[mapguide-commits] r9112 - trunk/Tools/Maestro/Maestro.AddIn.Rest/UI
svn_mapguide at osgeo.org
Mon Jan 2 02:42:09 PST 2017
Author: jng
Date: 2017-01-02 02:42:08 -0800 (Mon, 02 Jan 2017)
New Revision: 9112
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/NewRepresentationDialog.cs
#2506: Fix typo (should be "Representations", not "Representation")
Modified: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/NewRepresentationDialog.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/NewRepresentationDialog.cs 2016-12-31 16:57:13 UTC (rev 9111)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/NewRepresentationDialog.cs 2017-01-02 10:42:08 UTC (rev 9112)
@@ -75,11 +75,11 @@
private void btnSave_Click(object sender, EventArgs e)
dynamic repr = null;
- if (!((IDictionary<string, object>)_config).ContainsKey("Representations"))
+ if (!((IDictionary<string, object>)_config).ContainsKey(nameof(_config.Representations)))
- _config.Representation = new ExpandoObject();
+ _config.Representations = new ExpandoObject();
- repr = _config.Representation;
+ repr = _config.Representations;
dynamic conf = _ctrl.GetOptions();
((IDictionary<string, object>)repr)[_rep] = conf;
More information about the mapguide-commits
