[mapguide-commits] r9209 - sandbox/jng/geoprocessing/Common/Geometry
svn_mapguide at osgeo.org
Sat Jun 10 09:16:13 PDT 2017
Author: jng
Date: 2017-06-10 09:16:13 -0700 (Sat, 10 Jun 2017)
New Revision: 9209
sandbox/jng/geoprocessing/Common/Geometry/GeometrySimplifier.cpp
Plug a memory leak in MgGeometrySimplifier
Modified: sandbox/jng/geoprocessing/Common/Geometry/GeometrySimplifier.cpp
--- sandbox/jng/geoprocessing/Common/Geometry/GeometrySimplifier.cpp 2017-06-10 16:15:32 UTC (rev 9208)
+++ sandbox/jng/geoprocessing/Common/Geometry/GeometrySimplifier.cpp 2017-06-10 16:16:13 UTC (rev 9209)
@@ -33,7 +33,7 @@
MgGeometry* MgGeometrySimplifier::Simplify(MgGeometry* geom, double tolerance, INT32 algorithm)
Ptr<MgGeometry> simplified;
- Geometry* gInput = NULL;
+ std::auto_ptr<Geometry> gInput;
std::auto_ptr<Geometry> gOutput;
MG_GEOMETRY_TRY()
@@ -50,15 +50,15 @@
WKTReader r(&gf);
WKTWriter w;
- gInput = r.read(MgUtil::WideCharToMultiByte(inputWKt));
+ gInput.reset(r.read(MgUtil::WideCharToMultiByte(inputWKt)));
switch (algorithm)
case MgGeometrySimplificationAlgorithmType::DouglasPeucker:
- gOutput = geos::simplify::DouglasPeuckerSimplifier::simplify(gInput, tolerance);
+ gOutput = geos::simplify::DouglasPeuckerSimplifier::simplify(gInput.get(), tolerance);
break;
case MgGeometrySimplificationAlgorithmType::TopologyPreserving:
- gOutput = geos::simplify::TopologyPreservingSimplifier::simplify(gInput, tolerance);
+ gOutput = geos::simplify::TopologyPreservingSimplifier::simplify(gInput.get(), tolerance);
break;
@@ -72,6 +72,7 @@
MG_GEOMETRY_CATCH_AND_THROW(L"MgGeometrySimplifier.Simplify")
return simplified.Detach();
More information about the mapguide-commits
