[mapguide-commits] r9140 - sandbox/adsk/3.2o.AIMS/Server/src/Services/Feature
svn_mapguide at osgeo.org
Tue Apr 4 21:44:02 PDT 2017
Author: hubu
Date: 2017-04-04 21:44:02 -0700 (Tue, 04 Apr 2017)
New Revision: 9140
sandbox/adsk/3.2o.AIMS/Server/src/Services/Feature/ServerDescribeSchema.cpp
Ignore abstract classes when DescribeSchema because they should not be visible to consumer.
Modified: sandbox/adsk/3.2o.AIMS/Server/src/Services/Feature/ServerDescribeSchema.cpp
--- sandbox/adsk/3.2o.AIMS/Server/src/Services/Feature/ServerDescribeSchema.cpp 2017-03-24 01:23:47 UTC (rev 9139)
+++ sandbox/adsk/3.2o.AIMS/Server/src/Services/Feature/ServerDescribeSchema.cpp 2017-04-05 04:44:02 UTC (rev 9140)
@@ -1,5 +1,5 @@
-// Copyright (C) 2004-2011 by Autodesk, Inc.
+// Copyright (C) 2017 by Autodesk, Inc.
// This library is free software; you can redistribute it and/or
// modify it under the terms of version 2.1 of the GNU Lesser
@@ -283,8 +283,9 @@
FdoStringP qname = fc->GetQualifiedName();
FdoStringP name = fc->GetName();
+ FdoBoolean isAbstract = fc->GetIsAbstract();
- if (name != NULL && qname != NULL)
+ if (name != NULL && qname != NULL && !isAbstract)
Ptr<MgClassDefinition> classDefinition = MgServerFeatureUtil::GetMgClassDefinition(fc, serialize);
classCol->Add(classDefinition);
@@ -564,6 +565,9 @@
} // Repeat for all extensions
+ if (classCol->GetCount() == 0)
+ continue;
// Add the schema to the MgFeatureSchemaCollection
fsCollection->Add(schema);
More information about the mapguide-commits
