[mapguide-commits] r9148 - in sandbox/jng/clean_json: . UnitTest/WebTier/MapAgent/MapAgentForms Web/src/HttpHandler
svn_mapguide at osgeo.org
Tue Apr 18 09:18:26 PDT 2017
Author: jng
Date: 2017-04-18 09:18:26 -0700 (Tue, 18 Apr 2017)
New Revision: 9148
sandbox/jng/clean_json/
sandbox/jng/clean_json/UnitTest/WebTier/MapAgent/MapAgentForms/getfeaturesetenvelopeform.html
sandbox/jng/clean_json/UnitTest/WebTier/MapAgent/MapAgentForms/getsiteversionform.html
sandbox/jng/clean_json/Web/src/HttpHandler/HttpDescribeDrawing.cpp
sandbox/jng/clean_json/Web/src/HttpHandler/HttpEnumerateDrawingLayers.cpp
sandbox/jng/clean_json/Web/src/HttpHandler/HttpEnumerateDrawingSectionResources.cpp
sandbox/jng/clean_json/Web/src/HttpHandler/HttpEnumerateDrawingSections.cpp
sandbox/jng/clean_json/Web/src/HttpHandler/HttpEnumerateGroups.cpp
sandbox/jng/clean_json/Web/src/HttpHandler/HttpEnumerateRepositories.cpp
sandbox/jng/clean_json/Web/src/HttpHandler/HttpEnumerateUsers.cpp
sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetFeatureSetEnvelope.cpp
sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetRepositoryContent.cpp
sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetRepositoryHeader.cpp
sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetSiteInfo.cpp
sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetSiteStatus.cpp
sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetSiteVersion.cpp
sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetTileProviders.cpp
Trunk sync
Property changes on: sandbox/jng/clean_json
___________________________________________________________________
Modified: svn:mergeinfo
- /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/branches/2.6/MgDev:8276-8286,8288-8292,8297,8299,8301,8303,8314-8315,8318,8335,8340,8354-8355,8365,8373
/branches/3.0/MgDev:8658,8705,8710
/branches/3.1/MgDev:9026,9058-9059,9067-9068
/sandbox/VC140:8684-8759
/sandbox/adsk/2.6l:8727
/sandbox/adsk/3.0m:8563,8584,8607,8625,8694-8695
/sandbox/adsk/3.1n:8871,8895,8901,8912-8913,8921-8922,8942,9019-9020
/sandbox/jng/convenience_apis:8262-8268,8271-8363
/sandbox/jng/createruntimemap:7486-7555
/sandbox/jng/dwftk:8321-8324,8328-8329,8331,8352
/sandbox/jng/geos34x:8256-8259
/sandbox/jng/php56x:8975-8985
/sandbox/jng/rfc155:8872-8884
/sandbox/jng/simplify:8814-9141
/sandbox/jng/tiling:8174-8208
/sandbox/jng/v30:8212-8227
/sandbox/rfc94:5099-5163
/trunk/MgDev:8818-9143
+ /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/trunk/MgDev:8818-9147
Modified: sandbox/jng/clean_json/UnitTest/WebTier/MapAgent/MapAgentForms/getfeaturesetenvelopeform.html
--- sandbox/jng/clean_json/UnitTest/WebTier/MapAgent/MapAgentForms/getfeaturesetenvelopeform.html 2017-04-18 16:07:16 UTC (rev 9147)
+++ sandbox/jng/clean_json/UnitTest/WebTier/MapAgent/MapAgentForms/getfeaturesetenvelopeform.html 2017-04-18 16:18:26 UTC (rev 9148)
@@ -18,6 +18,13 @@
Map name: <input type="text" name="MAPNAME" value="TestMap" size="100" ID="Text4">
<p>
FeatureSet XML: <input type="text" name="FEATURESET" size="100" ID="Text4">
+ <p> Format:
+ <select name="FORMAT">
+ <option value="text/xml">text/xml</option>
+ <option value="application/json">application/json</option>
+ </select>
+ <p>
+ <input type="submit" value="Submit" onclick="SetActionTarget()"> <input type="reset">
</div>
</form>
</body>
Modified: sandbox/jng/clean_json/UnitTest/WebTier/MapAgent/MapAgentForms/getsiteversionform.html
--- sandbox/jng/clean_json/UnitTest/WebTier/MapAgent/MapAgentForms/getsiteversionform.html 2017-04-18 16:07:16 UTC (rev 9147)
+++ sandbox/jng/clean_json/UnitTest/WebTier/MapAgent/MapAgentForms/getsiteversionform.html 2017-04-18 16:18:26 UTC (rev 9148)
@@ -18,6 +18,11 @@
<input type="text" name="LOCALE" value="en" size="10" ID="Text4">
<p> Client Agent:
<input type="text" name="CLIENTAGENT" value="MapGuide Developer" size="100">
+ <p> Format:
+ </select>
<p>
</form>
Modified: sandbox/jng/clean_json/Web/src/HttpHandler/HttpDescribeDrawing.cpp
--- sandbox/jng/clean_json/Web/src/HttpHandler/HttpDescribeDrawing.cpp 2017-04-18 16:07:16 UTC (rev 9147)
+++ sandbox/jng/clean_json/Web/src/HttpHandler/HttpDescribeDrawing.cpp 2017-04-18 16:18:26 UTC (rev 9148)
@@ -61,6 +61,10 @@
// call the C++ API
Ptr<MgByteReader> byteReaderResult = service->DescribeDrawing(&resId);
+ // Convert to requested response format, if necessary
+ ProcessFormatConversion(byteReaderResult);
hResult->SetResultObject(byteReaderResult, byteReaderResult->GetMimeType());
MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpDescribeDrawing.Execute")
Modified: sandbox/jng/clean_json/Web/src/HttpHandler/HttpEnumerateDrawingLayers.cpp
--- sandbox/jng/clean_json/Web/src/HttpHandler/HttpEnumerateDrawingLayers.cpp 2017-04-18 16:07:16 UTC (rev 9147)
+++ sandbox/jng/clean_json/Web/src/HttpHandler/HttpEnumerateDrawingLayers.cpp 2017-04-18 16:18:26 UTC (rev 9148)
@@ -63,7 +63,13 @@
// call the C++ API
Ptr<MgStringCollection> layers = service->EnumerateLayers(&resId, m_sectionName);
- hResult->SetResultObject(layers, MgMimeType::Xml);
+ Ptr<MgByteReader> byteReader = layers->ToXml();
+ ProcessFormatConversion(byteReader);
+ hResult->SetResultObject(byteReader, byteReader->GetMimeType());
MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpEnumerateDrawingLayers.Execute")
Modified: sandbox/jng/clean_json/Web/src/HttpHandler/HttpEnumerateDrawingSectionResources.cpp
--- sandbox/jng/clean_json/Web/src/HttpHandler/HttpEnumerateDrawingSectionResources.cpp 2017-04-18 16:07:16 UTC (rev 9147)
+++ sandbox/jng/clean_json/Web/src/HttpHandler/HttpEnumerateDrawingSectionResources.cpp 2017-04-18 16:18:26 UTC (rev 9148)
@@ -62,8 +62,12 @@
Ptr<MgDrawingService> service = (MgDrawingService*)(CreateService(MgServiceType::DrawingService));
// call the C++ API
- Ptr<MgByteReader> sectionResources = service->EnumerateSectionResources(&resId, m_sectionName);
- hResult->SetResultObject(sectionResources, MgMimeType::Xml);
+ Ptr<MgByteReader> byteReader = service->EnumerateSectionResources(&resId, m_sectionName);
MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpEnumerateDrawingSectionResources.Execute")
Modified: sandbox/jng/clean_json/Web/src/HttpHandler/HttpEnumerateDrawingSections.cpp
--- sandbox/jng/clean_json/Web/src/HttpHandler/HttpEnumerateDrawingSections.cpp 2017-04-18 16:07:16 UTC (rev 9147)
+++ sandbox/jng/clean_json/Web/src/HttpHandler/HttpEnumerateDrawingSections.cpp 2017-04-18 16:18:26 UTC (rev 9148)
@@ -60,8 +60,12 @@
// call the C++ API
- Ptr<MgByteReader> sections = service->EnumerateSections(&resId);
- hResult->SetResultObject(sections, MgMimeType::Xml);
+ Ptr<MgByteReader> byteReader = service->EnumerateSections(&resId);
MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpEnumerateDrawingSections.Execute")
Modified: sandbox/jng/clean_json/Web/src/HttpHandler/HttpEnumerateGroups.cpp
--- sandbox/jng/clean_json/Web/src/HttpHandler/HttpEnumerateGroups.cpp 2017-04-18 16:07:16 UTC (rev 9147)
+++ sandbox/jng/clean_json/Web/src/HttpHandler/HttpEnumerateGroups.cpp 2017-04-18 16:18:26 UTC (rev 9148)
@@ -59,6 +59,9 @@
// Run API command
Ptr<MgByteReader> byteReaderResult = mgSite->EnumerateGroups();
MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpEnumerateGroups.Execute")
Modified: sandbox/jng/clean_json/Web/src/HttpHandler/HttpEnumerateRepositories.cpp
--- sandbox/jng/clean_json/Web/src/HttpHandler/HttpEnumerateRepositories.cpp 2017-04-18 16:07:16 UTC (rev 9147)
+++ sandbox/jng/clean_json/Web/src/HttpHandler/HttpEnumerateRepositories.cpp 2017-04-18 16:18:26 UTC (rev 9148)
@@ -64,6 +64,9 @@
// Run API command
Ptr<MgByteReader> byteReaderResult = mgprService->EnumerateRepositories(m_type);
MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpEnumerateRepositories.Execute")
Modified: sandbox/jng/clean_json/Web/src/HttpHandler/HttpEnumerateUsers.cpp
--- sandbox/jng/clean_json/Web/src/HttpHandler/HttpEnumerateUsers.cpp 2017-04-18 16:07:16 UTC (rev 9147)
+++ sandbox/jng/clean_json/Web/src/HttpHandler/HttpEnumerateUsers.cpp 2017-04-18 16:18:26 UTC (rev 9148)
@@ -64,6 +64,9 @@
// Run API command
Ptr<MgByteReader> byteReaderResult = mgSite->EnumerateUsers( m_group );
MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpEnumerateUsers.Execute")
Modified: sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetFeatureSetEnvelope.cpp
--- sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetFeatureSetEnvelope.cpp 2017-04-18 16:07:16 UTC (rev 9147)
+++ sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetFeatureSetEnvelope.cpp 2017-04-18 16:18:26 UTC (rev 9148)
@@ -66,7 +66,10 @@
Ptr<MgEnvelope> envelope = selection->GetExtents(featureService);
Ptr<MgByteReader> byteReader = envelope->ToXml();
- hResult->SetResultObject(byteReader, MgMimeType::Xml);
MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGetFeatureSetEnvelope.Execute")
Modified: sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetRepositoryContent.cpp
--- sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetRepositoryContent.cpp 2017-04-18 16:07:16 UTC (rev 9147)
+++ sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetRepositoryContent.cpp 2017-04-18 16:18:26 UTC (rev 9148)
@@ -67,6 +67,9 @@
// Run API command
Ptr<MgByteReader> byteReaderResult = mgprService->GetRepositoryContent(&mgrIdentifier);
MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGetRepositoryContent.Execute")
Modified: sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetRepositoryHeader.cpp
--- sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetRepositoryHeader.cpp 2017-04-18 16:07:16 UTC (rev 9147)
+++ sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetRepositoryHeader.cpp 2017-04-18 16:18:26 UTC (rev 9148)
@@ -67,6 +67,9 @@
// Run API command
Ptr<MgByteReader> byteReaderResult = mgprService->GetRepositoryHeader(&mgrIdentifier);
MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGetRepositoryHeader.Execute")
Modified: sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetSiteInfo.cpp
--- sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetSiteInfo.cpp 2017-04-18 16:07:16 UTC (rev 9147)
+++ sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetSiteInfo.cpp 2017-04-18 16:18:26 UTC (rev 9148)
@@ -125,12 +125,18 @@
xml += EndXml();
- Ptr<MgHttpPrimitiveValue> value = new MgHttpPrimitiveValue(xml);
- if(!value)
- throw new MgOutOfMemoryException(L"", __LINE__, __WFILE__, NULL, L"", NULL);
+ std::string mbXml;
+ MgUtil::WideCharToMultiByte(xml, mbXml);
- hResult->SetResultObject(value, MgMimeType::Xml);
+ Ptr<MgByteSource> byteSource = new MgByteSource((BYTE_ARRAY_IN)mbXml.c_str(), (INT32)mbXml.length());
+ byteSource->SetMimeType(MgMimeType::Xml);
+ Ptr<MgByteReader> byteReader = byteSource->GetReader();
+ //Convert to alternate response format, if necessary
MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGetSiteInfo.Execute")
Modified: sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetSiteStatus.cpp
--- sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetSiteStatus.cpp 2017-04-18 16:07:16 UTC (rev 9147)
+++ sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetSiteStatus.cpp 2017-04-18 16:18:26 UTC (rev 9148)
@@ -105,12 +105,18 @@
xml += EndXml();
- if(!value)
MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGetSiteStatus.Execute")
Modified: sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetSiteVersion.cpp
--- sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetSiteVersion.cpp 2017-04-18 16:07:16 UTC (rev 9147)
+++ sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetSiteVersion.cpp 2017-04-18 16:18:26 UTC (rev 9148)
@@ -117,12 +117,18 @@
xml += EndXml();
- if(!value)
MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGetSiteVersion.Execute")
Modified: sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetTileProviders.cpp
--- sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetTileProviders.cpp 2017-04-18 16:07:16 UTC (rev 9147)
+++ sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetTileProviders.cpp 2017-04-18 16:18:26 UTC (rev 9148)
@@ -59,6 +59,9 @@
// Call the C++ API
Ptr<MgByteReader> providers = service->GetTileProviders();
+ ProcessFormatConversion(providers);
// Set the result
hResult->SetResultObject(providers, providers->GetMimeType());
More information about the mapguide-commits
