[mapguide-commits] r9264 - in sandbox/jng/cmake_v2: . Common Common/Geometry Common/MapGuideCommon Oem Oem/CsMapLibrary Oem/geos Oem/geos/tools cmake/modules
svn_mapguide at osgeo.org
Mon Dec 25 07:19:09 PST 2017
Author: jng
Date: 2017-12-25 07:19:09 -0800 (Mon, 25 Dec 2017)
New Revision: 9264
Added:
sandbox/jng/cmake_v2/Oem/CsMapLibrary/
sandbox/jng/cmake_v2/Oem/CsMapLibrary/CMakeLists.txt
sandbox/jng/cmake_v2/Oem/CsMapLibrary/README.txt
sandbox/jng/cmake_v2/Oem/geos/tools/geos_svn_revision_cmake.h.in
sandbox/jng/cmake_v2/CMakeLists.txt
sandbox/jng/cmake_v2/Common/CMakeLists.txt
sandbox/jng/cmake_v2/Common/Geometry/CMakeLists.txt
sandbox/jng/cmake_v2/Common/MapGuideCommon/CMakeLists.txt
sandbox/jng/cmake_v2/Oem/CMakeLists.txt
sandbox/jng/cmake_v2/Oem/geos/geos_svn_revision.h
sandbox/jng/cmake_v2/cmake/modules/FindGD.cmake
sandbox/jng/cmake_v2/cmake/modules/FindGEOS.cmake
CMake-ify CS-Map and the rest of Common. All of Common can now be built with CMake
Modified: sandbox/jng/cmake_v2/CMakeLists.txt
--- sandbox/jng/cmake_v2/CMakeLists.txt 2017-12-25 14:50:51 UTC (rev 9263)
+++ sandbox/jng/cmake_v2/CMakeLists.txt 2017-12-25 15:19:09 UTC (rev 9264)
@@ -23,6 +23,7 @@
set(MG_VERSION_RELEASE 0)
set(MG_VERSION "${MG_VERSION_MAJOR}.${MG_VERSION_MINOR}.${MG_VERSION_RELEASE}")
+set(MG_OEM_CSMAP_INCLUDE_DIR "${CMAKE_CURRENT_SOURCE_DIR}/Oem/CsMap/Include")
set(MG_OEM_AGG_DIR "${CMAKE_CURRENT_SOURCE_DIR}/Oem/agg-2.4")
set(MG_OEM_AGG_INCLUDE_DIR "${MG_OEM_AGG_DIR}/include")
set(MG_OEM_AGG_FREETYPE_DIR "${MG_OEM_AGG_DIR}/font_freetype")
Modified: sandbox/jng/cmake_v2/Common/CMakeLists.txt
--- sandbox/jng/cmake_v2/Common/CMakeLists.txt 2017-12-25 14:50:51 UTC (rev 9263)
+++ sandbox/jng/cmake_v2/Common/CMakeLists.txt 2017-12-25 15:19:09 UTC (rev 9264)
@@ -10,11 +10,11 @@
add_definitions( -DACE_HAS_THREAD_SAFE_ACCEPT )
add_subdirectory(Foundation)
-#add_subdirectory(Geometry)
-#add_subdirectory(MapGuideCommon)
+add_subdirectory(Geometry)
+add_subdirectory(MapGuideCommon)
add_subdirectory(MdfModel)
add_subdirectory(MdfParser)
-#add_subdirectory(PlatformBase)
+add_subdirectory(PlatformBase)
add_subdirectory(Renderers)
add_subdirectory(Security)
add_subdirectory(Stylization)
Modified: sandbox/jng/cmake_v2/Common/Geometry/CMakeLists.txt
--- sandbox/jng/cmake_v2/Common/Geometry/CMakeLists.txt 2017-12-25 14:50:51 UTC (rev 9263)
+++ sandbox/jng/cmake_v2/Common/Geometry/CMakeLists.txt 2017-12-25 15:19:09 UTC (rev 9264)
@@ -1,6 +1,14 @@
project(geometry)
-set (MgGeometry_LIBRARY MgGeometry-${MG_VERSION})
+include_directories(${ACE_INCLUDE_DIR}
+ ${GEOS_INCLUDE_DIR}
+ ${MG_OEM_CSMAP_INCLUDE_DIR}
+ ${CMAKE_CURRENT_SOURCE_DIR}/../CoordinateSystem
+ ${CMAKE_CURRENT_SOURCE_DIR}/../Security
+ ${CMAKE_CURRENT_SOURCE_DIR}/../MdfPaser
+ ${CMAKE_CURRENT_SOURCE_DIR}/../MdfModel
+ ${CMAKE_CURRENT_SOURCE_DIR}/../Foundation
+ ${CMAKE_CURRENT_SOURCE_DIR}/../Geometry)
set (MgGeometry_SRCS
GeometryBuild.cpp
@@ -55,12 +63,14 @@
../CoordinateSystem/SmartCriticalClass.cpp
-add_library(${MgGeometry_LIBRARY} SHARED ${MgGeometry_SRCS})
+add_library(MgGeometry-${MG_VERSION} SHARED ${MgGeometry_SRCS})
-target_link_libraries(${MgGeometry_LIBRARY}
- ${MgFoundation_LIBRARY}
+target_link_libraries(MgGeometry-${MG_VERSION}
+ MgFoundation-${MG_VERSION}
+ CsMap
${ACE_LIBRARY}
${GEOS_LIBRARY}
+ pthread
#install( TARGETS ${MgGeometry_LIBRARY} DESTINATION ${LIB_INSTALL_DIR} )
\ No newline at end of file
Modified: sandbox/jng/cmake_v2/Common/MapGuideCommon/CMakeLists.txt
--- sandbox/jng/cmake_v2/Common/MapGuideCommon/CMakeLists.txt 2017-12-25 14:50:51 UTC (rev 9263)
+++ sandbox/jng/cmake_v2/Common/MapGuideCommon/CMakeLists.txt 2017-12-25 15:19:09 UTC (rev 9264)
@@ -2,6 +2,7 @@
${XERCESC_INCLUDE_DIR}
${CMAKE_CURRENT_SOURCE_DIR}/../PlatformBase
Modified: sandbox/jng/cmake_v2/Oem/CMakeLists.txt
--- sandbox/jng/cmake_v2/Oem/CMakeLists.txt 2017-12-25 14:50:51 UTC (rev 9263)
+++ sandbox/jng/cmake_v2/Oem/CMakeLists.txt 2017-12-25 15:19:09 UTC (rev 9264)
@@ -1 +1,8 @@
-add_subdirectory(DWFTK)
+#TODO: We have geos in-tree, which is CMake-enabled, so if required we can use
+#the internal copy of geos if required through an option like INTERNAL_GEOS
+#at the moment, we are just using the system-provided version of GEOS
+#set(GEOS_ENABLE_TESTS OFF)
+#add_subdirectory(geos)
+add_subdirectory(DWFTK)
+add_subdirectory(CsMapLibrary)
Added: sandbox/jng/cmake_v2/Oem/CsMapLibrary/CMakeLists.txt
--- sandbox/jng/cmake_v2/Oem/CsMapLibrary/CMakeLists.txt (rev 0)
+++ sandbox/jng/cmake_v2/Oem/CsMapLibrary/CMakeLists.txt 2017-12-25 15:19:09 UTC (rev 9264)
@@ -0,0 +1,142 @@
+include_directories(${MG_OEM_CSMAP_INCLUDE_DIR})
+add_definitions(-DCSCOMPARE -DCSAPI -DMG)
+set (CsMap_SRCS
+ ../CsMap/Source/CS_alber.c
+ ../CsMap/Source/CS_angle.c
+ ../CsMap/Source/CS_ansi.c
+ ../CsMap/Source/CS_ats77.c
+ ../CsMap/Source/CS_azmea.c
+ ../CsMap/Source/CS_azmed.c
+ ../CsMap/Source/CS_badekas.c
+ ../CsMap/Source/CS_bonne.c
+ ../CsMap/Source/CS_bpcnc.c
+ ../CsMap/Source/CS_bursa.c
+ ../CsMap/Source/CS_bynFile.c
+ ../CsMap/Source/CS_category.c
+ ../CsMap/Source/CS_csini.c
+ ../CsMap/Source/CS_csio.c
+ ../CsMap/Source/CS_csprm.c
+ ../CsMap/Source/CS_csvFileSupport.cpp
+ ../CsMap/Source/CS_csWktLoc.c
+ ../CsMap/Source/CS_ctio.c
+ ../CsMap/Source/CS_datum.c
+ ../CsMap/Source/CS_defaults.c
+ ../CsMap/Source/CS_defCmp.c
+ ../CsMap/Source/CS_defCmpEx.c
+ ../CsMap/Source/CS_dtcalc.c
+ ../CsMap/Source/CS_dtio.c
+ ../CsMap/Source/CS_dtmBridge.c
+ ../CsMap/Source/CS_edcnc.c
+ ../CsMap/Source/CS_edcyl.c
+ ../CsMap/Source/CS_egm96.c
+ ../CsMap/Source/CS_ekrt4.c
+ ../CsMap/Source/CS_ekrt6.c
+ ../CsMap/Source/CS_elCalc.c
+ ../CsMap/Source/CS_elio.c
+ ../CsMap/Source/CS_epsgStuff.cpp
+ ../CsMap/Source/CS_epsgSupport.cpp
+ ../CsMap/Source/CS_erpt.c
+ ../CsMap/Source/CS_error.c
+ ../CsMap/Source/CS_fips.c
+ ../CsMap/Source/CS_frame.c
+ ../CsMap/Source/CS_frnch.c
+ ../CsMap/Source/CS_gauss.c
+ ../CsMap/Source/CS_general.c
+ ../CsMap/Source/CS_geocn.c
+ ../CsMap/Source/CS_geoct.c
+ ../CsMap/Source/CS_geoid96.c
+ ../CsMap/Source/CS_geoid99.c
+ ../CsMap/Source/CS_geoidHeight.c
+ ../CsMap/Source/CS_gissupprt.c
+ ../CsMap/Source/CS_gnomc.c
+ ../CsMap/Source/CS_gpio.c
+ ../CsMap/Source/CS_gridi.c
+ ../CsMap/Source/CS_groups.c
+ ../CsMap/Source/CS_guiApi.c
+ ../CsMap/Source/CS_gxIndex.c
+ ../CsMap/Source/CS_gxio.c
+ ../CsMap/Source/CS_gxprm.c
+ ../CsMap/Source/CS_hlApi.c
+ ../CsMap/Source/CS_hmlsn.c
+ ../CsMap/Source/CS_hpApi.c
+ ../CsMap/Source/CS_japan.c
+ ../CsMap/Source/CS_krovk.c
+ ../CsMap/Source/CS_lmbrt.c
+ ../CsMap/Source/CS_lmtan.c
+ ../CsMap/Source/CS_mgrs.c
+ ../CsMap/Source/CS_millr.c
+ ../CsMap/Source/CS_modpc.c
+ ../CsMap/Source/CS_molod.c
+ ../CsMap/Source/CS_molwd.c
+ ../CsMap/Source/CS_mrcat.c
+ ../CsMap/Source/CS_mstro.c
+ ../CsMap/Source/CS_mulrg.c
+ ../CsMap/Source/CS_nacyl.c
+ ../CsMap/Source/CS_nadcn.c
+ ../CsMap/Source/CS_nameMapper.cpp
+ ../CsMap/Source/CS_nameMapperSupport.cpp
+ ../CsMap/Source/CS_nerth.c
+ ../CsMap/Source/CS_ntv1.c
+ ../CsMap/Source/CS_ntv2.c
+ ../CsMap/Source/CS_nullx.c
+ ../CsMap/Source/CS_nzlnd.c
+ ../CsMap/Source/CS_oblqm.c
+ ../CsMap/Source/CS_optional.c
+ ../CsMap/Source/CS_ortho.c
+ ../CsMap/Source/CS_osgm91.c
+ ../CsMap/Source/CS_ost02.c
+ ../CsMap/Source/CS_ost97.c
+ ../CsMap/Source/CS_ostn02.c
+ ../CsMap/Source/CS_ostn97.c
+ ../CsMap/Source/CS_ostro.c
+ ../CsMap/Source/CS_parm3.c
+ ../CsMap/Source/CS_parm4.c
+ ../CsMap/Source/CS_parm6.c
+ ../CsMap/Source/CS_parm7.c
+ ../CsMap/Source/CS_plycn.c
+ ../CsMap/Source/CS_plynm.c
+ ../CsMap/Source/CS_pstro.c
+ ../CsMap/Source/CS_rlsUpdt.c
+ ../CsMap/Source/CS_robin.c
+ ../CsMap/Source/CS_sinus.c
+ ../CsMap/Source/CS_sstro.c
+ ../CsMap/Source/CS_supprt.c
+ ../CsMap/Source/CS_swiss.c
+ ../CsMap/Source/CS_sys34.c
+ ../CsMap/Source/CS_system.c
+ ../CsMap/Source/CS_tacyl.c
+ ../CsMap/Source/CS_trmer.c
+ ../CsMap/Source/CS_trmrs.c
+ ../CsMap/Source/CS_units.c
+ ../CsMap/Source/CS_unity.c
+ ../CsMap/Source/CS_vdgrn.c
+ ../CsMap/Source/CS_vertconUS.c
+ ../CsMap/Source/CS_vrtcon.c
+ ../CsMap/Source/CS_wellknowntext.cpp
+ ../CsMap/Source/CS_wgs72.c
+ ../CsMap/Source/CS_winkelTripel.c
+ ../CsMap/Source/CS_wktObject.cpp
+ ../CsMap/Source/CS_wktObjKonstants.cpp
+ ../CsMap/Source/CS_zones.c
+ ../CsMap/Source/CScs2Wkt.cpp
+ ../CsMap/Source/CScscomp.c
+ ../CsMap/Source/CSdata.c
+ ../CsMap/Source/CSdataDT.c
+ ../CsMap/Source/CSdataPJ.c
+ ../CsMap/Source/CSdataU.c
+ ../CsMap/Source/CSdatumCatalog.c
+ ../CsMap/Source/CSdictDiff.c
+ ../CsMap/Source/CSdt2Wkt.cpp
+ ../CsMap/Source/CSdtcomp.c
+ ../CsMap/Source/CSel2Wkt.cpp
+ ../CsMap/Source/CSelcomp.c
+ ../CsMap/Source/CSgeodeticSupport.c
+ ../CsMap/Source/CSgpcomp.c
+ ../CsMap/Source/CSgxcomp.c
+ ../CsMap/Source/CSwktFlavors.c
+ ../CsMap/Source/csIoUtil.cpp
+add_library(CsMap STATIC ${CsMap_SRCS})
Added: sandbox/jng/cmake_v2/Oem/CsMapLibrary/README.txt
--- sandbox/jng/cmake_v2/Oem/CsMapLibrary/README.txt (rev 0)
+++ sandbox/jng/cmake_v2/Oem/CsMapLibrary/README.txt 2017-12-25 15:19:09 UTC (rev 9264)
@@ -0,0 +1,3 @@
+This directory contains a CMake build configuration for CS-Map
+It sits in this directory instead of CsMap as that is a SVN external, though in practice we should be upstanding OSS citizens and upstream a proper CMake build configuration in CS-Map itself.
Modified: sandbox/jng/cmake_v2/Oem/geos/geos_svn_revision.h
--- sandbox/jng/cmake_v2/Oem/geos/geos_svn_revision.h 2017-12-25 14:50:51 UTC (rev 9263)
+++ sandbox/jng/cmake_v2/Oem/geos/geos_svn_revision.h 2017-12-25 15:19:09 UTC (rev 9264)
@@ -1 +1 @@
-#define GEOS_SVN_REVISION 3921
+#define GEOS_SVN_REVISION 9261
Added: sandbox/jng/cmake_v2/Oem/geos/tools/geos_svn_revision_cmake.h.in
--- sandbox/jng/cmake_v2/Oem/geos/tools/geos_svn_revision_cmake.h.in (rev 0)
+++ sandbox/jng/cmake_v2/Oem/geos/tools/geos_svn_revision_cmake.h.in 2017-12-25 15:19:09 UTC (rev 9264)
@@ -0,0 +1 @@
+#cmakedefine GEOS_SVN_REVISION @GEOS_SVN_REVISION@
Modified: sandbox/jng/cmake_v2/cmake/modules/FindGD.cmake
--- sandbox/jng/cmake_v2/cmake/modules/FindGD.cmake 2017-12-25 14:50:51 UTC (rev 9263)
+++ sandbox/jng/cmake_v2/cmake/modules/FindGD.cmake 2017-12-25 15:19:09 UTC (rev 9264)
@@ -1,9 +1,9 @@
-# - Find PostgreSQL
-# Find the PostgreSQL includes and client library
+# - Find GD
+# Find the GD includes and client library
# This module defines
-# POSTGRESQL_INCLUDE_DIR, where to find POSTGRESQL.h
-# POSTGRESQL_LIBRARIES, the libraries needed to use POSTGRESQL.
-# POSTGRESQL_FOUND, If false, do not try to use PostgreSQL.
+# GD_INCLUDE_DIR, where to find gd.h
+# GD_LIBRARY, the libraries needed to use GD.
+# GD_FOUND, If false, do not try to use GD.
find_path(GD_INCLUDE_DIR NAMES "gd.h")
find_library(GD_LIBRARY NAMES gd)
Modified: sandbox/jng/cmake_v2/cmake/modules/FindGEOS.cmake
--- sandbox/jng/cmake_v2/cmake/modules/FindGEOS.cmake 2017-12-25 14:50:51 UTC (rev 9263)
+++ sandbox/jng/cmake_v2/cmake/modules/FindGEOS.cmake 2017-12-25 15:19:09 UTC (rev 9264)
@@ -1,175 +1,27 @@
-# Find GEOS
-# Copyright (c) 2008, Mateusz Loskot <mateusz at loskot.net>
-# (based on FindGDAL.cmake by Magnus Homann)
-# Redistribution and use is allowed according to the terms of the BSD license.
-# For details see the accompanying COPYING-CMAKE-SCRIPTS file.
-# CMake module to search for GEOS library
-# If it's found it sets GEOS_FOUND to TRUE
-# and following variables are set:
-# GEOS_INCLUDE_DIR
-# GEOS_LIBRARY
+# - Find GEOS
+# Find the GEOS includes and client library. NOTE: This concerns the C++ library, not the geos_c C API.
+# This module defines
+# GEOS_INCLUDE_DIR, where to find geos headers
+# GEOS_LIBRARY, the libraries needed to use GEOS.
+# GEOS_FOUND, If false, do not try to use GEOS.
-FUNCTION (GET_VERSION_PLIST PLISTFILE OUTVAR)
- SET (PVERSION "")
- IF (EXISTS ${PLISTFILE})
- FILE (READ "${PLISTFILE}" info_plist)
- STRING (REGEX REPLACE "\n" "" info_plist "${info_plist}")
- STRING (REGEX MATCH "<key>CFBundleShortVersionString</key>[ \t]*<string>([0-9\\.]*)</string>" PLISTVERSION "${info_plist}")
- STRING (REGEX REPLACE "<key>CFBundleShortVersionString</key>[ \t]*<string>([0-9\\.]*)</string>" "\\1" PVERSION "${PLISTVERSION}")
- ENDIF (EXISTS ${PLISTFILE})
- SET (${OUTVAR} ${PVERSION} PARENT_SCOPE)
-ENDFUNCTION (GET_VERSION_PLIST)
-IF(WIN32)
+find_path(GEOS_INCLUDE_DIR
+ NAMES "geos/version.h"
+ "geos/geom.h"
+ "geos/util.h"
+ "geos/io.h"
+ "geos/unload.h")
+find_library(GEOS_LIBRARY NAMES geos)
- IF (MINGW)
- FIND_PATH(GEOS_INCLUDE_DIR geos_c.h /usr/local/include /usr/include c:/msys/local/include)
- FIND_LIBRARY(GEOS_LIBRARY NAMES geos_c PATHS /usr/local/lib /usr/lib c:/msys/local/lib)
- ENDIF (MINGW)
+include(FindPackageHandleStandardArgs)
- IF (MSVC)
- FIND_PATH(GEOS_INCLUDE_DIR geos_c.h $ENV{LIB_DIR}/include $ENV{INCLUDE})
- FIND_LIBRARY(GEOS_LIBRARY NAMES geos geos_c_i PATHS
- "$ENV{LIB}/lib"
- $ENV{LIB}
- #mingw
- c:/msys/local/lib
- NO_DEFAULT_PATH
- IF (GEOS_LIBRARY)
- SET (
- GEOS_LIBRARY
- GEOS_LIBRARY;odbc32;odbccp32
- CACHE STRING INTERNAL)
- ENDIF (GEOS_LIBRARY)
- ENDIF (MSVC)
+# handle the QUIETLY and REQUIRED arguments and set CPPUNIT_FOUND to TRUE if
+# all listed variables are TRUE
+FIND_PACKAGE_HANDLE_STANDARD_ARGS(GEOS DEFAULT_MSG GEOS_LIBRARY GEOS_INCLUDE_DIR)
-ELSE(WIN32)
+if (GEOS_FOUND)
+ message(STATUS "Found libGEOS: ${GEOS_INCLUDE_DIR}, ${GEOS_LIBRARY}")
+endif (GEOS_FOUND)
- IF(UNIX)
+mark_as_advanced(GEOS_INCLUDE_DIR GEOS_LIBRARY)
- # try to use framework on mac
- # want clean framework path, not unix compatibility path
- IF (APPLE)
- IF (CMAKE_FIND_FRAMEWORK MATCHES "FIRST"
- OR CMAKE_FRAMEWORK_PATH MATCHES "ONLY"
- OR NOT CMAKE_FIND_FRAMEWORK)
- SET (CMAKE_FIND_FRAMEWORK_save ${CMAKE_FIND_FRAMEWORK} CACHE STRING "" FORCE)
- SET (CMAKE_FIND_FRAMEWORK "ONLY" CACHE STRING "" FORCE)
- FIND_LIBRARY(GEOS_LIBRARY GEOS)
- IF (GEOS_LIBRARY)
- # they're all the same in a framework
- SET (GEOS_INCLUDE_DIR ${GEOS_LIBRARY}/Headers CACHE PATH "Path to a file.")
- # set GEOS_CONFIG to make later test happy, not used here, may not exist
- SET (GEOS_CONFIG ${GEOS_LIBRARY}/unix/bin/geos-config CACHE FILEPATH "Path to a program.")
- # version in info.plist
- GET_VERSION_PLIST (${GEOS_LIBRARY}/Resources/Info.plist GEOS_VERSION)
- IF (NOT GEOS_VERSION)
- MESSAGE (FATAL_ERROR "Could not determine GEOS version from framework.")
- ENDIF (NOT GEOS_VERSION)
- STRING(REGEX REPLACE "([0-9]+)\\.([0-9]+)\\.([0-9]+)" "\\1" GEOS_VERSION_MAJOR "${GEOS_VERSION}")
- STRING(REGEX REPLACE "([0-9]+)\\.([0-9]+)\\.([0-9]+)" "\\2" GEOS_VERSION_MINOR "${GEOS_VERSION}")
- SET (CMAKE_FIND_FRAMEWORK ${CMAKE_FIND_FRAMEWORK_save} CACHE STRING "" FORCE)
- ENDIF ()
- ENDIF (APPLE)
- IF (NOT GEOS_INCLUDE_DIR OR NOT GEOS_LIBRARY OR NOT GEOS_CONFIG)
- # didn't find OS X framework, and was not set by user
- SET(GEOS_CONFIG_PREFER_PATH "$ENV{GEOS_HOME}/bin" CACHE STRING "preferred path to GEOS (geos-config)")
- FIND_PROGRAM(GEOS_CONFIG geos-config
- ${GEOS_CONFIG_PREFER_PATH}
- /usr/local/bin/
- /usr/bin/
- #MESSAGE("DBG GEOS_CONFIG ${GEOS_CONFIG}")
- IF (GEOS_CONFIG)
- EXEC_PROGRAM(${GEOS_CONFIG}
- ARGS --version
- OUTPUT_VARIABLE GEOS_VERSION)
- # set INCLUDE_DIR to prefix+include
- ARGS --prefix
- OUTPUT_VARIABLE GEOS_PREFIX)
- geos_c.h
- ${GEOS_PREFIX}/include
- /usr/local/include
- /usr/include
- ## extract link dirs for rpath
- ARGS --libs
- OUTPUT_VARIABLE GEOS_CONFIG_LIBS )
- ## split off the link dirs (for rpath)
- ## use regular expression to match wildcard equivalent "-L*<endchar>"
- ## with <endchar> is a space or a semicolon
- STRING(REGEX MATCHALL "[-][L]([^ ;])+"
- GEOS_LINK_DIRECTORIES_WITH_PREFIX
- "${GEOS_CONFIG_LIBS}" )
- #MESSAGE("DBG GEOS_LINK_DIRECTORIES_WITH_PREFIX=${GEOS_LINK_DIRECTORIES_WITH_PREFIX}")
- ## remove prefix -L because we need the pure directory for LINK_DIRECTORIES
- IF (GEOS_LINK_DIRECTORIES_WITH_PREFIX)
- STRING(REGEX REPLACE "[-][L]" "" GEOS_LINK_DIRECTORIES ${GEOS_LINK_DIRECTORIES_WITH_PREFIX} )
- ENDIF (GEOS_LINK_DIRECTORIES_WITH_PREFIX)
- ### XXX - mloskot: geos-config --libs does not return -lgeos_c, so set it manually
- ## split off the name
- ## use regular expression to match wildcard equivalent "-l*<endchar>"
- #STRING(REGEX MATCHALL "[-][l]([^ ;])+"
- # GEOS_LIB_NAME_WITH_PREFIX
- # "${GEOS_CONFIG_LIBS}" )
- #MESSAGE("DBG GEOS_CONFIG_LIBS=${GEOS_CONFIG_LIBS}")
- #MESSAGE("DBG GEOS_LIB_NAME_WITH_PREFIX=${GEOS_LIB_NAME_WITH_PREFIX}")
- SET(GEOS_LIB_NAME_WITH_PREFIX -lgeos_c CACHE STRING INTERNAL)
- ## remove prefix -l because we need the pure name
- IF (GEOS_LIB_NAME_WITH_PREFIX)
- STRING(REGEX REPLACE "[-][l]" "" GEOS_LIB_NAME ${GEOS_LIB_NAME_WITH_PREFIX} )
- ENDIF (GEOS_LIB_NAME_WITH_PREFIX)
- #MESSAGE("DBG GEOS_LIB_NAME=${GEOS_LIB_NAME}")
- IF (APPLE)
- IF (NOT GEOS_LIBRARY)
- # work around empty GEOS_LIBRARY left by framework check
- # while still preserving user setting if given
- # ***FIXME*** need to improve framework check so below not needed
- SET(GEOS_LIBRARY ${GEOS_LINK_DIRECTORIES}/lib${GEOS_LIB_NAME}.dylib CACHE STRING INTERNAL FORCE)
- ENDIF (NOT GEOS_LIBRARY)
- ELSE (APPLE)
- SET(GEOS_LIBRARY ${GEOS_LINK_DIRECTORIES}/lib${GEOS_LIB_NAME}.so CACHE STRING INTERNAL)
- ENDIF (APPLE)
- #MESSAGE("DBG GEOS_LIBRARY=${GEOS_LIBRARY}")
- ELSE(GEOS_CONFIG)
- MESSAGE("FindGEOS.cmake: geos-config not found. Please set it manually. GEOS_CONFIG=${GEOS_CONFIG}")
- ENDIF(GEOS_CONFIG)
- ENDIF(NOT GEOS_INCLUDE_DIR OR NOT GEOS_LIBRARY OR NOT GEOS_CONFIG)
- ENDIF(UNIX)
-ENDIF(WIN32)
-# Handle the QUIETLY and REQUIRED arguments and set GEOS_FOUND to TRUE
-# if all listed variables are TRUE
-include(FindPackageHandleStandardArgs)
-find_package_handle_standard_args(GEOS
- REQUIRED_VARS GEOS_LIBRARY GEOS_INCLUDE_DIR
- VERSION_VAR GEOS_VERSION)
-# Hide internal variables
-mark_as_advanced(GEOS_LIBRARY GEOS_INCLUDE_DIR)
More information about the mapguide-commits
