[mapguide-commits] r9419 - in trunk/MgDev: . Oem/DWFTK/develop/global/src/dwfcore Oem/DWFTK/develop/global/src/dwfcore/x64 Oem/LinuxApt cmake/modules
svn_mapguide at osgeo.org
Fri Dec 7 05:12:24 PST 2018
Author: jng
Date: 2018-12-07 05:12:24 -0800 (Fri, 07 Dec 2018)
New Revision: 9419
Added:
trunk/MgDev/cmake/modules/FindFDO.cmake
trunk/MgDev/CMakeLists.txt
trunk/MgDev/Oem/DWFTK/develop/global/src/dwfcore/CMakeLists.txt
trunk/MgDev/Oem/DWFTK/develop/global/src/dwfcore/Core.h
trunk/MgDev/Oem/DWFTK/develop/global/src/dwfcore/x64/Core.cpp
trunk/MgDev/Oem/LinuxApt/CMakeLists.txt
trunk/MgDev/cmake_bootstrap.sh
trunk/MgDev/cmake_build.sh
#2785: Fix Linux/CMake build:
- Fix incorrect tomcat version referenced in Oem/LinuxApt/CMakeLists.txt
- Refine DWF Toolkit #error message if the required atomic.h header could not be found
- Tweak dwfcore/Core.h to also check for x64 built-ins when checking if _DWFCORE_X64_SYSTEM should be defined
- Add FDO cmake module
- Fix up cmake_bootstrap.sh and cmake_build.sh issues reported by shellcheck
- Add ccache support to cmake_build.sh
Modified: trunk/MgDev/CMakeLists.txt
--- trunk/MgDev/CMakeLists.txt 2018-12-07 13:04:02 UTC (rev 9418)
+++ trunk/MgDev/CMakeLists.txt 2018-12-07 13:12:24 UTC (rev 9419)
@@ -143,7 +143,7 @@
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -g3")
set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -g3")
message(STATUS "Adding standard compiler flags for debug")
- endif (CMAKE_BUILD_TYPE MATCHES DEBUG)
+ endif (CMAKE_BUILD_TYPE MATCHES Debug)
endif(CMAKE_COMPILER_IS_GNUCXX)
if (USE_LD_GOLD)
Modified: trunk/MgDev/Oem/DWFTK/develop/global/src/dwfcore/CMakeLists.txt
--- trunk/MgDev/Oem/DWFTK/develop/global/src/dwfcore/CMakeLists.txt 2018-12-07 13:04:02 UTC (rev 9418)
+++ trunk/MgDev/Oem/DWFTK/develop/global/src/dwfcore/CMakeLists.txt 2018-12-07 13:12:24 UTC (rev 9419)
@@ -92,13 +92,14 @@
zlib/compress.c
zlib/crc32.c
zlib/deflate.c
- zlib/infblock.c
- zlib/infcodes.c
+ zlib/gzclose.c
+ zlib/gzlib.c
+ zlib/gzread.c
+ zlib/gzwrite.c
+ zlib/infback.c
zlib/inffast.c
zlib/inflate.c
zlib/inftrees.c
- zlib/infutil.c
- zlib/maketree.c
zlib/trees.c
zlib/uncompr.c
zlib/zutil.c
Modified: trunk/MgDev/Oem/DWFTK/develop/global/src/dwfcore/Core.h
--- trunk/MgDev/Oem/DWFTK/develop/global/src/dwfcore/Core.h 2018-12-07 13:04:02 UTC (rev 9418)
+++ trunk/MgDev/Oem/DWFTK/develop/global/src/dwfcore/Core.h 2018-12-07 13:12:24 UTC (rev 9419)
@@ -54,7 +54,7 @@
#if defined(__i386__) || defined(__i486__) || defined(__i586__) || defined(__i686) || defined(_M_IX86)
#define _DWFCORE_X86_SYSTEM
-#elif defined(_M_X64)
+#elif defined(__amd64__) || defined(__x86_64__) || defined(_M_X64)
#define _DWFCORE_X64_SYSTEM
#elif defined(_M_ALPHA)
#define _DWFCORE_ALPHA_SYSTEM
Modified: trunk/MgDev/Oem/DWFTK/develop/global/src/dwfcore/x64/Core.cpp
--- trunk/MgDev/Oem/DWFTK/develop/global/src/dwfcore/x64/Core.cpp 2018-12-07 13:04:02 UTC (rev 9418)
+++ trunk/MgDev/Oem/DWFTK/develop/global/src/dwfcore/x64/Core.cpp 2018-12-07 13:12:24 UTC (rev 9419)
@@ -66,7 +66,7 @@
#elif defined( HAVE_ALSA_IATOMIC_H )
#include <alsa/iatomic.h>
#else
- #error Missing header file - cannot continue
+ #error Missing atomic header file containing definition of atomic_t - cannot continue
#endif
Modified: trunk/MgDev/Oem/LinuxApt/CMakeLists.txt
--- trunk/MgDev/Oem/LinuxApt/CMakeLists.txt 2018-12-07 13:04:02 UTC (rev 9418)
+++ trunk/MgDev/Oem/LinuxApt/CMakeLists.txt 2018-12-07 13:12:24 UTC (rev 9419)
@@ -12,7 +12,7 @@
install(FILES ${CMAKE_CURRENT_BINARY_DIR}/tomcat.conf DESTINATION ${MG_INSTALL_WEB_PREFIX}/apache2/conf/mapguide COMPONENT ${MG_COMPONENT})
file(MAKE_DIRECTORY ${CMAKE_CURRENT_BINARY_DIR}/tomcat)
- execute_process(COMMAND tar -zxf ${CMAKE_CURRENT_SOURCE_DIR}/apache-tomcat-7.0.68.tar.gz -C ${CMAKE_CURRENT_BINARY_DIR}/tomcat --strip-components=1)
+ execute_process(COMMAND tar -zxf ${CMAKE_CURRENT_SOURCE_DIR}/apache-tomcat-7.0.82.tar.gz -C ${CMAKE_CURRENT_BINARY_DIR}/tomcat --strip-components=1)
configure_file(${CMAKE_MODULE_PATH}/../configs/mapguide.xml.in ${CMAKE_CURRENT_BINARY_DIR}/tomcat/conf/Catalina/localhost/mapguide.xml)
# Don't overwrite startup.sh in the CMAKE_CURRENT_BINARY_DIR as the subseqent install will do the same thing
Added: trunk/MgDev/cmake/modules/FindFDO.cmake
--- trunk/MgDev/cmake/modules/FindFDO.cmake (rev 0)
+++ trunk/MgDev/cmake/modules/FindFDO.cmake 2018-12-07 13:12:24 UTC (rev 9419)
@@ -0,0 +1,42 @@
+# - Find the FDO dir, include and library dirs
+# If found, this module will define:
+# FDO_INCLUDE_DIR - The FDO header directory
+# FDO_LIBRARY - The path to the FDO library
+# FDO_EXPRESSIONENGINE_LIBRARY - The path to the FDO expression engine library
+# FDO_LIBRARY_DIR - The path to the FDO library directory
+# FDO_NLS_DIR - The path to the FDO message catalogs
+# CMake base requires and policy tweaks
+cmake_minimum_required( VERSION 2.6.2 FATAL_ERROR )
+# CMP0005: keep escaping behaviour for definitions added via add_definitions()
+cmake_policy( SET CMP0005 OLD )
+set( FDO_DIR /usr/local/fdo-4.2.0 )
+set( FDO_VERSION 4.2.0 )
+if( FDO_INCLUDE_DIR AND FDO_LIBRARY_DIR)
+ set( FDO_FIND_QUIETLY TRUE )
+endif( FDO_INCLUDE_DIR AND FDO_LIBRARY_DIR )
+FIND_PATH( FDO_INCLUDE_DIR Fdo.h ${FDO_DIR}/include )
+FIND_LIBRARY( FDO_LIBRARY NAMES FDO PATHS ${FDO_DIR}/lib ${FDO_DIR}/lib64 )
+FIND_LIBRARY( FDO_EXPRESSIONENGINE_LIBRARY NAMES ExpressionEngine PATHS ${FDO_DIR}/lib ${FDO_DIR}/lib64 )
+FIND_PATH( FDO_LIBRARY_DIR libFDO.so ${FDO_DIR}/lib ${FDO_DIR}/lib64 )
+FIND_PATH( FDO_NLS_DIR FDOMessage.cat ${FDO_DIR}/nls )
+if( FDO_INCLUDE_DIR AND FDO_LIBRARY AND FDO_LIBRARY_DIR AND FDO_NLS_DIR )
+ set(FDO_FOUND TRUE)
+else( FDO_INCLUDE_DIR AND FDO_LIBRARY AND FDO_LIBRARY_DIR AND FDO_NLS_DIR )
+ set(FDO_FOUND FALSE)
+endif( FDO_INCLUDE_DIR AND FDO_LIBRARY AND FDO_LIBRARY_DIR AND FDO_NLS_DIR )
+if( FDO_FOUND )
+ if( NOT FDO_FIND_QUIETLY )
+ message( STATUS "Found FDO: ${FDO_LIBRARY}" )
+ endif( NOT FDO_FIND_QUIETLY )
+ mark_as_advanced( FDO_INCLUDE_DIR FDO_LIBRARY FDO_LIBRARY_DIR FDO_NLS_DIR )
+else( FDO_FOUND )
+ if( FDO_FIND_REQUIRED )
+ message(FATAL_ERROR "Could NOT find FDO")
+ endif (FDO_FIND_REQUIRED)
+endif (FDO_FOUND)
Modified: trunk/MgDev/cmake_bootstrap.sh
--- trunk/MgDev/cmake_bootstrap.sh 2018-12-07 13:04:02 UTC (rev 9418)
+++ trunk/MgDev/cmake_bootstrap.sh 2018-12-07 13:12:24 UTC (rev 9419)
@@ -1,13 +1,11 @@
#!/bin/sh
MG_INST_PREFIX=/usr/local/mapguideopensource-3.3.0
-CMAKE_BUILD_DIR=~/mapguide_build_area
OEM_WORK_DIR=~/mapguide_oem_build
BUILD_CPU=32
BUILD_CONFIG=Release
-BUILD_DBXML=0
-BUILD_LINUXAPT=0
HAVE_SYSTEM_XERCES=0
+USE_CCACHE=0
while [ $# -gt 0 ]; do # Until you run out of parameters...
case "$1" in
--prefix)
@@ -29,6 +27,9 @@
--have-system-xerces)
HAVE_SYSTEM_XERCES=1
+ --with-ccache)
+ USE_CCACHE=1
--help)
echo "Usage: $0 (options)"
echo "Options:"
@@ -44,7 +45,7 @@
shift # Check next set of parameters.
done
-SOURCE_DIR=`pwd`
+SOURCE_DIR=$(pwd)
check_build()
@@ -52,7 +53,7 @@
if [ $error -ne 0 ]; then
echo "$LIB_NAME: Error build failed ($error)................."
# Return back to this dir before bailing
- cd $SOURCE_DIR
+ cd "$SOURCE_DIR" || exit
exit $error
fi
@@ -72,10 +73,17 @@
echo "Building in: $BUILD_CONFIG"
echo "Using system xerces: $HAVE_SYSTEM_XERCES"
echo "OEM Working Directory is: $OEM_WORK_DIR"
+echo "Using ccache: $USE_CCACHE"
+if [ "$USE_CCACHE" = "1" ]; then
+ export CC="ccache gcc"
+ export CXX="ccache g++"
+ ccache -s
+fi
echo "Checking if OEM working dir exists"
-if [ ! -d $OEM_WORK_DIR ]; then
- mkdir -p $OEM_WORK_DIR
+if [ ! -d "$OEM_WORK_DIR" ]; then
+ mkdir -p "$OEM_WORK_DIR"
echo "Created OEM working dir at: $OEM_WORK_DIR"
fi
@@ -105,24 +113,24 @@
# (Re)build DBXML if any of the above is false
if test $HAS_DBXML_HEADERS -eq 0 -o $HAS_DBCXX_LIB -eq 0 -o $HAS_DBXML_LIB -eq 0 -o $HAS_XQILLA_LIB -eq 0; then
echo "Re-building DBXML (${BUILD_CONFIG})"
- cp -Rf Oem/dbxml ${OEM_WORK_DIR}/dbxml
- cd ${OEM_WORK_DIR}/dbxml
+ cp -Rf Oem/dbxml "${OEM_WORK_DIR}/dbxml"
+ cd "${OEM_WORK_DIR}/dbxml" || exit
if test $HAVE_SYSTEM_XERCES -eq 1; then
echo "Building DBXML with system-installed xerces. Please wait"
- if test $BUILD_CONFIG == "Debug"; then
- ./buildall.sh --enable-debug --with-xerces=/usr --have-system-xerces 2>&1 | tee $OEM_WORK_DIR/dbxml_build.log
+ if test "$BUILD_CONFIG" == Debug; then
+ ./buildall.sh --enable-debug --with-xerces=/usr --have-system-xerces 2>&1 | tee "$OEM_WORK_DIR/dbxml_build.log"
check_build
else
- ./buildall.sh --with-xerces=/usr --have-system-xerces 2>&1 | tee $OEM_WORK_DIR/dbxml_build.log
+ ./buildall.sh --with-xerces=/usr --have-system-xerces 2>&1 | tee "$OEM_WORK_DIR/dbxml_build.log"
check_build
fi
else
echo "Building DBXML with internal copy of xerces. Please wait"
- ./buildall.sh --enable-debug 2>&1 | tee $OEM_WORK_DIR/dbxml_build.log
+ ./buildall.sh --enable-debug 2>&1 | tee "$OEM_WORK_DIR/dbxml_build.log"
check_build
else
- ./buildall.sh 2>&1 | tee $OEM_WORK_DIR/dbxml_build.log
+ ./buildall.sh 2>&1 | tee "$OEM_WORK_DIR/dbxml_build.log"
check_build
fi
fi
@@ -138,28 +146,27 @@
MG_INSTALL_WEB_PREFIX=$MG_INST_PREFIX/webserverextensions
LA_WORKDIR=${OEM_WORK_DIR}/LinuxApt
-HTTPD_FAKE_INSTALL=${OEM_WORK_DIR}/HttpdFakeInstall
HTTPD_WORKDIR=${LA_WORKDIR}/httpd-${HTTPD_VER}
PHP_WORKDIR=${LA_WORKDIR}/php-${PHP_VER}
TC_WORKDIR=${LA_WORKDIR}/tomcat-connectors-${TC_VER}-src
-if [ ! -d ${LA_WORKDIR} ]; then
- mkdir -p $LA_WORKDIR
+if [ ! -d "${LA_WORKDIR}" ]; then
+ mkdir -p "$LA_WORKDIR"
fi
echo "Checking if we need to build httpd"
HAS_HTTPD=0
-if [ -d ${HTTPD_WORKDIR} ]; then
+if [ -d "${HTTPD_WORKDIR}" ]; then
HAS_HTTPD=1
fi
echo "Checking if we need to build php"
HAS_PHP=0
-if [ -d ${PHP_WORKDIR} ]; then
+if [ -d "${PHP_WORKDIR}" ]; then
HAS_PHP=1
fi
echo "Checking if we need to build tomcat connector"
HAS_TOMCAT_CONNECTOR=0
-if [ -d ${TC_WORKDIR} ]; then
+if [ -d "${TC_WORKDIR}" ]; then
HAS_TOMCAT_CONNECTOR=1
fi
echo "Has HTTPD: ${HAS_HTTPD}"
@@ -166,77 +173,83 @@
echo "Has PHP: ${HAS_PHP}"
echo "Has Tomcat Connector: ${HAS_TOMCAT_CONNECTOR}"
if test $HAS_HTTPD -eq 0; then
- cd $SOURCE_DIR/Oem/LinuxApt
+ cd "$SOURCE_DIR/Oem/LinuxApt" || exit
echo "Extracting HTTPD tarballs"
- tar -jxf httpd-${HTTPD_VER}.tar.bz2 -C ${LA_WORKDIR}
- tar -jxf httpd-${HTTPD_VER}-deps.tar.bz2 -C ${LA_WORKDIR}
- cd ${HTTPD_WORKDIR}
+ tar -jxf httpd-${HTTPD_VER}.tar.bz2 -C "${LA_WORKDIR}"
+ tar -jxf httpd-${HTTPD_VER}-deps.tar.bz2 -C "${LA_WORKDIR}"
+ cd "${HTTPD_WORKDIR}" || exit
echo "Configuring HTTPD"
- ./configure --prefix=${MG_INSTALL_WEB_PREFIX}/apache2 --enable-mods-shared-all --with-included-apr --with-port=${HTTPD_PORT} 2>&1 | tee $OEM_WORK_DIR/configure_httpd_fake.log
+ ./configure --prefix="${MG_INSTALL_WEB_PREFIX}/apache2" --enable-mods-shared-all --with-included-apr --with-port=${HTTPD_PORT} 2>&1 | tee "$OEM_WORK_DIR/configure_httpd_fake.log"
check_build
echo "Building HTTPD. Please wait"
- make 2>&1 | tee $OEM_WORK_DIR/make_httpd_fake.log
+ make 2>&1 | tee "$OEM_WORK_DIR/make_httpd_fake.log"
check_build
fi
-cd ${HTTPD_WORKDIR}
+cd "${HTTPD_WORKDIR}" || exit
echo "Installing HTTPD"
-make install 2>&1 | tee $OEM_WORK_DIR/make_install_httpd_fake.log
+make install 2>&1 | tee "$OEM_WORK_DIR/make_install_httpd_fake.log"
check_build
-echo "Include conf/mapguide/*.conf" >> ${MG_INSTALL_WEB_PREFIX}/apache2/conf/httpd.conf
+echo "Include conf/mapguide/*.conf" >> "${MG_INSTALL_WEB_PREFIX}/apache2/conf/httpd.conf"
# Activate mod_rewrite
-sed -i "s/#LoadModule rewrite_module modules\/mod_rewrite.so/LoadModule rewrite_module modules\/mod_rewrite.so/g" ${MG_INSTALL_WEB_PREFIX}/apache2/conf/httpd.conf
+sed -i "s/#LoadModule rewrite_module modules\/mod_rewrite.so/LoadModule rewrite_module modules\/mod_rewrite.so/g" "${MG_INSTALL_WEB_PREFIX}/apache2/conf/httpd.conf"
# Make sure lib dirs are in envvars
-cat >> ${MG_INSTALL_WEB_PREFIX}/apache2/bin/envvars <<END-OF-ENVVARS
+cat >> "${MG_INSTALL_WEB_PREFIX}/apache2/bin/envvars" <<END-OF-ENVVARS
export LD_LIBRARY_PATH=${MG_INSTALL_WEB_PREFIX}/lib:${MG_INSTALL_WEB_PREFIX}/php/lib:${MG_INST_PREFIX}/lib
export MENTOR_DICTIONARY_PATH=${MG_INST_PREFIX}/share/gis/coordsys
END-OF-ENVVARS
if test $HAS_PHP -eq 0; then
echo "Extracting PHP tarball"
- tar -jxf php-${PHP_VER}.tar.bz2 -C ${LA_WORKDIR}
- cd ${PHP_WORKDIR}
+ tar -jxf php-${PHP_VER}.tar.bz2 -C "${LA_WORKDIR}"
+ cd "${PHP_WORKDIR}" || exit
echo "Configuring PHP"
- ./configure --prefix=${MG_INSTALL_WEB_PREFIX}/php --with-apxs2=${MG_INSTALL_WEB_PREFIX}/apache2/bin/apxs --with-openssl --with-curl --enable-xml --enable-wddx --enable-shared --with-zlib --enable-zip --enable-mbstring=all --with-xsl=/usr/lib --with-gd --with-png-dir=/usr/lib --with-jpeg-dir=/usr/lib --with-freetype-dir=/usr/lib 2>&1 | tee $OEM_WORK_DIR/configure_php.log
+ ./configure --prefix="${MG_INSTALL_WEB_PREFIX}/php" --with-apxs2="${MG_INSTALL_WEB_PREFIX}/apache2/bin/apxs" --with-openssl --with-curl --enable-xml --enable-wddx --enable-shared --with-zlib --enable-zip --enable-mbstring=all --with-xsl=/usr/lib --with-gd --with-png-dir=/usr/lib --with-jpeg-dir=/usr/lib --with-freetype-dir=/usr/lib 2>&1 | tee "$OEM_WORK_DIR/configure_php.log"
check_build
echo "Building PHP. Please wait"
- make 2>&1 | tee $OEM_WORK_DIR/make_php.log
+ make 2>&1 | tee "$OEM_WORK_DIR/make_php.log"
check_build
fi
-cd ${PHP_WORKDIR}
+cd "${PHP_WORKDIR}" || exit
echo "Installing PHP"
-make install 2>&1 | tee $OEM_WORK_DIR/make_install_php.log
+make install 2>&1 | tee "$OEM_WORK_DIR/make_install_php.log"
check_build
if test $HAS_TOMCAT_CONNECTOR -eq 0; then
echo "Extracting Tomcat Connector tarball"
- tar -zxf tomcat-connectors-${TC_VER}-src.tar.gz -C ${LA_WORKDIR}
- cd ${TC_WORKDIR}/native
+ tar -zxf tomcat-connectors-${TC_VER}-src.tar.gz -C "${LA_WORKDIR}"
+ cd "${TC_WORKDIR}/native" || exit
echo "Configuring Tomcat Connector"
- ./configure --with-apxs=${MG_INSTALL_WEB_PREFIX}/apache2/bin/apxs 2>&1 | tee $OEM_WORK_DIR/configure_tc.log
+ ./configure --with-apxs="${MG_INSTALL_WEB_PREFIX}/apache2/bin/apxs" 2>&1 | tee "$OEM_WORK_DIR/configure_tc.log"
check_build
echo "Building Tomcat Connector. Please wait"
- make 2>&1 | tee $OEM_WORK_DIR/make_tc.log
+ make 2>&1 | tee "$OEM_WORK_DIR/make_tc.log"
check_build
fi
echo "Installing Tomcat Connector"
-cd ${TC_WORKDIR}/native
-make install 2>&1 | tee $OEM_WORK_DIR/make_install_tc.log
+cd "${TC_WORKDIR}/native" || exit
+make install 2>&1 | tee "$OEM_WORK_DIR/make_install_tc.log"
check_build
# dump vars to setup script
-echo "#!/bin/sh" > $OEM_WORK_DIR/env_vars.sh
-echo "export MG_INST_PREFIX=$MG_INST_PREFIX" >> $OEM_WORK_DIR/env_vars.sh
-echo "export BUILD_CPU=$BUILD_CPU" >> $OEM_WORK_DIR/env_vars.sh
-echo "export BUILD_CONFIG=$BUILD_CONFIG" >> $OEM_WORK_DIR/env_vars.sh
-echo "export PHP_VER=$PHP_VER" >> $OEM_WORK_DIR/env_vars.sh
-echo "export HTTPD_VER=$HTTPD_VER" >> $OEM_WORK_DIR/env_vars.sh
-echo "export TC_VER=$TC_VER" >> $OEM_WORK_DIR/env_vars.sh
-echo "export HTTPD_PORT=$HTTPD_PORT" >> $OEM_WORK_DIR/env_vars.sh
-echo "export TOMCAT_PORT=$TOMCAT_PORT" >> $OEM_WORK_DIR/env_vars.sh
-echo "export HAVE_SYSTEM_XERCES=$HAVE_SYSTEM_XERCES" >> $OEM_WORK_DIR/env_vars.sh
-chmod +x $OEM_WORK_DIR/env_vars.sh
+ echo "#!/bin/sh"
+ echo "export MG_INST_PREFIX=$MG_INST_PREFIX"
+ echo "export BUILD_CPU=$BUILD_CPU"
+ echo "export BUILD_CONFIG=$BUILD_CONFIG"
+ echo "export PHP_VER=$PHP_VER"
+ echo "export HTTPD_VER=$HTTPD_VER"
+ echo "export TC_VER=$TC_VER"
+ echo "export HTTPD_PORT=$HTTPD_PORT"
+ echo "export TOMCAT_PORT=$TOMCAT_PORT"
+ echo "export HAVE_SYSTEM_XERCES=$HAVE_SYSTEM_XERCES"
+} > "$OEM_WORK_DIR/env_vars.sh"
+chmod +x "$OEM_WORK_DIR/env_vars.sh"
+ ccache -s
+fi
echo "$OEM_WORK_DIR/env_vars.sh written"
echo "Make sure to run cmake_build.sh with --oem-working-dir set to: $OEM_WORK_DIR"
\ No newline at end of file
Modified: trunk/MgDev/cmake_build.sh
--- trunk/MgDev/cmake_build.sh 2018-12-07 13:04:02 UTC (rev 9418)
+++ trunk/MgDev/cmake_build.sh 2018-12-07 13:12:24 UTC (rev 9419)
@@ -2,11 +2,6 @@
-#BUILD_CPU=32
-#BUILD_CONFIG=Release
-BUILD_DBXML=0
-BUILD_LINUXAPT=0
-#HAVE_SYSTEM_XERCES=0
USE_NINJA=0
USE_ASAN=OFF
USE_LD_GOLD=OFF
@@ -44,7 +39,7 @@
done
-SOURCE_DIR=`pwd`
+SOURCE_DIR=$(pwd)
check_build()
@@ -52,18 +47,18 @@
- cd $SOURCE_DIR
exit $error
fi
-if [ ! -f $OEM_WORK_DIR/env_vars.sh ]; then
+if [ ! -f "$OEM_WORK_DIR/env_vars.sh" ]; then
echo "ERROR: Could not find env_vars.sh in $OEM_WORK_DIR"
echo " This file should exist if you ran cmake_bootstrap.sh with (--oem_working_dir $OEM_WORK_DIR)"
exit 1;
fi
-source $OEM_WORK_DIR/env_vars.sh
+. "$OEM_WORK_DIR/env_vars.sh"
# Validate
if test "$BUILD_CPU" != "32" -a "$BUILD_CPU" != "64"; then
@@ -80,11 +75,12 @@
echo "Building for: $BUILD_CPU-bit"
echo "Using Ninja build: $USE_NINJA"
+echo "Using ld.gold: $USE_LD_GOLD"
echo "CMake build directory is: $CMAKE_BUILD_DIR"
echo "Creating CMake build directory"
-mkdir -p $CMAKE_BUILD_DIR
+mkdir -p "$CMAKE_BUILD_DIR"
INTERNAL_XERCES=TRUE
@@ -93,14 +89,14 @@
# Now for the main event
echo "Setting up CMake in: $CMAKE_BUILD_DIR"
-cd $CMAKE_BUILD_DIR
+cd "$CMAKE_BUILD_DIR" || exit
if test $USE_NINJA -eq 1; then
- cmake -G Ninja $SOURCE_DIR -DMG_CPU=$BUILD_CPU -DWITH_JAVA=TRUE -DINTERNAL_XERCES=$INTERNAL_XERCES -DSANITIZE_ADDRESS=$USE_ASAN -DPHP_VER=${PHP_VER} -DHTTPD_VER=${HTTPD_VER} -DCMAKE_BUILD_TYPE=$BUILD_CONFIG -DMG_OEM_WORK_DIR=$OEM_WORK_DIR
+ cmake -G Ninja "$SOURCE_DIR" -DMG_CPU="$BUILD_CPU" -DWITH_JAVA=TRUE -DUSE_LD_GOLD="$USE_LD_GOLD" -DINTERNAL_XERCES=$INTERNAL_XERCES -DSANITIZE_ADDRESS=$USE_ASAN -DPHP_VER="$PHP_VER" -DHTTPD_VER="$HTTPD_VER" -DCMAKE_BUILD_TYPE="$BUILD_CONFIG" -DMG_OEM_WORK_DIR="$OEM_WORK_DIR"
check_build
ninja
check_build
else
- cmake $SOURCE_DIR -DMG_CPU=$BUILD_CPU -DWITH_JAVA=TRUE -DINTERNAL_XERCES=$INTERNAL_XERCES -DSANITIZE_ADDRESS=$USE_ASAN -DPHP_VER=${PHP_VER} -DHTTPD_VER=${HTTPD_VER} -DCMAKE_BUILD_TYPE=$BUILD_CONFIG -DMG_OEM_WORK_DIR=$OEM_WORK_DIR
+ cmake "$SOURCE_DIR" -DMG_CPU="$BUILD_CPU" -DWITH_JAVA=TRUE -DUSE_LD_GOLD="$USE_LD_GOLD" -DINTERNAL_XERCES=$INTERNAL_XERCES -DSANITIZE_ADDRESS=$USE_ASAN -DPHP_VER="$PHP_VER" -DHTTPD_VER="$HTTPD_VER" -DCMAKE_BUILD_TYPE="$BUILD_CONFIG" -DMG_OEM_WORK_DIR="$OEM_WORK_DIR"
check_build
make
check_build
More information about the mapguide-commits
