[mapguide-commits] r9184 - sandbox/jng/utfgrid/Common/Renderers
svn_mapguide at osgeo.org
Mon May 1 09:24:06 PDT 2017
Author: jng
Date: 2017-05-01 09:24:06 -0700 (Mon, 01 May 2017)
New Revision: 9184
sandbox/jng/utfgrid/Common/Renderers/MapUTFGrid.h
sandbox/jng/utfgrid/Common/Renderers/agg_utfgrid_context.h
Remove unnecessary agg headers form agg_utfgrid_context.h. Also apply same warning suppression set as agg_context
Modified: sandbox/jng/utfgrid/Common/Renderers/MapUTFGrid.h
--- sandbox/jng/utfgrid/Common/Renderers/MapUTFGrid.h 2017-05-01 16:17:05 UTC (rev 9183)
+++ sandbox/jng/utfgrid/Common/Renderers/MapUTFGrid.h 2017-05-01 16:24:06 UTC (rev 9184)
@@ -67,7 +67,7 @@
- AGG_INLINE void add(const self_type& c, unsigned cover)
+ AGG_INLINE void add(const self_type& c, unsigned /*cover*/)
*this = c;
Modified: sandbox/jng/utfgrid/Common/Renderers/agg_utfgrid_context.h
--- sandbox/jng/utfgrid/Common/Renderers/agg_utfgrid_context.h 2017-05-01 16:17:05 UTC (rev 9183)
+++ sandbox/jng/utfgrid/Common/Renderers/agg_utfgrid_context.h 2017-05-01 16:24:06 UTC (rev 9184)
@@ -19,40 +19,22 @@
#ifndef _AGGUTFGRIDCONTEXT_H_
#define _AGGUTFGRIDCONTEXT_H_
+#pragma warning(push)
+#pragma warning(disable: 4100 4244 4267 4512)
#include <map>
#include "agg_basics.h"
#include "agg_rendering_buffer.h"
-#include "agg_scanline_u.h"
#include "agg_scanline_bin.h"
#include "agg_renderer_scanline.h"
-#include "agg_renderer_outline_aa.h"
-#include "agg_renderer_outline_image.h"
-#include "agg_renderer_primitives.h"
#include "agg_rasterizer_scanline_aa.h"
-#include "agg_rasterizer_outline_aa.h"
-#include "agg_rasterizer_outline.h"
-#include "agg_conv_curve.h"
-#include "agg_conv_contour.h"
-#include "agg_pixfmt_rgba.h"
#include "agg_path_storage.h"
#include "agg_conv_stroke.h"
-#include "agg_font_freetype.h"
-#include "agg_span_interpolator_linear.h"
-#include "agg_image_accessors.h"
-#include "agg_span_pattern_rgba.h"
-#include "agg_trans_affine.h"
-#include "agg_conv_transform.h"
-#include "agg_span_image_filter_rgba.h"
-#include "agg_span_image_filter_rgb.h"
-#include "agg_span_allocator.h"
-#include "agg_pattern_filters_rgba.h"
-#include "agg_pixfmt_gray.h"
-#include "agg_pixfmt_amask_adaptor.h"
-#include "agg_alpha_mask_u8.h"
#include "MapUTFGrid.h"
+#pragma warning(pop)
typedef agg::int32u utfgrid_band_type;
typedef agg::row_ptr_cache<utfgrid_band_type> utfgrid_rendering_buffer;
typedef pixfmt_utf<utfpix32, utfgrid_rendering_buffer> pixfmt_utf32;
More information about the mapguide-commits
