[mapguide-commits] r9230 - in trunk/MgDev: . Common/Foundation/System Common/Geometry Common/PlatformBase/Services Common/Schema Server/src/UnitTesting UnitTest/WebTier/MapAgent/MapAgentForms Web/src/DotNetUnmanagedApi/Geometry Web/src/HttpHandler Web/src/MapGuideApi
svn_mapguide at osgeo.org
Tue Jul 11 08:44:27 PDT 2017
Author: jng
Date: 2017-07-11 08:44:27 -0700 (Tue, 11 Jul 2017)
New Revision: 9230
Added:
trunk/MgDev/Common/Geometry/PreparedGeometry.cpp
trunk/MgDev/Common/Geometry/PreparedGeometry.h
trunk/MgDev/Common/Schema/GeometryInfo-3.3.0.xsd
trunk/MgDev/Common/Schema/UnitOfMeasure-3.3.0.xsd
trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/binaryoperationform.html
trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/boundaryform.html
trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/bufferform.html
trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/convexhullform.html
trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/distanceform.html
trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/geometryinfoform.html
trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/geoprocessingapi.html
trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/simplifyform.html
trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/spatialpredicateform.html
trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/tessellateform.html
trunk/MgDev/Web/src/HttpHandler/HttpGeoBinaryOperation.cpp
trunk/MgDev/Web/src/HttpHandler/HttpGeoBinaryOperation.h
trunk/MgDev/Web/src/HttpHandler/HttpGeoBoundary.cpp
trunk/MgDev/Web/src/HttpHandler/HttpGeoBoundary.h
trunk/MgDev/Web/src/HttpHandler/HttpGeoBuffer.cpp
trunk/MgDev/Web/src/HttpHandler/HttpGeoBuffer.h
trunk/MgDev/Web/src/HttpHandler/HttpGeoConvexHull.cpp
trunk/MgDev/Web/src/HttpHandler/HttpGeoConvexHull.h
trunk/MgDev/Web/src/HttpHandler/HttpGeoDistance.cpp
trunk/MgDev/Web/src/HttpHandler/HttpGeoDistance.h
trunk/MgDev/Web/src/HttpHandler/HttpGeoSimplify.cpp
trunk/MgDev/Web/src/HttpHandler/HttpGeoSimplify.h
trunk/MgDev/Web/src/HttpHandler/HttpGeoSpatialPredicate.cpp
trunk/MgDev/Web/src/HttpHandler/HttpGeoSpatialPredicate.h
trunk/MgDev/Web/src/HttpHandler/HttpGeoTessellate.cpp
trunk/MgDev/Web/src/HttpHandler/HttpGeoTessellate.h
trunk/MgDev/Web/src/HttpHandler/HttpGeometryInfo.cpp
trunk/MgDev/Web/src/HttpHandler/HttpGeometryInfo.h
trunk/MgDev/
trunk/MgDev/Common/Foundation/System/Util.cpp
trunk/MgDev/Common/Foundation/System/Util.h
trunk/MgDev/Common/Geometry/Geometry.cpp
trunk/MgDev/Common/Geometry/Geometry.h
trunk/MgDev/Common/Geometry/Geometry.vcxproj
trunk/MgDev/Common/Geometry/Geometry.vcxproj.filters
trunk/MgDev/Common/Geometry/GeometryBuild.cpp
trunk/MgDev/Common/Geometry/GeometryClassId.h
trunk/MgDev/Common/Geometry/GeometryCommon.h
trunk/MgDev/Common/Geometry/GeometrySimplifier.cpp
trunk/MgDev/Common/Geometry/Makefile.am
trunk/MgDev/Common/PlatformBase/Services/GeoJsonWriter.cpp
trunk/MgDev/Common/PlatformBase/Services/GeoJsonWriter.h
trunk/MgDev/Server/src/UnitTesting/TestGeometry.cpp
trunk/MgDev/Server/src/UnitTesting/TestGeometry.h
trunk/MgDev/Server/src/UnitTesting/TestMisc.cpp
trunk/MgDev/Server/src/UnitTesting/TestMisc.h
trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/selectaggregatesform.html
trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/selectfeaturesform.html
trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/services.html
trunk/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryApiGen.xml
trunk/MgDev/Web/src/HttpHandler/HttpHandler.vcxproj
trunk/MgDev/Web/src/HttpHandler/HttpHandler.vcxproj.filters
trunk/MgDev/Web/src/HttpHandler/HttpHandlerBuild.cpp
trunk/MgDev/Web/src/HttpHandler/HttpRequest.cpp
trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.cpp
trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.h
trunk/MgDev/Web/src/HttpHandler/HttpSelectFeatures.cpp
trunk/MgDev/Web/src/HttpHandler/HttpSelectFeatures.h
trunk/MgDev/Web/src/HttpHandler/HttpSelectFeaturesSpatially.cpp
trunk/MgDev/Web/src/HttpHandler/HttpSelectFeaturesSpatially.h
trunk/MgDev/Web/src/HttpHandler/Makefile.am
trunk/MgDev/Web/src/HttpHandler/ReaderByteSourceImpl.cpp
trunk/MgDev/Web/src/HttpHandler/ReaderByteSourceImpl.h
trunk/MgDev/Web/src/HttpHandler/XmlJsonConvert.cpp
trunk/MgDev/Web/src/MapGuideApi/MapGuideApiGen.xml
Merge from sandbox/jng/geoprocessing. This completes MapGuide RFC 161
Property changes on: trunk/MgDev
___________________________________________________________________
Modified: svn:mergeinfo
- /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/branches/2.6/MgDev:8276-8286,8288-8292,8297,8299,8301,8303,8314-8315,8318,8335,8340,8354-8355,8365,8373
/branches/3.0/MgDev:8658,8705,8710
/branches/3.1/MgDev:9026,9058-9059,9067-9068
/sandbox/VC140:8684-8759
/sandbox/adsk/2.6l:8727
/sandbox/adsk/3.0m:8563,8584,8607,8625,8694-8695
/sandbox/adsk/3.1n:8871,8895,8901,8912-8913,8921-8922,8942,9019-9020
/sandbox/jng/clean_json:8818-9180
/sandbox/jng/cmdline:9199-9217
/sandbox/jng/convenience_apis:8262-8268,8271-8363
/sandbox/jng/createruntimemap:7486-7555
/sandbox/jng/dwftk:8321-8324,8328-8329,8331,8352
/sandbox/jng/geos34x:8256-8259
/sandbox/jng/php56x:8975-8985
/sandbox/jng/rfc155:8872-8884
/sandbox/jng/simplify:8814-9141
/sandbox/jng/tiling:8174-8208
/sandbox/jng/utfgrid:9179-9212
/sandbox/jng/v30:8212-8227
/sandbox/rfc94:5099-5163
+ /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/sandbox/jng/geoprocessing:9205-9229
Modified: trunk/MgDev/Common/Foundation/System/Util.cpp
--- trunk/MgDev/Common/Foundation/System/Util.cpp 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Common/Foundation/System/Util.cpp 2017-07-11 15:44:27 UTC (rev 9230)
@@ -1083,6 +1083,40 @@
str = &buf[0];
+void MgUtil::DoubleToString(double val, string& str, INT32 decimals)
+ if (decimals <= 0) //Took a wrong turn?
+ DoubleToString(val, str);
+ else
+ std::stringstream ss;
+ ss << std::fixed << std::setprecision(decimals) << val;
+ str = ss.str();
+ // Slice off trailing 0s
+ size_t end = str.find_last_not_of('0') + 1;
+ str.erase(end);
+void MgUtil::DoubleToString(double val, STRING& str, INT32 decimals)
+ else
+ std::wstringstream ws;
+ ws << std::fixed << std::setprecision(decimals) << val;
+ str = ws.str();
+ size_t end = str.find_last_not_of(L'0') + 1;
+ str.erase(end);
bool MgUtil::ValuesEqual(double value1, double value2, double tolerance, bool output)
bool valuesEqual = true;
Modified: trunk/MgDev/Common/Foundation/System/Util.h
--- trunk/MgDev/Common/Foundation/System/Util.h 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Common/Foundation/System/Util.h 2017-07-11 15:44:27 UTC (rev 9230)
@@ -553,6 +553,8 @@
static void SingleToString(float val, STRING& str);
static void DoubleToString(double val, string& str);
static void DoubleToString(double val, STRING& str);
+ static void DoubleToString(double val, string& str, INT32 decimals);
+ static void DoubleToString(double val, STRING& str, INT32 decimals);
static bool ValuesEqual(double value1, double value2,
double tolerance = MgUtil::DefaultCompareTolerance,
Modified: trunk/MgDev/Common/Geometry/Geometry.cpp
--- trunk/MgDev/Common/Geometry/Geometry.cpp 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Common/Geometry/Geometry.cpp 2017-07-11 15:44:27 UTC (rev 9230)
@@ -259,3 +259,13 @@
return MgGeometryEntityType::Geometry;
+MgPreparedGeometry* MgGeometry::Prepare()
+ return MgPreparedGeometry::Create(this);
+MgGeometry* MgGeometry::Tessellate()
+ return MgSpatialUtility::TesselateCurve(this);
\ No newline at end of file
Modified: trunk/MgDev/Common/Geometry/Geometry.h
--- trunk/MgDev/Common/Geometry/Geometry.h 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Common/Geometry/Geometry.h 2017-07-11 15:44:27 UTC (rev 9230)
@@ -18,6 +18,7 @@
#ifndef _MGGEOMETRY_H_
#define _MGGEOMETRY_H_
+class MgPreparedGeometry;
class MgGeometry;
template class MG_GEOMETRY_API Ptr<MgGeometry>;
@@ -733,6 +734,54 @@
virtual MgGeometry* Union(MgGeometry* other);
+ /// \brief
+ /// Returns a prepared version of this geometry that is optimized for
+ /// repeated evaluation of spatial predicate operations
+ /// <!-- Syntax in .Net, Java, and PHP -->
+ /// \htmlinclude DotNetSyntaxTop.html
+ /// virtual MgGeometry Prepare();
+ /// \htmlinclude SyntaxBottom.html
+ /// \htmlinclude JavaSyntaxTop.html
+ /// \htmlinclude PHPSyntaxTop.html
+ /// \since 3.3
+ /// \return
+ /// An MgPreparedGeometry representing the prepared version of this geometry
+ MgPreparedGeometry* Prepare();
+ /// \brief
+ /// Returns a tessellated version of this geometry. A tessellated version of this
+ /// geometry will have all arc/curve geometry components approximated with line
+ /// strings. Thus, this method is only applicable for curve geometries and has
+ /// no effect on non-curve geometries.
+ /// \since 3.3
+ /// \return
+ /// A tesellated version of this geometry. If this geometry is not curve-based, the operation does nothing and this method returns itself.
+ MgGeometry* Tessellate();
INTERNAL_API:
virtual INT32 GetEntityType();
Modified: trunk/MgDev/Common/Geometry/Geometry.vcxproj
--- trunk/MgDev/Common/Geometry/Geometry.vcxproj 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Common/Geometry/Geometry.vcxproj 2017-07-11 15:44:27 UTC (rev 9230)
@@ -492,6 +492,12 @@
<ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">true</ExcludedFromBuild>
<ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|x64'">true</ExcludedFromBuild>
</ClCompile>
+ <ClCompile Include="PreparedGeometry.cpp">
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|x64'">true</ExcludedFromBuild>
+ </ClCompile>
<ClCompile Include="Spatial\MathUtility.cpp">
@@ -907,6 +913,7 @@
<ClInclude Include="Parse\ParseAwktUtil.h" />
<ClInclude Include="Parse\StringUtility.h" />
<ClInclude Include="Parse\yyAwkt.h" />
+ <ClInclude Include="PreparedGeometry.h" />
<ClInclude Include="Spatial\MathUtility.h" />
<ClInclude Include="Spatial\SpatialUtility.h" />
<ClInclude Include="Spatial\SpatialUtilityCircularArc.h" />
Modified: trunk/MgDev/Common/Geometry/Geometry.vcxproj.filters
--- trunk/MgDev/Common/Geometry/Geometry.vcxproj.filters 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Common/Geometry/Geometry.vcxproj.filters 2017-07-11 15:44:27 UTC (rev 9230)
@@ -373,6 +373,7 @@
<ClCompile Include="Ring.cpp" />
<ClCompile Include="WktReaderWriter.cpp" />
<ClCompile Include="GeometrySimplifier.cpp" />
+ <ClCompile Include="PreparedGeometry.cpp" />
</ItemGroup>
<ItemGroup>
<ClInclude Include="Buffer\BorderWalker.h">
@@ -973,6 +974,7 @@
<ClInclude Include="WktReaderWriter.h" />
<ClInclude Include="GeometrySimplifier.h" />
<ClInclude Include="GeometrySimplificationAlgorithmType.h" />
</ItemGroup>
<ItemGroup>
<ResourceCompile Include="Geometry.rc" />
Modified: trunk/MgDev/Common/Geometry/GeometryBuild.cpp
--- trunk/MgDev/Common/Geometry/GeometryBuild.cpp 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Common/Geometry/GeometryBuild.cpp 2017-07-11 15:44:27 UTC (rev 9230)
@@ -56,6 +56,7 @@
#include "PointCollection.cpp"
#include "Polygon.cpp"
#include "PolygonCollection.cpp"
+#include "PreparedGeometry.cpp"
#include "Region.cpp"
#include "Ring.cpp"
#include "WktReaderWriter.cpp"
Modified: trunk/MgDev/Common/Geometry/GeometryClassId.h
--- trunk/MgDev/Common/Geometry/GeometryClassId.h 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Common/Geometry/GeometryClassId.h 2017-07-11 15:44:27 UTC (rev 9230)
@@ -79,6 +79,8 @@
// Simplifier
#define Geometry_GeometrySimplifier GEOMETRY_ID+54
+#define Geometry_PreparedGeometry GEOMETRY_ID+55
// CoordinateSystem API
#define CoordinateSystem_CoordinateSystem GEOMETRY_COORDINATE_SYSTEM_ID+0
#define CoordinateSystem_CoordinateSystemFactory GEOMETRY_COORDINATE_SYSTEM_ID+1
Modified: trunk/MgDev/Common/Geometry/GeometryCommon.h
--- trunk/MgDev/Common/Geometry/GeometryCommon.h 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Common/Geometry/GeometryCommon.h 2017-07-11 15:44:27 UTC (rev 9230)
@@ -100,6 +100,8 @@
#include "MultiPoint.h"
#include "MultiPolygon.h"
+#include "PreparedGeometry.h"
#include "AgfReaderWriter.h"
#include "WktReaderWriter.h"
Modified: trunk/MgDev/Common/Geometry/GeometrySimplifier.cpp
--- trunk/MgDev/Common/Geometry/GeometrySimplifier.cpp 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Common/Geometry/GeometrySimplifier.cpp 2017-07-11 15:44:27 UTC (rev 9230)
@@ -33,7 +33,7 @@
MgGeometry* MgGeometrySimplifier::Simplify(MgGeometry* geom, double tolerance, INT32 algorithm)
Ptr<MgGeometry> simplified;
- Geometry* gInput = NULL;
+ std::auto_ptr<Geometry> gInput;
std::auto_ptr<Geometry> gOutput;
MG_GEOMETRY_TRY()
@@ -50,15 +50,15 @@
WKTReader r(&gf);
WKTWriter w;
- gInput = r.read(MgUtil::WideCharToMultiByte(inputWKt));
+ gInput.reset(r.read(MgUtil::WideCharToMultiByte(inputWKt)));
switch (algorithm)
case MgGeometrySimplificationAlgorithmType::DouglasPeucker:
- gOutput = geos::simplify::DouglasPeuckerSimplifier::simplify(gInput, tolerance);
+ gOutput = geos::simplify::DouglasPeuckerSimplifier::simplify(gInput.get(), tolerance);
break;
case MgGeometrySimplificationAlgorithmType::TopologyPreserving:
- gOutput = geos::simplify::TopologyPreservingSimplifier::simplify(gInput, tolerance);
+ gOutput = geos::simplify::TopologyPreservingSimplifier::simplify(gInput.get(), tolerance);
break;
@@ -72,6 +72,7 @@
MG_GEOMETRY_CATCH_AND_THROW(L"MgGeometrySimplifier.Simplify")
return simplified.Detach();
Modified: trunk/MgDev/Common/Geometry/Makefile.am
--- trunk/MgDev/Common/Geometry/Makefile.am 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Common/Geometry/Makefile.am 2017-07-11 15:44:27 UTC (rev 9230)
@@ -100,6 +100,7 @@
PointCollection.cpp \
Polygon.cpp \
PolygonCollection.cpp \
+ PreparedGeometry.cpp \
Region.cpp \
Ring.cpp \
WktReaderWriter.cpp\
@@ -267,6 +268,7 @@
PointCollection.h \
Polygon.h \
PolygonCollection.h \
+ PreparedGeometry.h \
QuadToInstruction.h \
Region.h \
Ring.h \
Copied: trunk/MgDev/Common/Geometry/PreparedGeometry.cpp (from rev 9229, sandbox/jng/geoprocessing/Common/Geometry/PreparedGeometry.cpp)
--- trunk/MgDev/Common/Geometry/PreparedGeometry.cpp (rev 0)
+++ trunk/MgDev/Common/Geometry/PreparedGeometry.cpp 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,142 @@
+// Copyright (C) 2004-2017 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#include "GeometryCommon.h"
+#include <geos/geom/prep/PreparedGeometry.h>
+#include <geos/geom/prep/PreparedGeometryFactory.h>
+using namespace geos::geom::prep;
+class MgPreparedGeometry::PreparedGeometryImpl
+public:
+ PreparedGeometryImpl()
+ : m_pg(NULL),
+ m_pm(new PrecisionModel()),
+ m_gf(NULL),
+ m_geom(NULL)
+ m_gf.reset(new GeometryFactory(m_pm.get(), 10));
+ ~PreparedGeometryImpl()
+ PreparedGeometryFactory::destroy(m_pg);
+ Geometry* Convert(MgGeometry* geom)
+ WKTReader r(m_gf.get());
+ Ptr<MgGeometry> tGeom = MgSpatialUtility::TesselateCurve(geom);
+ STRING wktGeom = tGeom->ToAwkt(true);
+ return r.read(MgUtil::WideCharToMultiByte(wktGeom));
+ void Prepare(MgGeometry* geom)
+ m_geom.reset(r.read(MgUtil::WideCharToMultiByte(wktGeom)));
+ m_pg = PreparedGeometryFactory::prepare(m_geom.get());
+ const PreparedGeometry* m_pg;
+private:
+ std::auto_ptr<Geometry> m_geom;
+ std::auto_ptr<PrecisionModel> m_pm;
+ std::auto_ptr<GeometryFactory> m_gf;
+MgPreparedGeometry* MgPreparedGeometry::Create(MgGeometry* geom)
+ Ptr<MgPreparedGeometry> pGeom;
+ MG_GEOMETRY_TRY()
+ PreparedGeometryImpl* impl = new PreparedGeometryImpl();
+ impl->Prepare(geom);
+ pGeom = new MgPreparedGeometry(impl);
+ MG_GEOMETRY_CATCH_AND_THROW(L"MgPreparedGeometry.Create")
+ return SAFE_ADDREF((MgPreparedGeometry*)pGeom);
+MgPreparedGeometry::MgPreparedGeometry(PreparedGeometryImpl* impl)
+ : d_ptr(impl)
+MgPreparedGeometry::~MgPreparedGeometry()
+bool MgPreparedGeometry::Contains(MgGeometry * other)
+ std::auto_ptr<Geometry> gOther(d_ptr->Convert(other));
+ return d_ptr->m_pg->contains(gOther.get());
+bool MgPreparedGeometry::Crosses(MgGeometry * other)
+ return d_ptr->m_pg->crosses(gOther.get());
+bool MgPreparedGeometry::Disjoint(MgGeometry * other)
+ return d_ptr->m_pg->disjoint(gOther.get());
+bool MgPreparedGeometry::Intersects(MgGeometry * other)
+ return d_ptr->m_pg->intersects(gOther.get());
+bool MgPreparedGeometry::Overlaps(MgGeometry * other)
+ return d_ptr->m_pg->overlaps(gOther.get());
+bool MgPreparedGeometry::Touches(MgGeometry * other)
+ return d_ptr->m_pg->touches(gOther.get());
+bool MgPreparedGeometry::Within(MgGeometry * other)
+ return d_ptr->m_pg->within(gOther.get());
+INT32 MgPreparedGeometry::GetClassId()
+ return m_cls_id;
+void MgPreparedGeometry::Dispose()
+ delete this;
Copied: trunk/MgDev/Common/Geometry/PreparedGeometry.h (from rev 9229, sandbox/jng/geoprocessing/Common/Geometry/PreparedGeometry.h)
--- trunk/MgDev/Common/Geometry/PreparedGeometry.h (rev 0)
+++ trunk/MgDev/Common/Geometry/PreparedGeometry.h 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,303 @@
+#ifndef _MGPREPAREDGEOMETRY_H_
+#define _MGPREPAREDGEOMETRY_H_
+class MgGeometry;
+/// \brief
+/// MgPreparedGeometry is an prepared form of MgGeometry optimized for the case of
+/// repeated evaluation of spatial predicates against it and any other geometry
+class MG_GEOMETRY_API MgPreparedGeometry : public MgGuardDisposable
+PUBLISHED_API:
+ /// \brief
+ /// This is a convenience method. Given 2 geometries a and b,
+ /// a.Contains(b) is true if and only if b.MgGeometry::Within(a)
+ /// is true.
+ /// virtual bool Contains(MgGeometry other);
+ /// virtual boolean Contains(MgGeometry other);
+ /// \param other (MgGeometry)
+ /// The MgGeometry to test against this one.
+ /// \return
+ /// True if the other geometry is within this geometry, false
+ /// otherwise.
+ virtual bool Contains(MgGeometry* other);
+ /// \brief
+ /// Given 2 geometries a and b, a.Crosses(b) is true if and only
+ /// if the dimension of the intersection of the interior of a and
+ /// the interior of b is less than the greater of the dimension
+ /// of the interior of a and the dimension of the interior of b
+ /// and the intersection of a and b is neither a nor b.
+ /// \remarks
+ /// A Point cannot cross another geometry because the
+ /// intersection of the Point with the other geometry is the
+ /// Point.
+ /// \n
+ /// Two MultiPoint geometries cannot cross one another because
+ /// the dimension of the intersection of their interiors, namely
+ /// the 0-dimension, is not less than the greater of the
+ /// dimensions of their interiors, namely the 0-dimension.
+ /// \n
+ /// [\link OGC99049 OGC99-049 \endlink] implicitly excludes a Crosses
+ /// relationship between 2 polygons. According to the definition,
+ /// the possibility of such a relationship would require that the
+ /// intersection of the interior of one polygon with that of
+ /// another be a Point or Line.
+ /// <h2>Illustration</h2>
+ /// d, e and f are MultiPoint geometries.
+ /// \n
+ /// \image html crosses.png
+ /// virtual bool Crosses(MgGeometry other);
+ /// virtual boolean Crosses(MgGeometry other);
+ /// one.
+ /// \return
+ /// True if this geometry spatially crosses the other geometry,
+ /// false otherwise.
+ virtual bool Crosses(MgGeometry* other);
+ /// \brief
+ /// Given 2 geometries a and b, a.Disjoint(b)is true if and only
+ /// if the intersection of a and b is empty.
+ /// virtual bool Disjoint(MgGeometry other);
+ /// virtual boolean Disjoint(MgGeometry other);
+ /// \return
+ /// True if this geometry is spatially disjoint from the other
+ /// geometry, false otherwise.
+ virtual bool Disjoint(MgGeometry* other);
+ /// \brief
+ /// a.Intersects(b) is true if and only if a.\link MgGeometry::Disjoint Disjoint \endlink(b)
+ /// is false.
+ /// virtual bool Intersects(MgGeometry other);
+ /// virtual boolean Intersects(MgGeometry other);
+ /// \return
+ /// True if this geometry is not disjoint with respect to the
+ /// other geometry, false otherwise.
+ virtual bool Intersects(MgGeometry* other);
+ /// \brief
+ /// Given 2 geometries a and b, a.Overlaps(b) is true if and only
+ /// if the dimension of the interior of a equals the dimension of
+ /// the interior of b equals the dimension of the intersection of
+ /// the interior of a and the interior of b and the intersection
+ /// of a and b is neither a nor b.
+ /// \remarks
+ /// A Point cannot overlap a Point, and a MultiPoint cannot
+ /// overlap a Point but a MultiPoint can overlap a MultiPoint.
+ /// c and d are MultiPoint geometries.
+ /// \image html overlaps.png
+ /// virtual bool Overlaps(MgGeometry other);
+ /// virtual boolean Overlaps(MgGeometry other);
+ /// \return
+ /// True if this geometry spatially overlaps the other geometry,
+ virtual bool Overlaps(MgGeometry* other);
+ /// \brief
+ /// Given 2 geometries a and b, a.Touches(b) is true if and only
+ /// if the intersection of the interior of a and the interior of
+ /// b is empty and the intersection of a and b is not empty.
+ /// \remarks
+ /// A Point cannot touch a Point because a Point has no boundary
+ /// and so the intersection of the interiors of the two
+ /// geometries is not empty.
+ /// \n
+ /// A Point can touch a non-closed Line at one of the end points
+ /// of the Line.
+ /// \n
+ /// A Point cannot touch a closed Line because all of the points
+ /// in the Line are interior to it.
+ /// e are MultiPoint geometries and f is a LineString.
+ /// \image html touches.png
+ /// virtual bool Touches(MgGeometry other);
+ /// virtual boolean Touches(MgGeometry other);
+ /// one.
+ /// \return
+ /// True if this geometry spatially touches the other geometry,
+ virtual bool Touches(MgGeometry* other);
+ /// \brief
+ /// Given 2 geometries a and b, a.Within(b) is true if and only
+ /// if the intersection of a and b is a and the intersection of
+ /// the interior of a and the interior of b is not empty.
+ /// \remarks
+ /// If the entire point-set of a geometry intersects the boundary
+ /// of another geometry, the former is not within the latter.
+ /// The end point of d and the end point of e intersect. a, b, i,
+ /// j, k, and m are MultiPoints. The concentric circles represent
+ /// intersecting points. The polygon n1n2n3n4 is within the
+ /// polygon p1p2p3p4 and vice versa. The LineString q1q2 is
+ /// within the LineString r1r2 and vice versa. The MultiPoint j
+ /// is within the MultiPoint k and vice versa. The Point f is
+ /// within the point g and vice versa.
+ /// \n
+ /// \image html within.png
+ /// virtual bool Within(MgGeometry other);
+ /// virtual boolean Within(MgGeometry other);
+ /// one.
+ /// \return
+ /// True if this geometry is spatially within the other geometry,
+ virtual bool Within(MgGeometry* other);
+INTERNAL_API:
+ static MgPreparedGeometry* Create(MgGeometry* geom);
+ /// \brief
+ /// Get the unique identifier for the class
+ /// \return
+ /// Class Identifider.
+ virtual INT32 GetClassId();
+private:
+ class PreparedGeometryImpl;
+ std::auto_ptr<PreparedGeometryImpl> d_ptr;
+ MgPreparedGeometry(PreparedGeometryImpl* impl);
+protected:
+ virtual ~MgPreparedGeometry();
+ /// \brief
+ /// Dispose this object.
+ virtual void Dispose();
+CLASS_ID:
+ static const INT32 m_cls_id = Geometry_PreparedGeometry;
+#endif
Modified: trunk/MgDev/Common/PlatformBase/Services/GeoJsonWriter.cpp
--- trunk/MgDev/Common/PlatformBase/Services/GeoJsonWriter.cpp 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Common/PlatformBase/Services/GeoJsonWriter.cpp 2017-07-11 15:44:27 UTC (rev 9230)
@@ -6,8 +6,14 @@
MgGeoJsonWriter::MgGeoJsonWriter()
m_agfRw = new MgAgfReaderWriter();
+ m_precisionEnabled = false;
+ m_precision = 7;
+INT32 MgGeoJsonWriter::GetPrecision() { return m_precision; }
+void MgGeoJsonWriter::SetPrecision(INT32 precision) { m_precision = precision; }
STRING MgGeoJsonWriter::FeatureToGeoJson(MgFeatureReader* featureReader, MgTransform* transform)
Ptr<MgClassDefinition> clsDef = featureReader->GetClassDefinition();
@@ -36,7 +42,7 @@
MG_TRY()
- CHECKARGUMENTNULL(reader, L"MgGeoJsonWriter.FeatureToGeoJson");
+ CHECKARGUMENTNULL(reader, L"MgGeoJsonWriter.FeatureToGeoJson");
if (!idPropertyName.empty())
idIndex = reader->GetPropertyIndex(idPropertyName);
@@ -67,7 +73,9 @@
geom = m_agfRw->Read(agf, transform);
else
geom = m_agfRw->Read(agf);
- ToGeoJson(geom, geomVal);
+ Ptr<MgGeometry> g = geom->Tessellate();
+ ToGeoJson(g, geomVal);
catch (MgException* ex)
@@ -97,7 +105,9 @@
else
@@ -166,6 +176,25 @@
return ret;
+STRING MgGeoJsonWriter::GeometryToGeoJson(MgGeometry* geom)
+ STRING ret;
+ MG_TRY()
+ ret = L"{ \"type\": \"Feature\", "; //START FEATURE
+ ret += L"\"properties\": {}, "; //PROPERTIES
+ STRING geomVal;
+ ret += geomVal; //GEOMETRY
+ ret += L"}"; //END FEATURE
+ MG_CATCH_AND_THROW(L"MgGeoJsonWriter.GeometryToGeoJson")
+ return ret;
void MgGeoJsonWriter::ValueToString(MgReader* reader, INT32 index, REFSTRING str)
INT32 propType = reader->GetPropertyType(index);
@@ -193,6 +222,7 @@
case MgPropertyType::Double:
double val = reader->GetDouble(index);
+ //NOTE: Not applying precision here as that is for coordinate output
MgUtil::DoubleToString(val, str);
break;
@@ -361,9 +391,17 @@
str = L"[";
STRING sx;
- MgUtil::DoubleToString(coord->GetX(), sx);
STRING sy;
- MgUtil::DoubleToString(coord->GetY(), sy);
+ if (m_precisionEnabled)
+ MgUtil::DoubleToString(coord->GetX(), sx, m_precision);
+ MgUtil::DoubleToString(coord->GetY(), sy, m_precision);
+ else
+ MgUtil::DoubleToString(coord->GetX(), sx);
+ MgUtil::DoubleToString(coord->GetY(), sy);
str += sx;
str += L", ";
str += sy;
@@ -383,9 +421,17 @@
str += L"[";
STRING sx;
STRING sy;
+ else
str += sx;
str += L", ";
str += sy;
@@ -506,4 +552,14 @@
void MgGeoJsonWriter::Dispose()
delete this;
+void MgGeoJsonWriter::SetPrecisionEnabled(bool enabled)
+ m_precisionEnabled = enabled;
+bool MgGeoJsonWriter::IsPrecisionEnabled()
+ return m_precisionEnabled;
Modified: trunk/MgDev/Common/PlatformBase/Services/GeoJsonWriter.h
--- trunk/MgDev/Common/PlatformBase/Services/GeoJsonWriter.h 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Common/PlatformBase/Services/GeoJsonWriter.h 2017-07-11 15:44:27 UTC (rev 9230)
@@ -108,6 +108,94 @@
STRING FeatureToGeoJson(MgReader* reader, MgTransform* transform, CREFSTRING idPropertyName, CREFSTRING geomPropName);
+ /// \brief
+ /// Sets the decimal precision to use when writing out coordinates. If you do not call this method, the default precision used is 7 decimal places.
+ /// Precision must be enabled in order for this setting to have any effect
+ /// void SetPrecision(int precision);
+ /// \param precision (int)
+ /// The decimal precision to write out coordinates
+ void SetPrecision(INT32 precision);
+ /// \brief
+ /// Gets the decimal precision to use when writing out coordinates
+ /// int GetPrecision();
+ /// \return
+ /// Returns the current precision
+ INT32 GetPrecision();
+ /// \brief
+ /// Sets whether to apply coordinate precision when writing out GeoJSON coordinates
+ /// void SetPrecisionEnabled(bool enabled);
+ /// void SetPrecisionEnabled(boolean enabled);
+ /// \param enabled (bool)
+ /// If true, enables coordinate precision. Otherwise disables it
+ /// \return
+ /// Returns the GeoJSON output as a string.
+ void SetPrecisionEnabled(bool enabled);
+ /// \brief
+ /// Gets whether coordinate precision is enabled
+ /// bool IsPrecisionEnabled();
+ /// boolean IsPrecisionEnabled();
+ /// \return
+ /// True if coordinate precision is enabled. False otherwise
+ bool IsPrecisionEnabled();
+INTERNAL_API:
+ STRING GeometryToGeoJson(MgGeometry* geom);
protected:
@@ -123,6 +211,8 @@
void MultiPolygonToGeoJson(MgMultiPolygon* multi, REFSTRING str);
Ptr<MgAgfReaderWriter> m_agfRw;
+ INT32 m_precision;
+ bool m_precisionEnabled;
Copied: trunk/MgDev/Common/Schema/GeometryInfo-3.3.0.xsd (from rev 9229, sandbox/jng/geoprocessing/Common/Schema/GeometryInfo-3.3.0.xsd)
--- trunk/MgDev/Common/Schema/GeometryInfo-3.3.0.xsd (rev 0)
+++ trunk/MgDev/Common/Schema/GeometryInfo-3.3.0.xsd 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,55 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" attributeFormDefault="unqualified">
+ <xs:element name="GeometryInfo">
+ <xs:annotation>
+ <xs:documentation>Geometry Information</xs:documentation>
+ </xs:annotation>
+ <xs:complexType>
+ <xs:sequence>
+ <xs:element name="Area" type="xs:double" />
+ <xs:element name="Dimension" type="xs:int" />
+ <xs:element name="Length" type="xs:double" />
+ <xs:element name="IsClosed" type="xs:boolean" />
+ <xs:element name="IsEmpty" type="xs:boolean" />
+ <xs:element name="IsSimple" type="xs:boolean" />
+ <xs:element name="IsValid" type="xs:boolean" />
+ <xs:element name="Envelope" type="Envelope" />
+ <xs:element name="Centroid" type="Coordinate" />
+ </xs:sequence>
+ </xs:complexType>
+ </xs:element>
+ <xs:complexType name="Coordinate">
+ <xs:annotation>
+ <xs:documentation>Represents a bounding box</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="X" type="xs:double">
+ <xs:annotation>
+ <xs:documentation>x-coordinate</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Y" type="xs:double">
+ <xs:annotation>
+ <xs:documentation>y-coordinate</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="Envelope">
+ <xs:annotation>
+ <xs:documentation>Represents a bounding box defined in terms of a lower left coordinate and an upper right coordinate</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="LowerLeft" type="Coordinate">
+ <xs:annotation>
+ <xs:documentation>Lower-left coordinate</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="UpperRight" type="Coordinate">
+ <xs:annotation>
+ <xs:documentation>Upper-right coordinate</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+</xs:schema>
Copied: trunk/MgDev/Common/Schema/UnitOfMeasure-3.3.0.xsd (from rev 9229, sandbox/jng/geoprocessing/Common/Schema/UnitOfMeasure-3.3.0.xsd)
--- trunk/MgDev/Common/Schema/UnitOfMeasure-3.3.0.xsd (rev 0)
+++ trunk/MgDev/Common/Schema/UnitOfMeasure-3.3.0.xsd 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,14 @@
+ <xs:element name="UnitOfMeasure">
+ <xs:annotation>
+ <xs:documentation>Unit of measure</xs:documentation>
+ </xs:annotation>
+ <xs:complexType>
+ <xs:sequence>
+ <xs:element name="Value" type="xs:double" />
+ <xs:element name="Unit" type="xs:string" />
+ </xs:sequence>
+ </xs:complexType>
+ </xs:element>
+</xs:schema>
Modified: trunk/MgDev/Server/src/UnitTesting/TestGeometry.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestGeometry.cpp 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Server/src/UnitTesting/TestGeometry.cpp 2017-07-11 15:44:27 UTC (rev 9230)
@@ -16,6 +16,7 @@
#include "MapGuideCommon.h"
+#include "ServiceManager.h"
#include "TestGeometry.h"
#include "CppUnitExtensions.h"
#include "FoundationDefs.h"
@@ -41,11 +42,97 @@
void TestGeometry::TestStart()
ACE_DEBUG((LM_INFO, ACE_TEXT("\nRunning Geometry tests. (Mentor)\n")));
+#ifdef TEST_PREPARED_GEOMETRY_PERF
+ try
+ MgServiceManager* serviceManager = MgServiceManager::GetInstance();
+ if (serviceManager == 0)
+ throw new MgNullReferenceException(L"TestGeometry::TestStart", __LINE__, __WFILE__, NULL, L"", NULL);
+ Ptr<MgResourceService> pService = dynamic_cast<MgResourceService*>(serviceManager->RequestService(MgServiceType::ResourceService));
+ if (pService == 0)
+ throw new MgServiceNotAvailableException(L"TestGeometry::TestStart", __LINE__, __WFILE__, NULL, L"", NULL);
+ //Set the user information for the current thread to be administrator
+ MgUserInformation::SetCurrentUserInfo(NULL);
+ Ptr<MgUserInformation> userInfo = new MgUserInformation(L"Administrator", L"admin");
+ if (userInfo != NULL)
+ userInfo->SetLocale(TEST_LOCALE);
+ MgUserInformation::SetCurrentUserInfo(userInfo);
+ MgResourceIdentifier resourceIdentifier1(L"Library://UnitTests/Data/Sheboygan_Parcels.FeatureSource");
+ #ifdef _WIN32
+ STRING resourceContentFileName1 = L"..\\UnitTestFiles\\Sheboygan_Parcels.FeatureSource";
+ STRING dataFileName1 = L"..\\UnitTestFiles\\Sheboygan_Parcels.sdf";
+ #else
+ STRING resourceContentFileName1 = L"../UnitTestFiles/Sheboygan_Parcels.FeatureSource";
+ STRING dataFileName1 = L"../UnitTestFiles/Sheboygan_Parcels.sdf";
+ #endif
+ //Add a new resource
+ Ptr<MgByteSource> contentSource1 = new MgByteSource(resourceContentFileName1);
+ Ptr<MgByteReader> contentReader1 = contentSource1->GetReader();
+ pService->SetResource(&resourceIdentifier1, contentReader1, NULL);
+ //Set the resource data
+ Ptr<MgByteSource> dataSource1 = new MgByteSource(dataFileName1);
+ Ptr<MgByteReader> dataReader1 = dataSource1->GetReader();
+ pService->SetResourceData(&resourceIdentifier1, L"Sheboygan_Parcels.sdf", L"File", dataReader1);
+ catch (MgException* e)
+ STRING message = e->GetDetails(TEST_LOCALE);
+ SAFE_RELEASE(e);
+ CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+#endif
void TestGeometry::TestEnd()
+ try
+ throw new MgNullReferenceException(L"TestFeatureService.TestEnd",
+ __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgServiceNotAvailableException(L"TestFeatureService.TestEnd",
+ // set user info
+ Ptr<MgResourceIdentifier> fsres1 = new MgResourceIdentifier(L"Library://UnitTests/Data/Sheboygan_Parcels.FeatureSource");
+ pService->DeleteResource(fsres1);
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
+#endif
ACE_DEBUG((LM_INFO, ACE_TEXT("\nGeometry tests completed.\n\n")));
@@ -1965,6 +2052,12 @@
CPPUNIT_ASSERT(touches);
touches = polygon->Touches(point);
+ Ptr<MgPreparedGeometry> ppoint = point->Prepare();
+ Ptr<MgPreparedGeometry> ppolygon = polygon->Prepare();
+ touches = ppoint->Touches(polygon);
+ CPPUNIT_ASSERT(touches);
+ touches = ppolygon->Touches(point);
//TEST 2
MgGeometryFactory factory;
@@ -1974,6 +2067,12 @@
CPPUNIT_ASSERT(!touches);
+ ppoint = point->Prepare();
+ ppolygon = polygon->Prepare();
+ CPPUNIT_ASSERT(!touches);
//TEST 3
Ptr<MgMultiPolygon> multiPolygon = CreateMultiPolygon();
@@ -1982,6 +2081,12 @@
touches = multiPolygon->Touches(point);
+ Ptr<MgPreparedGeometry> pmultiPolygon = multiPolygon->Prepare();
+ touches = ppoint->Touches(multiPolygon);
+ touches = pmultiPolygon->Touches(point);
//TEST 4
Ptr<MgCoordinateCollection> collection = new MgCoordinateCollection();
@@ -2015,6 +2120,9 @@
point = factory.CreatePoint(coord);
//TEST 5
coord1 = factory.CreateCoordinateXY( 45.0, 45.0);
@@ -2047,6 +2155,9 @@
touches = point->Touches(polygon);
//TEST 6
coord1 = factory.CreateCoordinateXY(100.0, 100.0);
@@ -2713,4 +2824,237 @@
throw;
+void TestGeometry::TestCase_PreparedGeometryPerformance()
+ try
+ throw new MgNullReferenceException(L"TestGeometry::TestCase_PreparedGeometry", __LINE__, __WFILE__, NULL, L"", NULL);
+ Ptr<MgFeatureService> pService = dynamic_cast<MgFeatureService*>(serviceManager->RequestService(MgServiceType::FeatureService));
+ throw new MgServiceNotAvailableException(L"TestGeometry::TestCase_PreparedGeometry", __LINE__, __WFILE__, NULL, L"", NULL);
+ Ptr<MgAgfReaderWriter> agfRw = new MgAgfReaderWriter();
+ Ptr<MgWktReaderWriter> wktRw = new MgWktReaderWriter();
+ STRING wkt = L"POLYGON ((-87.70660400390625 43.761672246385025, -87.7045440673828 43.76576337413024, -87.7093505859375 43.77196151943297, -87.71999359130858 43.7755561494101, -87.73458480834961 43.770350063442635, -87.73355484008789 43.76315996157264, -87.73853302001953 43.758820688867885, -87.73595809936523 43.74642103270366, -87.72789001464842 43.735135112939105, -87.71844863891602 43.73191017368391, -87.71175384521484 43.73575527365514, -87.70797729492188 43.739228054975506, -87.7090072631836 43.74158447044938, -87.71278381347655 43.739848173302434, -87.71724700927734 43.737615717267765, -87.72720336914062 43.7374916894919, -87.72926330566406 43.74567697163676, -87.7313232421875 43.75125720420175, -87.73149490356445 43.75931662167704, -87.72222518920898 43.76092837491792, -87.72136688232422 43.76787081559809, -87.71467208862305 43.76712702120528, -87.71175384521484 43.76092837491792, -87.70660400390625 43.761672246385025))";
+ Ptr<MgGeometry> testGeom = wktRw->Read(wkt);
+ Ptr<MgResourceIdentifier> resource = new MgResourceIdentifier();
+ STRING className = L"";
+ Ptr<MgFeatureQueryOptions> options = new MgFeatureQueryOptions();
+ CPPUNIT_ASSERT_THROW_MG(pService->SelectFeatures(resource, className, options), MgInvalidArgumentException*);
+ resource = new MgResourceIdentifier(L"Library://UnitTests/Data/Sheboygan_Parcels.FeatureSource");
+ className = L"Parcels";
+ Ptr<MgFeatureReader> reader = pService->SelectFeatures(resource, className, options);
+ Ptr<MgClassDefinition> clsDef = reader->GetClassDefinition();
+ STRING geomName = clsDef->GetDefaultGeometryPropertyName();
+ INT32 containsCount1 = 0;
+ INT32 crossesCount1 = 0;
+ INT32 disjointCount1 = 0;
+ INT32 intersectsCount1 = 0;
+ INT32 overlapsCount1 = 0;
+ INT32 touchesCount1 = 0;
+ INT32 withinCount1 = 0;
+ long lStart = GetTickCount();
+ while (reader->ReadNext())
+ try
+ Ptr<MgByteReader> agf = ((MgReader*)reader)->GetGeometry(geomName);
+ Ptr<MgGeometry> geom = agfRw->Read(agf);
+ if (testGeom->Contains(geom))
+ containsCount1++;
+ if (testGeom->Crosses(geom))
+ crossesCount1++;
+ if (testGeom->Disjoint(geom))
+ disjointCount1++;
+ if (testGeom->Intersects(geom))
+ intersectsCount1++;
+ if (testGeom->Overlaps(geom))
+ overlapsCount1++;
+ if (testGeom->Touches(geom))
+ touchesCount1++;
+ if (testGeom->Within(geom))
+ withinCount1++;
+ catch (MgException* ex)
+ SAFE_RELEASE(ex);
+ reader->Close();
+ ACE_DEBUG((LM_INFO, ACE_TEXT("\n\n Execution Time: = %6.4f (s)\n"), ((GetTickCount() - lStart) / 1000.0)));
+ ACE_DEBUG((LM_INFO, ACE_TEXT(" Contains: %d, Crosses: %d, Disjoint: %d, Intersects: %d, Overlaps: %d, Touches: %d, Within: %d\n"), containsCount1, crossesCount1, disjointCount1, intersectsCount1, overlapsCount1, touchesCount1, withinCount1));
+ //Now, with prepared geometry
+ Ptr<MgPreparedGeometry> prep = testGeom->Prepare();
+ reader = pService->SelectFeatures(resource, className, options);
+ INT32 containsCount2 = 0;
+ INT32 crossesCount2 = 0;
+ INT32 disjointCount2 = 0;
+ INT32 intersectsCount2 = 0;
+ INT32 overlapsCount2 = 0;
+ INT32 touchesCount2 = 0;
+ INT32 withinCount2 = 0;
+ lStart = GetTickCount();
+ try
+ if (prep->Contains(geom))
+ containsCount2++;
+ if (prep->Crosses(geom))
+ crossesCount2++;
+ if (prep->Disjoint(geom))
+ disjointCount2++;
+ if (prep->Intersects(geom))
+ intersectsCount2++;
+ if (prep->Overlaps(geom))
+ overlapsCount2++;
+ if (prep->Touches(geom))
+ touchesCount2++;
+ if (prep->Within(geom))
+ withinCount2++;
+ SAFE_RELEASE(ex);
+ reader->Close();
+ ACE_DEBUG((LM_INFO, ACE_TEXT("\n Execution Time: = %6.4f (s)\n"), ((GetTickCount() - lStart) / 1000.0)));
+ ACE_DEBUG((LM_INFO, ACE_TEXT(" Contains: %d, Crosses: %d, Disjoint: %d, Intersects: %d, Overlaps: %d, Touches: %d, Within: %d\n"), containsCount2, crossesCount2, disjointCount2, intersectsCount2, overlapsCount2, touchesCount2, withinCount2));
+ CPPUNIT_ASSERT(containsCount1 == containsCount2);
+ CPPUNIT_ASSERT(crossesCount2 == crossesCount2);
+ CPPUNIT_ASSERT(disjointCount2 == disjointCount2);
+ CPPUNIT_ASSERT(intersectsCount2 == intersectsCount2);
+ CPPUNIT_ASSERT(overlapsCount2 == overlapsCount2);
+ CPPUNIT_ASSERT(touchesCount2 == touchesCount2);
+ CPPUNIT_ASSERT(withinCount2 == withinCount2);
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
+void TestGeometry::TestCase_CurvePolygon_AsGeoJSON()
+ try
+ Ptr<MgGeometry> geom = wktRw->Read(L"CURVEPOLYGON ((0 0 (LINESTRINGSEGMENT (10 10, 10 20, 20 20), ARC (20 15, 10 10))), (0 0 (ARC (11 11, 12 12), LINESTRINGSEGMENT (10 10, 20 20, 40 40, 90 90))))");
+ Ptr<MgGeoJsonWriter> gw = new MgGeoJsonWriter();
+ STRING geoJson = gw->GeometryToGeoJson(geom);
+ CPPUNIT_ASSERT(geoJson.find(L"geometry\": null") == STRING::npos);
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
+void TestGeometry::TestCase_CurveString_AsGeoJSON()
+ try
+ Ptr<MgGeometry> geom = wktRw->Read(L"CURVESTRING (0 0 (CIRCULARARCSEGMENT (11 11, 12 12), LINESTRINGSEGMENT (10 10, 20 20, 30 40)))");
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
+void TestGeometry::TestCase_MultiCurvePolygon_AsGeoJSON()
+ try
+ Ptr<MgGeometry> geom = wktRw->Read(L"MULTICURVEPOLYGON (((0 0 (LINESTRINGSEGMENT (10 10, 10 20, 20 20), ARC (20 15, 10 10))), (0 0 (ARC (11 11, 12 12), LINESTRINGSEGMENT (10 10, 20 20, 40 40, 90 90)))),((0 0 (LINESTRINGSEGMENT (10 10, 10 20, 20 20), ARC (20 15, 10 10))), (0 0 (ARC (11 11, 12 12), LINESTRINGSEGMENT (10 10, 20 20, 40 40, 90 90)))))");
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
+void TestGeometry::TestCase_MultiCurveString_AsGeoJSON()
+ try
+ Ptr<MgGeometry> geom = wktRw->Read(L"MULTICURVESTRING ((0 0 (LINESTRINGSEGMENT (10 10, 20 20, 30 40))),(0 0 (ARC (11 11, 12 12), LINESTRINGSEGMENT (10 10, 20 20, 30 40))))");
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
Modified: trunk/MgDev/Server/src/UnitTesting/TestGeometry.h
--- trunk/MgDev/Server/src/UnitTesting/TestGeometry.h 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Server/src/UnitTesting/TestGeometry.h 2017-07-11 15:44:27 UTC (rev 9230)
@@ -20,6 +20,8 @@
#include <cppunit/extensions/HelperMacros.h>
+//#define TEST_PREPARED_GEOMETRY_PERF
#ifndef _WIN32
//Linux: different naming for string functions
#define stricmp strcasecmp
@@ -68,6 +70,15 @@
CPPUNIT_TEST(TestCase_Simplify_DP);
CPPUNIT_TEST(TestCase_Simplify_TP);
+ CPPUNIT_TEST(TestCase_CurveString_AsGeoJSON);
+ CPPUNIT_TEST(TestCase_CurvePolygon_AsGeoJSON);
+ CPPUNIT_TEST(TestCase_MultiCurvePolygon_AsGeoJSON);
+ CPPUNIT_TEST(TestCase_MultiCurveString_AsGeoJSON);
+ CPPUNIT_TEST(TestCase_PreparedGeometryPerformance);
+#endif
CPPUNIT_TEST(TestEnd); // This must be the very last unit test
CPPUNIT_TEST_SUITE_END();
@@ -116,6 +127,13 @@
void TestCase_Simplify_DP();
void TestCase_Simplify_TP();
+ void TestCase_CurveString_AsGeoJSON();
+ void TestCase_CurvePolygon_AsGeoJSON();
+ void TestCase_MultiCurvePolygon_AsGeoJSON();
+ void TestCase_MultiCurveString_AsGeoJSON();
+ void TestCase_PreparedGeometryPerformance();
MgPoint* CreatePoint();
MgLineString* CreateLineString();
MgLinearRing* CreateLinearRing();
Modified: trunk/MgDev/Server/src/UnitTesting/TestMisc.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestMisc.cpp 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Server/src/UnitTesting/TestMisc.cpp 2017-07-11 15:44:27 UTC (rev 9230)
@@ -643,4 +643,76 @@
throw;
+void TestMisc::TestCase_DoubleToStringWithDecimals()
+ try
+ double d = 1.23456789032748754;
+ std::string s;
+ STRING ws;
+ MgUtil::DoubleToString(d, ws, 4);
+ MgUtil::DoubleToString(d, s, 4);
+ CPPUNIT_ASSERT(L"1.2346" == ws);
+ CPPUNIT_ASSERT("1.2346" == s);
+ ws.clear();
+ s.clear();
+ MgUtil::DoubleToString(d, ws, 8);
+ MgUtil::DoubleToString(d, s, 8);
+ CPPUNIT_ASSERT(L"1.23456789" == ws);
+ CPPUNIT_ASSERT("1.23456789" == s);
+ ws.clear();
+ s.clear();
+ std::string s1;
+ STRING ws1;
+ //This should be the equivalent to not even passing in precision at all
+ MgUtil::DoubleToString(d, ws, -1);
+ MgUtil::DoubleToString(d, s, -1);
+ MgUtil::DoubleToString(d, ws1);
+ MgUtil::DoubleToString(d, s1);
+ CPPUNIT_ASSERT(ws1 == ws);
+ CPPUNIT_ASSERT(s1 == s);
+ double d1 = 1.1;
+ ws.clear();
+ s.clear();
+ MgUtil::DoubleToString(d1, ws, 4);
+ MgUtil::DoubleToString(d1, s, 4);
+ CPPUNIT_ASSERT(L"1.1" == ws);
+ CPPUNIT_ASSERT("1.1" == s);
+ double d2 = 123.3457483434945;
+ ws.clear();
+ s.clear();
+ MgUtil::DoubleToString(d2, ws, 8);
+ MgUtil::DoubleToString(d2, s, 8);
+ CPPUNIT_ASSERT(L"123.34574834" == ws);
+ CPPUNIT_ASSERT("123.34574834" == s);
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
Modified: trunk/MgDev/Server/src/UnitTesting/TestMisc.h
--- trunk/MgDev/Server/src/UnitTesting/TestMisc.h 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Server/src/UnitTesting/TestMisc.h 2017-07-11 15:44:27 UTC (rev 9230)
@@ -31,6 +31,7 @@
CPPUNIT_TEST(TestCase_1304);
CPPUNIT_TEST(TestCase_MapLayerCollections);
CPPUNIT_TEST(TestCase_ApiVersionCheck);
+ CPPUNIT_TEST(TestCase_DoubleToStringWithDecimals);
@@ -51,6 +52,7 @@
void TestCase_MapLayerCollections();
void TestCase_CreateMapWithInitialDisplayParams();
void TestCase_ApiVersionCheck();
+ void TestCase_DoubleToStringWithDecimals();
private:
Ptr<MgSiteConnection> m_siteConnection;
Copied: trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/binaryoperationform.html (from rev 9229, sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/binaryoperationform.html)
--- trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/binaryoperationform.html (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/binaryoperationform.html 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,44 @@
+<html>
+<head>
+<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
+<script type="text/javascript" src="setactiontarget.js" >
+</script>
+</head>
+<body>
+<form name="input" action="" method="get">
+<b>Operation:</b>
+<input type="text" name="OPERATION" value="GEO.BINARYOPERATION" size="50">
+<p> Version:
+<input type="text" name="VERSION" value="3.3.0" size="10">
+<p> Locale:
+<input type="text" name="LOCALE" value="en" size="10">
+<p> Client Agent:
+<input type="text" name="CLIENTAGENT" value="MapGuide Developer" size="100">
+<p> Geometry A (WKT):
+<input type="text" name="GEOMETRYA" value="" size="100">
+<p> Geometry B (WKT):
+<input type="text" name="GEOMETRYB" value="" size="100">
+<p> Operator:
+<select name="OPERATOR">
+ <option value="UNION">Union</option>
+ <option value="DIFFERENCE">Difference</option>
+ <option value="INTERSECTION">Intersection</option>
+ <option value="SYMMETRICDIFFERENCE">SymmetricDifference</option>
+</select>
+<p> Output Format:
+<select name="FORMAT">
+ <option value="WKT">Geometry Well-Known Text</option>
+ <option value="GEOJSON">GeoJSON</option>
+</select>
+<p> Input Coordinate System (CS-Map Code):
+<input type="text" name="COORDINATESYSTEM" value="" size="10">
+<p> Output Coordinate System (CS-Map Code):
+<input type="text" name="TRANSFORMTO" value="" size="10">
+<p> Coordinate Precision (if requesting GeoJSON):
+<input type="text" name="PRECISION" value="7" size="10">
+<p>
+<input type="submit" value="Submit" onclick="SetActionTarget()"> <input type="reset">
+</form>
+</body>
+</html>
+<html>
Copied: trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/boundaryform.html (from rev 9229, sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/boundaryform.html)
--- trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/boundaryform.html (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/boundaryform.html 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,35 @@
+<html>
+<head>
+</script>
+</head>
+<body>
+<b>Operation:</b>
+<input type="text" name="OPERATION" value="GEO.BOUNDARY" size="50">
+<p> Version:
+<p> Locale:
+<p> Client Agent:
+<p> Geometry (WKT):
+<input type="text" name="GEOMETRY" value="" size="100">
+<p> Output Format:
+</select>
+<p>
+</form>
+</body>
+</html>
+<html>
Copied: trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/bufferform.html (from rev 9229, sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/bufferform.html)
--- trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/bufferform.html (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/bufferform.html 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,44 @@
+<html>
+<head>
+</script>
+</head>
+<body>
+<b>Operation:</b>
+<input type="text" name="OPERATION" value="GEO.BUFFER" size="50">
+<p> Version:
+<p> Locale:
+<p> Client Agent:
+<p> Buffer Distance:
+<input type="text" name="DISTANCE" value="" size="10">
+<p> Buffer Units:
+<select name="UNITS">
+ <option value="mi">Miles</option>
+ <option value="km">Kilometers</option>
+ <option value="ft">Feet</option>
+ <option value="m">Meters</option>
+</select>
+<p> Output Format:
+</select>
+<p>
+</form>
+</body>
+</html>
+<html>
Copied: trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/convexhullform.html (from rev 9229, sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/convexhullform.html)
--- trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/convexhullform.html (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/convexhullform.html 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,35 @@
+<html>
+<head>
+</script>
+</head>
+<body>
+<b>Operation:</b>
+<input type="text" name="OPERATION" value="GEO.CONVEXHULL" size="50">
+<p> Version:
+<p> Locale:
+<p> Client Agent:
+<p> Output Format:
+</select>
+<p>
+</form>
+</body>
+</html>
+<html>
Copied: trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/distanceform.html (from rev 9229, sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/distanceform.html)
--- trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/distanceform.html (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/distanceform.html 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,35 @@
+<html>
+<head>
+</script>
+</head>
+<body>
+<b>Operation:</b>
+<input type="text" name="OPERATION" value="GEO.DISTANCE" size="50">
+<p> Version:
+<p> Locale:
+<p> Client Agent:
+<p> Other Geometry (WKT):
+<input type="text" name="OTHERGEOMETRY" value="" size="100">
+<p> Output Format:
+ <option value="text/xml">text/xml</option>
+ <option value="application/json">application/json</option>
+</select>
+<p>
+ Clean JSON: <input type="text" name="CLEAN" value="1" ID="TextClean">
+<p> Coordinate System (CS-Map Code, for non-linear measurment):
+<p>
+</form>
+</body>
+</html>
+<html>
Copied: trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/geometryinfoform.html (from rev 9229, sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/geometryinfoform.html)
--- trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/geometryinfoform.html (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/geometryinfoform.html 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,31 @@
+<html>
+<head>
+</script>
+</head>
+<body>
+<b>Operation:</b>
+<input type="text" name="OPERATION" value="GEO.GEOMETRYINFO" size="50">
+<p> Version:
+<p> Locale:
+<p> Client Agent:
+<p> Output Format:
+</select>
+<p>
+<p>
+</form>
+</body>
+</html>
+<html>
Copied: trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/geoprocessingapi.html (from rev 9229, sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/geoprocessingapi.html)
--- trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/geoprocessingapi.html (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/geoprocessingapi.html 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,31 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
+<html>
+ <head>
+ <title></title>
+ <meta name="GENERATOR" content="Microsoft Visual Studio .NET 7.1">
+ <meta name="vs_targetSchema" content="http://schemas.microsoft.com/intellisense/ie5">
+ <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
+ </head>
+ <body>
+ <UL>
+ <LI>
+ <A href="boundaryform.html" target="showform">Boundary</A>
+ <LI>
+ <A href="bufferform.html" target="showform">Buffer</A>
+ <LI>
+ <A href="convexhullform.html" target="showform">ConvexHull</A>
+ <LI>
+ <A href="distanceform.html" target="showform">Distance</A>
+ <LI>
+ <A href="geometryinfoform.html" target="showform">GeometryInfo</A>
+ <LI>
+ <A href="simplifyform.html" target="showform">Simplify</A>
+ <LI>
+ <A href="tessellateform.html" target="showform">Tessellate</A>
+ <LI>
+ <A href="binaryoperationform.html" target="showform">BinaryOperation</A>
+ <LI>
+ <A href="spatialpredicateform.html" target="showform">SpatialPredicate</A>
+ </UL>
+ </body>
+</html>
Modified: trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/selectaggregatesform.html
--- trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/selectaggregatesform.html 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/selectaggregatesform.html 2017-07-11 15:44:27 UTC (rev 9230)
@@ -37,6 +37,8 @@
</select>
<p>
Clean JSON: <input type="text" name="CLEAN" value="0" ID="TextClean">
+ <p> Coordinate Precision (if requesting clean JSON):
+ <input type="text" name="PRECISION" value="7" size="10">
<p>
</form>
Modified: trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/selectfeaturesform.html
--- trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/selectfeaturesform.html 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/selectfeaturesform.html 2017-07-11 15:44:27 UTC (rev 9230)
@@ -37,6 +37,8 @@
</select>
<p>
<p>
</form>
Modified: trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/services.html
--- trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/services.html 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/services.html 2017-07-11 15:44:27 UTC (rev 9230)
@@ -11,6 +11,7 @@
<b>Services API</b>
<li><a href="drawingserviceapi.html" target="apilist">Drawing</a></li>
<li><a href="featureserviceapi.html" target="apilist">Feature</a></li>
+<li><a href="geoprocessingapi.html" target="apilist">Geo-Processing</a></li>
<li><a href="mappingserviceapi.html" target="apilist">Mapping</a></li>
<li><a href="renderingserviceapi.html" target="apilist">Rendering</a></li>
<li><a href="resourceserviceapi.html" target="apilist">Resource</a></li>
Copied: trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/simplifyform.html (from rev 9229, sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/simplifyform.html)
--- trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/simplifyform.html (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/simplifyform.html 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,42 @@
+<html>
+<head>
+</script>
+</head>
+<body>
+<b>Operation:</b>
+<input type="text" name="OPERATION" value="GEO.SIMPLIFY" size="50">
+<p> Version:
+<p> Locale:
+<p> Client Agent:
+<p> Algorithm:
+<select name="ALGORITHM">
+ <option value="0">Douglas-Peucker</option>
+ <option value="1">Topology Preserving</option>
+</select>
+<p> Tolerance:
+<input type="text" name="TOLERANCE" value="" size="10">
+<p> Output Format:
+</select>
+<p>
+</form>
+</body>
+</html>
+<html>
Copied: trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/spatialpredicateform.html (from rev 9229, sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/spatialpredicateform.html)
--- trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/spatialpredicateform.html (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/spatialpredicateform.html 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,37 @@
+<html>
+<head>
+</script>
+</head>
+<body>
+<b>Operation:</b>
+<input type="text" name="OPERATION" value="GEO.SPATIALPREDICATE" size="50">
+<p> Version:
+<p> Locale:
+<p> Client Agent:
+<p> Operator:
+ <option value="CONTAINS">Contains</option>
+ <option value="CROSSES">Crosses</option>
+ <option value="DISJOINT">Disjoint</option>
+ <option value="EQUALS">Equals</option>
+ <option value="INTERSECTS">Intersects</option>
+ <option value="OVERLAPS">Overlaps</option>
+ <option value="TOUCHES">Touches</option>
+ <option value="WITHIN">Within</option>
+</select>
+<p>
+</form>
+</body>
+</html>
+<html>
Copied: trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/tessellateform.html (from rev 9229, sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/tessellateform.html)
--- trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/tessellateform.html (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/tessellateform.html 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,35 @@
+<html>
+<head>
+</script>
+</head>
+<body>
+<b>Operation:</b>
+<input type="text" name="OPERATION" value="GEO.TESSELLATE" size="50">
+<p> Version:
+<p> Locale:
+<p> Client Agent:
+<p> Output Format:
+</select>
+<p>
+</form>
+</body>
+</html>
+<html>
Modified: trunk/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryApiGen.xml
--- trunk/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryApiGen.xml 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryApiGen.xml 2017-07-11 15:44:27 UTC (rev 9230)
@@ -130,6 +130,7 @@
<Header path="../../../../Common/Geometry/PointCollection.h" />
<Header path="../../../../Common/Geometry/Polygon.h" />
<Header path="../../../../Common/Geometry/PolygonCollection.h" />
+ <Header path="../../../../Common/Geometry/PreparedGeometry.h" />
<Header path="../../../../Common/Geometry/Transform.h" />
<Header path="../../../../Common/Geometry/WktReaderWriter.h" />
Copied: trunk/MgDev/Web/src/HttpHandler/HttpGeoBinaryOperation.cpp (from rev 9229, sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBinaryOperation.cpp)
--- trunk/MgDev/Web/src/HttpHandler/HttpGeoBinaryOperation.cpp (rev 0)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGeoBinaryOperation.cpp 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,131 @@
+#include "HttpHandler.h"
+#include "HttpGeoBinaryOperation.h"
+HTTP_IMPLEMENT_CREATE_OBJECT(MgHttpGeoBinaryOperation)
+MgHttpGeoBinaryOperation::MgHttpGeoBinaryOperation(MgHttpRequest* hRequest)
+ InitializeCommonParameters(hRequest);
+ Ptr<MgHttpRequestParam> params = hRequest->GetRequestParam();
+ m_geomWKT_A = params->GetParameterValue(MgHttpResourceStrings::reqGeoA);
+ m_geomWKT_B = params->GetParameterValue(MgHttpResourceStrings::reqGeoB);
+ m_operator = params->GetParameterValue(MgHttpResourceStrings::reqGeoOperator);
+ m_format = params->GetParameterValue(MgHttpResourceStrings::reqGeoFormat);
+ m_coordinateSystem = params->GetParameterValue(MgHttpResourceStrings::reqGeoCoordinateSystem);
+ m_transformTo = params->GetParameterValue(MgHttpResourceStrings::reqGeoTransformTo);
+ m_precision = -1;
+ m_bEnablePrecision = false;
+ STRING sPrecision = params->GetParameterValue(MgHttpResourceStrings::reqGeoPrecision);
+ if (!sPrecision.empty())
+ INT32 precision = MgUtil::StringToInt32(sPrecision);
+ if (precision > 0)
+ m_precision = precision;
+ m_bEnablePrecision = true;
+void MgHttpGeoBinaryOperation::Execute(MgHttpResponse & hResponse)
+ Ptr<MgHttpResult> hResult = hResponse.GetResult();
+ MG_HTTP_HANDLER_TRY()
+ // Check common parameters
+ ValidateCommonParameters();
+ Ptr<MgGeometry> geomA = wktRw->Read(m_geomWKT_A);
+ Ptr<MgGeometry> geomB = wktRw->Read(m_geomWKT_B);
+ Ptr<MgGeometry> result;
+ if (m_operator == L"UNION")
+ result = geomA->Union(geomB);
+ else if (m_operator == L"DIFFERENCE")
+ result = geomA->Difference(geomB);
+ else if (m_operator == L"INTERSECTION")
+ result = geomA->Intersection(geomB);
+ else if (m_operator == L"SYMMETRICDIFFERENCE")
+ result = geomA->SymetricDifference(geomB);
+ else
+ MgStringCollection arguments;
+ arguments.Add(MgHttpResourceStrings::reqGeoOperator);
+ arguments.Add(m_operator);
+ throw new MgInvalidArgumentException(L"MgHttpGeoBinaryOperation.Execute",
+ __LINE__, __WFILE__, &arguments, L"MgInvalidFeatureSpatialOperation", NULL);
+ if (!m_transformTo.empty())
+ Ptr<MgCoordinateSystemFactory> csFactory = new MgCoordinateSystemFactory();
+ Ptr<MgCoordinateSystem> cs = csFactory->CreateFromCode(m_coordinateSystem);
+ Ptr<MgCoordinateSystem> target = csFactory->CreateFromCode(m_transformTo);
+ Ptr<MgCoordinateSystemTransform> xform = csFactory->GetTransform(cs, target);
+ Ptr<MgGeometry> xGeom = (MgGeometry*)result->Transform(xform);
+ result = xGeom;
+ if (m_format == L"WKT")
+ STRING wkt = wktRw->Write(result);
+ Ptr<MgHttpPrimitiveValue> value = new MgHttpPrimitiveValue(wkt);
+ hResult->SetResultObject(value, MgMimeType::Text);
+ else if (m_format == L"GEOJSON")
+ MgGeoJsonWriter gw;
+ gw.SetPrecisionEnabled(m_bEnablePrecision);
+ gw.SetPrecision(m_precision);
+ STRING geoJson = gw.GeometryToGeoJson(result);
+ std::string mbGeoJson;
+ MgUtil::WideCharToMultiByte(geoJson, mbGeoJson);
+ Ptr<MgByteSource> byteSource = new MgByteSource((BYTE_ARRAY_IN)mbGeoJson.c_str(), (INT32)mbGeoJson.length());
+ byteSource->SetMimeType(MgMimeType::Json);
+ Ptr<MgByteReader> byteReader = byteSource->GetReader();
+ hResult->SetResultObject(byteReader, byteReader->GetMimeType());
+ MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGeoBinaryOperation.Execute")
+void MgHttpGeoBinaryOperation::ValidateOperationVersion()
+ // There are multiple supported versions
+ INT32 version = m_userInfo->GetApiVersion();
+ if (version != MG_API_VERSION(3, 3, 0))
+ throw new MgInvalidOperationVersionException(
+ L"MgHttpGeoBinaryOperation.ValidateOperationVersion", __LINE__, __WFILE__, NULL, L"", NULL);
+ MG_HTTP_HANDLER_CATCH_AND_THROW(L"MgHttpGeoBinaryOperation.ValidateOperationVersion");
Copied: trunk/MgDev/Web/src/HttpHandler/HttpGeoBinaryOperation.h (from rev 9229, sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBinaryOperation.h)
--- trunk/MgDev/Web/src/HttpHandler/HttpGeoBinaryOperation.h (rev 0)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGeoBinaryOperation.h 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,66 @@
+#ifndef MG_HTTP_GEO_BINARY_OPERATION_H
+#define MG_HTTP_GEO_BINARY_OPERATION_H
+class MgHttpGeoBinaryOperation : public MgHttpRequestResponseHandler
+ HTTP_DECLARE_CREATE_OBJECT()
+public:
+ /// <summary>
+ /// Initializes the common parameters of the request.
+ /// </summary>
+ /// <param name="name">Input
+ /// MgHttpRequest
+ /// This contains all the parameters of the request.
+ /// </param>
+ /// <returns>
+ /// nothing
+ /// </returns>
+ MgHttpGeoBinaryOperation(MgHttpRequest *hRequest);
+ /// <summary>
+ /// Executes the specific request.
+ /// </summary>
+ /// <param name="hResponse">Input
+ /// This contains the response (including MgHttpResult and StatusCode) from the server.
+ /// </param>
+ void Execute(MgHttpResponse& hResponse);
+ /// <summary>
+ /// Returns the classification of this request/response handler
+ /// </summary>
+ /// <returns>
+ /// Classification of handler
+ /// </returns>
+ MgRequestClassification GetRequestClassification() { return MgHttpRequestResponseHandler::mrcViewer; }
+ virtual void ValidateOperationVersion();
+private:
+ STRING m_geomWKT_A;
+ STRING m_geomWKT_B;
+ STRING m_operator;
+ STRING m_format;
+ STRING m_coordinateSystem;
+ STRING m_transformTo;
+ bool m_bEnablePrecision;
+#endif
Copied: trunk/MgDev/Web/src/HttpHandler/HttpGeoBoundary.cpp (from rev 9229, sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBoundary.cpp)
--- trunk/MgDev/Web/src/HttpHandler/HttpGeoBoundary.cpp (rev 0)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGeoBoundary.cpp 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,118 @@
+#include "HttpGeoBoundary.h"
+HTTP_IMPLEMENT_CREATE_OBJECT(MgHttpGeoBoundary)
+MgHttpGeoBoundary::MgHttpGeoBoundary(MgHttpRequest* hRequest)
+ m_geomWKT = params->GetParameterValue(MgHttpResourceStrings::reqFeatGeometry);
+ m_precision = -1;
+void MgHttpGeoBoundary::Execute(MgHttpResponse & hResponse)
+ if (m_geomWKT.empty())
+ arguments.Add(MgHttpResourceStrings::reqFeatGeometry);
+ arguments.Add(MgResources::BlankArgument);
+ throw new MgInvalidArgumentException(L"MgHttpGeoBoundary.Execute",
+ __LINE__, __WFILE__, &arguments, L"MgStringEmpty", NULL);
+ Ptr<MgGeometry> input = wktRw->Read(m_geomWKT);
+ Ptr<MgGeometry> result = input->ConvexHull();
+ result = xGeom;
+ MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGeoBoundary.Execute")
+void MgHttpGeoBoundary::ValidateOperationVersion()
+ L"MgHttpGeoBoundary.ValidateOperationVersion", __LINE__, __WFILE__, NULL, L"", NULL);
+ MG_HTTP_HANDLER_CATCH_AND_THROW(L"MgHttpGeoBoundary.ValidateOperationVersion");
Copied: trunk/MgDev/Web/src/HttpHandler/HttpGeoBoundary.h (from rev 9229, sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBoundary.h)
--- trunk/MgDev/Web/src/HttpHandler/HttpGeoBoundary.h (rev 0)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGeoBoundary.h 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,65 @@
+#ifndef MG_HTTP_GEO_BOUNDARY_H
+#define MG_HTTP_GEO_BOUNDARY_H
+class MgHttpGeoBoundary : public MgHttpRequestResponseHandler
+public:
+ /// <summary>
+ /// </summary>
+ /// MgHttpRequest
+ /// </param>
+ /// <returns>
+ /// nothing
+ /// </returns>
+ MgHttpGeoBoundary(MgHttpRequest *hRequest);
+ /// <summary>
+ /// </summary>
+ /// </param>
+ /// <summary>
+ /// </summary>
+ /// <returns>
+ /// </returns>
+private:
+ STRING m_geomWKT;
+ STRING m_format;
+#endif
Copied: trunk/MgDev/Web/src/HttpHandler/HttpGeoBuffer.cpp (from rev 9229, sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBuffer.cpp)
--- trunk/MgDev/Web/src/HttpHandler/HttpGeoBuffer.cpp (rev 0)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGeoBuffer.cpp 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,153 @@
+#include "HttpGeoBuffer.h"
+HTTP_IMPLEMENT_CREATE_OBJECT(MgHttpGeoBuffer)
+MgHttpGeoBuffer::MgHttpGeoBuffer(MgHttpRequest* hRequest)
+ m_units = params->GetParameterValue(MgHttpResourceStrings::reqGeoBufferUnits);
+ m_distance = MgUtil::StringToDouble(params->GetParameterValue(MgHttpResourceStrings::reqGeoBufferDistance));
+ m_precision = -1;
+void MgHttpGeoBuffer::Execute(MgHttpResponse & hResponse)
+ throw new MgInvalidArgumentException(L"MgHttpGeoBuffer.Execute",
+ if (m_coordinateSystem.empty())
+ arguments.Add(MgHttpResourceStrings::reqGeoCoordinateSystem);
+ if (m_format != L"WKT" && m_format != L"GEOJSON")
+ arguments.Add(MgHttpResourceStrings::reqGeoFormat);
+ arguments.Add(m_format);
+ __LINE__, __WFILE__, &arguments, L"MgInvalidValueOutsideRange", NULL);
+ //Convert distance to meters
+ if (m_units == L"mi") //miles
+ m_distance *= 1609.35;
+ else if (m_units == L"km") //kilometers
+ m_distance *= 1000;
+ else if (m_units == L"ft") //feet
+ m_distance *= 0.30480;
+ Ptr<MgMeasure> measure = cs->GetMeasure();
+ double bufDist = cs->ConvertMetersToCoordinateSystemUnits(m_distance);
+ Ptr<MgGeometry> result = input->Buffer(bufDist, measure);
+ result = xGeom;
+ MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGeoBuffer.Execute")
+void MgHttpGeoBuffer::ValidateOperationVersion()
+ L"MgHttpGeoBuffer.ValidateOperationVersion", __LINE__, __WFILE__, NULL, L"", NULL);
+ MG_HTTP_HANDLER_CATCH_AND_THROW(L"MgHttpGeoBuffer.ValidateOperationVersion");
Copied: trunk/MgDev/Web/src/HttpHandler/HttpGeoBuffer.h (from rev 9229, sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBuffer.h)
--- trunk/MgDev/Web/src/HttpHandler/HttpGeoBuffer.h (rev 0)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGeoBuffer.h 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,67 @@
+#ifndef MG_HTTP_GEO_BUFFER_H
+#define MG_HTTP_GEO_BUFFER_H
+class MgHttpGeoBuffer : public MgHttpRequestResponseHandler
+public:
+ /// <summary>
+ /// </summary>
+ /// MgHttpRequest
+ /// </param>
+ /// <returns>
+ /// nothing
+ /// </returns>
+ MgHttpGeoBuffer(MgHttpRequest *hRequest);
+ /// <summary>
+ /// </summary>
+ /// </param>
+ /// <summary>
+ /// </summary>
+ /// <returns>
+ /// </returns>
+private:
+ STRING m_geomWKT;
+ STRING m_units;
+ double m_distance;
+ STRING m_format;
+#endif
\ No newline at end of file
Copied: trunk/MgDev/Web/src/HttpHandler/HttpGeoConvexHull.cpp (from rev 9229, sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoConvexHull.cpp)
--- trunk/MgDev/Web/src/HttpHandler/HttpGeoConvexHull.cpp (rev 0)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGeoConvexHull.cpp 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,118 @@
+#include "HttpGeoConvexHull.h"
+HTTP_IMPLEMENT_CREATE_OBJECT(MgHttpGeoConvexHull)
+MgHttpGeoConvexHull::MgHttpGeoConvexHull(MgHttpRequest* hRequest)
+ m_precision = -1;
+void MgHttpGeoConvexHull::Execute(MgHttpResponse & hResponse)
+ throw new MgInvalidArgumentException(L"MgHttpGeoConvexHull.Execute",
+ result = xGeom;
+ MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGeoConvexHull.Execute")
+void MgHttpGeoConvexHull::ValidateOperationVersion()
+ L"MgHttpGeoConvexHull.ValidateOperationVersion", __LINE__, __WFILE__, NULL, L"", NULL);
+ MG_HTTP_HANDLER_CATCH_AND_THROW(L"MgHttpGeoConvexHull.ValidateOperationVersion");
Copied: trunk/MgDev/Web/src/HttpHandler/HttpGeoConvexHull.h (from rev 9229, sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoConvexHull.h)
--- trunk/MgDev/Web/src/HttpHandler/HttpGeoConvexHull.h (rev 0)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGeoConvexHull.h 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,65 @@
+#ifndef MG_HTTP_GEO_CONVEX_HULL_H
+#define MG_HTTP_GEO_CONVEX_HULL_H
+class MgHttpGeoConvexHull : public MgHttpRequestResponseHandler
+public:
+ /// <summary>
+ /// </summary>
+ /// MgHttpRequest
+ /// </param>
+ /// <returns>
+ /// nothing
+ /// </returns>
+ MgHttpGeoConvexHull(MgHttpRequest *hRequest);
+ /// <summary>
+ /// </summary>
+ /// </param>
+ /// <summary>
+ /// </summary>
+ /// <returns>
+ /// </returns>
+private:
+ STRING m_geomWKT;
+ STRING m_format;
+#endif
Copied: trunk/MgDev/Web/src/HttpHandler/HttpGeoDistance.cpp (from rev 9229, sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoDistance.cpp)
--- trunk/MgDev/Web/src/HttpHandler/HttpGeoDistance.cpp (rev 0)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGeoDistance.cpp 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,125 @@
+#include "HttpGeoDistance.h"
+HTTP_IMPLEMENT_CREATE_OBJECT(MgHttpGeoDistance)
+MgHttpGeoDistance::MgHttpGeoDistance(MgHttpRequest* hRequest)
+ m_geomOther = params->GetParameterValue(MgHttpResourceStrings::reqFeatGeometryOther);
+void MgHttpGeoDistance::Execute(MgHttpResponse & hResponse)
+ throw new MgInvalidArgumentException(L"MgHttpGeoDistance.Execute",
+ if (m_geomOther.empty())
+ arguments.Add(MgHttpResourceStrings::reqFeatGeometryOther);
+ Ptr<MgGeometry> other = wktRw->Read(m_geomOther);
+ Ptr<MgCoordinateSystem> cs;
+ Ptr<MgMeasure> measure;
+ if (!m_coordinateSystem.empty())
+ cs = csFactory->CreateFromCode(m_coordinateSystem);
+ measure = cs->GetMeasure();
+ double distance = input->Distance(other, measure);
+ if (NULL != cs.p)
+ distance = cs->ConvertCoordinateSystemUnitsToMeters(distance);
+ std::string mbXml;
+ mbXml = "<?xml version=\"1.0\" encoding=\"utf-8\"?>";
+ mbXml += "<UnitOfMeasure xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"UnitOfMeasure-3.3.0.xsd\">";
+ mbXml += "<Value>";
+ std::string sDistance;
+ MgUtil::DoubleToString(distance, sDistance);
+ mbXml += sDistance;
+ mbXml += "</Value>";
+ if (NULL != measure.p) //If a measure was given, this will be in meters
+ mbXml += "<Unit>meters</Unit>";
+ else //Otherwise this is a linear distance measure. We don't know what the units are here
+ mbXml += "<Unit>unknown</Unit>";
+ mbXml += "</UnitOfMeasure>";
+ Ptr<MgByteSource> bs = new MgByteSource((BYTE_ARRAY_IN)mbXml.c_str(), (INT32)mbXml.length());
+ bs->SetMimeType(MgMimeType::Xml);
+ Ptr<MgByteReader> br = bs->GetReader();
+ //Convert to alternate response format, if necessary
+ ProcessFormatConversion(br);
+ hResult->SetResultObject(br, br->GetMimeType());
+ MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGeoDistance.Execute")
+void MgHttpGeoDistance::ValidateOperationVersion()
+ L"MgHttpGeoDistance.ValidateOperationVersion", __LINE__, __WFILE__, NULL, L"", NULL);
+ MG_HTTP_HANDLER_CATCH_AND_THROW(L"MgHttpGeoDistance.ValidateOperationVersion");
Copied: trunk/MgDev/Web/src/HttpHandler/HttpGeoDistance.h (from rev 9229, sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoDistance.h)
--- trunk/MgDev/Web/src/HttpHandler/HttpGeoDistance.h (rev 0)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGeoDistance.h 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,62 @@
+#ifndef MG_HTTP_GEO_DISTANCE_H
+#define MG_HTTP_GEO_DISTANCE_H
+class MgHttpGeoDistance : public MgHttpRequestResponseHandler
+public:
+ /// <summary>
+ /// </summary>
+ /// MgHttpRequest
+ /// </param>
+ /// <returns>
+ /// nothing
+ /// </returns>
+ MgHttpGeoDistance(MgHttpRequest *hRequest);
+ /// <summary>
+ /// </summary>
+ /// </param>
+ /// <summary>
+ /// </summary>
+ /// <returns>
+ /// </returns>
+private:
+ STRING m_geomWKT;
+ STRING m_geomOther;
+#endif
Copied: trunk/MgDev/Web/src/HttpHandler/HttpGeoSimplify.cpp (from rev 9229, sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoSimplify.cpp)
--- trunk/MgDev/Web/src/HttpHandler/HttpGeoSimplify.cpp (rev 0)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGeoSimplify.cpp 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,135 @@
+#include "HttpGeoSimplify.h"
+HTTP_IMPLEMENT_CREATE_OBJECT(MgHttpGeoSimplify)
+MgHttpGeoSimplify::MgHttpGeoSimplify(MgHttpRequest* hRequest)
+ m_algorithm = MgUtil::StringToInt32(params->GetParameterValue(MgHttpResourceStrings::reqGeoAlgorithm));
+ m_tolerance = MgUtil::StringToDouble(params->GetParameterValue(MgHttpResourceStrings::reqGeoTolerance));
+ m_precision = -1;
+void MgHttpGeoSimplify::Execute(MgHttpResponse & hResponse)
+ throw new MgInvalidArgumentException(L"MgHttpGeoSimplify.Execute",
+ if (m_algorithm != MgGeometrySimplificationAlgorithmType::DouglasPeucker &&
+ m_algorithm != MgGeometrySimplificationAlgorithmType::TopologyPreserving)
+ STRING arg;
+ MgUtil::Int32ToString(m_algorithm, arg);
+ arguments.Add(MgHttpResourceStrings::reqGeoAlgorithm);
+ arguments.Add(arg);
+ Ptr<MgGeometrySimplifier> simp = new MgGeometrySimplifier();
+ Ptr<MgGeometry> result = simp->Simplify(input, m_tolerance, m_algorithm);
+ result = xGeom;
+ MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGeoSimplify.Execute")
+void MgHttpGeoSimplify::ValidateOperationVersion()
+ L"MgHttpGeoSimplify.ValidateOperationVersion", __LINE__, __WFILE__, NULL, L"", NULL);
+ MG_HTTP_HANDLER_CATCH_AND_THROW(L"MgHttpGeoSimplify.ValidateOperationVersion");
Copied: trunk/MgDev/Web/src/HttpHandler/HttpGeoSimplify.h (from rev 9229, sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoSimplify.h)
--- trunk/MgDev/Web/src/HttpHandler/HttpGeoSimplify.h (rev 0)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGeoSimplify.h 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,67 @@
+#ifndef MG_HTTP_GEO_SIMPLIFY_H
+#define MG_HTTP_GEO_SIMPLIFY_H
+class MgHttpGeoSimplify : public MgHttpRequestResponseHandler
+public:
+ /// <summary>
+ /// </summary>
+ /// MgHttpRequest
+ /// </param>
+ /// <returns>
+ /// nothing
+ /// </returns>
+ MgHttpGeoSimplify(MgHttpRequest *hRequest);
+ /// <summary>
+ /// </summary>
+ /// </param>
+ /// <summary>
+ /// </summary>
+ /// <returns>
+ /// </returns>
+private:
+ STRING m_geomWKT;
+ INT32 m_algorithm;
+ double m_tolerance;
+ STRING m_format;
+#endif
Copied: trunk/MgDev/Web/src/HttpHandler/HttpGeoSpatialPredicate.cpp (from rev 9229, sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoSpatialPredicate.cpp)
--- trunk/MgDev/Web/src/HttpHandler/HttpGeoSpatialPredicate.cpp (rev 0)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGeoSpatialPredicate.cpp 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,93 @@
+// Copyright (C) 2004-2017 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#include "HttpGeoSpatialPredicate.h"
+HTTP_IMPLEMENT_CREATE_OBJECT(MgHttpGeoSpatialPredicate)
+MgHttpGeoSpatialPredicate::MgHttpGeoSpatialPredicate(MgHttpRequest* hRequest)
+void MgHttpGeoSpatialPredicate::Execute(MgHttpResponse & hResponse)
+ bool result = false;
+ if (m_operator == L"CONTAINS")
+ result = geomA->Contains(geomB);
+ else if (m_operator == L"CROSSES")
+ result = geomA->Crosses(geomB);
+ else if (m_operator == L"DISJOINT")
+ result = geomA->Disjoint(geomB);
+ else if (m_operator == L"EQUALS")
+ result = geomA->Equals(geomB);
+ else if (m_operator == L"INTERSECTS")
+ result = geomA->Intersects(geomB);
+ else if (m_operator == L"OVERLAPS")
+ result = geomA->Overlaps(geomB);
+ else if (m_operator == L"TOUCHES")
+ result = geomA->Touches(geomB);
+ else if (m_operator == L"WITHIN")
+ result = geomA->Within(geomB);
+ else
+ throw new MgInvalidArgumentException(L"MgHttpGeoSpatialPredicate.Execute",
+ Ptr<MgHttpPrimitiveValue> value = new MgHttpPrimitiveValue(result);
+ MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGeoSpatialPredicate.Execute")
+void MgHttpGeoSpatialPredicate::ValidateOperationVersion()
+ L"MgHttpGeoSpatialPredicate.ValidateOperationVersion", __LINE__, __WFILE__, NULL, L"", NULL);
+ MG_HTTP_HANDLER_CATCH_AND_THROW(L"MgHttpGeoSpatialPredicate.ValidateOperationVersion");
Copied: trunk/MgDev/Web/src/HttpHandler/HttpGeoSpatialPredicate.h (from rev 9229, sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoSpatialPredicate.h)
--- trunk/MgDev/Web/src/HttpHandler/HttpGeoSpatialPredicate.h (rev 0)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGeoSpatialPredicate.h 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,62 @@
+#ifndef MG_HTTP_GEO_SPATIAL_PREDICATE_H
+#define MG_HTTP_GEO_SPATIAL_PREDICATE_H
+class MgHttpGeoSpatialPredicate : public MgHttpRequestResponseHandler
+public:
+ /// <summary>
+ /// </summary>
+ /// MgHttpRequest
+ /// </param>
+ /// <returns>
+ /// nothing
+ /// </returns>
+ MgHttpGeoSpatialPredicate(MgHttpRequest *hRequest);
+ /// <summary>
+ /// </summary>
+ /// </param>
+ /// <summary>
+ /// </summary>
+ /// <returns>
+ /// </returns>
+private:
+#endif
Copied: trunk/MgDev/Web/src/HttpHandler/HttpGeoTessellate.cpp (from rev 9229, sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoTessellate.cpp)
--- trunk/MgDev/Web/src/HttpHandler/HttpGeoTessellate.cpp (rev 0)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGeoTessellate.cpp 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,118 @@
+#include "HttpGeoTessellate.h"
+HTTP_IMPLEMENT_CREATE_OBJECT(MgHttpGeoTessellate)
+MgHttpGeoTessellate::MgHttpGeoTessellate(MgHttpRequest* hRequest)
+ m_precision = -1;
+void MgHttpGeoTessellate::Execute(MgHttpResponse & hResponse)
+ throw new MgInvalidArgumentException(L"MgHttpGeoTessellate.Execute",
+ Ptr<MgGeometry> result = input->Tessellate();
+ result = xGeom;
+ MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGeoTessellate.Execute")
+void MgHttpGeoTessellate::ValidateOperationVersion()
+ L"MgHttpGeoTessellate.ValidateOperationVersion", __LINE__, __WFILE__, NULL, L"", NULL);
+ MG_HTTP_HANDLER_CATCH_AND_THROW(L"MgHttpGeoTessellate.ValidateOperationVersion");
Copied: trunk/MgDev/Web/src/HttpHandler/HttpGeoTessellate.h (from rev 9229, sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoTessellate.h)
--- trunk/MgDev/Web/src/HttpHandler/HttpGeoTessellate.h (rev 0)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGeoTessellate.h 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,65 @@
+#ifndef MG_HTTP_GEO_TESSELLATE_H
+#define MG_HTTP_GEO_TESSELLATE_H
+class MgHttpGeoTessellate : public MgHttpRequestResponseHandler
+public:
+ /// <summary>
+ /// </summary>
+ /// MgHttpRequest
+ /// </param>
+ /// <returns>
+ /// nothing
+ /// </returns>
+ MgHttpGeoTessellate(MgHttpRequest *hRequest);
+ /// <summary>
+ /// </summary>
+ /// </param>
+ /// <summary>
+ /// </summary>
+ /// <returns>
+ /// </returns>
+private:
+ STRING m_geomWKT;
+ STRING m_format;
+#endif
Copied: trunk/MgDev/Web/src/HttpHandler/HttpGeometryInfo.cpp (from rev 9229, sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeometryInfo.cpp)
--- trunk/MgDev/Web/src/HttpHandler/HttpGeometryInfo.cpp (rev 0)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGeometryInfo.cpp 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,161 @@
+#include "HttpGeometryInfo.h"
+HTTP_IMPLEMENT_CREATE_OBJECT(MgHttpGeometryInfo)
+MgHttpGeometryInfo::MgHttpGeometryInfo(MgHttpRequest* hRequest)
+void MgHttpGeometryInfo::Execute(MgHttpResponse & hResponse)
+ throw new MgInvalidArgumentException(L"MgHttpGeometryInfo.Execute",
+ //Collect all geometry information
+ double area = input->GetArea();
+ INT32 dim = input->GetDimension();
+ double length = input->GetLength();
+ bool isClosed = input->IsClosed();
+ bool isEmpty = input->IsEmpty();
+ bool isSimple = input->IsSimple();
+ bool isValid = input->IsValid();
+ Ptr<MgEnvelope> env = input->Envelope();
+ Ptr<MgPoint> centroid = input->GetCentroid();
+ Ptr<MgCoordinate> cCentroid = centroid->GetCoordinate();
+ Ptr<MgCoordinate> envLL = env->GetLowerLeftCoordinate();
+ Ptr<MgCoordinate> envUR = env->GetUpperRightCoordinate();
+ mbXml += "<GeometryInfo xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"GeometryInfo-3.3.0.xsd\">";
+ mbXml += "<Area>";
+ std::string sArea;
+ MgUtil::DoubleToString(area, sArea);
+ mbXml += sArea;
+ mbXml += "</Area>";
+ mbXml += "<Dimension>";
+ std::string sDim;
+ MgUtil::Int32ToString(dim, sDim);
+ mbXml += sDim;
+ mbXml += "</Dimension>";
+ mbXml += "<Length>";
+ std::string sLen;
+ MgUtil::DoubleToString(length, sLen);
+ mbXml += sLen;
+ mbXml += "</Length>";
+ mbXml += "<IsClosed>";
+ mbXml += (isClosed ? "true" : "false");
+ mbXml += "</IsClosed>";
+ mbXml += "<IsEmpty>";
+ mbXml += (isEmpty ? "true" : "false");
+ mbXml += "</IsEmpty>";
+ mbXml += "<IsSimple>";
+ mbXml += (isSimple ? "true" : "false");
+ mbXml += "</IsSimple>";
+ mbXml += "<IsValid>";
+ mbXml += (isValid ? "true" : "false");
+ mbXml += "</IsValid>";
+ mbXml += "<Envelope>";
+ mbXml += "<LowerLeft>";
+ mbXml += "<X>";
+ std::string sLLX;
+ MgUtil::DoubleToString(envLL->GetX(), sLLX);
+ mbXml += sLLX;
+ mbXml += "</X>";
+ mbXml += "<Y>";
+ std::string sLLY;
+ MgUtil::DoubleToString(envLL->GetY(), sLLY);
+ mbXml += sLLY;
+ mbXml += "</Y>";
+ mbXml += "</LowerLeft>";
+ mbXml += "<UpperRight>";
+ mbXml += "<X>";
+ std::string sURX;
+ MgUtil::DoubleToString(envUR->GetX(), sURX);
+ mbXml += sURX;
+ mbXml += "</X>";
+ mbXml += "<Y>";
+ std::string sURY;
+ MgUtil::DoubleToString(envUR->GetY(), sURY);
+ mbXml += sURY;
+ mbXml += "</Y>";
+ mbXml += "</UpperRight>";
+ mbXml += "</Envelope>";
+ mbXml += "<Centroid>";
+ mbXml += "<X>";
+ std::string sCentX;
+ MgUtil::DoubleToString(cCentroid->GetX(), sCentX);
+ mbXml += sCentX;
+ mbXml += "</X>";
+ mbXml += "<Y>";
+ std::string sCentY;
+ MgUtil::DoubleToString(cCentroid->GetY(), sCentY);
+ mbXml += sCentY;
+ mbXml += "</Y>";
+ mbXml += "</Centroid>";
+ mbXml += "</GeometryInfo>";
+ MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGeometryInfo.Execute")
+void MgHttpGeometryInfo::ValidateOperationVersion()
+ L"MgHttpGeometryInfo.ValidateOperationVersion", __LINE__, __WFILE__, NULL, L"", NULL);
+ MG_HTTP_HANDLER_CATCH_AND_THROW(L"MgHttpGeometryInfo.ValidateOperationVersion");
Copied: trunk/MgDev/Web/src/HttpHandler/HttpGeometryInfo.h (from rev 9229, sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeometryInfo.h)
--- trunk/MgDev/Web/src/HttpHandler/HttpGeometryInfo.h (rev 0)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGeometryInfo.h 2017-07-11 15:44:27 UTC (rev 9230)
@@ -0,0 +1,60 @@
+#ifndef MG_HTTP_GEOMETRY_INFO_H
+#define MG_HTTP_GEOMETRY_INFO_H
+class MgHttpGeometryInfo : public MgHttpRequestResponseHandler
+public:
+ /// <summary>
+ /// </summary>
+ /// MgHttpRequest
+ /// </param>
+ /// <returns>
+ /// nothing
+ /// </returns>
+ MgHttpGeometryInfo(MgHttpRequest *hRequest);
+ /// <summary>
+ /// </summary>
+ /// </param>
+ /// <summary>
+ /// </summary>
+ /// <returns>
+ /// </returns>
+private:
+ STRING m_geomWKT;
+#endif
Modified: trunk/MgDev/Web/src/HttpHandler/HttpHandler.vcxproj
--- trunk/MgDev/Web/src/HttpHandler/HttpHandler.vcxproj 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Web/src/HttpHandler/HttpHandler.vcxproj 2017-07-11 15:44:27 UTC (rev 9230)
@@ -210,6 +210,18 @@
<ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">true</ExcludedFromBuild>
<ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|x64'">true</ExcludedFromBuild>
</ClCompile>
+ <ClCompile Include="HttpGeoBoundary.cpp">
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|x64'">true</ExcludedFromBuild>
+ </ClCompile>
+ <ClCompile Include="HttpGeoConvexHull.cpp">
+ </ClCompile>
<ClCompile Include="HttpCopyResource.cpp">
@@ -282,6 +294,48 @@
</ClCompile>
+ <ClCompile Include="HttpGeoBinaryOperation.cpp">
+ </ClCompile>
+ <ClCompile Include="HttpGeoBuffer.cpp">
+ </ClCompile>
+ <ClCompile Include="HttpGeoDistance.cpp">
+ </ClCompile>
+ <ClCompile Include="HttpGeometryInfo.cpp">
+ </ClCompile>
+ <ClCompile Include="HttpGeoSimplify.cpp">
+ </ClCompile>
+ <ClCompile Include="HttpGeoSpatialPredicate.cpp">
+ </ClCompile>
+ <ClCompile Include="HttpGeoTessellate.cpp">
+ </ClCompile>
<ClCompile Include="HttpGetRepositoryContent.cpp">
@@ -945,6 +999,8 @@
<ItemGroup>
<ClInclude Include="HttpApplyResourcePackage.h" />
<ClInclude Include="HttpChangeResourceOwner.h" />
+ <ClInclude Include="HttpGeoBoundary.h" />
+ <ClInclude Include="HttpGeoConvexHull.h" />
<ClInclude Include="HttpCopyResource.h" />
<ClInclude Include="HttpCreateRepository.h" />
<ClInclude Include="HttpCreateRuntimeMap.h" />
@@ -957,6 +1013,13 @@
<ClInclude Include="HttpEnumerateResourceReferences.h" />
<ClInclude Include="HttpEnumerateResources.h" />
<ClInclude Include="HttpEnumerateUnmanagedData.h" />
+ <ClInclude Include="HttpGeoBuffer.h" />
+ <ClInclude Include="HttpGeoBinaryOperation.h" />
+ <ClInclude Include="HttpGeoDistance.h" />
+ <ClInclude Include="HttpGeometryInfo.h" />
+ <ClInclude Include="HttpGeoSimplify.h" />
+ <ClInclude Include="HttpGeoSpatialPredicate.h" />
+ <ClInclude Include="HttpGeoTessellate.h" />
<ClInclude Include="HttpGetRepositoryContent.h" />
<ClInclude Include="HttpGetRepositoryHeader.h" />
<ClInclude Include="HttpGetResourceContent.h" />
Modified: trunk/MgDev/Web/src/HttpHandler/HttpHandler.vcxproj.filters
--- trunk/MgDev/Web/src/HttpHandler/HttpHandler.vcxproj.filters 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Web/src/HttpHandler/HttpHandler.vcxproj.filters 2017-07-11 15:44:27 UTC (rev 9230)
@@ -40,6 +40,9 @@
<Filter Include="Byte Source Adapters">
<UniqueIdentifier>{0f2e34d9-18f7-49af-b11f-8d3c874192ec}</UniqueIdentifier>
</Filter>
+ <Filter Include="GeoProcessing">
+ <UniqueIdentifier>{d7514524-5f3c-40fd-8b93-45a3020d8614}</UniqueIdentifier>
+ </Filter>
</ItemGroup>
<ItemGroup>
<ClCompile Include="HttpApplyResourcePackage.cpp">
@@ -386,6 +389,33 @@
<ClCompile Include="HttpDescribeRuntimeMap.cpp">
<Filter>Mapping Service</Filter>
</ClCompile>
+ <Filter>GeoProcessing</Filter>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
</ItemGroup>
<ItemGroup>
<ClInclude Include="HttpApplyResourcePackage.h">
@@ -757,6 +787,33 @@
<ClInclude Include="HttpDescribeRuntimeMap.h">
</ClInclude>
+ <ClInclude Include="HttpGeoBuffer.h">
+ </ClInclude>
+ <ClInclude Include="HttpGeoSimplify.h">
+ </ClInclude>
+ <ClInclude Include="HttpGeoSpatialPredicate.h">
+ </ClInclude>
+ <ClInclude Include="HttpGeoBinaryOperation.h">
+ </ClInclude>
+ <ClInclude Include="HttpGeoDistance.h">
+ </ClInclude>
+ <ClInclude Include="HttpGeoConvexHull.h">
+ </ClInclude>
+ <ClInclude Include="HttpGeometryInfo.h">
+ </ClInclude>
+ <ClInclude Include="HttpGeoTessellate.h">
+ </ClInclude>
+ <ClInclude Include="HttpGeoBoundary.h">
+ </ClInclude>
</ItemGroup>
<ItemGroup>
<ResourceCompile Include="HttpHandler.rc" />
Modified: trunk/MgDev/Web/src/HttpHandler/HttpHandlerBuild.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpHandlerBuild.cpp 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Web/src/HttpHandler/HttpHandlerBuild.cpp 2017-07-11 15:44:27 UTC (rev 9230)
@@ -55,6 +55,15 @@
#include "HttpEnumerateApplicationTemplates.cpp"
#include "HttpEnumerateApplicationWidgets.cpp"
#include "HttpEnumerateApplicationContainers.cpp"
+#include "HttpGeoBoundary.cpp"
+#include "HttpGeoBuffer.cpp"
+#include "HttpGeoBinaryOperation.cpp"
+#include "HttpGeoConvexHull.cpp"
+#include "HttpGeoDistance.cpp"
+#include "HttpGeometryInfo.cpp"
+#include "HttpGeoSimplify.cpp"
+#include "HttpGeoSpatialPredicate.cpp"
+#include "HttpGeoTessellate.cpp"
#include "HttpGetCapabilities.cpp"
#include "HttpGetConnectionPropertyValues.cpp"
#include "HttpGetDefaultTileSizeX.cpp"
Modified: trunk/MgDev/Web/src/HttpHandler/HttpRequest.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpRequest.cpp 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Web/src/HttpHandler/HttpRequest.cpp 2017-07-11 15:44:27 UTC (rev 9230)
@@ -124,6 +124,17 @@
#include "HttpCsGetBaseLibrary.h"
#include "HttpCsIsValid.h"
+// Geo-Processing
#include <algorithm>
using namespace std;
@@ -431,6 +442,15 @@
httpClassCreators[MgHttpResourceStrings::opEnumerateApplicationContainers] = MgHttpEnumerateApplicationContainers::CreateObject;
httpClassCreators[MgHttpResourceStrings::opGetDefaultTileSizeX] = MgHttpGetDefaultTileSizeX::CreateObject;
httpClassCreators[MgHttpResourceStrings::opGetDefaultTileSizeY] = MgHttpGetDefaultTileSizeY::CreateObject;
+ httpClassCreators[MgHttpResourceStrings::opGeoBoundary] = MgHttpGeoBoundary::CreateObject;
+ httpClassCreators[MgHttpResourceStrings::opGeoBuffer] = MgHttpGeoBuffer::CreateObject;
+ httpClassCreators[MgHttpResourceStrings::opGeoBinaryOperation] = MgHttpGeoBinaryOperation::CreateObject;
+ httpClassCreators[MgHttpResourceStrings::opGeoConvexHull] = MgHttpGeoConvexHull::CreateObject;
+ httpClassCreators[MgHttpResourceStrings::opGeoDistance] = MgHttpGeoDistance::CreateObject;
+ httpClassCreators[MgHttpResourceStrings::opGeometryInfo] = MgHttpGeometryInfo::CreateObject;
+ httpClassCreators[MgHttpResourceStrings::opGeoSimplify] = MgHttpGeoSimplify::CreateObject;
+ httpClassCreators[MgHttpResourceStrings::opGeoSpatialPredicate] = MgHttpGeoSpatialPredicate::CreateObject;
+ httpClassCreators[MgHttpResourceStrings::opGeoTessellate] = MgHttpGeoTessellate::CreateObject;
httpPostHandlerCreators.push_back(MgHttpWfsGetCapabilities::ProcessPostRequest);
httpPostHandlerCreators.push_back(MgHttpWfsDescribeFeatureType::ProcessPostRequest);
Modified: trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.cpp 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.cpp 2017-07-11 15:44:27 UTC (rev 9230)
@@ -149,6 +149,7 @@
const STRING MgHttpResourceStrings::reqFeatGeomProperty = L"GEOMPROPERTY";
const STRING MgHttpResourceStrings::reqFeatSpatialOp = L"SPATIALOP";
const STRING MgHttpResourceStrings::reqFeatGeometry = L"GEOMETRY";
+const STRING MgHttpResourceStrings::reqFeatGeometryOther = L"OTHERGEOMETRY";
const STRING MgHttpResourceStrings::reqFeatProperties = L"PROPERTIES";
const STRING MgHttpResourceStrings::reqFeatActiveOnly = L"ACTIVEONLY";
const STRING MgHttpResourceStrings::reqFeatComputedProperties = L"COMPUTED_PROPERTIES";
@@ -363,6 +364,29 @@
const STRING MgHttpResourceStrings::opEnumerateApplicationWidgets = L"ENUMERATEAPPLICATIONWIDGETS";
const STRING MgHttpResourceStrings::opEnumerateApplicationContainers = L"ENUMERATEAPPLICATIONCONTAINERS";
+// Geo-Processing Operations
+const STRING MgHttpResourceStrings::opGeoBoundary = L"GEO.BOUNDARY";
+const STRING MgHttpResourceStrings::opGeoBuffer = L"GEO.BUFFER";
+const STRING MgHttpResourceStrings::opGeoConvexHull = L"GEO.CONVEXHULL";
+const STRING MgHttpResourceStrings::opGeoDistance = L"GEO.DISTANCE";
+const STRING MgHttpResourceStrings::opGeometryInfo = L"GEO.GEOMETRYINFO";
+const STRING MgHttpResourceStrings::opGeoSimplify = L"GEO.SIMPLIFY";
+const STRING MgHttpResourceStrings::opGeoSpatialPredicate = L"GEO.SPATIALPREDICATE";
+const STRING MgHttpResourceStrings::opGeoTessellate = L"GEO.TESSELLATE";
+const STRING MgHttpResourceStrings::opGeoBinaryOperation = L"GEO.BINARYOPERATION";
+const STRING MgHttpResourceStrings::reqGeoA = L"GEOMETRYA";
+const STRING MgHttpResourceStrings::reqGeoB = L"GEOMETRYB";
+const STRING MgHttpResourceStrings::reqGeoBufferDistance = L"DISTANCE";
+const STRING MgHttpResourceStrings::reqGeoBufferUnits = L"UNITS";
+const STRING MgHttpResourceStrings::reqGeoOperator = L"OPERATOR";
+const STRING MgHttpResourceStrings::reqGeoCoordinateSystem = L"COORDINATESYSTEM";
+const STRING MgHttpResourceStrings::reqGeoFormat = L"FORMAT";
+const STRING MgHttpResourceStrings::reqGeoTransformTo = L"TRANSFORMTO";
+const STRING MgHttpResourceStrings::reqGeoAlgorithm = L"ALGORITHM";
+const STRING MgHttpResourceStrings::reqGeoTolerance = L"TOLERANCE";
+const STRING MgHttpResourceStrings::reqGeoPrecision = L"PRECISION";
// Coordinate System Request Parameters
const STRING MgHttpResourceStrings::reqCsWkt = L"CSWKT";
const STRING MgHttpResourceStrings::reqCsCode = L"CSCODE";
Modified: trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.h
--- trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.h 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.h 2017-07-11 15:44:27 UTC (rev 9230)
@@ -125,6 +125,7 @@
static const STRING reqFeatGeomProperty;
static const STRING reqFeatSpatialOp;
static const STRING reqFeatGeometry;
+ static const STRING reqFeatGeometryOther;
static const STRING reqFeatActiveOnly;
static const STRING reqFeatComputedProperties;
static const STRING reqFeatComputedAliases;
@@ -367,7 +368,29 @@
static const STRING opEnumerateApplicationWidgets;
static const STRING opEnumerateApplicationContainers;
+ // Geo-Processing Operations
+ static const STRING opGeoBoundary;
+ static const STRING opGeoBuffer;
+ static const STRING opGeoConvexHull;
+ static const STRING opGeoDistance;
+ static const STRING opGeometryInfo;
+ static const STRING opGeoSimplify;
+ static const STRING opGeoSpatialPredicate;
+ static const STRING opGeoTessellate;
+ static const STRING opGeoBinaryOperation;
+ static const STRING reqGeoA;
+ static const STRING reqGeoB;
+ static const STRING reqGeoBufferDistance;
+ static const STRING reqGeoBufferUnits;
+ static const STRING reqGeoOperator;
+ static const STRING reqGeoCoordinateSystem;
+ static const STRING reqGeoFormat;
+ static const STRING reqGeoTransformTo;
+ static const STRING reqGeoAlgorithm;
+ static const STRING reqGeoTolerance;
+ static const STRING reqGeoPrecision;
static const STRING reqCsWkt;
static const STRING reqCsCode;
Modified: trunk/MgDev/Web/src/HttpHandler/HttpSelectFeatures.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpSelectFeatures.cpp 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Web/src/HttpHandler/HttpSelectFeatures.cpp 2017-07-11 15:44:27 UTC (rev 9230)
@@ -42,6 +42,19 @@
//Default to xml if not specified
if (m_responseFormat.empty())
m_responseFormat = MgMimeType::Xml;
+ m_precision = -1;
/// <summary>
@@ -110,7 +123,7 @@
Ptr<MgFeatureReader> featureReader = service->SelectFeatures(&resId, m_className, qryOptions);
//MgByteSource owns this and will clean it up when done
- ByteSourceImpl* bsImpl = new MgReaderByteSourceImpl(featureReader, m_responseFormat, m_bCleanJson);
+ ByteSourceImpl* bsImpl = new MgReaderByteSourceImpl(featureReader, m_responseFormat, m_bCleanJson, m_bEnablePrecision, m_precision);
Ptr<MgByteSource> byteSource = new MgByteSource(bsImpl);
byteSource->SetMimeType(m_responseFormat);
Modified: trunk/MgDev/Web/src/HttpHandler/HttpSelectFeatures.h
--- trunk/MgDev/Web/src/HttpHandler/HttpSelectFeatures.h 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Web/src/HttpHandler/HttpSelectFeatures.h 2017-07-11 15:44:27 UTC (rev 9230)
@@ -46,6 +46,8 @@
private:
STRING m_resId;
STRING m_className;
+ INT32 m_precision;
#endif // _FS_SELECT_FEATURES_H
Modified: trunk/MgDev/Web/src/HttpHandler/HttpSelectFeaturesSpatially.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpSelectFeaturesSpatially.cpp 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Web/src/HttpHandler/HttpSelectFeaturesSpatially.cpp 2017-07-11 15:44:27 UTC (rev 9230)
@@ -52,6 +52,19 @@
+ m_precision = -1;
/// <summary>
@@ -120,7 +133,7 @@
Ptr<MgDataReader> dataReader = service->SelectAggregate(&resId, m_className, qryOptions);
- ByteSourceImpl* bsImpl = new MgReaderByteSourceImpl(dataReader, m_responseFormat, m_bCleanJson);
+ ByteSourceImpl* bsImpl = new MgReaderByteSourceImpl(dataReader, m_responseFormat, m_bCleanJson, m_bEnablePrecision, m_precision);
Modified: trunk/MgDev/Web/src/HttpHandler/HttpSelectFeaturesSpatially.h
--- trunk/MgDev/Web/src/HttpHandler/HttpSelectFeaturesSpatially.h 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Web/src/HttpHandler/HttpSelectFeaturesSpatially.h 2017-07-11 15:44:27 UTC (rev 9230)
@@ -49,6 +49,8 @@
STRING m_geometry;
STRING m_geometryClass;
INT32 m_operation;
#endif // _FS_SELECT_FEATURES_SPATIALLY_H
Modified: trunk/MgDev/Web/src/HttpHandler/Makefile.am
--- trunk/MgDev/Web/src/HttpHandler/Makefile.am 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Web/src/HttpHandler/Makefile.am 2017-07-11 15:44:27 UTC (rev 9230)
@@ -54,6 +54,15 @@
HttpEnumerateApplicationContainers.cpp \
HttpEnumerateApplicationWidgets.cpp \
HttpEnumerateApplicationTemplates.cpp \
+ HttpGeoBinaryOperation.cpp \
+ HttpGeoBoundary.cpp \
+ HttpGeoBuffer.cpp \
+ HttpGeoConvexHull.cpp \
+ HttpGeoDistance.cpp \
+ HttpGeometryInfo.cpp \
+ HttpGeoSimplify.cpp \
+ HttpGeoSpatialPredicate.cpp \
+ HttpGeoTessellate.cpp \
HttpGetCapabilities.cpp \
HttpGetClassDefinition.cpp \
HttpGetClasses.cpp \
@@ -179,6 +188,15 @@
HttpEnumerateApplicationContainers.h \
HttpEnumerateApplicationWidgets.h \
HttpEnumerateApplicationTemplates.h \
+ HttpGeoBinaryOperation.h \
+ HttpGeoBoundary.h \
+ HttpGeoBuffer.h \
+ HttpGeoConvexHull.h \
+ HttpGeoDistance.h \
+ HttpGeometryInfo.h \
+ HttpGeoSimplify.h \
+ HttpGeoSpatialPredicate.h \
+ HttpGeoTessellate.h \
HttpGetCapabilities.h \
HttpGetClassDefinition.h \
HttpGetClasses.h \
Modified: trunk/MgDev/Web/src/HttpHandler/ReaderByteSourceImpl.cpp
--- trunk/MgDev/Web/src/HttpHandler/ReaderByteSourceImpl.cpp 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Web/src/HttpHandler/ReaderByteSourceImpl.cpp 2017-07-11 15:44:27 UTC (rev 9230)
@@ -17,7 +17,7 @@
#include "ReaderByteSourceImpl.h"
#include "PlatformBase.h"
-MgReaderByteSourceImpl::MgReaderByteSourceImpl(MgReader* reader, CREFSTRING format, bool bCleanJson)
+MgReaderByteSourceImpl::MgReaderByteSourceImpl(MgReader* reader, CREFSTRING format, bool bCleanJson, bool bEnablePrecision, INT32 precision)
m_reader = SAFE_ADDREF(reader);
m_format = format;
@@ -27,6 +27,8 @@
m_bInternalReaderHasMore = true;
m_bFirstRecord = true;
m_bCleanJson = bCleanJson;
+ m_bEnablePrecision = bEnablePrecision;
MgReaderByteSourceImpl::~MgReaderByteSourceImpl()
@@ -167,6 +169,8 @@
if (m_bCleanJson)
MgGeoJsonWriter geoJsonWriter;
+ geoJsonWriter.SetPrecisionEnabled(m_bEnablePrecision);
+ geoJsonWriter.SetPrecision(m_precision);
STRING sGeoJson;
if (m_reader->GetReaderType() == MgReaderType::FeatureReader)
Modified: trunk/MgDev/Web/src/HttpHandler/ReaderByteSourceImpl.h
--- trunk/MgDev/Web/src/HttpHandler/ReaderByteSourceImpl.h 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Web/src/HttpHandler/ReaderByteSourceImpl.h 2017-07-11 15:44:27 UTC (rev 9230)
@@ -29,7 +29,7 @@
DECLARE_CLASSNAME(MgReaderByteSourceImpl)
public:
- MgReaderByteSourceImpl(MgReader* reader, CREFSTRING format, bool bCleanJson);
+ MgReaderByteSourceImpl(MgReader* reader, CREFSTRING format, bool bCleanJson, bool bEnablePrecision, INT32 precision);
virtual ~MgReaderByteSourceImpl();
@@ -89,9 +89,11 @@
bool m_bReadHeader;
bool m_bInternalReaderHasMore;
bool m_bFirstRecord;
std::string m_buf;
INT32 m_bufOffset;
#endif
Modified: trunk/MgDev/Web/src/HttpHandler/XmlJsonConvert.cpp
--- trunk/MgDev/Web/src/HttpHandler/XmlJsonConvert.cpp 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Web/src/HttpHandler/XmlJsonConvert.cpp 2017-07-11 15:44:27 UTC (rev 9230)
@@ -944,6 +944,22 @@
s_elementPathTypeMap["/ClassDefinition/Properties/Property/HasMeasure"] = XML_DATA_TYPE_BOOLEAN;
s_elementPathTypeMap["/ClassDefinition/Properties/Property/DefaultImageXSize"] = XML_DATA_TYPE_NUM_INT;
s_elementPathTypeMap["/ClassDefinition/Properties/Property/DefaultImageYSize"] = XML_DATA_TYPE_NUM_INT;
+ //UnitOfMeasure-3.3.0.xsd
+ s_elementPathTypeMap["/UnitOfMeasure/Value"] = XML_DATA_TYPE_NUM_DOUBLE;
+ //GeometryInfo-3.3.0.xsd
+ s_elementPathTypeMap["/GeometryInfo/Area"] = XML_DATA_TYPE_NUM_DOUBLE;
+ s_elementPathTypeMap["/GeometryInfo/Dimension"] = XML_DATA_TYPE_NUM_INT;
+ s_elementPathTypeMap["/GeometryInfo/Length"] = XML_DATA_TYPE_NUM_DOUBLE;
+ s_elementPathTypeMap["/GeometryInfo/IsClosed"] = XML_DATA_TYPE_BOOLEAN;
+ s_elementPathTypeMap["/GeometryInfo/IsEmpty"] = XML_DATA_TYPE_BOOLEAN;
+ s_elementPathTypeMap["/GeometryInfo/IsSimple"] = XML_DATA_TYPE_BOOLEAN;
+ s_elementPathTypeMap["/GeometryInfo/IsValid"] = XML_DATA_TYPE_BOOLEAN;
+ s_elementPathTypeMap["/GeometryInfo/Envelope/LowerLeft/X"] = XML_DATA_TYPE_NUM_DOUBLE;
+ s_elementPathTypeMap["/GeometryInfo/Envelope/LowerLeft/Y"] = XML_DATA_TYPE_NUM_DOUBLE;
+ s_elementPathTypeMap["/GeometryInfo/Envelope/UpperRight/X"] = XML_DATA_TYPE_NUM_DOUBLE;
+ s_elementPathTypeMap["/GeometryInfo/Envelope/UpperRight/Y"] = XML_DATA_TYPE_NUM_DOUBLE;
+ s_elementPathTypeMap["/GeometryInfo/Centroid/X"] = XML_DATA_TYPE_NUM_DOUBLE;
+ s_elementPathTypeMap["/GeometryInfo/Centroid/Y"] = XML_DATA_TYPE_NUM_DOUBLE;
//Miscellaneous MapGuide response types that don't have a formal schema
s_elementPathTypeMap["/SessionTimeout/Value"] = XML_DATA_TYPE_NUM_INT;
s_elementPathTypeMap["/FeatureInformation/SelectedFeatures/SelectedLayer/LayerMetadata/Property/Type"] = XML_DATA_TYPE_NUM_INT;
Modified: trunk/MgDev/Web/src/MapGuideApi/MapGuideApiGen.xml
--- trunk/MgDev/Web/src/MapGuideApi/MapGuideApiGen.xml 2017-06-28 15:18:59 UTC (rev 9229)
+++ trunk/MgDev/Web/src/MapGuideApi/MapGuideApiGen.xml 2017-07-11 15:44:27 UTC (rev 9230)
@@ -213,6 +213,7 @@
<Header path="../../../Common/Geometry/PointCollection.h" />
<Header path="../../../Common/Geometry/Polygon.h" />
<Header path="../../../Common/Geometry/PolygonCollection.h" />
+ <Header path="../../../Common/Geometry/PreparedGeometry.h" />
<Header path="../../../Common/Geometry/Transform.h" />
<Header path="../../../Common/Geometry/WktReaderWriter.h" />
More information about the mapguide-commits
