[mapguide-commits] r9428 - branches/3.1/MgDev
svn_mapguide at osgeo.org
Mon Dec 31 01:00:21 PST 2018
Author: jng
Date: 2018-12-31 01:00:21 -0800 (Mon, 31 Dec 2018)
New Revision: 9428
branches/3.1/MgDev/configure.in
branches/3.1/MgDev/prepare_webtier_components.bat
RFC 168: Update httpd/PHP version numbers for build
Modified: branches/3.1/MgDev/configure.in
--- branches/3.1/MgDev/configure.in 2018-12-31 08:42:00 UTC (rev 9427)
+++ branches/3.1/MgDev/configure.in 2018-12-31 09:00:21 UTC (rev 9428)
@@ -39,7 +39,7 @@
map_opt_oem_distsubdirs=""
dnl *******************************************************
-dnl PHP 5.6.33 Configuration
+dnl PHP 5.6.39 Configuration
AC_ARG_WITH([php],
MAP_HELP_STRING([--with-php],
@@ -48,8 +48,8 @@
[with_php=no])
if test $with_php = "no"; then
- AC_MSG_NOTICE([Using php 5.6.33 from included Oem Directory])
- php_src=`pwd`/Oem/LinuxApt/php-5.6.33
+ AC_MSG_NOTICE([Using php 5.6.39 from included Oem Directory])
+ php_src=`pwd`/Oem/LinuxApt/php-5.6.39
else
AC_MSG_NOTICE([Using custom PHP source directory])
php_src=$with_php
@@ -62,7 +62,7 @@
AC_SUBST(php_src)
-dnl httpd 2.4.29 Configuration
+dnl httpd 2.4.37 Configuration
AC_ARG_WITH([httpd],
MAP_HELP_STRING([--with-httpd],
@@ -71,8 +71,8 @@
[with_httpd=no])
if test $with_httpd = "no"; then
- AC_MSG_NOTICE([Using httpd 2.4.29 from included Oem Directory])
- httpd_src=`pwd`/Oem/LinuxApt/httpd-2.4.29
+ AC_MSG_NOTICE([Using httpd 2.4.37 from included Oem Directory])
+ httpd_src=`pwd`/Oem/LinuxApt/httpd-2.4.37
else
AC_MSG_NOTICE([Using custom httpd source directory])
httpd_src=$with_httpd
Modified: branches/3.1/MgDev/prepare_webtier_components.bat
--- branches/3.1/MgDev/prepare_webtier_components.bat 2018-12-31 08:42:00 UTC (rev 9427)
+++ branches/3.1/MgDev/prepare_webtier_components.bat 2018-12-31 09:00:21 UTC (rev 9428)
@@ -1,7 +1,7 @@
@echo off
SET SEVENZ=%CD%\BuildTools\WebTools\7-zip\7z.exe
-SET HTTPD_VER=2.4.29
-SET PHP_VER=5.6.33
+SET HTTPD_VER=2.4.37
+SET PHP_VER=5.6.39
pushd Oem\LinuxApt
:check_httpd
if not exist httpd-%HTTPD_VER% goto unpack_httpd
More information about the mapguide-commits
