[mapguide-commits] r9266 - in sandbox/jng/cmake_v2: . Web Web/src Web/src/ApacheAgent Web/src/HttpHandler Web/src/WebApp Web/src/WebSupport cmake/modules
svn_mapguide at osgeo.org
Mon Dec 25 20:48:58 PST 2017
Author: jng
Date: 2017-12-25 20:48:58 -0800 (Mon, 25 Dec 2017)
New Revision: 9266
Added:
sandbox/jng/cmake_v2/Web/CMakeLists.txt
sandbox/jng/cmake_v2/Web/src/ApacheAgent/CMakeLists.txt
sandbox/jng/cmake_v2/Web/src/CMakeLists.txt
sandbox/jng/cmake_v2/Web/src/HttpHandler/CMakeLists.txt
sandbox/jng/cmake_v2/Web/src/WebApp/CMakeLists.txt
sandbox/jng/cmake_v2/Web/src/WebSupport/CMakeLists.txt
sandbox/jng/cmake_v2/cmake/modules/FindJsonCpp.cmake
sandbox/jng/cmake_v2/CMakeLists.txt
sandbox/jng/cmake_v2/Web/src/HttpHandler/JsonDoc.h
CMake-ify some of the Web Tier. Also fix up JsonDoc.h so that it can be used with a system-installed copy of jsoncpp
Modified: sandbox/jng/cmake_v2/CMakeLists.txt
--- sandbox/jng/cmake_v2/CMakeLists.txt 2017-12-25 17:07:31 UTC (rev 9265)
+++ sandbox/jng/cmake_v2/CMakeLists.txt 2017-12-26 04:48:58 UTC (rev 9266)
@@ -17,17 +17,22 @@
include(CheckIncludeFile)
include(CheckCXXSourceCompiles)
include(CheckLibraryExists)
+include(ExternalProject)
set(MG_VERSION_MAJOR 3)
set(MG_VERSION_MINOR 3)
set(MG_VERSION_RELEASE 0)
set(MG_VERSION "${MG_VERSION_MAJOR}.${MG_VERSION_MINOR}.${MG_VERSION_RELEASE}")
+set(MG_HTTPD_PORT 8008)
+set(MG_TOMCAT_PORT 8009)
set(MG_OEM_CSMAP_INCLUDE_DIR "${CMAKE_CURRENT_SOURCE_DIR}/Oem/CsMap/Include")
set(MG_OEM_AGG_DIR "${CMAKE_CURRENT_SOURCE_DIR}/Oem/agg-2.4")
set(MG_OEM_AGG_INCLUDE_DIR "${MG_OEM_AGG_DIR}/include")
set(MG_OEM_AGG_FREETYPE_DIR "${MG_OEM_AGG_DIR}/font_freetype")
set(MG_OEM_AGG_SOURCE_DIR "${MG_OEM_AGG_DIR}/src")
+set(MG_OEM_HTTPD_SOURCE_DIR, "${CMAKE_CURRENT_SOURCE_DIR}/Oem/LinuxApt/httpd-2.4.18")
set(MG_OEM_DWF_INCLUDE_DIR "${CMAKE_CURRENT_SOURCE_DIR}/Oem/DWFTK/develop/global/src")
set(MG_COMMON_DIR "${CMAKE_CURRENT_SOURCE_DIR}/Common")
@@ -58,4 +63,4 @@
add_subdirectory(Oem)
add_subdirectory(Common)
add_subdirectory(Server)
-#add_subdirectory(Web)
+add_subdirectory(Web)
Added: sandbox/jng/cmake_v2/Web/CMakeLists.txt
--- sandbox/jng/cmake_v2/Web/CMakeLists.txt (rev 0)
+++ sandbox/jng/cmake_v2/Web/CMakeLists.txt 2017-12-26 04:48:58 UTC (rev 9266)
@@ -0,0 +1,8 @@
+add_definitions( -DACE_HAS_THREAD_SAFE_ACCEPT )
+# NOTE: Not applied for server tier projects except for mgserver main executable
+if( CMAKE_COMPILER_IS_GNUCXX )
+ set ( CMAKE_SHARED_LINKER_FLAGS "-Wl,--as-needed -Wl,--no-undefined -lc ${CMAKE_SHARED_LINKER_FLAGS}")
+endif( CMAKE_COMPILER_IS_GNUCXX )
+add_subdirectory(src)
\ No newline at end of file
Added: sandbox/jng/cmake_v2/Web/src/ApacheAgent/CMakeLists.txt
--- sandbox/jng/cmake_v2/Web/src/ApacheAgent/CMakeLists.txt (rev 0)
+++ sandbox/jng/cmake_v2/Web/src/ApacheAgent/CMakeLists.txt 2017-12-26 04:48:58 UTC (rev 9266)
@@ -0,0 +1,40 @@
+include_directories(
+ ${MG_COMMON_DIR}/Foundation
+ ${MG_COMMON_DIR}/Geometry
+ ${MG_COMMON_DIR}/PlatformBase
+ ${MG_COMMON_DIR}/MapGuideCommon
+ ${MG_COMMON_DIR}/MdfModel
+ ${ACE_INCLUDE_DIR}
+ ${MG_OEM_HTTPD_SOURCE_DIR}/include
+ ${MG_OEM_HTTPD_SOURCE_DIR}/srclib/apr/include
+ ${MG_OEM_HTTPD_SOURCE_DIR}/srclib/apr-util/include
+ ${MG_OEM_HTTPD_SOURCE_DIR}/os/unix
+ ${CMAKE_CURRENT_SOURCE_DIR}/../HttpHandler
+ ${CMAKE_CURRENT_SOURCE_DIR}/../WebSupport
+ ${CMAKE_CURRENT_SOURCE_DIR}/../MapAgentCommon
+set(mod_mgmapagent_SRCS
+ ApacheAgent.cpp
+ ApachePostParser.cpp
+ ApacheReaderStreamer.cpp
+ ApacheResponseHandler.cpp
+ ../MapAgentCommon/MapAgentCommon.cpp
+ ../MapAgentCommon/MapAgentGetParser.cpp
+ ../MapAgentCommon/MapAgentStrings.cpp
+ ../WebSupport/InitializeWebTier.cpp
+add_library(mod_mgmapagent SHARED ${mod_mgmapagent_SRCS})
+target_link_libraries(mod_mgmapagent
+ MgFoundation-${MG_VERSION}
+ MgPlatformBase-${MG_VERSION}
+ MgMdfModel-${MG_VERSION}
+ MgMdfParser-${MG_VERSION}
+ MgHttpHandler-${MG_VERSION}
+ MgWebSupport-${MG_VERSION}
+# Make sure this doesn't have the "lib" prefix
+set_target_properties(mod_mgmapagent PROPERTIES PREFIX "")
Added: sandbox/jng/cmake_v2/Web/src/CMakeLists.txt
--- sandbox/jng/cmake_v2/Web/src/CMakeLists.txt (rev 0)
+++ sandbox/jng/cmake_v2/Web/src/CMakeLists.txt 2017-12-26 04:48:58 UTC (rev 9266)
@@ -0,0 +1,8 @@
+add_subdirectory(WebApp)
+add_subdirectory(WebSupport)
+add_subdirectory(HttpHandler)
+#add_subdirectory(CgiAgent)
+#add_subdirectory(PhpApi)
+#add_subdirectory(JavaApi)
+#add_subdirectory(JavaApiEx)
+#add_subdirectory(ApacheAgent)
Added: sandbox/jng/cmake_v2/Web/src/HttpHandler/CMakeLists.txt
--- sandbox/jng/cmake_v2/Web/src/HttpHandler/CMakeLists.txt (rev 0)
+++ sandbox/jng/cmake_v2/Web/src/HttpHandler/CMakeLists.txt 2017-12-26 04:48:58 UTC (rev 9266)
@@ -0,0 +1,27 @@
+find_package (JsonCpp REQUIRED)
+include_directories(${JsonCpp_INCLUDE_DIR}
+ ${XERCESC_INCLUDE_DIR}
+set(MgHttpHandler_SRCS
+ HttpHandlerBuild.cpp
+add_library(MgHttpHandler-${MG_VERSION} SHARED ${MgHttpHandler_SRCS})
+target_link_libraries(MgHttpHandler-${MG_VERSION}
+ MgGeometry-${MG_VERSION}
+ MgMapGuideCommon-${MG_VERSION}
+ ${JsonCpp_LIBRARY}
Modified: sandbox/jng/cmake_v2/Web/src/HttpHandler/JsonDoc.h
--- sandbox/jng/cmake_v2/Web/src/HttpHandler/JsonDoc.h 2017-12-25 17:07:31 UTC (rev 9265)
+++ sandbox/jng/cmake_v2/Web/src/HttpHandler/JsonDoc.h 2017-12-26 04:48:58 UTC (rev 9266)
@@ -23,25 +23,29 @@
struct MgJsonNode
- MgJsonNode() {}
+ MgJsonNode() : Name(StaticString(NULL)) {}
MgJsonNode(const StaticString &name, Json::Value element)
+ : Name(name)
this->Name = name;
this->Element = element;
this->isUsingStaticString = true;
MgJsonNode(const string &name, Json::Value element)
+ : Name(StaticString(NULL))
this->strName = name;
this->isUsingStaticString = false;
MgJsonNode(Json::Value element, int index)
this->Index = index;
MgJsonNode(Json::Value element)
Added: sandbox/jng/cmake_v2/Web/src/WebApp/CMakeLists.txt
--- sandbox/jng/cmake_v2/Web/src/WebApp/CMakeLists.txt (rev 0)
+++ sandbox/jng/cmake_v2/Web/src/WebApp/CMakeLists.txt 2017-12-26 04:48:58 UTC (rev 9266)
@@ -0,0 +1,49 @@
+include_directories(${MG_COMMON_DIR}/MdfModel
+set(MgWebApp_SRCS
+ WebBufferCommand.cpp
+ WebCommand.cpp
+ WebCommandCollection.cpp
+ WebCommandWidget.cpp
+ WebContextMenu.cpp
+ WebFlyoutWidget.cpp
+ WebGettingStarted.cpp
+ WebGetPrintablePageCommand.cpp
+ WebHelpCommand.cpp
+ WebInformationPane.cpp
+ WebInvokeScriptCommand.cpp
+ WebInvokeUrlCommand.cpp
+ WebLayout.cpp
+ WebMeasureCommand.cpp
+ WebPrintCommand.cpp
+ WebSearchCommand.cpp
+ WebSelectWithinCommand.cpp
+ WebSeparatorWidget.cpp
+ WebTaskBarWidget.cpp
+ WebTaskBar.cpp
+ WebTaskPane.cpp
+ WebToolbar.cpp
+ WebUiPane.cpp
+ WebUiSizablePane.cpp
+ WebUiTargetCommand.cpp
+ WebViewOptionsCommand.cpp
+ WebWidget.cpp
+ WebWidgetCollection.cpp
+add_library(MgWebApp-${MG_VERSION} SHARED ${MgWebApp_SRCS})
+target_link_libraries(MgWebApp-${MG_VERSION}
+ ${XERCESC_LIBRARIES}
Added: sandbox/jng/cmake_v2/Web/src/WebSupport/CMakeLists.txt
--- sandbox/jng/cmake_v2/Web/src/WebSupport/CMakeLists.txt (rev 0)
+++ sandbox/jng/cmake_v2/Web/src/WebSupport/CMakeLists.txt 2017-12-26 04:48:58 UTC (rev 9266)
@@ -0,0 +1,19 @@
+set(MgWebSupport_SRCS
+ InitializeWebTier.cpp
+add_library(MgWebSupport-${MG_VERSION} SHARED ${MgWebSupport_SRCS})
+target_link_libraries(MgWebSupport-${MG_VERSION}
Added: sandbox/jng/cmake_v2/cmake/modules/FindJsonCpp.cmake
--- sandbox/jng/cmake_v2/cmake/modules/FindJsonCpp.cmake (rev 0)
+++ sandbox/jng/cmake_v2/cmake/modules/FindJsonCpp.cmake 2017-12-26 04:48:58 UTC (rev 9266)
@@ -0,0 +1,25 @@
+# - Find JsonCpp
+# Find the JsonCpp includes and client library
+# This module defines
+# JsonCpp_INCLUDE_DIR, where to find JsonCpp.h
+# JsonCpp_LIBRARY, the libraries needed to use JsonCpp.
+# JsonCpp_FOUND, If false, do not try to use JsonCpp.
+find_path(JsonCpp_INCLUDE_DIR
+ NAMES "json/json.h"
+ HINTS "/usr/include"
+ "/usr/include/jsoncpp")
+find_library(JsonCpp_LIBRARY NAMES jsoncpp)
+include(FindPackageHandleStandardArgs)
+# handle the QUIETLY and REQUIRED arguments and set CPPUNIT_FOUND to TRUE if
+# all listed variables are TRUE
+FIND_PACKAGE_HANDLE_STANDARD_ARGS(JsonCpp DEFAULT_MSG JsonCpp_LIBRARY JsonCpp_INCLUDE_DIR)
+if (JsonCpp_FOUND)
+ message(STATUS "Found libJsonCpp: ${JsonCpp_INCLUDE_DIR}, ${JsonCpp_LIBRARY}")
+endif (JsonCpp_FOUND)
+mark_as_advanced(JsonCpp_INCLUDE_DIR JsonCpp_LIBRARY)
More information about the mapguide-commits
