[mapguide-commits] r9136 - in sandbox/adsk/3.2o.AIMS/Web/src: mapviewernet viewerfiles
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Mar 13 00:26:52 PDT 2017
Author: hubu
Date: 2017-03-13 00:26:52 -0700 (Mon, 13 Mar 2017)
New Revision: 9136
   sandbox/adsk/3.2o.AIMS/Web/src/mapviewernet/selectwithin.aspx
   sandbox/adsk/3.2o.AIMS/Web/src/viewerfiles/selectwithinui.templ
#2764 Select Within returns all features when actually no result should be found
Clear selection if there is no features in the polygon.
Modified: sandbox/adsk/3.2o.AIMS/Web/src/mapviewernet/selectwithin.aspx
--- sandbox/adsk/3.2o.AIMS/Web/src/mapviewernet/selectwithin.aspx	2017-03-10 08:21:34 UTC (rev 9135)
+++ sandbox/adsk/3.2o.AIMS/Web/src/mapviewernet/selectwithin.aspx	2017-03-13 07:26:52 UTC (rev 9136)
@@ -1,5 +1,5 @@
-Copyright (C) 2004-2011 by Autodesk, Inc.
+Copyright (C) 2017 by Autodesk, Inc.
 This library is free software; you can redistribute it and/or
 modify it under the terms of version 2.1 of the GNU Lesser
 General Public License as published by the Free Software Foundation.
@@ -50,6 +50,7 @@
         site.Open(cred);
         MgFeatureService featureSrvc = site.CreateService(MgServiceType.FeatureService) as MgFeatureService;
         MgRenderingService renderingSrvc = site.CreateService(MgServiceType.RenderingService) as MgRenderingService;
+        MgResourceService resourceSrvc = site.CreateService(MgServiceType.ResourceService) as MgResourceService;
         //load the map runtime state
@@ -79,8 +80,16 @@
                     if(resultSel != null)
                         // Return XML
-                        Response.AddHeader("Content-type", "text/xml");
-                        Response.Write(resultSel.ToXml());
+                        resultSel.Save(resourceSrvc, mapName);
+                        //this needs to be re-opened for some reason
+                        resultSel = new MgSelection(map);
+                        resultSel.Open(resourceSrvc, mapName);
+                        MgReadOnlyLayerCollection resLayers = resultSel.GetLayers();
+                        if (resLayers != null && resLayers.GetCount() >= 0)
+                            Response.AddHeader("Content-type", "text/xml");
+                            Response.Write(resultSel.ToXml());
Modified: sandbox/adsk/3.2o.AIMS/Web/src/viewerfiles/selectwithinui.templ
--- sandbox/adsk/3.2o.AIMS/Web/src/viewerfiles/selectwithinui.templ	2017-03-10 08:21:34 UTC (rev 9135)
+++ sandbox/adsk/3.2o.AIMS/Web/src/viewerfiles/selectwithinui.templ	2017-03-13 07:26:52 UTC (rev 9136)
@@ -90,6 +90,8 @@
         reqHandler.send(reqParams);
         if(reqHandler.responseXML)
             GetParent().SetSelectionXML(reqHandler.responseText);
+        else
+            GetParent().GetMapFrame().ClearSelection();
     catch(e) {}
     GetParent().GotoHomePage();
More information about the mapguide-commits mailing list
