[mapguide-commits] r9131 - in sandbox/adsk/3.2o: . Common/PlatformBase/Services Server/src/Services/Resource
svn_mapguide at osgeo.org
Sun Feb 5 19:01:11 PST 2017
Author: christinebao
Date: 2017-02-05 19:01:11 -0800 (Sun, 05 Feb 2017)
New Revision: 9131
sandbox/adsk/3.2o/
sandbox/adsk/3.2o/Common/PlatformBase/Services/ResourceDefs.cpp
sandbox/adsk/3.2o/Common/PlatformBase/Services/ResourceDefs.h
sandbox/adsk/3.2o/Server/src/Services/Resource/ApplicationRepositoryManager.cpp
sandbox/adsk/3.2o/Server/src/Services/Resource/TagManager.cpp
Merged revision(s) 9130 from trunk/MgDev:
Fix ticket: MapGuide feature source data add supporting for proxy
https://trac.osgeo.org/mapguide/ticket/2761
Add support for proxy resource data.
Property changes on: sandbox/adsk/3.2o
___________________________________________________________________
Modified: svn:mergeinfo
- /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/branches/2.6/MgDev:8276-8286,8288-8292,8297,8299,8301,8303,8314-8315,8318,8335,8340,8354-8355,8365,8373
/branches/3.0/MgDev:8658,8705,8710
/branches/3.1/MgDev:9026,9058-9059,9067-9068
/sandbox/VC140:8684-8759
/sandbox/adsk/2.6l:8727
/sandbox/adsk/3.0m:8563,8584,8607,8625,8694-8695
/sandbox/adsk/3.1n:8871,8895,8901,8912-8913,8921-8922,8942,9019-9020
/sandbox/jng/convenience_apis:8262-8268,8271-8363
/sandbox/jng/createruntimemap:7486-7555
/sandbox/jng/dwftk:8321-8324,8328-8329,8331,8352
/sandbox/jng/geos34x:8256-8259
/sandbox/jng/php56x:8975-8985
/sandbox/jng/rfc155:8872-8884
/sandbox/jng/tiling:8174-8208
/sandbox/jng/v30:8212-8227
/sandbox/rfc94:5099-5163
/trunk/MgDev:8869-8871,9106-9107
+ /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/trunk/MgDev:8869-8871,9106-9107,9130
Modified: sandbox/adsk/3.2o/Common/PlatformBase/Services/ResourceDefs.cpp
--- sandbox/adsk/3.2o/Common/PlatformBase/Services/ResourceDefs.cpp 2017-02-06 02:58:45 UTC (rev 9130)
+++ sandbox/adsk/3.2o/Common/PlatformBase/Services/ResourceDefs.cpp 2017-02-06 03:01:11 UTC (rev 9131)
@@ -1,5 +1,5 @@
-// Copyright (C) 2004-2011 by Autodesk, Inc.
+// Copyright (C) 2017 by Autodesk, Inc.
// This library is free software; you can redistribute it and/or
// modify it under the terms of version 2.1 of the GNU Lesser
@@ -69,6 +69,10 @@
const STRING MgResourceTag::LoginPassword = L"%MG_LOGIN_PASSWORD%";
const STRING MgResourceTag::Username = L"%MG_USERNAME%";
const STRING MgResourceTag::Password = L"%MG_PASSWORD%";
+const STRING MgResourceTag::ProxyServer = L"%MG_PROXY_SERVER%";
+const STRING MgResourceTag::ProxyPort = L"%MG_PROXY_PORT%";
+const STRING MgResourceTag::ProxyUsername = L"%MG_PROXY_USERNAME%";
+const STRING MgResourceTag::ProxyPassword = L"%MG_PROXY_PASSWORD%";
const STRING MgResourceTag::DataFilePath = L"%MG_DATA_FILE_PATH%";
const STRING MgResourceTag::TileCachePath = L"%MG_TILE_CACHE_PATH%";
const STRING MgResourceTag::DataPathAliasBegin = L"%MG_DATA_PATH_ALIAS[";
@@ -79,6 +83,9 @@
/// Resource data names
const STRING MgResourceDataName::UserCredentials = L"MG_USER_CREDENTIALS";
+const STRING MgResourceDataName::ProxyServerName = L"MG_PROXY_SERVER";
+const STRING MgResourceDataName::ProxyServerPort = L"MG_PROXY_PORT";
+const STRING MgResourceDataName::ProxyCredentials = L"MG_PROXY_CREDENTIALS";
Modified: sandbox/adsk/3.2o/Common/PlatformBase/Services/ResourceDefs.h
--- sandbox/adsk/3.2o/Common/PlatformBase/Services/ResourceDefs.h 2017-02-06 02:58:45 UTC (rev 9130)
+++ sandbox/adsk/3.2o/Common/PlatformBase/Services/ResourceDefs.h 2017-02-06 03:01:11 UTC (rev 9131)
@@ -1,5 +1,5 @@
@@ -366,7 +366,30 @@
static const STRING Password; ///\if INTERNAL value("%MG_PASSWORD%") \endif
+ /// \brief
+ /// Replaced with the proxy server name.
+ static const STRING ProxyServer; ///\if INTERNAL value("%MG_PROXY_SERVER%") \endif
+ /// \brief
+ /// Replaced with the proxy server port.
+ static const STRING ProxyPort; ///\if INTERNAL value("%MG_PROXY_PORT%") \endif
+ /// \brief
+ /// Replaced with the proxy server user name.
+ static const STRING ProxyUsername; ///\if INTERNAL value("%MG_PROXY_USERNAME%") \endif
+ /// \brief
+ /// Replaced with the proxy server password.
+ static const STRING ProxyPassword; ///\if INTERNAL value("%MG_PROXY_PASSWORD%") \endif
/// \brief
/// Replaced with the location of data files associated with the
@@ -404,16 +427,49 @@
class MG_PLATFORMBASE_API MgResourceDataName
PUBLISHED_API:
+ /// \brief
+ /// Data name for adding default credentials to a resource.
+ /// \note1
+ /// \remarks
+ /// For an example, see \link MgResourceService::SetResourceData SetResourceData \endlink.
+ static const STRING UserCredentials; ///\if INTERNAL value("MG_USER_CREDENTIALS") \endif
/// \brief
- /// Data name for adding default credentials to a resource.
+ /// Data name for adding proxy server name to a resource.
/// \note1
/// \remarks
- static const STRING UserCredentials; ///\if INTERNAL value("MG_USER_CREDENTIALS") \endif
+ static const STRING ProxyServerName; ///\if INTERNAL value("MG_PROXY_SERVER") \endif
+ /// \brief
+ /// Data name for adding proxy server port to a resource.
+ /// \note1
+ /// \remarks
+ static const STRING ProxyServerPort; ///\if INTERNAL value("MG_PROXY_PORT") \endif
+ /// \brief
+ /// Data name for adding proxy credentials to a resource.
+ /// \note1
+ /// \remarks
+ static const STRING ProxyCredentials; ///\if INTERNAL value("MG_PROXY_CREDENTIALS") \endif
Modified: sandbox/adsk/3.2o/Server/src/Services/Resource/ApplicationRepositoryManager.cpp
--- sandbox/adsk/3.2o/Server/src/Services/Resource/ApplicationRepositoryManager.cpp 2017-02-06 02:58:45 UTC (rev 9130)
+++ sandbox/adsk/3.2o/Server/src/Services/Resource/ApplicationRepositoryManager.cpp 2017-02-06 03:01:11 UTC (rev 9131)
@@ -1,5 +1,5 @@
@@ -945,7 +945,7 @@
dataValue = data->ToString();
- if (MgResourceDataName::UserCredentials == dataName)
+ if (MgResourceDataName::UserCredentials == dataName || MgResourceDataName::ProxyCredentials == dataName)
MgCryptographyManager cryptoManager;
@@ -1221,7 +1221,7 @@
string data;
// For security purpose, only the decrypted username
// (no decrypted password) is returned.
Modified: sandbox/adsk/3.2o/Server/src/Services/Resource/TagManager.cpp
--- sandbox/adsk/3.2o/Server/src/Services/Resource/TagManager.cpp 2017-02-06 02:58:45 UTC (rev 9130)
+++ sandbox/adsk/3.2o/Server/src/Services/Resource/TagManager.cpp 2017-02-06 03:01:11 UTC (rev 9131)
@@ -1,5 +1,5 @@
@@ -175,9 +175,9 @@
if ((MgResourceDataType::String != type
- && MgResourceDataName::UserCredentials == name)
+ && ((MgResourceDataName::UserCredentials == name) || (MgResourceDataName::ProxyServerName == name) || (MgResourceDataName::ProxyServerPort == name) || (MgResourceDataName::ProxyCredentials == name)))
|| (MgResourceDataType::String == type
- && MgResourceDataName::UserCredentials != name))
+ && ((MgResourceDataName::UserCredentials != name) && (MgResourceDataName::ProxyServerName != name) && (MgResourceDataName::ProxyServerPort != name) && (MgResourceDataName::ProxyCredentials != name))))
throw new MgInvalidResourceDataTypeException(
L"MgTagManager.ValidateTag", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -323,6 +323,46 @@
MG_CRYPTOGRAPHY_CATCH_AND_THROW(L"MgTagManager.SubstituteTags")
+ if (GetTag(MgResourceDataName::ProxyServerName, tagInfo, false))
+ CREFSTRING proxyServer = tagInfo.GetAttribute(MgTagInfo::TokenValue);
+ count += MgUtil::ReplaceString(
+ MgUtil::WideCharToMultiByte(MgResourceTag::ProxyServer),
+ MgUtil::WideCharToMultiByte(proxyServer),
+ doc, -1);
+ if (GetTag(MgResourceDataName::ProxyServerPort, tagInfo, false))
+ CREFSTRING proxyPort = tagInfo.GetAttribute(MgTagInfo::TokenValue);
+ MgUtil::WideCharToMultiByte(MgResourceTag::ProxyPort),
+ MgUtil::WideCharToMultiByte(proxyPort),
+ doc, -1);
+ if (GetTag(MgResourceDataName::ProxyCredentials, tagInfo, false))
+ MG_CRYPTOGRAPHY_TRY()
+ MgCryptographyUtil cryptoUtil;
+ string proxyUsername, proxyPassword;
+ cryptoUtil.DecryptCredentials(MgUtil::WideCharToMultiByte(
+ tagInfo.GetAttribute(MgTagInfo::TokenValue)), proxyUsername, proxyPassword);
+ MgUtil::WideCharToMultiByte(MgResourceTag::ProxyUsername),
+ proxyUsername,
+ doc, -1);
+ MgUtil::WideCharToMultiByte(MgResourceTag::ProxyPassword),
+ proxyPassword,
+ doc, -1);
+ MG_CRYPTOGRAPHY_CATCH_AND_THROW(L"MgTagManager.SubstituteTags")
MgUtil::WideCharToMultiByte(MgResourceTag::LoginUsername),
MgUtil::WideCharToMultiByte(dataBindingInfo.GetLoginUsername()),
More information about the mapguide-commits
