[mapguide-commits] r9042 - in trunk/MgDev/Web/src: mapviewerjava mapviewernet mapviewerphp
svn_mapguide at osgeo.org
Mon Sep 19 06:54:37 PDT 2016
Author: jng
Date: 2016-09-19 06:54:37 -0700 (Mon, 19 Sep 2016)
New Revision: 9042
trunk/MgDev/Web/src/mapviewerjava/search.jsp
trunk/MgDev/Web/src/mapviewernet/search.aspx
trunk/MgDev/Web/src/mapviewerphp/search.php
#2556: Escape single quotes in search command input.
Patch by tuceda. PHP/.net versions provided by me.
Modified: trunk/MgDev/Web/src/mapviewerjava/search.jsp
--- trunk/MgDev/Web/src/mapviewerjava/search.jsp 2016-09-19 13:27:57 UTC (rev 9041)
+++ trunk/MgDev/Web/src/mapviewerjava/search.jsp 2016-09-19 13:54:37 UTC (rev 9042)
@@ -105,6 +105,8 @@
if(layer == null)
throw new SearchError(MessageFormat.format(MgLocalizer.GetString("SEARCHLAYERNOTFOUND", locale), new Object[] { layerName }), searchError);
+ userInput = userInput.replace("'", "''");
//substitute the input tag with the actual user input to make up the filter
int varIndex = filter.indexOf("$USER_VARIABLE");
if(varIndex != -1)
Modified: trunk/MgDev/Web/src/mapviewernet/search.aspx
--- trunk/MgDev/Web/src/mapviewernet/search.aspx 2016-09-19 13:27:57 UTC (rev 9041)
+++ trunk/MgDev/Web/src/mapviewernet/search.aspx 2016-09-19 13:54:37 UTC (rev 9042)
@@ -93,6 +93,9 @@
throw new SearchError(String.Format(MgLocalizer.GetString("SEARCHLAYERNOTFOUND", locale), new Object[] { layerName }), searchError);
+ //escape single quote in userInput
+ userInput = userInput.Replace("'", "''");
filter = filter.Replace("$USER_VARIABLE", userInput);
Modified: trunk/MgDev/Web/src/mapviewerphp/search.php
--- trunk/MgDev/Web/src/mapviewerphp/search.php 2016-09-19 13:27:57 UTC (rev 9041)
+++ trunk/MgDev/Web/src/mapviewerphp/search.php 2016-09-19 13:54:37 UTC (rev 9042)
@@ -43,6 +43,7 @@
$resNames = array();
$resProps = array();
$matchLimit = 0;
+ $features = NULL;
GetRequestParameters();
SetLocalizedFilesPath(GetLocalizationPath());
@@ -77,6 +78,8 @@
trigger_error(FormatMessage("SEARCHLAYERNOTFOUND", $locale, array($layerName)));
+ $userInput = str_replace("'", "''", $userInput);
//unescape strings
More information about the mapguide-commits
