[mapguide-commits] r9100 - sandbox/jng/diet_v2/MgDev_Slim
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Nov 24 04:33:01 PST 2016
Author: jng
Date: 2016-11-24 04:33:01 -0800 (Thu, 24 Nov 2016)
New Revision: 9100
Added:
   sandbox/jng/diet_v2/MgDev_Slim/prebuild.sh
Bring across prebuild.sh from the old diet branch and svn link in configure.in
Property changes on: sandbox/jng/diet_v2/MgDev_Slim
___________________________________________________________________
Modified: svn:externals
   - ../Installer Installer
/mapguide/trunk/Tools/MgInstantSetup InstantSetup
../MgDev/BuildTools BuildTools
../MgDev/Server Server
../MgDev/Web Web
../MgDev/Common Common
../MgDev/Desktop Desktop
../MgDev/Doc Doc
../MgDev/UnitTest UnitTest
../MgDev/nuget nuget
../MgDev/base_package_excludes.txt base_package_excludes.txt
../MgDev/csmap_excludes.txt csmap_excludes.txt
../MgDev/debug_excludes.txt debug_excludes.txt
../MgDev/debug64_excludes.txt debug64_excludes.txt
../MgDev/desktop_package_excludes.txt desktop_package_excludes.txt
../MgDev/dll_excludes.txt dll_excludes.txt
../MgDev/dotnet_excludes.txt dotnet_excludes.txt
../MgDev/dotnetapi_excludes.txt dotnetapi_excludes.txt
../MgDev/dotnetxml_excludes.txt dotnetxml_excludes.txt
../MgDev/java_excludes.txt java_excludes.txt
../MgDev/mapagent_excludes.txt mapagent_excludes.txt
../MgDev/package_excludes.txt package_excludes.txt
../MgDev/php_excludes.txt php_excludes.txt
../MgDev/release_excludes.txt release_excludes.txt
../MgDev/release64_excludes.txt release64_excludes.txt
../MgDev/svn_excludes.txt svn_excludes.txt
../MgDev/viewer_package_excludes.txt viewer_package_excludes.txt
../MgDev/build.bat build.bat
../MgDev/build_desktop.bat build_desktop.bat
../MgDev/nuget_pack.bat nuget_pack.bat
../MgDev/nuget_prepare.bat nuget_prepare.bat
../MgDev/prepare_webtier_components.bat prepare_webtier_components.bat
../MgDev/run_tests.bat run_tests.bat
../MgDev/setenvironment.bat setenvironment.bat
../MgDev/setenvironment64.bat setenvironment64.bat
../MgDev/stampassemblies.bat stampassemblies.bat
../MgDev/updateversion.vbs updateversion.vbs
   + ../Installer Installer
../MgDev/Web Web
../MgDev/Doc Doc
../MgDev/configure.in configure.in
Added: sandbox/jng/diet_v2/MgDev_Slim/prebuild.sh
--- sandbox/jng/diet_v2/MgDev_Slim/prebuild.sh	                        (rev 0)
+++ sandbox/jng/diet_v2/MgDev_Slim/prebuild.sh	2016-11-24 12:33:01 UTC (rev 9100)
@@ -0,0 +1,152 @@
+#! /bin/bash
+# MapGuide Open Source build script.
+# Initialization
+echo "MapGuide Open Source build script for OEM components"
+INSTALLDIR=/usr/local/mapguideopensource
+CLEAN_FLAG=0
+BUILD_CPU=32
+BUILD_CONFIG=release
+while [ $# -gt 0 ]; do    # Until you run out of parameters...
+    case "$1" in
+        -prefix|--prefix)
+            INSTALLDIR="$2"
+            shift
+        -clean|--clean)
+            CLEAN_FLAG=1
+            shift
+        -build|--build)
+            BUILD_CPU=$2
+            shift
+        -config|--config)
+            BUILD_CONFIG=$2
+            shift
+        -help|--help)
+            echo "Usage: $0 (options)"
+            echo "Options:"
+            echo "  --prefix [installation directory]"
+            echo "  --clean [clean all objects and binaries in Oem]"
+            echo "  --build [32(default)|64]"
+            echo "  --config [release(default)|debug]"
+            echo "  --help [Display usage]"
+            exit
+    esac
+    shift   # Check next set of parameters.
+done
+echo "OEM Build Initialization ............................"
+echo "Oem Libraries will be installed at: ${INSTALLDIR}"
+LIB_NAME=""
+# Generic Functions
+check_build()
+    error=$?
+    if [ $error -ne 0 ]; then
+        echo "$LIB_NAME: Error build failed ($error)................."
+        exit $error
+    fi
+check_clean()
+    error=$?
+        echo "$LIB_NAME: Error clean failed ($error)................."
+        exit $error
+    fi
+# Build AGG 2.4
+# Notes: none
+init_agg()
+    LIB_NAME="AGG 2.4"
+build_agg()
+    pushd agg-2.4
+    if [ $BUILD_CPU -eq 64 ]; then
+        make EXTRACXXFLAGS="-fPIC -m64"
+    else
+        make
+    fi
+    check_build
+    popd
+clean_agg()
+    pushd agg-2.4
+    make clean
+    check_clean
+    popd
+# Build Fusion
+# Notes: requires Apache Ant
+init_fusion()
+    LIB_NAME="Fusion"
+build_fusion()
+    pushd fusion
+    ant prepare
+    ant compress
+    popd
+clean_fusion()
+    pushd fusion
+    ant clean
+    popd
+# Script loop
+pushd Oem
+for lib in fusion agg;
+do
+    echo "$lib: Initialization..........................."
+    init_"$lib"
+    if test "$CLEAN_FLAG" = "1"; then
+        echo "$lib: Clean ....................................."
+        clean_"$lib"
+        echo "$lib: Clean Successful .........................."
+    else
+        echo "$lib: Configure/Build ..........................."
+        build_"$lib"
+        echo "$lib: Build Successful .........................."
+    fi
+done
+popd
More information about the mapguide-commits mailing list
