[mapguide-commits] r9190 - sandbox/jng/utfgrid/Common/Renderers
svn_mapguide at osgeo.org
Fri May 26 09:05:42 PDT 2017
Author: jng
Date: 2017-05-26 09:05:42 -0700 (Fri, 26 May 2017)
New Revision: 9190
sandbox/jng/utfgrid/Common/Renderers/UTFGridContent.cpp
sandbox/jng/utfgrid/Common/Renderers/UTFGridContent.h
sandbox/jng/utfgrid/Common/Renderers/UTFGridRenderer.cpp
UTFGridRenderer changes:
- Pass layerinfo, tooltip and url to UTFGridContent::AddFeature
- Emit extra debugging attributes of UTFGrid feature data if DEBUG_UTFGRID is defined
- Remove the use of auto keyword, for I am reminded that we need to build this on GCC versions with questionable support for what we now take for granted as "modern C++"
Modified: sandbox/jng/utfgrid/Common/Renderers/UTFGridContent.cpp
--- sandbox/jng/utfgrid/Common/Renderers/UTFGridContent.cpp 2017-05-02 17:01:31 UTC (rev 9189)
+++ sandbox/jng/utfgrid/Common/Renderers/UTFGridContent.cpp 2017-05-26 16:05:42 UTC (rev 9190)
@@ -3,6 +3,10 @@
#include "agg_utfgrid_context.h"
#include "KeyEncode.h"
+//Uncomment this line below to render UTFGrid content with extra debugging information attached to each
+//feature
+#define DEBUG_UTFGRID
UTFGridContent::UTFGridContent()
@@ -18,7 +22,7 @@
return mbContent;
-bool UTFGridContent::AddFeature(unsigned int decodedColor, RS_FeatureReader* feature)
+bool UTFGridContent::AddFeature(RS_LayerUIInfo* layer, unsigned int decodedColor, RS_FeatureReader* feature, const RS_String * tooltip, const RS_String * url)
static const size_t MAX_STRING = 64;
@@ -28,15 +32,15 @@
std::wstring wVal = L"{";
- auto geomName = feature->GetGeomPropName();
- auto rasterName = feature->GetRasterPropName();
+ const wchar_t * geomName = feature->GetGeomPropName();
+ const wchar_t * rasterName = feature->GetRasterPropName();
bool bFirst = true;
int count = 0;
- auto propNames = feature->GetPropNames(count);
+ const wchar_t* const* propNames = feature->GetPropNames(count);
for (int i = 0; i < count; i++)
- auto propName = propNames[i];
+ const wchar_t* propName = propNames[i];
//Skip geometry/raster
if ((geomName && wcscmp(propName, geomName) == 0) ||
(rasterName && wcscmp(propName, rasterName) == 0))
@@ -48,13 +52,13 @@
wVal.append(L",");
- auto propVal = feature->GetAsString(propName);
+ const wchar_t* propVal = feature->GetAsString(propName);
wVal.append(L"\"");
wVal.append(propName);
wVal.append(L"\": ");
- auto propType = feature->GetPropertyType(propName);
+ int propType = feature->GetPropertyType(propName);
if (propType == FdoDataType_String || propType == FdoDataType_DateTime)
wVal.append(L"\"");
@@ -69,6 +73,43 @@
bFirst = false;
+#ifdef DEBUG_UTFGRID
+ wVal.append(L",\"_MGLAYER_NAME\": ");
+ wVal.append(L"\"");
+ wVal.append(layer->name());
+ wVal.append(L",\"_MGLAYER_ID\": ");
+ wVal.append(layer->layerdef());
+ wVal.append(L",\"_MGLAYER_TOOLTIP\": ");
+ if (NULL != tooltip)
+ wVal.append(*tooltip);
+ else
+ wVal.append(L"null");
+ wVal.append(L",\"_MGLAYER_URL\": ");
+ if (NULL != url)
+ wVal.append(*url);
+ else
+ wVal.append(L",\"_MGLAYER_SELECTABLE\": ");
+ wVal.append(layer->selectable() ? L"true" : L"false");
+ wVal.append(L",\"_MGLAYER_HASTOOLTIPS\": ");
+ wVal.append(layer->hastooltips() ? L"true" : L"false");
+#endif
wVal += L"}";
m_features.insert(std::make_pair(key, wVal));
@@ -111,7 +152,7 @@
m_content << "," << std::endl;
m_content << " \"keys\": [" << std::endl;
- for (auto it = m_trackedEncodedColors.begin(); it != m_trackedEncodedColors.end(); it++)
+ for (ColorSet::iterator it = m_trackedEncodedColors.begin(); it != m_trackedEncodedColors.end(); it++)
if (it != m_trackedEncodedColors.begin())
@@ -122,7 +163,7 @@
else
- auto decodedKey = DecodeChar(*it);
+ unsigned int decodedKey = DecodeChar(*it);
m_content << " \"" << decodedKey << "\"";
@@ -134,18 +175,18 @@
m_content << " \"data\": {" << std::endl;
bool bFirst = true;
if (*it == 32) // This is the "empty space" pixel
continue;
- auto colorKey = DecodeChar(*it);
+ unsigned int colorKey = DecodeChar(*it);
if (m_pixels.find(colorKey) != m_pixels.end())
- auto featKey = m_pixels[colorKey];
- auto featData = m_features[featKey];
+ std::string featKey = m_pixels[colorKey];
+ std::wstring featData = m_features[featKey];
if (!bFirst)
Modified: sandbox/jng/utfgrid/Common/Renderers/UTFGridContent.h
--- sandbox/jng/utfgrid/Common/Renderers/UTFGridContent.h 2017-05-02 17:01:31 UTC (rev 9189)
+++ sandbox/jng/utfgrid/Common/Renderers/UTFGridContent.h 2017-05-26 16:05:42 UTC (rev 9190)
@@ -19,6 +19,7 @@
#define _UTFGRIDCONTENT_H_
#include "Renderers.h"
+#include "RendererStyles.h"
#include "RS_FeatureReader.h"
#include <set>
@@ -26,6 +27,7 @@
typedef std::map<unsigned int, std::string> ColorKeyMap;
typedef std::map<std::string, std::wstring> KeyFeatureMap;
+typedef std::set<unsigned int> ColorSet;
class UTFGridContent
@@ -35,7 +37,7 @@
RENDERERS_API std::string GetString();
- bool AddFeature(unsigned int color, RS_FeatureReader* feature);
+ bool AddFeature(RS_LayerUIInfo* layer, unsigned int color, RS_FeatureReader* feature, const RS_String * tooltip, const RS_String * url);
void StartGrid();
void StartGridRow(bool bFirst);
@@ -52,7 +54,7 @@
private:
std::wstringstream m_content;
- std::set<unsigned int> m_trackedEncodedColors;
+ ColorSet m_trackedEncodedColors;
KeyFeatureMap m_features;
ColorKeyMap m_pixels;
Modified: sandbox/jng/utfgrid/Common/Renderers/UTFGridRenderer.cpp
--- sandbox/jng/utfgrid/Common/Renderers/UTFGridRenderer.cpp 2017-05-02 17:01:31 UTC (rev 9189)
+++ sandbox/jng/utfgrid/Common/Renderers/UTFGridRenderer.cpp 2017-05-26 16:05:42 UTC (rev 9190)
@@ -122,7 +122,7 @@
for (int y = m_context->rendering_buffer.height() - 1; y >= 0; y--)
m_content->StartGridRow(bFirst);
- auto row_ptr = m_context->rendering_buffer.row_ptr(y);
+ utfgrid_band_type* row_ptr = m_context->rendering_buffer.row_ptr(y);
for (int x = 0; x < m_context->rendering_buffer.width(); x++)
m_content->AppendRowPixel(row_ptr[x]);
@@ -149,12 +149,12 @@
m_fcInfo = NULL;
-void UTFGridRenderer::StartFeature(RS_FeatureReader * feature, bool /* initialPass */, const RS_String * /* tooltip */, const RS_String * /* url */, const RS_String * /* theme */, double /* zOffset */, double /* zExtrusion */, RS_ElevationType /* zOffsetType */)
+void UTFGridRenderer::StartFeature(RS_FeatureReader * feature, bool /* initialPass */, const RS_String * tooltip, const RS_String * url, const RS_String * /* theme */, double /* zOffset */, double /* zExtrusion */, RS_ElevationType /* zOffsetType */)
m_currentColor++;
- m_renderThisFeature = m_content->AddFeature(m_currentColor, feature);
+ m_renderThisFeature = m_content->AddFeature(m_layerInfo, m_currentColor, feature, tooltip, url);
if (!m_renderThisFeature)
- m_currentColor--; //Rewind
+ m_currentColor--; //Rewind, as we have a limited budget for available pixel values and want to maximize the use of each value available to us
void UTFGridRenderer::ProcessPolygon(LineBuffer * lb, RS_FillStyle & fill)
More information about the mapguide-commits
