[mapguide-commits] r9206 - in sandbox/jng/geoprocessing: Common/PlatformBase/Services UnitTest/WebTier/MapAgent/MapAgentForms Web/src/HttpHandler
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat Jun 10 02:44:55 PDT 2017
Author: jng
Date: 2017-06-10 02:44:55 -0700 (Sat, 10 Jun 2017)
New Revision: 9206
Added:
   sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/binaryoperationform.html
   sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/bufferform.html
   sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/geoprocessingapi.html
   sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/simplifyform.html
   sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/spatialpredicateform.html
   sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBinaryOperation.cpp
   sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBinaryOperation.h
   sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBuffer.cpp
   sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBuffer.h
   sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoSimplify.cpp
   sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoSimplify.h
   sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoSpatialPredicate.cpp
   sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoSpatialPredicate.h
   sandbox/jng/geoprocessing/Common/PlatformBase/Services/GeoJsonWriter.cpp
   sandbox/jng/geoprocessing/Common/PlatformBase/Services/GeoJsonWriter.h
   sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/services.html
   sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandler.vcxproj
   sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandler.vcxproj.filters
   sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandlerBuild.cpp
   sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpRequest.cpp
   sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpResourceStrings.cpp
   sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpResourceStrings.h
   sandbox/jng/geoprocessing/Web/src/HttpHandler/Makefile.am
Implement mapagent operations for geo-processing:
 - GEO.BUFFER
   - Buffers the given input geometry (in WKT) with the desired distance as WKT or GeoJSON with optional transformation
 - GEO.SIMPLIFY
   - Simplifies the given input geometry (in WKT) with the simplification algorithm (Douglas-Peucker or Topology-Preserving) as WKT or GeoJSON with optional transformation
 - GEO.SPATIALPREDICATE
   - Tests if the given 2 input geometries (in WKT) satisifes the given spatial predicate operator
 - GEO.BINARYOPERATION
   - Performs the given operation against the 2 input geometries (in WKT) as WKT or GeoJSON with optional transformation
This includes mapagent forms to exercise said operations
Modified: sandbox/jng/geoprocessing/Common/PlatformBase/Services/GeoJsonWriter.cpp
--- sandbox/jng/geoprocessing/Common/PlatformBase/Services/GeoJsonWriter.cpp	2017-06-09 13:54:30 UTC (rev 9205)
+++ sandbox/jng/geoprocessing/Common/PlatformBase/Services/GeoJsonWriter.cpp	2017-06-10 09:44:55 UTC (rev 9206)
@@ -166,6 +166,24 @@
     return ret;
+STRING MgGeoJsonWriter::GeometryToGeoJson(MgGeometry* geom)
+    STRING ret;
+    MG_TRY()
+    ret = L"{ \"type\": \"Feature\", "; //START FEATURE
+    ret += L"\"properties\": {}, "; //PROPERTIES
+    STRING geomVal;
+    ToGeoJson(geom, geomVal);
+    ret += geomVal; //GEOMETRY
+    ret += L"}"; //END FEATURE
+    MG_CATCH_AND_THROW(L"MgGeoJsonWriter.GeometryToGeoJson")
+    return ret;
 void MgGeoJsonWriter::ValueToString(MgReader* reader, INT32 index, REFSTRING str)
     INT32 propType = reader->GetPropertyType(index);
Modified: sandbox/jng/geoprocessing/Common/PlatformBase/Services/GeoJsonWriter.h
--- sandbox/jng/geoprocessing/Common/PlatformBase/Services/GeoJsonWriter.h	2017-06-09 13:54:30 UTC (rev 9205)
+++ sandbox/jng/geoprocessing/Common/PlatformBase/Services/GeoJsonWriter.h	2017-06-10 09:44:55 UTC (rev 9206)
@@ -108,6 +108,9 @@
     STRING FeatureToGeoJson(MgReader* reader, MgTransform* transform, CREFSTRING idPropertyName, CREFSTRING geomPropName);
+INTERNAL_API:
+    STRING GeometryToGeoJson(MgGeometry* geom);
 protected:
     virtual void Dispose();
Added: sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/binaryoperationform.html
--- sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/binaryoperationform.html	                        (rev 0)
+++ sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/binaryoperationform.html	2017-06-10 09:44:55 UTC (rev 9206)
@@ -0,0 +1,42 @@
+<html>
+<head>
+<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
+<script type="text/javascript" src="setactiontarget.js" >
+</script>
+</head>
+<body>
+<form name="input" action="" method="get">
+<b>Operation:</b>
+<input type="text" name="OPERATION" value="GEO.BINARYOPERATION" size="50">
+<p> Version:
+<input type="text" name="VERSION" value="3.3.0" size="10">
+<p> Locale:
+<input type="text" name="LOCALE" value="en" size="10">
+<p> Client Agent:
+<input type="text" name="CLIENTAGENT" value="MapGuide Developer" size="100">
+<p> Geometry A (WKT):
+<input type="text" name="GEOMETRYA" value="" size="100">
+<p> Geometry B (WKT):
+<input type="text" name="GEOMETRYB" value="" size="100">
+<p> Operator:
+<select name="OPERATOR">
+    <option value="UNION">Union</option>
+    <option value="DIFFERENCE">Difference</option>
+    <option value="INTERSECTION">Intersection</option>
+    <option value="SYMMETRICDIFFERENCE">SymmetricDifference</option>
+</select>
+<p> Output Format:
+<select name="FORMAT">
+    <option value="WKT">Geometry Well-Known Text</option>
+    <option value="GEOJSON">GeoJSON</option>
+</select>
+<p> Input Coordinate System (CS-Map Code):
+<input type="text" name="COORDINATESYSTEM" value="" size="10">
+<p> Output Coordinate System (CS-Map Code):
+<input type="text" name="TRANSFORMTO" value="" size="10">
+<p>
+<input type="submit" value="Submit" onclick="SetActionTarget()"> <input type="reset">
+</form>
+</body>
+</html>
+<html>
Added: sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/bufferform.html
--- sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/bufferform.html	                        (rev 0)
+++ sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/bufferform.html	2017-06-10 09:44:55 UTC (rev 9206)
@@ -0,0 +1,42 @@
+<html>
+<head>
+</script>
+</head>
+<body>
+<b>Operation:</b>
+<input type="text" name="OPERATION" value="GEO.BUFFER" size="50">
+<p> Version:
+<p> Locale:
+<p> Client Agent:
+<p> Geometry (WKT):
+<input type="text" name="GEOMETRY" value="" size="100">
+<p> Buffer Distance:
+<input type="text" name="DISTANCE" value="" size="10">
+<p> Buffer Units:
+<select name="UNITS">
+    <option value="mi">Miles</option>
+    <option value="km">Kilometers</option>
+    <option value="ft">Feet</option>
+    <option value="m">Meters</option>
+</select>
+<p> Output Format:
+</select>
+<p>
+</form>
+</body>
+</html>
+<html>
Added: sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/geoprocessingapi.html
--- sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/geoprocessingapi.html	                        (rev 0)
+++ sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/geoprocessingapi.html	2017-06-10 09:44:55 UTC (rev 9206)
@@ -0,0 +1,21 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
+<html>
+    <head>
+        <title></title>
+        <meta name="GENERATOR" content="Microsoft Visual Studio .NET 7.1">
+        <meta name="vs_targetSchema" content="http://schemas.microsoft.com/intellisense/ie5">
+        <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
+    </head>
+    <body>
+        <UL>
+            <LI>
+                <A href="bufferform.html" target="showform">Buffer</A>
+            <LI>
+                <A href="simplifyform.html" target="showform">Simplify</A>
+            <LI>
+                <A href="binaryoperationform.html" target="showform">BinaryOperation</A>
+            <LI>
+                <A href="spatialpredicateform.html" target="showform">SpatialPredicate</A>
+        </UL>
+    </body>
+</html>
Modified: sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/services.html
--- sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/services.html	2017-06-09 13:54:30 UTC (rev 9205)
+++ sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/services.html	2017-06-10 09:44:55 UTC (rev 9206)
@@ -11,6 +11,7 @@
 <b>Services API</b>
 <li><a href="drawingserviceapi.html" target="apilist">Drawing</a></li>
 <li><a href="featureserviceapi.html" target="apilist">Feature</a></li>
+<li><a href="geoprocessingapi.html" target="apilist">Geo-Processing</a></li>
 <li><a href="mappingserviceapi.html" target="apilist">Mapping</a></li>
 <li><a href="renderingserviceapi.html" target="apilist">Rendering</a></li>
 <li><a href="resourceserviceapi.html" target="apilist">Resource</a></li>
Added: sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/simplifyform.html
--- sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/simplifyform.html	                        (rev 0)
+++ sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/simplifyform.html	2017-06-10 09:44:55 UTC (rev 9206)
@@ -0,0 +1,40 @@
+<html>
+<head>
+</script>
+</head>
+<body>
+<b>Operation:</b>
+<input type="text" name="OPERATION" value="GEO.SIMPLIFY" size="50">
+<p> Version:
+<p> Locale:
+<p> Client Agent:
+<p> Algorithm:
+<select name="ALGORITHM">
+    <option value="0">Douglas-Peucker</option>
+    <option value="1">Topology Preserving</option>
+</select>
+<p> Tolerance:
+<input type="text" name="TOLERANCE" value="" size="10">
+<p> Output Format:
+</select>
+<p>
+</form>
+</body>
+</html>
+<html>
Added: sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/spatialpredicateform.html
--- sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/spatialpredicateform.html	                        (rev 0)
+++ sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/spatialpredicateform.html	2017-06-10 09:44:55 UTC (rev 9206)
@@ -0,0 +1,37 @@
+<html>
+<head>
+</script>
+</head>
+<body>
+<b>Operation:</b>
+<input type="text" name="OPERATION" value="GEO.SPATIALPREDICATE" size="50">
+<p> Version:
+<p> Locale:
+<p> Client Agent:
+<p> Operator:
+    <option value="CONTAINS">Contains</option>
+    <option value="CROSSES">Crosses</option>
+    <option value="DISJOINT">Disjoint</option>
+    <option value="EQUALS">Equals</option>
+    <option value="INTERSECTS">Intersects</option>
+    <option value="OVERLAPS">Overlaps</option>
+    <option value="TOUCHES">Touches</option>
+    <option value="WITHIN">Within</option>
+</select>
+<p>
+</form>
+</body>
+</html>
+<html>
Added: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBinaryOperation.cpp
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBinaryOperation.cpp	                        (rev 0)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBinaryOperation.cpp	2017-06-10 09:44:55 UTC (rev 9206)
@@ -0,0 +1,117 @@
+//  Copyright (C) 2004-2017 by Autodesk, Inc.
+//  This library is free software; you can redistribute it and/or
+//  modify it under the terms of version 2.1 of the GNU Lesser
+//  General Public License as published by the Free Software Foundation.
+//  This library is distributed in the hope that it will be useful,
+//  but WITHOUT ANY WARRANTY; without even the implied warranty of
+//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+//  Lesser General Public License for more details.
+//  You should have received a copy of the GNU Lesser General Public
+//  License along with this library; if not, write to the Free Software
+//  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
+#include "HttpHandler.h"
+#include "HttpGeoBinaryOperation.h"
+HTTP_IMPLEMENT_CREATE_OBJECT(MgHttpGeoBinaryOperation)
+MgHttpGeoBinaryOperation::MgHttpGeoBinaryOperation(MgHttpRequest* hRequest)
+    InitializeCommonParameters(hRequest);
+    Ptr<MgHttpRequestParam> params = hRequest->GetRequestParam();
+    m_geomWKT_A = params->GetParameterValue(MgHttpResourceStrings::reqGeoA);
+    m_geomWKT_B = params->GetParameterValue(MgHttpResourceStrings::reqGeoB);
+    m_operator = params->GetParameterValue(MgHttpResourceStrings::reqGeoOperator);
+    m_format = params->GetParameterValue(MgHttpResourceStrings::reqGeoFormat);
+    m_coordinateSystem = params->GetParameterValue(MgHttpResourceStrings::reqGeoCoordinateSystem);
+    m_transformTo = params->GetParameterValue(MgHttpResourceStrings::reqGeoTransformTo);
+void MgHttpGeoBinaryOperation::Execute(MgHttpResponse & hResponse)
+    Ptr<MgHttpResult> hResult = hResponse.GetResult();
+    MG_HTTP_HANDLER_TRY()
+    // Check common parameters
+    ValidateCommonParameters();
+    Ptr<MgWktReaderWriter> wktRw = new MgWktReaderWriter();
+    Ptr<MgGeometry> geomA = wktRw->Read(m_geomWKT_A);
+    Ptr<MgGeometry> geomB = wktRw->Read(m_geomWKT_B);
+    Ptr<MgGeometry> result;
+    if (m_operator == L"UNION")
+        result = geomA->Union(geomB);
+    else if (m_operator == L"DIFFERENCE")
+        result = geomA->Difference(geomB);
+    else if (m_operator == L"INTERSECTION")
+        result = geomA->Intersection(geomB);
+    else if (m_operator == L"SYMMETRICDIFFERENCE")
+        result = geomA->SymetricDifference(geomB);
+    else
+        MgStringCollection arguments;
+        arguments.Add(MgHttpResourceStrings::reqGeoOperator);
+        arguments.Add(m_operator);
+        throw new MgInvalidArgumentException(L"MgHttpGeoBinaryOperation.Execute",
+            __LINE__, __WFILE__, &arguments, L"MgInvalidFeatureSpatialOperation", NULL);
+    if (!m_transformTo.empty())
+        Ptr<MgCoordinateSystemFactory> csFactory = new MgCoordinateSystemFactory();
+        Ptr<MgCoordinateSystem> cs = csFactory->CreateFromCode(m_coordinateSystem);
+        Ptr<MgCoordinateSystem> target = csFactory->CreateFromCode(m_transformTo);
+        Ptr<MgCoordinateSystemTransform> xform = csFactory->GetTransform(cs, target);
+        Ptr<MgGeometry> xGeom = (MgGeometry*)result->Transform(xform);
+        result = xGeom;
+    if (m_format == L"WKT")
+        STRING wkt = wktRw->Write(result);
+        Ptr<MgHttpPrimitiveValue> value = new MgHttpPrimitiveValue(wkt);
+        hResult->SetResultObject(value, MgMimeType::Text);
+    else if (m_format == L"GEOJSON")
+        MgGeoJsonWriter gw;
+        STRING geoJson = gw.GeometryToGeoJson(result);
+        std::string mbGeoJson;
+        MgUtil::WideCharToMultiByte(geoJson, mbGeoJson);
+        Ptr<MgByteSource> byteSource = new MgByteSource((BYTE_ARRAY_IN)mbGeoJson.c_str(), (INT32)mbGeoJson.length());
+        byteSource->SetMimeType(MgMimeType::Json);
+        Ptr<MgByteReader> byteReader = byteSource->GetReader();
+        hResult->SetResultObject(byteReader, byteReader->GetMimeType());
+    MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGeoBinaryOperation.Execute")
+void MgHttpGeoBinaryOperation::ValidateOperationVersion()
+    // There are multiple supported versions
+    INT32 version = m_userInfo->GetApiVersion();
+    if (version != MG_API_VERSION(3, 3, 0))
+        throw new MgInvalidOperationVersionException(
+            L"MgHttpGeoBinaryOperation.ValidateOperationVersion", __LINE__, __WFILE__, NULL, L"", NULL);
+    MG_HTTP_HANDLER_CATCH_AND_THROW(L"MgHttpGeoBinaryOperation.ValidateOperationVersion");
\ No newline at end of file
Added: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBinaryOperation.h
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBinaryOperation.h	                        (rev 0)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBinaryOperation.h	2017-06-10 09:44:55 UTC (rev 9206)
@@ -0,0 +1,64 @@
+#ifndef MG_HTTP_GEO_BINARY_OPERATION_H
+#define MG_HTTP_GEO_BINARY_OPERATION_H
+class MgHttpGeoBinaryOperation : public MgHttpRequestResponseHandler
+    HTTP_DECLARE_CREATE_OBJECT()
+public:
+    /// <summary>
+    /// Initializes the common parameters of the request.
+    /// </summary>
+    /// <param name="name">Input
+    /// MgHttpRequest
+    /// This contains all the parameters of the request.
+    /// </param>
+    /// <returns>
+    /// nothing
+    /// </returns>
+    MgHttpGeoBinaryOperation(MgHttpRequest *hRequest);
+    /// <summary>
+    /// Executes the specific request.
+    /// </summary>
+    /// <param name="hResponse">Input
+    /// This contains the response (including MgHttpResult and StatusCode) from the server.
+    /// </param>
+    void Execute(MgHttpResponse& hResponse);
+    /// <summary>
+    /// Returns the classification of this request/response handler
+    /// </summary>
+    /// <returns>
+    /// Classification of handler
+    /// </returns>
+    MgRequestClassification GetRequestClassification() { return MgHttpRequestResponseHandler::mrcViewer; }
+    virtual void ValidateOperationVersion();
+private:
+    STRING m_geomWKT_A;
+    STRING m_geomWKT_B;
+    STRING m_operator;
+    STRING m_format;
+    STRING m_coordinateSystem;
+    STRING m_transformTo;
+#endif
Added: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBuffer.cpp
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBuffer.cpp	                        (rev 0)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBuffer.cpp	2017-06-10 09:44:55 UTC (rev 9206)
@@ -0,0 +1,139 @@
+#include "HttpGeoBuffer.h"
+HTTP_IMPLEMENT_CREATE_OBJECT(MgHttpGeoBuffer)
+MgHttpGeoBuffer::MgHttpGeoBuffer(MgHttpRequest* hRequest)
+    m_geomWKT = params->GetParameterValue(MgHttpResourceStrings::reqFeatGeometry);
+    m_units = params->GetParameterValue(MgHttpResourceStrings::reqGeoBufferUnits);
+    m_distance = MgUtil::StringToDouble(params->GetParameterValue(MgHttpResourceStrings::reqGeoBufferDistance));
+void MgHttpGeoBuffer::Execute(MgHttpResponse & hResponse)
+    if (m_geomWKT.empty())
+        arguments.Add(MgHttpResourceStrings::reqFeatGeometry);
+        arguments.Add(MgResources::BlankArgument);
+        throw new MgInvalidArgumentException(L"MgHttpGeoBuffer.Execute",
+            __LINE__, __WFILE__, &arguments, L"MgStringEmpty", NULL);
+    if (m_coordinateSystem.empty())
+        arguments.Add(MgHttpResourceStrings::reqGeoCoordinateSystem);
+    if (m_format != L"WKT" && m_format != L"GEOJSON")
+        arguments.Add(MgHttpResourceStrings::reqGeoFormat);
+        arguments.Add(m_format);
+            __LINE__, __WFILE__, &arguments, L"MgInvalidValueOutsideRange", NULL);
+    //Convert distance to meters
+    if (m_units == L"mi")      //miles
+        m_distance *= 1609.35;
+    else if (m_units == L"km") //kilometers
+        m_distance *= 1000;
+    else if (m_units == L"ft") //feet
+        m_distance *= 0.30480;
+    Ptr<MgGeometry> input = wktRw->Read(m_geomWKT);
+    Ptr<MgMeasure> measure = cs->GetMeasure();
+    double bufDist = cs->ConvertMetersToCoordinateSystemUnits(m_distance);
+    Ptr<MgGeometry> result = input->Buffer(bufDist, measure);
+        result = xGeom;
+    MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGeoBuffer.Execute")
+void MgHttpGeoBuffer::ValidateOperationVersion()
+            L"MgHttpGeoBuffer.ValidateOperationVersion", __LINE__, __WFILE__, NULL, L"", NULL);
+    MG_HTTP_HANDLER_CATCH_AND_THROW(L"MgHttpGeoBuffer.ValidateOperationVersion");
Added: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBuffer.h
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBuffer.h	                        (rev 0)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBuffer.h	2017-06-10 09:44:55 UTC (rev 9206)
@@ -0,0 +1,65 @@
+#ifndef MG_HTTP_GEO_BUFFER_H
+#define MG_HTTP_GEO_BUFFER_H
+class MgHttpGeoBuffer : public MgHttpRequestResponseHandler
+public:
+    /// <summary>
+    /// </summary>
+    /// MgHttpRequest
+    /// </param>
+    /// <returns>
+    /// nothing
+    /// </returns>
+    MgHttpGeoBuffer(MgHttpRequest *hRequest);
+    /// <summary>
+    /// </summary>
+    /// </param>
+    /// <summary>
+    /// </summary>
+    /// <returns>
+    /// </returns>
+private:
+    STRING m_geomWKT;
+    STRING m_units;
+    double m_distance;
+    STRING m_format;
+#endif
Added: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoSimplify.cpp
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoSimplify.cpp	                        (rev 0)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoSimplify.cpp	2017-06-10 09:44:55 UTC (rev 9206)
@@ -0,0 +1,121 @@
+#include "HttpGeoSimplify.h"
+HTTP_IMPLEMENT_CREATE_OBJECT(MgHttpGeoSimplify)
+MgHttpGeoSimplify::MgHttpGeoSimplify(MgHttpRequest* hRequest)
+    m_algorithm = MgUtil::StringToInt32(params->GetParameterValue(MgHttpResourceStrings::reqGeoAlgorithm));
+    m_tolerance = MgUtil::StringToDouble(params->GetParameterValue(MgHttpResourceStrings::reqGeoTolerance));
+void MgHttpGeoSimplify::Execute(MgHttpResponse & hResponse)
+        throw new MgInvalidArgumentException(L"MgHttpGeoSimplify.Execute",
+    if (m_algorithm != MgGeometrySimplificationAlgorithmType::DouglasPeucker &&
+        m_algorithm != MgGeometrySimplificationAlgorithmType::TopologyPreserving)
+        STRING arg;
+        MgUtil::Int32ToString(m_algorithm, arg);
+        arguments.Add(MgHttpResourceStrings::reqGeoAlgorithm);
+        arguments.Add(arg);
+    Ptr<MgGeometrySimplifier> simp = new MgGeometrySimplifier();
+    Ptr<MgGeometry> result = simp->Simplify(input, m_tolerance, m_algorithm);
+        result = xGeom;
+    MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGeoSimplify.Execute")
+void MgHttpGeoSimplify::ValidateOperationVersion()
+            L"MgHttpGeoSimplify.ValidateOperationVersion", __LINE__, __WFILE__, NULL, L"", NULL);
+    MG_HTTP_HANDLER_CATCH_AND_THROW(L"MgHttpGeoSimplify.ValidateOperationVersion");
Added: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoSimplify.h
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoSimplify.h	                        (rev 0)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoSimplify.h	2017-06-10 09:44:55 UTC (rev 9206)
@@ -0,0 +1,65 @@
+#ifndef MG_HTTP_GEO_SIMPLIFY_H
+#define MG_HTTP_GEO_SIMPLIFY_H
+class MgHttpGeoSimplify : public MgHttpRequestResponseHandler
+public:
+    /// <summary>
+    /// </summary>
+    /// MgHttpRequest
+    /// </param>
+    /// <returns>
+    /// nothing
+    /// </returns>
+    MgHttpGeoSimplify(MgHttpRequest *hRequest);
+    /// <summary>
+    /// </summary>
+    /// </param>
+    /// <summary>
+    /// </summary>
+    /// <returns>
+    /// </returns>
+private:
+    STRING m_geomWKT;
+    INT32 m_algorithm;
+    double m_tolerance;
+    STRING m_format;
+#endif
Added: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoSpatialPredicate.cpp
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoSpatialPredicate.cpp	                        (rev 0)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoSpatialPredicate.cpp	2017-06-10 09:44:55 UTC (rev 9206)
@@ -0,0 +1,93 @@
+#include "HttpGeoSpatialPredicate.h"
+HTTP_IMPLEMENT_CREATE_OBJECT(MgHttpGeoSpatialPredicate)
+MgHttpGeoSpatialPredicate::MgHttpGeoSpatialPredicate(MgHttpRequest* hRequest)
+void MgHttpGeoSpatialPredicate::Execute(MgHttpResponse & hResponse)
+    bool result = false;
+    if (m_operator == L"CONTAINS")
+        result = geomA->Contains(geomB);
+    else if (m_operator == L"CROSSES")
+        result = geomA->Crosses(geomB);
+    else if (m_operator == L"DISJOINT")
+        result = geomA->Disjoint(geomB);
+    else if (m_operator == L"EQUALS")
+        result = geomA->Equals(geomB);
+    else if (m_operator == L"INTERSECTS")
+        result = geomA->Intersects(geomB);
+    else if (m_operator == L"OVERLAPS")
+        result = geomA->Overlaps(geomB);
+    else if (m_operator == L"TOUCHES")
+        result = geomA->Touches(geomB);
+    else if (m_operator == L"WITHIN")
+        result = geomA->Within(geomB);
+    else
+        throw new MgInvalidArgumentException(L"MgHttpGeoSpatialPredicate.Execute",
+    Ptr<MgHttpPrimitiveValue> value = new MgHttpPrimitiveValue(result);
+    MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGeoSpatialPredicate.Execute")
+void MgHttpGeoSpatialPredicate::ValidateOperationVersion()
+            L"MgHttpGeoSpatialPredicate.ValidateOperationVersion", __LINE__, __WFILE__, NULL, L"", NULL);
+    MG_HTTP_HANDLER_CATCH_AND_THROW(L"MgHttpGeoSpatialPredicate.ValidateOperationVersion");
Added: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoSpatialPredicate.h
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoSpatialPredicate.h	                        (rev 0)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoSpatialPredicate.h	2017-06-10 09:44:55 UTC (rev 9206)
@@ -0,0 +1,62 @@
+#ifndef MG_HTTP_GEO_SPATIAL_PREDICATE_H
+#define MG_HTTP_GEO_SPATIAL_PREDICATE_H
+class MgHttpGeoSpatialPredicate : public MgHttpRequestResponseHandler
+public:
+    /// <summary>
+    /// </summary>
+    /// MgHttpRequest
+    /// </param>
+    /// <returns>
+    /// nothing
+    /// </returns>
+    MgHttpGeoSpatialPredicate(MgHttpRequest *hRequest);
+    /// <summary>
+    /// </summary>
+    /// </param>
+    /// <summary>
+    /// </summary>
+    /// <returns>
+    /// </returns>
+private:
+#endif
Modified: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandler.vcxproj
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandler.vcxproj	2017-06-09 13:54:30 UTC (rev 9205)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandler.vcxproj	2017-06-10 09:44:55 UTC (rev 9206)
@@ -282,6 +282,30 @@
       <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">true</ExcludedFromBuild>
       <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|x64'">true</ExcludedFromBuild>
     </ClCompile>
+    <ClCompile Include="HttpGeoBinaryOperation.cpp">
+      <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">true</ExcludedFromBuild>
+      <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">true</ExcludedFromBuild>
+      <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">true</ExcludedFromBuild>
+      <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|x64'">true</ExcludedFromBuild>
+    </ClCompile>
+    <ClCompile Include="HttpGeoBuffer.cpp">
+    </ClCompile>
+    <ClCompile Include="HttpGeoSimplify.cpp">
+    </ClCompile>
+    <ClCompile Include="HttpGeoSpatialPredicate.cpp">
+    </ClCompile>
     <ClCompile Include="HttpGetRepositoryContent.cpp">
@@ -957,6 +981,10 @@
     <ClInclude Include="HttpEnumerateResourceReferences.h" />
     <ClInclude Include="HttpEnumerateResources.h" />
     <ClInclude Include="HttpEnumerateUnmanagedData.h" />
+    <ClInclude Include="HttpGeoBuffer.h" />
+    <ClInclude Include="HttpGeoBinaryOperation.h" />
+    <ClInclude Include="HttpGeoSimplify.h" />
+    <ClInclude Include="HttpGeoSpatialPredicate.h" />
     <ClInclude Include="HttpGetRepositoryContent.h" />
     <ClInclude Include="HttpGetRepositoryHeader.h" />
     <ClInclude Include="HttpGetResourceContent.h" />
Modified: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandler.vcxproj.filters
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandler.vcxproj.filters	2017-06-09 13:54:30 UTC (rev 9205)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandler.vcxproj.filters	2017-06-10 09:44:55 UTC (rev 9206)
@@ -40,6 +40,9 @@
     <Filter Include="Byte Source Adapters">
       <UniqueIdentifier>{0f2e34d9-18f7-49af-b11f-8d3c874192ec}</UniqueIdentifier>
     </Filter>
+    <Filter Include="GeoProcessing">
+      <UniqueIdentifier>{d7514524-5f3c-40fd-8b93-45a3020d8614}</UniqueIdentifier>
+    </Filter>
   </ItemGroup>
   <ItemGroup>
     <ClCompile Include="HttpApplyResourcePackage.cpp">
@@ -386,6 +389,18 @@
     <ClCompile Include="HttpDescribeRuntimeMap.cpp">
       <Filter>Mapping Service</Filter>
     </ClCompile>
+      <Filter>GeoProcessing</Filter>
+    </ClCompile>
+    </ClCompile>
+    </ClCompile>
+    </ClCompile>
   </ItemGroup>
   <ItemGroup>
     <ClInclude Include="HttpApplyResourcePackage.h">
@@ -757,6 +772,18 @@
     <ClInclude Include="HttpDescribeRuntimeMap.h">
     </ClInclude>
+    <ClInclude Include="HttpGeoBuffer.h">
+    </ClInclude>
+    <ClInclude Include="HttpGeoSimplify.h">
+    </ClInclude>
+    <ClInclude Include="HttpGeoSpatialPredicate.h">
+    </ClInclude>
+    <ClInclude Include="HttpGeoBinaryOperation.h">
+    </ClInclude>
   </ItemGroup>
   <ItemGroup>
     <ResourceCompile Include="HttpHandler.rc" />
Modified: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandlerBuild.cpp
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandlerBuild.cpp	2017-06-09 13:54:30 UTC (rev 9205)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandlerBuild.cpp	2017-06-10 09:44:55 UTC (rev 9206)
@@ -55,6 +55,10 @@
 #include "HttpEnumerateApplicationTemplates.cpp"
 #include "HttpEnumerateApplicationWidgets.cpp"
 #include "HttpEnumerateApplicationContainers.cpp"
+#include "HttpGeoBuffer.cpp"
+#include "HttpGeoBinaryOperation.cpp"
+#include "HttpGeoSimplify.cpp"
+#include "HttpGeoSpatialPredicate.cpp"
 #include "HttpGetCapabilities.cpp"
 #include "HttpGetConnectionPropertyValues.cpp"
 #include "HttpGetDefaultTileSizeX.cpp"
Modified: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpRequest.cpp
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpRequest.cpp	2017-06-09 13:54:30 UTC (rev 9205)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpRequest.cpp	2017-06-10 09:44:55 UTC (rev 9206)
@@ -124,6 +124,12 @@
 #include "HttpCsGetBaseLibrary.h"
 #include "HttpCsIsValid.h"
+// Geo-Processing
 #include <algorithm>
 using namespace std;
@@ -431,6 +437,10 @@
     httpClassCreators[MgHttpResourceStrings::opEnumerateApplicationContainers] = MgHttpEnumerateApplicationContainers::CreateObject;
     httpClassCreators[MgHttpResourceStrings::opGetDefaultTileSizeX] = MgHttpGetDefaultTileSizeX::CreateObject;
     httpClassCreators[MgHttpResourceStrings::opGetDefaultTileSizeY] = MgHttpGetDefaultTileSizeY::CreateObject;
+    httpClassCreators[MgHttpResourceStrings::opGeoBuffer] = MgHttpGeoBuffer::CreateObject;
+    httpClassCreators[MgHttpResourceStrings::opGeoBinaryOperation] = MgHttpGeoBinaryOperation::CreateObject;
+    httpClassCreators[MgHttpResourceStrings::opGeoSimplify] = MgHttpGeoSimplify::CreateObject;
+    httpClassCreators[MgHttpResourceStrings::opGeoSpatialPredicate] = MgHttpGeoSpatialPredicate::CreateObject;
     httpPostHandlerCreators.push_back(MgHttpWfsGetCapabilities::ProcessPostRequest);
     httpPostHandlerCreators.push_back(MgHttpWfsDescribeFeatureType::ProcessPostRequest);
Modified: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpResourceStrings.cpp
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpResourceStrings.cpp	2017-06-09 13:54:30 UTC (rev 9205)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpResourceStrings.cpp	2017-06-10 09:44:55 UTC (rev 9206)
@@ -363,6 +363,23 @@
 const STRING MgHttpResourceStrings::opEnumerateApplicationWidgets = L"ENUMERATEAPPLICATIONWIDGETS";
 const STRING MgHttpResourceStrings::opEnumerateApplicationContainers = L"ENUMERATEAPPLICATIONCONTAINERS";
+// Geo-Processing Operations
+const STRING MgHttpResourceStrings::opGeoBuffer = L"GEO.BUFFER";
+const STRING MgHttpResourceStrings::opGeoSimplify = L"GEO.SIMPLIFY";
+const STRING MgHttpResourceStrings::opGeoSpatialPredicate = L"GEO.SPATIALPREDICATE";
+const STRING MgHttpResourceStrings::opGeoBinaryOperation = L"GEO.BINARYOPERATION";
+const STRING MgHttpResourceStrings::reqGeoA = L"GEOMETRYA";
+const STRING MgHttpResourceStrings::reqGeoB = L"GEOMETRYB";
+const STRING MgHttpResourceStrings::reqGeoBufferDistance = L"DISTANCE";
+const STRING MgHttpResourceStrings::reqGeoBufferUnits = L"UNITS";
+const STRING MgHttpResourceStrings::reqGeoOperator = L"OPERATOR";
+const STRING MgHttpResourceStrings::reqGeoCoordinateSystem = L"COORDINATESYSTEM";
+const STRING MgHttpResourceStrings::reqGeoFormat = L"FORMAT";
+const STRING MgHttpResourceStrings::reqGeoTransformTo = L"TRANSFORMTO";
+const STRING MgHttpResourceStrings::reqGeoAlgorithm = L"ALGORITHM";
+const STRING MgHttpResourceStrings::reqGeoTolerance = L"TOLERANCE";
 // Coordinate System Request Parameters
 const STRING MgHttpResourceStrings::reqCsWkt = L"CSWKT";
 const STRING MgHttpResourceStrings::reqCsCode = L"CSCODE";
Modified: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpResourceStrings.h
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpResourceStrings.h	2017-06-09 13:54:30 UTC (rev 9205)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpResourceStrings.h	2017-06-10 09:44:55 UTC (rev 9206)
@@ -367,7 +367,23 @@
     static const STRING opEnumerateApplicationWidgets;
     static const STRING opEnumerateApplicationContainers;
+    // Geo-Processing Operations
+    static const STRING opGeoBuffer;
+    static const STRING opGeoSimplify;
+    static const STRING opGeoSpatialPredicate;
+    static const STRING opGeoBinaryOperation;
+    static const STRING reqGeoA;
+    static const STRING reqGeoB;
+    static const STRING reqGeoBufferDistance;
+    static const STRING reqGeoBufferUnits;
+    static const STRING reqGeoOperator;
+    static const STRING reqGeoCoordinateSystem;
+    static const STRING reqGeoFormat;
+    static const STRING reqGeoTransformTo;
+    static const STRING reqGeoAlgorithm;
+    static const STRING reqGeoTolerance;
     static const STRING reqCsWkt;
     static const STRING reqCsCode;
Modified: sandbox/jng/geoprocessing/Web/src/HttpHandler/Makefile.am
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/Makefile.am	2017-06-09 13:54:30 UTC (rev 9205)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/Makefile.am	2017-06-10 09:44:55 UTC (rev 9206)
@@ -54,6 +54,10 @@
   HttpEnumerateApplicationContainers.cpp \
   HttpEnumerateApplicationWidgets.cpp \
   HttpEnumerateApplicationTemplates.cpp \
+  HttpGeoBinaryOperation.cpp \
+  HttpGeoBuffer.cpp \
+  HttpGeoSimplify.cpp \
+  HttpGeoSpatialPredicate.cpp \
   HttpGetCapabilities.cpp \
   HttpGetClassDefinition.cpp \
   HttpGetClasses.cpp \
@@ -179,6 +183,10 @@
   HttpEnumerateApplicationContainers.h \
   HttpEnumerateApplicationWidgets.h \
   HttpEnumerateApplicationTemplates.h \
+  HttpGeoBinaryOperation.h \
+  HttpGeoBuffer.h \
+  HttpGeoSimplify.h \
+  HttpGeoSpatialPredicate.h \
   HttpGetCapabilities.h \
   HttpGetClassDefinition.h \
   HttpGetClasses.h \
More information about the mapguide-commits mailing list
