[mapguide-commits] r9173 -	sandbox/jng/clean_json/Web/src/HttpHandler
    svn_mapguide at osgeo.org
    Sat Apr 22 22:41:50 PDT 2017
Author: jng
Date: 2017-04-22 22:41:50 -0700 (Sat, 22 Apr 2017)
New Revision: 9173
   sandbox/jng/clean_json/Web/src/HttpHandler/XmlJsonConvert.cpp
   sandbox/jng/clean_json/Web/src/HttpHandler/XmlJsonConvert.h
Fix linux build
Modified: sandbox/jng/clean_json/Web/src/HttpHandler/XmlJsonConvert.cpp
--- sandbox/jng/clean_json/Web/src/HttpHandler/XmlJsonConvert.cpp	2017-04-22 16:55:27 UTC (rev 9172)
+++ sandbox/jng/clean_json/Web/src/HttpHandler/XmlJsonConvert.cpp	2017-04-23 05:41:50 UTC (rev 9173)
@@ -405,7 +405,9 @@
             XMLSize_t childNodeCount = childNodes->getLength();
             if (childNodeCount == 0)
-                m_jsonDoc.SetArrayValue(index, NULL);
+                // Write the node as a zero array element
+                m_jsonDoc.BeginArrayObject(index);
+                m_jsonDoc.EndArrayObject();
                 return;
             else if (childNodeCount == 1)
@@ -477,8 +479,13 @@
     if (NULL != attribute)
         STRING elPath = L"/@";
-        elPath += attribute->getNodeName();
-        elPath += suffix;
+        elPath += X2W(attribute->getNodeName());
+        if (NULL != suffix)
+            STRING ws;
+            ws = X2W(suffix);
+            elPath += ws;
         DOMNode* currentNode = parent;
         while (NULL != currentNode)
@@ -486,7 +493,7 @@
             if (nt == DOMNode::ELEMENT_NODE)
                 STRING pathPart = L"/";
-                pathPart += currentNode->getNodeName();
+                pathPart += X2W(currentNode->getNodeName());
                 elPath = pathPart + elPath;
                 currentNode = currentNode->getParentNode();
                 if (NULL == currentNode)
@@ -512,8 +519,13 @@
             elPath += L"@";
-        elPath += node->getNodeName();
-        elPath += suffix;
+        elPath += X2W(node->getNodeName());
+            STRING ws;
+            ws = X2W(suffix);
+            elPath += ws;
         DOMNode* currentNode = node->getParentNode();
@@ -521,7 +533,7 @@
@@ -541,7 +553,7 @@
 bool MgXmlJsonConvert::GetAttributeType(DOMNode * attribute, DOMNode * parent, int & type, const XMLCh * suffix)
     string path;
-    if (GetAttributePath(attribute, parent, path))
+    if (GetAttributePath(attribute, parent, path, suffix))
         if (s_elementPathTypeMap.find(path) != s_elementPathTypeMap.end())
@@ -556,7 +568,7 @@
 bool MgXmlJsonConvert::GetElementType(DOMNode * node, int & type, const XMLCh * suffix)
     string path;
-    if (GetElementPath(node, path))
+    if (GetElementPath(node, path, suffix))
Modified: sandbox/jng/clean_json/Web/src/HttpHandler/XmlJsonConvert.h
--- sandbox/jng/clean_json/Web/src/HttpHandler/XmlJsonConvert.h	2017-04-22 16:55:27 UTC (rev 9172)
+++ sandbox/jng/clean_json/Web/src/HttpHandler/XmlJsonConvert.h	2017-04-23 05:41:50 UTC (rev 9173)
@@ -50,12 +50,12 @@
     void ProcessObjectNode(DOMNode *node, bool bClean);
     void ProcessArrayNode(int index, DOMNode *node, bool bClean);
-    static bool GetAttributePath(DOMNode* attribute, DOMNode* parent, string& path, const XMLCh* suffix = L"");
-    static bool GetAttributeType(DOMNode* attribute, DOMNode* parent, int& type, const XMLCh* suffix = L"");
+    static bool GetAttributePath(DOMNode* attribute, DOMNode* parent, string& path, const XMLCh* suffix = NULL);
+    static bool GetAttributeType(DOMNode* attribute, DOMNode* parent, int& type, const XMLCh* suffix = NULL);
-    static bool GetElementPath(DOMNode* node, string& path, const XMLCh* suffix = L"");
-    static bool GetElementType(DOMNode* node, int& type, const XMLCh* suffix = L"");
-    static bool IsMultiple(DOMNode* node, bool& isMultiple, const XMLCh* suffix = L"");
+    static bool GetElementPath(DOMNode* node, string& path, const XMLCh* suffix = NULL);
+    static bool GetElementType(DOMNode* node, int& type, const XMLCh* suffix = NULL);
+    static bool IsMultiple(DOMNode* node, bool& isMultiple, const XMLCh* suffix = NULL);
     /// Data Members
 private:
     MgXmlUtil m_xmlUtil;
More information about the mapguide-commits
