[mapguide-commits] r9323 - in branches/3.1/MgDev/Oem: httpd/lib64 php/x64/Release_TS
svn_mapguide at osgeo.org
Wed Feb 28 06:36:56 PST 2018
Author: jng
Date: 2018-02-28 06:36:56 -0800 (Wed, 28 Feb 2018)
New Revision: 9323
Added:
branches/3.1/MgDev/Oem/httpd/lib64/mod_proxy.lib
branches/3.1/MgDev/Oem/httpd/lib64/apr-1.lib
branches/3.1/MgDev/Oem/httpd/lib64/aprutil-1.lib
branches/3.1/MgDev/Oem/httpd/lib64/libapr-1.exp
branches/3.1/MgDev/Oem/httpd/lib64/libapr-1.lib
branches/3.1/MgDev/Oem/httpd/lib64/libapriconv-1.exp
branches/3.1/MgDev/Oem/httpd/lib64/libapriconv-1.lib
branches/3.1/MgDev/Oem/httpd/lib64/libaprutil-1.exp
branches/3.1/MgDev/Oem/httpd/lib64/libaprutil-1.lib
branches/3.1/MgDev/Oem/httpd/lib64/libhttpd.exp
branches/3.1/MgDev/Oem/httpd/lib64/libhttpd.lib
branches/3.1/MgDev/Oem/httpd/lib64/mod_dav.exp
branches/3.1/MgDev/Oem/httpd/lib64/mod_dav.lib
branches/3.1/MgDev/Oem/httpd/lib64/xml.lib
branches/3.1/MgDev/Oem/php/x64/Release_TS/php5ts.lib
#2774: Update import libs for 64-bit PHP and Apache
Modified: branches/3.1/MgDev/Oem/httpd/lib64/apr-1.lib
(Binary files differ)
Modified: branches/3.1/MgDev/Oem/httpd/lib64/aprutil-1.lib
Modified: branches/3.1/MgDev/Oem/httpd/lib64/libapr-1.exp
Modified: branches/3.1/MgDev/Oem/httpd/lib64/libapr-1.lib
Modified: branches/3.1/MgDev/Oem/httpd/lib64/libapriconv-1.exp
Modified: branches/3.1/MgDev/Oem/httpd/lib64/libapriconv-1.lib
Modified: branches/3.1/MgDev/Oem/httpd/lib64/libaprutil-1.exp
Modified: branches/3.1/MgDev/Oem/httpd/lib64/libaprutil-1.lib
Modified: branches/3.1/MgDev/Oem/httpd/lib64/libhttpd.exp
Modified: branches/3.1/MgDev/Oem/httpd/lib64/libhttpd.lib
Modified: branches/3.1/MgDev/Oem/httpd/lib64/mod_dav.exp
Modified: branches/3.1/MgDev/Oem/httpd/lib64/mod_dav.lib
Added: branches/3.1/MgDev/Oem/httpd/lib64/mod_proxy.lib
Index: branches/3.1/MgDev/Oem/httpd/lib64/mod_proxy.lib
--- branches/3.1/MgDev/Oem/httpd/lib64/mod_proxy.lib 2018-02-28 14:31:57 UTC (rev 9322)
+++ branches/3.1/MgDev/Oem/httpd/lib64/mod_proxy.lib 2018-02-28 14:36:56 UTC (rev 9323)
Property changes on: branches/3.1/MgDev/Oem/httpd/lib64/mod_proxy.lib
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+application/octet-stream
\ No newline at end of property
Modified: branches/3.1/MgDev/Oem/httpd/lib64/xml.lib
Modified: branches/3.1/MgDev/Oem/php/x64/Release_TS/php5ts.lib
More information about the mapguide-commits
