninstallcentos.sh
-sudo sed -i 's/MGVER_POINT=0/MGVER_POINT='"$MG_VER_REV"'/g' /vagrant/build/mguninstallcentos.sh
+sudo sed -i 's/FDOVER_MAJOR=0/FDOVER_MAJOR='"$FDO_VER_MAJOR"'/g' $MOUNT_DIR/build/mguninstallcentos.sh
+sudo sed -i 's/FDOVER_MINOR=0/FDOVER_MINOR='"$FDO_VER_MINOR"'/g' $MOUNT_DIR/build/mguninstallcentos.sh
+sudo sed -i 's/FDOVER_POINT=0/FDOVER_POINT='"$FDO_VER_REV"'/g' $MOUNT_DIR/build/mguninstallcentos.sh
+sudo sed -i 's/MGVER_MAJOR=0/MGVER_MAJOR='"$MG_VER_MAJOR"'/g' $MOUNT_DIR/build/mguninstallcentos.sh
+sudo sed -i 's/MGVER_MINOR=0/MGVER_MINOR='"$MG_VER_MINOR"'/g' $MOUNT_DIR/build/mguninstallcentos.sh
+sudo sed -i 's/MGVER_POINT=0/MGVER_POINT='"$MG_VER_REV"'/g' $MOUNT_DIR/build/mguninstallcentos.sh
PROVISION_END_TIME=`date +%s`
echo [provision]: Build complete
echo [provision]: Overall build duration: `expr $PROVISION_END_TIME - $PROVISION_START_TIME` s
\ No newline at end of file
Modified: branches/3.0/vagrant/scripts/provision_ubuntu.sh
--- branches/3.0/vagrant/scripts/provision_ubuntu.sh 2016-04-30 18:01:24 UTC (rev 8934)
+++ branches/3.0/vagrant/scripts/provision_ubuntu.sh 2016-04-30 18:03:10 UTC (rev 8935)
@@ -6,7 +6,7 @@
# Expected environment (set up by vagrant)
-# - Calling vagrantfile is for a Ubuntu 12.04.x LTS box
+# - Calling vagrantfile is for a Ubuntu >= 12.04 box
# - Vagrant folder (path of the Vagrantfile) mounted as: /vagrant
# - Source folder mounted as: /mapguide_sources
# - Contains tarballs for MapGuide/FDO
@@ -26,6 +26,8 @@
@@ -44,6 +46,8 @@
echo " 11 - ${11}"
echo " 12 - ${12}"
echo " 13 - ${13}"
# FDO version
@@ -69,6 +73,12 @@
TEST_FDO_FLAG=${12}
TEST_MG_FLAG=${13}
+MG_HOME=`pwd`
+FDO_HOME=`pwd`
FDO_PLATFORM=
FDO_PLATFORM=64
@@ -92,6 +102,8 @@
export UBUNTU
export FDO_DISTRO
export MG_DISTRO
+export FDO_HOME
+export MG_HOME
BUILD_COMPONENT=
check_build()
exit $error
fi
-check_test()
+check_test_generic()
error=$?
fi
+ error=$PIPESTATUS
+ else
+ fi
+ fi
else
check_build
fi
-cd ~
+cd $MG_HOME
HAVE_FDO=0
HAVE_FDO_LIBS=0
HAVE_MAPGUIDE=0
fi
MAKE_FDO_SDK=0
fi
fi
@@ -183,162 +209,180 @@
else
fi
cd $SCRIPT_ROOT
then
fi
then
fi
then
fi
then
fi
then
fi
+# If Ubuntu > 12, we need to svn upgrade our working copies first
+UBUNTU_MAJOR_VERSION=`lsb_release -r | awk '{print $2}' | sed 's/\./ /g' | awk '{print $1}'`
+if [ $UBUNTU_MAJOR_VERSION -gt 12 ]; then
+ echo [provison]: We are on Ubuntu >= 12 [`lsb_release -r`]
+ svn upgrade $FDO_SRC
+ svn upgrade $MG_SRC
+fi
-cd ~/scripts
check_build
check_build
BUILD_COMPONENT="MapGuide deb packages"
-./dpkgmapguide.sh $MG_ARCH $MG_REV 2>&1 | tee ~/dpkg_mapguide.log
+./dpkgmapguide.sh $MG_ARCH $MG_REV 2>&1 | tee $MG_HOME/dpkg_mapguide.log
check_build
then
- check_test
- check_test
- check_test
- check_test
- check_test
then
- check_test
fi
- # check_test
fi
then
- # VM
do
- check_test
+ check_server_test
fi
done
+ # Run the rest
+ do
+ check_server_test
+ fi
+ done
fi
cd $SCRIPT_ROOT
fi
echo [provision]: Copy FDO deb packages
-sudo cp fdo_build_area/install/bin/*.deb /vagrant/build
+sudo cp fdo_build_area/install/bin/*.deb $MOUNT_DIR/build
echo [provision]: Copy MapGuide deb packages
-sudo cp bin/*.deb /vagrant/build
+sudo cp bin/*.deb $MOUNT_DIR/build
fi
else
fi
else
fi
@@ -347,21 +391,22 @@
DISTNAME=${MG_DISTRO}_x64
fi
-sudo cp /vagrant/mginstallubuntu.sh /vagrant/build/mginstallubuntu.sh
-sudo cp /vagrant/mguninstallubuntu.sh /vagrant/build/mguninstallubuntu.sh
-sudo sed -i 's/URL_PART="ubuntu12"/URL_PART='"$DISTNAME"'/g' /vagrant/build/mginstallubuntu.sh
-sudo sed -i 's/MGRELEASELABEL="ReleaseLabel"/MGRELEASELABEL='"$MG_RELEASE_LABEL"'/g' /vagrant/build/mginstallubuntu.sh
-sudo sed -i 's/FDOARCH=i386/FDOARCH='"$MG_ARCH"'/g' /vagrant/build/mginstallubuntu.sh
-sudo sed -i 's/MGARCH=i386/MGARCH='"$MG_ARCH"'/g' /vagrant/build/mginstallubuntu.sh
-sudo sed -i 's/FDOBUILD=0/FDOBUILD='"$FDO_REV"'/g' /vagrant/build/mginstallubuntu.sh
-sudo sed -i 's/MGBUILD=0/MGBUILD='"$MG_REV"'/g' /vagrant/build/mginstallubuntu.sh
-sudo sed -i 's/FDOVER_MAJOR=0/FDOVER_MAJOR='"$FDO_VER_MAJOR"'/g' /vagrant/build/mginstallubuntu.sh
-sudo sed -i 's/FDOVER_MINOR=0/FDOVER_MINOR='"$FDO_VER_MINOR"'/g' /vagrant/build/mginstallubuntu.sh
-sudo sed -i 's/FDOVER_POINT=0/FDOVER_POINT='"$FDO_VER_REV"'/g' /vagrant/build/mginstallubuntu.sh
-sudo sed -i 's/MGVER_MAJOR=0/MGVER_MAJOR='"$MG_VER_MAJOR"'/g' /vagrant/build/mginstallubuntu.sh
-sudo sed -i 's/MGVER_MINOR=0/MGVER_MINOR='"$MG_VER_MINOR"'/g' /vagrant/build/mginstallubuntu.sh
-sudo sed -i 's/MGVER_POINT=0/MGVER_POINT='"$MG_VER_REV"'/g' /vagrant/build/mginstallubuntu.sh
+sudo cp $MOUNT_DIR/mginstallubuntu.sh $MOUNT_DIR/build/mginstallubuntu.sh
+sudo cp $MOUNT_DIR/mguninstallubuntu.sh $MOUNT_DIR/build/mguninstallubuntu.sh
+sudo sed -i 's/URL_PART="ubuntu12"/URL_PART='"$DISTNAME"'/g' $MOUNT_DIR/build/mginstallubuntu.sh
+sudo sed -i 's/MGRELEASELABEL="ReleaseLabel"/MGRELEASELABEL='"$MG_RELEASE_LABEL"'/g' $MOUNT_DIR/build/mginstallubuntu.sh
+sudo sed -i 's/FDOARCH=i386/FDOARCH='"$MG_ARCH"'/g' $MOUNT_DIR/build/mginstallubuntu.sh
+sudo sed -i 's/MGARCH=i386/MGARCH='"$MG_ARCH"'/g' $MOUNT_DIR/build/mginstallubuntu.sh
+sudo sed -i 's/FDOBUILD=0/FDOBUILD='"$FDO_REV"'/g' $MOUNT_DIR/build/mginstallubuntu.sh
+sudo sed -i 's/MGBUILD=0/MGBUILD='"$MG_REV"'/g' $MOUNT_DIR/build/mginstallubuntu.sh
+sudo sed -i 's/FDOVER_MAJOR=0/FDOVER_MAJOR='"$FDO_VER_MAJOR"'/g' $MOUNT_DIR/build/mginstallubuntu.sh
+sudo sed -i 's/FDOVER_MINOR=0/FDOVER_MINOR='"$FDO_VER_MINOR"'/g' $MOUNT_DIR/build/mginstallubuntu.sh
+sudo sed -i 's/FDOVER_POINT=0/FDOVER_POINT='"$FDO_VER_REV"'/g' $MOUNT_DIR/build/mginstallubuntu.sh
+sudo sed -i 's/MGVER_MAJOR=0/MGVER_MAJOR='"$MG_VER_MAJOR"'/g' $MOUNT_DIR/build/mginstallubuntu.sh
+sudo sed -i 's/MGVER_MINOR=0/MGVER_MINOR='"$MG_VER_MINOR"'/g' $MOUNT_DIR/build/mginstallubuntu.sh
+sudo sed -i 's/MGVER_POINT=0/MGVER_POINT='"$MG_VER_REV"'/g' $MOUNT_DIR/build/mginstallubuntu.sh
More information about the mapguide-commits
