[mapguide-commits] r9051 - trunk/Installer/Installers/MapGuide
svn_mapguide at osgeo.org
Wed Sep 21 09:39:37 PDT 2016
Author: jng
Date: 2016-09-21 09:39:37 -0700 (Wed, 21 Sep 2016)
New Revision: 9051
trunk/Installer/Installers/MapGuide/MapGuide.wxs
#2742: Change the IISVERSIONMAJOR check in the Windows installer so that it passes on Windows 10 (that bundles IIS 10.0). Since the versions of windows we support will have IIS >= 7, we don't really have to check for IISVERSIONMAJOR >= "#7". Instead, we change this check to (NOT IISVERSIONMAJOR = "#0"), which basically says IIS just have to be present, we can safely assume it will be version 7 or higher (thus appcmd.exe will be present).
Modified: trunk/Installer/Installers/MapGuide/MapGuide.wxs
--- trunk/Installer/Installers/MapGuide/MapGuide.wxs 2016-09-21 14:58:25 UTC (rev 9050)
+++ trunk/Installer/Installers/MapGuide/MapGuide.wxs 2016-09-21 16:39:37 UTC (rev 9051)
@@ -500,7 +500,7 @@
<!-- Show the FastCGI warning before advancing to any IIS configuration dialog -->
<Publish Dialog="FastCgiWarningDlg" Control="Next" Event="NewDialog" Value="IISLangConfigDlg" Order="1">MGWEB_CONFIG="IIS" AND NETFRAMEWORK40FULL</Publish>
- <Publish Dialog="FastCgiWarningDlg" Control="Next" Event="NewDialog" Value="IIS7ConfigDlg" Order="2">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND (NOT NETFRAMEWORK40FULL)</Publish>
+ <Publish Dialog="FastCgiWarningDlg" Control="Next" Event="NewDialog" Value="IIS7ConfigDlg" Order="2">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND (NOT NETFRAMEWORK40FULL)</Publish>
<Publish Dialog="FastCgiWarningDlg" Control="Back" Event="NewDialog" Value="WebServerConfigDlgIIS">1</Publish>
<Publish Dialog="FastCgiWarningDlg" Control="Cancel" Event="SpawnDialog" Value="CancelDlg">1</Publish>
@@ -572,7 +572,7 @@
<Publish Dialog="ApacheConfigDlg" Control="Back" Event="NewDialog" Value="WebServerConfigDlgIIS" Order="2">NOT IISVERSIONMAJOR="#0"</Publish>
<Publish Dialog="ApacheConfigDlg" Control="Cancel" Event="SpawnDialog" Value="CancelDlg">1</Publish>
- <Publish Dialog="IISLangConfigDlg" Control="Next" Event="NewDialog" Value="IIS7ConfigDlg" Order="1">IISVERSIONMAJOR>="#7"</Publish>
+ <Publish Dialog="IISLangConfigDlg" Control="Next" Event="NewDialog" Value="IIS7ConfigDlg" Order="1">(NOT IISVERSIONMAJOR="#0")</Publish>
<!-- Default feature settings for PHP API - AddLocal required in case user changes mind and comes back -->
<Publish Dialog="IISLangConfigDlg" Control="Next" Event="Remove" Value="WebExtMapViewerASPXFeature">IIS_API_TYPE="PHP"</Publish>
<Publish Dialog="IISLangConfigDlg" Control="Next" Event="Remove" Value="WebExtDotNetDevGuideSamplesFeature">IIS_API_TYPE="PHP"</Publish>
@@ -595,7 +595,7 @@
<Publish Dialog="IIS7ConfigDlg" Control="Cancel" Event="SpawnDialog" Value="CancelDlg">1</Publish>
<Publish Dialog="IPConfigDlg" Control="Next" Event="NewDialog" Value="InstallDirDlg">1</Publish>
- <Publish Dialog="IPConfigDlg" Control="Back" Event="NewDialog" Value="IIS7ConfigDlg" Order="1">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7"</Publish>
+ <Publish Dialog="IPConfigDlg" Control="Back" Event="NewDialog" Value="IIS7ConfigDlg" Order="1">(NOT IISVERSIONMAJOR="#0") AND MGWEB_CONFIG="IIS"</Publish>
<Publish Dialog="IPConfigDlg" Control="Back" Event="NewDialog" Value="ApacheConfigDlg" Order="2">MGWEB_CONFIG="APACHE"</Publish>
<Publish Dialog="IPConfigDlg" Control="Back" Event="DoAction" Value="MgWeb_Config_To_IIS_CA" Order="3">(NOT IISVERSIONMAJOR="#0") AND ( (IISVERSIONMAJOR="#5" AND (NOT NETFRAMEWORK40FULL)) OR (MGWEB_CONFIG="MANUAL" ))</Publish>
<Publish Dialog="IPConfigDlg" Control="Back" Event="NewDialog" Value="WebServerConfigDlgIIS" Order="4">(NOT IISVERSIONMAJOR="#0") AND ( (IISVERSIONMAJOR="#5" AND (NOT NETFRAMEWORK40FULL) AND MGWEB_CONFIG="IIS" ) OR (MGWEB_CONFIG="MANUAL" ))</Publish>
@@ -683,7 +683,7 @@
<ProgressText Action="FdoRegMySql">!(loc.FdoRegMySql)</ProgressText>
<ProgressText Action="FdoRegGdal">!(loc.FdoRegGdal)</ProgressText>
<ProgressText Action="FdoRegOgr">!(loc.FdoRegOgr)</ProgressText>
- <ProgressText Action="FdoRegPostgreSql">!(loc.FdoRegPostgreSql)</ProgressText>
+ <ProgressText Action="FdoRegPostgreSql">!(loc.FdoRegPostgreSql)</ProgressText>
<ProgressText Action="FdoRegOracle">!(loc.FdoRegOracle)</ProgressText>
<ProgressText Action="FdoRegSqlServer">!(loc.FdoRegSqlServer)</ProgressText>
<ProgressText Action="FdoRegSlt">!(loc.FdoRegSlt)</ProgressText>
@@ -707,129 +707,129 @@
<InstallExecuteSequence>
<!-- IIS7 Base properties for deferred actions -->
- <Custom Action="MapGuideIIS7_I_AppCmd_Cmd" After="CostFinalize">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_CreateFastCgi_Cmd" After="MapGuideIIS7_I_AppCmd_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_CreateAppPool_Cmd" After="MapGuideIIS7_I_CreateFastCgi_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_SetAppPoolProp_Cmd" After="MapGuideIIS7_I_CreateAppPool_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_AppCmd_Cmd" After="CostFinalize">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_CreateFastCgi_Cmd" After="MapGuideIIS7_I_AppCmd_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_CreateAppPool_Cmd" After="MapGuideIIS7_I_CreateFastCgi_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_SetAppPoolProp_Cmd" After="MapGuideIIS7_I_CreateAppPool_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
<?if "$(var.MgPlatform)" = "x64" ?>
- <Custom Action="MapGuideIIS7_I_UnlockSrvHandlers_Cmd" After="MapGuideIIS7_I_SetAppPoolProp_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_UnlockSrvHandlers_Cmd" After="MapGuideIIS7_I_SetAppPoolProp_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
<?else ?>
- <Custom Action="MapGuideIIS7_I_Set32BitAppPool_Cmd" After="MapGuideIIS7_I_SetAppPoolProp_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_UnlockSrvHandlers_Cmd" After="MapGuideIIS7_I_Set32BitAppPool_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_Set32BitAppPool_Cmd" After="MapGuideIIS7_I_SetAppPoolProp_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_UnlockSrvHandlers_Cmd" After="MapGuideIIS7_I_Set32BitAppPool_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
<?endif ?>
- <Custom Action="MapGuideIIS7_I_UnlockSiteHandlers_Cmd" After="MapGuideIIS7_I_UnlockSrvHandlers_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_CreateMapGuideApp_Cmd" After="MapGuideIIS7_I_UnlockSiteHandlers_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_SelectXmlCompat_Cmd" After="MapGuideIIS7_I_CreateMapGuideApp_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_CreatePhpScriptMapping_Cmd" After="MapGuideIIS7_I_SelectXmlCompat_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_CreateMapAgentApp_Cmd" After="MapGuideIIS7_I_CreatePhpScriptMapping_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_SetMapAgentHandlerAccess_Cmd" After="MapGuideIIS7_I_CreateMapAgentApp_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_CreateMapAgentScriptHandling_Cmd" After="MapGuideIIS7_I_SetMapAgentHandlerAccess_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_EnableMapAgentExtension_Cmd" After="MapGuideIIS7_I_CreateMapAgentScriptHandling_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_AssignMapGuideAppPool_Cmd" After="MapGuideIIS7_I_EnableMapAgentExtension_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_AssignMapAgentAppPool_Cmd" After="MapGuideIIS7_I_AssignMapGuideAppPool_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_UnlockHttpErrorsMain_Cmd" After="MapGuideIIS7_I_AssignMapAgentAppPool_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_UnlockHttpErrorsWebSite_Cmd" After="MapGuideIIS7_I_UnlockHttpErrorsMain_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_UnlockHttpErrorsMapGuide_Cmd" After="MapGuideIIS7_I_UnlockHttpErrorsWebSite_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_Reset401Handler_Cmd" After="MapGuideIIS7_I_UnlockHttpErrorsMapGuide_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_AddJsonMime_Cmd" After="MapGuideIIS7_I_Reset401Handler_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_UnlockSiteHandlers_Cmd" After="MapGuideIIS7_I_UnlockSrvHandlers_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_CreateMapGuideApp_Cmd" After="MapGuideIIS7_I_UnlockSiteHandlers_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_SelectXmlCompat_Cmd" After="MapGuideIIS7_I_CreateMapGuideApp_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_CreatePhpScriptMapping_Cmd" After="MapGuideIIS7_I_SelectXmlCompat_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_CreateMapAgentApp_Cmd" After="MapGuideIIS7_I_CreatePhpScriptMapping_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_SetMapAgentHandlerAccess_Cmd" After="MapGuideIIS7_I_CreateMapAgentApp_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_CreateMapAgentScriptHandling_Cmd" After="MapGuideIIS7_I_SetMapAgentHandlerAccess_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_EnableMapAgentExtension_Cmd" After="MapGuideIIS7_I_CreateMapAgentScriptHandling_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_AssignMapGuideAppPool_Cmd" After="MapGuideIIS7_I_EnableMapAgentExtension_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_AssignMapAgentAppPool_Cmd" After="MapGuideIIS7_I_AssignMapGuideAppPool_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_UnlockHttpErrorsMain_Cmd" After="MapGuideIIS7_I_AssignMapAgentAppPool_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_UnlockHttpErrorsWebSite_Cmd" After="MapGuideIIS7_I_UnlockHttpErrorsMain_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_UnlockHttpErrorsMapGuide_Cmd" After="MapGuideIIS7_I_UnlockHttpErrorsWebSite_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_Reset401Handler_Cmd" After="MapGuideIIS7_I_UnlockHttpErrorsMapGuide_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_AddJsonMime_Cmd" After="MapGuideIIS7_I_Reset401Handler_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
<!-- IIS7 PHP Viewer properties for deferred actions -->
- <Custom Action="MapGuideIIS7_I_CreateViewerPhp_Cmd" After="MapGuideIIS7_I_AddJsonMime_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="PHP" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_SetViewerDocPhp_Cmd" After="MapGuideIIS7_I_CreateViewerPhp_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="PHP" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_AssignViewerAppPoolPhp_Cmd" After="MapGuideIIS7_I_SetViewerDocPhp_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="PHP" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_CreateViewerPhp_Cmd" After="MapGuideIIS7_I_AddJsonMime_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="PHP" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_SetViewerDocPhp_Cmd" After="MapGuideIIS7_I_CreateViewerPhp_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="PHP" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_AssignViewerAppPoolPhp_Cmd" After="MapGuideIIS7_I_SetViewerDocPhp_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="PHP" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
<!-- IIS7 ASP.Net Viewer properties for deferred actions -->
- <Custom Action="MapGuideIIS7_I_CreateViewerNet_Cmd" After="MapGuideIIS7_I_Reset401Handler_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_SetViewerDocNet_Cmd" After="MapGuideIIS7_I_CreateViewerNet_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_AssignViewerAppPoolNet_Cmd" After="MapGuideIIS7_I_SetViewerDocNet_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_CreateViewerNet_Cmd" After="MapGuideIIS7_I_Reset401Handler_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_SetViewerDocNet_Cmd" After="MapGuideIIS7_I_CreateViewerNet_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_AssignViewerAppPoolNet_Cmd" After="MapGuideIIS7_I_SetViewerDocNet_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
<!-- mapviewernet -->
- <Custom Action="MapGuideIIS7_I_CreateMapViewerNet_Cmd" After="MapGuideIIS7_I_AssignViewerAppPoolNet_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_SetMapViewerDocNet_Cmd" After="MapGuideIIS7_I_CreateMapViewerNet_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_AssignMapViewerAppPoolNet_Cmd" After="MapGuideIIS7_I_SetMapViewerDocNet_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_CreateMapViewerNet_Cmd" After="MapGuideIIS7_I_AssignViewerAppPoolNet_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_SetMapViewerDocNet_Cmd" After="MapGuideIIS7_I_CreateMapViewerNet_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_AssignMapViewerAppPoolNet_Cmd" After="MapGuideIIS7_I_SetMapViewerDocNet_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
<!-- .net viewer sample -->
- <Custom Action="MapGuideIIS7_I_CreateViewerSampleNet_Cmd" After="MapGuideIIS7_I_AssignMapViewerAppPoolNet_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2 AND &WebExtDotNetViewerSampleFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_SetViewerDocViewerSampleNet_Cmd" After="MapGuideIIS7_I_CreateViewerSampleNet_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2 AND &WebExtDotNetViewerSampleFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_AssignViewerAppPoolViewerSampleNet_Cmd" After="MapGuideIIS7_I_SetViewerDocViewerSampleNet_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2 AND &WebExtDotNetViewerSampleFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_CreateViewerSampleNet_Cmd" After="MapGuideIIS7_I_AssignMapViewerAppPoolNet_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2 AND &WebExtDotNetViewerSampleFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_SetViewerDocViewerSampleNet_Cmd" After="MapGuideIIS7_I_CreateViewerSampleNet_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2 AND &WebExtDotNetViewerSampleFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_AssignViewerAppPoolViewerSampleNet_Cmd" After="MapGuideIIS7_I_SetViewerDocViewerSampleNet_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2 AND &WebExtDotNetViewerSampleFeature>2</Custom>
<!-- .net devguide sample -->
- <Custom Action="MapGuideIIS7_I_CreateViewerDevGuideSamplesNet_Cmd" After="MapGuideIIS7_I_AssignViewerAppPoolViewerSampleNet_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2 AND &WebExtDotNetDevGuideSamplesFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_SetViewerDocDevGuideSamplesNet_Cmd" After="MapGuideIIS7_I_CreateViewerDevGuideSamplesNet_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2 AND &WebExtDotNetDevGuideSamplesFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_AssignViewerAppPoolDevGuideSamplesNet_Cmd" After="MapGuideIIS7_I_SetViewerDocDevGuideSamplesNet_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2 AND &WebExtDotNetDevGuideSamplesFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_CreateViewerDevGuideSamplesNet_Cmd" After="MapGuideIIS7_I_AssignViewerAppPoolViewerSampleNet_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2 AND &WebExtDotNetDevGuideSamplesFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_SetViewerDocDevGuideSamplesNet_Cmd" After="MapGuideIIS7_I_CreateViewerDevGuideSamplesNet_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2 AND &WebExtDotNetDevGuideSamplesFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_AssignViewerAppPoolDevGuideSamplesNet_Cmd" After="MapGuideIIS7_I_SetViewerDocDevGuideSamplesNet_Cmd">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2 AND &WebExtDotNetDevGuideSamplesFeature>2</Custom>
<!-- IIS7 Base deferred CAs -->
- <Custom Action="MapGuideIIS7_I_CreateAppPool" After="InstallFiles">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_CreateFastCgi" After="MapGuideIIS7_I_CreateAppPool">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_SetAppPoolProp" After="MapGuideIIS7_I_CreateFastCgi">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_CreateAppPool" After="InstallFiles">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_CreateFastCgi" After="MapGuideIIS7_I_CreateAppPool">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_SetAppPoolProp" After="MapGuideIIS7_I_CreateFastCgi">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_UnlockSrvHandlers" After="MapGuideIIS7_I_SetAppPoolProp">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_UnlockSrvHandlers" After="MapGuideIIS7_I_SetAppPoolProp">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
<?else ?>
- <Custom Action="MapGuideIIS7_I_Set32BitAppPool" After="MapGuideIIS7_I_SetAppPoolProp">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_UnlockSrvHandlers" After="MapGuideIIS7_I_Set32BitAppPool">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_Set32BitAppPool" After="MapGuideIIS7_I_SetAppPoolProp">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_UnlockSrvHandlers" After="MapGuideIIS7_I_Set32BitAppPool">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
<?endif ?>
- <Custom Action="MapGuideIIS7_I_UnlockSiteHandlers" After="MapGuideIIS7_I_UnlockSrvHandlers">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_CreateMapGuideApp" After="MapGuideIIS7_I_UnlockSiteHandlers">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_SelectXmlCompat" After="MapGuideIIS7_I_CreateMapGuideApp">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_CreatePhpScriptMapping" After="MapGuideIIS7_I_SelectXmlCompat">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_CreateMapAgentApp" After="MapGuideIIS7_I_CreatePhpScriptMapping">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_SetMapAgentHandlerAccess" After="MapGuideIIS7_I_CreateMapAgentApp">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_CreateMapAgentScriptHandling" After="MapGuideIIS7_I_SetMapAgentHandlerAccess">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_EnableMapAgentExtension" After="MapGuideIIS7_I_CreateMapAgentScriptHandling">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_AssignMapGuideAppPool" After="MapGuideIIS7_I_EnableMapAgentExtension">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_AssignMapAgentAppPool" After="MapGuideIIS7_I_AssignMapGuideAppPool">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_UnlockHttpErrorsMain" After="MapGuideIIS7_I_AssignMapAgentAppPool">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_UnlockHttpErrorsWebSite" After="MapGuideIIS7_I_UnlockHttpErrorsMain">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_UnlockHttpErrorsMapGuide" After="MapGuideIIS7_I_UnlockHttpErrorsWebSite">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_Reset401Handler" After="MapGuideIIS7_I_UnlockHttpErrorsMapGuide">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_AddJsonMime" After="MapGuideIIS7_I_Reset401Handler">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_UnlockSiteHandlers" After="MapGuideIIS7_I_UnlockSrvHandlers">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_CreateMapGuideApp" After="MapGuideIIS7_I_UnlockSiteHandlers">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_SelectXmlCompat" After="MapGuideIIS7_I_CreateMapGuideApp">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_CreatePhpScriptMapping" After="MapGuideIIS7_I_SelectXmlCompat">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_CreateMapAgentApp" After="MapGuideIIS7_I_CreatePhpScriptMapping">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_SetMapAgentHandlerAccess" After="MapGuideIIS7_I_CreateMapAgentApp">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_CreateMapAgentScriptHandling" After="MapGuideIIS7_I_SetMapAgentHandlerAccess">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_EnableMapAgentExtension" After="MapGuideIIS7_I_CreateMapAgentScriptHandling">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_AssignMapGuideAppPool" After="MapGuideIIS7_I_EnableMapAgentExtension">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_AssignMapAgentAppPool" After="MapGuideIIS7_I_AssignMapGuideAppPool">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_UnlockHttpErrorsMain" After="MapGuideIIS7_I_AssignMapAgentAppPool">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_UnlockHttpErrorsWebSite" After="MapGuideIIS7_I_UnlockHttpErrorsMain">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_UnlockHttpErrorsMapGuide" After="MapGuideIIS7_I_UnlockHttpErrorsWebSite">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_Reset401Handler" After="MapGuideIIS7_I_UnlockHttpErrorsMapGuide">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_AddJsonMime" After="MapGuideIIS7_I_Reset401Handler">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
<!-- IIS7 PHP Viewer deferred CAs -->
- <Custom Action="MapGuideIIS7_I_CreateViewerPhp" After="MapGuideIIS7_I_AddJsonMime">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="PHP" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_SetViewerDocPhp" After="MapGuideIIS7_I_CreateViewerPhp">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="PHP" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_AssignViewerAppPoolPhp" After="MapGuideIIS7_I_SetViewerDocPhp">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="PHP" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_CreateViewerPhp" After="MapGuideIIS7_I_AddJsonMime">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="PHP" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_SetViewerDocPhp" After="MapGuideIIS7_I_CreateViewerPhp">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="PHP" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_AssignViewerAppPoolPhp" After="MapGuideIIS7_I_SetViewerDocPhp">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="PHP" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
<!-- IIS7 DOTNET Viewer deferred CAs -->
- <Custom Action="MapGuideIIS7_I_CreateViewerNet" After="MapGuideIIS7_I_Reset401Handler">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_SetViewerDocNet" After="MapGuideIIS7_I_CreateViewerNet">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_AssignViewerAppPoolNet" After="MapGuideIIS7_I_SetViewerDocNet">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_CreateViewerNet" After="MapGuideIIS7_I_Reset401Handler">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_SetViewerDocNet" After="MapGuideIIS7_I_CreateViewerNet">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_AssignViewerAppPoolNet" After="MapGuideIIS7_I_SetViewerDocNet">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_CreateMapViewerNet" After="MapGuideIIS7_I_AssignViewerAppPoolNet">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2 AND &WebExtMapViewerASPXFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_SetMapViewerDocNet" After="MapGuideIIS7_I_CreateMapViewerNet">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2 AND &WebExtMapViewerASPXFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_AssignMapViewerAppPoolNet" After="MapGuideIIS7_I_SetMapViewerDocNet">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2 AND &WebExtMapViewerASPXFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_CreateMapViewerNet" After="MapGuideIIS7_I_AssignViewerAppPoolNet">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2 AND &WebExtMapViewerASPXFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_SetMapViewerDocNet" After="MapGuideIIS7_I_CreateMapViewerNet">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2 AND &WebExtMapViewerASPXFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_AssignMapViewerAppPoolNet" After="MapGuideIIS7_I_SetMapViewerDocNet">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2 AND &WebExtMapViewerASPXFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_CreateViewerSampleNet" After="MapGuideIIS7_I_AssignMapViewerAppPoolNet">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2 AND &WebExtDotNetViewerSampleFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_SetViewerDocViewerSampleNet" After="MapGuideIIS7_I_CreateViewerSampleNet">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2 AND &WebExtDotNetViewerSampleFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_AssignViewerAppPoolViewerSampleNet" After="MapGuideIIS7_I_SetViewerDocViewerSampleNet">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2 AND &WebExtDotNetViewerSampleFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_CreateViewerSampleNet" After="MapGuideIIS7_I_AssignMapViewerAppPoolNet">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2 AND &WebExtDotNetViewerSampleFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_SetViewerDocViewerSampleNet" After="MapGuideIIS7_I_CreateViewerSampleNet">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2 AND &WebExtDotNetViewerSampleFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_AssignViewerAppPoolViewerSampleNet" After="MapGuideIIS7_I_SetViewerDocViewerSampleNet">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2 AND &WebExtDotNetViewerSampleFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_CreateViewerDevGuideSamplesNet" After="MapGuideIIS7_I_AssignViewerAppPoolViewerSampleNet">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2 AND &WebExtDotNetDevGuideSamplesFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_SetViewerDocDevGuideSamplesNet" After="MapGuideIIS7_I_CreateViewerDevGuideSamplesNet">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2 AND &WebExtDotNetDevGuideSamplesFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_AssignViewerAppPoolDevGuideSamplesNet" After="MapGuideIIS7_I_SetViewerDocDevGuideSamplesNet">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature>2 AND &WebExtDotNetDevGuideSamplesFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_CreateViewerDevGuideSamplesNet" After="MapGuideIIS7_I_AssignViewerAppPoolViewerSampleNet">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2 AND &WebExtDotNetDevGuideSamplesFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_SetViewerDocDevGuideSamplesNet" After="MapGuideIIS7_I_CreateViewerDevGuideSamplesNet">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2 AND &WebExtDotNetDevGuideSamplesFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_AssignViewerAppPoolDevGuideSamplesNet" After="MapGuideIIS7_I_SetViewerDocDevGuideSamplesNet">MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature>2 AND &WebExtDotNetDevGuideSamplesFeature>2</Custom>
<!-- IIS7 UNINSTALL deferred action properties -->
- <Custom Action="MapGuideIIS7_U_AppCmd_Cmd" After="InstallInitialize">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature=2</Custom>
- <Custom Action="MapGuideIIS7_U_ClearMapAgentRestriction_Cmd" After="MapGuideIIS7_U_AppCmd_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature=2</Custom>
- <Custom Action="MapGuideIIS7_U_RemoveDotNetSamples_Cmd" After="MapGuideIIS7_U_ClearMapAgentRestriction_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature=2</Custom>
- <Custom Action="MapGuideIIS7_U_RemoveDotNetViewerSample_Cmd" After="MapGuideIIS7_U_RemoveDotNetSamples_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature=2</Custom>
- <Custom Action="MapGuideIIS7_U_RemoveViewer_Cmd" After="MapGuideIIS7_U_RemoveDotNetViewerSample_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature=2</Custom>
- <Custom Action="MapGuideIIS7_U_RemoveViewerNet_Cmd" After="MapGuideIIS7_U_RemoveViewer_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature=2</Custom>
- <Custom Action="MapGuideIIS7_U_RemoveMapAgent_Cmd" After="MapGuideIIS7_U_RemoveViewerNet_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature=2</Custom>
- <Custom Action="MapGuideIIS7_U_RemoveMapGuide_Cmd" After="MapGuideIIS7_U_RemoveMapAgent_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature=2</Custom>
- <Custom Action="MapGuideIIS7_U_DeleteAppPool_Cmd" After="MapGuideIIS7_U_RemoveMapGuide_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature=2</Custom>
+ <Custom Action="MapGuideIIS7_U_AppCmd_Cmd" After="InstallInitialize">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature=2</Custom>
+ <Custom Action="MapGuideIIS7_U_ClearMapAgentRestriction_Cmd" After="MapGuideIIS7_U_AppCmd_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature=2</Custom>
+ <Custom Action="MapGuideIIS7_U_RemoveDotNetSamples_Cmd" After="MapGuideIIS7_U_ClearMapAgentRestriction_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature=2</Custom>
+ <Custom Action="MapGuideIIS7_U_RemoveDotNetViewerSample_Cmd" After="MapGuideIIS7_U_RemoveDotNetSamples_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature=2</Custom>
+ <Custom Action="MapGuideIIS7_U_RemoveViewer_Cmd" After="MapGuideIIS7_U_RemoveDotNetViewerSample_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature=2</Custom>
+ <Custom Action="MapGuideIIS7_U_RemoveViewerNet_Cmd" After="MapGuideIIS7_U_RemoveViewer_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature=2</Custom>
+ <Custom Action="MapGuideIIS7_U_RemoveMapAgent_Cmd" After="MapGuideIIS7_U_RemoveViewerNet_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature=2</Custom>
+ <Custom Action="MapGuideIIS7_U_RemoveMapGuide_Cmd" After="MapGuideIIS7_U_RemoveMapAgent_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature=2</Custom>
+ <Custom Action="MapGuideIIS7_U_DeleteAppPool_Cmd" After="MapGuideIIS7_U_RemoveMapGuide_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature=2</Custom>
<!-- IIS7 UNINSTALL deferred CAs -->
- <Custom Action="MapGuideIIS7_U_ClearMapAgentRestriction" After="MapGuideIIS7_U_DeleteAppPool_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature=2</Custom>
- <Custom Action="MapGuideIIS7_U_RemoveDotNetSamples" After="MapGuideIIS7_U_ClearMapAgentRestriction">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature=2</Custom>
- <Custom Action="MapGuideIIS7_U_RemoveDotNetViewerSample" After="MapGuideIIS7_U_RemoveDotNetSamples">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature=2</Custom>
- <Custom Action="MapGuideIIS7_U_RemoveViewer" After="MapGuideIIS7_U_RemoveDotNetViewerSample">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature=2</Custom>
- <Custom Action="MapGuideIIS7_U_RemoveViewerNet" After="MapGuideIIS7_U_RemoveViewer">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature=2</Custom>
- <Custom Action="MapGuideIIS7_U_RemoveMapAgent" After="MapGuideIIS7_U_RemoveViewerNet">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature=2</Custom>
- <Custom Action="MapGuideIIS7_U_RemoveMapGuide" After="MapGuideIIS7_U_RemoveMapAgent">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature=2</Custom>
- <Custom Action="MapGuideIIS7_U_DeleteAppPool" After="MapGuideIIS7_U_RemoveMapGuide">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR>="#7" AND &WebExtensionsFeature=2</Custom>
+ <Custom Action="MapGuideIIS7_U_ClearMapAgentRestriction" After="MapGuideIIS7_U_DeleteAppPool_Cmd">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature=2</Custom>
+ <Custom Action="MapGuideIIS7_U_RemoveDotNetSamples" After="MapGuideIIS7_U_ClearMapAgentRestriction">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature=2</Custom>
+ <Custom Action="MapGuideIIS7_U_RemoveDotNetViewerSample" After="MapGuideIIS7_U_RemoveDotNetSamples">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature=2</Custom>
+ <Custom Action="MapGuideIIS7_U_RemoveViewer" After="MapGuideIIS7_U_RemoveDotNetViewerSample">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature=2</Custom>
+ <Custom Action="MapGuideIIS7_U_RemoveViewerNet" After="MapGuideIIS7_U_RemoveViewer">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature=2</Custom>
+ <Custom Action="MapGuideIIS7_U_RemoveMapAgent" After="MapGuideIIS7_U_RemoveViewerNet">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature=2</Custom>
+ <Custom Action="MapGuideIIS7_U_RemoveMapGuide" After="MapGuideIIS7_U_RemoveMapAgent">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature=2</Custom>
+ <Custom Action="MapGuideIIS7_U_DeleteAppPool" After="MapGuideIIS7_U_RemoveMapGuide">MGWEB_CONFIG="IIS" AND (NOT IISVERSIONMAJOR="#0") AND &WebExtensionsFeature=2</Custom>
<Custom Action="FdoRegCmd" After="InstallInitialize"></Custom>
<!-- FDO Provider Registration Immediate Actions -->
More information about the mapguide-commits
