[mapguide-commits] r9272 - in sandbox/jng/cmake_v2: . BuildTools BuildTools/WebTools BuildTools/WebTools/IMake Common Desktop Desktop/MgDesktop Desktop/MgDesktop/Services/Feature Desktop/UnitTest cmake/modules
svn_mapguide at osgeo.org
Thu Jan 4 01:43:37 PST 2018
Author: jng
Date: 2018-01-04 01:43:37 -0800 (Thu, 04 Jan 2018)
New Revision: 9272
Added:
sandbox/jng/cmake_v2/BuildTools/CMakeLists.txt
sandbox/jng/cmake_v2/BuildTools/WebTools/CMakeLists.txt
sandbox/jng/cmake_v2/BuildTools/WebTools/IMake/CMakeLists.txt
sandbox/jng/cmake_v2/Desktop/CMakeLists.txt
sandbox/jng/cmake_v2/Desktop/MgDesktop/CMakeLists.txt
sandbox/jng/cmake_v2/Desktop/UnitTest/CMakeLists.txt
sandbox/jng/cmake_v2/cmake/modules/FindCppUnit.cmake
sandbox/jng/cmake_v2/cmake/modules/TestCmakeVersion.cxx
sandbox/jng/cmake_v2/CMakeLists.txt
sandbox/jng/cmake_v2/Common/CMakeLists.txt
sandbox/jng/cmake_v2/Desktop/MgDesktop/Services/Feature/FeatureConnection.h
sandbox/jng/cmake_v2/Desktop/UnitTest/TestFeatureService.cpp
sandbox/jng/cmake_v2/Desktop/UnitTest/TestResourceService.cpp
Get mg-desktop building through CMake
Added: sandbox/jng/cmake_v2/BuildTools/CMakeLists.txt
--- sandbox/jng/cmake_v2/BuildTools/CMakeLists.txt (rev 0)
+++ sandbox/jng/cmake_v2/BuildTools/CMakeLists.txt 2018-01-04 09:43:37 UTC (rev 9272)
@@ -0,0 +1 @@
+add_subdirectory(WebTools)
\ No newline at end of file
Added: sandbox/jng/cmake_v2/BuildTools/WebTools/CMakeLists.txt
--- sandbox/jng/cmake_v2/BuildTools/WebTools/CMakeLists.txt (rev 0)
+++ sandbox/jng/cmake_v2/BuildTools/WebTools/CMakeLists.txt 2018-01-04 09:43:37 UTC (rev 9272)
@@ -0,0 +1 @@
+add_subdirectory(IMake)
Added: sandbox/jng/cmake_v2/BuildTools/WebTools/IMake/CMakeLists.txt
--- sandbox/jng/cmake_v2/BuildTools/WebTools/IMake/CMakeLists.txt (rev 0)
+++ sandbox/jng/cmake_v2/BuildTools/WebTools/IMake/CMakeLists.txt 2018-01-04 09:43:37 UTC (rev 9272)
@@ -0,0 +1,7 @@
+set(IMake_SRCS
+ IMake.cpp
+ SimpleXmlParser.cpp
+ stdafx.cpp
+add_executable(IMake ${IMake_SRCS})
Modified: sandbox/jng/cmake_v2/CMakeLists.txt
--- sandbox/jng/cmake_v2/CMakeLists.txt 2017-12-26 14:28:41 UTC (rev 9271)
+++ sandbox/jng/cmake_v2/CMakeLists.txt 2018-01-04 09:43:37 UTC (rev 9272)
@@ -10,6 +10,8 @@
${CMAKE_CURRENT_SOURCE_DIR}/cmake/modules
+message(STATUS "Building for: ${CMAKE_BUILD_TYPE}")
# Make CPack available to easy generate binary packages
include(CPack)
@@ -54,13 +56,33 @@
if( CMAKE_COMPILER_IS_GNUCXX )
add_definitions( -D__USE_GNU -Wno-deprecated )
if( CMAKE_SIZEOF_VOID_P EQUAL 8 )
- set ( CMAKE_CXX_FLAGS "-m64" )
+ set ( CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -m64" )
+ set ( CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -m64" )
else( CMAKE_SIZEOF_VOID_P EQUAL 8 )
- set ( CMAKE_CXX_FLAGS "-m32" )
+ set ( CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -m32" )
+ set ( CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -m32" )
endif( CMAKE_SIZEOF_VOID_P EQUAL 8 )
+ if (CMAKE_BUILD_TYPE MATCHES DEBUG)
+ add_definitions(-DDEBUG -D_DEBUG)
+ set ( CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -g3" )
+ set ( CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -g3" )
+ message(STATUS "Adding standard compiler flags for debug")
+ endif (CMAKE_BUILD_TYPE MATCHES DEBUG)
endif( CMAKE_COMPILER_IS_GNUCXX )
+find_package(GEOS REQUIRED)
+find_package(ACE REQUIRED)
+find_package(XercesC REQUIRED)
+find_package(GD REQUIRED)
+find_package(Freetype REQUIRED)
+find_package(JPEG REQUIRED)
+find_package(PNG REQUIRED)
+find_package(FDO REQUIRED)
+find_package(CppUnit REQUIRED)
+add_subdirectory(BuildTools)
add_subdirectory(Oem)
add_subdirectory(Common)
add_subdirectory(Server)
add_subdirectory(Web)
+add_subdirectory(Desktop)
Modified: sandbox/jng/cmake_v2/Common/CMakeLists.txt
--- sandbox/jng/cmake_v2/Common/CMakeLists.txt 2017-12-26 14:28:41 UTC (rev 9271)
+++ sandbox/jng/cmake_v2/Common/CMakeLists.txt 2018-01-04 09:43:37 UTC (rev 9272)
@@ -1,12 +1,3 @@
-find_package (GEOS REQUIRED)
-find_package (ACE REQUIRED)
-find_package (XercesC REQUIRED)
-find_package (GD REQUIRED)
-find_package (Freetype REQUIRED)
-find_package (JPEG REQUIRED)
-find_package (PNG REQUIRED)
-find_package (FDO REQUIRED)
# NOTE: Not applied for server tier projects except for mgserver main executable
set ( CMAKE_SHARED_LINKER_FLAGS "-Wl,--as-needed -Wl,--no-undefined -lc ${CMAKE_SHARED_LINKER_FLAGS}")
Added: sandbox/jng/cmake_v2/Desktop/CMakeLists.txt
--- sandbox/jng/cmake_v2/Desktop/CMakeLists.txt (rev 0)
+++ sandbox/jng/cmake_v2/Desktop/CMakeLists.txt 2018-01-04 09:43:37 UTC (rev 9272)
@@ -0,0 +1,9 @@
+add_definitions( -DACE_HAS_THREAD_SAFE_ACCEPT )
+# NOTE: Not applied for server tier projects except for mgserver main executable
+if( CMAKE_COMPILER_IS_GNUCXX )
+ set ( CMAKE_SHARED_LINKER_FLAGS "-Wl,--as-needed -Wl,--no-undefined -lc ${CMAKE_SHARED_LINKER_FLAGS}")
+endif( CMAKE_COMPILER_IS_GNUCXX )
+add_subdirectory(MgDesktop)
+add_subdirectory(UnitTest)
Added: sandbox/jng/cmake_v2/Desktop/MgDesktop/CMakeLists.txt
--- sandbox/jng/cmake_v2/Desktop/MgDesktop/CMakeLists.txt (rev 0)
+++ sandbox/jng/cmake_v2/Desktop/MgDesktop/CMakeLists.txt 2018-01-04 09:43:37 UTC (rev 9272)
@@ -0,0 +1,52 @@
+project(mgdesktop)
+#NOTE: DWF headers *must* go before MdfModel headers because we want Version.h from
+#MdfModel first and not DWF Toolkit
+include_directories(${ACE_INCLUDE_DIR}
+ ${XERCESC_INCLUDE_DIR}
+ ${CMAKE_CURRENT_SOURCE_DIR}
+ ${FDO_INCLUDE_DIR}
+ ${FDO_INCLUDE_DIR}/ExpressionEngine
+ ${MG_COMMON_DIR}/PlatformBase
+ ${MG_COMMON_DIR}/CoordinateSystem
+ ${MG_COMMON_DIR}/Security
+ ${MG_COMMON_DIR}/MdfModel
+ ${MG_COMMON_DIR}/MdfParser
+ ${MG_COMMON_DIR}/Foundation
+ ${MG_COMMON_DIR}/Geometry
+ ${MG_COMMON_DIR}/Renderers
+ ${MG_COMMON_DIR}/Stylization
+ ${MG_OEM_DWF_INCLUDE_DIR}
+ ${MG_OEM_DWF_INCLUDE_DIR}/dwf
+ ${MG_SERVER_GWS_DIR}/Include
+ ${MG_SERVER_GWS_DIR}/GwsCommon/inc
+ ${MG_SERVER_GWS_DIR}/GwsQueryEngine/inc
+set (MgDesktop_SRCS
+ MgDesktopBuild.cpp
+add_definitions(-DDWFCORE_STATIC -DDWFTK_STATIC -DDWFTK_USE_DWFCORE_ZLIB -DDWFTK_BUILD_EXPAT -DWHIP_STATIC_LIB)
+add_library(MgDesktop-${MG_VERSION} SHARED ${MgDesktop_SRCS})
+target_link_libraries(MgDesktop-${MG_VERSION}
+ ${ACE_LIBRARY}
+ ${XERCESC_LIBRARIES}
+ ${FDO_LIBRARY}
+ ${FDO_EXPRESSIONENGINE_LIBRARY}
+ dwfcore
+ dwftk
+ dwfwhiptk
+ MgMdfModel-${MG_VERSION}
+ MgMdfParser-${MG_VERSION}
+ MgFoundation-${MG_VERSION}
+ MgPlatformBase-${MG_VERSION}
+ MgSecurity-${MG_VERSION}
+ MgRenderers-${MG_VERSION}
+ MgStylization-${MG_VERSION}
+ MgGwsCommon-${MG_VERSION}
+ MgGwsQueryEngine-${MG_VERSION}
+ pthread
Modified: sandbox/jng/cmake_v2/Desktop/MgDesktop/Services/Feature/FeatureConnection.h
--- sandbox/jng/cmake_v2/Desktop/MgDesktop/Services/Feature/FeatureConnection.h 2017-12-26 14:28:41 UTC (rev 9271)
+++ sandbox/jng/cmake_v2/Desktop/MgDesktop/Services/Feature/FeatureConnection.h 2018-01-04 09:43:37 UTC (rev 9272)
@@ -5,7 +5,6 @@
class MgResourceIdentifier;
class MgdFdoConnectionPool;
-template class Ptr<MgResourceIdentifier>;
/// \cond INTERNAL
class MgdFeatureConnection : public MgGuardDisposable
Added: sandbox/jng/cmake_v2/Desktop/UnitTest/CMakeLists.txt
--- sandbox/jng/cmake_v2/Desktop/UnitTest/CMakeLists.txt (rev 0)
+++ sandbox/jng/cmake_v2/Desktop/UnitTest/CMakeLists.txt 2018-01-04 09:43:37 UTC (rev 9272)
@@ -0,0 +1,45 @@
+ ${CMAKE_CURRENT_SOURCE_DIR}/../MgDesktop
+ ${CMAKE_CURRENT_SOURCE_DIR}/../MgDesktop/Services
+ ${CPPUNIT_INCLUDE_DIR}
+set (UnitTest_SRCS
+ main.cpp
+ TestFeatureService.cpp
+ #TestKmlService.cpp
+ TestLogManager.cpp
+ TestLogManagerThread.cpp
+ TestMappingService.cpp
+ #TestPerformance.cpp
+ TestProfilingService.cpp
+ TestRenderingService.cpp
+ TestResourceService.cpp
+ TestTileService.cpp
+add_executable(UnitTest ${UnitTest_SRCS})
+target_link_libraries(UnitTest
+ ${ACE_LIBRARY}
+ ${FDO_LIBRARY}
+ ${CPPUNIT_LIBRARIES}
+ MgDesktop-${MG_VERSION}
Modified: sandbox/jng/cmake_v2/Desktop/UnitTest/TestFeatureService.cpp
--- sandbox/jng/cmake_v2/Desktop/UnitTest/TestFeatureService.cpp 2017-12-26 14:28:41 UTC (rev 9271)
+++ sandbox/jng/cmake_v2/Desktop/UnitTest/TestFeatureService.cpp 2018-01-04 09:43:37 UTC (rev 9272)
@@ -21,6 +21,7 @@
#include "TestFeatureService.h"
#include "CppUnitExtensions.h"
#include "Fdo.h"
+#include <ctime>
//Uncommenting this will make the join benchmarks 10-15x slower (because we're writing each feature out!)
@@ -3162,7 +3163,7 @@
#else
const int iterations = 1000;
#endif
- long lStart = GetTickCount();
+ clock_t clock_start = clock();
for(int i=0;i<iterations;i++)
int nFeatures = 0;
@@ -3176,8 +3177,8 @@
reader->Close();
CPPUNIT_ASSERT(nFeatures == 17565);
- ACE_DEBUG((LM_INFO, ACE_TEXT(" Execution Time (Average of %d runs): = %6.4f (s)\n"), iterations, ((GetTickCount()-lStart)/1000.0)/(double)iterations ));
+ clock_t clock_end = clock();
+ ACE_DEBUG((LM_INFO, ACE_TEXT(" Execution Time (Average of %d runs): = %6.4f (s)\n"), iterations, ((double)(clock_end - clock_start) / CLOCKS_PER_SEC)/(double)iterations ));
ACE_DEBUG((LM_INFO, ACE_TEXT("TestCase_BenchmarkSelectFeatures - END\n")));
catch(MgException* e)
@@ -3624,18 +3625,18 @@
// ----- Start the tests ------- //
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSdfJoin() - Inner Join \n")));
reader = featSvc->SelectFeatures(fsId, L"ParcelsInner", NULL);
while(reader->ReadNext())
total++;
reader->Close();
- ACE_DEBUG((LM_INFO, ACE_TEXT(" Execution Time (%d results): = %6.4f (s)\n"), total, ((GetTickCount()-lStart)/1000.0) ));
+ ACE_DEBUG((LM_INFO, ACE_TEXT(" Execution Time (%d results): = %6.4f (s)\n"), total, ((double)(clock_end - clock_start) / CLOCKS_PER_SEC) ));
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSdfJoin() - Left Outer Join \n")));
- lStart = GetTickCount();
+ clock_start = clock();
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsLeftOuter", NULL);
@@ -3644,10 +3645,10 @@
total++;
reader->Close();
+ clock_end = clock();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSdfJoin() - Inner Join (Forced 1:1) \n")));
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsInnerOneToOne", NULL);
@@ -3656,10 +3657,10 @@
total++;
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSdfJoin() - Left Outer Join (Forced 1:1) \n")));
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsLeftOuterOneToOne", NULL);
@@ -3668,8 +3669,8 @@
total++;
reader->Close();
@@ -3724,7 +3725,7 @@
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSqliteJoin() - Inner Join \n")));
long total = 0L;
@@ -3733,10 +3734,10 @@
total++;
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSqliteJoin() - Left Outer Join \n")));
total = 0L;
@@ -3745,10 +3746,10 @@
total++;
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSqliteJoin() - Inner Join (Forced 1:1) \n")));
total = 0L;
@@ -3757,10 +3758,10 @@
total++;
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSqliteJoin() - Left Outer Join (Forced 1:1) \n")));
total = 0L;
@@ -3769,8 +3770,8 @@
total++;
reader->Close();
@@ -3819,7 +3820,7 @@
aggOpts->AddComputedProperty(L"TotalCount", L"Count(SdfId)");
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSqliteAggregateJoin() - Inner Join \n")));
long total = 0L;
int iterations = 0;
@@ -3832,10 +3833,10 @@
reader->Close();
CPPUNIT_ASSERT(iterations == 1);
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSqliteAggregateJoin() - Left Outer Join \n")));
iterations = 0L;
reader = featSvc->SelectAggregate(fsId, L"ParcelsLeftOuter", aggOpts);
@@ -3847,10 +3848,10 @@
reader->Close();
CPPUNIT_ASSERT(iterations == 1L);
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSqliteAggregateJoin() - Inner Join (Forced 1:1) \n")));
iterations = 0L;
reader = featSvc->SelectAggregate(fsId, L"ParcelsInnerOneToOne", aggOpts);
@@ -3862,10 +3863,10 @@
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSqliteAggregateJoin() - Left Outer Join (Forced 1:1) \n")));
iterations = 0L;
reader = featSvc->SelectAggregate(fsId, L"ParcelsLeftOuterOneToOne", aggOpts);
@@ -3877,8 +3878,8 @@
reader->Close();
@@ -3924,7 +3925,7 @@
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkMergeSortJoin() - Inner Join \n")));
long total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsInnerSortMerge", NULL);
@@ -3945,10 +3946,10 @@
total++;
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkMergeSortJoin() - Left Outer Join \n")));
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsLeftOuterSortMerge", NULL);
@@ -3965,10 +3966,10 @@
total++;
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkMergeSortJoin() - Inner Join (Forced 1:1) \n")));
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsInnerOneToOneSortMerge", NULL);
@@ -3985,10 +3986,10 @@
total++;
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkMergeSortJoin() - Left Outer Join (Forced 1:1) \n")));
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsLeftOuterOneToOneSortMerge", NULL);
@@ -4005,8 +4006,8 @@
total++;
reader->Close();
@@ -4052,7 +4053,7 @@
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkBatchSortedBlockJoin() - Inner Join \n")));
long total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsInnerBatchSortedBlock", NULL);
@@ -4073,10 +4074,10 @@
total++;
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkBatchSortedBlockJoin() - Left Outer Join \n")));
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsLeftOuterBatchSortedBlock", NULL);
@@ -4093,10 +4094,10 @@
total++;
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkBatchSortedBlockJoin() - Inner Join (Forced 1:1) \n")));
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsInnerOneToOneBatchSortedBlock", NULL);
@@ -4113,10 +4114,10 @@
total++;
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkBatchSortedBlockJoin() - Left Outer Join (Forced 1:1) \n")));
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsLeftOuterOneToOneBatchSortedBlock", NULL);
@@ -4133,8 +4134,8 @@
total++;
reader->Close();
@@ -4180,7 +4181,7 @@
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkNestedLoopsSortedBlockJoin() - Inner Join \n")));
long total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsInnerNestedLoopSortedBlock", NULL);
@@ -4201,10 +4202,10 @@
total++;
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkNestedLoopsSortedBlockJoin() - Left Outer Join \n")));
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsLeftOuterNestedLoopSortedBlock", NULL);
@@ -4221,10 +4222,10 @@
total++;
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkNestedLoopsSortedBlockJoin() - Inner Join (Forced 1:1) \n")));
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsInnerOneToOneNestedLoopSortedBlock", NULL);
@@ -4241,10 +4242,10 @@
total++;
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkNestedLoopsSortedBlockJoin() - Left Outer Join (Forced 1:1) \n")));
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsLeftOuterOneToOneNestedLoopSortedBlock", NULL);
@@ -4261,8 +4262,8 @@
total++;
reader->Close();
@@ -4539,7 +4540,7 @@
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkNestedLoopsJoin() - Inner Join \n")));
long total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsInnerNestedLoops", NULL);
@@ -4561,10 +4562,10 @@
total++;
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkNestedLoopsJoin() - Left Outer Join \n")));
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsLeftOuterNestedLoops", NULL);
@@ -4581,10 +4582,10 @@
total++;
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkNestedLoopsJoin() - Inner Join (Forced 1:1) \n")));
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsInnerOneToOneNestedLoops", NULL);
@@ -4601,10 +4602,10 @@
total++;
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkNestedLoopsJoin() - Left Outer Join (Forced 1:1) \n")));
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsLeftOuterOneToOneNestedLoops", NULL);
@@ -4621,8 +4622,8 @@
total++;
reader->Close();
Modified: sandbox/jng/cmake_v2/Desktop/UnitTest/TestResourceService.cpp
--- sandbox/jng/cmake_v2/Desktop/UnitTest/TestResourceService.cpp 2017-12-26 14:28:41 UTC (rev 9271)
+++ sandbox/jng/cmake_v2/Desktop/UnitTest/TestResourceService.cpp 2018-01-04 09:43:37 UTC (rev 9272)
@@ -16,10 +16,11 @@
#include "MgDesktop.h"
-#include "Services\Resource\ResourceContentCache.h"
+#include "Services/Resource/ResourceContentCache.h"
#include "Fdo.h"
#include "TestResourceService.h"
+#include <ctime>
CPPUNIT_TEST_SUITE_NAMED_REGISTRATION(TestResourceService, "TestResourceService");
@@ -1122,78 +1123,82 @@
void TestResourceService::TestCase_BenchmarkGetResourceContents()
- try
- Ptr<MgdServiceFactory> fact = new MgdServiceFactory();
+ try
+ Ptr<MgdServiceFactory> fact = new MgdServiceFactory();
Ptr<MgResourceService> pService = dynamic_cast<MgResourceService*>(fact->CreateService(MgServiceType::ResourceService));
if (pService == 0)
throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_BenchmarkGetResourceContents", __LINE__, __WFILE__, NULL, L"", NULL);
- Ptr<MgStringCollection> resources = new MgStringCollection();
+ Ptr<MgStringCollection> resources = new MgStringCollection();
- Ptr<MgByteSource> source = new MgByteSource(resourceContentFileName2);
- Ptr<MgByteReader> reader = source->GetReader();
- // Prepare the resources
- for (INT32 i = 0; i < 150; i++)
- STRING numStr;
- MgUtil::Int32ToString(i, numStr);
- STRING resIdStr = L"Library://BatchTests/Layer";
- resIdStr += numStr;
- resIdStr += L".LayerDefinition";
+ Ptr<MgByteSource> source = new MgByteSource(resourceContentFileName2);
+ Ptr<MgByteReader> reader = source->GetReader();
+ // Prepare the resources
+ for (INT32 i = 0; i < 150; i++)
+ STRING numStr;
+ MgUtil::Int32ToString(i, numStr);
+ STRING resIdStr = L"Library://BatchTests/Layer";
+ resIdStr += numStr;
+ resIdStr += L".LayerDefinition";
- Ptr<MgResourceIdentifier> resId = new MgResourceIdentifier(resIdStr);
- pService->SetResource(resId, reader, NULL);
- resources->Add(resId->ToString());
- reader->Rewind();
+ Ptr<MgResourceIdentifier> resId = new MgResourceIdentifier(resIdStr);
+ pService->SetResource(resId, reader, NULL);
+ resources->Add(resId->ToString());
+ reader->Rewind();
- //Evict all cached copies to avoid distortion of results due to caching
- MgdResourceContentCache* cache = MgdResourceContentCache::GetInstance();
- cache->Clear();
+ //Evict all cached copies to avoid distortion of results due to caching
+ MgdResourceContentCache* cache = MgdResourceContentCache::GetInstance();
+ cache->Clear();
- ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestResourceService::TestCase_BenchmarkGetResourceContents() - Individual GetResourceContent calls (cold) \n")));
- for (INT32 i = 0; i < resources->GetCount(); i++)
- Ptr<MgResourceIdentifier> resId = new MgResourceIdentifier(resources->GetItem(i));
- Ptr<MgByteReader> content = pService->GetResourceContent(resId);
- ACE_DEBUG((LM_INFO, ACE_TEXT(" Execution Time: = %6.4f (s)\n"), ((GetTickCount()-lStart)/1000.0) ));
- ACE_DEBUG((LM_INFO, ACE_TEXT(" %d resource content items in cache\n"), (cache->GetCacheSize()) ));
+ ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestResourceService::TestCase_BenchmarkGetResourceContents() - Individual GetResourceContent calls (cold) \n")));
+ for (INT32 i = 0; i < resources->GetCount(); i++)
+ Ptr<MgResourceIdentifier> resId = new MgResourceIdentifier(resources->GetItem(i));
+ Ptr<MgByteReader> content = pService->GetResourceContent(resId);
+ ACE_DEBUG((LM_INFO, ACE_TEXT(" Execution Time: = %6.4f (s)\n"), ((double)(clock_end - clock_start) / CLOCKS_PER_SEC) ));
+ ACE_DEBUG((LM_INFO, ACE_TEXT(" %d resource content items in cache\n"), (cache->GetCacheSize()) ));
- ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestResourceService::TestCase_BenchmarkGetResourceContents() - Individual GetResourceContent calls (cached contents) \n")));
+ ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestResourceService::TestCase_BenchmarkGetResourceContents() - Individual GetResourceContent calls (cached contents) \n")));
cache->Clear();
- Ptr<MgStringCollection> contents;
- ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestResourceService::TestCase_BenchmarkGetResourceContents() - Multi-threaded GetResourceContents call (cold) \n")));
- contents = pService->GetResourceContents(resources, NULL);
- CPPUNIT_ASSERT(NULL != contents.p);
- CPPUNIT_ASSERT(contents->GetCount() == resources->GetCount());
+ Ptr<MgStringCollection> contents;
+ ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestResourceService::TestCase_BenchmarkGetResourceContents() - Multi-threaded GetResourceContents call (cold) \n")));
+ contents = pService->GetResourceContents(resources, NULL);
+ CPPUNIT_ASSERT(NULL != contents.p);
+ CPPUNIT_ASSERT(contents->GetCount() == resources->GetCount());
- ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestResourceService::TestCase_BenchmarkGetResourceContents() - Multi-threaded GetResourceContents call (cached contents) \n")));
+ ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestResourceService::TestCase_BenchmarkGetResourceContents() - Multi-threaded GetResourceContents call (cached contents) \n")));
STRING message = e->GetDetails(TEST_LOCALE);
Added: sandbox/jng/cmake_v2/cmake/modules/FindCppUnit.cmake
--- sandbox/jng/cmake_v2/cmake/modules/FindCppUnit.cmake (rev 0)
+++ sandbox/jng/cmake_v2/cmake/modules/FindCppUnit.cmake 2018-01-04 09:43:37 UTC (rev 9272)
@@ -0,0 +1,60 @@
+# - Try to find cppunit
+# Once done this will define
+# CPPUNIT_FOUND - System has cppunit
+# CPPUNIT_INCLUDE_DIR - The cppunit include directory
+# CPPUNIT_LIBRARY_DIR - The cppunit library dir
+# CPPUNIT_LIBRARIES - The libraries needed to use cppunit
+# CPPUNIT_DEFINITIONS - Compiler switches required for using cppunit
+# Copyright (c) 2009, Helio Chissini de Castro, <helio at kde.org>
+# Redistribution and use is allowed according to the terms of the BSD license.
+# For details see the accompanying COPYING-CMAKE-SCRIPTS file.
+IF (CPPUNIT_INCLUDE_DIR AND CPPUNIT_LIBRARIES)
+ # in cache already
+ SET(cppunit_FIND_QUIETLY TRUE)
+ENDIF (CPPUNIT_INCLUDE_DIR AND CPPUNIT_LIBRARIES)
+IF (NOT WIN32)
+ # use pkg-config to get the directories and then use these values
+ # in the FIND_PATH() and FIND_LIBRARY() calls
+ FIND_PACKAGE(PkgConfig)
+ PKG_CHECK_MODULES(PC_CPPUNIT cppunit)
+ SET(CPPUNIT_DEFINITIONS ${PC_CPPUNIT_CFLAGS_OTHER})
+ SET(CPPUNIT_LIBRARY_DIR ${PC_CPPUNIT_LIBRARY_DIRS})
+ENDIF (NOT WIN32)
+FIND_PATH(CPPUNIT_INCLUDE_DIR cppunit/CompilerOutputter.h
+ HINTS
+ ${PC_CPPUNIT_INCLUDEDIR}
+ ${PC_CPPUNIT_INCLUDE_DIRS}
+ PATH_SUFFIXES cppunit
+FIND_LIBRARY(CPPUNIT_LIBRARIES NAMES cppunit
+ HINTS
+ ${PC_CPPUNIT_LIBDIR}
+ ${PC_CPPUNIT_LIBRARY_DIRS}
+INCLUDE(FindPackageHandleStandardArgs)
+# handle the QUIETLY and REQUIRED arguments and set CPPUNIT_FOUND to TRUE if
+# all listed variables are TRUE
+FIND_PACKAGE_HANDLE_STANDARD_ARGS(cppunit DEFAULT_MSG CPPUNIT_LIBRARIES CPPUNIT_INCLUDE_DIR)
+IF(CPPUNIT_FOUND)
+ TRY_COMPILE(CPPUNIT_MODERN_API ${CMAKE_BINARY_DIR}
+ ${CMAKE_CURRENT_SOURCE_DIR}/cmake/modules/TestCmakeVersion.cxx )
+ IF(CPPUNIT_MODERN_API)
+ MESSAGE(STATUS "CPPUNIT uses modern API ( > 1.10 )")
+ ADD_DEFINITIONS(-DCPPUNIT_MODERN_API)
+ ENDIF(CPPUNIT_MODERN_API)
+ MARK_AS_ADVANCED(CPPUNIT_INCLUDE_DIR CPPUNIT_LIBRARIES CPPUNIT_LIBRARY_DIR)
+ENDIF(CPPUNIT_FOUND)
Added: sandbox/jng/cmake_v2/cmake/modules/TestCmakeVersion.cxx
--- sandbox/jng/cmake_v2/cmake/modules/TestCmakeVersion.cxx (rev 0)
+++ sandbox/jng/cmake_v2/cmake/modules/TestCmakeVersion.cxx 2018-01-04 09:43:37 UTC (rev 9272)
@@ -0,0 +1,18 @@
+#include <cppunit/config-auto.h>
+#include <cstdlib>
+#include <cstdio>
+// Simple test against arbitrary versions > 1.10
+#define MIN_MAJOR 1
+#define MIN_MINOR 10
+int main(int, char*[])
+ char *base;
+ if( strtol( CPPUNIT_VERSION, &base, 10 ) == MIN_MAJOR )
+ if( strtol( ++base, NULL, 10 ) >= MIN_MINOR )
+ return 1;
+ return 0;
+ return 0;
More information about the mapguide-commits
