[mapguide-commits] r9196 - in sandbox/jng/utfgrid: Common/Renderers Server/src/UnitTesting UnitTest/TestData/TileService
svn_mapguide at osgeo.org
Fri Jun 2 06:24:15 PDT 2017
Author: jng
Date: 2017-06-02 06:24:15 -0700 (Fri, 02 Jun 2017)
New Revision: 9196
sandbox/jng/utfgrid/Common/Renderers/UTFGridRenderer.cpp
sandbox/jng/utfgrid/Common/Renderers/agg_utfgrid_context.h
sandbox/jng/utfgrid/Server/src/UnitTesting/TestRenderingService.cpp
sandbox/jng/utfgrid/UnitTest/TestData/TileService/UT_RoadCenterLines.ldf
- Add tooltip for UT_RoadCenterLines layer
- Setup a separate MgMap instance for XYZ/UTFGrid rendering that includes the tooltipped UT_RoadCenterLines
- Fix lines not rendering in UTFGrid content
Modified: sandbox/jng/utfgrid/Common/Renderers/UTFGridRenderer.cpp
--- sandbox/jng/utfgrid/Common/Renderers/UTFGridRenderer.cpp 2017-05-31 15:30:41 UTC (rev 9195)
+++ sandbox/jng/utfgrid/Common/Renderers/UTFGridRenderer.cpp 2017-06-02 13:24:15 UTC (rev 9196)
@@ -172,12 +172,12 @@
m_renderThisFeature = m_content->AddFeature(m_layerInfo, m_currentColor, feature, tooltip, url);
-void UTFGridRenderer::ProcessPolygon(LineBuffer * lb, RS_FillStyle & fill)
+void UTFGridRenderer::ProcessPolygon(LineBuffer * lb, RS_FillStyle & /*fill*/)
if (!m_renderThisFeature)
return;
- DrawScreenPolygon(lb, &m_xform, fill.color().argb());
+ DrawScreenPolygon(lb, &m_xform, m_currentColor);
void UTFGridRenderer::ProcessPolyline(LineBuffer * lb, RS_LineStroke & /*lsym*/)
@@ -185,6 +185,7 @@
return;
+ m_lineStroke.color = m_currentColor;
DrawScreenPolyline(lb, &m_xform, m_lineStroke);
@@ -483,7 +484,7 @@
if (srclb->geom_count() == 0)
return;
- double weightpx = rs_max(1.0, lineStroke.weight);
+ double weightpx = rs_max(1.0, lineStroke.weight) / c->m_resolution;
// add to the agg path storage - here it doesn't matter
// how many geometries there are in the line buffer,
@@ -530,16 +531,15 @@
break;
+ c->rasterizer.reset();
+ c->rasterizer.filling_rule(agg::fill_even_odd);
c->rasterizer.add_path(stroke);
- c->rasterizer.filling_rule(agg::fill_non_zero);
c->renderer_scanline.color(utfpix32(UTFGridContent::EncodeChar(lineStroke.color)));
agg::render_scanlines(c->rasterizer, c->scanline_utf, c->renderer_scanline);
- c->rasterizer.filling_rule(agg::fill_even_odd);
-void UTFGridRenderer::DrawScreenPolygon(LineBuffer * polygon, const SE_Matrix * xform, unsigned int /*fill*/)
+void UTFGridRenderer::DrawScreenPolygon(LineBuffer * polygon, const SE_Matrix * xform, unsigned int fill)
// if you have no geoms, why do you call us at all?
if (polygon->geom_count() == 0)
@@ -554,7 +554,7 @@
m_context->rasterizer.reset();
m_context->rasterizer.add_path(m_context->ps, pathids[i]);
- m_context->renderer_scanline.color(utfpix32(UTFGridContent::EncodeChar(m_currentColor)));
+ m_context->renderer_scanline.color(utfpix32(UTFGridContent::EncodeChar(fill)));
agg::render_scanlines(m_context->rasterizer, m_context->scanline_utf, m_context->renderer_scanline);
Modified: sandbox/jng/utfgrid/Common/Renderers/agg_utfgrid_context.h
--- sandbox/jng/utfgrid/Common/Renderers/agg_utfgrid_context.h 2017-05-31 15:30:41 UTC (rev 9195)
+++ sandbox/jng/utfgrid/Common/Renderers/agg_utfgrid_context.h 2017-06-02 13:24:15 UTC (rev 9196)
@@ -50,8 +50,9 @@
public:
agg_utfgrid_context(int width, int height, unsigned int resolution)
- int bufWidth = width / resolution;
- int bufHeight = height / resolution;
+ m_resolution = resolution;
+ int bufWidth = width / m_resolution;
+ int bufHeight = height / m_resolution;
size_t len = bufWidth * bufHeight * sizeof(utfgrid_band_type);
m_rows = new utfgrid_band_type[len];
@@ -70,6 +71,7 @@
// rendering buffer
+ unsigned int m_resolution;
utfgrid_band_type* m_rows; //Not owned by this
bool ownrows;
utfgrid_rendering_buffer rendering_buffer;
Modified: sandbox/jng/utfgrid/Server/src/UnitTesting/TestRenderingService.cpp
--- sandbox/jng/utfgrid/Server/src/UnitTesting/TestRenderingService.cpp 2017-05-31 15:30:41 UTC (rev 9195)
+++ sandbox/jng/utfgrid/Server/src/UnitTesting/TestRenderingService.cpp 2017-06-02 13:24:15 UTC (rev 9196)
@@ -107,6 +107,12 @@
Ptr<MgByteReader> mdfrdr1 = mdfsrc1->GetReader();
m_svcResource->SetResource(mapres1, mdfrdr1, NULL);
+ // publish tile set
+ Ptr<MgResourceIdentifier> tilesetres1 = new MgResourceIdentifier(L"Library://UnitTests/TileSets/XYZ.TileSetDefinition");
+ Ptr<MgByteSource> tsdsrc1 = new MgByteSource(L"../UnitTestFiles/UT_XYZ.tsd", false);
+ Ptr<MgByteReader> tsdrdr1 = tsdsrc1->GetReader();
+ m_svcResource->SetResource(tilesetres1, tsdrdr1, NULL);
// publish the layer definitions
Ptr<MgResourceIdentifier> ldfres1 = new MgResourceIdentifier(L"Library://UnitTests/Layers/HydrographicPolygons.LayerDefinition");
Ptr<MgByteSource> ldfsrc1 = new MgByteSource(L"../UnitTestFiles/UT_HydrographicPolygons.ldf", false);
@@ -446,6 +452,10 @@
Ptr<MgResourceIdentifier> mapres1 = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan.MapDefinition");
m_svcResource->DeleteResource(mapres1);
+ // delete tile set
+ m_svcResource->DeleteResource(tilesetres1);
// delete the layer definitions
m_svcResource->DeleteResource(ldfres1);
@@ -1349,6 +1359,29 @@
return map;
+MgMap* TestRenderingService::CreateTestXYZMap()
+ Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/BaseMap.MapDefinition");
+ MgMap* map = new MgMap(m_siteConnection);
+ map->Create(mdfres, L"UnitTestSheboyganXYZ");
+ Ptr<MgLayerCollection> layers = map->GetLayers();
+ Ptr<MgLayerGroupCollection> groups = map->GetLayerGroups();
+ Ptr<MgLayerBase> roads = layers->GetItem(L"RoadCenterLines");
+ Ptr<MgLayerGroup> baseGroup = groups->GetItem(L"BaseLayers");
+ roads->SetGroup(baseGroup);
+ Ptr<MgCoordinate> coordNewCenter = new MgCoordinateXY(-87.733253, 43.746199);
+ Ptr<MgPoint> ptNewCenter = new MgPoint(coordNewCenter);
+ map->SetViewCenter(ptNewCenter);
+ map->SetViewScale(75000.0);
+ map->SetDisplayDpi(96);
+ map->SetDisplayWidth(1024);
+ map->SetDisplayHeight(1024);
+ return map;
MgMap* TestRenderingService::CreateTestTiledMap()
@@ -1765,7 +1798,7 @@
try
- Ptr<MgMap> map = CreateTestTiledMap();
+ Ptr<MgMap> map = CreateTestXYZMap();
//For ease of visual verfication, render the XYZ image tiles as baseline
Ptr<MgByteReader> imgTL = m_svcRendering->RenderTileXYZ(map, L"BaseLayers", 16797, 23893, 16, 96, MgImageFormats::Png);
Modified: sandbox/jng/utfgrid/UnitTest/TestData/TileService/UT_RoadCenterLines.ldf
--- sandbox/jng/utfgrid/UnitTest/TestData/TileService/UT_RoadCenterLines.ldf 2017-05-31 15:30:41 UTC (rev 9195)
+++ sandbox/jng/utfgrid/UnitTest/TestData/TileService/UT_RoadCenterLines.ldf 2017-06-02 13:24:15 UTC (rev 9196)
@@ -5,6 +5,7 @@
<FeatureName>Default:RoadCenterLines</FeatureName>
<FeatureNameType>FeatureClass</FeatureNameType>
<Geometry>Geometry</Geometry>
+ <ToolTip>NAME</ToolTip>
<VectorScaleRange>
<LineTypeStyle>
<LineRule>
More information about the mapguide-commits
