[mapguide-commits] r9170 - in branches/3.0/vagrant: . centos6/x64 centos6/x86 scripts ubuntu12/x64 ubuntu12/x86 ubuntu14/x64 ubuntu14/x86
svn_mapguide at osgeo.org
Sat Apr 22 09:25:33 PDT 2017
Author: jng
Date: 2017-04-22 09:25:33 -0700 (Sat, 22 Apr 2017)
New Revision: 9170
branches/3.0/vagrant/
branches/3.0/vagrant/centos6/x64/Vagrantfile
branches/3.0/vagrant/centos6/x86/Vagrantfile
branches/3.0/vagrant/clean.bat
branches/3.0/vagrant/scripts/mginstallubuntu.sh
branches/3.0/vagrant/scripts/provision_ubuntu.sh
branches/3.0/vagrant/ubuntu12/x64/Vagrantfile
branches/3.0/vagrant/ubuntu12/x86/Vagrantfile
branches/3.0/vagrant/ubuntu14/x64/Vagrantfile
branches/3.0/vagrant/ubuntu14/x86/Vagrantfile
Merged revision(s) 9163, 9166-9168 from trunk/Tools/Vagrant:
Update clean.bat and Vagrantfiles in light of stupidity introduced in vagrant that demands the script file being referenced by the shell provisioner configuration physically exist, even if I just want to destroy the associated running VM!
Fix bad provision script path for centos6/x86
- Remove bash-isms from install script. This script now runs on vanilla POSIX sh. Fixes #2760
- Add support for:
--no-service-install: To prevent automatic installation of service scripts
--no-mgserver-start: Do not auto-start mgserver
--no-tomcat-start: Do not auto-start tomcat
--no-httpd-start: Do not auto-start httpd
All these new flags only apply if the --headless flag is specified. Fixes #2768
Merged revision(s) 8967, 8972-8973 from branches/3.1/vagrant:
Fix release label not being properly stamped onto ubuntu install script as it was looking for a default label that doesn't exist.
Update ubuntu install script:
- Add extra pre-requisite packages that were discovered to be required when testing on a clean barebones Ubuntu server installation.
Remove libc6 requirement from mginstallubuntu.sh. This package will always be present.
Property changes on: branches/3.0/vagrant
___________________________________________________________________
Modified: svn:mergeinfo
- /branches/3.1/vagrant:8963
/trunk/Tools/Vagrant:8932-8947,8964
+ /branches/3.1/vagrant:8963,8967,8972-8973
/trunk/Tools/Vagrant:8932-8947,8964,9163,9166-9168
Modified: branches/3.0/vagrant/centos6/x64/Vagrantfile
--- branches/3.0/vagrant/centos6/x64/Vagrantfile 2017-04-22 16:18:41 UTC (rev 9169)
+++ branches/3.0/vagrant/centos6/x64/Vagrantfile 2017-04-22 16:25:33 UTC (rev 9170)
@@ -116,8 +116,13 @@
# chef.validation_client_name = "ORGNAME-validator"
+ # UPDATE 21/04/2017: Vagrant (as of 1.9.1, could be earlier release) does something stupid now
+ # and demands the script path below exists, even if I want to just destroy the VM!!!
+ # The path has changed to a relative reference that will *always* be there
config.vm.provision "shell",
privileged: false,
- path: "provision_centos.sh",
+ path: "../../scripts/provision_centos.sh",
args: [4, 0, 0, 3, 0, 1, "4.0", "3.0", "amd64", "Final", "centos6", 1, 1]
end
Modified: branches/3.0/vagrant/centos6/x86/Vagrantfile
--- branches/3.0/vagrant/centos6/x86/Vagrantfile 2017-04-22 16:18:41 UTC (rev 9169)
+++ branches/3.0/vagrant/centos6/x86/Vagrantfile 2017-04-22 16:25:33 UTC (rev 9170)
privileged: false,
args: [4, 0, 0, 3, 0, 1, "4.0", "3.0", "i386", "Final", "centos6", 1, 1]
end
Modified: branches/3.0/vagrant/clean.bat
--- branches/3.0/vagrant/clean.bat 2017-04-22 16:18:41 UTC (rev 9169)
+++ branches/3.0/vagrant/clean.bat 2017-04-22 16:25:33 UTC (rev 9170)
@@ -6,50 +6,70 @@
if exist filelist rd /S /Q filelist
if exist fdosdk_filename del /F fdosdk_filename
if exist fdosdk_rev del /F fdosdk_rev
-del /F fdosdk*.tar.gz
+if exist fdosdk*.tar.gz del /F fdosdk*.tar.gz
popd
-pushd centos\src_update
+pushd centos6\src_update
call vagrant destroy -f
popd
-pushd ubuntu\x86
-SET COMPONENT=Ubuntu Build 32-bit
-echo [clean]: MapGuide Ubuntu build 32-bit
+pushd ubuntu12\x86
+SET COMPONENT=Ubuntu 12 Build 32-bit
+echo [clean]: %COMPONENT%
+call vagrant destroy -f
if exist build rd /S /Q build
if exist *.sh del *.sh
if exist *.pl del *.pl
if exist *.txt del *.txt
+popd
+pushd ubuntu14\x86
+SET COMPONENT=Ubuntu 14 Build 32-bit
+if exist build rd /S /Q build
+if exist filelist rd /S /Q filelist
+if exist *.sh del *.sh
+if exist *.pl del *.pl
+if exist *.txt del *.txt
popd
-pushd centos\x86
-SET COMPONENT=CentOS Build 32-bit
-echo [clean]: MapGuide CentOS build 32-bit
+pushd centos6\x86
+SET COMPONENT=CentOS 6 Build 32-bit
+popd
+pushd ubuntu12\x64
+SET COMPONENT=Ubuntu 12 Build 64-bit
popd
-pushd ubuntu\x64
-SET COMPONENT=Ubuntu Build 64-bit
-echo [clean]: MapGuide Ubuntu build 64-bit
+pushd ubuntu14\x64
+SET COMPONENT=Ubuntu 14 Build 64-bit
+popd
+pushd centos6\x64
+SET COMPONENT=CentOS 6 Build 64-bit
-popd
-pushd centos\x64
-SET COMPONENT=CentOS Build 64-bit
-echo [clean]: MapGuide CentOS build 64-bit
-call vagrant destroy -f
popd
goto quit
:error
Modified: branches/3.0/vagrant/scripts/mginstallubuntu.sh
--- branches/3.0/vagrant/scripts/mginstallubuntu.sh 2017-04-22 16:18:41 UTC (rev 9169)
+++ branches/3.0/vagrant/scripts/mginstallubuntu.sh 2017-04-22 16:25:33 UTC (rev 9170)
@@ -1,5 +1,10 @@
-#!/bin/bash
-TEMPDIR=/tmp/build_mapguide
+#!/bin/sh
+# Set safe shell defaults
+set -euf
+HEADLESS=0
+TEMPDIR=/tmp/install_mapguide
URL_HOST="http://download.osgeo.org"
URL_RELPATH="/mapguide/releases"
FDOVER_MAJOR=0
@@ -49,7 +54,7 @@
fdo_provider_choice=""
# Must have root
-if [[ $EUID -ne 0 ]]; then
+if ! [ "$(id -u)" = "0" ]; then
echo "You must run this script with superuser privileges"
exit 1
fi
@@ -57,9 +62,20 @@
while [ $# -gt 0 ]; do # Until you run out of parameters...
case "$1" in
-headless|--headless)
- HEADLESS=1
- #shift
+ HEADLESS=1
+ -no-service-install|--no-service-install)
+ NO_SERVICE_INSTALL=1
+ -no-mgserver-start|--no-mgserver-start)
+ NO_MGSERVER_START=1
+ -no-tomcat-start|--no-tomcat-start)
+ NO_TOMCAT_START=1
+ -no-httpd-start|--no-httpd-start)
+ NO_HTTPD_START=1
-with-sdf|--with-sdf)
fdo_provider_choice="$fdo_provider_choice sdf"
#shift
@@ -141,13 +157,14 @@
shift # Check next set of parameters.
done
+echo "[install]: Installing pre-requisite packages"
if [ "$HEADLESS" != "1" ]
then
-# Install required packages
-apt-get -y install dialog libexpat1 libssl1.0.0 odbcinst unixodbc libcurl3 libxslt1.1
+# Install required packages
+apt-get -y -q install openjdk-7-jre libxml2 dialog libexpat1 libssl1.0.0 odbcinst unixodbc libcurl3 libxslt1.1 libmysqlclient18 libpq5
else
-apt-get -y install libexpat1 libssl1.0.0 odbcinst unixodbc libcurl3 libxslt1.1
+apt-get -y -q install openjdk-7-jre libxml2 libexpat1 libssl1.0.0 odbcinst unixodbc libcurl3 libxslt1.1 libmysqlclient18 libpq5
fi
DIALOG=${DIALOG=dialog}
@@ -161,9 +178,8 @@
dialog_server
dialog_webtier
#dialog_coordsys
- else
- dump_configuration
fi
+ dump_configuration
install_fdo
install_mapguide_packages
post_install
@@ -171,19 +187,21 @@
set_server_vars()
- set -- $(<$1)
- server_ip=$1
- admin_port=$2
- client_port=$3
- site_port=$4
+ vars=$(cat $1)
+ set $vars
+ server_ip=${1:-$DEFAULT_SERVER_IP}
+ admin_port=${2:-$DEFAULT_ADMIN_PORT}
+ client_port=${3:-$DEFAULT_CLIENT_PORT}
+ site_port=${4:-$DEFAULT_SITE_PORT}
set_webtier_vars()
- set -- $(<$1)
- webtier_server_ip=$1
- httpd_port=$2
- tomcat_port=$3
+ vars=$(cat $1)
+ set $vars
+ webtier_server_ip=${1:-$DEFAULT_SERVER_IP}
+ httpd_port=${2:-$DEFAULT_HTTPD_PORT}
+ tomcat_port=${3:-$DEFAULT_TOMCAT_PORT}
dump_configuration()
@@ -228,8 +246,8 @@
dialog_fdo_provider()
- tempfile=`tempfile 2>/dev/null` || tempfile=/tmp/test$$
- trap "rm -f $tempfile" 0 1 2 5 15
+ tempfile=$(mktemp 2>/dev/null) || tempfile=/tmp/test$$
+ trap 'rm -f $tempfile' 0 1 2 5 15
#arcsde "OSGeo FDO Provider for ArcSDE" off \
# Disable RDBMS provider selection by default
@@ -246,7 +264,7 @@
wfs "OSGeo FDO Provider for WFS" ON \
wms "OSGeo FDO Provider for WMS" ON 2> $tempfile
- fdo_provider_choice=`cat $tempfile | sed s/\"//g`
+ fdo_provider_choice=$(cat $tempfile | sed s/\"//g)
case $? in
1)
echo "Cancelled"
@@ -259,12 +277,13 @@
dialog_server()
+ tempfile=$(mktemp 2>/dev/null) || tempfile=/tmp/form.$$
dialog --backtitle "$INSTALLER_TITLE" --title "Server Configuration" \
--form "\nSet the port numbers that the MapGuide Server will listen on" 25 60 16 \
"Server IP:" 1 1 "${DEFAULT_SERVER_IP}" 1 25 25 30 \
"Admin Port:" 2 1 "${DEFAULT_ADMIN_PORT}" 2 25 25 30 \
"Client Port:" 3 1 "${DEFAULT_CLIENT_PORT}" 3 25 25 30 \
- "Site Port:" 4 1 "${DEFAULT_SITE_PORT}" 4 25 25 30 2>/tmp/form.$$
+ "Site Port:" 4 1 "${DEFAULT_SITE_PORT}" 4 25 25 30 2> $tempfile
case $? in
1)
echo "Cancelled"
@@ -273,17 +292,18 @@
echo "Cancelled"
exit 255;;
esac
- set_server_vars "/tmp/form.$$"
- rm /tmp/form.$$
+ set_server_vars $tempfile
+ rm $tempfile
dialog_webtier()
dialog --backtitle "$INSTALLER_TITLE" --title "Web Tier Configuration" \
--form "\nSet the port numbers that Apache/Tomcat will listen on" 25 60 16 \
"Connect to Server IP:" 1 1 "${DEFAULT_SERVER_IP}" 1 25 25 30 \
"Apache Port:" 2 1 "${DEFAULT_HTTPD_PORT}" 2 25 25 30 \
- "Tomcat Port:" 3 1 "${DEFAULT_TOMCAT_PORT}" 3 25 25 30 2>/tmp/form.$$
+ "Tomcat Port:" 3 1 "${DEFAULT_TOMCAT_PORT}" 3 25 25 30 2> $tempfile
case $? in
1)
echo "Cancelled"
@@ -292,21 +312,21 @@
echo "Cancelled"
exit 255;;
esac
- set_webtier_vars "/tmp/form.$$"
- rm /tmp/form.$$
+ set_webtier_vars $tempfile
+ rm $tempfile
dialog_coordsys()
dialog --backtitle "$INSTALLER_TITLE" \
--title "Coordinate System Configuration" --clear \
--radiolist "Choose the CS-Map profile you want for this MapGuide Installation" 20 80 5 \
"full" "Download/Install the full set of data files" ON \
"lite" "Download/Install the lite configuration (no grid files)" off 2> $tempfile
- csmap_choice=`cat $tempfile`
+ csmap_choice=$(cat $tempfile)
case $? in
1)
echo "Cancelled"
@@ -336,16 +356,15 @@
# Download and install Ubuntu packages for FDO
for file in $fdo_provider_choice
do
- #echo "Downloading ${URL}/fdo-${file}_${FDOVER}.deb"
- wget -N ${URL}/fdo-${file}_${FDOVER}.deb
- #echo "Installing fdo-${file}_${FDOVER}.deb"
- dpkg -E -G --install fdo-${file}_${FDOVER}.deb
+ download_file="${TEMPDIR}/fdo-${file}_${FDOVER}.deb"
+ wget -N -O "${download_file}" "${URL}/fdo-${file}_${FDOVER}.deb"
+ dpkg -E -G --install "${download_file}"
done
# Nuke the old providers.xml, we're rebuiding it
providersxml=/usr/local/fdo-${FDOVER_MAJOR_MINOR_REV}/lib/providers.xml
- echo -ne "<?xml version=\"1.0\" encoding=\"utf-8\" standalone=\"no\" ?>" > ${providersxml}
- echo -ne "\n<FeatureProviderRegistry>" >> ${providersxml}
+ echo "<?xml version=\"1.0\" encoding=\"utf-8\" standalone=\"no\" ?>" > ${providersxml}
+ echo "<FeatureProviderRegistry>" >> ${providersxml}
do
case $file in
@@ -355,15 +374,15 @@
continue
fi
echo "Registering ArcSDE Provider"
- echo -ne "\n <FeatureProvider>" >> ${providersxml}
- echo -ne "\n <Name>OSGeo.ArcSDE.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
- echo -ne "\n <DisplayName>OSGeo FDO Provider for ArcSDE</DisplayName>" >> ${providersxml}
- echo -ne "\n <Description>Read/write access to an ESRI ArcSDE-based data store, using Oracle and SQL Server</Description>" >> ${providersxml}
- echo -ne "\n <IsManaged>False</IsManaged>" >> ${providersxml}
- echo -ne "\n <Version>${FDOVER_MAJOR_MINOR_REV}.0</Version>" >> ${providersxml}
- echo -ne "\n <FeatureDataObjectsVersion>${FDOVER_MAJOR_MINOR_REV}.0</FeatureDataObjectsVersion>" >> ${providersxml}
- echo -ne "\n <LibraryPath>libArcSDEProvider.so</LibraryPath>" >> ${providersxml}
- echo -ne "\n </FeatureProvider>" >> ${providersxml}
+ echo " <FeatureProvider>" >> ${providersxml}
+ echo " <Name>OSGeo.ArcSDE.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+ echo " <DisplayName>OSGeo FDO Provider for ArcSDE</DisplayName>" >> ${providersxml}
+ echo " <Description>Read/write access to an ESRI ArcSDE-based data store, using Oracle and SQL Server</Description>" >> ${providersxml}
+ echo " <IsManaged>False</IsManaged>" >> ${providersxml}
+ echo " <Version>${FDOVER_MAJOR_MINOR_REV}.0</Version>" >> ${providersxml}
+ echo " <FeatureDataObjectsVersion>${FDOVER_MAJOR_MINOR_REV}.0</FeatureDataObjectsVersion>" >> ${providersxml}
+ echo " <LibraryPath>libArcSDEProvider.so</LibraryPath>" >> ${providersxml}
+ echo " </FeatureProvider>" >> ${providersxml}
arcsde_registered=1
gdal)
@@ -372,15 +391,15 @@
continue
fi
echo "Registering GDAL Provider"
- echo -ne "\n <Name>OSGeo.Gdal.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
- echo -ne "\n <DisplayName>OSGeo FDO Provider for GDAL</DisplayName>" >> ${providersxml}
- echo -ne "\n <Description>FDO Provider for GDAL</Description>" >> ${providersxml}
- echo -ne "\n <LibraryPath>libGRFPProvider.so</LibraryPath>" >> ${providersxml}
+ echo " <Name>OSGeo.Gdal.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+ echo " <DisplayName>OSGeo FDO Provider for GDAL</DisplayName>" >> ${providersxml}
+ echo " <Description>FDO Provider for GDAL</Description>" >> ${providersxml}
+ echo " <LibraryPath>libGRFPProvider.so</LibraryPath>" >> ${providersxml}
gdal_registered=1
kingoracle)
@@ -389,15 +408,15 @@
continue
fi
echo "Registering King Oracle Provider"
- echo -ne "\n <Name>OSGeo.KingOracle.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
- echo -ne "\n <DisplayName>OSGeo FDO Provider for Oracle</DisplayName>" >> ${providersxml}
- echo -ne "\n <Description>Read/write access to spatial and attribute data in Oracle Spatial</Description>" >> ${providersxml}
- echo -ne "\n <LibraryPath>libKingOracleProvider.so</LibraryPath>" >> ${providersxml}
+ echo " <Name>OSGeo.KingOracle.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+ echo " <DisplayName>OSGeo FDO Provider for Oracle</DisplayName>" >> ${providersxml}
+ echo " <Description>Read/write access to spatial and attribute data in Oracle Spatial</Description>" >> ${providersxml}
+ echo " <LibraryPath>libKingOracleProvider.so</LibraryPath>" >> ${providersxml}
kingoracle_registered=1
rdbms)
@@ -406,35 +425,35 @@
continue
fi
echo "Registering ODBC Provider"
- echo -ne "\n <Name>OSGeo.ODBC.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
- echo -ne "\n <DisplayName>OSGeo FDO Provider for ODBC</DisplayName>" >> ${providersxml}
- echo -ne "\n <Description>FDO Provider for ODBC</Description>" >> ${providersxml}
- echo -ne "\n <LibraryPath>libFdoODBC.so</LibraryPath>" >> ${providersxml}
+ echo " <Name>OSGeo.ODBC.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+ echo " <DisplayName>OSGeo FDO Provider for ODBC</DisplayName>" >> ${providersxml}
+ echo " <Description>FDO Provider for ODBC</Description>" >> ${providersxml}
+ echo " <LibraryPath>libFdoODBC.so</LibraryPath>" >> ${providersxml}
echo "Registering PostgreSQL Provider"
- echo -ne "\n <Name>OSGeo.PostgreSQL.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
- echo -ne "\n <DisplayName>OSGeo FDO Provider for PostgreSQL</DisplayName>" >> ${providersxml}
- echo -ne "\n <Description>Read/write access to PostgreSQL/PostGIS-based data store. Supports spatial data types and spatial query operations</Description>" >> ${providersxml}
- echo -ne "\n <LibraryPath>libFdoPostgreSQL.so</LibraryPath>" >> ${providersxml}
+ echo " <Name>OSGeo.PostgreSQL.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+ echo " <DisplayName>OSGeo FDO Provider for PostgreSQL</DisplayName>" >> ${providersxml}
+ echo " <Description>Read/write access to PostgreSQL/PostGIS-based data store. Supports spatial data types and spatial query operations</Description>" >> ${providersxml}
+ echo " <LibraryPath>libFdoPostgreSQL.so</LibraryPath>" >> ${providersxml}
echo "Registering MySQL Provider"
- echo -ne "\n <Name>OSGeo.MySQL.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
- echo -ne "\n <DisplayName>OSGeo FDO Provider for MySQL</DisplayName>" >> ${providersxml}
- echo -ne "\n <Description>FDO Provider for MySQL</Description>" >> ${providersxml}
- echo -ne "\n <LibraryPath>libFdoMySQL.so</LibraryPath>" >> ${providersxml}
+ echo " <Name>OSGeo.MySQL.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+ echo " <DisplayName>OSGeo FDO Provider for MySQL</DisplayName>" >> ${providersxml}
+ echo " <Description>FDO Provider for MySQL</Description>" >> ${providersxml}
+ echo " <LibraryPath>libFdoMySQL.so</LibraryPath>" >> ${providersxml}
rdbms_registered=1
ogr)
@@ -443,15 +462,15 @@
continue
fi
echo "Registering OGR Provider"
- echo -ne "\n <Name>OSGeo.OGR.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
- echo -ne "\n <DisplayName>OSGeo FDO Provider for OGR</DisplayName>" >> ${providersxml}
- echo -ne "\n <Description>FDO Access to OGR Data Sources</Description>" >> ${providersxml}
- echo -ne "\n <LibraryPath>libOGRProvider.so</LibraryPath>" >> ${providersxml}
+ echo " <Name>OSGeo.OGR.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+ echo " <DisplayName>OSGeo FDO Provider for OGR</DisplayName>" >> ${providersxml}
+ echo " <Description>FDO Access to OGR Data Sources</Description>" >> ${providersxml}
+ echo " <LibraryPath>libOGRProvider.so</LibraryPath>" >> ${providersxml}
ogr_registered=1
sdf)
@@ -460,15 +479,15 @@
continue
fi
echo "Registering SDF Provider"
- echo -ne "\n <Name>OSGeo.SDF.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
- echo -ne "\n <DisplayName>OSGeo FDO Provider for SDF</DisplayName>" >> ${providersxml}
- echo -ne "\n <Description>Read/write access to Autodesk's spatial database format, a file-based geodatabase that supports multiple features/attributes, spatial indexing and file-locking</Description>" >> ${providersxml}
- echo -ne "\n <LibraryPath>libSDFProvider.so</LibraryPath>" >> ${providersxml}
+ echo " <Name>OSGeo.SDF.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+ echo " <DisplayName>OSGeo FDO Provider for SDF</DisplayName>" >> ${providersxml}
+ echo " <Description>Read/write access to Autodesk's spatial database format, a file-based geodatabase that supports multiple features/attributes, spatial indexing and file-locking</Description>" >> ${providersxml}
+ echo " <LibraryPath>libSDFProvider.so</LibraryPath>" >> ${providersxml}
sdf_registered=1
shp)
@@ -477,15 +496,15 @@
continue
fi
echo "Registering SHP Provider"
- echo -ne "\n <Name>OSGeo.SHP.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
- echo -ne "\n <DisplayName>OSGeo FDO Provider for SHP</DisplayName>" >> ${providersxml}
- echo -ne "\n <Description>Read/write access to spatial and attribute data in an ESRI SHP file</Description>" >> ${providersxml}
- echo -ne "\n <LibraryPath>libSHPProvider.so</LibraryPath>" >> ${providersxml}
+ echo " <Name>OSGeo.SHP.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+ echo " <DisplayName>OSGeo FDO Provider for SHP</DisplayName>" >> ${providersxml}
+ echo " <Description>Read/write access to spatial and attribute data in an ESRI SHP file</Description>" >> ${providersxml}
+ echo " <LibraryPath>libSHPProvider.so</LibraryPath>" >> ${providersxml}
shp_registered=1
sqlite)
@@ -494,15 +513,15 @@
continue
fi
echo "Registering SQLite Provider"
- echo -ne "\n <Name>OSGeo.SQLite.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
- echo -ne "\n <DisplayName>OSGeo FDO Provider for SQLite</DisplayName>" >> ${providersxml}
- echo -ne "\n <Description>Read/write access to feature data in a SQLite file</Description>" >> ${providersxml}
- echo -ne "\n <LibraryPath>libSQLiteProvider.so</LibraryPath>" >> ${providersxml}
+ echo " <Name>OSGeo.SQLite.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+ echo " <DisplayName>OSGeo FDO Provider for SQLite</DisplayName>" >> ${providersxml}
+ echo " <Description>Read/write access to feature data in a SQLite file</Description>" >> ${providersxml}
+ echo " <LibraryPath>libSQLiteProvider.so</LibraryPath>" >> ${providersxml}
sqlite_registered=1
wfs)
@@ -511,15 +530,15 @@
continue
fi
echo "Registering WFS Provider"
- echo -ne "\n <Name>OSGeo.WFS.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
- echo -ne "\n <DisplayName>OSGeo FDO Provider for WFS</DisplayName>" >> ${providersxml}
- echo -ne "\n <Description>Read access to OGC WFS-based data store</Description>" >> ${providersxml}
- echo -ne "\n <LibraryPath>libWFSProvider.so</LibraryPath>" >> ${providersxml}
+ echo " <Name>OSGeo.WFS.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+ echo " <DisplayName>OSGeo FDO Provider for WFS</DisplayName>" >> ${providersxml}
+ echo " <Description>Read access to OGC WFS-based data store</Description>" >> ${providersxml}
+ echo " <LibraryPath>libWFSProvider.so</LibraryPath>" >> ${providersxml}
wfs_registered=1
wms)
@@ -528,35 +547,34 @@
continue
fi
echo "Registering WMS Provider"
- echo -ne "\n <Name>OSGeo.WMS.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
- echo -ne "\n <DisplayName>OSGeo FDO Provider for WMS</DisplayName>" >> ${providersxml}
- echo -ne "\n <Description>Read access to OGC WMS-based data store</Description>" >> ${providersxml}
- echo -ne "\n <LibraryPath>libWMSProvider.so</LibraryPath>" >> ${providersxml}
+ echo " <Name>OSGeo.WMS.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+ echo " <DisplayName>OSGeo FDO Provider for WMS</DisplayName>" >> ${providersxml}
+ echo " <Description>Read access to OGC WMS-based data store</Description>" >> ${providersxml}
+ echo " <LibraryPath>libWMSProvider.so</LibraryPath>" >> ${providersxml}
wms_registered=1
esac
done
- echo -ne "\n</FeatureProviderRegistry>" >> ${providersxml}
+ echo "</FeatureProviderRegistry>" >> ${providersxml}
install_mapguide_packages()
# Download Ubuntu packages for MapGuide
mapguide_packages="platformbase coordsys common server webextensions httpd"
- if [ $csmap_choice = "lite" ]; then
+ if [ "$csmap_choice" = "lite" ]; then
mapguide_packages="platformbase coordsys-lite common server webextensions httpd"
fi
for file in $mapguide_packages
do
- echo "[download]: ${URL}/mapguideopensource-${file}_${MGVER}.deb"
- wget -N ${URL}/mapguideopensource-${file}_${MGVER}.deb
- echo "[install]: mapguideopensource-${file}_${MGVER}.deb"
- dpkg -E -G --install mapguideopensource-${file}_${MGVER}.deb
+ download_file="${TEMPDIR}/mapguideopensource-${file}_${MGVER}.deb"
+ wget -N -O "${download_file}" "${URL}/mapguideopensource-${file}_${MGVER}.deb"
done
@@ -582,25 +600,52 @@
echo "[config]: Fixing permissions for certain folders"
chmod 777 /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/webserverextensions/www/TempDir
- echo "[config]: Registering Services"
- ln -s /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/server/bin/mapguidectl /etc/init.d/mapguide
- ln -s /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/webserverextensions/apache2/bin/apachectl /etc/init.d/apache-mapguide
- update-rc.d mapguide defaults 35 65
- update-rc.d apache-mapguide defaults 30 70
+ if [ "$HEADLESS" = "1" ] && [ "$NO_SERVICE_INSTALL" = "1" ];
+ then
+ echo "[config]: Skipping service registration as --headless and --no-service-install specified"
+ else
+ echo "[config]: Registering Services"
+ ln -s /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/server/bin/mapguidectl /etc/init.d/mapguide
+ ln -s /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/webserverextensions/apache2/bin/apachectl /etc/init.d/apache-mapguide
+ update-rc.d mapguide defaults 35 65
+ update-rc.d apache-mapguide defaults 30 70
+ fi
- echo "[install]: Starting httpd"
- /etc/init.d/apache-mapguide start
- echo "[install]: Starting tomcat"
- pushd /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/webserverextensions/tomcat/bin
- sh ./startup.sh
- popd
- echo "[install]: Starting mgserver"
- /etc/init.d/mapguide start
+ if [ "$HEADLESS" = "1" ] && [ "$NO_HTTPD_START" = "1" ];
+ then
+ echo "[install]: Skipping httpd auto-start as --headless and --no-httpd-start specified"
+ else
+ if [ -e "/etc/init.d/apache-mapguide" ];
+ then
+ echo "[install]: Starting httpd"
+ /etc/init.d/apache-mapguide start
+ else
+ echo "[install]: WARNING - apache-mapguide service entry not found"
+ fi
+ fi
+ if [ "$HEADLESS" = "1" ] && [ "$NO_MGSERVER_START" = "1" ];
+ then
+ echo "[install]: Skipping mgserver auto-start as --headless and --no-mgserver-start specified"
+ else
+ if [ -e "/etc/init.d/mapguide" ];
+ then
+ echo "[install]: Starting mgserver"
+ /etc/init.d/mapguide start
+ else
+ echo "[install]: WARNING - mgserver service entry not found"
+ fi
+ fi
+ if [ "$HEADLESS" = "1" ] && [ "$NO_TOMCAT_START" = "1" ];
+ then
+ echo "[install]: Skipping tomcat auto-start as --headless and --no-tomcat-start specified"
+ else
+ echo "[install]: Starting tomcat"
+ # This can be allowed to fail
+ sh /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/webserverextensions/tomcat/bin/startup.sh || true
+ fi
echo "DONE!"
# Create temporary download directory
mkdir -p ${TEMPDIR}
-pushd ${TEMPDIR}
main
-popd
Modified: branches/3.0/vagrant/scripts/provision_ubuntu.sh
--- branches/3.0/vagrant/scripts/provision_ubuntu.sh 2017-04-22 16:18:41 UTC (rev 9169)
+++ branches/3.0/vagrant/scripts/provision_ubuntu.sh 2017-04-22 16:25:33 UTC (rev 9170)
@@ -395,7 +395,7 @@
echo [provision]: Stamping install script
sudo cp $MOUNT_DIR/mginstallubuntu.sh $MOUNT_DIR/build/mginstallubuntu.sh
sudo cp $MOUNT_DIR/mguninstallubuntu.sh $MOUNT_DIR/build/mguninstallubuntu.sh
-sudo sed -i 's/URL_PART="ubuntu12"/URL_PART='"$DISTNAME"'/g' $MOUNT_DIR/build/mginstallubuntu.sh
+sudo sed -i 's/URL_PART="ubuntu"/URL_PART='"$DISTNAME"'/g' $MOUNT_DIR/build/mginstallubuntu.sh
sudo sed -i 's/MGRELEASELABEL="ReleaseLabel"/MGRELEASELABEL='"$MG_RELEASE_LABEL"'/g' $MOUNT_DIR/build/mginstallubuntu.sh
sudo sed -i 's/FDOARCH=i386/FDOARCH='"$MG_ARCH"'/g' $MOUNT_DIR/build/mginstallubuntu.sh
sudo sed -i 's/MGARCH=i386/MGARCH='"$MG_ARCH"'/g' $MOUNT_DIR/build/mginstallubuntu.sh
Modified: branches/3.0/vagrant/ubuntu12/x64/Vagrantfile
--- branches/3.0/vagrant/ubuntu12/x64/Vagrantfile 2017-04-22 16:18:41 UTC (rev 9169)
+++ branches/3.0/vagrant/ubuntu12/x64/Vagrantfile 2017-04-22 16:25:33 UTC (rev 9170)
privileged: false,
- path: "provision_ubuntu.sh",
+ path: "../../scripts/provision_ubuntu.sh",
args: [4, 0, 0, 3, 0, 1, "4.0", "3.0", "amd64", "Final", "ubuntu12", 1, 1]
end
Modified: branches/3.0/vagrant/ubuntu12/x86/Vagrantfile
--- branches/3.0/vagrant/ubuntu12/x86/Vagrantfile 2017-04-22 16:18:41 UTC (rev 9169)
+++ branches/3.0/vagrant/ubuntu12/x86/Vagrantfile 2017-04-22 16:25:33 UTC (rev 9170)
privileged: false,
args: [4, 0, 0, 3, 0, 1, "4.0", "3.0", "i386", "Final", "ubuntu12", 1, 1]
end
Modified: branches/3.0/vagrant/ubuntu14/x64/Vagrantfile
--- branches/3.0/vagrant/ubuntu14/x64/Vagrantfile 2017-04-22 16:18:41 UTC (rev 9169)
+++ branches/3.0/vagrant/ubuntu14/x64/Vagrantfile 2017-04-22 16:25:33 UTC (rev 9170)
privileged: false,
args: [4, 0, 0, 3, 0, 1, "4.0", "3.0", "amd64", "Final", "ubuntu14", 1, 1]
end
Modified: branches/3.0/vagrant/ubuntu14/x86/Vagrantfile
--- branches/3.0/vagrant/ubuntu14/x86/Vagrantfile 2017-04-22 16:18:41 UTC (rev 9169)
+++ branches/3.0/vagrant/ubuntu14/x86/Vagrantfile 2017-04-22 16:25:33 UTC (rev 9170)
privileged: false,
args: [4, 0, 0, 3, 0, 1, "4.0", "3.0", "i386", "Final", "ubuntu14", 1, 1]
end
More information about the mapguide-commits
