[mapguide-commits] r9279 - in sandbox/jng/cmake_v2/Oem/dbxml: . dbxml dbxml/dist/aclocal xqilla
svn_mapguide at osgeo.org
Fri Jan 5 05:35:40 PST 2018
Author: jng
Date: 2018-01-05 05:35:40 -0800 (Fri, 05 Jan 2018)
New Revision: 9279
sandbox/jng/cmake_v2/Oem/dbxml/buildall.sh
sandbox/jng/cmake_v2/Oem/dbxml/dbxml/configure
sandbox/jng/cmake_v2/Oem/dbxml/dbxml/dist/aclocal/options.ac
sandbox/jng/cmake_v2/Oem/dbxml/xqilla/configure
sandbox/jng/cmake_v2/Oem/dbxml/xqilla/configure.in
dbxml and xqilla can compile/link against a system-installed copy of xerces, but its configure scripts and the root buildall.sh are not aware of the Ubuntu paths where xerces is installed. This commit updates the configure scripts and buildall.sh to allow for building against a system-installed copy of xerces on Ubuntu
Modified: sandbox/jng/cmake_v2/Oem/dbxml/buildall.sh
--- sandbox/jng/cmake_v2/Oem/dbxml/buildall.sh 2018-01-05 11:44:27 UTC (rev 9278)
+++ sandbox/jng/cmake_v2/Oem/dbxml/buildall.sh 2018-01-05 13:35:40 UTC (rev 9279)
@@ -97,6 +97,9 @@
--build-one=<library> build only the specified library,
which is one of berkeleydb, xerces,
xqilla, dbxml, or perl
+ --have-system-xerces Specifies that you intend to use a system-installed
+ copy of xerces-c, thus xerces is not built when
+ --build-one is not specified
EOF
@@ -145,6 +148,7 @@
BUILD_PERL="no"
PERL_INSTALLDIR=""
PERL="perl"
+HAVE_SYSTEM_XERCES="no"
# Parse arguments
for option
@@ -210,6 +214,9 @@
DBXML_CONF_ARGS="$DBXML_CONF_ARGS $option"
JAVA_ENABLED="yes"
+ --have-system-xerces)
+ HAVE_SYSTEM_XERCES="yes"
--with-tcl=*)
DB_CONF_ARGS="$DB_CONF_ARGS $option"
@@ -383,41 +390,45 @@
# Xerces
# change args, depending on platform
-if [ $BUILD_ONE = "no" -o $BUILD_ONE = "xerces" ]; then
- echo Start Xerces build: `date`
- cd $XERCES_DIR
- if [ $DO_CONFIGURE = "yes" ]; then
- echo Configuring Xerces
- chmod +x ./configure
- eval $CONF_ENV ./configure --prefix=$XERCES_INSTALL_DIR \
- $XERCES_CONF_ARGS $XERCES_CONF_XARGS || exit $?
- fi
+if [ $HAVE_SYSTEM_XERCES = "no" ]; then
+ if [ $BUILD_ONE = "no" -o $BUILD_ONE = "xerces" ]; then
+ echo Start Xerces build: `date`
+ cd $XERCES_DIR
+ if [ $DO_CONFIGURE = "yes" ]; then
+ echo Configuring Xerces
+ chmod +x ./configure
+ eval $CONF_ENV ./configure --prefix=$XERCES_INSTALL_DIR \
+ $XERCES_CONF_ARGS $XERCES_CONF_XARGS || exit $?
+ fi
- echo Building Xerces
- # only build source/library tree
- cd src
- $MAKE || exit $?
- cd ..
+ echo Building Xerces
+ # only build source/library tree
+ cd src
+ $MAKE || exit $?
+ cd ..
- if [ $DO_INSTALL = "yes" ]; then
- echo Installing Xerces
- # remove symlinks that cause make install to fail if re-run
- for i in $XERCES_TO_REMOVE
- do
- rm -f $XERCES_INSTALL_DIR/lib/$i
- done
- # only install source tree, not samples
- cd src
- $MAKE install || exit $?
- cd ..
- # remove unused xerces library. Cannot suppress build, but can remove it.
- for i in $XERCES_DEPDOM
- do
- done
+ if [ $DO_INSTALL = "yes" ]; then
+ echo Installing Xerces
+ # remove symlinks that cause make install to fail if re-run
+ for i in $XERCES_TO_REMOVE
+ do
+ rm -f $XERCES_INSTALL_DIR/lib/$i
+ done
+ # only install source tree, not samples
+ cd src
+ $MAKE install || exit $?
+ cd ..
+ # remove unused xerces library. Cannot suppress build, but can remove it.
+ for i in $XERCES_DEPDOM
+ do
+ done
+ fi
+ cd $TOP
+ echo End Xerces build: `date`
fi
- cd $TOP
- echo End Xerces build: `date`
+else
+ echo Skipping Xerces build as HAVE_SYSTEM_XERCES is $HAVE_SYSTEM_XERCES
fi
echo "********************************"
@@ -458,6 +469,10 @@
if [ $BUILD_ONE = "no" -o $BUILD_ONE = "dbxml" ]; then
echo Start DB XML build: `date`
cd $DBXML_BUILD_DIR
+ XERCES_INST=$XERCES_DIR
+ if [ ! -d $XERCES_INST ]; then
+ XERCES_INST=$XERCES_INSTALL_DIR
+ fi
echo Configuring DB XML
# Note: passing ../../$DB_DIR for --with-dbbuild will not work
@@ -466,7 +481,7 @@
chmod +x ../configure
eval $CONF_ENV ../configure --prefix=$DBXML_INSTALL_DIR \
--with-xqilla=$XQILLA_INSTALL_DIR \
- --with-xerces=$XERCES_INSTALL_DIR \
+ --with-xerces=$XERCES_INST \
--with-berkeleydb=$DB_INSTALL_DIR \
--with-dbbuild=../../$DB_DIR $DBXML_CONF_ARGS \
$DBXML_CONF_XARGS || exit $?
Modified: sandbox/jng/cmake_v2/Oem/dbxml/dbxml/configure
--- sandbox/jng/cmake_v2/Oem/dbxml/dbxml/configure 2018-01-05 11:44:27 UTC (rev 9278)
+++ sandbox/jng/cmake_v2/Oem/dbxml/dbxml/configure 2018-01-05 13:35:40 UTC (rev 9279)
@@ -1,62 +1,83 @@
#! /bin/sh
# Guess values for system-dependent variables and create Makefiles.
-# Generated by GNU Autoconf 2.61 for Berkeley DB XML 2.5.16.
+# Generated by GNU Autoconf 2.69 for Berkeley DB XML 2.5.16.
# Report bugs to <Oracle Technology Network Berkeley DB XML forum>.
-# Copyright (C) 1992, 1993, 1994, 1995, 1996, 1998, 1999, 2000, 2001,
-# 2002, 2003, 2004, 2005, 2006 Free Software Foundation, Inc.
+# Copyright (C) 1992-1996, 1998-2012 Free Software Foundation, Inc.
# This configure script is free software; the Free Software Foundation
# gives unlimited permission to copy, distribute and modify it.
-## M4sh Initialization. ##
+## M4sh Initialization. ##
# Be more Bourne compatible
DUALCASE=1; export DUALCASE # for MKS sh
-if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
+if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then :
emulate sh
NULLCMD=:
- # Zsh 3.x and 4.x performs word splitting on ${1+"$@"}, which
+ # Pre-4.2 versions of Zsh do word splitting on ${1+"$@"}, which
# is contrary to our usage. Disable this feature.
alias -g '${1+"$@"}'='"$@"'
setopt NO_GLOB_SUBST
else
- case `(set -o) 2>/dev/null` in
- *posix*) set -o posix ;;
+ case `(set -o) 2>/dev/null` in #(
+ *posix*) :
+ set -o posix ;; #(
esac
fi
-# PATH needs CR
-# Avoid depending upon Character Ranges.
-as_cr_letters='abcdefghijklmnopqrstuvwxyz'
-as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
-as_cr_Letters=$as_cr_letters$as_cr_LETTERS
-as_cr_digits='0123456789'
-as_cr_alnum=$as_cr_Letters$as_cr_digits
-# The user is always right.
-if test "${PATH_SEPARATOR+set}" != set; then
- echo "#! /bin/sh" >conf$$.sh
- echo "exit 0" >>conf$$.sh
- chmod +x conf$$.sh
- if (PATH="/nonexistent;."; conf$$.sh) >/dev/null 2>&1; then
- PATH_SEPARATOR=';'
+as_nl='
+export as_nl
+# Printing a long string crashes Solaris 7 /usr/bin/printf.
+as_echo='\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\'
+as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo
+as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo$as_echo
+# Prefer a ksh shell builtin over an external printf program on Solaris,
+# but without wasting forks for bash or zsh.
+if test -z "$BASH_VERSION$ZSH_VERSION" \
+ && (test "X`print -r -- $as_echo`" = "X$as_echo") 2>/dev/null; then
+ as_echo='print -r --'
+ as_echo_n='print -rn --'
+elif (test "X`printf %s $as_echo`" = "X$as_echo") 2>/dev/null; then
+ as_echo='printf %s\n'
+ as_echo_n='printf %s'
+else
+ if test "X`(/usr/ucb/echo -n -n $as_echo) 2>/dev/null`" = "X-n $as_echo"; then
+ as_echo_body='eval /usr/ucb/echo -n "$1$as_nl"'
+ as_echo_n='/usr/ucb/echo -n'
else
- PATH_SEPARATOR=:
+ as_echo_body='eval expr "X$1" : "X\\(.*\\)"'
+ as_echo_n_body='eval
+ arg=$1;
+ case $arg in #(
+ *"$as_nl"*)
+ expr "X$arg" : "X\\(.*\\)$as_nl";
+ arg=`expr "X$arg" : ".*$as_nl\\(.*\\)"`;;
+ esac;
+ expr "X$arg" : "X\\(.*\\)" | tr -d "$as_nl"
+ export as_echo_n_body
+ as_echo_n='sh -c $as_echo_n_body as_echo'
fi
- rm -f conf$$.sh
+ export as_echo_body
+ as_echo='sh -c $as_echo_body as_echo'
fi
-# Support unset when possible.
-if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then
- as_unset=unset
-else
- as_unset=false
+# The user is always right.
+if test "${PATH_SEPARATOR+set}" != set; then
+ PATH_SEPARATOR=:
+ (PATH='/bin;/bin'; FPATH=$PATH; sh -c :) >/dev/null 2>&1 && {
+ (PATH='/bin:/bin'; FPATH=$PATH; sh -c :) >/dev/null 2>&1 ||
+ PATH_SEPARATOR=';'
fi
@@ -65,20 +86,19 @@
# there to prevent editors from complaining about space-tab.
# (If _AS_PATH_WALK were called with IFS unset, it would disable word
# splitting by setting IFS to empty value.)
-as_nl='
IFS=" "" $as_nl"
# Find who we are. Look in the path if we contain no directory separator.
-case $0 in
+as_myself=
+case $0 in #((
*[\\/]* ) as_myself=$0 ;;
*) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
for as_dir in $PATH
do
IFS=$as_save_IFS
test -z "$as_dir" && as_dir=.
- test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
-done
+ test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
+ done
IFS=$as_save_IFS
@@ -89,354 +109,367 @@
as_myself=$0
fi
if test ! -f "$as_myself"; then
- echo "$as_myself: error: cannot find myself; rerun with an absolute file name" >&2
- { (exit 1); exit 1; }
+ $as_echo "$as_myself: error: cannot find myself; rerun with an absolute file name" >&2
+ exit 1
fi
-# Work around bugs in pre-3.0 UWIN ksh.
-for as_var in ENV MAIL MAILPATH
-do ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var
+# Unset variables that we do not need and which cause bugs (e.g. in
+# pre-3.0 UWIN ksh). But do not cause bugs in bash 2.01; the "|| exit 1"
+# suppresses any "Segmentation fault" message there. '((' could
+# trigger a bug in pdksh 5.2.14.
+for as_var in BASH_ENV ENV MAIL MAILPATH
+do eval test x\${$as_var+set} = xset \
+ && ( (unset $as_var) || exit 1) >/dev/null 2>&1 && unset $as_var || :
done
PS1='$ '
PS2='> '
PS4='+ '
# NLS nuisances.
-for as_var in \
- LANG LANGUAGE LC_ADDRESS LC_ALL LC_COLLATE LC_CTYPE LC_IDENTIFICATION \
- LC_MEASUREMENT LC_MESSAGES LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER \
- LC_TELEPHONE LC_TIME
-do
- if (set +x; test -z "`(eval $as_var=C; export $as_var) 2>&1`"); then
- eval $as_var=C; export $as_var
- else
- ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var
- fi
-done
+LC_ALL=C
+export LC_ALL
+LANGUAGE=C
+export LANGUAGE
-# Required to use basename.
-if expr a : '\(a\)' >/dev/null 2>&1 &&
- test "X`expr 00001 : '.*\(...\)'`" = X001; then
- as_expr=expr
-else
- as_expr=false
-fi
-if (basename -- /) >/dev/null 2>&1 && test "X`basename -- / 2>&1`" = "X/"; then
- as_basename=basename
-else
- as_basename=false
-fi
-# Name of the executable.
-as_me=`$as_basename -- "$0" ||
-$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
- X"$0" : 'X\(//\)$' \| \
- X"$0" : 'X\(/\)' \| . 2>/dev/null ||
-echo X/"$0" |
- sed '/^.*\/\([^/][^/]*\)\/*$/{
- s//\1/
- q
- /^X\/\(\/\/\)$/{
- s//\1/
- q
- /^X\/\(\/\).*/{
- s//\1/
- q
- s/.*/./; q'`
# CDPATH.
-$as_unset CDPATH
+(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
+# Use a proper internal environment variable to ensure we don't fall
+ # into an infinite loop, continuously re-executing ourselves.
+ if test x"${_as_can_reexec}" != xno && test "x$CONFIG_SHELL" != x; then
+ _as_can_reexec=no; export _as_can_reexec;
+ # We cannot yet assume a decent shell, so we have to provide a
+# neutralization value for shells without unset; and this also
+# works around shells that cannot unset nonexistent variables.
+# Preserve -v and -x to the replacement shell.
+BASH_ENV=/dev/null
+ENV=/dev/null
+(unset BASH_ENV) >/dev/null 2>&1 && unset BASH_ENV ENV
+case $- in # ((((
+ *v*x* | *x*v* ) as_opts=-vx ;;
+ *v* ) as_opts=-v ;;
+ *x* ) as_opts=-x ;;
+ * ) as_opts= ;;
+esac
+exec $CONFIG_SHELL $as_opts "$as_myself" ${1+"$@"}
+# Admittedly, this is quite paranoid, since all the known shells bail
+# out after a failed `exec'.
+$as_echo "$0: could not re-execute with $CONFIG_SHELL" >&2
+as_fn_exit 255
+ fi
+ # We don't want this to propagate to other subprocesses.
+ { _as_can_reexec=; unset _as_can_reexec;}
if test "x$CONFIG_SHELL" = x; then
- if (eval ":") 2>/dev/null; then
- as_have_required=yes
+ as_bourne_compatible="if test -n \"\${ZSH_VERSION+set}\" && (emulate sh) >/dev/null 2>&1; then :
+ emulate sh
+ NULLCMD=:
+ # Pre-4.2 versions of Zsh do word splitting on \${1+\"\$@\"}, which
+ # is contrary to our usage. Disable this feature.
+ alias -g '\${1+\"\$@\"}'='\"\$@\"'
+ setopt NO_GLOB_SUBST
else
- as_have_required=no
+ case \`(set -o) 2>/dev/null\` in #(
+ *posix*) :
+esac
fi
+ as_required="as_fn_return () { (exit \$1); }
+as_fn_success () { as_fn_return 0; }
+as_fn_failure () { as_fn_return 1; }
+as_fn_ret_success () { return 0; }
+as_fn_ret_failure () { return 1; }
- if test $as_have_required = yes && (eval ":
-(as_func_return () {
- (exit \$1)
-as_func_success () {
- as_func_return 0
-as_func_failure () {
- as_func_return 1
-as_func_ret_success () {
- return 0
-as_func_ret_failure () {
- return 1
exitcode=0
-if as_func_success; then
-else
- exitcode=1
- echo as_func_success failed.
-fi
+as_fn_success || { exitcode=1; echo as_fn_success failed.; }
+as_fn_failure && { exitcode=1; echo as_fn_failure succeeded.; }
+as_fn_ret_success || { exitcode=1; echo as_fn_ret_success failed.; }
+as_fn_ret_failure && { exitcode=1; echo as_fn_ret_failure succeeded.; }
+if ( set x; as_fn_ret_success y && test x = \"\$1\" ); then :
-if as_func_failure; then
- exitcode=1
- echo as_func_failure succeeded.
-fi
-if as_func_ret_success; then
else
- exitcode=1
- echo as_func_ret_success failed.
+ exitcode=1; echo positional parameters were not saved.
fi
-if as_func_ret_failure; then
- exitcode=1
- echo as_func_ret_failure succeeded.
-fi
-if ( set x; as_func_ret_success y && test x = \"\$1\" ); then
+test x\$exitcode = x0 || exit 1
+test -x / || exit 1"
+ as_suggested=" as_lineno_1=";as_suggested=$as_suggested$LINENO;as_suggested=$as_suggested" as_lineno_1a=\$LINENO
+ as_lineno_2=";as_suggested=$as_suggested$LINENO;as_suggested=$as_suggested" as_lineno_2a=\$LINENO
+ eval 'test \"x\$as_lineno_1'\$as_run'\" != \"x\$as_lineno_2'\$as_run'\" &&
+ test \"x\`expr \$as_lineno_1'\$as_run' + 1\`\" = \"x\$as_lineno_2'\$as_run'\"' || exit 1
+test \$(( 1 + 1 )) = 2 || exit 1"
+ if (eval "$as_required") 2>/dev/null; then :
+ as_have_required=yes
else
- exitcode=1
- echo positional parameters were not saved.
+ as_have_required=no
fi
+ if test x$as_have_required = xyes && (eval "$as_suggested") 2>/dev/null; then :
-test \$exitcode = 0) || { (exit 1); exit 1; }
- as_lineno_1=\$LINENO
- as_lineno_2=\$LINENO
- test \"x\$as_lineno_1\" != \"x\$as_lineno_2\" &&
- test \"x\`expr \$as_lineno_1 + 1\`\" = \"x\$as_lineno_2\") || { (exit 1); exit 1; }
-") 2> /dev/null; then
else
- as_candidate_shells=
- as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+ as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+as_found=false
for as_dir in /bin$PATH_SEPARATOR/usr/bin$PATH_SEPARATOR$PATH
do
IFS=$as_save_IFS
- case $as_dir in
+ as_found=:
+ case $as_dir in #(
for as_base in sh bash ksh sh5; do
- as_candidate_shells="$as_candidate_shells $as_dir/$as_base"
+ # Try only shells that exist, to save several forks.
+ as_shell=$as_dir/$as_base
+ if { test -f "$as_shell" || test -f "$as_shell.exe"; } &&
+ { $as_echo "$as_bourne_compatible""$as_required" | as_run=a "$as_shell"; } 2>/dev/null; then :
+ CONFIG_SHELL=$as_shell as_have_required=yes
+ if { $as_echo "$as_bourne_compatible""$as_suggested" | as_run=a "$as_shell"; } 2>/dev/null; then :
+ break 2
+fi
+fi
done;;
esac
+ as_found=false
done
+$as_found || { if { test -f "$SHELL" || test -f "$SHELL.exe"; } &&
+ { $as_echo "$as_bourne_compatible""$as_required" | as_run=a "$SHELL"; } 2>/dev/null; then :
+ CONFIG_SHELL=$SHELL as_have_required=yes
+fi; }
IFS=$as_save_IFS
- for as_shell in $as_candidate_shells $SHELL; do
- # Try only shells that exist, to save several forks.
- if { test -f "$as_shell" || test -f "$as_shell.exe"; } &&
- { ("$as_shell") 2> /dev/null <<\_ASEOF
- emulate sh
- NULLCMD=:
- # is contrary to our usage. Disable this feature.
- alias -g '${1+"$@"}'='"$@"'
- setopt NO_GLOB_SUBST
-else
+ if test "x$CONFIG_SHELL" != x; then :
+ export CONFIG_SHELL
+BASH_ENV=/dev/null
+ENV=/dev/null
+case $- in # ((((
+ * ) as_opts= ;;
esac
+exit 255
fi
-_ASEOF
-}; then
- CONFIG_SHELL=$as_shell
- if { "$as_shell" 2> /dev/null <<\_ASEOF
- emulate sh
- NULLCMD=:
-else
-esac
+ if test x$as_have_required = xno; then :
+ $as_echo "$0: This script requires a shell more modern than all"
+ $as_echo "$0: the shells that I found on your system."
+ if test x${ZSH_VERSION+set} = xset ; then
+ $as_echo "$0: In particular, zsh $ZSH_VERSION has bugs and should"
+ $as_echo "$0: be upgraded to zsh 4.3.4 or later."
+ else
+ $as_echo "$0: Please tell bug-autoconf at gnu.org and Oracle Technology
+$0: Network Berkeley DB XML forum about your system,
+$0: including any error possibly output before this
+$0: message. Then install a modern shell, or manually run
+$0: the script under such a shell if you do have one."
+ fi
+ exit 1
fi
- (exit $1)
- as_func_return 0
- as_func_return 1
- return 0
- return 1
-exitcode=0
-else
- exitcode=1
fi
- exitcode=1
fi
+SHELL=${CONFIG_SHELL-/bin/sh}
+export SHELL
+# Unset more variables known to interfere with behavior of common tools.
+CLICOLOR_FORCE= GREP_OPTIONS=
+unset CLICOLOR_FORCE GREP_OPTIONS
-else
- exitcode=1
-fi
+## M4sh Shell Functions. ##
+# as_fn_unset VAR
+# Portably unset VAR.
+as_fn_unset ()
+ { eval $1=; unset $1;}
+as_unset=as_fn_unset
- exitcode=1
-fi
+# as_fn_set_status STATUS
+# Set $? to STATUS, without forking.
+as_fn_set_status ()
+ return $1
+} # as_fn_set_status
-if ( set x; as_func_ret_success y && test x = "$1" ); then
-else
- exitcode=1
-fi
+# as_fn_exit STATUS
+# Exit the shell with STATUS, even in a "trap 0" or "set -e" context.
+as_fn_exit ()
+ set +e
+ as_fn_set_status $1
+ exit $1
+} # as_fn_exit
-test $exitcode = 0) || { (exit 1); exit 1; }
+# as_fn_mkdir_p
+# Create "$as_dir" as a directory, including parents if necessary.
+as_fn_mkdir_p ()
- as_lineno_1=$LINENO
- as_lineno_2=$LINENO
- test "x$as_lineno_1" != "x$as_lineno_2" &&
- test "x`expr $as_lineno_1 + 1`" = "x$as_lineno_2") || { (exit 1); exit 1; }
+ -*) as_dir=./$as_dir;;
+ esac
+ test -d "$as_dir" || eval $as_mkdir_p || {
+ as_dirs=
+ while :; do
+ *\'*) as_qdir=`$as_echo "$as_dir" | sed "s/'/'\\\\\\\\''/g"`;; #'(
+ *) as_qdir=$as_dir;;
+ esac
+ as_dirs="'$as_qdir' $as_dirs"
+ as_dir=`$as_dirname -- "$as_dir" ||
+$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
+ X"$as_dir" : 'X\(//\)[^/]' \| \
+ X"$as_dir" : 'X\(//\)$' \| \
+ X"$as_dir" : 'X\(/\)' \| . 2>/dev/null ||
+$as_echo X"$as_dir" |
+ sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{
+ s//\1/
+ q
+ /^X\(\/\/\)[^/].*/{
+ s//\1/
+ q
+ /^X\(\/\/\)$/{
+ s//\1/
+ q
+ /^X\(\/\).*/{
+ s//\1/
+ q
+ s/.*/./; q'`
+ test -d "$as_dir" && break
+ done
+ test -z "$as_dirs" || eval "mkdir $as_dirs"
+ } || test -d "$as_dir" || as_fn_error $? "cannot create directory $as_dir"
-_ASEOF
-}; then
- break
-fi
-fi
+} # as_fn_mkdir_p
- done
+# as_fn_executable_p FILE
+# Test if FILE is an executable regular file.
+as_fn_executable_p ()
+ test -f "$1" && test -x "$1"
+} # as_fn_executable_p
+# as_fn_append VAR VALUE
+# Append the text in VALUE to the end of the definition contained in VAR. Take
+# advantage of any shell optimizations that allow amortized linear growth over
+# repeated appends, instead of the typical quadratic growth present in naive
+# implementations.
+if (eval "as_var=1; as_var+=2; test x\$as_var = x12") 2>/dev/null; then :
+ eval 'as_fn_append ()
+ eval $1+=\$2
+else
+ as_fn_append ()
+ eval $1=\$$1\$2
+fi # as_fn_append
- if test "x$CONFIG_SHELL" != x; then
- for as_var in BASH_ENV ENV
- do ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var
- done
- export CONFIG_SHELL
- exec "$CONFIG_SHELL" "$as_myself" ${1+"$@"}
-fi
+# as_fn_arith ARG...
+# Perform arithmetic evaluation on the ARGs, and store the result in the
+# global $as_val. Take advantage of shells that can avoid forks. The arguments
+# must be portable across $(()) and expr.
+if (eval "test \$(( 1 + 1 )) = 2") 2>/dev/null; then :
+ eval 'as_fn_arith ()
+ as_val=$(( $* ))
+else
+ as_fn_arith ()
+ as_val=`expr "$@" || test $? -eq 1`
+fi # as_fn_arith
- if test $as_have_required = no; then
- echo This script requires a shell more modern than all the
- echo shells that I found on your system. Please install a
- echo modern shell, or manually run the script under such a
- echo shell if you do have one.
-fi
+# as_fn_error STATUS ERROR [LINENO LOG_FD]
+# Output "`basename $0`: error: ERROR" to stderr. If LINENO and LOG_FD are
+# provided, also output the error to LOG_FD, referencing LINENO. Then exit the
+# script with STATUS, using 1 if that was 0.
+as_fn_error ()
+ as_status=$1; test $as_status -eq 0 && as_status=1
+ if test "$4"; then
+ as_lineno=${as_lineno-"$3"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
+ $as_echo "$as_me:${as_lineno-$LINENO}: error: $2" >&$4
+ fi
+ $as_echo "$as_me: error: $2" >&2
+ as_fn_exit $as_status
+} # as_fn_error
-fi
-fi
-(eval "as_func_return () {
- (exit \$1)
- as_func_return 0
- as_func_return 1
- return 0
- return 1
-exitcode=0
+if expr a : '\(a\)' >/dev/null 2>&1 &&
+ test "X`expr 00001 : '.*\(...\)'`" = X001; then
+ as_expr=expr
else
- exitcode=1
+ as_expr=false
fi
- exitcode=1
-fi
+if (basename -- /) >/dev/null 2>&1 && test "X`basename -- / 2>&1`" = "X/"; then
+ as_basename=basename
else
- exitcode=1
+ as_basename=false
fi
- exitcode=1
-fi
+if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then
+ as_dirname=dirname
else
- exitcode=1
+ as_dirname=false
fi
-test \$exitcode = 0") || {
- echo No shell found that supports shell functions.
- echo Please tell autoconf at gnu.org about your system,
- echo including any error possibly output before this
- echo message
+as_me=`$as_basename -- "$0" ||
+$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
+ X"$0" : 'X\(//\)$' \| \
+ X"$0" : 'X\(/\)' \| . 2>/dev/null ||
+$as_echo X/"$0" |
+ sed '/^.*\/\([^/][^/]*\)\/*$/{
+ s//\1/
+ q
+ /^X\/\(\/\/\)$/{
+ s//\1/
+ q
+ /^X\/\(\/\).*/{
+ s//\1/
+ q
+ s/.*/./; q'`
+# Avoid depending upon Character Ranges.
+as_cr_letters='abcdefghijklmnopqrstuvwxyz'
+as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
+as_cr_Letters=$as_cr_letters$as_cr_LETTERS
+as_cr_digits='0123456789'
+as_cr_alnum=$as_cr_Letters$as_cr_digits
- test "x`expr $as_lineno_1 + 1`" = "x$as_lineno_2" || {
- # Create $as_me.lineno as a copy of $as_myself, but with $LINENO
- # uniformly replaced by the line number. The first 'sed' inserts a
- # line-number line after each line using $LINENO; the second 'sed'
- # does the real work. The second script uses 'N' to pair each
- # line-number line with the line containing $LINENO, and appends
- # trailing '-' during substitution so that $LINENO is not a special
- # case at line end.
- # (Raja R Harinath suggested sed '=', and Paul Eggert wrote the
- # scripts with optimization help from Paolo Bonzini. Blame Lee
- # E. McMahon (1931-1989) for sed's syntax. :-)
+ as_lineno_1=$LINENO as_lineno_1a=$LINENO
+ as_lineno_2=$LINENO as_lineno_2a=$LINENO
+ eval 'test "x$as_lineno_1'$as_run'" != "x$as_lineno_2'$as_run'" &&
+ test "x`expr $as_lineno_1'$as_run' + 1`" = "x$as_lineno_2'$as_run'"' || {
+ # Blame Lee E. McMahon (1931-1989) for sed's syntax. :-)
sed -n '
p
/[$]LINENO/=
@@ -453,9 +486,12 @@
s/-\n.*//
' >$as_me.lineno &&
chmod +x "$as_me.lineno" ||
- { echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2
- { (exit 1); exit 1; }; }
+ { $as_echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2; as_fn_exit 1; }
+ # If we had to re-execute with $CONFIG_SHELL, we're ensured to have
+ # already done that, so ensure we don't try to do so again and fall
+ # in an infinite loop. This has already happened in practice.
# Don't try to exec as it changes $[0], causing all sort of problems
# (the dirname of $[0] is not the place where we might find the
# original and so on. Autoconf is especially sensitive to this).
@@ -464,84 +500,55 @@
exit
-if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then
- as_dirname=dirname
-else
- as_dirname=false
-fi
ECHO_C= ECHO_N= ECHO_T=
-case `echo -n x` in
+case `echo -n x` in #(((((
-n*)
- case `echo 'x\c'` in
+ case `echo 'xy\c'` in
*c*) ECHO_T=' ';; # ECHO_T is single tab character.
- *) ECHO_C='\c';;
+ xy) ECHO_C='\c';;
+ *) echo `echo ksh88 bug on AIX 6.1` > /dev/null
+ ECHO_T=' ';;
esac;;
ECHO_N='-n';;
esac
- as_expr=expr
-else
- as_expr=false
-fi
rm -f conf$$ conf$$.exe conf$$.file
if test -d conf$$.dir; then
rm -f conf$$.dir/conf$$.file
else
rm -f conf$$.dir
- mkdir conf$$.dir
+ mkdir conf$$.dir 2>/dev/null
fi
-echo >conf$$.file
-if ln -s conf$$.file conf$$ 2>/dev/null; then
- as_ln_s='ln -s'
- # ... but there are two gotchas:
- # 1) On MSYS, both `ln -s file dir' and `ln file dir' fail.
- # 2) DJGPP < 2.04 has no symlinks; `ln -s' creates a wrapper executable.
- # In both cases, we have to default to `cp -p'.
- ln -s conf$$.file conf$$.dir 2>/dev/null && test ! -f conf$$.exe ||
- as_ln_s='cp -p'
-elif ln conf$$.file conf$$ 2>/dev/null; then
- as_ln_s=ln
+if (echo >conf$$.file) 2>/dev/null; then
+ if ln -s conf$$.file conf$$ 2>/dev/null; then
+ as_ln_s='ln -s'
+ # ... but there are two gotchas:
+ # 1) On MSYS, both `ln -s file dir' and `ln file dir' fail.
+ # 2) DJGPP < 2.04 has no symlinks; `ln -s' creates a wrapper executable.
+ # In both cases, we have to default to `cp -pR'.
+ ln -s conf$$.file conf$$.dir 2>/dev/null && test ! -f conf$$.exe ||
+ as_ln_s='cp -pR'
+ elif ln conf$$.file conf$$ 2>/dev/null; then
+ as_ln_s=ln
+ else
+ as_ln_s='cp -pR'
+ fi
else
- as_ln_s='cp -p'
+ as_ln_s='cp -pR'
fi
rm -f conf$$ conf$$.exe conf$$.dir/conf$$.file conf$$.file
rmdir conf$$.dir 2>/dev/null
if mkdir -p . 2>/dev/null; then
- as_mkdir_p=:
+ as_mkdir_p='mkdir -p "$as_dir"'
else
test -d ./-p && rmdir ./-p
as_mkdir_p=false
fi
-if test -x / >/dev/null 2>&1; then
- as_test_x='test -x'
-else
- if ls -dL / >/dev/null 2>&1; then
- as_ls_L_option=L
- else
- as_ls_L_option=
- fi
- as_test_x='
- eval sh -c '\''
- if test -d "$1"; then
- test -d "$1/.";
- else
- case $1 in
- -*)set "./$1";;
- esac;
- case `ls -ld'$as_ls_L_option' "$1" 2>/dev/null` in
- ???[sx]*):;;*)false;;esac;fi
- '\'' sh
-fi
-as_executable_p=$as_test_x
+as_test_x='test -x'
+as_executable_p=as_fn_executable_p
# Sed expression to map a string onto a valid CPP name.
as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
@@ -551,7 +558,6 @@
# Check that we are running under the correct shell.
@@ -705,10 +711,11 @@
tagnames=${tagnames+${tagnames},}F77
-exec 7<&0 </dev/null 6>&1
+test -n "$DJDIR" || exec 7<&0 </dev/null
+exec 6>&1
# Name of the host.
-# hostname on some systems (SVR3.2, Linux) returns a bogus exit status,
+# hostname on some systems (SVR3.2, old GNU/Linux) returns a bogus exit status,
# so uname gets run too.
ac_hostname=`(hostname || uname -n) 2>/dev/null | sed 1q`
@@ -723,7 +730,6 @@
subdirs=
MFLAGS=
MAKEFLAGS=
-SHELL=${CONFIG_SHELL-/bin/sh}
# Identity of this package.
PACKAGE_NAME='Berkeley DB XML'
@@ -731,6 +737,7 @@
PACKAGE_VERSION='2.5.16'
PACKAGE_STRING='Berkeley DB XML 2.5.16'
PACKAGE_BUGREPORT='Oracle Technology Network Berkeley DB XML forum'
+PACKAGE_URL=''
ac_unique_file="src/dbxml/Buffer.cpp"
ac_default_prefix=/usr/local/BerkeleyDBXML.2.5
@@ -770,162 +777,189 @@
# include <unistd.h>
#endif"
-ac_subst_vars='SHELL
-PATH_SEPARATOR
-PACKAGE_NAME
-PACKAGE_TARNAME
-PACKAGE_VERSION
-PACKAGE_STRING
-PACKAGE_BUGREPORT
-exec_prefix
-prefix
-program_transform_name
-bindir
-sbindir
-libexecdir
-datarootdir
-datadir
-sysconfdir
-sharedstatedir
-localstatedir
-includedir
-oldincludedir
-docdir
-infodir
-htmldir
-dvidir
-pdfdir
-psdir
-libdir
-localedir
-mandir
-DEFS
-ECHO_C
-ECHO_N
-ECHO_T
-LIBS
-build_alias
-host_alias
-target_alias
-INSTALL_PROGRAM
-INSTALL_SCRIPT
-INSTALL_DATA
-am__isrc
-CYGPATH_W
-PACKAGE
-VERSION
-ACLOCAL
-AUTOCONF
-AUTOMAKE
-AUTOHEADER
-MAKEINFO
-install_sh
-STRIP
-INSTALL_STRIP_PROGRAM
-mkdir_p
-AWK
-SET_MAKE
-am__leading_dot
-AMTAR
-am__tar
-am__untar
-build
-build_cpu
-build_vendor
-build_os
-host
-host_cpu
-host_vendor
-host_os
-DBXML_VERSION_MAJOR
-DBXML_VERSION_MINOR
-DBXML_VERSION_PATCH
-DBXML_VERSION_STRING
-DB_TCLLIB
-DB_TEST_PATH
-DB_UTIL_PATH
-DB_DIR
-berkeleydb_include
-berkeleydb_lib
-berkeleydb_library
-berkeleydb_jar
-XQILLA_DIR
-xqilla_include
-xqilla_lib
-XERCES_DIR
-xerces_include
-xerces_include_dir
-xerces_lib
-JUNIT_JAR
-zlib_include
-zlib_lib
-zlib_library
-BUILD_TCL_TRUE
-BUILD_TCL_FALSE
-BUILD_JAVA_TRUE
-BUILD_JAVA_FALSE
-BUILD_TEST_TRUE
-BUILD_TEST_FALSE
-USE_COMPRESSION_TRUE
-USE_COMPRESSION_FALSE
-CC
-CFLAGS
-LDFLAGS
-CPPFLAGS
-ac_ct_CC
-EXEEXT
-OBJEXT
-DEPDIR
-am__include
-am__quote
-AMDEP_TRUE
-AMDEP_FALSE
-AMDEPBACKSLASH
-CCDEPMODE
-am__fastdepCC_TRUE
-am__fastdepCC_FALSE
-CXX
-CXXFLAGS
-ac_ct_CXX
-CXXDEPMODE
-am__fastdepCXX_TRUE
-am__fastdepCXX_FALSE
-SED
-GREP
-EGREP
-LN_S
-ECHO
-AR
-RANLIB
-DSYMUTIL
-NMEDIT
-CPP
-CXXCPP
-F77
-FFLAGS
-ac_ct_F77
-LIBTOOL
-LIBOBJS
-POW_LIB
-JAVAC
-JAR
-_ACJNI_JAVAC
-JAVACFLAGS
-SWIGCPPFLAGS
-JAVA_INCLUDE_SPEC
-MODSUFFIX
-JAVA_LIBRARY_EXTENSION
-LIBJSO_LIBS
-LIBTSO_MODSUFFIX
-LIBTSO_LIBS
-TCL_LIBRARY_EXTENSION
-TCL_BIN_DIR
-TCL_INCLUDE_SPEC
-TCL_LIB_FILE
-TCL_SRC_DIR
+ac_subst_vars='LTLIBOBJS
TCL_TCLSH
-LTLIBOBJS'
+TCL_SRC_DIR
+TCL_LIB_FILE
+TCL_INCLUDE_SPEC
+TCL_BIN_DIR
+TCL_LIBRARY_EXTENSION
+LIBTSO_LIBS
+LIBTSO_MODSUFFIX
+LIBJSO_LIBS
+JAVA_LIBRARY_EXTENSION
+MODSUFFIX
+JAVA_INCLUDE_SPEC
+SWIGCPPFLAGS
+JAVACFLAGS
+_ACJNI_JAVAC
+JAR
+JAVAC
+POW_LIB
+LIBOBJS
+LIBTOOL
+ac_ct_F77
+FFLAGS
+F77
+CXXCPP
+CPP
+NMEDIT
+DSYMUTIL
+RANLIB
+AR
+ECHO
+LN_S
+EGREP
+GREP
+SED
+am__fastdepCXX_FALSE
+am__fastdepCXX_TRUE
+CXXDEPMODE
+ac_ct_CXX
+CXXFLAGS
+CXX
+am__fastdepCC_FALSE
+am__fastdepCC_TRUE
+CCDEPMODE
+AMDEPBACKSLASH
+AMDEP_FALSE
+AMDEP_TRUE
+am__quote
+am__include
+DEPDIR
+OBJEXT
+EXEEXT
+ac_ct_CC
+CPPFLAGS
+LDFLAGS
+CFLAGS
+CC
+USE_COMPRESSION_FALSE
+USE_COMPRESSION_TRUE
+BUILD_TEST_FALSE
+BUILD_TEST_TRUE
+BUILD_JAVA_FALSE
+BUILD_JAVA_TRUE
+BUILD_TCL_FALSE
+BUILD_TCL_TRUE
+zlib_library
+zlib_lib
+zlib_include
+JUNIT_JAR
+xerces_lib
+xerces_include_dir
+xerces_include
+XERCES_DIR
+xqilla_lib
+xqilla_include
+XQILLA_DIR
+berkeleydb_jar
+berkeleydb_library
+berkeleydb_lib
+berkeleydb_include
+DB_DIR
+DB_UTIL_PATH
+DB_TEST_PATH
+DB_TCLLIB
+DBXML_VERSION_STRING
+DBXML_VERSION_PATCH
+DBXML_VERSION_MINOR
+DBXML_VERSION_MAJOR
+host_os
+host_vendor
+host_cpu
+host
+build_os
+build_vendor
+build_cpu
+build
+am__untar
+am__tar
+AMTAR
+am__leading_dot
+SET_MAKE
+AWK
+mkdir_p
+MKDIR_P
+INSTALL_STRIP_PROGRAM
+STRIP
+install_sh
+MAKEINFO
+AUTOHEADER
+AUTOMAKE
+AUTOCONF
+ACLOCAL
+VERSION
+PACKAGE
+CYGPATH_W
+am__isrc
+INSTALL_DATA
+INSTALL_SCRIPT
+INSTALL_PROGRAM
+target_alias
+host_alias
+build_alias
+LIBS
+ECHO_T
+ECHO_N
+ECHO_C
+DEFS
+mandir
+localedir
+libdir
+psdir
+pdfdir
+dvidir
+htmldir
+infodir
+docdir
+oldincludedir
+includedir
+localstatedir
+sharedstatedir
+sysconfdir
+datadir
+datarootdir
+libexecdir
+sbindir
+bindir
+program_transform_name
+prefix
+exec_prefix
+PACKAGE_URL
+PACKAGE_BUGREPORT
+PACKAGE_STRING
+PACKAGE_VERSION
+PACKAGE_TARNAME
+PACKAGE_NAME
+PATH_SEPARATOR
+SHELL'
ac_subst_files=''
+ac_user_opts='
+enable_option_checking
+enable_debug
+enable_test
+with_berkeleydb
+with_dbbuild
+with_xqilla
+with_xerces
+enable_java
+with_junit
+enable_tcl
+with_tcl
+enable_compression
+with_zlib
+enable_static_zlib
+enable_rpath
+enable_dependency_tracking
+enable_shared
+enable_static
+enable_fast_install
+with_gnu_ld
+enable_libtool_lock
+with_pic
+with_tags
ac_precious_vars='build_alias
host_alias
target_alias
@@ -946,6 +980,8 @@
# Initialize some variables set by options.
ac_init_help=
ac_init_version=false
+ac_unrecognized_opts=
+ac_unrecognized_sep=
# The variables have the same names as the options, with
# dashes changed to underlines.
cache_file=/dev/null
@@ -1001,8 +1037,9 @@
fi
case $ac_option in
- *=*) ac_optarg=`expr "X$ac_option" : '[^=]*=\(.*\)'` ;;
- *) ac_optarg=yes ;;
+ *=?*) ac_optarg=`expr "X$ac_option" : '[^=]*=\(.*\)'` ;;
+ *=) ac_optarg= ;;
+ *) ac_optarg=yes ;;
esac
# Accept the important Cygnus configure options, so we can diagnose typos.
@@ -1044,13 +1081,20 @@
datarootdir=$ac_optarg ;;
-disable-* | --disable-*)
- ac_feature=`expr "x$ac_option" : 'x-*disable-\(.*\)'`
+ ac_useropt=`expr "x$ac_option" : 'x-*disable-\(.*\)'`
# Reject names that are not valid shell variable names.
- expr "x$ac_feature" : ".*[^-._$as_cr_alnum]" >/dev/null &&
- { echo "$as_me: error: invalid feature name: $ac_feature" >&2
- ac_feature=`echo $ac_feature | sed 's/[-.]/_/g'`
- eval enable_$ac_feature=no ;;
+ expr "x$ac_useropt" : ".*[^-+._$as_cr_alnum]" >/dev/null &&
+ as_fn_error $? "invalid feature name: $ac_useropt"
+ ac_useropt_orig=$ac_useropt
+ ac_useropt=`$as_echo "$ac_useropt" | sed 's/[-+.]/_/g'`
+ case $ac_user_opts in
+"enable_$ac_useropt"
+ *) ac_unrecognized_opts="$ac_unrecognized_opts$ac_unrecognized_sep--disable-$ac_useropt_orig"
+ ac_unrecognized_sep=', ';;
+ esac
+ eval enable_$ac_useropt=no ;;
-docdir | --docdir | --docdi | --doc | --do)
ac_prev=docdir ;;
@@ -1063,13 +1107,20 @@
dvidir=$ac_optarg ;;
-enable-* | --enable-*)
- ac_feature=`expr "x$ac_option" : 'x-*enable-\([^=]*\)'`
+ ac_useropt=`expr "x$ac_option" : 'x-*enable-\([^=]*\)'`
- eval enable_$ac_feature=\$ac_optarg ;;
+ *) ac_unrecognized_opts="$ac_unrecognized_opts$ac_unrecognized_sep--enable-$ac_useropt_orig"
+ esac
+ eval enable_$ac_useropt=\$ac_optarg ;;
-exec-prefix | --exec_prefix | --exec-prefix | --exec-prefi \
| --exec-pref | --exec-pre | --exec-pr | --exec-p | --exec- \
@@ -1260,22 +1311,36 @@
ac_init_version=: ;;
-with-* | --with-*)
- ac_package=`expr "x$ac_option" : 'x-*with-\([^=]*\)'`
+ ac_useropt=`expr "x$ac_option" : 'x-*with-\([^=]*\)'`
- expr "x$ac_package" : ".*[^-._$as_cr_alnum]" >/dev/null &&
- { echo "$as_me: error: invalid package name: $ac_package" >&2
- ac_package=`echo $ac_package | sed 's/[-.]/_/g'`
- eval with_$ac_package=\$ac_optarg ;;
+ as_fn_error $? "invalid package name: $ac_useropt"
+"with_$ac_useropt"
+ *) ac_unrecognized_opts="$ac_unrecognized_opts$ac_unrecognized_sep--with-$ac_useropt_orig"
+ esac
+ eval with_$ac_useropt=\$ac_optarg ;;
-without-* | --without-*)
- ac_package=`expr "x$ac_option" : 'x-*without-\(.*\)'`
+ ac_useropt=`expr "x$ac_option" : 'x-*without-\(.*\)'`
- eval with_$ac_package=no ;;
+"with_$ac_useropt"
+ *) ac_unrecognized_opts="$ac_unrecognized_opts$ac_unrecognized_sep--without-$ac_useropt_orig"
+ esac
+ eval with_$ac_useropt=no ;;
--x)
# Obsolete; use --with-x.
@@ -1295,26 +1360,26 @@
| --x-librar=* | --x-libra=* | --x-libr=* | --x-lib=* | --x-li=* | --x-l=*)
x_libraries=$ac_optarg ;;
- -*) { echo "$as_me: error: unrecognized option: $ac_option
-Try \`$0 --help' for more information." >&2
+ -*) as_fn_error $? "unrecognized option: \`$ac_option'
+Try \`$0 --help' for more information"
ac_envvar=`expr "x$ac_option" : 'x\([^=]*\)='`
- expr "x$ac_envvar" : ".*[^_$as_cr_alnum]" >/dev/null &&
- { echo "$as_me: error: invalid variable name: $ac_envvar" >&2
+ case $ac_envvar in #(
+ '' | [0-9]* | *[!_$as_cr_alnum]* )
+ as_fn_error $? "invalid variable name: \`$ac_envvar'" ;;
+ esac
eval $ac_envvar=\$ac_optarg
export $ac_envvar ;;
# FIXME: should be removed in autoconf 3.0.
- echo "$as_me: WARNING: you should use --build, --host, --target" >&2
+ $as_echo "$as_me: WARNING: you should use --build, --host, --target" >&2
expr "x$ac_option" : ".*[^-._$as_cr_alnum]" >/dev/null &&
- echo "$as_me: WARNING: invalid host type: $ac_option" >&2
- : ${build_alias=$ac_option} ${host_alias=$ac_option} ${target_alias=$ac_option}
+ $as_echo "$as_me: WARNING: invalid host type: $ac_option" >&2
+ : "${build_alias=$ac_option} ${host_alias=$ac_option} ${target_alias=$ac_option}"
esac
@@ -1322,23 +1387,36 @@
if test -n "$ac_prev"; then
ac_option=--`echo $ac_prev | sed 's/_/-/g'`
- { echo "$as_me: error: missing argument to $ac_option" >&2
+ as_fn_error $? "missing argument to $ac_option"
fi
-# Be sure to have absolute directory names.
+if test -n "$ac_unrecognized_opts"; then
+ case $enable_option_checking in
+ no) ;;
+ fatal) as_fn_error $? "unrecognized options: $ac_unrecognized_opts" ;;
+ *) $as_echo "$as_me: WARNING: unrecognized options: $ac_unrecognized_opts" >&2 ;;
+ esac
+fi
+# Check all directory arguments for consistency.
for ac_var in exec_prefix prefix bindir sbindir libexecdir datarootdir \
datadir sysconfdir sharedstatedir localstatedir includedir \
oldincludedir docdir infodir htmldir dvidir pdfdir psdir \
libdir localedir mandir
do
eval ac_val=\$$ac_var
+ # Remove trailing slashes.
case $ac_val in
+ ac_val=`expr "X$ac_val" : 'X\(.*[^/]\)' \| "X$ac_val" : 'X\(.*\)'`
+ eval $ac_var=\$ac_val;;
+ esac
+ # Be sure to have absolute directory names.
+ case $ac_val in
[\\/$]* | ?:[\\/]* ) continue;;
NONE | '' ) case $ac_var in *prefix ) continue;; esac;;
esac
- { echo "$as_me: error: expected an absolute directory name for --$ac_var: $ac_val" >&2
+ as_fn_error $? "expected an absolute directory name for --$ac_var: $ac_val"
done
# There might be people who depend on the old broken behavior: `$host'
@@ -1352,8 +1430,6 @@
if test "x$host_alias" != x; then
if test "x$build_alias" = x; then
cross_compiling=maybe
- echo "$as_me: WARNING: If you wanted to set the --build type, don't use --host.
- If a cross compiler is detected then cross compile mode will be used." >&2
elif test "x$build_alias" != "x$host_alias"; then
cross_compiling=yes
fi
@@ -1368,23 +1444,21 @@
ac_pwd=`pwd` && test -n "$ac_pwd" &&
ac_ls_di=`ls -di .` &&
ac_pwd_ls_di=`cd "$ac_pwd" && ls -di .` ||
- { echo "$as_me: error: Working directory cannot be determined" >&2
+ as_fn_error $? "working directory cannot be determined"
test "X$ac_ls_di" = "X$ac_pwd_ls_di" ||
- { echo "$as_me: error: pwd does not report name of working directory" >&2
+ as_fn_error $? "pwd does not report name of working directory"
# Find the source files, if location was not specified.
if test -z "$srcdir"; then
ac_srcdir_defaulted=yes
# Try the directory containing this script, then the parent directory.
- ac_confdir=`$as_dirname -- "$0" ||
-$as_expr X"$0" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$0" : 'X\(//\)[^/]' \| \
-echo X"$0" |
+ ac_confdir=`$as_dirname -- "$as_myself" ||
+$as_expr X"$as_myself" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
+ X"$as_myself" : 'X\(//\)[^/]' \| \
+ X"$as_myself" : 'X\(//\)$' \| \
+ X"$as_myself" : 'X\(/\)' \| . 2>/dev/null ||
+$as_echo X"$as_myself" |
s//\1/
q
@@ -1411,13 +1485,11 @@
fi
if test ! -r "$srcdir/$ac_unique_file"; then
test "$ac_srcdir_defaulted" = yes && srcdir="$ac_confdir or .."
- { echo "$as_me: error: cannot find sources ($ac_unique_file) in $srcdir" >&2
+ as_fn_error $? "cannot find sources ($ac_unique_file) in $srcdir"
fi
ac_msg="sources are in $srcdir, but \`cd $srcdir' does not work"
ac_abs_confdir=`(
- cd "$srcdir" && test -r "./$ac_unique_file" || { echo "$as_me: error: $ac_msg" >&2
+ cd "$srcdir" && test -r "./$ac_unique_file" || as_fn_error $? "$ac_msg"
pwd)`
# When building in place, set srcdir=.
if test "$ac_abs_confdir" = "$ac_pwd"; then
@@ -1457,7 +1529,7 @@
--help=short display options specific to this package
--help=recursive display the short help of all the included packages
-V, --version display version information and exit
- -q, --quiet, --silent do not print \`checking...' messages
+ -q, --quiet, --silent do not print \`checking ...' messages
--cache-file=FILE cache test results in FILE [disabled]
-C, --config-cache alias for \`--cache-file=config.cache'
-n, --no-create do not create output files
@@ -1465,9 +1537,9 @@
Installation directories:
--prefix=PREFIX install architecture-independent files in PREFIX
- [$ac_default_prefix]
+ [$ac_default_prefix]
--exec-prefix=EPREFIX install architecture-dependent files in EPREFIX
- [PREFIX]
+ [PREFIX]
By default, \`make install' will install all the files in
\`$ac_default_prefix/bin', \`$ac_default_prefix/lib' etc. You can specify
@@ -1477,25 +1549,25 @@
For better control, use the options below.
Fine tuning of the installation directories:
- --bindir=DIR user executables [EPREFIX/bin]
- --sbindir=DIR system admin executables [EPREFIX/sbin]
- --libexecdir=DIR program executables [EPREFIX/libexec]
- --sysconfdir=DIR read-only single-machine data [PREFIX/etc]
- --sharedstatedir=DIR modifiable architecture-independent data [PREFIX/com]
- --localstatedir=DIR modifiable single-machine data [PREFIX/var]
- --libdir=DIR object code libraries [EPREFIX/lib]
- --includedir=DIR C header files [PREFIX/include]
- --oldincludedir=DIR C header files for non-gcc [/usr/include]
- --datarootdir=DIR read-only arch.-independent data root [PREFIX/share]
- --datadir=DIR read-only architecture-independent data [DATAROOTDIR]
- --infodir=DIR info documentation [DATAROOTDIR/info]
- --localedir=DIR locale-dependent data [DATAROOTDIR/locale]
- --mandir=DIR man documentation [DATAROOTDIR/man]
- --docdir=DIR documentation root [DATAROOTDIR/doc/dbxml-2.5.16]
- --htmldir=DIR html documentation [DOCDIR]
- --dvidir=DIR dvi documentation [DOCDIR]
- --pdfdir=DIR pdf documentation [DOCDIR]
- --psdir=DIR ps documentation [DOCDIR]
+ --bindir=DIR user executables [EPREFIX/bin]
+ --sbindir=DIR system admin executables [EPREFIX/sbin]
+ --libexecdir=DIR program executables [EPREFIX/libexec]
+ --sysconfdir=DIR read-only single-machine data [PREFIX/etc]
+ --sharedstatedir=DIR modifiable architecture-independent data [PREFIX/com]
+ --localstatedir=DIR modifiable single-machine data [PREFIX/var]
+ --libdir=DIR object code libraries [EPREFIX/lib]
+ --includedir=DIR C header files [PREFIX/include]
+ --oldincludedir=DIR C header files for non-gcc [/usr/include]
+ --datarootdir=DIR read-only arch.-independent data root [PREFIX/share]
+ --datadir=DIR read-only architecture-independent data [DATAROOTDIR]
+ --infodir=DIR info documentation [DATAROOTDIR/info]
+ --localedir=DIR locale-dependent data [DATAROOTDIR/locale]
+ --mandir=DIR man documentation [DATAROOTDIR/man]
+ --docdir=DIR documentation root [DATAROOTDIR/doc/dbxml-2.5.16]
+ --htmldir=DIR html documentation [DOCDIR]
+ --dvidir=DIR dvi documentation [DOCDIR]
+ --pdfdir=DIR pdf documentation [DOCDIR]
+ --psdir=DIR ps documentation [DOCDIR]
_ACEOF
cat <<\_ACEOF
@@ -1518,6 +1590,7 @@
cat <<\_ACEOF
Optional Features:
+ --disable-option-checking ignore unrecognized --enable/--with options
--disable-FEATURE do not include FEATURE (same as --enable-FEATURE=no)
--enable-FEATURE[=ARG] include FEATURE [ARG=yes]
--enable-debug Build a debugging version.
@@ -1559,7 +1632,7 @@
LDFLAGS linker flags, e.g. -L<lib dir> if you have libraries in a
nonstandard directory <lib dir>
LIBS libraries to pass to the linker, e.g. -l<library>
- CPPFLAGS C/C++/Objective C preprocessor flags, e.g. -I<include dir> if
+ CPPFLAGS (Objective) C/C++ preprocessor flags, e.g. -I<include dir> if
you have headers in a nonstandard directory <include dir>
CXX C++ compiler command
CXXFLAGS C++ compiler flags
@@ -1579,15 +1652,17 @@
if test "$ac_init_help" = "recursive"; then
# If there are subdirs, report their specific --help.
for ac_dir in : $ac_subdirs_all; do test "x$ac_dir" = x: && continue
- test -d "$ac_dir" || continue
+ test -d "$ac_dir" ||
+ { cd "$srcdir" && ac_pwd=`pwd` && srcdir=. && test -d "$ac_dir"; } ||
+ continue
ac_builddir=.
case "$ac_dir" in
.) ac_dir_suffix= ac_top_builddir_sub=. ac_top_build_prefix= ;;
- ac_dir_suffix=/`echo "$ac_dir" | sed 's,^\.[\\/],,'`
+ ac_dir_suffix=/`$as_echo "$ac_dir" | sed 's|^\.[\\/]||'`
# A ".." for each directory in $ac_dir_suffix.
- ac_top_builddir_sub=`echo "$ac_dir_suffix" | sed 's,/[^\\/]*,/..,g;s,/,,'`
+ ac_top_builddir_sub=`$as_echo "$ac_dir_suffix" | sed 's|/[^\\/]*|/..|g;s|/||'`
case $ac_top_builddir_sub in
"") ac_top_builddir_sub=. ac_top_build_prefix= ;;
*) ac_top_build_prefix=$ac_top_builddir_sub/ ;;
@@ -1623,7 +1698,7 @@
echo &&
$SHELL "$ac_srcdir/configure" --help=recursive
else
- echo "$as_me: WARNING: no configuration information is in $ac_dir" >&2
+ $as_echo "$as_me: WARNING: no configuration information is in $ac_dir" >&2
fi || ac_status=$?
cd "$ac_pwd" || { ac_status=$?; break; }
done
@@ -1633,21 +1708,765 @@
if $ac_init_version; then
cat <<\_ACEOF
Berkeley DB XML configure 2.5.16
-generated by GNU Autoconf 2.61
+generated by GNU Autoconf 2.69
-Copyright (C) 1992, 1993, 1994, 1995, 1996, 1998, 1999, 2000, 2001,
-2002, 2003, 2004, 2005, 2006 Free Software Foundation, Inc.
+Copyright (C) 2012 Free Software Foundation, Inc.
_ACEOF
exit
fi
+## Autoconf initialization. ##
+# ac_fn_c_try_compile LINENO
+# Try to compile conftest.$ac_ext, and return whether this succeeded.
+ac_fn_c_try_compile ()
+ as_lineno=${as_lineno-"$1"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
+ rm -f conftest.$ac_objext
+ if { { ac_try="$ac_compile"
+case "(($ac_try" in
+ *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
+ *) ac_try_echo=$ac_try;;
+esac
+eval ac_try_echo="\"\$as_me:${as_lineno-$LINENO}: $ac_try_echo\""
+$as_echo "$ac_try_echo"; } >&5
+ (eval "$ac_compile") 2>conftest.err
+ ac_status=$?
+ if test -s conftest.err; then
+ grep -v '^ *+' conftest.err >conftest.er1
+ cat conftest.er1 >&5
+ mv -f conftest.er1 conftest.err
+ fi
+ $as_echo "$as_me:${as_lineno-$LINENO}: \$? = $ac_status" >&5
+ test $ac_status = 0; } && {
+ test -z "$ac_c_werror_flag" ||
+ test ! -s conftest.err
+ } && test -s conftest.$ac_objext; then :
+ ac_retval=0
+else
+ $as_echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+ ac_retval=1
+fi
+ eval $as_lineno_stack; ${as_lineno_stack:+:} unset as_lineno
+ as_fn_set_status $ac_retval
+} # ac_fn_c_try_compile
+# ac_fn_cxx_try_compile LINENO
+ac_fn_cxx_try_compile ()
+esac
+ ac_status=$?
+ fi
+ test -z "$ac_cxx_werror_flag" ||
+ ac_retval=0
+else
+ ac_retval=1
+fi
+} # ac_fn_cxx_try_compile
+# ac_fn_c_try_link LINENO
+# Try to link conftest.$ac_ext, and return whether this succeeded.
+ac_fn_c_try_link ()
+ rm -f conftest.$ac_objext conftest$ac_exeext
+ if { { ac_try="$ac_link"
+esac
+ (eval "$ac_link") 2>conftest.err
+ ac_status=$?
+ fi
+ } && test -s conftest$ac_exeext && {
+ test "$cross_compiling" = yes ||
+ test -x conftest$ac_exeext
+ }; then :
+ ac_retval=0
+else
+ ac_retval=1
+fi
+ # Delete the IPA/IPO (Inter Procedural Analysis/Optimization) information
+ # created by the PGI compiler (conftest_ipa8_conftest.oo), as it would
+ # interfere with the next link command; also delete a directory that is
+ # left behind by Apple's compiler. We do this before executing the actions.
+ rm -rf conftest.dSYM conftest_ipa8_conftest.oo
+} # ac_fn_c_try_link
+# ac_fn_c_try_cpp LINENO
+# Try to preprocess conftest.$ac_ext, and return whether this succeeded.
+ac_fn_c_try_cpp ()
+ if { { ac_try="$ac_cpp conftest.$ac_ext"
+esac
+ (eval "$ac_cpp conftest.$ac_ext") 2>conftest.err
+ ac_status=$?
+ fi
+ test $ac_status = 0; } > conftest.i && {
+ test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" ||
+ }; then :
+ ac_retval=0
+else
+ ac_retval=1
+fi
+} # ac_fn_c_try_cpp
+# ac_fn_c_check_header_mongrel LINENO HEADER VAR INCLUDES
+# Tests whether HEADER exists, giving a warning if it cannot be compiled using
+# the include files in INCLUDES and setting the cache variable VAR
+# accordingly.
+ac_fn_c_check_header_mongrel ()
+ if eval \${$3+:} false; then :
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking for $2" >&5
+$as_echo_n "checking for $2... " >&6; }
+if eval \${$3+:} false; then :
+ $as_echo_n "(cached) " >&6
+fi
+eval ac_res=\$$3
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_res" >&5
+$as_echo "$ac_res" >&6; }
+else
+ # Is the header compilable?
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking $2 usability" >&5
+$as_echo_n "checking $2 usability... " >&6; }
+cat confdefs.h - <<_ACEOF >conftest.$ac_ext
+/* end confdefs.h. */
+$4
+#include <$2>
+_ACEOF
+if ac_fn_c_try_compile "$LINENO"; then :
+ ac_header_compiler=yes
+else
+ ac_header_compiler=no
+fi
+rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_header_compiler" >&5
+$as_echo "$ac_header_compiler" >&6; }
+# Is the header present?
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking $2 presence" >&5
+$as_echo_n "checking $2 presence... " >&6; }
+#include <$2>
+_ACEOF
+if ac_fn_c_try_cpp "$LINENO"; then :
+ ac_header_preproc=yes
+else
+ ac_header_preproc=no
+fi
+rm -f conftest.err conftest.i conftest.$ac_ext
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_header_preproc" >&5
+$as_echo "$ac_header_preproc" >&6; }
+# So? What about this header?
+case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in #((
+ yes:no: )
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: accepted by the compiler, rejected by the preprocessor!" >&5
+$as_echo "$as_me: WARNING: $2: accepted by the compiler, rejected by the preprocessor!" >&2;}
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: proceeding with the compiler's result" >&5
+$as_echo "$as_me: WARNING: $2: proceeding with the compiler's result" >&2;}
+ no:yes:* )
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: present but cannot be compiled" >&5
+$as_echo "$as_me: WARNING: $2: present but cannot be compiled" >&2;}
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: check for missing prerequisite headers?" >&5
+$as_echo "$as_me: WARNING: $2: check for missing prerequisite headers?" >&2;}
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: see the Autoconf documentation" >&5
+$as_echo "$as_me: WARNING: $2: see the Autoconf documentation" >&2;}
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: section \"Present But Cannot Be Compiled\"" >&5
+$as_echo "$as_me: WARNING: $2: section \"Present But Cannot Be Compiled\"" >&2;}
+( $as_echo "## -------------------------------------------------------------- ##
+## Report this to Oracle Technology Network Berkeley DB XML forum ##
+ ) | sed "s/^/$as_me: WARNING: /" >&2
+esac
+else
+ eval "$3=\$ac_header_compiler"
+fi
+eval ac_res=\$$3
+fi
+} # ac_fn_c_check_header_mongrel
+# ac_fn_c_try_run LINENO
+# Try to link conftest.$ac_ext, and return whether this succeeded. Assumes
+# that executables *can* be run.
+ac_fn_c_try_run ()
+esac
+ (eval "$ac_link") 2>&5
+ ac_status=$?
+ test $ac_status = 0; } && { ac_try='./conftest$ac_exeext'
+ { { case "(($ac_try" in
+esac
+ (eval "$ac_try") 2>&5
+ ac_status=$?
+ test $ac_status = 0; }; }; then :
+ ac_retval=0
+else
+ $as_echo "$as_me: program exited with status $ac_status" >&5
+ ac_retval=$ac_status
+fi
+} # ac_fn_c_try_run
+# ac_fn_c_check_header_compile LINENO HEADER VAR INCLUDES
+# Tests whether HEADER exists and can be compiled using the include files in
+# INCLUDES, setting the cache variable VAR accordingly.
+ac_fn_c_check_header_compile ()
+else
+ cat confdefs.h - <<_ACEOF >conftest.$ac_ext
+$4
+#include <$2>
+_ACEOF
+ eval "$3=yes"
+else
+ eval "$3=no"
+fi
+fi
+eval ac_res=\$$3
+} # ac_fn_c_check_header_compile
+# ac_fn_c_check_func LINENO FUNC VAR
+# Tests whether FUNC exists, setting the cache variable VAR accordingly
+ac_fn_c_check_func ()
+else
+/* Define $2 to an innocuous variant, in case <limits.h> declares $2.
+ For example, HP-UX 11i <limits.h> declares gettimeofday. */
+#define $2 innocuous_$2
+/* System header to define __stub macros and hopefully few prototypes,
+ which can conflict with char $2 (); below.
+ Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
+ <limits.h> exists even on freestanding compilers. */
+#ifdef __STDC__
+# include <limits.h>
+#else
+# include <assert.h>
+#endif
+#undef $2
+/* Override any GCC internal prototype to avoid an error.
+ Use char because int might match the return type of a GCC
+ builtin and then its argument prototype would still apply. */
+#ifdef __cplusplus
+extern "C"
+#endif
+char $2 ();
+/* The GNU C library defines this for functions which it implements
+ to always fail with ENOSYS. Some functions are actually named
+ something starting with __ and the normal name is an alias. */
+#if defined __stub_$2 || defined __stub___$2
+choke me
+#endif
+int
+main ()
+return $2 ();
+ return 0;
+_ACEOF
+if ac_fn_c_try_link "$LINENO"; then :
+ eval "$3=yes"
+else
+ eval "$3=no"
+fi
+rm -f core conftest.err conftest.$ac_objext \
+ conftest$ac_exeext conftest.$ac_ext
+fi
+eval ac_res=\$$3
+} # ac_fn_c_check_func
+# ac_fn_cxx_try_cpp LINENO
+ac_fn_cxx_try_cpp ()
+esac
+ ac_status=$?
+ fi
+ test -z "$ac_cxx_preproc_warn_flag$ac_cxx_werror_flag" ||
+ }; then :
+ ac_retval=0
+else
+ ac_retval=1
+fi
+} # ac_fn_cxx_try_cpp
+# ac_fn_cxx_try_link LINENO
+ac_fn_cxx_try_link ()
+esac
+ ac_status=$?
+ fi
+ }; then :
+ ac_retval=0
+else
+ ac_retval=1
+fi
+} # ac_fn_cxx_try_link
+# ac_fn_f77_try_compile LINENO
+ac_fn_f77_try_compile ()
+esac
+ ac_status=$?
+ fi
+ test -z "$ac_f77_werror_flag" ||
+ ac_retval=0
+else
+ ac_retval=1
+fi
+} # ac_fn_f77_try_compile
+# ac_fn_f77_try_link LINENO
+ac_fn_f77_try_link ()
+esac
+ ac_status=$?
+ fi
+ }; then :
+ ac_retval=0
+else
+ ac_retval=1
+fi
+} # ac_fn_f77_try_link
+# ac_fn_c_check_type LINENO TYPE VAR INCLUDES
+# Tests whether TYPE exists after having included INCLUDES, setting cache
+# variable VAR accordingly.
+ac_fn_c_check_type ()
+else
+ eval "$3=no"
+$4
+int
+main ()
+if (sizeof ($2))
+ return 0;
+ return 0;
+_ACEOF
+$4
+int
+main ()
+if (sizeof (($2)))
+ return 0;
+ return 0;
+_ACEOF
+else
+ eval "$3=yes"
+fi
+fi
+fi
+eval ac_res=\$$3
+} # ac_fn_c_check_type
+# ac_fn_c_find_intX_t LINENO BITS VAR
+# Finds a signed integer type with width BITS, setting cache variable VAR
+# accordingly.
+ac_fn_c_find_intX_t ()
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking for int$2_t" >&5
+$as_echo_n "checking for int$2_t... " >&6; }
+else
+ eval "$3=no"
+ # Order is important - never check a type that is potentially smaller
+ # than half of the expected target width.
+ for ac_type in int$2_t 'int' 'long int' \
+ 'long long int' 'short int' 'signed char'; do
+$ac_includes_default
+ enum { N = $2 / 2 - 1 };
+int
+main ()
+static int test_array [1 - 2 * !(0 < ($ac_type) ((((($ac_type) 1 << N) << N) - 1) * 2 + 1))];
+test_array [0] = 0;
+return test_array [0];
+ return 0;
+_ACEOF
+int
+main ()
+static int test_array [1 - 2 * !(($ac_type) ((((($ac_type) 1 << N) << N) - 1) * 2 + 1)
+ < ($ac_type) ((((($ac_type) 1 << N) << N) - 1) * 2 + 2))];
+ return 0;
+_ACEOF
+else
+ case $ac_type in #(
+ int$2_t) :
+ eval "$3=yes" ;; #(
+ eval "$3=\$ac_type" ;;
+esac
+fi
+fi
+ if eval test \"x\$"$3"\" = x"no"; then :
+else
+ break
+fi
+ done
+fi
+eval ac_res=\$$3
+} # ac_fn_c_find_intX_t
+# ac_fn_c_find_uintX_t LINENO BITS VAR
+# Finds an unsigned integer type with width BITS, setting cache variable VAR
+# accordingly.
+ac_fn_c_find_uintX_t ()
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking for uint$2_t" >&5
+$as_echo_n "checking for uint$2_t... " >&6; }
+else
+ eval "$3=no"
+ for ac_type in uint$2_t 'unsigned int' 'unsigned long int' \
+ 'unsigned long long int' 'unsigned short int' 'unsigned char'; do
+int
+main ()
+static int test_array [1 - 2 * !((($ac_type) -1 >> ($2 / 2 - 1)) >> ($2 / 2 - 1) == 3)];
+ return 0;
+_ACEOF
+ uint$2_t) :
+esac
+fi
+else
+ break
+fi
+ done
+fi
+eval ac_res=\$$3
+} # ac_fn_c_find_uintX_t
cat >config.log <<_ACEOF
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by Berkeley DB XML $as_me 2.5.16, which was
-generated by GNU Autoconf 2.61. Invocation command line was
+generated by GNU Autoconf 2.69. Invocation command line was
$ $0 $@
@@ -1683,8 +2502,8 @@
do
IFS=$as_save_IFS
- echo "PATH: $as_dir"
-done
+ $as_echo "PATH: $as_dir"
+ done
IFS=$as_save_IFS
} >&5
@@ -1718,12 +2537,12 @@
| -silent | --silent | --silen | --sile | --sil)
continue ;;
- ac_arg=`echo "$ac_arg" | sed "s/'/'\\\\\\\\''/g"` ;;
+ ac_arg=`$as_echo "$ac_arg" | sed "s/'/'\\\\\\\\''/g"` ;;
esac
case $ac_pass in
- 1) ac_configure_args0="$ac_configure_args0 '$ac_arg'" ;;
+ 1) as_fn_append ac_configure_args0 " '$ac_arg'" ;;
2)
- ac_configure_args1="$ac_configure_args1 '$ac_arg'"
+ as_fn_append ac_configure_args1 " '$ac_arg'"
if test $ac_must_keep_next = true; then
ac_must_keep_next=false # Got value, back to normal.
else
@@ -1739,13 +2558,13 @@
-* ) ac_must_keep_next=true ;;
esac
fi
- ac_configure_args="$ac_configure_args '$ac_arg'"
+ as_fn_append ac_configure_args " '$ac_arg'"
esac
done
done
-$as_unset ac_configure_args0 || test "${ac_configure_args0+set}" != set || { ac_configure_args0=; export ac_configure_args0; }
-$as_unset ac_configure_args1 || test "${ac_configure_args1+set}" != set || { ac_configure_args1=; export ac_configure_args1; }
+{ ac_configure_args0=; unset ac_configure_args0;}
+{ ac_configure_args1=; unset ac_configure_args1;}
# When interrupted or exit'd, cleanup temporary files, and complete
# config.log. We remove comments because anyway the quotes in there
@@ -1757,11 +2576,9 @@
echo
- cat <<\_ASBOX
+ $as_echo "## ---------------- ##
## Cache variables. ##
-_ASBOX
echo
# The following way of writing the cache mishandles newlines in values,
@@ -1770,12 +2587,13 @@
case $ac_val in #(
*${as_nl}*)
case $ac_var in #(
- *_cv_*) { echo "$as_me:$LINENO: WARNING: Cache variable $ac_var contains a newline." >&5
-echo "$as_me: WARNING: Cache variable $ac_var contains a newline." >&2;} ;;
+ *_cv_*) { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: cache variable $ac_var contains a newline" >&5
+$as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
esac
case $ac_var in #(
_ | IFS | as_nl) ;; #(
- *) $as_unset $ac_var ;;
+ BASH_ARGV | BASH_SOURCE) eval $ac_var= ;; #(
+ *) { eval $ac_var=; unset $ac_var;} ;;
esac ;;
esac
done
@@ -1794,128 +2612,136 @@
echo
- cat <<\_ASBOX
+ $as_echo "## ----------------- ##
## Output variables. ##
-_ASBOX
echo
for ac_var in $ac_subst_vars
do
case $ac_val in
- *\'\''*) ac_val=`echo "$ac_val" | sed "s/'\''/'\''\\\\\\\\'\'''\''/g"`;;
+ *\'\''*) ac_val=`$as_echo "$ac_val" | sed "s/'\''/'\''\\\\\\\\'\'''\''/g"`;;
esac
- echo "$ac_var='\''$ac_val'\''"
+ $as_echo "$ac_var='\''$ac_val'\''"
done | sort
echo
if test -n "$ac_subst_files"; then
- cat <<\_ASBOX
+ $as_echo "## ------------------- ##
## File substitutions. ##
-_ASBOX
echo
for ac_var in $ac_subst_files
do
case $ac_val in
esac
done | sort
echo
fi
if test -s confdefs.h; then
- cat <<\_ASBOX
+ $as_echo "## ----------- ##
## confdefs.h. ##
-_ASBOX
echo
cat confdefs.h
echo
fi
test "$ac_signal" != 0 &&
- echo "$as_me: caught signal $ac_signal"
- echo "$as_me: exit $exit_status"
+ $as_echo "$as_me: caught signal $ac_signal"
+ $as_echo "$as_me: exit $exit_status"
} >&5
rm -f core *.core core.conftest.* &&
rm -f -r conftest* confdefs* conf$$* $ac_clean_files &&
exit $exit_status
' 0
for ac_signal in 1 2 13 15; do
- trap 'ac_signal='$ac_signal'; { (exit 1); exit 1; }' $ac_signal
+ trap 'ac_signal='$ac_signal'; as_fn_exit 1' $ac_signal
done
ac_signal=0
# confdefs.h avoids OS command line length limits that DEFS can exceed.
rm -f -r conftest* confdefs.h
+$as_echo "/* confdefs.h */" > confdefs.h
# Predefined preprocessor variables.
cat >>confdefs.h <<_ACEOF
#define PACKAGE_NAME "$PACKAGE_NAME"
_ACEOF
#define PACKAGE_TARNAME "$PACKAGE_TARNAME"
_ACEOF
#define PACKAGE_VERSION "$PACKAGE_VERSION"
_ACEOF
#define PACKAGE_STRING "$PACKAGE_STRING"
_ACEOF
#define PACKAGE_BUGREPORT "$PACKAGE_BUGREPORT"
_ACEOF
+cat >>confdefs.h <<_ACEOF
+#define PACKAGE_URL "$PACKAGE_URL"
+_ACEOF
# Let the site file select an alternate cache file if it wants to.
-# Prefer explicitly selected file to automatically selected ones.
+# Prefer an explicitly selected file to automatically selected ones.
+ac_site_file1=NONE
+ac_site_file2=NONE
if test -n "$CONFIG_SITE"; then
- set x "$CONFIG_SITE"
+ # We do not want a PATH search for config.site.
+ case $CONFIG_SITE in #((
+ -*) ac_site_file1=./$CONFIG_SITE;;
+ */*) ac_site_file1=$CONFIG_SITE;;
+ *) ac_site_file1=./$CONFIG_SITE;;
+ esac
elif test "x$prefix" != xNONE; then
- set x "$prefix/share/config.site" "$prefix/etc/config.site"
+ ac_site_file1=$prefix/share/config.site
+ ac_site_file2=$prefix/etc/config.site
else
- set x "$ac_default_prefix/share/config.site" \
- "$ac_default_prefix/etc/config.site"
+ ac_site_file1=$ac_default_prefix/share/config.site
+ ac_site_file2=$ac_default_prefix/etc/config.site
fi
-shift
-for ac_site_file
+for ac_site_file in "$ac_site_file1" "$ac_site_file2"
do
- if test -r "$ac_site_file"; then
- { echo "$as_me:$LINENO: loading site script $ac_site_file" >&5
-echo "$as_me: loading site script $ac_site_file" >&6;}
+ test "x$ac_site_file" = xNONE && continue
+ if test /dev/null != "$ac_site_file" && test -r "$ac_site_file"; then
+ { $as_echo "$as_me:${as_lineno-$LINENO}: loading site script $ac_site_file" >&5
+$as_echo "$as_me: loading site script $ac_site_file" >&6;}
sed 's/^/| /' "$ac_site_file" >&5
- . "$ac_site_file"
+ . "$ac_site_file" \
+ || { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
+$as_echo "$as_me: error: in \`$ac_pwd':" >&2;}
+as_fn_error $? "failed to load site script $ac_site_file
+See \`config.log' for more details" "$LINENO" 5; }
fi
done
if test -r "$cache_file"; then
- # Some versions of bash will fail to source /dev/null (special
- # files actually), so we avoid doing that.
- if test -f "$cache_file"; then
- { echo "$as_me:$LINENO: loading cache $cache_file" >&5
-echo "$as_me: loading cache $cache_file" >&6;}
+ # Some versions of bash will fail to source /dev/null (special files
+ # actually), so we avoid doing that. DJGPP emulates it as a regular file.
+ if test /dev/null != "$cache_file" && test -f "$cache_file"; then
+ { $as_echo "$as_me:${as_lineno-$LINENO}: loading cache $cache_file" >&5
+$as_echo "$as_me: loading cache $cache_file" >&6;}
case $cache_file in
[\\/]* | ?:[\\/]* ) . "$cache_file";;
*) . "./$cache_file";;
esac
fi
else
- { echo "$as_me:$LINENO: creating cache $cache_file" >&5
-echo "$as_me: creating cache $cache_file" >&6;}
+ { $as_echo "$as_me:${as_lineno-$LINENO}: creating cache $cache_file" >&5
+$as_echo "$as_me: creating cache $cache_file" >&6;}
>$cache_file
fi
@@ -1929,69 +2755,57 @@
eval ac_new_val=\$ac_env_${ac_var}_value
case $ac_old_set,$ac_new_set in
set,)
- { echo "$as_me:$LINENO: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&5
-echo "$as_me: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&2;}
+ { $as_echo "$as_me:${as_lineno-$LINENO}: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&5
+$as_echo "$as_me: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&2;}
ac_cache_corrupted=: ;;
,set)
- { echo "$as_me:$LINENO: error: \`$ac_var' was not set in the previous run" >&5
-echo "$as_me: error: \`$ac_var' was not set in the previous run" >&2;}
+ { $as_echo "$as_me:${as_lineno-$LINENO}: error: \`$ac_var' was not set in the previous run" >&5
+$as_echo "$as_me: error: \`$ac_var' was not set in the previous run" >&2;}
if test "x$ac_old_val" != "x$ac_new_val"; then
- { echo "$as_me:$LINENO: error: \`$ac_var' has changed since the previous run:" >&5
-echo "$as_me: error: \`$ac_var' has changed since the previous run:" >&2;}
- { echo "$as_me:$LINENO: former value: $ac_old_val" >&5
-echo "$as_me: former value: $ac_old_val" >&2;}
- { echo "$as_me:$LINENO: current value: $ac_new_val" >&5
-echo "$as_me: current value: $ac_new_val" >&2;}
- ac_cache_corrupted=:
+ # differences in whitespace do not lead to failure.
+ ac_old_val_w=`echo x $ac_old_val`
+ ac_new_val_w=`echo x $ac_new_val`
+ if test "$ac_old_val_w" != "$ac_new_val_w"; then
+ { $as_echo "$as_me:${as_lineno-$LINENO}: error: \`$ac_var' has changed since the previous run:" >&5
+$as_echo "$as_me: error: \`$ac_var' has changed since the previous run:" >&2;}
+ ac_cache_corrupted=:
+ else
+ { $as_echo "$as_me:${as_lineno-$LINENO}: warning: ignoring whitespace changes in \`$ac_var' since the previous run:" >&5
+$as_echo "$as_me: warning: ignoring whitespace changes in \`$ac_var' since the previous run:" >&2;}
+ eval $ac_var=\$ac_old_val
+ fi
+ { $as_echo "$as_me:${as_lineno-$LINENO}: former value: \`$ac_old_val'" >&5
+$as_echo "$as_me: former value: \`$ac_old_val'" >&2;}
+ { $as_echo "$as_me:${as_lineno-$LINENO}: current value: \`$ac_new_val'" >&5
+$as_echo "$as_me: current value: \`$ac_new_val'" >&2;}
fi;;
esac
# Pass precious variables to config.status.
if test "$ac_new_set" = set; then
case $ac_new_val in
- *\'*) ac_arg=$ac_var=`echo "$ac_new_val" | sed "s/'/'\\\\\\\\''/g"` ;;
+ *\'*) ac_arg=$ac_var=`$as_echo "$ac_new_val" | sed "s/'/'\\\\\\\\''/g"` ;;
*) ac_arg=$ac_var=$ac_new_val ;;
esac
case " $ac_configure_args " in
*" '$ac_arg' "*) ;; # Avoid dups. Use of quotes ensures accuracy.
- *) ac_configure_args="$ac_configure_args '$ac_arg'" ;;
+ *) as_fn_append ac_configure_args " '$ac_arg'" ;;
esac
fi
done
if $ac_cache_corrupted; then
- { echo "$as_me:$LINENO: error: changes in the environment can compromise the build" >&5
-echo "$as_me: error: changes in the environment can compromise the build" >&2;}
- { { echo "$as_me:$LINENO: error: run \`make distclean' and/or \`rm $cache_file' and start over" >&5
-echo "$as_me: error: run \`make distclean' and/or \`rm $cache_file' and start over" >&2;}
+ { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: error: changes in the environment can compromise the build" >&5
+$as_echo "$as_me: error: changes in the environment can compromise the build" >&2;}
+ as_fn_error $? "run \`make distclean' and/or \`rm $cache_file' and start over" "$LINENO" 5
fi
+## Main body of script. ##
ac_ext=c
ac_cpp='$CPP $CPPFLAGS'
ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
@@ -2016,9 +2830,7 @@
fi
done
if test -z "$ac_aux_dir"; then
- { { echo "$as_me:$LINENO: error: cannot find install-sh or install.sh in dist \"$srcdir\"/dist" >&5
-echo "$as_me: error: cannot find install-sh or install.sh in dist \"$srcdir\"/dist" >&2;}
+ as_fn_error $? "cannot find install-sh, install.sh, or shtool in dist \"$srcdir\"/dist" "$LINENO" 5
fi
# These three variables are undocumented and unsupported,
@@ -2045,22 +2857,23 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# OS/2's system install, which has a completely different semantic
# ./install, which can be erroneously created by make from ./install.sh.
-{ echo "$as_me:$LINENO: checking for a BSD-compatible install" >&5
-echo $ECHO_N "checking for a BSD-compatible install... $ECHO_C" >&6; }
+# Reject install programs that cannot install multiple files.
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for a BSD-compatible install" >&5
+$as_echo_n "checking for a BSD-compatible install... " >&6; }
if test -z "$INSTALL"; then
-if test "${ac_cv_path_install+set}" = set; then
- echo $ECHO_N "(cached) $ECHO_C" >&6
+if ${ac_cv_path_install+:} false; then :
else
for as_dir in $PATH
do
IFS=$as_save_IFS
- # Account for people who put trailing slashes in PATH elements.
-case $as_dir/ in
- ./ | .// | /cC/* | \
+ # Account for people who put trailing slashes in PATH elements.
+case $as_dir/ in #((
+ ./ | .// | /[cC]/* | \
/etc/* | /usr/sbin/* | /usr/etc/* | /sbin/* | /usr/afsws/bin/* | \
- ?:\\/os2\\/install\\/* | ?:\\/OS2\\/INSTALL\\/* | \
+ ?:[\\/]os2[\\/]install[\\/]* | ?:[\\/]OS2[\\/]INSTALL[\\/]* | \
/usr/ucb/* ) ;;
# OSF1 and SCO ODT 3.0 have their own names for install.
@@ -2068,7 +2881,7 @@
# by default.
for ac_prog in ginstall scoinst install; do
for ac_exec_ext in '' $ac_executable_extensions; do
- if { test -f "$as_dir/$ac_prog$ac_exec_ext" && $as_test_x "$as_dir/$ac_prog$ac_exec_ext"; }; then
+ if as_fn_executable_p "$as_dir/$ac_prog$ac_exec_ext"; then
if test $ac_prog = install &&
grep dspmsg "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
# AIX install. It has an incompatible calling convention.
@@ -2078,17 +2891,29 @@
# program-specific install script used by HP pwplus--don't use.
else
- ac_cv_path_install="$as_dir/$ac_prog$ac_exec_ext -c"
- break 3
+ rm -rf conftest.one conftest.two conftest.dir
+ echo one > conftest.one
+ echo two > conftest.two
+ mkdir conftest.dir
+ if "$as_dir/$ac_prog$ac_exec_ext" -c conftest.one conftest.two "`pwd`/conftest.dir" &&
+ test -s conftest.one && test -s conftest.two &&
+ test -s conftest.dir/conftest.one &&
+ test -s conftest.dir/conftest.two
+ then
+ ac_cv_path_install="$as_dir/$ac_prog$ac_exec_ext -c"
+ break 3
+ fi
fi
fi
done
done
esac
-done
+ done
IFS=$as_save_IFS
+rm -rf conftest.one conftest.two conftest.dir
fi
@@ -2101,8 +2926,8 @@
INSTALL=$ac_install_sh
fi
fi
-{ echo "$as_me:$LINENO: result: $INSTALL" >&5
-echo "${ECHO_T}$INSTALL" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $INSTALL" >&5
+$as_echo "$INSTALL" >&6; }
# Use test -z because SunOS4 sh mishandles braces in ${var-val}.
# It thinks the first close brace ends the variable substitution.
@@ -2112,8 +2937,8 @@
test -z "$INSTALL_DATA" && INSTALL_DATA='${INSTALL} -m 644'
-{ echo "$as_me:$LINENO: checking whether build environment is sane" >&5
-echo $ECHO_N "checking whether build environment is sane... $ECHO_C" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether build environment is sane" >&5
+$as_echo_n "checking whether build environment is sane... " >&6; }
# Just in case
sleep 1
echo timestamp > conftest.file
@@ -2136,11 +2961,8 @@
# if, for instance, CONFIG_SHELL is bash and it inherits a
# broken ls alias from the environment. This has actually
# happened. Such a system could not be considered "sane".
- { { echo "$as_me:$LINENO: error: ls -t appears to fail. Make sure there is not a broken
-alias in your environment" >&5
-echo "$as_me: error: ls -t appears to fail. Make sure there is not a broken
-alias in your environment" >&2;}
+ as_fn_error $? "ls -t appears to fail. Make sure there is not a broken
+alias in your environment" "$LINENO" 5
fi
test "$2" = conftest.file
@@ -2149,26 +2971,20 @@
# Ok.
else
- { { echo "$as_me:$LINENO: error: newly created file is older than distributed files!
-Check your system clock" >&5
-echo "$as_me: error: newly created file is older than distributed files!
-Check your system clock" >&2;}
+ as_fn_error $? "newly created file is older than distributed files!
+Check your system clock" "$LINENO" 5
fi
-{ echo "$as_me:$LINENO: result: yes" >&5
-echo "${ECHO_T}yes" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
+$as_echo "yes" >&6; }
test "$program_prefix" != NONE &&
program_transform_name="s&^&$program_prefix&;$program_transform_name"
# Use a double $ so make ignores it.
test "$program_suffix" != NONE &&
program_transform_name="s&\$&$program_suffix&;$program_transform_name"
-# Double any \ or $. echo might interpret backslashes.
+# Double any \ or $.
# By default was `s,x,x', remove it if useless.
-cat <<\_ACEOF >conftest.sed
-s/[\\$]/&&/g;s/;s,x,x,$//
-_ACEOF
-program_transform_name=`echo $program_transform_name | sed -f conftest.sed`
-rm -f conftest.sed
+ac_script='s/[\\$]/&&/g;s/;s,x,x,$//'
+program_transform_name=`$as_echo "$program_transform_name" | sed "$ac_script"`
# expand $ac_aux_dir to an absolute path
am_aux_dir=`cd $ac_aux_dir && pwd`
@@ -2179,24 +2995,24 @@
am_missing_run="$MISSING --run "
else
am_missing_run=
- { echo "$as_me:$LINENO: WARNING: \`missing' script is too old or missing" >&5
-echo "$as_me: WARNING: \`missing' script is too old or missing" >&2;}
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: \`missing' script is too old or missing" >&5
+$as_echo "$as_me: WARNING: \`missing' script is too old or missing" >&2;}
fi
-{ echo "$as_me:$LINENO: checking for a thread-safe mkdir -p" >&5
-echo $ECHO_N "checking for a thread-safe mkdir -p... $ECHO_C" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for a thread-safe mkdir -p" >&5
+$as_echo_n "checking for a thread-safe mkdir -p... " >&6; }
if test -z "$MKDIR_P"; then
- if test "${ac_cv_path_mkdir+set}" = set; then
+ if ${ac_cv_path_mkdir+:} false; then :
else
for as_dir in $PATH$PATH_SEPARATOR/opt/sfw/bin
do
IFS=$as_save_IFS
test -z "$as_dir" && as_dir=.
- for ac_prog in mkdir gmkdir; do
+ for ac_prog in mkdir gmkdir; do
- { test -f "$as_dir/$ac_prog$ac_exec_ext" && $as_test_x "$as_dir/$ac_prog$ac_exec_ext"; } || continue
+ as_fn_executable_p "$as_dir/$ac_prog$ac_exec_ext" || continue
case `"$as_dir/$ac_prog$ac_exec_ext" --version 2>&1` in #(
'mkdir (GNU coreutils) '* | \
'mkdir (coreutils) '* | \
@@ -2206,11 +3022,12 @@
esac
done
done
-done
+ done
IFS=$as_save_IFS
fi
+ test -d ./--version && rmdir ./--version
MKDIR_P="$ac_cv_path_mkdir -p"
else
@@ -2218,12 +3035,11 @@
# value for MKDIR_P within a source directory, because that will
# break other packages using the cache if that directory is
# removed, or if the value is a relative name.
- test -d ./--version && rmdir ./--version
MKDIR_P="$ac_install_sh -d"
fi
fi
-{ echo "$as_me:$LINENO: result: $MKDIR_P" >&5
-echo "${ECHO_T}$MKDIR_P" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $MKDIR_P" >&5
+$as_echo "$MKDIR_P" >&6; }
mkdir_p="$MKDIR_P"
case $mkdir_p in
@@ -2235,10 +3051,10 @@
do
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-{ echo "$as_me:$LINENO: checking for $ac_word" >&5
-echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6; }
-if test "${ac_cv_prog_AWK+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $ac_word" >&5
+$as_echo_n "checking for $ac_word... " >&6; }
+if ${ac_cv_prog_AWK+:} false; then :
else
if test -n "$AWK"; then
ac_cv_prog_AWK="$AWK" # Let the user override the test.
@@ -2248,43 +3064,44 @@
do
IFS=$as_save_IFS
- for ac_exec_ext in '' $ac_executable_extensions; do
- if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then
+ for ac_exec_ext in '' $ac_executable_extensions; do
+ if as_fn_executable_p "$as_dir/$ac_word$ac_exec_ext"; then
ac_cv_prog_AWK="$ac_prog"
- echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5
+ $as_echo "$as_me:${as_lineno-$LINENO}: found $as_dir/$ac_word$ac_exec_ext" >&5
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
AWK=$ac_cv_prog_AWK
- { echo "$as_me:$LINENO: result: $AWK" >&5
-echo "${ECHO_T}$AWK" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $AWK" >&5
+$as_echo "$AWK" >&6; }
else
- { echo "$as_me:$LINENO: result: no" >&5
-echo "${ECHO_T}no" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
+$as_echo "no" >&6; }
fi
test -n "$AWK" && break
done
-{ echo "$as_me:$LINENO: checking whether ${MAKE-make} sets \$(MAKE)" >&5
-echo $ECHO_N "checking whether ${MAKE-make} sets \$(MAKE)... $ECHO_C" >&6; }
-set x ${MAKE-make}; ac_make=`echo "$2" | sed 's/+/p/g; s/[^a-zA-Z0-9_]/_/g'`
-if { as_var=ac_cv_prog_make_${ac_make}_set; eval "test \"\${$as_var+set}\" = set"; }; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether ${MAKE-make} sets \$(MAKE)" >&5
+$as_echo_n "checking whether ${MAKE-make} sets \$(MAKE)... " >&6; }
+set x ${MAKE-make}
+ac_make=`$as_echo "$2" | sed 's/+/p/g; s/[^a-zA-Z0-9_]/_/g'`
+if eval \${ac_cv_prog_make_${ac_make}_set+:} false; then :
else
cat >conftest.make <<\_ACEOF
SHELL = /bin/sh
all:
@echo '@@@%%%=$(MAKE)=@@@%%%'
_ACEOF
-# GNU make sometimes prints "make[1]: Entering...", which would confuse us.
+# GNU make sometimes prints "make[1]: Entering ...", which would confuse us.
case `${MAKE-make} -f conftest.make 2>/dev/null` in
eval ac_cv_prog_make_${ac_make}_set=yes;;
@@ -2294,12 +3111,12 @@
rm -f conftest.make
fi
if eval test \$ac_cv_prog_make_${ac_make}_set = yes; then
- { echo "$as_me:$LINENO: result: yes" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
SET_MAKE=
else
SET_MAKE="MAKE=${MAKE-make}"
fi
@@ -2318,9 +3135,7 @@
am__isrc=' -I$(srcdir)'
# test to see if srcdir already configured
if test -f $srcdir/config.status; then
- { { echo "$as_me:$LINENO: error: source directory already configured; run \"make distclean\" there first" >&5
-echo "$as_me: error: source directory already configured; run \"make distclean\" there first" >&2;}
+ as_fn_error $? "source directory already configured; run \"make distclean\" there first" "$LINENO" 5
fi
fi
@@ -2374,10 +3189,10 @@
if test -n "$ac_tool_prefix"; then
# Extract the first word of "${ac_tool_prefix}strip", so it can be a program name with args.
set dummy ${ac_tool_prefix}strip; ac_word=$2
-if test "${ac_cv_prog_STRIP+set}" = set; then
+if ${ac_cv_prog_STRIP+:} false; then :
else
if test -n "$STRIP"; then
ac_cv_prog_STRIP="$STRIP" # Let the user override the test.
@@ -2387,25 +3202,25 @@
do
IFS=$as_save_IFS
ac_cv_prog_STRIP="${ac_tool_prefix}strip"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
STRIP=$ac_cv_prog_STRIP
- { echo "$as_me:$LINENO: result: $STRIP" >&5
-echo "${ECHO_T}$STRIP" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $STRIP" >&5
+$as_echo "$STRIP" >&6; }
else
fi
@@ -2414,10 +3229,10 @@
ac_ct_STRIP=$STRIP
# Extract the first word of "strip", so it can be a program name with args.
set dummy strip; ac_word=$2
-if test "${ac_cv_prog_ac_ct_STRIP+set}" = set; then
+if ${ac_cv_prog_ac_ct_STRIP+:} false; then :
else
if test -n "$ac_ct_STRIP"; then
ac_cv_prog_ac_ct_STRIP="$ac_ct_STRIP" # Let the user override the test.
@@ -2427,25 +3242,25 @@
do
IFS=$as_save_IFS
ac_cv_prog_ac_ct_STRIP="strip"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
ac_ct_STRIP=$ac_cv_prog_ac_ct_STRIP
- { echo "$as_me:$LINENO: result: $ac_ct_STRIP" >&5
-echo "${ECHO_T}$ac_ct_STRIP" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_STRIP" >&5
+$as_echo "$ac_ct_STRIP" >&6; }
else
fi
if test "x$ac_ct_STRIP" = x; then
@@ -2453,12 +3268,8 @@
else
case $cross_compiling:$ac_tool_warned in
yes:)
-{ echo "$as_me:$LINENO: WARNING: In the future, Autoconf will not detect cross-tools
-whose name does not start with the host triplet. If you think this
-configuration is useful to you, please write to autoconf at gnu.org." >&5
-echo "$as_me: WARNING: In the future, Autoconf will not detect cross-tools
-configuration is useful to you, please write to autoconf at gnu.org." >&2;}
+{ $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: using cross tools not prefixed with host triplet" >&5
+$as_echo "$as_me: WARNING: using cross tools not prefixed with host triplet" >&2;}
ac_tool_warned=yes ;;
esac
STRIP=$ac_ct_STRIP
@@ -2489,35 +3300,27 @@
# Host info
# Make sure we can run config.sub.
$SHELL "$ac_aux_dir/config.sub" sun4 >/dev/null 2>&1 ||
- { { echo "$as_me:$LINENO: error: cannot run $SHELL $ac_aux_dir/config.sub" >&5
-echo "$as_me: error: cannot run $SHELL $ac_aux_dir/config.sub" >&2;}
+ as_fn_error $? "cannot run $SHELL $ac_aux_dir/config.sub" "$LINENO" 5
-{ echo "$as_me:$LINENO: checking build system type" >&5
-echo $ECHO_N "checking build system type... $ECHO_C" >&6; }
-if test "${ac_cv_build+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking build system type" >&5
+$as_echo_n "checking build system type... " >&6; }
+if ${ac_cv_build+:} false; then :
else
ac_build_alias=$build_alias
test "x$ac_build_alias" = x &&
ac_build_alias=`$SHELL "$ac_aux_dir/config.guess"`
- { { echo "$as_me:$LINENO: error: cannot guess build type; you must specify one" >&5
-echo "$as_me: error: cannot guess build type; you must specify one" >&2;}
+ as_fn_error $? "cannot guess build type; you must specify one" "$LINENO" 5
ac_cv_build=`$SHELL "$ac_aux_dir/config.sub" $ac_build_alias` ||
- { { echo "$as_me:$LINENO: error: $SHELL $ac_aux_dir/config.sub $ac_build_alias failed" >&5
-echo "$as_me: error: $SHELL $ac_aux_dir/config.sub $ac_build_alias failed" >&2;}
+ as_fn_error $? "$SHELL $ac_aux_dir/config.sub $ac_build_alias failed" "$LINENO" 5
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_build" >&5
-echo "${ECHO_T}$ac_cv_build" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_build" >&5
+$as_echo "$ac_cv_build" >&6; }
case $ac_cv_build in
-*) { { echo "$as_me:$LINENO: error: invalid value of canonical build" >&5
-echo "$as_me: error: invalid value of canonical build" >&2;}
- { (exit 1); exit 1; }; };;
+*) as_fn_error $? "invalid value of canonical build" "$LINENO" 5;;
esac
build=$ac_cv_build
ac_save_IFS=$IFS; IFS='-'
@@ -2533,28 +3336,24 @@
case $build_os in *\ *) build_os=`echo "$build_os" | sed 's/ /-/g'`;; esac
-{ echo "$as_me:$LINENO: checking host system type" >&5
-echo $ECHO_N "checking host system type... $ECHO_C" >&6; }
-if test "${ac_cv_host+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking host system type" >&5
+$as_echo_n "checking host system type... " >&6; }
+if ${ac_cv_host+:} false; then :
else
if test "x$host_alias" = x; then
ac_cv_host=$ac_cv_build
else
ac_cv_host=`$SHELL "$ac_aux_dir/config.sub" $host_alias` ||
- { { echo "$as_me:$LINENO: error: $SHELL $ac_aux_dir/config.sub $host_alias failed" >&5
-echo "$as_me: error: $SHELL $ac_aux_dir/config.sub $host_alias failed" >&2;}
+ as_fn_error $? "$SHELL $ac_aux_dir/config.sub $host_alias failed" "$LINENO" 5
fi
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_host" >&5
-echo "${ECHO_T}$ac_cv_host" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_host" >&5
+$as_echo "$ac_cv_host" >&6; }
case $ac_cv_host in
-*) { { echo "$as_me:$LINENO: error: invalid value of canonical host" >&5
-echo "$as_me: error: invalid value of canonical host" >&2;}
+*) as_fn_error $? "invalid value of canonical host" "$LINENO" 5;;
esac
host=$ac_cv_host
@@ -2582,64 +3381,64 @@
DBXML_VERSION_PATCH="16"
-DBXML_VERSION_STRING='"Oracle: Berkeley DB XML 2.5.16: (December 22, 2009)"'
+DBXML_VERSION_STRING='"Oracle: Berkeley DB XML 2.5.16: (January 6, 2018)"'
# Process all options before using them.
# Check debug option
-{ echo "$as_me:$LINENO: checking if --enable-debug option specified" >&5
-echo $ECHO_N "checking if --enable-debug option specified... $ECHO_C" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if --enable-debug option specified" >&5
+$as_echo_n "checking if --enable-debug option specified... " >&6; }
# Check whether --enable-debug was given.
-if test "${enable_debug+set}" = set; then
+if test "${enable_debug+set}" = set; then :
enableval=$enable_debug; db_cv_debug="$enable_debug"
else
db_cv_debug="no"
fi
-{ echo "$as_me:$LINENO: result: $db_cv_debug" >&5
-echo "${ECHO_T}$db_cv_debug" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $db_cv_debug" >&5
+$as_echo "$db_cv_debug" >&6; }
# Check if we want to build the tests
-{ echo "$as_me:$LINENO: checking if --enable-test option specified" >&5
-echo $ECHO_N "checking if --enable-test option specified... $ECHO_C" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if --enable-test option specified" >&5
+$as_echo_n "checking if --enable-test option specified... " >&6; }
# Check whether --enable-test was given.
-if test "${enable_test+set}" = set; then
+if test "${enable_test+set}" = set; then :
enableval=$enable_test; db_cv_test="$enable_test"
else
db_cv_test="no"
fi
-{ echo "$as_me:$LINENO: result: $db_cv_test" >&5
-echo "${ECHO_T}$db_cv_test" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $db_cv_test" >&5
+$as_echo "$db_cv_test" >&6; }
# Check for Berkeley DB
-{ echo "$as_me:$LINENO: checking if --with-berkeleydb=DIR option specified" >&5
-echo $ECHO_N "checking if --with-berkeleydb=DIR option specified... $ECHO_C" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if --with-berkeleydb=DIR option specified" >&5
+$as_echo_n "checking if --with-berkeleydb=DIR option specified... " >&6; }
# Check whether --with-berkeleydb was given.
-if test "${with_berkeleydb+set}" = set; then
+if test "${with_berkeleydb+set}" = set; then :
withval=$with_berkeleydb; with_berkeleydb="$withval"
else
with_berkeleydb="no"
fi
-{ echo "$as_me:$LINENO: result: $with_berkeleydb" >&5
-echo "${ECHO_T}$with_berkeleydb" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $with_berkeleydb" >&5
+$as_echo "$with_berkeleydb" >&6; }
# Check for Berkeley DB build directory
-{ echo "$as_me:$LINENO: checking if --with-dbbuild=DIR option specified" >&5
-echo $ECHO_N "checking if --with-dbbuild=DIR option specified... $ECHO_C" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if --with-dbbuild=DIR option specified" >&5
+$as_echo_n "checking if --with-dbbuild=DIR option specified... " >&6; }
# Check whether --with-dbbuild was given.
-if test "${with_dbbuild+set}" = set; then
+if test "${with_dbbuild+set}" = set; then :
withval=$with_dbbuild; with_dbbuild="$withval"
else
with_dbbuild="no"
fi
-{ echo "$as_me:$LINENO: result: $with_dbbuild" >&5
-echo "${ECHO_T}$with_dbbuild" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $with_dbbuild" >&5
+$as_echo "$with_dbbuild" >&6; }
# If --with-berkeleydb isn't specified, assume it's here | wc -l` -gt 0
if test "$with_berkeleydb" = "no"; then
@@ -2657,11 +3456,11 @@
# Check for a DB install tree
if test `ls "$with_berkeleydb"/lib/libdb-*.la 2>/dev/null | wc -l` -gt 0 ; then
- { echo "$as_me:$LINENO: checking for Berkeley DB version from install tree" >&5
-echo $ECHO_N "checking for Berkeley DB version from install tree... $ECHO_C" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking for Berkeley DB version from install tree" >&5
+$as_echo_n "checking for Berkeley DB version from install tree... " >&6; }
db_version=`ls "$with_berkeleydb"/lib/libdb-*.la | sed 's/.*db-\(.*\).la/\1/'`
- { echo "$as_me:$LINENO: result: $db_version" >&5
-echo "${ECHO_T}$db_version" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $db_version" >&5
+$as_echo "$db_version" >&6; }
DB_TCLLIB="<replace_with:_path_to_db_libs_with_tcl>/libdb_tcl-$db_version"
berkeleydb_include="-I$with_berkeleydb/include"
@@ -2672,11 +3471,11 @@
# Check for a built DB source tree
elif test `ls "$with_berkeleydb"/build_unix/libdb-*.la 2>/dev/null | wc -l` -gt 0 ; then
- { echo "$as_me:$LINENO: checking for Berkeley DB version from build tree" >&5
-echo $ECHO_N "checking for Berkeley DB version from build tree... $ECHO_C" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking for Berkeley DB version from build tree" >&5
+$as_echo_n "checking for Berkeley DB version from build tree... " >&6; }
db_version=`ls "$with_berkeleydb"/build_unix/libdb-*.la | sed 's/.*db-\(.*\).la/\1/'`
berkeleydb_include="-I$with_berkeleydb/build_unix -I$with_berkeleydb -I$with_berkeleydb/dbinc"
berkeleydb_lib="$with_berkeleydb/build_unix"
@@ -2690,11 +3489,11 @@
# Alternate check for a built DB source tree
elif test `ls "$with_berkeleydb"/build_unix/libdb-*.a 2>/dev/null | wc -l` -gt 0 ; then
db_version=`ls "$with_berkeleydb"/build_unix/libdb-*.a | sed 's/.*db-\(.*\).a/\1/'`
@@ -2708,11 +3507,11 @@
# Check if path points to the build directory itself for DB
elif test `ls "$with_berkeleydb"/libdb-*.la 2>/dev/null | wc -l` -gt 0 ; then
db_version=`ls "$with_berkeleydb"/libdb-*.la | sed 's/.*db-\(.*\).la/\1/'`
berkeleydb_include="-I$with_berkeleydb -I$with_berkeleydb/.. -I$with_berkeleydb/../dbinc"
berkeleydb_lib="$with_berkeleydb"
@@ -2726,11 +3525,11 @@
# Alternate check if path points to the build directory itself for DB
elif test `ls "$with_berkeleydb"/libdb-*.a 2>/dev/null | wc -l` -gt 0 ; then
db_version=`ls "$with_berkeleydb"/libdb-*.a | sed 's/.*db-\(.*\).a/\1/'`
@@ -2741,15 +3540,11 @@
DB_TEST_PATH="$with_berkeleydb/../test"
DB_UTIL_PATH="$with_berkeleydb"
else
- { { echo "$as_me:$LINENO: error: $with_berkeleydb not a valid Berkeley DB tree. Note that Berkeley DB must be configured and built with '--enable-cxx'." >&5
-echo "$as_me: error: $with_berkeleydb not a valid Berkeley DB tree. Note that Berkeley DB must be configured and built with '--enable-cxx'." >&2;}
+ as_fn_error $? "$with_berkeleydb not a valid Berkeley DB tree. Note that Berkeley DB must be configured and built with '--enable-cxx'." "$LINENO" 5
fi
if test "$db_version" != "4.3" && test "$db_version" != "4.4" && test "$db_version" != "4.5" && test "$db_version" != "4.6" && test "$db_version" != "4.7" && test "$db_version" != "4.8"; then
- { { echo "$as_me:$LINENO: error: $with_berkeleydb is version $db_version, which is not a supported version of Berkeley DB. The version must be at least 4.3" >&5
-echo "$as_me: error: $with_berkeleydb is version $db_version, which is not a supported version of Berkeley DB. The version must be at least 4.3" >&2;}
+ as_fn_error $? "$with_berkeleydb is version $db_version, which is not a supported version of Berkeley DB. The version must be at least 4.3" "$LINENO" 5
fi
if test "$db_cv_test" = "yes"; then
@@ -2772,18 +3567,18 @@
# Check for XQilla
-{ echo "$as_me:$LINENO: checking if --with-xqilla=DIR option specified" >&5
-echo $ECHO_N "checking if --with-xqilla=DIR option specified... $ECHO_C" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if --with-xqilla=DIR option specified" >&5
+$as_echo_n "checking if --with-xqilla=DIR option specified... " >&6; }
# Check whether --with-xqilla was given.
-if test "${with_xqilla+set}" = set; then
+if test "${with_xqilla+set}" = set; then :
withval=$with_xqilla; with_xqilla="$withval"
else
with_xqilla="no"
fi
-{ echo "$as_me:$LINENO: result: $with_xqilla" >&5
-echo "${ECHO_T}$with_xqilla" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $with_xqilla" >&5
+$as_echo "$with_xqilla" >&6; }
if test "$with_xqilla" = "no"; then
with_xqilla="@XQILLA_HOME@"
fi
@@ -2805,9 +3600,7 @@
fi
xqilla_lib="$with_xqilla"
else
- { { echo "$as_me:$LINENO: error: XQilla is required to build DB XML. $with_xqilla is not a valid XQilla tree (maybe it has not been compiled). You should specify the path where XQilla is installed with --with-xqilla." >&5
-echo "$as_me: error: XQilla is required to build DB XML. $with_xqilla is not a valid XQilla tree (maybe it has not been compiled). You should specify the path where XQilla is installed with --with-xqilla." >&2;}
+ as_fn_error $? "XQilla is required to build DB XML. $with_xqilla is not a valid XQilla tree (maybe it has not been compiled). You should specify the path where XQilla is installed with --with-xqilla." "$LINENO" 5
fi
XQILLA_DIR=$with_xqilla
@@ -2815,18 +3608,18 @@
# Check for the Xerces-C library
-{ echo "$as_me:$LINENO: checking if --with-xerces=DIR option specified" >&5
-echo $ECHO_N "checking if --with-xerces=DIR option specified... $ECHO_C" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if --with-xerces=DIR option specified" >&5
+$as_echo_n "checking if --with-xerces=DIR option specified... " >&6; }
# Check whether --with-xerces was given.
-if test "${with_xerces+set}" = set; then
+if test "${with_xerces+set}" = set; then :
withval=$with_xerces; with_xerces="$withval"
else
with_xerces="no"
fi
-{ echo "$as_me:$LINENO: result: $with_xerces" >&5
-echo "${ECHO_T}$with_xerces" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $with_xerces" >&5
+$as_echo "$with_xerces" >&6; }
if test "$with_xerces" = "no"; then
with_xerces="/usr/local"
fi
@@ -2848,19 +3641,17 @@
xerces_source_tree="yes"
else
- { { echo "$as_me:$LINENO: error: Unable to find the Xerces-C include directory." >&5
-echo "$as_me: error: Unable to find the Xerces-C include directory." >&2;}
+ as_fn_error $? "Unable to find the Xerces-C include directory." "$LINENO" 5
fi
# Work out the Xerces-C version
-{ echo "$as_me:$LINENO: checking for Xerces-C version" >&5
-echo $ECHO_N "checking for Xerces-C version... $ECHO_C" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for Xerces-C version" >&5
+$as_echo_n "checking for Xerces-C version... " >&6; }
xerces_version_major=`grep "^\#define XERCES_VERSION_MAJOR" "$xerces_include_dir"/xercesc/util/XercesVersion.hpp | sed -e 's/^\#define XERCES_VERSION_MAJOR \([0-9]*\)/\1/'`
xerces_version_minor=`grep "^\#define XERCES_VERSION_MINOR" "$xerces_include_dir"/xercesc/util/XercesVersion.hpp | sed -e 's/^\#define XERCES_VERSION_MINOR \([0-9]*\)/\1/'`
xerces_version=$xerces_version_major"."$xerces_version_minor
-{ echo "$as_me:$LINENO: result: $xerces_version" >&5
-echo "${ECHO_T}$xerces_version" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $xerces_version" >&5
+$as_echo "$xerces_version" >&6; }
# Find the library
if test `ls $with_xerces/lib/libxerces-c.* 2>/dev/null | wc -l` -gt 0 ; then
@@ -2868,14 +3659,21 @@
elif test `ls $with_xerces/src/libxerces-c.* 2>/dev/null | wc -l` -gt 0 ; then
xerces_lib="$with_xerces/src"
else
- if test "$xerces_source_tree" = "yes" -a "$xerces_version_major" -ge "3"; then
- xerces_lib="$with_xerces/src"
+ # For distros like Ubuntu there are extra places to check for non-source-tree xerces assuming --with-xerces=/usr was given
+ # NOTE: Surely one would've have both 32 and 64 bit versions of this library installed ... right?
+ if test "$xerces_source_tree" = "no" -a `ls $with_xerces/lib/i386-linux-gnu/libxerces-c.* 2>/dev/null | wc -l` -gt 0 ; then
+ xerces_lib="$with_xerces/lib/i386-linux-gnu"
+ elif test "$xerces_source_tree" = "no" -a `ls $with_xerces/lib/x86_64-linux-gnu/libxerces-c.* 2>/dev/null | wc -l` -gt 0 ; then
+ xerces_lib="$with_xerces/lib/x86_64-linux-gnu"
else
- xerces_lib="$with_xerces/lib"
+ if test "$xerces_source_tree" = "yes" -a "$xerces_version_major" -ge "3"; then
+ xerces_lib="$with_xerces/src"
+ else
+ xerces_lib="$with_xerces/lib"
+ fi
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: Unable to find the Xerces-C library. Guessed path is $xerces_lib." >&5
+$as_echo "$as_me: WARNING: Unable to find the Xerces-C library. Guessed path is $xerces_lib." >&2;}
fi
- { echo "$as_me:$LINENO: WARNING: Unable to find the Xerces-C library. Guessed path is $xerces_lib." >&5
-echo "$as_me: WARNING: Unable to find the Xerces-C library. Guessed path is $xerces_lib." >&2;}
fi
XERCES_DIR=$with_xerces
@@ -2885,61 +3683,61 @@
# Check if we want to compile the Java API
-{ echo "$as_me:$LINENO: checking if --enable-java option specified" >&5
-echo $ECHO_N "checking if --enable-java option specified... $ECHO_C" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if --enable-java option specified" >&5
+$as_echo_n "checking if --enable-java option specified... " >&6; }
# Check whether --enable-java was given.
-if test "${enable_java+set}" = set; then
+if test "${enable_java+set}" = set; then :
enableval=$enable_java; db_cv_java="$enable_java"
else
db_cv_java="no"
fi
-{ echo "$as_me:$LINENO: result: $db_cv_java" >&5
-echo "${ECHO_T}$db_cv_java" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $db_cv_java" >&5
+$as_echo "$db_cv_java" >&6; }
# JUnit location
-{ echo "$as_me:$LINENO: checking if --with-junit=JUNIT_JAR option specified" >&5
-echo $ECHO_N "checking if --with-junit=JUNIT_JAR option specified... $ECHO_C" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if --with-junit=JUNIT_JAR option specified" >&5
+$as_echo_n "checking if --with-junit=JUNIT_JAR option specified... " >&6; }
# Check whether --with-junit was given.
-if test "${with_junit+set}" = set; then
+if test "${with_junit+set}" = set; then :
withval=$with_junit; with_junit="$withval"
else
with_junit="no"
fi
-{ echo "$as_me:$LINENO: result: $with_junit" >&5
-echo "${ECHO_T}$with_junit" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $with_junit" >&5
+$as_echo "$with_junit" >&6; }
if test "$with_junit" != "no"; then
JUNIT_JAR=$with_junit
fi
# Check if we want to compile the Tcl API
-{ echo "$as_me:$LINENO: checking if --enable-tcl option specified" >&5
-echo $ECHO_N "checking if --enable-tcl option specified... $ECHO_C" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if --enable-tcl option specified" >&5
+$as_echo_n "checking if --enable-tcl option specified... " >&6; }
# Check whether --enable-tcl was given.
-if test "${enable_tcl+set}" = set; then
+if test "${enable_tcl+set}" = set; then :
enableval=$enable_tcl; db_cv_tcl="$enable_tcl"
else
db_cv_tcl="no"
fi
-{ echo "$as_me:$LINENO: result: $db_cv_tcl" >&5
-echo "${ECHO_T}$db_cv_tcl" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $db_cv_tcl" >&5
+$as_echo "$db_cv_tcl" >&6; }
-{ echo "$as_me:$LINENO: checking if --with-tcl=DIR option specified" >&5
-echo $ECHO_N "checking if --with-tcl=DIR option specified... $ECHO_C" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if --with-tcl=DIR option specified" >&5
+$as_echo_n "checking if --with-tcl=DIR option specified... " >&6; }
# Check whether --with-tcl was given.
-if test "${with_tcl+set}" = set; then
+if test "${with_tcl+set}" = set; then :
withval=$with_tcl; with_tclconfig="$withval"
else
with_tclconfig="no"
fi
-{ echo "$as_me:$LINENO: result: $with_tclconfig" >&5
-echo "${ECHO_T}$with_tclconfig" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $with_tclconfig" >&5
+$as_echo "$with_tclconfig" >&6; }
if test "$with_tclconfig" != "no"; then
db_cv_tcl="yes"
fi
@@ -2953,74 +3751,70 @@
if test "$db_cv_java" != "no"; then
tmp_has_lang="yes"
if test "$with_junit" = "no"; then
- { { echo "$as_me:$LINENO: error: --enable-test plus --enable-java requires --with-junit" >&5
-echo "$as_me: error: --enable-test plus --enable-java requires --with-junit" >&2;}
+ as_fn_error $? "--enable-test plus --enable-java requires --with-junit" "$LINENO" 5
fi
fi
if test "$tmp_has_lang" = "no"; then
- { { echo "$as_me:$LINENO: error: --enable-test requires either --enable-tcl or --enable-java" >&5
-echo "$as_me: error: --enable-test requires either --enable-tcl or --enable-java" >&2;}
+ as_fn_error $? "--enable-test requires either --enable-tcl or --enable-java" "$LINENO" 5
fi
fi
# Check default compression option
-{ echo "$as_me:$LINENO: checking if --enable-compression option specified" >&5
-echo $ECHO_N "checking if --enable-compression option specified... $ECHO_C" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if --enable-compression option specified" >&5
+$as_echo_n "checking if --enable-compression option specified... " >&6; }
# Check whether --enable-compression was given.
-if test "${enable_compression+set}" = set; then
+if test "${enable_compression+set}" = set; then :
enableval=$enable_compression; db_cv_compression="$enable_compression"
else
db_cv_compression="yes"
fi
-{ echo "$as_me:$LINENO: result: $db_cv_compression" >&5
-echo "${ECHO_T}$db_cv_compression" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $db_cv_compression" >&5
+$as_echo "$db_cv_compression" >&6; }
# Check if the ZLIB library is present
if test "$db_cv_compression" != "no"; then
- { echo "$as_me:$LINENO: checking if --with-zlib=DIR option specified" >&5
-echo $ECHO_N "checking if --with-zlib=DIR option specified... $ECHO_C" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking if --with-zlib=DIR option specified" >&5
+$as_echo_n "checking if --with-zlib=DIR option specified... " >&6; }
# Check whether --with-zlib was given.
-if test "${with_zlib+set}" = set; then
+if test "${with_zlib+set}" = set; then :
withval=$with_zlib; with_zlib="$withval"
else
with_zlib="/usr"
fi
- { echo "$as_me:$LINENO: result: $with_zlib" >&5
-echo "${ECHO_T}$with_zlib" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $with_zlib" >&5
+$as_echo "$with_zlib" >&6; }
if test "$with_zlib" != "no"; then
- { echo "$as_me:$LINENO: checking if the ZLIB library is present" >&5
-echo $ECHO_N "checking if the ZLIB library is present... $ECHO_C" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking if the ZLIB library is present" >&5
+$as_echo_n "checking if the ZLIB library is present... " >&6; }
if test `ls $with_zlib/lib/libz.a 2>/dev/null | wc -l` -gt 0 ; then
zlib_lib="-L$with_zlib/lib -R$with_zlib/lib"
zlib_library="-lz"
zlib_include="-I$with_zlib/include"
with_zlib="$with_zlib/lib"
elif test `ls $with_zlib/libz.a 2>/dev/null | wc -l` -gt 0 ; then
if test `ls $with_zlib/include/zlib.h 2>/dev/null | wc -l` -gt 0 ; then
zlib_lib="-L$with_zlib -R$with_zlib"
zlib_library="-lz"
elif test `ls $with_zlib/../include/zlib.h 2>/dev/null | wc -l` -gt 0 ; then
zlib_library="-lz"
zlib_include="-I$with_zlib/../include"
fi
else
- { echo "$as_me:$LINENO: ZLIB not found, disabling default data compression." >&5
-echo "$as_me: ZLIB not found, disabling default data compression." >&6;}
+ { $as_echo "$as_me:${as_lineno-$LINENO}: ZLIB not found, disabling default data compression." >&5
+$as_echo "$as_me: ZLIB not found, disabling default data compression." >&6;}
zlib_lib=""
zlib_library=""
zlib_include=""
@@ -3034,17 +3828,17 @@
#link zlib statically
- { echo "$as_me:$LINENO: checking if --enable-static-zlib option specified" >&5
-echo $ECHO_N "checking if --enable-static-zlib option specified... $ECHO_C" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking if --enable-static-zlib option specified" >&5
+$as_echo_n "checking if --enable-static-zlib option specified... " >&6; }
# Check whether --enable-static_zlib was given.
-if test "${enable_static_zlib+set}" = set; then
+if test "${enable_static_zlib+set}" = set; then :
enableval=$enable_static_zlib; db_cv_zlib_static="yes"
else
db_cv_zlib_static="no"
fi
- { echo "$as_me:$LINENO: result: $db_cv_zlib_static" >&5
-echo "${ECHO_T}$db_cv_zlib_static" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $db_cv_zlib_static" >&5
+$as_echo "$db_cv_zlib_static" >&6; }
if test "$db_cv_zlib_static" != "no"; then
zlib_library="$with_zlib/libz.a"
fi
@@ -3059,17 +3853,17 @@
# Check if rpath is disabled
-{ echo "$as_me:$LINENO: checking if --enable-rpath option specified" >&5
-echo $ECHO_N "checking if --enable-rpath option specified... $ECHO_C" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if --enable-rpath option specified" >&5
+$as_echo_n "checking if --enable-rpath option specified... " >&6; }
# Check whether --enable-rpath was given.
-if test "${enable_rpath+set}" = set; then
+if test "${enable_rpath+set}" = set; then :
enableval=$enable_rpath; db_cv_rpath="$enable_rpath"
else
db_cv_rpath="yes"
fi
-{ echo "$as_me:$LINENO: result: $db_cv_rpath" >&5
-echo "${ECHO_T}$db_cv_rpath" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $db_cv_rpath" >&5
+$as_echo "$db_cv_rpath" >&6; }
BUILD_TCL_TRUE=
@@ -3156,28 +3950,19 @@
esac
if test "$db_cv_debug" = "yes"; then
- cat >>confdefs.h <<\_ACEOF
-#define DEBUG 1
-_ACEOF
+ $as_echo "#define DEBUG 1" >>confdefs.h
+ $as_echo "#define ENABLE_ASSERTS 1" >>confdefs.h
-#define ENABLE_ASSERTS 1
-_ACEOF
optimize_def=$optimize_debug
fi
-cat >>confdefs.h <<\_ACEOF
-#define DBXML_COMPRESSION 1
-_ACEOF
+$as_echo "#define DBXML_COMPRESSION 1" >>confdefs.h
# Set CFLAGS/CXXFLAGS. We MUST set the flags before we call autoconf
# compiler configuration macros, because if we don't, they set CFLAGS
# to no optimization and -g, which isn't what we want.
@@ -3193,10 +3978,10 @@
# Extract the first word of "${ac_tool_prefix}gcc", so it can be a program name with args.
set dummy ${ac_tool_prefix}gcc; ac_word=$2
-if test "${ac_cv_prog_CC+set}" = set; then
+if ${ac_cv_prog_CC+:} false; then :
else
if test -n "$CC"; then
ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -3206,25 +3991,25 @@
do
IFS=$as_save_IFS
ac_cv_prog_CC="${ac_tool_prefix}gcc"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
CC=$ac_cv_prog_CC
- { echo "$as_me:$LINENO: result: $CC" >&5
-echo "${ECHO_T}$CC" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $CC" >&5
+$as_echo "$CC" >&6; }
else
fi
@@ -3233,10 +4018,10 @@
ac_ct_CC=$CC
# Extract the first word of "gcc", so it can be a program name with args.
set dummy gcc; ac_word=$2
-if test "${ac_cv_prog_ac_ct_CC+set}" = set; then
+if ${ac_cv_prog_ac_ct_CC+:} false; then :
else
if test -n "$ac_ct_CC"; then
ac_cv_prog_ac_ct_CC="$ac_ct_CC" # Let the user override the test.
@@ -3246,25 +4031,25 @@
do
IFS=$as_save_IFS
ac_cv_prog_ac_ct_CC="gcc"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
ac_ct_CC=$ac_cv_prog_ac_ct_CC
- { echo "$as_me:$LINENO: result: $ac_ct_CC" >&5
-echo "${ECHO_T}$ac_ct_CC" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_CC" >&5
+$as_echo "$ac_ct_CC" >&6; }
else
fi
if test "x$ac_ct_CC" = x; then
@@ -3272,12 +4057,8 @@
else
yes:)
esac
CC=$ac_ct_CC
@@ -3290,10 +4071,10 @@
# Extract the first word of "${ac_tool_prefix}cc", so it can be a program name with args.
set dummy ${ac_tool_prefix}cc; ac_word=$2
else
@@ -3303,25 +4084,25 @@
do
IFS=$as_save_IFS
ac_cv_prog_CC="${ac_tool_prefix}cc"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
CC=$ac_cv_prog_CC
else
fi
@@ -3330,10 +4111,10 @@
if test -z "$CC"; then
# Extract the first word of "cc", so it can be a program name with args.
set dummy cc; ac_word=$2
else
@@ -3344,18 +4125,18 @@
do
IFS=$as_save_IFS
if test "$as_dir/$ac_word$ac_exec_ext" = "/usr/ucb/cc"; then
ac_prog_rejected=yes
continue
fi
ac_cv_prog_CC="cc"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
if test $ac_prog_rejected = yes; then
@@ -3374,11 +4155,11 @@
fi
CC=$ac_cv_prog_CC
else
fi
@@ -3389,10 +4170,10 @@
do
# Extract the first word of "$ac_tool_prefix$ac_prog", so it can be a program name with args.
set dummy $ac_tool_prefix$ac_prog; ac_word=$2
else
@@ -3402,25 +4183,25 @@
do
IFS=$as_save_IFS
ac_cv_prog_CC="$ac_tool_prefix$ac_prog"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
CC=$ac_cv_prog_CC
else
fi
@@ -3433,10 +4214,10 @@
do
else
@@ -3446,25 +4227,25 @@
do
IFS=$as_save_IFS
ac_cv_prog_ac_ct_CC="$ac_prog"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
else
fi
@@ -3476,12 +4257,8 @@
else
yes:)
esac
CC=$ac_ct_CC
@@ -3491,51 +4268,37 @@
fi
-test -z "$CC" && { { echo "$as_me:$LINENO: error: no acceptable C compiler found in \$PATH
-See \`config.log' for more details." >&5
-echo "$as_me: error: no acceptable C compiler found in \$PATH
-See \`config.log' for more details." >&2;}
+test -z "$CC" && { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
+as_fn_error $? "no acceptable C compiler found in \$PATH
# Provide some information about the compiler.
-echo "$as_me:$LINENO: checking for C compiler version" >&5
-ac_compiler=`set X $ac_compile; echo $2`
-{ (ac_try="$ac_compiler --version >&5"
+$as_echo "$as_me:${as_lineno-$LINENO}: checking for C compiler version" >&5
+set X $ac_compile
+ac_compiler=$2
+for ac_option in --version -v -V -qversion; do
+ { { ac_try="$ac_compiler $ac_option >&5"
case "(($ac_try" in
*\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
*) ac_try_echo=$ac_try;;
esac
-eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5
- (eval "$ac_compiler --version >&5") 2>&5
+eval ac_try_echo="\"\$as_me:${as_lineno-$LINENO}: $ac_try_echo\""
+$as_echo "$ac_try_echo"; } >&5
+ (eval "$ac_compiler $ac_option >&5") 2>conftest.err
ac_status=$?
- echo "$as_me:$LINENO: \$? = $ac_status" >&5
- (exit $ac_status); }
-{ (ac_try="$ac_compiler -v >&5"
-case "(($ac_try" in
- *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
- *) ac_try_echo=$ac_try;;
-esac
- (eval "$ac_compiler -v >&5") 2>&5
- ac_status=$?
-{ (ac_try="$ac_compiler -V >&5"
-esac
- (eval "$ac_compiler -V >&5") 2>&5
- ac_status=$?
+ if test -s conftest.err; then
+ sed '10a\
+... rest of stderr output deleted ...
+ 10q' conftest.err >conftest.er1
+ cat conftest.er1 >&5
+ fi
+ rm -f conftest.er1 conftest.err
+ $as_echo "$as_me:${as_lineno-$LINENO}: \$? = $ac_status" >&5
+done
-cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h. */
-_ACEOF
-cat confdefs.h >>conftest.$ac_ext
-cat >>conftest.$ac_ext <<_ACEOF
int
@@ -3547,42 +4310,38 @@
_ACEOF
ac_clean_files_save=$ac_clean_files
-ac_clean_files="$ac_clean_files a.out a.exe b.out"
+ac_clean_files="$ac_clean_files a.out a.out.dSYM a.exe b.out"
# Try to create an executable without -o first, disregard a.out.
# It will help us diagnose broken compilers, and finding out an intuition
# of exeext.
-{ echo "$as_me:$LINENO: checking for C compiler default output file name" >&5
-echo $ECHO_N "checking for C compiler default output file name... $ECHO_C" >&6; }
-ac_link_default=`echo "$ac_link" | sed 's/ -o *conftest[^ ]*//'`
-# List of possible output files, starting from the most likely.
-# The algorithm is not robust to junk in `.', hence go to wildcards (a.*)
-# only as a last resort. b.out is created by i960 compilers.
-ac_files='a_out.exe a.exe conftest.exe a.out conftest a.* conftest.* b.out'
-# The IRIX 6 linker writes into existing files which may not be
-# executable, retaining their permissions. Remove them first so a
-# subsequent execution test works.
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the C compiler works" >&5
+$as_echo_n "checking whether the C compiler works... " >&6; }
+ac_link_default=`$as_echo "$ac_link" | sed 's/ -o *conftest[^ ]*//'`
+# The possible output files:
+ac_files="a.out conftest.exe conftest a.exe a_out.exe b.out conftest.*"
ac_rmfiles=
for ac_file in $ac_files
do
case $ac_file in
- *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.map | *.inf | *.o | *.obj ) ;;
+ *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.map | *.inf | *.dSYM | *.o | *.obj ) ;;
* ) ac_rmfiles="$ac_rmfiles $ac_file";;
esac
done
rm -f $ac_rmfiles
-if { (ac_try="$ac_link_default"
+if { { ac_try="$ac_link_default"
case "(($ac_try" in
esac
(eval "$ac_link_default") 2>&5
ac_status=$?
- (exit $ac_status); }; then
+ test $ac_status = 0; }; then :
# Autoconf-2.13 could set the ac_cv_exeext variable to `no'.
# So ignore a value of `no', otherwise this would lead to `EXEEXT = no'
# in a Makefile. We should not override ac_cv_exeext if it was cached,
@@ -3592,14 +4351,14 @@
do
test -f "$ac_file" || continue
case $ac_file in
[ab].out )
# We found the default executable, but exeext='' is most
# certainly right.
break;;
- if test "${ac_cv_exeext+set}" = set && test "$ac_cv_exeext" != no;
+ if test "${ac_cv_exeext+set}" = set && test "$ac_cv_exeext" != no;
then :; else
ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'`
fi
@@ -3618,78 +4377,41 @@
else
ac_file=''
fi
-{ echo "$as_me:$LINENO: result: $ac_file" >&5
-echo "${ECHO_T}$ac_file" >&6; }
-if test -z "$ac_file"; then
- echo "$as_me: failed program was:" >&5
+if test -z "$ac_file"; then :
+$as_echo "$as_me: failed program was:" >&5
sed 's/^/| /' conftest.$ac_ext >&5
-{ { echo "$as_me:$LINENO: error: C compiler cannot create executables
-echo "$as_me: error: C compiler cannot create executables
- { (exit 77); exit 77; }; }
+{ { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
+as_fn_error 77 "C compiler cannot create executables
+else
fi
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for C compiler default output file name" >&5
+$as_echo_n "checking for C compiler default output file name... " >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_file" >&5
+$as_echo "$ac_file" >&6; }
ac_exeext=$ac_cv_exeext
-# Check that the compiler produces executables we can run. If not, either
-# the compiler is broken, or we cross compile.
-{ echo "$as_me:$LINENO: checking whether the C compiler works" >&5
-echo $ECHO_N "checking whether the C compiler works... $ECHO_C" >&6; }
-# FIXME: These cross compiler hacks should be removed for Autoconf 3.0
-# If not cross compiling, check that we can run a simple program.
-if test "$cross_compiling" != yes; then
- if { ac_try='./$ac_file'
- { (case "(($ac_try" in
-esac
- (eval "$ac_try") 2>&5
- ac_status=$?
- (exit $ac_status); }; }; then
- cross_compiling=no
- else
- if test "$cross_compiling" = maybe; then
- cross_compiling=yes
- else
- { { echo "$as_me:$LINENO: error: cannot run C compiled programs.
-If you meant to cross compile, use \`--host'.
-echo "$as_me: error: cannot run C compiled programs.
- fi
- fi
-fi
-rm -f a.out a.exe conftest$ac_cv_exeext b.out
+rm -f -r a.out a.out.dSYM a.exe conftest$ac_cv_exeext b.out
ac_clean_files=$ac_clean_files_save
-{ echo "$as_me:$LINENO: checking whether we are cross compiling" >&5
-echo $ECHO_N "checking whether we are cross compiling... $ECHO_C" >&6; }
-{ echo "$as_me:$LINENO: result: $cross_compiling" >&5
-echo "${ECHO_T}$cross_compiling" >&6; }
-{ echo "$as_me:$LINENO: checking for suffix of executables" >&5
-echo $ECHO_N "checking for suffix of executables... $ECHO_C" >&6; }
-if { (ac_try="$ac_link"
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for suffix of executables" >&5
+$as_echo_n "checking for suffix of executables... " >&6; }
+if { { ac_try="$ac_link"
case "(($ac_try" in
esac
(eval "$ac_link") 2>&5
ac_status=$?
# If both `conftest.exe' and `conftest' are `present' (well, observable)
# catch `conftest.exe'. For instance with Cygwin, `ls conftest' will
# work properly (i.e., refer to `conftest.exe'), while it won't with
@@ -3697,37 +4419,90 @@
for ac_file in conftest.exe conftest conftest.*; do
case $ac_file in
*.* ) ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'`
break;;
* ) break;;
esac
done
else
- { { echo "$as_me:$LINENO: error: cannot compute suffix of executables: cannot compile and link
-echo "$as_me: error: cannot compute suffix of executables: cannot compile and link
+ { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
+as_fn_error $? "cannot compute suffix of executables: cannot compile and link
fi
+rm -f conftest conftest$ac_cv_exeext
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_exeext" >&5
+$as_echo "$ac_cv_exeext" >&6; }
-rm -f conftest$ac_cv_exeext
-{ echo "$as_me:$LINENO: result: $ac_cv_exeext" >&5
-echo "${ECHO_T}$ac_cv_exeext" >&6; }
rm -f conftest.$ac_ext
EXEEXT=$ac_cv_exeext
ac_exeext=$EXEEXT
-{ echo "$as_me:$LINENO: checking for suffix of object files" >&5
-echo $ECHO_N "checking for suffix of object files... $ECHO_C" >&6; }
-if test "${ac_cv_objext+set}" = set; then
-else
- cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h. */
+cat confdefs.h - <<_ACEOF >conftest.$ac_ext
+/* end confdefs.h. */
+#include <stdio.h>
+int
+main ()
+FILE *f = fopen ("conftest.out", "w");
+ return ferror (f) || fclose (f) != 0;
+ return 0;
_ACEOF
+ac_clean_files="$ac_clean_files conftest.out"
+# Check that the compiler produces executables we can run. If not, either
+# the compiler is broken, or we cross compile.
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether we are cross compiling" >&5
+$as_echo_n "checking whether we are cross compiling... " >&6; }
+if test "$cross_compiling" != yes; then
+ { { ac_try="$ac_link"
+case "(($ac_try" in
+ *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
+ *) ac_try_echo=$ac_try;;
+esac
+ (eval "$ac_link") 2>&5
+ ac_status=$?
+ if { ac_try='./conftest$ac_cv_exeext'
+ { { case "(($ac_try" in
+esac
+ (eval "$ac_try") 2>&5
+ ac_status=$?
+ test $ac_status = 0; }; }; then
+ cross_compiling=no
+ else
+ if test "$cross_compiling" = maybe; then
+ cross_compiling=yes
+ else
+as_fn_error $? "cannot run C compiled programs.
+If you meant to cross compile, use \`--host'.
+ fi
+ fi
+fi
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $cross_compiling" >&5
+$as_echo "$cross_compiling" >&6; }
+rm -f conftest.$ac_ext conftest$ac_cv_exeext conftest.out
+ac_clean_files=$ac_clean_files_save
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for suffix of object files" >&5
+$as_echo_n "checking for suffix of object files... " >&6; }
+if ${ac_cv_objext+:} false; then :
+ $as_echo_n "(cached) " >&6
+else
+ cat confdefs.h - <<_ACEOF >conftest.$ac_ext
int
@@ -3739,51 +4514,46 @@
_ACEOF
rm -f conftest.o conftest.obj
-if { (ac_try="$ac_compile"
+if { { ac_try="$ac_compile"
case "(($ac_try" in
esac
(eval "$ac_compile") 2>&5
ac_status=$?
for ac_file in conftest.o conftest.obj conftest.*; do
test -f "$ac_file" || continue;
case $ac_file in
- *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.map | *.inf ) ;;
+ *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.map | *.inf | *.dSYM ) ;;
*) ac_cv_objext=`expr "$ac_file" : '.*\.\(.*\)'`
break;;
esac
done
else
+ $as_echo "$as_me: failed program was:" >&5
-{ { echo "$as_me:$LINENO: error: cannot compute suffix of object files: cannot compile
-echo "$as_me: error: cannot compute suffix of object files: cannot compile
+as_fn_error $? "cannot compute suffix of object files: cannot compile
fi
rm -f conftest.$ac_cv_objext conftest.$ac_ext
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_objext" >&5
-echo "${ECHO_T}$ac_cv_objext" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_objext" >&5
+$as_echo "$ac_cv_objext" >&6; }
OBJEXT=$ac_cv_objext
ac_objext=$OBJEXT
-{ echo "$as_me:$LINENO: checking whether we are using the GNU C compiler" >&5
-echo $ECHO_N "checking whether we are using the GNU C compiler... $ECHO_C" >&6; }
-if test "${ac_cv_c_compiler_gnu+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether we are using the GNU C compiler" >&5
+$as_echo_n "checking whether we are using the GNU C compiler... " >&6; }
+if ${ac_cv_c_compiler_gnu+:} false; then :
else
-/* confdefs.h. */
-_ACEOF
int
@@ -3797,54 +4567,34 @@
return 0;
_ACEOF
-rm -f conftest.$ac_objext
-esac
- (eval "$ac_compile") 2>conftest.er1
- ac_status=$?
- grep -v '^ *+' conftest.er1 >conftest.err
- rm -f conftest.er1
- cat conftest.err >&5
- (exit $ac_status); } && {
- test -z "$ac_c_werror_flag" ||
- test ! -s conftest.err
- } && test -s conftest.$ac_objext; then
+if ac_fn_c_try_compile "$LINENO"; then :
ac_compiler_gnu=yes
else
-sed 's/^/| /' conftest.$ac_ext >&5
- ac_compiler_gnu=no
+ ac_compiler_gnu=no
fi
rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
ac_cv_c_compiler_gnu=$ac_compiler_gnu
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_c_compiler_gnu" >&5
-echo "${ECHO_T}$ac_cv_c_compiler_gnu" >&6; }
-GCC=`test $ac_compiler_gnu = yes && echo yes`
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_c_compiler_gnu" >&5
+$as_echo "$ac_cv_c_compiler_gnu" >&6; }
+if test $ac_compiler_gnu = yes; then
+ GCC=yes
+else
+ GCC=
+fi
ac_test_CFLAGS=${CFLAGS+set}
ac_save_CFLAGS=$CFLAGS
-{ echo "$as_me:$LINENO: checking whether $CC accepts -g" >&5
-echo $ECHO_N "checking whether $CC accepts -g... $ECHO_C" >&6; }
-if test "${ac_cv_prog_cc_g+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether $CC accepts -g" >&5
+$as_echo_n "checking whether $CC accepts -g... " >&6; }
+if ${ac_cv_prog_cc_g+:} false; then :
else
ac_save_c_werror_flag=$ac_c_werror_flag
ac_c_werror_flag=yes
ac_cv_prog_cc_g=no
CFLAGS="-g"
-/* confdefs.h. */
-_ACEOF
int
@@ -3855,34 +4605,11 @@
return 0;
_ACEOF
-esac
- ac_status=$?
ac_cv_prog_cc_g=yes
else
- CFLAGS=""
-/* confdefs.h. */
-_ACEOF
+ CFLAGS=""
int
@@ -3893,35 +4620,12 @@
return 0;
_ACEOF
-esac
- ac_status=$?
-else
- ac_c_werror_flag=$ac_save_c_werror_flag
+else
+ ac_c_werror_flag=$ac_save_c_werror_flag
CFLAGS="-g"
-/* confdefs.h. */
-_ACEOF
int
@@ -3932,42 +4636,18 @@
return 0;
_ACEOF
-esac
- ac_status=$?
ac_cv_prog_cc_g=yes
-else
fi
fi
fi
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_prog_cc_g" >&5
-echo "${ECHO_T}$ac_cv_prog_cc_g" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_prog_cc_g" >&5
+$as_echo "$ac_cv_prog_cc_g" >&6; }
if test "$ac_test_CFLAGS" = set; then
CFLAGS=$ac_save_CFLAGS
elif test $ac_cv_prog_cc_g = yes; then
@@ -3983,23 +4663,18 @@
CFLAGS=
fi
fi
-{ echo "$as_me:$LINENO: checking for $CC option to accept ISO C89" >&5
-echo $ECHO_N "checking for $CC option to accept ISO C89... $ECHO_C" >&6; }
-if test "${ac_cv_prog_cc_c89+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $CC option to accept ISO C89" >&5
+$as_echo_n "checking for $CC option to accept ISO C89... " >&6; }
+if ${ac_cv_prog_cc_c89+:} false; then :
else
ac_cv_prog_cc_c89=no
ac_save_CC=$CC
-/* confdefs.h. */
-_ACEOF
#include <stdarg.h>
#include <stdio.h>
-#include <sys/types.h>
-#include <sys/stat.h>
+struct stat;
/* Most of the following tests are stolen from RCS 5.7's src/conf.sh. */
struct buf { int x; };
FILE * (*rcsopen) (struct buf *, struct stat *, int);
@@ -4051,31 +4726,9 @@
-Ae "-Aa -D_HPUX_SOURCE" "-Xc -D__EXTENSIONS__"
do
CC="$ac_save_CC $ac_arg"
- rm -f conftest.$ac_objext
-esac
- ac_status=$?
+ if ac_fn_c_try_compile "$LINENO"; then :
ac_cv_prog_cc_c89=$ac_arg
-else
fi
test "x$ac_cv_prog_cc_c89" != "xno" && break
done
@@ -4086,17 +4739,19 @@
# AC_CACHE_VAL
case "x$ac_cv_prog_cc_c89" in
x)
- { echo "$as_me:$LINENO: result: none needed" >&5
-echo "${ECHO_T}none needed" >&6; } ;;
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: none needed" >&5
+$as_echo "none needed" >&6; } ;;
xno)
- { echo "$as_me:$LINENO: result: unsupported" >&5
-echo "${ECHO_T}unsupported" >&6; } ;;
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: unsupported" >&5
+$as_echo "unsupported" >&6; } ;;
CC="$CC $ac_cv_prog_cc_c89"
- { echo "$as_me:$LINENO: result: $ac_cv_prog_cc_c89" >&5
-echo "${ECHO_T}$ac_cv_prog_cc_c89" >&6; } ;;
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_prog_cc_c89" >&5
+$as_echo "$ac_cv_prog_cc_c89" >&6; } ;;
esac
+if test "x$ac_cv_prog_cc_c89" != xno; then :
+fi
ac_ext=c
@@ -4115,8 +4770,8 @@
.PHONY: am__doit
END
# If we don't find an include directive, just comment out the code.
-{ echo "$as_me:$LINENO: checking for style of include used by $am_make" >&5
-echo $ECHO_N "checking for style of include used by $am_make... $ECHO_C" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for style of include used by $am_make" >&5
+$as_echo_n "checking for style of include used by $am_make... " >&6; }
am__include="#"
am__quote=
_am_result=none
@@ -4143,12 +4798,12 @@
fi
-{ echo "$as_me:$LINENO: result: $_am_result" >&5
-echo "${ECHO_T}$_am_result" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $_am_result" >&5
+$as_echo "$_am_result" >&6; }
rm -f confinc confmf
# Check whether --enable-dependency-tracking was given.
-if test "${enable_dependency_tracking+set}" = set; then
+if test "${enable_dependency_tracking+set}" = set; then :
enableval=$enable_dependency_tracking;
fi
@@ -4168,10 +4823,10 @@
depcc="$CC" am_compiler_list=
-{ echo "$as_me:$LINENO: checking dependency style of $depcc" >&5
-echo $ECHO_N "checking dependency style of $depcc... $ECHO_C" >&6; }
-if test "${am_cv_CC_dependencies_compiler_type+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking dependency style of $depcc" >&5
+$as_echo_n "checking dependency style of $depcc... " >&6; }
+if ${am_cv_CC_dependencies_compiler_type+:} false; then :
else
if test -z "$AMDEP_TRUE" && test -f "$am_depcomp"; then
# We make a subdir and do the tests there. Otherwise we can end up
@@ -4259,8 +4914,8 @@
fi
fi
-{ echo "$as_me:$LINENO: result: $am_cv_CC_dependencies_compiler_type" >&5
-echo "${ECHO_T}$am_cv_CC_dependencies_compiler_type" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $am_cv_CC_dependencies_compiler_type" >&5
+$as_echo "$am_cv_CC_dependencies_compiler_type" >&6; }
CCDEPMODE=depmode=$am_cv_CC_dependencies_compiler_type
if
@@ -4288,10 +4943,10 @@
do
-if test "${ac_cv_prog_CXX+set}" = set; then
+if ${ac_cv_prog_CXX+:} false; then :
else
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -4301,25 +4956,25 @@
do
IFS=$as_save_IFS
ac_cv_prog_CXX="$ac_tool_prefix$ac_prog"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
CXX=$ac_cv_prog_CXX
- { echo "$as_me:$LINENO: result: $CXX" >&5
-echo "${ECHO_T}$CXX" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $CXX" >&5
+$as_echo "$CXX" >&6; }
else
fi
@@ -4332,10 +4987,10 @@
do
-if test "${ac_cv_prog_ac_ct_CXX+set}" = set; then
+if ${ac_cv_prog_ac_ct_CXX+:} false; then :
else
if test -n "$ac_ct_CXX"; then
ac_cv_prog_ac_ct_CXX="$ac_ct_CXX" # Let the user override the test.
@@ -4345,25 +5000,25 @@
do
IFS=$as_save_IFS
ac_cv_prog_ac_ct_CXX="$ac_prog"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
ac_ct_CXX=$ac_cv_prog_ac_ct_CXX
- { echo "$as_me:$LINENO: result: $ac_ct_CXX" >&5
-echo "${ECHO_T}$ac_ct_CXX" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_CXX" >&5
+$as_echo "$ac_ct_CXX" >&6; }
else
fi
@@ -4375,12 +5030,8 @@
else
yes:)
esac
CXX=$ac_ct_CXX
@@ -4390,49 +5041,36 @@
fi
fi
-echo "$as_me:$LINENO: checking for C++ compiler version" >&5
+$as_echo "$as_me:${as_lineno-$LINENO}: checking for C++ compiler version" >&5
+set X $ac_compile
+ac_compiler=$2
case "(($ac_try" in
esac
ac_status=$?
-esac
- ac_status=$?
-esac
- ac_status=$?
+ sed '10a\
+ fi
+done
-{ echo "$as_me:$LINENO: checking whether we are using the GNU C++ compiler" >&5
-echo $ECHO_N "checking whether we are using the GNU C++ compiler... $ECHO_C" >&6; }
-if test "${ac_cv_cxx_compiler_gnu+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether we are using the GNU C++ compiler" >&5
+$as_echo_n "checking whether we are using the GNU C++ compiler... " >&6; }
+if ${ac_cv_cxx_compiler_gnu+:} false; then :
else
-/* confdefs.h. */
-_ACEOF
int
@@ -4446,54 +5084,34 @@
return 0;
_ACEOF
-esac
- ac_status=$?
- test -z "$ac_cxx_werror_flag" ||
+if ac_fn_cxx_try_compile "$LINENO"; then :
ac_compiler_gnu=yes
else
fi
ac_cv_cxx_compiler_gnu=$ac_compiler_gnu
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_cxx_compiler_gnu" >&5
-echo "${ECHO_T}$ac_cv_cxx_compiler_gnu" >&6; }
-GXX=`test $ac_compiler_gnu = yes && echo yes`
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_cxx_compiler_gnu" >&5
+$as_echo "$ac_cv_cxx_compiler_gnu" >&6; }
+ GXX=yes
+else
+ GXX=
+fi
ac_test_CXXFLAGS=${CXXFLAGS+set}
ac_save_CXXFLAGS=$CXXFLAGS
-{ echo "$as_me:$LINENO: checking whether $CXX accepts -g" >&5
-echo $ECHO_N "checking whether $CXX accepts -g... $ECHO_C" >&6; }
-if test "${ac_cv_prog_cxx_g+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether $CXX accepts -g" >&5
+$as_echo_n "checking whether $CXX accepts -g... " >&6; }
+if ${ac_cv_prog_cxx_g+:} false; then :
else
ac_save_cxx_werror_flag=$ac_cxx_werror_flag
ac_cxx_werror_flag=yes
ac_cv_prog_cxx_g=no
CXXFLAGS="-g"
-/* confdefs.h. */
-_ACEOF
int
@@ -4504,34 +5122,11 @@
return 0;
_ACEOF
-esac
- ac_status=$?
ac_cv_prog_cxx_g=yes
else
- CXXFLAGS=""
-/* confdefs.h. */
-_ACEOF
+ CXXFLAGS=""
int
@@ -4542,35 +5137,12 @@
return 0;
_ACEOF
-esac
- ac_status=$?
-else
- ac_cxx_werror_flag=$ac_save_cxx_werror_flag
+else
+ ac_cxx_werror_flag=$ac_save_cxx_werror_flag
CXXFLAGS="-g"
-/* confdefs.h. */
-_ACEOF
int
@@ -4581,42 +5153,18 @@
return 0;
_ACEOF
-esac
- ac_status=$?
-else
fi
fi
fi
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_prog_cxx_g" >&5
-echo "${ECHO_T}$ac_cv_prog_cxx_g" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_prog_cxx_g" >&5
+$as_echo "$ac_cv_prog_cxx_g" >&6; }
if test "$ac_test_CXXFLAGS" = set; then
CXXFLAGS=$ac_save_CXXFLAGS
elif test $ac_cv_prog_cxx_g = yes; then
@@ -4640,10 +5188,10 @@
depcc="$CXX" am_compiler_list=
-if test "${am_cv_CXX_dependencies_compiler_type+set}" = set; then
+if ${am_cv_CXX_dependencies_compiler_type+:} false; then :
else
@@ -4731,8 +5279,8 @@
fi
fi
-{ echo "$as_me:$LINENO: result: $am_cv_CXX_dependencies_compiler_type" >&5
-echo "${ECHO_T}$am_cv_CXX_dependencies_compiler_type" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $am_cv_CXX_dependencies_compiler_type" >&5
+$as_echo "$am_cv_CXX_dependencies_compiler_type" >&6; }
CXXDEPMODE=depmode=$am_cv_CXX_dependencies_compiler_type
if
@@ -4749,7 +5297,7 @@
# Check whether --enable-shared was given.
-if test "${enable_shared+set}" = set; then
+if test "${enable_shared+set}" = set; then :
enableval=$enable_shared; p=${PACKAGE-default}
case $enableval in
yes) enable_shared=yes ;;
@@ -4773,7 +5321,7 @@
# Check whether --enable-static was given.
-if test "${enable_static+set}" = set; then
+if test "${enable_static+set}" = set; then :
enableval=$enable_static; p=${PACKAGE-default}
case $enableval in
yes) enable_static=yes ;;
@@ -4797,7 +5345,7 @@
# Check whether --enable-fast-install was given.
-if test "${enable_fast_install+set}" = set; then
+if test "${enable_fast_install+set}" = set; then :
enableval=$enable_fast_install; p=${PACKAGE-default}
case $enableval in
yes) enable_fast_install=yes ;;
@@ -4820,10 +5368,10 @@
fi
-{ echo "$as_me:$LINENO: checking for a sed that does not truncate output" >&5
-echo $ECHO_N "checking for a sed that does not truncate output... $ECHO_C" >&6; }
-if test "${lt_cv_path_SED+set}" = set; then
- echo $ECHO_N "(cached) $ECHO_C" >&6
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for a sed that does not truncate output" >&5
+$as_echo_n "checking for a sed that does not truncate output... " >&6; }
+if ${lt_cv_path_SED+:} false; then :
else
# Loop through the user's path and test for sed and gsed.
# Then use that list of sed's as ones to test for truncation.
@@ -4834,7 +5382,7 @@
for lt_ac_prog in sed gsed; do
- if { test -f "$as_dir/$lt_ac_prog$ac_exec_ext" && $as_test_x "$as_dir/$lt_ac_prog$ac_exec_ext"; }; then
+ if as_fn_executable_p "$as_dir/$lt_ac_prog$ac_exec_ext"; then
lt_ac_sed_list="$lt_ac_sed_list $as_dir/$lt_ac_prog$ac_exec_ext"
fi
done
@@ -4876,48 +5424,43 @@
SED=$lt_cv_path_SED
-{ echo "$as_me:$LINENO: result: $SED" >&5
-echo "${ECHO_T}$SED" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $SED" >&5
+$as_echo "$SED" >&6; }
-{ echo "$as_me:$LINENO: checking for grep that handles long lines and -e" >&5
-echo $ECHO_N "checking for grep that handles long lines and -e... $ECHO_C" >&6; }
-if test "${ac_cv_path_GREP+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for grep that handles long lines and -e" >&5
+$as_echo_n "checking for grep that handles long lines and -e... " >&6; }
+if ${ac_cv_path_GREP+:} false; then :
else
- # Extract the first word of "grep ggrep" to use in msg output
-if test -z "$GREP"; then
-set dummy grep ggrep; ac_prog_name=$2
-else
+ if test -z "$GREP"; then
ac_path_GREP_found=false
-# Loop through the user's path and test for each of PROGNAME-LIST
-as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+ # Loop through the user's path and test for each of PROGNAME-LIST
+ as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
for as_dir in $PATH$PATH_SEPARATOR/usr/xpg4/bin
do
IFS=$as_save_IFS
- for ac_prog in grep ggrep; do
- ac_path_GREP="$as_dir/$ac_prog$ac_exec_ext"
- { test -f "$ac_path_GREP" && $as_test_x "$ac_path_GREP"; } || continue
- # Check for GNU ac_path_GREP and select it if it is found.
+ for ac_prog in grep ggrep; do
+ ac_path_GREP="$as_dir/$ac_prog$ac_exec_ext"
+ as_fn_executable_p "$ac_path_GREP" || continue
+# Check for GNU ac_path_GREP and select it if it is found.
# Check for GNU $ac_path_GREP
case `"$ac_path_GREP" --version 2>&1` in
*GNU*)
ac_cv_path_GREP="$ac_path_GREP" ac_path_GREP_found=:;;
ac_count=0
- echo $ECHO_N "0123456789$ECHO_C" >"conftest.in"
+ $as_echo_n 0123456789 >"conftest.in"
while :
do
cat "conftest.in" "conftest.in" >"conftest.tmp"
mv "conftest.tmp" "conftest.in"
cp "conftest.in" "conftest.nl"
- echo 'GREP' >> "conftest.nl"
+ $as_echo 'GREP' >> "conftest.nl"
"$ac_path_GREP" -e 'GREP$' -e '-(cannot match)-' < "conftest.nl" >"conftest.out" 2>/dev/null || break
diff "conftest.out" "conftest.nl" >/dev/null 2>&1 || break
- ac_count=`expr $ac_count + 1`
+ as_fn_arith $ac_count + 1 && ac_count=$as_val
if test $ac_count -gt ${ac_path_GREP_max-0}; then
# Best one so far, save it but keep looking for a better one
@@ -4929,77 +5472,61 @@
rm -f conftest.in conftest.tmp conftest.nl conftest.out;;
esac
- $ac_path_GREP_found && break 3
+ $ac_path_GREP_found && break 3
+ done
done
-done
-done
+ done
IFS=$as_save_IFS
-fi
-GREP="$ac_cv_path_GREP"
- { { echo "$as_me:$LINENO: error: no acceptable $ac_prog_name could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&5
-echo "$as_me: error: no acceptable $ac_prog_name could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&2;}
-fi
+ if test -z "$ac_cv_path_GREP"; then
+ as_fn_error $? "no acceptable grep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" "$LINENO" 5
+ fi
else
ac_cv_path_GREP=$GREP
fi
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_path_GREP" >&5
-echo "${ECHO_T}$ac_cv_path_GREP" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_path_GREP" >&5
+$as_echo "$ac_cv_path_GREP" >&6; }
-{ echo "$as_me:$LINENO: checking for egrep" >&5
-echo $ECHO_N "checking for egrep... $ECHO_C" >&6; }
-if test "${ac_cv_path_EGREP+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for egrep" >&5
+$as_echo_n "checking for egrep... " >&6; }
+if ${ac_cv_path_EGREP+:} false; then :
else
if echo a | $GREP -E '(a|b)' >/dev/null 2>&1
then ac_cv_path_EGREP="$GREP -E"
else
- # Extract the first word of "egrep" to use in msg output
-if test -z "$EGREP"; then
-set dummy egrep; ac_prog_name=$2
-else
+ if test -z "$EGREP"; then
ac_path_EGREP_found=false
do
IFS=$as_save_IFS
- for ac_prog in egrep; do
- ac_path_EGREP="$as_dir/$ac_prog$ac_exec_ext"
- { test -f "$ac_path_EGREP" && $as_test_x "$ac_path_EGREP"; } || continue
- # Check for GNU ac_path_EGREP and select it if it is found.
+ for ac_prog in egrep; do
+ ac_path_EGREP="$as_dir/$ac_prog$ac_exec_ext"
+ as_fn_executable_p "$ac_path_EGREP" || continue
+# Check for GNU ac_path_EGREP and select it if it is found.
# Check for GNU $ac_path_EGREP
case `"$ac_path_EGREP" --version 2>&1` in
*GNU*)
ac_cv_path_EGREP="$ac_path_EGREP" ac_path_EGREP_found=:;;
ac_count=0
while :
do
- echo 'EGREP' >> "conftest.nl"
+ $as_echo 'EGREP' >> "conftest.nl"
"$ac_path_EGREP" 'EGREP$' < "conftest.nl" >"conftest.out" 2>/dev/null || break
if test $ac_count -gt ${ac_path_EGREP_max-0}; then
@@ -5011,39 +5538,28 @@
esac
- $ac_path_EGREP_found && break 3
+ $ac_path_EGREP_found && break 3
+ done
done
-done
-done
+ done
IFS=$as_save_IFS
-fi
-EGREP="$ac_cv_path_EGREP"
-fi
+ if test -z "$ac_cv_path_EGREP"; then
+ as_fn_error $? "no acceptable egrep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" "$LINENO" 5
+ fi
else
ac_cv_path_EGREP=$EGREP
fi
fi
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_path_EGREP" >&5
-echo "${ECHO_T}$ac_cv_path_EGREP" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_path_EGREP" >&5
+$as_echo "$ac_cv_path_EGREP" >&6; }
# Check whether --with-gnu-ld was given.
-if test "${with_gnu_ld+set}" = set; then
+if test "${with_gnu_ld+set}" = set; then :
withval=$with_gnu_ld; test "$withval" = no || with_gnu_ld=yes
else
with_gnu_ld=no
@@ -5052,8 +5568,8 @@
ac_prog=ld
if test "$GCC" = yes; then
# Check if gcc -print-prog-name=ld gives a path.
- { echo "$as_me:$LINENO: checking for ld used by $CC" >&5
-echo $ECHO_N "checking for ld used by $CC... $ECHO_C" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking for ld used by $CC" >&5
+$as_echo_n "checking for ld used by $CC... " >&6; }
case $host in
*-*-mingw*)
# gcc leaves a trailing carriage return which upsets mingw
@@ -5082,14 +5598,14 @@
esac
elif test "$with_gnu_ld" = yes; then
- { echo "$as_me:$LINENO: checking for GNU ld" >&5
-echo $ECHO_N "checking for GNU ld... $ECHO_C" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking for GNU ld" >&5
+$as_echo_n "checking for GNU ld... " >&6; }
else
- { echo "$as_me:$LINENO: checking for non-GNU ld" >&5
-echo $ECHO_N "checking for non-GNU ld... $ECHO_C" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking for non-GNU ld" >&5
+$as_echo_n "checking for non-GNU ld... " >&6; }
fi
-if test "${lt_cv_path_LD+set}" = set; then
+if ${lt_cv_path_LD+:} false; then :
else
if test -z "$LD"; then
lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
@@ -5119,19 +5635,17 @@
LD="$lt_cv_path_LD"
if test -n "$LD"; then
- { echo "$as_me:$LINENO: result: $LD" >&5
-echo "${ECHO_T}$LD" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $LD" >&5
+$as_echo "$LD" >&6; }
else
- { echo "$as_me:$LINENO: result: no" >&5
-echo "${ECHO_T}no" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
+$as_echo "no" >&6; }
fi
-test -z "$LD" && { { echo "$as_me:$LINENO: error: no acceptable ld found in \$PATH" >&5
-echo "$as_me: error: no acceptable ld found in \$PATH" >&2;}
-{ echo "$as_me:$LINENO: checking if the linker ($LD) is GNU ld" >&5
-echo $ECHO_N "checking if the linker ($LD) is GNU ld... $ECHO_C" >&6; }
-if test "${lt_cv_prog_gnu_ld+set}" = set; then
+test -z "$LD" && as_fn_error $? "no acceptable ld found in \$PATH" "$LINENO" 5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if the linker ($LD) is GNU ld" >&5
+$as_echo_n "checking if the linker ($LD) is GNU ld... " >&6; }
+if ${lt_cv_prog_gnu_ld+:} false; then :
else
# I'd rather use --version here, but apparently some GNU lds only accept -v.
case `$LD -v 2>&1 </dev/null` in
@@ -5143,20 +5657,20 @@
esac
fi
-{ echo "$as_me:$LINENO: result: $lt_cv_prog_gnu_ld" >&5
-echo "${ECHO_T}$lt_cv_prog_gnu_ld" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_gnu_ld" >&5
+$as_echo "$lt_cv_prog_gnu_ld" >&6; }
with_gnu_ld=$lt_cv_prog_gnu_ld
-{ echo "$as_me:$LINENO: checking for $LD option to reload object files" >&5
-echo $ECHO_N "checking for $LD option to reload object files... $ECHO_C" >&6; }
-if test "${lt_cv_ld_reload_flag+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $LD option to reload object files" >&5
+$as_echo_n "checking for $LD option to reload object files... " >&6; }
+if ${lt_cv_ld_reload_flag+:} false; then :
else
lt_cv_ld_reload_flag='-r'
fi
-{ echo "$as_me:$LINENO: result: $lt_cv_ld_reload_flag" >&5
-echo "${ECHO_T}$lt_cv_ld_reload_flag" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_ld_reload_flag" >&5
+$as_echo "$lt_cv_ld_reload_flag" >&6; }
reload_flag=$lt_cv_ld_reload_flag
case $reload_flag in
@@ -5173,10 +5687,10 @@
esac
-{ echo "$as_me:$LINENO: checking for BSD-compatible nm" >&5
-echo $ECHO_N "checking for BSD-compatible nm... $ECHO_C" >&6; }
-if test "${lt_cv_path_NM+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for BSD-compatible nm" >&5
+$as_echo_n "checking for BSD-compatible nm... " >&6; }
+if ${lt_cv_path_NM+:} false; then :
else
if test -n "$NM"; then
@@ -5222,25 +5736,25 @@
test -z "$lt_cv_path_NM" && lt_cv_path_NM=nm
fi
fi
-{ echo "$as_me:$LINENO: result: $lt_cv_path_NM" >&5
-echo "${ECHO_T}$lt_cv_path_NM" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_path_NM" >&5
+$as_echo "$lt_cv_path_NM" >&6; }
NM="$lt_cv_path_NM"
-{ echo "$as_me:$LINENO: checking whether ln -s works" >&5
-echo $ECHO_N "checking whether ln -s works... $ECHO_C" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether ln -s works" >&5
+$as_echo_n "checking whether ln -s works... " >&6; }
LN_S=$as_ln_s
if test "$LN_S" = "ln -s"; then
- { echo "$as_me:$LINENO: result: yes" >&5
-echo "${ECHO_T}yes" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
+$as_echo "yes" >&6; }
else
- { echo "$as_me:$LINENO: result: no, using $LN_S" >&5
-echo "${ECHO_T}no, using $LN_S" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: no, using $LN_S" >&5
+$as_echo "no, using $LN_S" >&6; }
fi
-{ echo "$as_me:$LINENO: checking how to recognize dependent libraries" >&5
-echo $ECHO_N "checking how to recognize dependent libraries... $ECHO_C" >&6; }
-if test "${lt_cv_deplibs_check_method+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking how to recognize dependent libraries" >&5
+$as_echo_n "checking how to recognize dependent libraries... " >&6; }
+if ${lt_cv_deplibs_check_method+:} false; then :
else
lt_cv_file_magic_cmd='$MAGIC_CMD'
lt_cv_file_magic_test_file=
@@ -5423,8 +5937,8 @@
esac
fi
-{ echo "$as_me:$LINENO: result: $lt_cv_deplibs_check_method" >&5
-echo "${ECHO_T}$lt_cv_deplibs_check_method" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_deplibs_check_method" >&5
+$as_echo "$lt_cv_deplibs_check_method" >&6; }
file_magic_cmd=$lt_cv_file_magic_cmd
deplibs_check_method=$lt_cv_deplibs_check_method
test -z "$deplibs_check_method" && deplibs_check_method=unknown
@@ -5443,7 +5957,7 @@
# Check whether --enable-libtool-lock was given.
-if test "${enable_libtool_lock+set}" = set; then
+if test "${enable_libtool_lock+set}" = set; then :
enableval=$enable_libtool_lock;
fi
@@ -5455,11 +5969,11 @@
ia64-*-hpux*)
# Find out which ABI we are using.
echo 'int i;' > conftest.$ac_ext
- if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+ if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$ac_compile\""; } >&5
(eval $ac_compile) 2>&5
ac_status=$?
case `/usr/bin/file conftest.$ac_objext` in
*ELF-32*)
HPUX_IA64_MODE="32"
@@ -5473,12 +5987,12 @@
*-*-irix6*)
- echo '#line 5476 "configure"' > conftest.$ac_ext
+ echo '#line 5990 "configure"' > conftest.$ac_ext
ac_status=$?
if test "$lt_cv_prog_gnu_ld" = yes; then
*32-bit*)
@@ -5512,11 +6026,11 @@
s390*-*linux*|sparc*-*linux*)
ac_status=$?
case `/usr/bin/file conftest.o` in
*32-bit*)
case $host in
@@ -5565,10 +6079,10 @@
# On SCO OpenServer 5, we need -belf to get full-featured binaries.
SAVE_CFLAGS="$CFLAGS"
CFLAGS="$CFLAGS -belf"
- { echo "$as_me:$LINENO: checking whether the C compiler needs -belf" >&5
-echo $ECHO_N "checking whether the C compiler needs -belf... $ECHO_C" >&6; }
-if test "${lt_cv_cc_needs_belf+set}" = set; then
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the C compiler needs -belf" >&5
+$as_echo_n "checking whether the C compiler needs -belf... " >&6; }
+if ${lt_cv_cc_needs_belf+:} false; then :
else
ac_ext=c
ac_cpp='$CPP $CPPFLAGS'
@@ -5576,11 +6090,7 @@
ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
ac_compiler_gnu=$ac_cv_c_compiler_gnu
-/* confdefs.h. */
-_ACEOF
int
@@ -5591,34 +6101,13 @@
return 0;
_ACEOF
-rm -f conftest.$ac_objext conftest$ac_exeext
-esac
- (eval "$ac_link") 2>conftest.er1
- ac_status=$?
- } && test -s conftest$ac_exeext &&
- $as_test_x conftest$ac_exeext; then
+if ac_fn_c_try_link "$LINENO"; then :
lt_cv_cc_needs_belf=yes
else
- lt_cv_cc_needs_belf=no
+ lt_cv_cc_needs_belf=no
fi
-rm -f core conftest.err conftest.$ac_objext conftest_ipa8_conftest.oo \
- conftest$ac_exeext conftest.$ac_ext
+rm -f core conftest.err conftest.$ac_objext \
+ conftest$ac_exeext conftest.$ac_ext
ac_ext=c
ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
@@ -5626,8 +6115,8 @@
fi
-{ echo "$as_me:$LINENO: result: $lt_cv_cc_needs_belf" >&5
-echo "${ECHO_T}$lt_cv_cc_needs_belf" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_cc_needs_belf" >&5
+$as_echo "$lt_cv_cc_needs_belf" >&6; }
if test x"$lt_cv_cc_needs_belf" != x"yes"; then
# this is probably gcc 2.8.0, egcs 1.0 or newer; no need for -belf
CFLAGS="$SAVE_CFLAGS"
@@ -5636,11 +6125,11 @@
sparc*-*solaris*)
ac_status=$?
*64-bit*)
case $lt_cv_prog_gnu_ld in
@@ -5668,15 +6157,15 @@
-{ echo "$as_me:$LINENO: checking how to run the C preprocessor" >&5
-echo $ECHO_N "checking how to run the C preprocessor... $ECHO_C" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking how to run the C preprocessor" >&5
+$as_echo_n "checking how to run the C preprocessor... " >&6; }
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
fi
if test -z "$CPP"; then
- if test "${ac_cv_prog_CPP+set}" = set; then
+ if ${ac_cv_prog_CPP+:} false; then :
else
# Double quotes because CPP needs to be expanded
for CPP in "$CC -E" "$CC -E -traditional-cpp" "/lib/cpp"
@@ -5690,11 +6179,7 @@
# <limits.h> exists even on freestanding compilers.
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp. "Syntax error" is here to catch this case.
-/* confdefs.h. */
-_ACEOF
#ifdef __STDC__
# include <limits.h>
@@ -5703,76 +6188,34 @@
#endif
Syntax error
_ACEOF
-if { (ac_try="$ac_cpp conftest.$ac_ext"
-esac
- (eval "$ac_cpp conftest.$ac_ext") 2>conftest.er1
- ac_status=$?
- (exit $ac_status); } >/dev/null && {
- test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" ||
- }; then
-else
+if ac_fn_c_try_cpp "$LINENO"; then :
+else
# Broken: fails on valid input.
continue
fi
+rm -f conftest.err conftest.i conftest.$ac_ext
-rm -f conftest.err conftest.$ac_ext
# OK, works on sane cases. Now check whether nonexistent headers
# can be detected and how.
-/* confdefs.h. */
-_ACEOF
#include <ac_nonexistent.h>
_ACEOF
-esac
- ac_status=$?
- }; then
# Broken: success on invalid input.
continue
else
# Passes both tests.
ac_preproc_ok=:
break
fi
done
# Because of `break', _AC_PREPROC_IFELSE's cleaning code was skipped.
-if $ac_preproc_ok; then
+rm -f conftest.i conftest.err conftest.$ac_ext
+if $ac_preproc_ok; then :
break
fi
@@ -5784,8 +6227,8 @@
else
ac_cv_prog_CPP=$CPP
fi
-{ echo "$as_me:$LINENO: result: $CPP" >&5
-echo "${ECHO_T}$CPP" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $CPP" >&5
+$as_echo "$CPP" >&6; }
ac_preproc_ok=false
for ac_c_preproc_warn_flag in '' yes
do
@@ -5795,11 +6238,7 @@
-/* confdefs.h. */
-_ACEOF
#ifdef __STDC__
@@ -5808,83 +6247,40 @@
#endif
Syntax error
_ACEOF
-esac
- ac_status=$?
- }; then
-else
+else
continue
fi
-/* confdefs.h. */
-_ACEOF
_ACEOF
-esac
- ac_status=$?
- }; then
continue
else
ac_preproc_ok=:
break
fi
done
else
- { { echo "$as_me:$LINENO: error: C preprocessor \"$CPP\" fails sanity check
-echo "$as_me: error: C preprocessor \"$CPP\" fails sanity check
- { (exit 1); exit 1; }; }
+$as_echo "$as_me: error: in \`$ac_pwd':" >&2;}
+as_fn_error $? "C preprocessor \"$CPP\" fails sanity check
+See \`config.log' for more details" "$LINENO" 5; }
fi
ac_ext=c
@@ -5894,16 +6290,12 @@
-{ echo "$as_me:$LINENO: checking for ANSI C header files" >&5
-echo $ECHO_N "checking for ANSI C header files... $ECHO_C" >&6; }
-if test "${ac_cv_header_stdc+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for ANSI C header files" >&5
+$as_echo_n "checking for ANSI C header files... " >&6; }
+if ${ac_cv_header_stdc+:} false; then :
else
-/* confdefs.h. */
-_ACEOF
#include <stdlib.h>
#include <stdarg.h>
@@ -5918,47 +6310,23 @@
return 0;
_ACEOF
-esac
- ac_status=$?
ac_cv_header_stdc=yes
else
- ac_cv_header_stdc=no
+ ac_cv_header_stdc=no
fi
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-/* confdefs.h. */
-_ACEOF
#include <string.h>
_ACEOF
if (eval "$ac_cpp conftest.$ac_ext") 2>&5 |
- $EGREP "memchr" >/dev/null 2>&1; then
+ $EGREP "memchr" >/dev/null 2>&1; then :
else
fi
@@ -5968,18 +6336,14 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-/* confdefs.h. */
-_ACEOF
#include <stdlib.h>
_ACEOF
- $EGREP "free" >/dev/null 2>&1; then
+ $EGREP "free" >/dev/null 2>&1; then :
else
fi
@@ -5989,14 +6353,10 @@
# /bin/cc in Irix-4.0.5 gets non-ANSI ctype macros unless using -ansi.
- if test "$cross_compiling" = yes; then
+ if test "$cross_compiling" = yes; then :
else
-/* confdefs.h. */
-_ACEOF
#include <ctype.h>
#include <stdlib.h>
@@ -6023,113 +6383,35 @@
return 0;
_ACEOF
-rm -f conftest$ac_exeext
-esac
- (eval "$ac_link") 2>&5
- ac_status=$?
- (exit $ac_status); } && { ac_try='./conftest$ac_exeext'
-esac
- ac_status=$?
-else
- echo "$as_me: program exited with status $ac_status" >&5
-echo "$as_me: failed program was:" >&5
+if ac_fn_c_try_run "$LINENO"; then :
-( exit $ac_status )
-ac_cv_header_stdc=no
+else
fi
-rm -f core *.core core.conftest.* gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext
+rm -f core *.core core.conftest.* gmon.out bb.out conftest$ac_exeext \
+ conftest.$ac_objext conftest.beam conftest.$ac_ext
fi
fi
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_header_stdc" >&5
-echo "${ECHO_T}$ac_cv_header_stdc" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_header_stdc" >&5
+$as_echo "$ac_cv_header_stdc" >&6; }
-#define STDC_HEADERS 1
-_ACEOF
+$as_echo "#define STDC_HEADERS 1" >>confdefs.h
fi
# On IRIX 5.3, sys/types and inttypes.h are conflicting.
for ac_header in sys/types.h sys/stat.h stdlib.h string.h memory.h strings.h \
inttypes.h stdint.h unistd.h
-do
-as_ac_Header=`echo "ac_cv_header_$ac_header" | $as_tr_sh`
-{ echo "$as_me:$LINENO: checking for $ac_header" >&5
-echo $ECHO_N "checking for $ac_header... $ECHO_C" >&6; }
-if { as_var=$as_ac_Header; eval "test \"\${$as_var+set}\" = set"; }; then
-else
-/* confdefs.h. */
-_ACEOF
-/* end confdefs.h. */
-$ac_includes_default
-#include <$ac_header>
-_ACEOF
-esac
- ac_status=$?
- eval "$as_ac_Header=yes"
-else
- eval "$as_ac_Header=no"
-fi
-rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
-fi
-ac_res=`eval echo '${'$as_ac_Header'}'`
- { echo "$as_me:$LINENO: result: $ac_res" >&5
-echo "${ECHO_T}$ac_res" >&6; }
-if test `eval echo '${'$as_ac_Header'}'` = yes; then
+do :
+ as_ac_Header=`$as_echo "ac_cv_header_$ac_header" | $as_tr_sh`
+ac_fn_c_check_header_compile "$LINENO" "$ac_header" "$as_ac_Header" "$ac_includes_default
+if eval test \"x\$"$as_ac_Header"\" = x"yes"; then :
cat >>confdefs.h <<_ACEOF
-#define `echo "HAVE_$ac_header" | $as_tr_cpp` 1
+#define `$as_echo "HAVE_$ac_header" | $as_tr_cpp` 1
_ACEOF
fi
@@ -6137,145 +6419,12 @@
done
for ac_header in dlfcn.h
-do
- { echo "$as_me:$LINENO: checking for $ac_header" >&5
-fi
-else
- # Is the header compilable?
-{ echo "$as_me:$LINENO: checking $ac_header usability" >&5
-echo $ECHO_N "checking $ac_header usability... $ECHO_C" >&6; }
-/* confdefs.h. */
-_ACEOF
-_ACEOF
-esac
- ac_status=$?
- ac_header_compiler=yes
-else
- ac_header_compiler=no
-fi
-{ echo "$as_me:$LINENO: result: $ac_header_compiler" >&5
-echo "${ECHO_T}$ac_header_compiler" >&6; }
-# Is the header present?
-{ echo "$as_me:$LINENO: checking $ac_header presence" >&5
-echo $ECHO_N "checking $ac_header presence... $ECHO_C" >&6; }
-/* confdefs.h. */
-_ACEOF
-_ACEOF
-esac
- ac_status=$?
- }; then
- ac_header_preproc=yes
-else
- ac_header_preproc=no
-fi
-{ echo "$as_me:$LINENO: result: $ac_header_preproc" >&5
-echo "${ECHO_T}$ac_header_preproc" >&6; }
-# So? What about this header?
-case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in
- yes:no: )
- { echo "$as_me:$LINENO: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&5
-echo "$as_me: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the compiler's result" >&5
-echo "$as_me: WARNING: $ac_header: proceeding with the compiler's result" >&2;}
- no:yes:* )
- { echo "$as_me:$LINENO: WARNING: $ac_header: present but cannot be compiled" >&5
-echo "$as_me: WARNING: $ac_header: present but cannot be compiled" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: check for missing prerequisite headers?" >&5
-echo "$as_me: WARNING: $ac_header: check for missing prerequisite headers?" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: see the Autoconf documentation" >&5
-echo "$as_me: WARNING: $ac_header: see the Autoconf documentation" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: section \"Present But Cannot Be Compiled\"" >&5
-echo "$as_me: WARNING: $ac_header: section \"Present But Cannot Be Compiled\"" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the preprocessor's result" >&5
-echo "$as_me: WARNING: $ac_header: proceeding with the preprocessor's result" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: in the future, the compiler will take precedence" >&5
-echo "$as_me: WARNING: $ac_header: in the future, the compiler will take precedence" >&2;}
- ( cat <<\_ASBOX
-## Report this to Oracle Technology Network Berkeley DB XML forum ##
-_ASBOX
- ) | sed "s/^/$as_me: WARNING: /" >&2
-esac
-else
- eval "$as_ac_Header=\$ac_header_preproc"
-fi
-fi
+do :
+ ac_fn_c_check_header_mongrel "$LINENO" "dlfcn.h" "ac_cv_header_dlfcn_h" "$ac_includes_default"
+if test "x$ac_cv_header_dlfcn_h" = xyes; then :
+#define HAVE_DLFCN_H 1
_ACEOF
fi
@@ -6292,11 +6441,11 @@
ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
-{ echo "$as_me:$LINENO: checking how to run the C++ preprocessor" >&5
-echo $ECHO_N "checking how to run the C++ preprocessor... $ECHO_C" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking how to run the C++ preprocessor" >&5
+$as_echo_n "checking how to run the C++ preprocessor... " >&6; }
if test -z "$CXXCPP"; then
- if test "${ac_cv_prog_CXXCPP+set}" = set; then
+ if ${ac_cv_prog_CXXCPP+:} false; then :
else
# Double quotes because CXXCPP needs to be expanded
for CXXCPP in "$CXX -E" "/lib/cpp"
@@ -6310,11 +6459,7 @@
-/* confdefs.h. */
-_ACEOF
#ifdef __STDC__
@@ -6323,76 +6468,34 @@
#endif
Syntax error
_ACEOF
-esac
- ac_status=$?
- test -z "$ac_cxx_preproc_warn_flag$ac_cxx_werror_flag" ||
- }; then
-else
+if ac_fn_cxx_try_cpp "$LINENO"; then :
+else
continue
fi
-/* confdefs.h. */
-_ACEOF
_ACEOF
-esac
- ac_status=$?
- }; then
continue
else
ac_preproc_ok=:
break
fi
done
break
fi
@@ -6404,8 +6507,8 @@
else
ac_cv_prog_CXXCPP=$CXXCPP
fi
-{ echo "$as_me:$LINENO: result: $CXXCPP" >&5
-echo "${ECHO_T}$CXXCPP" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $CXXCPP" >&5
+$as_echo "$CXXCPP" >&6; }
ac_preproc_ok=false
for ac_cxx_preproc_warn_flag in '' yes
do
@@ -6415,11 +6518,7 @@
-/* confdefs.h. */
-_ACEOF
#ifdef __STDC__
@@ -6428,83 +6527,40 @@
#endif
Syntax error
_ACEOF
-esac
- ac_status=$?
- }; then
-else
+else
continue
fi
-/* confdefs.h. */
-_ACEOF
_ACEOF
-esac
- ac_status=$?
- }; then
continue
else
ac_preproc_ok=:
break
fi
done
else
- { { echo "$as_me:$LINENO: error: C++ preprocessor \"$CXXCPP\" fails sanity check
-echo "$as_me: error: C++ preprocessor \"$CXXCPP\" fails sanity check
+as_fn_error $? "C++ preprocessor \"$CXXCPP\" fails sanity check
fi
ac_ext=cpp
@@ -6521,14 +6577,14 @@
ac_link='$F77 -o conftest$ac_exeext $FFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
ac_compiler_gnu=$ac_cv_f77_compiler_gnu
if test -n "$ac_tool_prefix"; then
- for ac_prog in g77 xlf f77 frt pgf77 cf77 fort77 fl32 af77 xlf90 f90 pgf90 pghpf epcf90 gfortran g95 xlf95 f95 fort ifort ifc efc pgf95 lf95 ftn
+ for ac_prog in g77 xlf f77 frt pgf77 cf77 fort77 fl32 af77 xlf90 f90 pgf90 pghpf epcf90 gfortran g95 xlf95 f95 fort ifort ifc efc pgfortran pgf95 lf95 ftn nagfor
do
-{ echo "$as_me:$LINENO: checking for $ac_word" >&5
-echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6; }
-if test "${ac_cv_prog_F77+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $ac_word" >&5
+$as_echo_n "checking for $ac_word... " >&6; }
+if ${ac_cv_prog_F77+:} false; then :
else
if test -n "$F77"; then
ac_cv_prog_F77="$F77" # Let the user override the test.
@@ -6538,25 +6594,25 @@
do
IFS=$as_save_IFS
test -z "$as_dir" && as_dir=.
- for ac_exec_ext in '' $ac_executable_extensions; do
- if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then
+ for ac_exec_ext in '' $ac_executable_extensions; do
+ if as_fn_executable_p "$as_dir/$ac_word$ac_exec_ext"; then
ac_cv_prog_F77="$ac_tool_prefix$ac_prog"
- echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5
+ $as_echo "$as_me:${as_lineno-$LINENO}: found $as_dir/$ac_word$ac_exec_ext" >&5
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
F77=$ac_cv_prog_F77
- { echo "$as_me:$LINENO: result: $F77" >&5
-echo "${ECHO_T}$F77" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $F77" >&5
+$as_echo "$F77" >&6; }
else
fi
@@ -6565,14 +6621,14 @@
fi
if test -z "$F77"; then
ac_ct_F77=$F77
do
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-if test "${ac_cv_prog_ac_ct_F77+set}" = set; then
+if ${ac_cv_prog_ac_ct_F77+:} false; then :
else
if test -n "$ac_ct_F77"; then
ac_cv_prog_ac_ct_F77="$ac_ct_F77" # Let the user override the test.
@@ -6582,25 +6638,25 @@
do
IFS=$as_save_IFS
ac_cv_prog_ac_ct_F77="$ac_prog"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
ac_ct_F77=$ac_cv_prog_ac_ct_F77
- { echo "$as_me:$LINENO: result: $ac_ct_F77" >&5
-echo "${ECHO_T}$ac_ct_F77" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_F77" >&5
+$as_echo "$ac_ct_F77" >&6; }
else
fi
@@ -6612,12 +6668,8 @@
else
case $cross_compiling:$ac_tool_warned in
yes:)
-{ echo "$as_me:$LINENO: WARNING: In the future, Autoconf will not detect cross-tools
-whose name does not start with the host triplet. If you think this
-configuration is useful to you, please write to autoconf at gnu.org." >&5
-echo "$as_me: WARNING: In the future, Autoconf will not detect cross-tools
-configuration is useful to you, please write to autoconf at gnu.org." >&2;}
+{ $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: using cross tools not prefixed with host triplet" >&5
+$as_echo "$as_me: WARNING: using cross tools not prefixed with host triplet" >&2;}
ac_tool_warned=yes ;;
esac
F77=$ac_ct_F77
@@ -6626,50 +6678,41 @@
-echo "$as_me:$LINENO: checking for Fortran 77 compiler version" >&5
+$as_echo "$as_me:${as_lineno-$LINENO}: checking for Fortran 77 compiler version" >&5
+set X $ac_compile
+ac_compiler=$2
case "(($ac_try" in
esac
ac_status=$?
-esac
- ac_status=$?
-esac
- ac_status=$?
+ sed '10a\
+ fi
+done
rm -f a.out
# If we don't use `.F' as extension, the preprocessor is not run on the
# input file. (Note that this only needs to work for GNU compilers.)
ac_save_ext=$ac_ext
ac_ext=F
-{ echo "$as_me:$LINENO: checking whether we are using the GNU Fortran 77 compiler" >&5
-echo $ECHO_N "checking whether we are using the GNU Fortran 77 compiler... $ECHO_C" >&6; }
-if test "${ac_cv_f77_compiler_gnu+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether we are using the GNU Fortran 77 compiler" >&5
+$as_echo_n "checking whether we are using the GNU Fortran 77 compiler... " >&6; }
+if ${ac_cv_f77_compiler_gnu+:} false; then :
else
+ cat > conftest.$ac_ext <<_ACEOF
program main
#ifndef __GNUC__
choke me
@@ -6677,82 +6720,42 @@
end
_ACEOF
-esac
- ac_status=$?
- test -z "$ac_f77_werror_flag" ||
+if ac_fn_f77_try_compile "$LINENO"; then :
ac_compiler_gnu=yes
else
fi
ac_cv_f77_compiler_gnu=$ac_compiler_gnu
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_f77_compiler_gnu" >&5
-echo "${ECHO_T}$ac_cv_f77_compiler_gnu" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_f77_compiler_gnu" >&5
+$as_echo "$ac_cv_f77_compiler_gnu" >&6; }
ac_ext=$ac_save_ext
ac_test_FFLAGS=${FFLAGS+set}
ac_save_FFLAGS=$FFLAGS
FFLAGS=
-{ echo "$as_me:$LINENO: checking whether $F77 accepts -g" >&5
-echo $ECHO_N "checking whether $F77 accepts -g... $ECHO_C" >&6; }
-if test "${ac_cv_prog_f77_g+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether $F77 accepts -g" >&5
+$as_echo_n "checking whether $F77 accepts -g... " >&6; }
+if ${ac_cv_prog_f77_g+:} false; then :
else
FFLAGS=-g
+cat > conftest.$ac_ext <<_ACEOF
program main
end
_ACEOF
-esac
- ac_status=$?
ac_cv_prog_f77_g=yes
else
- ac_cv_prog_f77_g=no
+ ac_cv_prog_f77_g=no
fi
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_prog_f77_g" >&5
-echo "${ECHO_T}$ac_cv_prog_f77_g" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_prog_f77_g" >&5
+$as_echo "$ac_cv_prog_f77_g" >&6; }
if test "$ac_test_FFLAGS" = set; then
FFLAGS=$ac_save_FFLAGS
elif test $ac_cv_prog_f77_g = yes; then
@@ -6769,7 +6772,11 @@
fi
fi
-G77=`test $ac_compiler_gnu = yes && echo yes`
+ G77=yes
+else
+ G77=
+fi
ac_ext=c
@@ -6780,10 +6787,10 @@
# Autoconf 2.13's AC_OBJEXT and AC_EXEEXT macros only works for C compilers!
# find the maximum length of command line arguments
-{ echo "$as_me:$LINENO: checking the maximum length of command line arguments" >&5
-echo $ECHO_N "checking the maximum length of command line arguments... $ECHO_C" >&6; }
-if test "${lt_cv_sys_max_cmd_len+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking the maximum length of command line arguments" >&5
+$as_echo_n "checking the maximum length of command line arguments... " >&6; }
+if ${lt_cv_sys_max_cmd_len+:} false; then :
else
i=0
teststring="ABCD"
@@ -6892,11 +6899,11 @@
fi
if test -n $lt_cv_sys_max_cmd_len ; then
- { echo "$as_me:$LINENO: result: $lt_cv_sys_max_cmd_len" >&5
-echo "${ECHO_T}$lt_cv_sys_max_cmd_len" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_sys_max_cmd_len" >&5
+$as_echo "$lt_cv_sys_max_cmd_len" >&6; }
else
- { echo "$as_me:$LINENO: result: none" >&5
-echo "${ECHO_T}none" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: none" >&5
+$as_echo "none" >&6; }
fi
@@ -6904,10 +6911,10 @@
# Check for command to grab the raw symbol name followed by C symbol from nm.
-{ echo "$as_me:$LINENO: checking command to parse $NM output from $compiler object" >&5
-echo $ECHO_N "checking command to parse $NM output from $compiler object... $ECHO_C" >&6; }
-if test "${lt_cv_sys_global_symbol_pipe+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking command to parse $NM output from $compiler object" >&5
+$as_echo_n "checking command to parse $NM output from $compiler object... " >&6; }
+if ${lt_cv_sys_global_symbol_pipe+:} false; then :
else
# These are sane defaults that work on at least a few old systems.
@@ -7009,18 +7016,18 @@
int main(){nm_test_var='a';nm_test_func();return(0);}
EOF
ac_status=$?
# Now try to grab the symbols.
nlist=conftest.nm
- if { (eval echo "$as_me:$LINENO: \"$NM conftest.$ac_objext \| $lt_cv_sys_global_symbol_pipe \> $nlist\"") >&5
+ if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$NM conftest.$ac_objext \| $lt_cv_sys_global_symbol_pipe \> $nlist\""; } >&5
(eval $NM conftest.$ac_objext \| $lt_cv_sys_global_symbol_pipe \> $nlist) 2>&5
ac_status=$?
- (exit $ac_status); } && test -s "$nlist"; then
+ test $ac_status = 0; } && test -s "$nlist"; then
# Try sorting and uniquifying the output.
if sort "$nlist" | uniq > "$nlist"T; then
mv -f "$nlist"T "$nlist"
@@ -7071,11 +7078,11 @@
lt_save_CFLAGS="$CFLAGS"
LIBS="conftstm.$ac_objext"
CFLAGS="$CFLAGS$lt_prog_compiler_no_builtin_flag"
- if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+ if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$ac_link\""; } >&5
(eval $ac_link) 2>&5
ac_status=$?
- (exit $ac_status); } && test -s conftest${ac_exeext}; then
+ test $ac_status = 0; } && test -s conftest${ac_exeext}; then
pipe_works=yes
fi
LIBS="$lt_save_LIBS"
@@ -7109,17 +7116,17 @@
lt_cv_sys_global_symbol_to_cdecl=
fi
if test -z "$lt_cv_sys_global_symbol_pipe$lt_cv_sys_global_symbol_to_cdecl"; then
- { echo "$as_me:$LINENO: result: failed" >&5
-echo "${ECHO_T}failed" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: failed" >&5
+$as_echo "failed" >&6; }
else
- { echo "$as_me:$LINENO: result: ok" >&5
-echo "${ECHO_T}ok" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: ok" >&5
+$as_echo "ok" >&6; }
fi
-{ echo "$as_me:$LINENO: checking for objdir" >&5
-echo $ECHO_N "checking for objdir... $ECHO_C" >&6; }
-if test "${lt_cv_objdir+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for objdir" >&5
+$as_echo_n "checking for objdir... " >&6; }
+if ${lt_cv_objdir+:} false; then :
else
rm -f .libs 2>/dev/null
mkdir .libs 2>/dev/null
@@ -7131,8 +7138,8 @@
fi
rmdir .libs 2>/dev/null
fi
-{ echo "$as_me:$LINENO: result: $lt_cv_objdir" >&5
-echo "${ECHO_T}$lt_cv_objdir" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_objdir" >&5
+$as_echo "$lt_cv_objdir" >&6; }
objdir=$lt_cv_objdir
@@ -7183,10 +7190,10 @@
# Extract the first word of "${ac_tool_prefix}ar", so it can be a program name with args.
set dummy ${ac_tool_prefix}ar; ac_word=$2
-if test "${ac_cv_prog_AR+set}" = set; then
+if ${ac_cv_prog_AR+:} false; then :
else
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -7196,25 +7203,25 @@
do
IFS=$as_save_IFS
ac_cv_prog_AR="${ac_tool_prefix}ar"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
AR=$ac_cv_prog_AR
- { echo "$as_me:$LINENO: result: $AR" >&5
-echo "${ECHO_T}$AR" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $AR" >&5
+$as_echo "$AR" >&6; }
else
fi
@@ -7223,10 +7230,10 @@
ac_ct_AR=$AR
# Extract the first word of "ar", so it can be a program name with args.
set dummy ar; ac_word=$2
-if test "${ac_cv_prog_ac_ct_AR+set}" = set; then
+if ${ac_cv_prog_ac_ct_AR+:} false; then :
else
if test -n "$ac_ct_AR"; then
ac_cv_prog_ac_ct_AR="$ac_ct_AR" # Let the user override the test.
@@ -7236,25 +7243,25 @@
do
IFS=$as_save_IFS
ac_cv_prog_ac_ct_AR="ar"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
ac_ct_AR=$ac_cv_prog_ac_ct_AR
- { echo "$as_me:$LINENO: result: $ac_ct_AR" >&5
-echo "${ECHO_T}$ac_ct_AR" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_AR" >&5
+$as_echo "$ac_ct_AR" >&6; }
else
fi
if test "x$ac_ct_AR" = x; then
@@ -7262,12 +7269,8 @@
else
yes:)
esac
AR=$ac_ct_AR
@@ -7279,10 +7282,10 @@
# Extract the first word of "${ac_tool_prefix}ranlib", so it can be a program name with args.
set dummy ${ac_tool_prefix}ranlib; ac_word=$2
-if test "${ac_cv_prog_RANLIB+set}" = set; then
+if ${ac_cv_prog_RANLIB+:} false; then :
else
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -7292,25 +7295,25 @@
do
IFS=$as_save_IFS
ac_cv_prog_RANLIB="${ac_tool_prefix}ranlib"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
RANLIB=$ac_cv_prog_RANLIB
- { echo "$as_me:$LINENO: result: $RANLIB" >&5
-echo "${ECHO_T}$RANLIB" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $RANLIB" >&5
+$as_echo "$RANLIB" >&6; }
else
fi
@@ -7319,10 +7322,10 @@
ac_ct_RANLIB=$RANLIB
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-if test "${ac_cv_prog_ac_ct_RANLIB+set}" = set; then
+if ${ac_cv_prog_ac_ct_RANLIB+:} false; then :
else
if test -n "$ac_ct_RANLIB"; then
ac_cv_prog_ac_ct_RANLIB="$ac_ct_RANLIB" # Let the user override the test.
@@ -7332,25 +7335,25 @@
do
IFS=$as_save_IFS
ac_cv_prog_ac_ct_RANLIB="ranlib"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
ac_ct_RANLIB=$ac_cv_prog_ac_ct_RANLIB
- { echo "$as_me:$LINENO: result: $ac_ct_RANLIB" >&5
-echo "${ECHO_T}$ac_ct_RANLIB" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_RANLIB" >&5
+$as_echo "$ac_ct_RANLIB" >&6; }
else
fi
if test "x$ac_ct_RANLIB" = x; then
@@ -7358,12 +7361,8 @@
else
yes:)
esac
RANLIB=$ac_ct_RANLIB
@@ -7375,10 +7374,10 @@
# Extract the first word of "${ac_tool_prefix}strip", so it can be a program name with args.
set dummy ${ac_tool_prefix}strip; ac_word=$2
-if test "${ac_cv_prog_STRIP+set}" = set; then
+if ${ac_cv_prog_STRIP+:} false; then :
else
if test -n "$STRIP"; then
ac_cv_prog_STRIP="$STRIP" # Let the user override the test.
@@ -7388,25 +7387,25 @@
do
IFS=$as_save_IFS
ac_cv_prog_STRIP="${ac_tool_prefix}strip"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
STRIP=$ac_cv_prog_STRIP
- { echo "$as_me:$LINENO: result: $STRIP" >&5
-echo "${ECHO_T}$STRIP" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $STRIP" >&5
+$as_echo "$STRIP" >&6; }
else
fi
@@ -7415,10 +7414,10 @@
ac_ct_STRIP=$STRIP
# Extract the first word of "strip", so it can be a program name with args.
set dummy strip; ac_word=$2
-if test "${ac_cv_prog_ac_ct_STRIP+set}" = set; then
+if ${ac_cv_prog_ac_ct_STRIP+:} false; then :
else
if test -n "$ac_ct_STRIP"; then
ac_cv_prog_ac_ct_STRIP="$ac_ct_STRIP" # Let the user override the test.
@@ -7428,25 +7427,25 @@
do
IFS=$as_save_IFS
ac_cv_prog_ac_ct_STRIP="strip"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
ac_ct_STRIP=$ac_cv_prog_ac_ct_STRIP
- { echo "$as_me:$LINENO: result: $ac_ct_STRIP" >&5
-echo "${ECHO_T}$ac_ct_STRIP" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_STRIP" >&5
+$as_echo "$ac_ct_STRIP" >&6; }
else
fi
if test "x$ac_ct_STRIP" = x; then
@@ -7454,12 +7453,8 @@
else
yes:)
esac
STRIP=$ac_ct_STRIP
@@ -7522,10 +7517,10 @@
case $deplibs_check_method in
file_magic*)
if test "$file_magic_cmd" = '$MAGIC_CMD'; then
- { echo "$as_me:$LINENO: checking for ${ac_tool_prefix}file" >&5
-echo $ECHO_N "checking for ${ac_tool_prefix}file... $ECHO_C" >&6; }
-if test "${lt_cv_path_MAGIC_CMD+set}" = set; then
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking for ${ac_tool_prefix}file" >&5
+$as_echo_n "checking for ${ac_tool_prefix}file... " >&6; }
+if ${lt_cv_path_MAGIC_CMD+:} false; then :
else
case $MAGIC_CMD in
@@ -7575,19 +7570,19 @@
MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
if test -n "$MAGIC_CMD"; then
- { echo "$as_me:$LINENO: result: $MAGIC_CMD" >&5
-echo "${ECHO_T}$MAGIC_CMD" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $MAGIC_CMD" >&5
+$as_echo "$MAGIC_CMD" >&6; }
else
fi
if test -z "$lt_cv_path_MAGIC_CMD"; then
- { echo "$as_me:$LINENO: checking for file" >&5
-echo $ECHO_N "checking for file... $ECHO_C" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking for file" >&5
+$as_echo_n "checking for file... " >&6; }
else
case $MAGIC_CMD in
@@ -7637,11 +7632,11 @@
else
fi
else
@@ -7659,10 +7654,10 @@
# Extract the first word of "${ac_tool_prefix}dsymutil", so it can be a program name with args.
set dummy ${ac_tool_prefix}dsymutil; ac_word=$2
-if test "${ac_cv_prog_DSYMUTIL+set}" = set; then
+if ${ac_cv_prog_DSYMUTIL+:} false; then :
else
if test -n "$DSYMUTIL"; then
ac_cv_prog_DSYMUTIL="$DSYMUTIL" # Let the user override the test.
@@ -7672,25 +7667,25 @@
do
IFS=$as_save_IFS
ac_cv_prog_DSYMUTIL="${ac_tool_prefix}dsymutil"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
DSYMUTIL=$ac_cv_prog_DSYMUTIL
- { echo "$as_me:$LINENO: result: $DSYMUTIL" >&5
-echo "${ECHO_T}$DSYMUTIL" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $DSYMUTIL" >&5
+$as_echo "$DSYMUTIL" >&6; }
else
fi
@@ -7699,10 +7694,10 @@
ac_ct_DSYMUTIL=$DSYMUTIL
# Extract the first word of "dsymutil", so it can be a program name with args.
set dummy dsymutil; ac_word=$2
-if test "${ac_cv_prog_ac_ct_DSYMUTIL+set}" = set; then
+if ${ac_cv_prog_ac_ct_DSYMUTIL+:} false; then :
else
if test -n "$ac_ct_DSYMUTIL"; then
ac_cv_prog_ac_ct_DSYMUTIL="$ac_ct_DSYMUTIL" # Let the user override the test.
@@ -7712,25 +7707,25 @@
do
IFS=$as_save_IFS
ac_cv_prog_ac_ct_DSYMUTIL="dsymutil"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
ac_ct_DSYMUTIL=$ac_cv_prog_ac_ct_DSYMUTIL
- { echo "$as_me:$LINENO: result: $ac_ct_DSYMUTIL" >&5
-echo "${ECHO_T}$ac_ct_DSYMUTIL" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_DSYMUTIL" >&5
+$as_echo "$ac_ct_DSYMUTIL" >&6; }
else
fi
if test "x$ac_ct_DSYMUTIL" = x; then
@@ -7738,12 +7733,8 @@
else
yes:)
esac
DSYMUTIL=$ac_ct_DSYMUTIL
@@ -7755,10 +7746,10 @@
# Extract the first word of "${ac_tool_prefix}nmedit", so it can be a program name with args.
set dummy ${ac_tool_prefix}nmedit; ac_word=$2
-if test "${ac_cv_prog_NMEDIT+set}" = set; then
+if ${ac_cv_prog_NMEDIT+:} false; then :
else
if test -n "$NMEDIT"; then
ac_cv_prog_NMEDIT="$NMEDIT" # Let the user override the test.
@@ -7768,25 +7759,25 @@
do
IFS=$as_save_IFS
ac_cv_prog_NMEDIT="${ac_tool_prefix}nmedit"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
NMEDIT=$ac_cv_prog_NMEDIT
- { echo "$as_me:$LINENO: result: $NMEDIT" >&5
-echo "${ECHO_T}$NMEDIT" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $NMEDIT" >&5
+$as_echo "$NMEDIT" >&6; }
else
fi
@@ -7795,10 +7786,10 @@
ac_ct_NMEDIT=$NMEDIT
# Extract the first word of "nmedit", so it can be a program name with args.
set dummy nmedit; ac_word=$2
-if test "${ac_cv_prog_ac_ct_NMEDIT+set}" = set; then
+if ${ac_cv_prog_ac_ct_NMEDIT+:} false; then :
else
if test -n "$ac_ct_NMEDIT"; then
ac_cv_prog_ac_ct_NMEDIT="$ac_ct_NMEDIT" # Let the user override the test.
@@ -7808,25 +7799,25 @@
do
IFS=$as_save_IFS
ac_cv_prog_ac_ct_NMEDIT="nmedit"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
ac_ct_NMEDIT=$ac_cv_prog_ac_ct_NMEDIT
- { echo "$as_me:$LINENO: result: $ac_ct_NMEDIT" >&5
-echo "${ECHO_T}$ac_ct_NMEDIT" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_NMEDIT" >&5
+$as_echo "$ac_ct_NMEDIT" >&6; }
else
fi
if test "x$ac_ct_NMEDIT" = x; then
@@ -7834,12 +7825,8 @@
else
yes:)
esac
NMEDIT=$ac_ct_NMEDIT
@@ -7849,10 +7836,10 @@
fi
- { echo "$as_me:$LINENO: checking for -single_module linker flag" >&5
-echo $ECHO_N "checking for -single_module linker flag... $ECHO_C" >&6; }
-if test "${lt_cv_apple_cc_single_mod+set}" = set; then
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking for -single_module linker flag" >&5
+$as_echo_n "checking for -single_module linker flag... " >&6; }
+if ${lt_cv_apple_cc_single_mod+:} false; then :
else
lt_cv_apple_cc_single_mod=no
if test -z "${LT_MULTI_MODULE}"; then
@@ -7870,22 +7857,18 @@
rm conftest.c
fi
fi
-{ echo "$as_me:$LINENO: result: $lt_cv_apple_cc_single_mod" >&5
-echo "${ECHO_T}$lt_cv_apple_cc_single_mod" >&6; }
- { echo "$as_me:$LINENO: checking for -exported_symbols_list linker flag" >&5
-echo $ECHO_N "checking for -exported_symbols_list linker flag... $ECHO_C" >&6; }
-if test "${lt_cv_ld_exported_symbols_list+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_apple_cc_single_mod" >&5
+$as_echo "$lt_cv_apple_cc_single_mod" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking for -exported_symbols_list linker flag" >&5
+$as_echo_n "checking for -exported_symbols_list linker flag... " >&6; }
+if ${lt_cv_ld_exported_symbols_list+:} false; then :
else
lt_cv_ld_exported_symbols_list=no
save_LDFLAGS=$LDFLAGS
echo "_main" > conftest.sym
LDFLAGS="$LDFLAGS -Wl,-exported_symbols_list,conftest.sym"
-/* confdefs.h. */
-_ACEOF
-cat confdefs.h >>conftest.$ac_ext
-cat >>conftest.$ac_ext <<_ACEOF
int
@@ -7896,39 +7879,18 @@
return 0;
_ACEOF
-if { (ac_try="$ac_link"
-case "(($ac_try" in
- *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
- *) ac_try_echo=$ac_try;;
-esac
-eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5
- ac_status=$?
- echo "$as_me:$LINENO: \$? = $ac_status" >&5
lt_cv_ld_exported_symbols_list=yes
else
- echo "$as_me: failed program was:" >&5
- lt_cv_ld_exported_symbols_list=no
+ lt_cv_ld_exported_symbols_list=no
fi
LDFLAGS="$save_LDFLAGS"
fi
-{ echo "$as_me:$LINENO: result: $lt_cv_ld_exported_symbols_list" >&5
-echo "${ECHO_T}$lt_cv_ld_exported_symbols_list" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_ld_exported_symbols_list" >&5
+$as_echo "$lt_cv_ld_exported_symbols_list" >&6; }
case $host_os in
rhapsody* | darwin1.[0123])
_lt_dar_allow_undefined='${wl}-undefined ${wl}suppress' ;;
@@ -7969,7 +7931,7 @@
enable_win32_dll=no
fi
@@ -7977,7 +7939,7 @@
# Check whether --with-pic was given.
-if test "${with_pic+set}" = set; then
+if test "${with_pic+set}" = set; then :
withval=$with_pic; pic_mode="$withval"
else
pic_mode=default
@@ -8040,10 +8002,10 @@
lt_prog_compiler_no_builtin_flag=' -fno-builtin'
-{ echo "$as_me:$LINENO: checking if $compiler supports -fno-rtti -fno-exceptions" >&5
-echo $ECHO_N "checking if $compiler supports -fno-rtti -fno-exceptions... $ECHO_C" >&6; }
-if test "${lt_cv_prog_compiler_rtti_exceptions+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if $compiler supports -fno-rtti -fno-exceptions" >&5
+$as_echo_n "checking if $compiler supports -fno-rtti -fno-exceptions... " >&6; }
+if ${lt_cv_prog_compiler_rtti_exceptions+:} false; then :
else
lt_cv_prog_compiler_rtti_exceptions=no
ac_outfile=conftest.$ac_objext
@@ -8058,11 +8020,11 @@
-e 's:.*FLAGS}\{0,1\} :&$lt_compiler_flag :; t' \
-e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
-e 's:$: $lt_compiler_flag:'`
- (eval echo "\"\$as_me:8061: $lt_compile\"" >&5)
+ (eval echo "\"\$as_me:8023: $lt_compile\"" >&5)
(eval "$lt_compile" 2>conftest.err)
ac_status=$?
- echo "$as_me:8065: \$? = $ac_status" >&5
+ echo "$as_me:8027: \$? = $ac_status" >&5
if (exit $ac_status) && test -s "$ac_outfile"; then
# The compiler can only warn and ignore the option if not recognized
# So say no if there are warnings other than the usual output.
@@ -8075,8 +8037,8 @@
$rm conftest*
fi
-{ echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_rtti_exceptions" >&5
-echo "${ECHO_T}$lt_cv_prog_compiler_rtti_exceptions" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_rtti_exceptions" >&5
+$as_echo "$lt_cv_prog_compiler_rtti_exceptions" >&6; }
if test x"$lt_cv_prog_compiler_rtti_exceptions" = xyes; then
lt_prog_compiler_no_builtin_flag="$lt_prog_compiler_no_builtin_flag -fno-rtti -fno-exceptions"
@@ -8090,8 +8052,8 @@
lt_prog_compiler_pic=
lt_prog_compiler_static=
-{ echo "$as_me:$LINENO: checking for $compiler option to produce PIC" >&5
-echo $ECHO_N "checking for $compiler option to produce PIC... $ECHO_C" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $compiler option to produce PIC" >&5
+$as_echo_n "checking for $compiler option to produce PIC... " >&6; }
lt_prog_compiler_wl='-Wl,'
@@ -8322,18 +8284,18 @@
esac
fi
-{ echo "$as_me:$LINENO: result: $lt_prog_compiler_pic" >&5
-echo "${ECHO_T}$lt_prog_compiler_pic" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_prog_compiler_pic" >&5
+$as_echo "$lt_prog_compiler_pic" >&6; }
# Check to make sure the PIC flag actually works.
if test -n "$lt_prog_compiler_pic"; then
-{ echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic works" >&5
-echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic works... $ECHO_C" >&6; }
-if test "${lt_cv_prog_compiler_pic_works+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if $compiler PIC flag $lt_prog_compiler_pic works" >&5
+$as_echo_n "checking if $compiler PIC flag $lt_prog_compiler_pic works... " >&6; }
+if ${lt_cv_prog_compiler_pic_works+:} false; then :
+ $as_echo_n "(cached) " >&6
else
lt_cv_prog_compiler_pic_works=no
@@ -8348,11 +8310,11 @@
- (eval echo "\"\$as_me:8351: $lt_compile\"" >&5)
+ (eval echo "\"\$as_me:8313: $lt_compile\"" >&5)
ac_status=$?
- echo "$as_me:8355: \$? = $ac_status" >&5
+ echo "$as_me:8317: \$? = $ac_status" >&5
@@ -8365,8 +8327,8 @@
$rm conftest*
fi
-{ echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_pic_works" >&5
-echo "${ECHO_T}$lt_cv_prog_compiler_pic_works" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_pic_works" >&5
+$as_echo "$lt_cv_prog_compiler_pic_works" >&6; }
if test x"$lt_cv_prog_compiler_pic_works" = xyes; then
case $lt_prog_compiler_pic in
@@ -8393,10 +8355,10 @@
# Check to make sure the static flag actually works.
wl=$lt_prog_compiler_wl eval lt_tmp_static_flag=\"$lt_prog_compiler_static\"
-{ echo "$as_me:$LINENO: checking if $compiler static flag $lt_tmp_static_flag works" >&5
-echo $ECHO_N "checking if $compiler static flag $lt_tmp_static_flag works... $ECHO_C" >&6; }
-if test "${lt_cv_prog_compiler_static_works+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if $compiler static flag $lt_tmp_static_flag works" >&5
+$as_echo_n "checking if $compiler static flag $lt_tmp_static_flag works... " >&6; }
+if ${lt_cv_prog_compiler_static_works+:} false; then :
else
lt_cv_prog_compiler_static_works=no
save_LDFLAGS="$LDFLAGS"
@@ -8421,8 +8383,8 @@
fi
-{ echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_static_works" >&5
-echo "${ECHO_T}$lt_cv_prog_compiler_static_works" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_static_works" >&5
+$as_echo "$lt_cv_prog_compiler_static_works" >&6; }
if test x"$lt_cv_prog_compiler_static_works" = xyes; then
@@ -8431,10 +8393,10 @@
fi
-{ echo "$as_me:$LINENO: checking if $compiler supports -c -o file.$ac_objext" >&5
-echo $ECHO_N "checking if $compiler supports -c -o file.$ac_objext... $ECHO_C" >&6; }
-if test "${lt_cv_prog_compiler_c_o+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if $compiler supports -c -o file.$ac_objext" >&5
+$as_echo_n "checking if $compiler supports -c -o file.$ac_objext... " >&6; }
+if ${lt_cv_prog_compiler_c_o+:} false; then :
else
lt_cv_prog_compiler_c_o=no
$rm -r conftest 2>/dev/null
@@ -8452,11 +8414,11 @@
- (eval echo "\"\$as_me:8455: $lt_compile\"" >&5)
+ (eval echo "\"\$as_me:8417: $lt_compile\"" >&5)
(eval "$lt_compile" 2>out/conftest.err)
ac_status=$?
cat out/conftest.err >&5
- echo "$as_me:8459: \$? = $ac_status" >&5
+ echo "$as_me:8421: \$? = $ac_status" >&5
if (exit $ac_status) && test -s out/conftest2.$ac_objext
then
@@ -8478,34 +8440,34 @@
$rm conftest*
fi
-{ echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o" >&5
-echo "${ECHO_T}$lt_cv_prog_compiler_c_o" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_c_o" >&5
+$as_echo "$lt_cv_prog_compiler_c_o" >&6; }
hard_links="nottested"
if test "$lt_cv_prog_compiler_c_o" = no && test "$need_locks" != no; then
# do not overwrite the value of need_locks provided by the user
- { echo "$as_me:$LINENO: checking if we can lock with hard links" >&5
-echo $ECHO_N "checking if we can lock with hard links... $ECHO_C" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking if we can lock with hard links" >&5
+$as_echo_n "checking if we can lock with hard links... " >&6; }
hard_links=yes
$rm conftest*
ln conftest.a conftest.b 2>/dev/null && hard_links=no
touch conftest.a
ln conftest.a conftest.b 2>&5 || hard_links=no
- { echo "$as_me:$LINENO: result: $hard_links" >&5
-echo "${ECHO_T}$hard_links" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $hard_links" >&5
+$as_echo "$hard_links" >&6; }
if test "$hard_links" = no; then
- { echo "$as_me:$LINENO: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
-echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
+$as_echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
need_locks=warn
fi
else
need_locks=no
fi
-{ echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
-echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the $compiler linker ($LD) supports shared libraries" >&5
+$as_echo_n "checking whether the $compiler linker ($LD) supports shared libraries... " >&6; }
runpath_var=
allow_undefined_flag=
@@ -8915,11 +8877,7 @@
# -berok will link without error, but may produce a broken library.
allow_undefined_flag='-berok'
# Determine the default libpath from the value encoded in an empty executable.
- cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h. */
-_ACEOF
+ cat confdefs.h - <<_ACEOF >conftest.$ac_ext
int
@@ -8930,24 +8888,7 @@
return 0;
_ACEOF
-esac
- ac_status=$?
- grep -v '^ *+' conftest.er1 >conftest.err
- rm -f conftest.er1
- cat conftest.err >&5
- test -z "$ac_c_werror_flag" ||
- test ! -s conftest.err
lt_aix_libpath_sed='
/Import File Strings/,/^$/ {
@@ -8961,15 +8902,9 @@
if test -z "$aix_libpath"; then
aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e "$lt_aix_libpath_sed"`
fi
-else
-sed 's/^/| /' conftest.$ac_ext >&5
fi
if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
hardcode_libdir_flag_spec='${wl}-blibpath:$libdir:'"$aix_libpath"
@@ -8981,11 +8916,7 @@
archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
else
-/* confdefs.h. */
-_ACEOF
int
@@ -8996,24 +8927,7 @@
return 0;
_ACEOF
-esac
- ac_status=$?
@@ -9027,15 +8941,9 @@
fi
-else
fi
@@ -9485,8 +9393,8 @@
esac
fi
-{ echo "$as_me:$LINENO: result: $ld_shlibs" >&5
-echo "${ECHO_T}$ld_shlibs" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ld_shlibs" >&5
+$as_echo "$ld_shlibs" >&6; }
test "$ld_shlibs" = no && can_build_shared=no
@@ -9506,16 +9414,16 @@
# Test whether the compiler implicitly links with -lc since on some
# systems, -lgcc has to come before -lc. If gcc already passes -lc
# to ld, don't add -lc before -lgcc.
- { echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
-echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether -lc should be explicitly linked in" >&5
+$as_echo_n "checking whether -lc should be explicitly linked in... " >&6; }
$rm conftest*
echo "$lt_simple_compile_test_code" > conftest.$ac_ext
ac_status=$?
- (exit $ac_status); } 2>conftest.err; then
+ $as_echo "$as_me:${as_lineno-$LINENO}: \$? = $ac_status" >&5
+ test $ac_status = 0; } 2>conftest.err; then
soname=conftest
lib=conftest
libobjs=conftest.$ac_objext
@@ -9529,11 +9437,11 @@
libname=conftest
lt_save_allow_undefined_flag=$allow_undefined_flag
- if { (eval echo "$as_me:$LINENO: \"$archive_cmds 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
+ if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$archive_cmds 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\""; } >&5
(eval $archive_cmds 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
ac_status=$?
then
archive_cmds_need_lc=no
else
@@ -9544,16 +9452,16 @@
cat conftest.err 1>&5
fi
$rm conftest*
- { echo "$as_me:$LINENO: result: $archive_cmds_need_lc" >&5
-echo "${ECHO_T}$archive_cmds_need_lc" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $archive_cmds_need_lc" >&5
+$as_echo "$archive_cmds_need_lc" >&6; }
esac
fi
esac
-{ echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
-echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking dynamic linker characteristics" >&5
+$as_echo_n "checking dynamic linker characteristics... " >&6; }
library_names_spec=
libname_spec='lib$name'
soname_spec=
@@ -10166,19 +10074,19 @@
dynamic_linker=no
esac
-{ echo "$as_me:$LINENO: result: $dynamic_linker" >&5
-echo "${ECHO_T}$dynamic_linker" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $dynamic_linker" >&5
+$as_echo "$dynamic_linker" >&6; }
test "$dynamic_linker" = no && can_build_shared=no
-if test "${lt_cv_sys_lib_search_path_spec+set}" = set; then
+if ${lt_cv_sys_lib_search_path_spec+:} false; then :
else
lt_cv_sys_lib_search_path_spec="$sys_lib_search_path_spec"
fi
sys_lib_search_path_spec="$lt_cv_sys_lib_search_path_spec"
-if test "${lt_cv_sys_lib_dlsearch_path_spec+set}" = set; then
+if ${lt_cv_sys_lib_dlsearch_path_spec+:} false; then :
else
lt_cv_sys_lib_dlsearch_path_spec="$sys_lib_dlsearch_path_spec"
fi
@@ -10190,8 +10098,8 @@
variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
fi
-{ echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
-echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking how to hardcode library paths into programs" >&5
+$as_echo_n "checking how to hardcode library paths into programs... " >&6; }
hardcode_action=
if test -n "$hardcode_libdir_flag_spec" || \
test -n "$runpath_var" || \
@@ -10215,8 +10123,8 @@
# directories.
hardcode_action=unsupported
fi
-{ echo "$as_me:$LINENO: result: $hardcode_action" >&5
-echo "${ECHO_T}$hardcode_action" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $hardcode_action" >&5
+$as_echo "$hardcode_action" >&6; }
if test "$hardcode_action" = relink; then
# Fast installation is not supported
@@ -10229,13 +10137,13 @@
striplib=
old_striplib=
-{ echo "$as_me:$LINENO: checking whether stripping libraries is possible" >&5
-echo $ECHO_N "checking whether stripping libraries is possible... $ECHO_C" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether stripping libraries is possible" >&5
+$as_echo_n "checking whether stripping libraries is possible... " >&6; }
if test -n "$STRIP" && $STRIP -V 2>&1 | grep "GNU strip" >/dev/null; then
test -z "$old_striplib" && old_striplib="$STRIP --strip-debug"
test -z "$striplib" && striplib="$STRIP --strip-unneeded"
else
# FIXME - insert some real tests, host_os isn't really good enough
case $host_os in
@@ -10243,16 +10151,16 @@
if test -n "$STRIP" ; then
striplib="$STRIP -x"
old_striplib="$STRIP -S"
else
fi
esac
fi
@@ -10284,18 +10192,14 @@
darwin*)
# if libdl is installed we need to link against it
- { echo "$as_me:$LINENO: checking for dlopen in -ldl" >&5
-echo $ECHO_N "checking for dlopen in -ldl... $ECHO_C" >&6; }
-if test "${ac_cv_lib_dl_dlopen+set}" = set; then
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking for dlopen in -ldl" >&5
+$as_echo_n "checking for dlopen in -ldl... " >&6; }
+if ${ac_cv_lib_dl_dlopen+:} false; then :
else
ac_check_lib_save_LIBS=$LIBS
LIBS="-ldl $LIBS"
-cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h. */
-_ACEOF
+cat confdefs.h - <<_ACEOF >conftest.$ac_ext
/* Override any GCC internal prototype to avoid an error.
@@ -10313,39 +10217,18 @@
return 0;
_ACEOF
-esac
- ac_status=$?
ac_cv_lib_dl_dlopen=yes
else
- ac_cv_lib_dl_dlopen=no
+ ac_cv_lib_dl_dlopen=no
fi
LIBS=$ac_check_lib_save_LIBS
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_lib_dl_dlopen" >&5
-echo "${ECHO_T}$ac_cv_lib_dl_dlopen" >&6; }
-if test $ac_cv_lib_dl_dlopen = yes; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_dl_dlopen" >&5
+$as_echo "$ac_cv_lib_dl_dlopen" >&6; }
+if test "x$ac_cv_lib_dl_dlopen" = xyes; then :
lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-ldl"
else
@@ -10358,102 +10241,18 @@
- { echo "$as_me:$LINENO: checking for shl_load" >&5
-echo $ECHO_N "checking for shl_load... $ECHO_C" >&6; }
-if test "${ac_cv_func_shl_load+set}" = set; then
- echo $ECHO_N "(cached) $ECHO_C" >&6
-else
-/* confdefs.h. */
-_ACEOF
-/* Define shl_load to an innocuous variant, in case <limits.h> declares shl_load.
- For example, HP-UX 11i <limits.h> declares gettimeofday. */
-#define shl_load innocuous_shl_load
-/* System header to define __stub macros and hopefully few prototypes,
- which can conflict with char shl_load (); below.
- Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
- <limits.h> exists even on freestanding compilers. */
-#ifdef __STDC__
-# include <limits.h>
-#else
-# include <assert.h>
-#endif
-#undef shl_load
-/* Override any GCC internal prototype to avoid an error.
- Use char because int might match the return type of a GCC
- builtin and then its argument prototype would still apply. */
-#ifdef __cplusplus
-extern "C"
-#endif
-char shl_load ();
-/* The GNU C library defines this for functions which it implements
- to always fail with ENOSYS. Some functions are actually named
- something starting with __ and the normal name is an alias. */
-#if defined __stub_shl_load || defined __stub___shl_load
-choke me
-#endif
-int
-main ()
-return shl_load ();
- return 0;
-_ACEOF
-esac
- ac_status=$?
- ac_cv_func_shl_load=yes
-else
- ac_cv_func_shl_load=no
-fi
-fi
-{ echo "$as_me:$LINENO: result: $ac_cv_func_shl_load" >&5
-echo "${ECHO_T}$ac_cv_func_shl_load" >&6; }
-if test $ac_cv_func_shl_load = yes; then
+ ac_fn_c_check_func "$LINENO" "shl_load" "ac_cv_func_shl_load"
+if test "x$ac_cv_func_shl_load" = xyes; then :
lt_cv_dlopen="shl_load"
else
- { echo "$as_me:$LINENO: checking for shl_load in -ldld" >&5
-echo $ECHO_N "checking for shl_load in -ldld... $ECHO_C" >&6; }
-if test "${ac_cv_lib_dld_shl_load+set}" = set; then
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking for shl_load in -ldld" >&5
+$as_echo_n "checking for shl_load in -ldld... " >&6; }
+if ${ac_cv_lib_dld_shl_load+:} false; then :
else
LIBS="-ldld $LIBS"
-/* confdefs.h. */
-_ACEOF
@@ -10471,137 +10270,32 @@
return 0;
_ACEOF
-esac
- ac_status=$?
ac_cv_lib_dld_shl_load=yes
else
- ac_cv_lib_dld_shl_load=no
+ ac_cv_lib_dld_shl_load=no
fi
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_lib_dld_shl_load" >&5
-echo "${ECHO_T}$ac_cv_lib_dld_shl_load" >&6; }
-if test $ac_cv_lib_dld_shl_load = yes; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_dld_shl_load" >&5
+$as_echo "$ac_cv_lib_dld_shl_load" >&6; }
+if test "x$ac_cv_lib_dld_shl_load" = xyes; then :
lt_cv_dlopen="shl_load" lt_cv_dlopen_libs="-ldld"
else
- { echo "$as_me:$LINENO: checking for dlopen" >&5
-echo $ECHO_N "checking for dlopen... $ECHO_C" >&6; }
-if test "${ac_cv_func_dlopen+set}" = set; then
-else
-/* confdefs.h. */
-_ACEOF
-/* Define dlopen to an innocuous variant, in case <limits.h> declares dlopen.
-#define dlopen innocuous_dlopen
- which can conflict with char dlopen (); below.
-#ifdef __STDC__
-#else
-#endif
-#undef dlopen
-#ifdef __cplusplus
-extern "C"
-#endif
-char dlopen ();
-#if defined __stub_dlopen || defined __stub___dlopen
-choke me
-#endif
-int
-main ()
-return dlopen ();
- return 0;
-_ACEOF
-esac
- ac_status=$?
- ac_cv_func_dlopen=yes
-else
- ac_cv_func_dlopen=no
-fi
-fi
-{ echo "$as_me:$LINENO: result: $ac_cv_func_dlopen" >&5
-echo "${ECHO_T}$ac_cv_func_dlopen" >&6; }
-if test $ac_cv_func_dlopen = yes; then
+ ac_fn_c_check_func "$LINENO" "dlopen" "ac_cv_func_dlopen"
+if test "x$ac_cv_func_dlopen" = xyes; then :
else
else
LIBS="-ldl $LIBS"
-/* confdefs.h. */
-_ACEOF
@@ -10619,53 +10313,28 @@
return 0;
_ACEOF
-esac
- ac_status=$?
else
fi
fi
else
- { echo "$as_me:$LINENO: checking for dlopen in -lsvld" >&5
-echo $ECHO_N "checking for dlopen in -lsvld... $ECHO_C" >&6; }
-if test "${ac_cv_lib_svld_dlopen+set}" = set; then
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking for dlopen in -lsvld" >&5
+$as_echo_n "checking for dlopen in -lsvld... " >&6; }
+if ${ac_cv_lib_svld_dlopen+:} false; then :
else
LIBS="-lsvld $LIBS"
-/* confdefs.h. */
-_ACEOF
@@ -10683,53 +10352,28 @@
return 0;
_ACEOF
-esac
- ac_status=$?
ac_cv_lib_svld_dlopen=yes
else
- ac_cv_lib_svld_dlopen=no
+ ac_cv_lib_svld_dlopen=no
fi
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_lib_svld_dlopen" >&5
-echo "${ECHO_T}$ac_cv_lib_svld_dlopen" >&6; }
-if test $ac_cv_lib_svld_dlopen = yes; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_svld_dlopen" >&5
+$as_echo "$ac_cv_lib_svld_dlopen" >&6; }
+if test "x$ac_cv_lib_svld_dlopen" = xyes; then :
lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-lsvld"
else
- { echo "$as_me:$LINENO: checking for dld_link in -ldld" >&5
-echo $ECHO_N "checking for dld_link in -ldld... $ECHO_C" >&6; }
-if test "${ac_cv_lib_dld_dld_link+set}" = set; then
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking for dld_link in -ldld" >&5
+$as_echo_n "checking for dld_link in -ldld... " >&6; }
+if ${ac_cv_lib_dld_dld_link+:} false; then :
else
LIBS="-ldld $LIBS"
-/* confdefs.h. */
-_ACEOF
@@ -10747,39 +10391,18 @@
return 0;
_ACEOF
-esac
- ac_status=$?
ac_cv_lib_dld_dld_link=yes
else
- ac_cv_lib_dld_dld_link=no
+ ac_cv_lib_dld_dld_link=no
fi
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_lib_dld_dld_link" >&5
-echo "${ECHO_T}$ac_cv_lib_dld_dld_link" >&6; }
-if test $ac_cv_lib_dld_dld_link = yes; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_dld_dld_link" >&5
+$as_echo "$ac_cv_lib_dld_dld_link" >&6; }
+if test "x$ac_cv_lib_dld_dld_link" = xyes; then :
lt_cv_dlopen="dld_link" lt_cv_dlopen_libs="-ldld"
fi
@@ -10818,10 +10441,10 @@
save_LIBS="$LIBS"
LIBS="$lt_cv_dlopen_libs $LIBS"
- { echo "$as_me:$LINENO: checking whether a program can dlopen itself" >&5
-echo $ECHO_N "checking whether a program can dlopen itself... $ECHO_C" >&6; }
-if test "${lt_cv_dlopen_self+set}" = set; then
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether a program can dlopen itself" >&5
+$as_echo_n "checking whether a program can dlopen itself... " >&6; }
+if ${lt_cv_dlopen_self+:} false; then :
else
lt_cv_dlopen_self=cross
@@ -10829,7 +10452,7 @@
lt_dlunknown=0; lt_dlno_uscore=1; lt_dlneed_uscore=2
lt_status=$lt_dlunknown
cat > conftest.$ac_ext <<EOF
-#line 10832 "configure"
+#line 10455 "configure"
#include "confdefs.h"
#if HAVE_DLFCN_H
@@ -10892,11 +10515,11 @@
exit (status);
EOF
ac_status=$?
- (exit $ac_status); } && test -s conftest${ac_exeext} 2>/dev/null; then
+ test $ac_status = 0; } && test -s conftest${ac_exeext} 2>/dev/null; then
(./conftest; exit; ) >&5 2>/dev/null
lt_status=$?
case x$lt_status in
@@ -10913,15 +10536,15 @@
fi
-{ echo "$as_me:$LINENO: result: $lt_cv_dlopen_self" >&5
-echo "${ECHO_T}$lt_cv_dlopen_self" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_dlopen_self" >&5
+$as_echo "$lt_cv_dlopen_self" >&6; }
if test "x$lt_cv_dlopen_self" = xyes; then
wl=$lt_prog_compiler_wl eval LDFLAGS=\"\$LDFLAGS $lt_prog_compiler_static\"
- { echo "$as_me:$LINENO: checking whether a statically linked program can dlopen itself" >&5
-echo $ECHO_N "checking whether a statically linked program can dlopen itself... $ECHO_C" >&6; }
-if test "${lt_cv_dlopen_self_static+set}" = set; then
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether a statically linked program can dlopen itself" >&5
+$as_echo_n "checking whether a statically linked program can dlopen itself... " >&6; }
+if ${lt_cv_dlopen_self_static+:} false; then :
else
lt_cv_dlopen_self_static=cross
@@ -10929,7 +10552,7 @@
-#line 10932 "configure"
+#line 10555 "configure"
#if HAVE_DLFCN_H
@@ -10992,11 +10615,11 @@
exit (status);
EOF
ac_status=$?
lt_status=$?
case x$lt_status in
@@ -11013,8 +10636,8 @@
fi
-{ echo "$as_me:$LINENO: result: $lt_cv_dlopen_self_static" >&5
-echo "${ECHO_T}$lt_cv_dlopen_self_static" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_dlopen_self_static" >&5
+$as_echo "$lt_cv_dlopen_self_static" >&6; }
fi
CPPFLAGS="$save_CPPFLAGS"
@@ -11036,13 +10659,13 @@
# Report which library types will actually be built
-{ echo "$as_me:$LINENO: checking if libtool supports shared libraries" >&5
-echo $ECHO_N "checking if libtool supports shared libraries... $ECHO_C" >&6; }
-{ echo "$as_me:$LINENO: result: $can_build_shared" >&5
-echo "${ECHO_T}$can_build_shared" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if libtool supports shared libraries" >&5
+$as_echo_n "checking if libtool supports shared libraries... " >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $can_build_shared" >&5
+$as_echo "$can_build_shared" >&6; }
-{ echo "$as_me:$LINENO: checking whether to build shared libraries" >&5
-echo $ECHO_N "checking whether to build shared libraries... $ECHO_C" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether to build shared libraries" >&5
+$as_echo_n "checking whether to build shared libraries... " >&6; }
test "$can_build_shared" = "no" && enable_shared=no
# On AIX, shared libraries and static libraries use the same namespace, and
@@ -11062,15 +10685,15 @@
fi
esac
-{ echo "$as_me:$LINENO: result: $enable_shared" >&5
-echo "${ECHO_T}$enable_shared" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $enable_shared" >&5
+$as_echo "$enable_shared" >&6; }
-{ echo "$as_me:$LINENO: checking whether to build static libraries" >&5
-echo $ECHO_N "checking whether to build static libraries... $ECHO_C" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether to build static libraries" >&5
+$as_echo_n "checking whether to build static libraries... " >&6; }
# Make sure either enable_shared or enable_static is yes.
test "$enable_shared" = yes || enable_static=yes
-{ echo "$as_me:$LINENO: result: $enable_static" >&5
-echo "${ECHO_T}$enable_static" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $enable_static" >&5
+$as_echo "$enable_static" >&6; }
# The else clause should only fire when bootstrapping the
# libtool distribution, otherwise you forgot to ship ltmain.sh
@@ -11163,8 +10786,8 @@
cfgfile="${ofile}T"
trap "$rm \"$cfgfile\"; exit 1" 1 2 15
$rm -f "$cfgfile"
- { echo "$as_me:$LINENO: creating $ofile" >&5
-echo "$as_me: creating $ofile" >&6;}
+ { $as_echo "$as_me:${as_lineno-$LINENO}: creating $ofile" >&5
+$as_echo "$as_me: creating $ofile" >&6;}
cat <<__EOF__ >> "$cfgfile"
#! $SHELL
@@ -11569,25 +11192,25 @@
# Check whether --with-tags was given.
-if test "${with_tags+set}" = set; then
+if test "${with_tags+set}" = set; then :
withval=$with_tags; tagnames="$withval"
fi
if test -f "$ltmain" && test -n "$tagnames"; then
if test ! -f "${ofile}"; then
- { echo "$as_me:$LINENO: WARNING: output file \`$ofile' does not exist" >&5
-echo "$as_me: WARNING: output file \`$ofile' does not exist" >&2;}
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: output file \`$ofile' does not exist" >&5
+$as_echo "$as_me: WARNING: output file \`$ofile' does not exist" >&2;}
fi
if test -z "$LTCC"; then
eval "`$SHELL ${ofile} --config | grep '^LTCC='`"
- { echo "$as_me:$LINENO: WARNING: output file \`$ofile' does not look like a libtool script" >&5
-echo "$as_me: WARNING: output file \`$ofile' does not look like a libtool script" >&2;}
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: output file \`$ofile' does not look like a libtool script" >&5
+$as_echo "$as_me: WARNING: output file \`$ofile' does not look like a libtool script" >&2;}
else
- { echo "$as_me:$LINENO: WARNING: using \`LTCC=$LTCC', extracted from \`$ofile'" >&5
-echo "$as_me: WARNING: using \`LTCC=$LTCC', extracted from \`$ofile'" >&2;}
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: using \`LTCC=$LTCC', extracted from \`$ofile'" >&5
+$as_echo "$as_me: WARNING: using \`LTCC=$LTCC', extracted from \`$ofile'" >&2;}
fi
fi
if test -z "$LTCFLAGS"; then
@@ -11604,17 +11227,13 @@
# Check whether tagname contains only valid characters
case `$echo "X$tagname" | $Xsed -e 's:[-_ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz1234567890,/]::g'` in
- *) { { echo "$as_me:$LINENO: error: invalid tag name: $tagname" >&5
-echo "$as_me: error: invalid tag name: $tagname" >&2;}
+ *) as_fn_error $? "invalid tag name: $tagname" "$LINENO" 5
esac
if grep "^# ### BEGIN LIBTOOL TAG CONFIG: $tagname$" < "${ofile}" > /dev/null
then
- { { echo "$as_me:$LINENO: error: tag name \"$tagname\" already exists" >&5
-echo "$as_me: error: tag name \"$tagname\" already exists" >&2;}
+ as_fn_error $? "tag name \"$tagname\" already exists" "$LINENO" 5
fi
# Update the list of available tags.
@@ -11747,7 +11366,7 @@
# Check whether --with-gnu-ld was given.
-if test "${with_gnu_ld+set}" = set; then
+if test "${with_gnu_ld+set}" = set; then :
withval=$with_gnu_ld; test "$withval" = no || with_gnu_ld=yes
else
with_gnu_ld=no
@@ -11756,8 +11375,8 @@
ac_prog=ld
if test "$GCC" = yes; then
# Check if gcc -print-prog-name=ld gives a path.
- { echo "$as_me:$LINENO: checking for ld used by $CC" >&5
-echo $ECHO_N "checking for ld used by $CC... $ECHO_C" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking for ld used by $CC" >&5
+$as_echo_n "checking for ld used by $CC... " >&6; }
case $host in
*-*-mingw*)
# gcc leaves a trailing carriage return which upsets mingw
@@ -11786,14 +11405,14 @@
esac
elif test "$with_gnu_ld" = yes; then
- { echo "$as_me:$LINENO: checking for GNU ld" >&5
-echo $ECHO_N "checking for GNU ld... $ECHO_C" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking for GNU ld" >&5
+$as_echo_n "checking for GNU ld... " >&6; }
else
- { echo "$as_me:$LINENO: checking for non-GNU ld" >&5
-echo $ECHO_N "checking for non-GNU ld... $ECHO_C" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking for non-GNU ld" >&5
+$as_echo_n "checking for non-GNU ld... " >&6; }
fi
-if test "${lt_cv_path_LD+set}" = set; then
+if ${lt_cv_path_LD+:} false; then :
else
if test -z "$LD"; then
lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
@@ -11823,19 +11442,17 @@
LD="$lt_cv_path_LD"
if test -n "$LD"; then
- { echo "$as_me:$LINENO: result: $LD" >&5
-echo "${ECHO_T}$LD" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $LD" >&5
+$as_echo "$LD" >&6; }
else
- { echo "$as_me:$LINENO: result: no" >&5
-echo "${ECHO_T}no" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
+$as_echo "no" >&6; }
fi
-test -z "$LD" && { { echo "$as_me:$LINENO: error: no acceptable ld found in \$PATH" >&5
-echo "$as_me: error: no acceptable ld found in \$PATH" >&2;}
-{ echo "$as_me:$LINENO: checking if the linker ($LD) is GNU ld" >&5
-echo $ECHO_N "checking if the linker ($LD) is GNU ld... $ECHO_C" >&6; }
-if test "${lt_cv_prog_gnu_ld+set}" = set; then
+test -z "$LD" && as_fn_error $? "no acceptable ld found in \$PATH" "$LINENO" 5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if the linker ($LD) is GNU ld" >&5
+$as_echo_n "checking if the linker ($LD) is GNU ld... " >&6; }
+if ${lt_cv_prog_gnu_ld+:} false; then :
else
# I'd rather use --version here, but apparently some GNU lds only accept -v.
case `$LD -v 2>&1 </dev/null` in
@@ -11847,8 +11464,8 @@
esac
fi
-{ echo "$as_me:$LINENO: result: $lt_cv_prog_gnu_ld" >&5
-echo "${ECHO_T}$lt_cv_prog_gnu_ld" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_gnu_ld" >&5
+$as_echo "$lt_cv_prog_gnu_ld" >&6; }
with_gnu_ld=$lt_cv_prog_gnu_ld
@@ -11898,8 +11515,8 @@
fi
# PORTME: fill in a description of your system's C++ link characteristics
ld_shlibs_CXX=yes
case $host_os in
aix3*)
@@ -11995,11 +11612,7 @@
allow_undefined_flag_CXX='-berok'
-/* confdefs.h. */
-_ACEOF
int
@@ -12010,24 +11623,7 @@
return 0;
_ACEOF
-rm -f conftest.$ac_objext conftest$ac_exeext
-esac
- (eval "$ac_link") 2>conftest.er1
- ac_status=$?
- test -z "$ac_cxx_werror_flag" ||
- } && test -s conftest$ac_exeext &&
- $as_test_x conftest$ac_exeext; then
+if ac_fn_cxx_try_link "$LINENO"; then :
@@ -12041,15 +11637,9 @@
fi
-else
fi
-rm -f core conftest.err conftest.$ac_objext conftest_ipa8_conftest.oo \
- conftest$ac_exeext conftest.$ac_ext
+rm -f core conftest.err conftest.$ac_objext \
+ conftest$ac_exeext conftest.$ac_ext
hardcode_libdir_flag_spec_CXX='${wl}-blibpath:$libdir:'"$aix_libpath"
@@ -12062,11 +11652,7 @@
archive_expsym_cmds_CXX="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
else
-/* confdefs.h. */
-_ACEOF
int
@@ -12077,24 +11663,7 @@
return 0;
_ACEOF
-esac
- ac_status=$?
@@ -12108,15 +11677,9 @@
fi
-else
fi
@@ -12844,8 +12407,8 @@
ld_shlibs_CXX=no
esac
-{ echo "$as_me:$LINENO: result: $ld_shlibs_CXX" >&5
-echo "${ECHO_T}$ld_shlibs_CXX" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ld_shlibs_CXX" >&5
+$as_echo "$ld_shlibs_CXX" >&6; }
test "$ld_shlibs_CXX" = no && can_build_shared=no
GCC_CXX="$GXX"
@@ -12861,11 +12424,11 @@
EOF
-if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$ac_compile\""; } >&5
(eval $ac_compile) 2>&5
ac_status=$?
- (exit $ac_status); }; then
+ test $ac_status = 0; }; then
# Parse the compiler output and extract the necessary
# objects, libraries and library flags.
@@ -13020,8 +12583,8 @@
lt_prog_compiler_pic_CXX=
lt_prog_compiler_static_CXX=
# C++ specific cases for pic, static, wl, etc.
if test "$GXX" = yes; then
@@ -13304,18 +12867,18 @@
esac
fi
-{ echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_CXX" >&5
-echo "${ECHO_T}$lt_prog_compiler_pic_CXX" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_prog_compiler_pic_CXX" >&5
+$as_echo "$lt_prog_compiler_pic_CXX" >&6; }
if test -n "$lt_prog_compiler_pic_CXX"; then
-{ echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic_CXX works" >&5
-echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic_CXX works... $ECHO_C" >&6; }
-if test "${lt_cv_prog_compiler_pic_works_CXX+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if $compiler PIC flag $lt_prog_compiler_pic_CXX works" >&5
+$as_echo_n "checking if $compiler PIC flag $lt_prog_compiler_pic_CXX works... " >&6; }
+if ${lt_cv_prog_compiler_pic_works_CXX+:} false; then :
else
lt_cv_prog_compiler_pic_works_CXX=no
@@ -13330,11 +12893,11 @@
- (eval echo "\"\$as_me:13333: $lt_compile\"" >&5)
+ (eval echo "\"\$as_me:12896: $lt_compile\"" >&5)
ac_status=$?
- echo "$as_me:13337: \$? = $ac_status" >&5
+ echo "$as_me:12900: \$? = $ac_status" >&5
@@ -13347,8 +12910,8 @@
$rm conftest*
fi
-{ echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_pic_works_CXX" >&5
-echo "${ECHO_T}$lt_cv_prog_compiler_pic_works_CXX" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_pic_works_CXX" >&5
+$as_echo "$lt_cv_prog_compiler_pic_works_CXX" >&6; }
if test x"$lt_cv_prog_compiler_pic_works_CXX" = xyes; then
case $lt_prog_compiler_pic_CXX in
@@ -13375,10 +12938,10 @@
wl=$lt_prog_compiler_wl_CXX eval lt_tmp_static_flag=\"$lt_prog_compiler_static_CXX\"
-if test "${lt_cv_prog_compiler_static_works_CXX+set}" = set; then
+if ${lt_cv_prog_compiler_static_works_CXX+:} false; then :
else
lt_cv_prog_compiler_static_works_CXX=no
@@ -13403,8 +12966,8 @@
fi
-{ echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_static_works_CXX" >&5
-echo "${ECHO_T}$lt_cv_prog_compiler_static_works_CXX" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_static_works_CXX" >&5
+$as_echo "$lt_cv_prog_compiler_static_works_CXX" >&6; }
if test x"$lt_cv_prog_compiler_static_works_CXX" = xyes; then
@@ -13413,10 +12976,10 @@
fi
-if test "${lt_cv_prog_compiler_c_o_CXX+set}" = set; then
+if ${lt_cv_prog_compiler_c_o_CXX+:} false; then :
else
lt_cv_prog_compiler_c_o_CXX=no
@@ -13434,11 +12997,11 @@
- (eval echo "\"\$as_me:13437: $lt_compile\"" >&5)
+ (eval echo "\"\$as_me:13000: $lt_compile\"" >&5)
ac_status=$?
- echo "$as_me:13441: \$? = $ac_status" >&5
+ echo "$as_me:13004: \$? = $ac_status" >&5
then
@@ -13460,34 +13023,34 @@
$rm conftest*
fi
-{ echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o_CXX" >&5
-echo "${ECHO_T}$lt_cv_prog_compiler_c_o_CXX" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_c_o_CXX" >&5
+$as_echo "$lt_cv_prog_compiler_c_o_CXX" >&6; }
if test "$lt_cv_prog_compiler_c_o_CXX" = no && test "$need_locks" != no; then
hard_links=yes
$rm conftest*
touch conftest.a
need_locks=warn
fi
else
need_locks=no
fi
export_symbols_cmds_CXX='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
case $host_os in
@@ -13515,8 +13078,8 @@
esac
exclude_expsyms_CXX='_GLOBAL_OFFSET_TABLE_|_GLOBAL__F[ID]_.*'
@@ -13536,16 +13099,16 @@
$rm conftest*
- if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+ if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$ac_compile\""; } >&5
ac_status=$?
soname=conftest
lib=conftest
@@ -13559,11 +13122,11 @@
libname=conftest
lt_save_allow_undefined_flag=$allow_undefined_flag_CXX
- if { (eval echo "$as_me:$LINENO: \"$archive_cmds_CXX 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
+ if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$archive_cmds_CXX 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\""; } >&5
(eval $archive_cmds_CXX 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
ac_status=$?
then
archive_cmds_need_lc_CXX=no
else
@@ -13574,16 +13137,16 @@
fi
$rm conftest*
- { echo "$as_me:$LINENO: result: $archive_cmds_need_lc_CXX" >&5
-echo "${ECHO_T}$archive_cmds_need_lc_CXX" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $archive_cmds_need_lc_CXX" >&5
+$as_echo "$archive_cmds_need_lc_CXX" >&6; }
esac
fi
esac
library_names_spec=
soname_spec=
@@ -14144,19 +13707,19 @@
dynamic_linker=no
esac
else
fi
else
fi
@@ -14168,8 +13731,8 @@
fi
hardcode_action_CXX=
if test -n "$hardcode_libdir_flag_spec_CXX" || \
test -n "$runpath_var_CXX" || \
@@ -14193,8 +13756,8 @@
# directories.
hardcode_action_CXX=unsupported
fi
-{ echo "$as_me:$LINENO: result: $hardcode_action_CXX" >&5
-echo "${ECHO_T}$hardcode_action_CXX" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $hardcode_action_CXX" >&5
+$as_echo "$hardcode_action_CXX" >&6; }
if test "$hardcode_action_CXX" = relink; then
@@ -14732,13 +14295,13 @@
cc_basename=`$echo "X$cc_temp" | $Xsed -e 's%.*/%%' -e "s%^$host_alias-%%"`
@@ -14757,15 +14320,15 @@
fi
esac
GCC_F77="$G77"
LD_F77="$LD"
@@ -14774,8 +14337,8 @@
lt_prog_compiler_pic_F77=
lt_prog_compiler_static_F77=
lt_prog_compiler_wl_F77='-Wl,'
@@ -15006,18 +14569,18 @@
esac
fi
-{ echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_F77" >&5
-echo "${ECHO_T}$lt_prog_compiler_pic_F77" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_prog_compiler_pic_F77" >&5
+$as_echo "$lt_prog_compiler_pic_F77" >&6; }
if test -n "$lt_prog_compiler_pic_F77"; then
-{ echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic_F77 works" >&5
-echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic_F77 works... $ECHO_C" >&6; }
-if test "${lt_cv_prog_compiler_pic_works_F77+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if $compiler PIC flag $lt_prog_compiler_pic_F77 works" >&5
+$as_echo_n "checking if $compiler PIC flag $lt_prog_compiler_pic_F77 works... " >&6; }
+if ${lt_cv_prog_compiler_pic_works_F77+:} false; then :
else
lt_cv_prog_compiler_pic_works_F77=no
@@ -15032,11 +14595,11 @@
- (eval echo "\"\$as_me:15035: $lt_compile\"" >&5)
+ (eval echo "\"\$as_me:14598: $lt_compile\"" >&5)
ac_status=$?
- echo "$as_me:15039: \$? = $ac_status" >&5
+ echo "$as_me:14602: \$? = $ac_status" >&5
@@ -15049,8 +14612,8 @@
$rm conftest*
fi
-{ echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_pic_works_F77" >&5
-echo "${ECHO_T}$lt_cv_prog_compiler_pic_works_F77" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_pic_works_F77" >&5
+$as_echo "$lt_cv_prog_compiler_pic_works_F77" >&6; }
if test x"$lt_cv_prog_compiler_pic_works_F77" = xyes; then
case $lt_prog_compiler_pic_F77 in
@@ -15077,10 +14640,10 @@
wl=$lt_prog_compiler_wl_F77 eval lt_tmp_static_flag=\"$lt_prog_compiler_static_F77\"
-if test "${lt_cv_prog_compiler_static_works_F77+set}" = set; then
+if ${lt_cv_prog_compiler_static_works_F77+:} false; then :
else
lt_cv_prog_compiler_static_works_F77=no
@@ -15105,8 +14668,8 @@
fi
-{ echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_static_works_F77" >&5
-echo "${ECHO_T}$lt_cv_prog_compiler_static_works_F77" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_static_works_F77" >&5
+$as_echo "$lt_cv_prog_compiler_static_works_F77" >&6; }
if test x"$lt_cv_prog_compiler_static_works_F77" = xyes; then
@@ -15115,10 +14678,10 @@
fi
-if test "${lt_cv_prog_compiler_c_o_F77+set}" = set; then
+if ${lt_cv_prog_compiler_c_o_F77+:} false; then :
else
lt_cv_prog_compiler_c_o_F77=no
@@ -15136,11 +14699,11 @@
- (eval echo "\"\$as_me:15139: $lt_compile\"" >&5)
+ (eval echo "\"\$as_me:14702: $lt_compile\"" >&5)
ac_status=$?
- echo "$as_me:15143: \$? = $ac_status" >&5
+ echo "$as_me:14706: \$? = $ac_status" >&5
then
@@ -15162,34 +14725,34 @@
$rm conftest*
fi
-{ echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o_F77" >&5
-echo "${ECHO_T}$lt_cv_prog_compiler_c_o_F77" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_c_o_F77" >&5
+$as_echo "$lt_cv_prog_compiler_c_o_F77" >&6; }
if test "$lt_cv_prog_compiler_c_o_F77" = no && test "$need_locks" != no; then
hard_links=yes
$rm conftest*
touch conftest.a
need_locks=warn
fi
else
need_locks=no
fi
runpath_var=
allow_undefined_flag_F77=
@@ -15599,29 +15162,12 @@
allow_undefined_flag_F77='-berok'
program main
end
_ACEOF
-esac
- ac_status=$?
- (exit $ac_status); } && {
+if ac_fn_f77_try_link "$LINENO"; then :
@@ -15635,15 +15181,9 @@
fi
-else
fi
hardcode_libdir_flag_spec_F77='${wl}-blibpath:$libdir:'"$aix_libpath"
@@ -15655,29 +15195,12 @@
archive_expsym_cmds_F77="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
else
program main
end
_ACEOF
-esac
- ac_status=$?
@@ -15691,15 +15214,9 @@
fi
-else
fi
@@ -16149,8 +15666,8 @@
esac
fi
-{ echo "$as_me:$LINENO: result: $ld_shlibs_F77" >&5
-echo "${ECHO_T}$ld_shlibs_F77" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ld_shlibs_F77" >&5
+$as_echo "$ld_shlibs_F77" >&6; }
test "$ld_shlibs_F77" = no && can_build_shared=no
@@ -16170,16 +15687,16 @@
$rm conftest*
ac_status=$?
soname=conftest
lib=conftest
@@ -16193,11 +15710,11 @@
libname=conftest
lt_save_allow_undefined_flag=$allow_undefined_flag_F77
- if { (eval echo "$as_me:$LINENO: \"$archive_cmds_F77 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
+ if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$archive_cmds_F77 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\""; } >&5
(eval $archive_cmds_F77 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
ac_status=$?
then
archive_cmds_need_lc_F77=no
else
@@ -16208,16 +15725,16 @@
fi
$rm conftest*
- { echo "$as_me:$LINENO: result: $archive_cmds_need_lc_F77" >&5
-echo "${ECHO_T}$archive_cmds_need_lc_F77" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $archive_cmds_need_lc_F77" >&5
+$as_echo "$archive_cmds_need_lc_F77" >&6; }
esac
fi
esac
library_names_spec=
soname_spec=
@@ -16778,19 +16295,19 @@
dynamic_linker=no
esac
else
fi
else
fi
@@ -16802,8 +16319,8 @@
fi
hardcode_action_F77=
if test -n "$hardcode_libdir_flag_spec_F77" || \
test -n "$runpath_var_F77" || \
@@ -16827,8 +16344,8 @@
# directories.
hardcode_action_F77=unsupported
fi
-{ echo "$as_me:$LINENO: result: $hardcode_action_F77" >&5
-echo "${ECHO_T}$hardcode_action_F77" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $hardcode_action_F77" >&5
+$as_echo "$hardcode_action_F77" >&6; }
if test "$hardcode_action_F77" = relink; then
@@ -17338,10 +16855,10 @@
lt_prog_compiler_no_builtin_flag_GCJ=' -fno-builtin'
else
@@ -17356,11 +16873,11 @@
- (eval echo "\"\$as_me:17359: $lt_compile\"" >&5)
+ (eval echo "\"\$as_me:16876: $lt_compile\"" >&5)
ac_status=$?
- echo "$as_me:17363: \$? = $ac_status" >&5
+ echo "$as_me:16880: \$? = $ac_status" >&5
@@ -17373,8 +16890,8 @@
$rm conftest*
fi
lt_prog_compiler_no_builtin_flag_GCJ="$lt_prog_compiler_no_builtin_flag_GCJ -fno-rtti -fno-exceptions"
@@ -17388,8 +16905,8 @@
lt_prog_compiler_pic_GCJ=
lt_prog_compiler_static_GCJ=
lt_prog_compiler_wl_GCJ='-Wl,'
@@ -17620,18 +17137,18 @@
esac
fi
-{ echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_GCJ" >&5
-echo "${ECHO_T}$lt_prog_compiler_pic_GCJ" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_prog_compiler_pic_GCJ" >&5
+$as_echo "$lt_prog_compiler_pic_GCJ" >&6; }
if test -n "$lt_prog_compiler_pic_GCJ"; then
-{ echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic_GCJ works" >&5
-echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic_GCJ works... $ECHO_C" >&6; }
-if test "${lt_cv_prog_compiler_pic_works_GCJ+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if $compiler PIC flag $lt_prog_compiler_pic_GCJ works" >&5
+$as_echo_n "checking if $compiler PIC flag $lt_prog_compiler_pic_GCJ works... " >&6; }
+if ${lt_cv_prog_compiler_pic_works_GCJ+:} false; then :
else
lt_cv_prog_compiler_pic_works_GCJ=no
@@ -17646,11 +17163,11 @@
- (eval echo "\"\$as_me:17649: $lt_compile\"" >&5)
+ (eval echo "\"\$as_me:17166: $lt_compile\"" >&5)
ac_status=$?
- echo "$as_me:17653: \$? = $ac_status" >&5
+ echo "$as_me:17170: \$? = $ac_status" >&5
@@ -17663,8 +17180,8 @@
$rm conftest*
fi
-{ echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_pic_works_GCJ" >&5
-echo "${ECHO_T}$lt_cv_prog_compiler_pic_works_GCJ" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_pic_works_GCJ" >&5
+$as_echo "$lt_cv_prog_compiler_pic_works_GCJ" >&6; }
if test x"$lt_cv_prog_compiler_pic_works_GCJ" = xyes; then
case $lt_prog_compiler_pic_GCJ in
@@ -17691,10 +17208,10 @@
wl=$lt_prog_compiler_wl_GCJ eval lt_tmp_static_flag=\"$lt_prog_compiler_static_GCJ\"
-if test "${lt_cv_prog_compiler_static_works_GCJ+set}" = set; then
+if ${lt_cv_prog_compiler_static_works_GCJ+:} false; then :
else
lt_cv_prog_compiler_static_works_GCJ=no
@@ -17719,8 +17236,8 @@
fi
-{ echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_static_works_GCJ" >&5
-echo "${ECHO_T}$lt_cv_prog_compiler_static_works_GCJ" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_static_works_GCJ" >&5
+$as_echo "$lt_cv_prog_compiler_static_works_GCJ" >&6; }
if test x"$lt_cv_prog_compiler_static_works_GCJ" = xyes; then
@@ -17729,10 +17246,10 @@
fi
-if test "${lt_cv_prog_compiler_c_o_GCJ+set}" = set; then
+if ${lt_cv_prog_compiler_c_o_GCJ+:} false; then :
else
lt_cv_prog_compiler_c_o_GCJ=no
@@ -17750,11 +17267,11 @@
- (eval echo "\"\$as_me:17753: $lt_compile\"" >&5)
+ (eval echo "\"\$as_me:17270: $lt_compile\"" >&5)
ac_status=$?
- echo "$as_me:17757: \$? = $ac_status" >&5
+ echo "$as_me:17274: \$? = $ac_status" >&5
then
@@ -17776,34 +17293,34 @@
$rm conftest*
fi
-{ echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o_GCJ" >&5
-echo "${ECHO_T}$lt_cv_prog_compiler_c_o_GCJ" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_c_o_GCJ" >&5
+$as_echo "$lt_cv_prog_compiler_c_o_GCJ" >&6; }
if test "$lt_cv_prog_compiler_c_o_GCJ" = no && test "$need_locks" != no; then
hard_links=yes
$rm conftest*
touch conftest.a
need_locks=warn
fi
else
need_locks=no
fi
runpath_var=
allow_undefined_flag_GCJ=
@@ -18213,11 +17730,7 @@
allow_undefined_flag_GCJ='-berok'
-/* confdefs.h. */
-_ACEOF
/* end confdefs.h. */
int
@@ -18228,24 +17741,7 @@
return 0;
_ACEOF
-esac
- ac_status=$?
+if ac_fn_c_try_link "$LINENO"; then :
@@ -18259,15 +17755,9 @@
fi
-else
fi
hardcode_libdir_flag_spec_GCJ='${wl}-blibpath:$libdir:'"$aix_libpath"
@@ -18279,11 +17769,7 @@
archive_expsym_cmds_GCJ="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
else
-/* confdefs.h. */
-_ACEOF
int
@@ -18294,24 +17780,7 @@
return 0;
_ACEOF
-esac
- ac_status=$?
@@ -18325,15 +17794,9 @@
fi
-else
fi
@@ -18783,8 +18246,8 @@
esac
fi
-{ echo "$as_me:$LINENO: result: $ld_shlibs_GCJ" >&5
-echo "${ECHO_T}$ld_shlibs_GCJ" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ld_shlibs_GCJ" >&5
+$as_echo "$ld_shlibs_GCJ" >&6; }
test "$ld_shlibs_GCJ" = no && can_build_shared=no
@@ -18804,16 +18267,16 @@
$rm conftest*
ac_status=$?
soname=conftest
lib=conftest
@@ -18827,11 +18290,11 @@
libname=conftest
lt_save_allow_undefined_flag=$allow_undefined_flag_GCJ
- if { (eval echo "$as_me:$LINENO: \"$archive_cmds_GCJ 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
+ if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$archive_cmds_GCJ 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\""; } >&5
(eval $archive_cmds_GCJ 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
ac_status=$?
then
archive_cmds_need_lc_GCJ=no
else
@@ -18842,16 +18305,16 @@
fi
$rm conftest*
- { echo "$as_me:$LINENO: result: $archive_cmds_need_lc_GCJ" >&5
-echo "${ECHO_T}$archive_cmds_need_lc_GCJ" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $archive_cmds_need_lc_GCJ" >&5
+$as_echo "$archive_cmds_need_lc_GCJ" >&6; }
esac
fi
esac
library_names_spec=
soname_spec=
@@ -19412,19 +18875,19 @@
dynamic_linker=no
esac
else
fi
else
fi
@@ -19436,8 +18899,8 @@
fi
hardcode_action_GCJ=
if test -n "$hardcode_libdir_flag_spec_GCJ" || \
test -n "$runpath_var_GCJ" || \
@@ -19461,8 +18924,8 @@
# directories.
hardcode_action_GCJ=unsupported
fi
-{ echo "$as_me:$LINENO: result: $hardcode_action_GCJ" >&5
-echo "${ECHO_T}$hardcode_action_GCJ" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $hardcode_action_GCJ" >&5
+$as_echo "$hardcode_action_GCJ" >&6; }
if test "$hardcode_action_GCJ" = relink; then
@@ -20385,9 +19848,7 @@
- { { echo "$as_me:$LINENO: error: Unsupported tag name: $tagname" >&5
-echo "$as_me: error: Unsupported tag name: $tagname" >&2;}
- { (exit 1); exit 1; }; }
+ as_fn_error $? "Unsupported tag name: $tagname" "$LINENO" 5
esac
@@ -20405,9 +19866,7 @@
chmod +x "$ofile"
else
rm -f "${ofile}T"
- { { echo "$as_me:$LINENO: error: unable to update list of available tagged configurations." >&5
-echo "$as_me: error: unable to update list of available tagged configurations." >&2;}
+ as_fn_error $? "unable to update list of available tagged configurations." "$LINENO" 5
fi
fi
@@ -20440,98 +19899,20 @@
-# Find a good install program. We prefer a C program (faster),
-# so one script is as good as another. But avoid the broken or
-# incompatible versions:
-# SysV /etc/install, /usr/sbin/install
-# SunOS /usr/etc/install
-# IRIX /sbin/install
-# AIX /bin/install
-# AmigaOS /C/install, which installs bootblocks on floppy discs
-# AIX 4 /usr/bin/installbsd, which doesn't work without a -g flag
-# AFS /usr/afsws/bin/install, which mishandles nonexistent args
-# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
-# OS/2's system install, which has a completely different semantic
-# ./install, which can be erroneously created by make from ./install.sh.
-{ echo "$as_me:$LINENO: checking for a BSD-compatible install" >&5
-echo $ECHO_N "checking for a BSD-compatible install... $ECHO_C" >&6; }
-if test -z "$INSTALL"; then
-if test "${ac_cv_path_install+set}" = set; then
-else
- as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-for as_dir in $PATH
-do
- IFS=$as_save_IFS
- test -z "$as_dir" && as_dir=.
- # Account for people who put trailing slashes in PATH elements.
-case $as_dir/ in
- ./ | .// | /cC/* | \
- /etc/* | /usr/sbin/* | /usr/etc/* | /sbin/* | /usr/afsws/bin/* | \
- ?:\\/os2\\/install\\/* | ?:\\/OS2\\/INSTALL\\/* | \
- /usr/ucb/* ) ;;
- # OSF1 and SCO ODT 3.0 have their own names for install.
- # Don't use installbsd from OSF since it installs stuff as root
- # by default.
- for ac_prog in ginstall scoinst install; do
- for ac_exec_ext in '' $ac_executable_extensions; do
- if { test -f "$as_dir/$ac_prog$ac_exec_ext" && $as_test_x "$as_dir/$ac_prog$ac_exec_ext"; }; then
- if test $ac_prog = install &&
- grep dspmsg "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
- # AIX install. It has an incompatible calling convention.
- elif test $ac_prog = install &&
- grep pwplus "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
- # program-specific install script used by HP pwplus--don't use.
- else
- ac_cv_path_install="$as_dir/$ac_prog$ac_exec_ext -c"
- break 3
- fi
- fi
- done
- done
-esac
-done
-IFS=$as_save_IFS
-fi
- if test "${ac_cv_path_install+set}" = set; then
- INSTALL=$ac_cv_path_install
- else
- # As a last resort, use the slow shell script. Don't cache a
- # value for INSTALL within a source directory, because that will
- # break other packages using the cache if that directory is
- # removed, or if the value is a relative name.
- INSTALL=$ac_install_sh
- fi
-fi
-{ echo "$as_me:$LINENO: result: $INSTALL" >&5
-echo "${ECHO_T}$INSTALL" >&6; }
-# Use test -z because SunOS4 sh mishandles braces in ${var-val}.
-# It thinks the first close brace ends the variable substitution.
-test -z "$INSTALL_PROGRAM" && INSTALL_PROGRAM='${INSTALL}'
-test -z "$INSTALL_SCRIPT" && INSTALL_SCRIPT='${INSTALL}'
-test -z "$INSTALL_DATA" && INSTALL_DATA='${INSTALL} -m 644'
-{ echo "$as_me:$LINENO: checking whether ${MAKE-make} sets \$(MAKE)" >&5
-echo $ECHO_N "checking whether ${MAKE-make} sets \$(MAKE)... $ECHO_C" >&6; }
-set x ${MAKE-make}; ac_make=`echo "$2" | sed 's/+/p/g; s/[^a-zA-Z0-9_]/_/g'`
-if { as_var=ac_cv_prog_make_${ac_make}_set; eval "test \"\${$as_var+set}\" = set"; }; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether ${MAKE-make} sets \$(MAKE)" >&5
+$as_echo_n "checking whether ${MAKE-make} sets \$(MAKE)... " >&6; }
+set x ${MAKE-make}
+ac_make=`$as_echo "$2" | sed 's/+/p/g; s/[^a-zA-Z0-9_]/_/g'`
+if eval \${ac_cv_prog_make_${ac_make}_set+:} false; then :
else
cat >conftest.make <<\_ACEOF
SHELL = /bin/sh
all:
@echo '@@@%%%=$(MAKE)=@@@%%%'
_ACEOF
-# GNU make sometimes prints "make[1]: Entering...", which would confuse us.
+# GNU make sometimes prints "make[1]: Entering ...", which would confuse us.
case `${MAKE-make} -f conftest.make 2>/dev/null` in
eval ac_cv_prog_make_${ac_make}_set=yes;;
@@ -20541,22 +19922,22 @@
rm -f conftest.make
fi
if eval test \$ac_cv_prog_make_${ac_make}_set = yes; then
- { echo "$as_me:$LINENO: result: yes" >&5
-echo "${ECHO_T}yes" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
+$as_echo "yes" >&6; }
SET_MAKE=
else
SET_MAKE="MAKE=${MAKE-make}"
fi
if test -n "$ac_tool_prefix"; then
# Extract the first word of "${ac_tool_prefix}ranlib", so it can be a program name with args.
set dummy ${ac_tool_prefix}ranlib; ac_word=$2
-{ echo "$as_me:$LINENO: checking for $ac_word" >&5
-echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6; }
-if test "${ac_cv_prog_RANLIB+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $ac_word" >&5
+$as_echo_n "checking for $ac_word... " >&6; }
+if ${ac_cv_prog_RANLIB+:} false; then :
else
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -20566,25 +19947,25 @@
do
IFS=$as_save_IFS
- if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then
+ for ac_exec_ext in '' $ac_executable_extensions; do
+ if as_fn_executable_p "$as_dir/$ac_word$ac_exec_ext"; then
ac_cv_prog_RANLIB="${ac_tool_prefix}ranlib"
- echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5
+ $as_echo "$as_me:${as_lineno-$LINENO}: found $as_dir/$ac_word$ac_exec_ext" >&5
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
RANLIB=$ac_cv_prog_RANLIB
- { echo "$as_me:$LINENO: result: $RANLIB" >&5
-echo "${ECHO_T}$RANLIB" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $RANLIB" >&5
+$as_echo "$RANLIB" >&6; }
else
fi
@@ -20593,10 +19974,10 @@
ac_ct_RANLIB=$RANLIB
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-if test "${ac_cv_prog_ac_ct_RANLIB+set}" = set; then
+if ${ac_cv_prog_ac_ct_RANLIB+:} false; then :
else
if test -n "$ac_ct_RANLIB"; then
ac_cv_prog_ac_ct_RANLIB="$ac_ct_RANLIB" # Let the user override the test.
@@ -20606,25 +19987,25 @@
do
IFS=$as_save_IFS
ac_cv_prog_ac_ct_RANLIB="ranlib"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
ac_ct_RANLIB=$ac_cv_prog_ac_ct_RANLIB
- { echo "$as_me:$LINENO: result: $ac_ct_RANLIB" >&5
-echo "${ECHO_T}$ac_ct_RANLIB" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_RANLIB" >&5
+$as_echo "$ac_ct_RANLIB" >&6; }
else
fi
if test "x$ac_ct_RANLIB" = x; then
@@ -20632,12 +20013,8 @@
else
case $cross_compiling:$ac_tool_warned in
yes:)
-{ echo "$as_me:$LINENO: WARNING: In the future, Autoconf will not detect cross-tools
-whose name does not start with the host triplet. If you think this
-configuration is useful to you, please write to autoconf at gnu.org." >&5
-echo "$as_me: WARNING: In the future, Autoconf will not detect cross-tools
-configuration is useful to you, please write to autoconf at gnu.org." >&2;}
+{ $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: using cross tools not prefixed with host triplet" >&5
+$as_echo "$as_me: WARNING: using cross tools not prefixed with host triplet" >&2;}
ac_tool_warned=yes ;;
esac
RANLIB=$ac_ct_RANLIB
@@ -20648,16 +20025,12 @@
# Checks for header files.
-{ echo "$as_me:$LINENO: checking for ANSI C header files" >&5
-echo $ECHO_N "checking for ANSI C header files... $ECHO_C" >&6; }
-if test "${ac_cv_header_stdc+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for ANSI C header files" >&5
+$as_echo_n "checking for ANSI C header files... " >&6; }
+if ${ac_cv_header_stdc+:} false; then :
else
-/* confdefs.h. */
-_ACEOF
#include <stdlib.h>
#include <stdarg.h>
@@ -20672,47 +20045,23 @@
return 0;
_ACEOF
-if { (ac_try="$ac_compile"
-esac
- (eval "$ac_compile") 2>conftest.er1
- ac_status=$?
- } && test -s conftest.$ac_objext; then
+if ac_fn_c_try_compile "$LINENO"; then :
ac_cv_header_stdc=yes
else
- ac_cv_header_stdc=no
+ ac_cv_header_stdc=no
fi
rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-/* confdefs.h. */
-_ACEOF
#include <string.h>
_ACEOF
if (eval "$ac_cpp conftest.$ac_ext") 2>&5 |
- $EGREP "memchr" >/dev/null 2>&1; then
+ $EGREP "memchr" >/dev/null 2>&1; then :
else
fi
@@ -20722,18 +20071,14 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-/* confdefs.h. */
-_ACEOF
#include <stdlib.h>
_ACEOF
- $EGREP "free" >/dev/null 2>&1; then
+ $EGREP "free" >/dev/null 2>&1; then :
else
fi
@@ -20743,14 +20088,10 @@
# /bin/cc in Irix-4.0.5 gets non-ANSI ctype macros unless using -ansi.
- if test "$cross_compiling" = yes; then
+ if test "$cross_compiling" = yes; then :
else
-/* confdefs.h. */
-_ACEOF
#include <ctype.h>
#include <stdlib.h>
@@ -20777,195 +20118,32 @@
return 0;
_ACEOF
-rm -f conftest$ac_exeext
-esac
- (eval "$ac_link") 2>&5
- ac_status=$?
- (exit $ac_status); } && { ac_try='./conftest$ac_exeext'
- { (case "(($ac_try" in
-esac
- (eval "$ac_try") 2>&5
- ac_status=$?
- (exit $ac_status); }; }; then
-else
- echo "$as_me: program exited with status $ac_status" >&5
-echo "$as_me: failed program was:" >&5
+if ac_fn_c_try_run "$LINENO"; then :
-( exit $ac_status )
-ac_cv_header_stdc=no
+else
fi
-rm -f core *.core core.conftest.* gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext
+rm -f core *.core core.conftest.* gmon.out bb.out conftest$ac_exeext \
+ conftest.$ac_objext conftest.beam conftest.$ac_ext
fi
fi
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_header_stdc" >&5
-echo "${ECHO_T}$ac_cv_header_stdc" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_header_stdc" >&5
+$as_echo "$ac_cv_header_stdc" >&6; }
-cat >>confdefs.h <<\_ACEOF
-#define STDC_HEADERS 1
-_ACEOF
+$as_echo "#define STDC_HEADERS 1" >>confdefs.h
fi
for ac_header in float.h limits.h stdlib.h string.h sys/time.h unistd.h
-do
-as_ac_Header=`echo "ac_cv_header_$ac_header" | $as_tr_sh`
-if { as_var=$as_ac_Header; eval "test \"\${$as_var+set}\" = set"; }; then
- { echo "$as_me:$LINENO: checking for $ac_header" >&5
-echo $ECHO_N "checking for $ac_header... $ECHO_C" >&6; }
-fi
-ac_res=`eval echo '${'$as_ac_Header'}'`
- { echo "$as_me:$LINENO: result: $ac_res" >&5
-echo "${ECHO_T}$ac_res" >&6; }
-else
- # Is the header compilable?
-{ echo "$as_me:$LINENO: checking $ac_header usability" >&5
-echo $ECHO_N "checking $ac_header usability... $ECHO_C" >&6; }
-/* confdefs.h. */
-_ACEOF
-cat confdefs.h >>conftest.$ac_ext
-cat >>conftest.$ac_ext <<_ACEOF
-/* end confdefs.h. */
-$ac_includes_default
-#include <$ac_header>
-_ACEOF
-case "(($ac_try" in
- *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
- *) ac_try_echo=$ac_try;;
-esac
-eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5
- ac_status=$?
- echo "$as_me:$LINENO: \$? = $ac_status" >&5
- ac_header_compiler=yes
-else
- echo "$as_me: failed program was:" >&5
- ac_header_compiler=no
-fi
-rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
-{ echo "$as_me:$LINENO: result: $ac_header_compiler" >&5
-echo "${ECHO_T}$ac_header_compiler" >&6; }
-# Is the header present?
-{ echo "$as_me:$LINENO: checking $ac_header presence" >&5
-echo $ECHO_N "checking $ac_header presence... $ECHO_C" >&6; }
-/* confdefs.h. */
-_ACEOF
-_ACEOF
-if { (ac_try="$ac_cpp conftest.$ac_ext"
-esac
- (eval "$ac_cpp conftest.$ac_ext") 2>conftest.er1
- ac_status=$?
- (exit $ac_status); } >/dev/null && {
- test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" ||
- }; then
- ac_header_preproc=yes
-else
- ac_header_preproc=no
-fi
-rm -f conftest.err conftest.$ac_ext
-{ echo "$as_me:$LINENO: result: $ac_header_preproc" >&5
-echo "${ECHO_T}$ac_header_preproc" >&6; }
-# So? What about this header?
-case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in
- yes:no: )
- { echo "$as_me:$LINENO: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&5
-echo "$as_me: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the compiler's result" >&5
-echo "$as_me: WARNING: $ac_header: proceeding with the compiler's result" >&2;}
- no:yes:* )
- { echo "$as_me:$LINENO: WARNING: $ac_header: present but cannot be compiled" >&5
-echo "$as_me: WARNING: $ac_header: present but cannot be compiled" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: check for missing prerequisite headers?" >&5
-echo "$as_me: WARNING: $ac_header: check for missing prerequisite headers?" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: see the Autoconf documentation" >&5
-echo "$as_me: WARNING: $ac_header: see the Autoconf documentation" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: section \"Present But Cannot Be Compiled\"" >&5
-echo "$as_me: WARNING: $ac_header: section \"Present But Cannot Be Compiled\"" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the preprocessor's result" >&5
-echo "$as_me: WARNING: $ac_header: proceeding with the preprocessor's result" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: in the future, the compiler will take precedence" >&5
-echo "$as_me: WARNING: $ac_header: in the future, the compiler will take precedence" >&2;}
- ( cat <<\_ASBOX
-## Report this to Oracle Technology Network Berkeley DB XML forum ##
-_ASBOX
- ) | sed "s/^/$as_me: WARNING: /" >&2
-esac
-{ echo "$as_me:$LINENO: checking for $ac_header" >&5
-else
- eval "$as_ac_Header=\$ac_header_preproc"
-fi
-fi
-if test `eval echo '${'$as_ac_Header'}'` = yes; then
+do :
+ as_ac_Header=`$as_echo "ac_cv_header_$ac_header" | $as_tr_sh`
+ac_fn_c_check_header_mongrel "$LINENO" "$ac_header" "$as_ac_Header" "$ac_includes_default"
+if eval test \"x\$"$as_ac_Header"\" = x"yes"; then :
cat >>confdefs.h <<_ACEOF
-#define `echo "HAVE_$ac_header" | $as_tr_cpp` 1
+#define `$as_echo "HAVE_$ac_header" | $as_tr_cpp` 1
_ACEOF
fi
@@ -20974,177 +20152,85 @@
# Checks for typedefs, structures, and compiler characteristics.
-{ echo "$as_me:$LINENO: checking for stdbool.h that conforms to C99" >&5
-echo $ECHO_N "checking for stdbool.h that conforms to C99... $ECHO_C" >&6; }
-if test "${ac_cv_header_stdbool_h+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for stdbool.h that conforms to C99" >&5
+$as_echo_n "checking for stdbool.h that conforms to C99... " >&6; }
+if ${ac_cv_header_stdbool_h+:} false; then :
else
-/* confdefs.h. */
-_ACEOF
-#include <stdbool.h>
-#ifndef bool
- "error: bool is not defined"
-#endif
-#ifndef false
- "error: false is not defined"
-#endif
-#if false
- "error: false is not 0"
-#endif
-#ifndef true
- "error: true is not defined"
-#endif
-#if true != 1
- "error: true is not 1"
-#endif
-#ifndef __bool_true_false_are_defined
- "error: __bool_true_false_are_defined is not defined"
-#endif
+ #include <stdbool.h>
+ #ifndef bool
+ "error: bool is not defined"
+ #endif
+ #ifndef false
+ "error: false is not defined"
+ #endif
+ #if false
+ "error: false is not 0"
+ #endif
+ #ifndef true
+ "error: true is not defined"
+ #endif
+ #if true != 1
+ "error: true is not 1"
+ #endif
+ #ifndef __bool_true_false_are_defined
+ "error: __bool_true_false_are_defined is not defined"
+ #endif
- struct s { _Bool s: 1; _Bool t; } s;
+ struct s { _Bool s: 1; _Bool t; } s;
- char a[true == 1 ? 1 : -1];
- char b[false == 0 ? 1 : -1];
- char c[__bool_true_false_are_defined == 1 ? 1 : -1];
- char d[(bool) 0.5 == true ? 1 : -1];
- bool e = &s;
- char f[(_Bool) 0.0 == false ? 1 : -1];
- char g[true];
- char h[sizeof (_Bool)];
- char i[sizeof s.t];
- enum { j = false, k = true, l = false * true, m = true * 256 };
- _Bool n[m];
- char o[sizeof n == m * sizeof n[0] ? 1 : -1];
- char p[-1 - (_Bool) 0 < 0 && -1 - (bool) 0 < 0 ? 1 : -1];
-# if defined __xlc__ || defined __GNUC__
- /* Catch a bug in IBM AIX xlc compiler version 6.0.0.0
- reported by James Lemley on 2005-10-05; see
- http://lists.gnu.org/archive/html/bug-coreutils/2005-10/msg00086.html
- This test is not quite right, since xlc is allowed to
- reject this program, as the initializer for xlcbug is
- not one of the forms that C requires support for.
- However, doing the test right would require a runtime
- test, and that would make cross-compilation harder.
- Let us hope that IBM fixes the xlc bug, and also adds
- support for this kind of constant expression. In the
- meantime, this test will reject xlc, which is OK, since
- our stdbool.h substitute should suffice. We also test
- this with GCC, where it should work, to detect more
- quickly whether someone messes up the test in the
- future. */
- char digs[] = "0123456789";
- int xlcbug = 1 / (&(digs + 5)[-2 + (bool) 1] == &digs[4] ? 1 : -1);
-# endif
- /* Catch a bug in an HP-UX C compiler. See
- http://gcc.gnu.org/ml/gcc-patches/2003-12/msg02303.html
- http://lists.gnu.org/archive/html/bug-coreutils/2005-11/msg00161.html
- _Bool q = true;
- _Bool *pq = &q;
+ char a[true == 1 ? 1 : -1];
+ char b[false == 0 ? 1 : -1];
+ char c[__bool_true_false_are_defined == 1 ? 1 : -1];
+ char d[(bool) 0.5 == true ? 1 : -1];
+ /* See body of main program for 'e'. */
+ char f[(_Bool) 0.0 == false ? 1 : -1];
+ char g[true];
+ char h[sizeof (_Bool)];
+ char i[sizeof s.t];
+ enum { j = false, k = true, l = false * true, m = true * 256 };
+ /* The following fails for
+ HP aC++/ANSI C B3910B A.05.55 [Dec 04 2003]. */
+ _Bool n[m];
+ char o[sizeof n == m * sizeof n[0] ? 1 : -1];
+ char p[-1 - (_Bool) 0 < 0 && -1 - (bool) 0 < 0 ? 1 : -1];
+ /* Catch a bug in an HP-UX C compiler. See
+ http://gcc.gnu.org/ml/gcc-patches/2003-12/msg02303.html
+ http://lists.gnu.org/archive/html/bug-coreutils/2005-11/msg00161.html
+ _Bool q = true;
+ _Bool *pq = &q;
int
main ()
- *pq |= q;
- *pq |= ! q;
- /* Refer to every declared value, to avoid compiler optimizations. */
- return (!a + !b + !c + !d + !e + !f + !g + !h + !i + !!j + !k + !!l
- + !m + !n + !o + !p + !q + !pq);
+ bool e = &s;
+ *pq |= q;
+ *pq |= ! q;
+ /* Refer to every declared value, to avoid compiler optimizations. */
+ return (!a + !b + !c + !d + !e + !f + !g + !h + !i + !!j + !k + !!l
+ + !m + !n + !o + !p + !q + !pq);
return 0;
_ACEOF
-esac
- ac_status=$?
ac_cv_header_stdbool_h=yes
else
- ac_cv_header_stdbool_h=no
+ ac_cv_header_stdbool_h=no
fi
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_header_stdbool_h" >&5
-echo "${ECHO_T}$ac_cv_header_stdbool_h" >&6; }
-{ echo "$as_me:$LINENO: checking for _Bool" >&5
-echo $ECHO_N "checking for _Bool... $ECHO_C" >&6; }
-if test "${ac_cv_type__Bool+set}" = set; then
-else
-/* confdefs.h. */
-_ACEOF
-typedef _Bool ac__type_new_;
-int
-main ()
-if ((ac__type_new_ *) 0)
- return 0;
-if (sizeof (ac__type_new_))
- return 0;
- return 0;
-_ACEOF
-esac
- ac_status=$?
- ac_cv_type__Bool=yes
-else
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_header_stdbool_h" >&5
+$as_echo "$ac_cv_header_stdbool_h" >&6; }
+ ac_fn_c_check_type "$LINENO" "_Bool" "ac_cv_type__Bool" "$ac_includes_default"
+if test "x$ac_cv_type__Bool" = xyes; then :
- ac_cv_type__Bool=no
-fi
-fi
-{ echo "$as_me:$LINENO: result: $ac_cv_type__Bool" >&5
-echo "${ECHO_T}$ac_cv_type__Bool" >&6; }
-if test $ac_cv_type__Bool = yes; then
#define HAVE__BOOL 1
_ACEOF
@@ -21152,34 +20238,29 @@
fi
if test $ac_cv_header_stdbool_h = yes; then
-#define HAVE_STDBOOL_H 1
-_ACEOF
+$as_echo "#define HAVE_STDBOOL_H 1" >>confdefs.h
fi
-{ echo "$as_me:$LINENO: checking for an ANSI C-conforming const" >&5
-echo $ECHO_N "checking for an ANSI C-conforming const... $ECHO_C" >&6; }
-if test "${ac_cv_c_const+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for an ANSI C-conforming const" >&5
+$as_echo_n "checking for an ANSI C-conforming const... " >&6; }
+if ${ac_cv_c_const+:} false; then :
+ $as_echo_n "(cached) " >&6
else
- cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h. */
-_ACEOF
+ cat confdefs.h - <<_ACEOF >conftest.$ac_ext
int
main ()
-/* FIXME: Include the comments suggested by Paul. */
#ifndef __cplusplus
- /* Ultrix mips cc rejects this. */
+ /* Ultrix mips cc rejects this sort of thing. */
typedef int charset[2];
- const charset cs;
+ const charset cs = { 0, 0 };
/* SunOS 4.1.1 cc rejects this. */
char const *const *pcpcc;
char **ppc;
@@ -21196,8 +20277,9 @@
++pcpcc;
ppc = (char**) pcpcc;
pcpcc = (char const *const *) ppc;
- { /* SCO 3.2v4 cc rejects this. */
- char *t;
+ { /* SCO 3.2v4 cc rejects this sort of thing. */
+ char tx;
+ char *t = &tx;
char const *s = 0 ? (char *) 0 : (char const *) 0;
*t++ = 0;
@@ -21213,10 +20295,10 @@
iptr p = 0;
++p;
- { /* AIX XL C 1.02.0.0 rejects this saying
+ { /* AIX XL C 1.02.0.0 rejects this sort of thing, saying
"k.c", line 2.27: 1506-025 (S) Operand must be a modifiable lvalue. */
- struct s { int j; const int *ap[3]; };
- struct s *b; b->j = 5;
+ struct s { int j; const int *ap[3]; } bx;
+ struct s *b = &bx; b->j = 5;
{ /* ULTRIX-32 V3.1 (Rev 9) vcc rejects this */
const int foo = 10;
@@ -21229,55 +20311,29 @@
return 0;
_ACEOF
-esac
- ac_status=$?
- grep -v '^ *+' conftest.er1 >conftest.err
- rm -f conftest.er1
- cat conftest.err >&5
- test -z "$ac_c_werror_flag" ||
- test ! -s conftest.err
ac_cv_c_const=yes
else
-sed 's/^/| /' conftest.$ac_ext >&5
- ac_cv_c_const=no
+ ac_cv_c_const=no
fi
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_c_const" >&5
-echo "${ECHO_T}$ac_cv_c_const" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_c_const" >&5
+$as_echo "$ac_cv_c_const" >&6; }
if test $ac_cv_c_const = no; then
-#define const
-_ACEOF
+$as_echo "#define const /**/" >>confdefs.h
fi
-{ echo "$as_me:$LINENO: checking for inline" >&5
-echo $ECHO_N "checking for inline... $ECHO_C" >&6; }
-if test "${ac_cv_c_inline+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for inline" >&5
+$as_echo_n "checking for inline... " >&6; }
+if ${ac_cv_c_inline+:} false; then :
else
ac_cv_c_inline=no
for ac_kw in inline __inline__ __inline; do
-/* confdefs.h. */
-_ACEOF
#ifndef __cplusplus
typedef int foo_t;
@@ -21286,40 +20342,17 @@
#endif
_ACEOF
-esac
- ac_status=$?
ac_cv_c_inline=$ac_kw
-else
fi
test "$ac_cv_c_inline" != no && break
done
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_c_inline" >&5
-echo "${ECHO_T}$ac_cv_c_inline" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_c_inline" >&5
+$as_echo "$ac_cv_c_inline" >&6; }
case $ac_cv_c_inline in
inline | yes) ;;
@@ -21335,111 +20368,8 @@
esac
- { echo "$as_me:$LINENO: checking for int32_t" >&5
-echo $ECHO_N "checking for int32_t... $ECHO_C" >&6; }
-if test "${ac_cv_c_int32_t+set}" = set; then
-else
- ac_cv_c_int32_t=no
- for ac_type in 'int32_t' 'int' 'long int' \
- 'long long int' 'short int' 'signed char'; do
-/* confdefs.h. */
-_ACEOF
-int
-main ()
-static int test_array [1 - 2 * !(0 < ($ac_type) (((($ac_type) 1 << (32 - 2)) - 1) * 2 + 1))];
-test_array [0] = 0
- return 0;
-_ACEOF
-esac
- ac_status=$?
-/* confdefs.h. */
-_ACEOF
-int
-main ()
-static int test_array [1 - 2 * !(($ac_type) (((($ac_type) 1 << (32 - 2)) - 1) * 2 + 1)
- < ($ac_type) (((($ac_type) 1 << (32 - 2)) - 1) * 2 + 2))];
-test_array [0] = 0
- return 0;
-_ACEOF
-esac
- ac_status=$?
-else
- case $ac_type in
- int32_t) ac_cv_c_int32_t=yes ;;
- *) ac_cv_c_int32_t=$ac_type ;;
-esac
-fi
-else
-fi
- test "$ac_cv_c_int32_t" != no && break
- done
-fi
-{ echo "$as_me:$LINENO: result: $ac_cv_c_int32_t" >&5
-echo "${ECHO_T}$ac_cv_c_int32_t" >&6; }
- case $ac_cv_c_int32_t in #(
+ac_fn_c_find_intX_t "$LINENO" "32" "ac_cv_c_int32_t"
+case $ac_cv_c_int32_t in #(
no|yes) ;; #(
@@ -21447,113 +20377,10 @@
#define int32_t $ac_cv_c_int32_t
_ACEOF
- esac
- { echo "$as_me:$LINENO: checking for int64_t" >&5
-echo $ECHO_N "checking for int64_t... $ECHO_C" >&6; }
-if test "${ac_cv_c_int64_t+set}" = set; then
-else
- ac_cv_c_int64_t=no
- for ac_type in 'int64_t' 'int' 'long int' \
-/* confdefs.h. */
-_ACEOF
-int
-main ()
-static int test_array [1 - 2 * !(0 < ($ac_type) (((($ac_type) 1 << (64 - 2)) - 1) * 2 + 1))];
-test_array [0] = 0
- return 0;
-_ACEOF
esac
- ac_status=$?
-/* confdefs.h. */
-_ACEOF
-int
-main ()
-static int test_array [1 - 2 * !(($ac_type) (((($ac_type) 1 << (64 - 2)) - 1) * 2 + 1)
- < ($ac_type) (((($ac_type) 1 << (64 - 2)) - 1) * 2 + 2))];
-test_array [0] = 0
- return 0;
-_ACEOF
-esac
- ac_status=$?
-else
- case $ac_type in
- int64_t) ac_cv_c_int64_t=yes ;;
- *) ac_cv_c_int64_t=$ac_type ;;
-esac
-fi
-else
-fi
- test "$ac_cv_c_int64_t" != no && break
- done
-fi
-{ echo "$as_me:$LINENO: result: $ac_cv_c_int64_t" >&5
-echo "${ECHO_T}$ac_cv_c_int64_t" >&6; }
- case $ac_cv_c_int64_t in #(
+ac_fn_c_find_intX_t "$LINENO" "64" "ac_cv_c_int64_t"
+case $ac_cv_c_int64_t in #(
no|yes) ;; #(
@@ -21561,63 +20388,11 @@
#define int64_t $ac_cv_c_int64_t
_ACEOF
- esac
-{ echo "$as_me:$LINENO: checking for size_t" >&5
-echo $ECHO_N "checking for size_t... $ECHO_C" >&6; }
-if test "${ac_cv_type_size_t+set}" = set; then
-else
-/* confdefs.h. */
-_ACEOF
-typedef size_t ac__type_new_;
-int
-main ()
- return 0;
- return 0;
- return 0;
-_ACEOF
esac
- ac_status=$?
- ac_cv_type_size_t=yes
-else
- ac_cv_type_size_t=no
-fi
+ac_fn_c_check_type "$LINENO" "size_t" "ac_cv_type_size_t" "$ac_includes_default"
+if test "x$ac_cv_type_size_t" = xyes; then :
-fi
-{ echo "$as_me:$LINENO: result: $ac_cv_type_size_t" >&5
-echo "${ECHO_T}$ac_cv_type_size_t" >&6; }
-if test $ac_cv_type_size_t = yes; then
else
@@ -21626,16 +20401,12 @@
fi
-{ echo "$as_me:$LINENO: checking whether time.h and sys/time.h may both be included" >&5
-echo $ECHO_N "checking whether time.h and sys/time.h may both be included... $ECHO_C" >&6; }
-if test "${ac_cv_header_time+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether time.h and sys/time.h may both be included" >&5
+$as_echo_n "checking whether time.h and sys/time.h may both be included... " >&6; }
+if ${ac_cv_header_time+:} false; then :
else
-/* confdefs.h. */
-_ACEOF
#include <sys/types.h>
#include <sys/time.h>
@@ -21650,53 +20421,27 @@
return 0;
_ACEOF
-esac
- ac_status=$?
ac_cv_header_time=yes
else
- ac_cv_header_time=no
+ ac_cv_header_time=no
fi
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_header_time" >&5
-echo "${ECHO_T}$ac_cv_header_time" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_header_time" >&5
+$as_echo "$ac_cv_header_time" >&6; }
if test $ac_cv_header_time = yes; then
-#define TIME_WITH_SYS_TIME 1
-_ACEOF
+$as_echo "#define TIME_WITH_SYS_TIME 1" >>confdefs.h
fi
-{ echo "$as_me:$LINENO: checking whether struct tm is in sys/time.h or time.h" >&5
-echo $ECHO_N "checking whether struct tm is in sys/time.h or time.h... $ECHO_C" >&6; }
-if test "${ac_cv_struct_tm+set}" = set; then
- echo $ECHO_N "(cached) $ECHO_C" >&6
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether struct tm is in sys/time.h or time.h" >&5
+$as_echo_n "checking whether struct tm is in sys/time.h or time.h... " >&6; }
+if ${ac_cv_struct_tm+:} false; then :
else
-/* confdefs.h. */
-_ACEOF
#include <time.h>
@@ -21706,116 +20451,32 @@
struct tm tm;
int *p = &tm.tm_sec;
- return !p;
+ return !p;
return 0;
_ACEOF
-esac
- ac_status=$?
ac_cv_struct_tm=time.h
else
- ac_cv_struct_tm=sys/time.h
+ ac_cv_struct_tm=sys/time.h
fi
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_struct_tm" >&5
-echo "${ECHO_T}$ac_cv_struct_tm" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_struct_tm" >&5
+$as_echo "$ac_cv_struct_tm" >&6; }
if test $ac_cv_struct_tm = sys/time.h; then
-#define TM_IN_SYS_TIME 1
-_ACEOF
+$as_echo "#define TM_IN_SYS_TIME 1" >>confdefs.h
fi
- { echo "$as_me:$LINENO: checking for uint32_t" >&5
-echo $ECHO_N "checking for uint32_t... $ECHO_C" >&6; }
-if test "${ac_cv_c_uint32_t+set}" = set; then
-else
- ac_cv_c_uint32_t=no
- for ac_type in 'uint32_t' 'unsigned int' 'unsigned long int' \
- 'unsigned long long int' 'unsigned short int' 'unsigned char'; do
-/* confdefs.h. */
-_ACEOF
-int
-main ()
-static int test_array [1 - 2 * !(($ac_type) -1 >> (32 - 1) == 1)];
-test_array [0] = 0
- return 0;
-_ACEOF
-esac
- ac_status=$?
- case $ac_type in
- uint32_t) ac_cv_c_uint32_t=yes ;;
- *) ac_cv_c_uint32_t=$ac_type ;;
-esac
-else
-fi
- test "$ac_cv_c_uint32_t" != no && break
- done
-fi
-{ echo "$as_me:$LINENO: result: $ac_cv_c_uint32_t" >&5
-echo "${ECHO_T}$ac_cv_c_uint32_t" >&6; }
- case $ac_cv_c_uint32_t in #(
+ac_fn_c_find_uintX_t "$LINENO" "32" "ac_cv_c_uint32_t"
+case $ac_cv_c_uint32_t in #(
no|yes) ;; #(
-#define _UINT32_T 1
-_ACEOF
+$as_echo "#define _UINT32_T 1" >>confdefs.h
@@ -21824,74 +20485,12 @@
esac
- { echo "$as_me:$LINENO: checking for uint64_t" >&5
-echo $ECHO_N "checking for uint64_t... $ECHO_C" >&6; }
-if test "${ac_cv_c_uint64_t+set}" = set; then
-else
- ac_cv_c_uint64_t=no
- for ac_type in 'uint64_t' 'unsigned int' 'unsigned long int' \
-/* confdefs.h. */
-_ACEOF
-int
-main ()
-static int test_array [1 - 2 * !(($ac_type) -1 >> (64 - 1) == 1)];
-test_array [0] = 0
- return 0;
-_ACEOF
-esac
- ac_status=$?
- case $ac_type in
- uint64_t) ac_cv_c_uint64_t=yes ;;
- *) ac_cv_c_uint64_t=$ac_type ;;
-esac
-else
-fi
- test "$ac_cv_c_uint64_t" != no && break
- done
-fi
-{ echo "$as_me:$LINENO: result: $ac_cv_c_uint64_t" >&5
-echo "${ECHO_T}$ac_cv_c_uint64_t" >&6; }
- case $ac_cv_c_uint64_t in #(
+ac_fn_c_find_uintX_t "$LINENO" "64" "ac_cv_c_uint64_t"
+case $ac_cv_c_uint64_t in #(
no|yes) ;; #(
-#define _UINT64_T 1
-_ACEOF
+$as_echo "#define _UINT64_T 1" >>confdefs.h
@@ -21900,74 +20499,12 @@
esac
- { echo "$as_me:$LINENO: checking for uint8_t" >&5
-echo $ECHO_N "checking for uint8_t... $ECHO_C" >&6; }
-if test "${ac_cv_c_uint8_t+set}" = set; then
-else
- ac_cv_c_uint8_t=no
- for ac_type in 'uint8_t' 'unsigned int' 'unsigned long int' \
-/* confdefs.h. */
-_ACEOF
-int
-main ()
-static int test_array [1 - 2 * !(($ac_type) -1 >> (8 - 1) == 1)];
-test_array [0] = 0
- return 0;
-_ACEOF
-esac
- ac_status=$?
- case $ac_type in
- uint8_t) ac_cv_c_uint8_t=yes ;;
- *) ac_cv_c_uint8_t=$ac_type ;;
-esac
-else
-fi
- test "$ac_cv_c_uint8_t" != no && break
- done
-fi
-{ echo "$as_me:$LINENO: result: $ac_cv_c_uint8_t" >&5
-echo "${ECHO_T}$ac_cv_c_uint8_t" >&6; }
- case $ac_cv_c_uint8_t in #(
+ac_fn_c_find_uintX_t "$LINENO" "8" "ac_cv_c_uint8_t"
+case $ac_cv_c_uint8_t in #(
no|yes) ;; #(
-#define _UINT8_T 1
-_ACEOF
+$as_echo "#define _UINT8_T 1" >>confdefs.h
@@ -21976,61 +20513,9 @@
esac
-{ echo "$as_me:$LINENO: checking for ptrdiff_t" >&5
-echo $ECHO_N "checking for ptrdiff_t... $ECHO_C" >&6; }
-if test "${ac_cv_type_ptrdiff_t+set}" = set; then
-else
-/* confdefs.h. */
-_ACEOF
-typedef ptrdiff_t ac__type_new_;
-int
-main ()
- return 0;
- return 0;
- return 0;
-_ACEOF
-esac
- ac_status=$?
- ac_cv_type_ptrdiff_t=yes
-else
+ac_fn_c_check_type "$LINENO" "ptrdiff_t" "ac_cv_type_ptrdiff_t" "$ac_includes_default"
+if test "x$ac_cv_type_ptrdiff_t" = xyes; then :
- ac_cv_type_ptrdiff_t=no
-fi
-fi
-{ echo "$as_me:$LINENO: result: $ac_cv_type_ptrdiff_t" >&5
-echo "${ECHO_T}$ac_cv_type_ptrdiff_t" >&6; }
-if test $ac_cv_type_ptrdiff_t = yes; then
#define HAVE_PTRDIFF_T 1
_ACEOF
@@ -22040,16 +20525,12 @@
# Checks for library functions.
-{ echo "$as_me:$LINENO: checking for error_at_line" >&5
-echo $ECHO_N "checking for error_at_line... $ECHO_C" >&6; }
-if test "${ac_cv_lib_error_at_line+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for error_at_line" >&5
+$as_echo_n "checking for error_at_line... " >&6; }
+if ${ac_cv_lib_error_at_line+:} false; then :
else
-/* confdefs.h. */
-_ACEOF
#include <error.h>
int
@@ -22060,37 +20541,16 @@
return 0;
_ACEOF
-if { (ac_try="$ac_link"
-esac
- ac_status=$?
ac_cv_lib_error_at_line=yes
else
- ac_cv_lib_error_at_line=no
+ ac_cv_lib_error_at_line=no
fi
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_lib_error_at_line" >&5
-echo "${ECHO_T}$ac_cv_lib_error_at_line" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_error_at_line" >&5
+$as_echo "$ac_cv_lib_error_at_line" >&6; }
if test $ac_cv_lib_error_at_line = no; then
case " $LIBOBJS " in
*" error.$ac_objext "* ) ;;
@@ -22100,164 +20560,27 @@
fi
for ac_header in stdlib.h
-do
-fi
-else
-cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h. */
-_ACEOF
-_ACEOF
-esac
- ac_status=$?
-else
-fi
-/* confdefs.h. */
-_ACEOF
-_ACEOF
-esac
- ac_status=$?
- }; then
-else
-fi
- yes:no: )
- no:yes:* )
- ( cat <<\_ASBOX
-_ASBOX
-esac
-else
-fi
-fi
+do :
+ ac_fn_c_check_header_mongrel "$LINENO" "stdlib.h" "ac_cv_header_stdlib_h" "$ac_includes_default"
+if test "x$ac_cv_header_stdlib_h" = xyes; then :
+#define HAVE_STDLIB_H 1
_ACEOF
fi
done
-{ echo "$as_me:$LINENO: checking for GNU libc compatible malloc" >&5
-echo $ECHO_N "checking for GNU libc compatible malloc... $ECHO_C" >&6; }
-if test "${ac_cv_func_malloc_0_nonnull+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for GNU libc compatible malloc" >&5
+$as_echo_n "checking for GNU libc compatible malloc... " >&6; }
+if ${ac_cv_func_malloc_0_nonnull+:} false; then :
else
ac_cv_func_malloc_0_nonnull=no
else
-/* confdefs.h. */
-_ACEOF
#if defined STDC_HEADERS || defined HAVE_STDLIB_H
# include <stdlib.h>
@@ -22273,52 +20596,24 @@
return 0;
_ACEOF
-esac
- ac_status=$?
-esac
- ac_status=$?
ac_cv_func_malloc_0_nonnull=yes
else
-ac_cv_func_malloc_0_nonnull=no
+ ac_cv_func_malloc_0_nonnull=no
fi
fi
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_func_malloc_0_nonnull" >&5
-echo "${ECHO_T}$ac_cv_func_malloc_0_nonnull" >&6; }
-if test $ac_cv_func_malloc_0_nonnull = yes; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_func_malloc_0_nonnull" >&5
+$as_echo "$ac_cv_func_malloc_0_nonnull" >&6; }
+if test $ac_cv_func_malloc_0_nonnull = yes; then :
-#define HAVE_MALLOC 1
-_ACEOF
+$as_echo "#define HAVE_MALLOC 1" >>confdefs.h
else
- cat >>confdefs.h <<\_ACEOF
-#define HAVE_MALLOC 0
-_ACEOF
+ $as_echo "#define HAVE_MALLOC 0" >>confdefs.h
*" malloc.$ac_objext "* ) ;;
@@ -22327,27 +20622,20 @@
esac
-#define malloc rpl_malloc
-_ACEOF
+$as_echo "#define malloc rpl_malloc" >>confdefs.h
fi
-{ echo "$as_me:$LINENO: checking for working memcmp" >&5
-echo $ECHO_N "checking for working memcmp... $ECHO_C" >&6; }
-if test "${ac_cv_func_memcmp_working+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for working memcmp" >&5
+$as_echo_n "checking for working memcmp... " >&6; }
+if ${ac_cv_func_memcmp_working+:} false; then :
else
ac_cv_func_memcmp_working=no
else
-/* confdefs.h. */
-_ACEOF
int
@@ -22382,42 +20670,18 @@
return 0;
_ACEOF
-esac
- ac_status=$?
-esac
- ac_status=$?
ac_cv_func_memcmp_working=yes
else
-ac_cv_func_memcmp_working=no
+ ac_cv_func_memcmp_working=no
fi
fi
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_func_memcmp_working" >&5
-echo "${ECHO_T}$ac_cv_func_memcmp_working" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_func_memcmp_working" >&5
+$as_echo "$ac_cv_func_memcmp_working" >&6; }
test $ac_cv_func_memcmp_working = no && case " $LIBOBJS " in
*" memcmp.$ac_objext "* ) ;;
*) LIBOBJS="$LIBOBJS memcmp.$ac_objext"
@@ -22425,164 +20689,27 @@
esac
-do
-fi
-else
-/* confdefs.h. */
-_ACEOF
-_ACEOF
-esac
- ac_status=$?
-else
-fi
-/* confdefs.h. */
-_ACEOF
-_ACEOF
-esac
- ac_status=$?
- }; then
-else
-fi
- yes:no: )
- no:yes:* )
- ( cat <<\_ASBOX
-_ASBOX
-esac
-else
-fi
-fi
+do :
_ACEOF
fi
done
-{ echo "$as_me:$LINENO: checking for GNU libc compatible realloc" >&5
-echo $ECHO_N "checking for GNU libc compatible realloc... $ECHO_C" >&6; }
-if test "${ac_cv_func_realloc_0_nonnull+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for GNU libc compatible realloc" >&5
+$as_echo_n "checking for GNU libc compatible realloc... " >&6; }
+if ${ac_cv_func_realloc_0_nonnull+:} false; then :
else
ac_cv_func_realloc_0_nonnull=no
else
-/* confdefs.h. */
-_ACEOF
@@ -22598,52 +20725,24 @@
return 0;
_ACEOF
-esac
- ac_status=$?
-esac
- ac_status=$?
ac_cv_func_realloc_0_nonnull=yes
else
-ac_cv_func_realloc_0_nonnull=no
+ ac_cv_func_realloc_0_nonnull=no
fi
fi
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_func_realloc_0_nonnull" >&5
-echo "${ECHO_T}$ac_cv_func_realloc_0_nonnull" >&6; }
-if test $ac_cv_func_realloc_0_nonnull = yes; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_func_realloc_0_nonnull" >&5
+$as_echo "$ac_cv_func_realloc_0_nonnull" >&6; }
+if test $ac_cv_func_realloc_0_nonnull = yes; then :
-#define HAVE_REALLOC 1
-_ACEOF
+$as_echo "#define HAVE_REALLOC 1" >>confdefs.h
else
-#define HAVE_REALLOC 0
-_ACEOF
+ $as_echo "#define HAVE_REALLOC 0" >>confdefs.h
*" realloc.$ac_objext "* ) ;;
@@ -22652,24 +20751,17 @@
esac
-#define realloc rpl_realloc
-_ACEOF
+$as_echo "#define realloc rpl_realloc" >>confdefs.h
fi
-{ echo "$as_me:$LINENO: checking return type of signal handlers" >&5
-echo $ECHO_N "checking return type of signal handlers... $ECHO_C" >&6; }
-if test "${ac_cv_type_signal+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking return type of signal handlers" >&5
+$as_echo_n "checking return type of signal handlers... " >&6; }
+if ${ac_cv_type_signal+:} false; then :
else
-/* confdefs.h. */
-_ACEOF
#include <signal.h>
@@ -22682,64 +20774,40 @@
return 0;
_ACEOF
-esac
- ac_status=$?
ac_cv_type_signal=int
else
- ac_cv_type_signal=void
+ ac_cv_type_signal=void
fi
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_type_signal" >&5
-echo "${ECHO_T}$ac_cv_type_signal" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_type_signal" >&5
+$as_echo "$ac_cv_type_signal" >&6; }
#define RETSIGTYPE $ac_cv_type_signal
_ACEOF
-{ echo "$as_me:$LINENO: checking whether lstat dereferences a symlink specified with a trailing slash" >&5
-echo $ECHO_N "checking whether lstat dereferences a symlink specified with a trailing slash... $ECHO_C" >&6; }
-if test "${ac_cv_func_lstat_dereferences_slashed_symlink+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether lstat correctly handles trailing slash" >&5
+$as_echo_n "checking whether lstat correctly handles trailing slash... " >&6; }
+if ${ac_cv_func_lstat_dereferences_slashed_symlink+:} false; then :
else
rm -f conftest.sym conftest.file
echo >conftest.file
if test "$as_ln_s" = "ln -s" && ln -s conftest.file conftest.sym; then
ac_cv_func_lstat_dereferences_slashed_symlink=no
else
-/* confdefs.h. */
-_ACEOF
int
main ()
struct stat sbuf;
- /* Linux will dereference the symlink and fail.
+ /* Linux will dereference the symlink and fail, as required by POSIX.
That is better in the sense that it means we will not
have to compile and use the lstat wrapper. */
return lstat ("conftest.sym/", &sbuf) == 0;
@@ -22747,39 +20815,15 @@
return 0;
_ACEOF
-esac
- ac_status=$?
-esac
- ac_status=$?
ac_cv_func_lstat_dereferences_slashed_symlink=yes
else
-ac_cv_func_lstat_dereferences_slashed_symlink=no
+ ac_cv_func_lstat_dereferences_slashed_symlink=no
fi
fi
else
# If the `ln -s' command failed, then we probably don't even
# have an lstat function.
@@ -22788,8 +20832,8 @@
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_func_lstat_dereferences_slashed_symlink" >&5
-echo "${ECHO_T}$ac_cv_func_lstat_dereferences_slashed_symlink" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_func_lstat_dereferences_slashed_symlink" >&5
+$as_echo "$ac_cv_func_lstat_dereferences_slashed_symlink" >&6; }
test $ac_cv_func_lstat_dereferences_slashed_symlink = yes &&
@@ -22798,7 +20842,7 @@
_ACEOF
-if test $ac_cv_func_lstat_dereferences_slashed_symlink = no; then
+if test "x$ac_cv_func_lstat_dereferences_slashed_symlink" = xno; then
*" lstat.$ac_objext "* ) ;;
*) LIBOBJS="$LIBOBJS lstat.$ac_objext"
@@ -22807,19 +20851,15 @@
fi
-{ echo "$as_me:$LINENO: checking whether stat accepts an empty string" >&5
-echo $ECHO_N "checking whether stat accepts an empty string... $ECHO_C" >&6; }
-if test "${ac_cv_func_stat_empty_string_bug+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether stat accepts an empty string" >&5
+$as_echo_n "checking whether stat accepts an empty string... " >&6; }
+if ${ac_cv_func_stat_empty_string_bug+:} false; then :
else
ac_cv_func_stat_empty_string_bug=yes
else
-/* confdefs.h. */
-_ACEOF
int
@@ -22831,42 +20871,18 @@
return 0;
_ACEOF
-esac
- ac_status=$?
-esac
- ac_status=$?
ac_cv_func_stat_empty_string_bug=no
else
-ac_cv_func_stat_empty_string_bug=yes
+ ac_cv_func_stat_empty_string_bug=yes
fi
fi
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_func_stat_empty_string_bug" >&5
-echo "${ECHO_T}$ac_cv_func_stat_empty_string_bug" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_func_stat_empty_string_bug" >&5
+$as_echo "$ac_cv_func_stat_empty_string_bug" >&6; }
if test $ac_cv_func_stat_empty_string_bug = yes; then
*" stat.$ac_objext "* ) ;;
@@ -22881,111 +20897,24 @@
fi
for ac_func in strftime
-do
-as_ac_var=`echo "ac_cv_func_$ac_func" | $as_tr_sh`
-{ echo "$as_me:$LINENO: checking for $ac_func" >&5
-echo $ECHO_N "checking for $ac_func... $ECHO_C" >&6; }
-if { as_var=$as_ac_var; eval "test \"\${$as_var+set}\" = set"; }; then
-else
-/* confdefs.h. */
-_ACEOF
-/* Define $ac_func to an innocuous variant, in case <limits.h> declares $ac_func.
- For example, HP-UX 11i <limits.h> declares gettimeofday. */
-#define $ac_func innocuous_$ac_func
-/* System header to define __stub macros and hopefully few prototypes,
- which can conflict with char $ac_func (); below.
- Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
- <limits.h> exists even on freestanding compilers. */
-#ifdef __STDC__
-# include <limits.h>
-#else
-# include <assert.h>
-#endif
-#undef $ac_func
-/* Override any GCC internal prototype to avoid an error.
- Use char because int might match the return type of a GCC
- builtin and then its argument prototype would still apply. */
-#ifdef __cplusplus
-extern "C"
-#endif
-char $ac_func ();
-/* The GNU C library defines this for functions which it implements
- to always fail with ENOSYS. Some functions are actually named
- something starting with __ and the normal name is an alias. */
-#if defined __stub_$ac_func || defined __stub___$ac_func
-choke me
-#endif
-int
-main ()
-return $ac_func ();
- return 0;
-_ACEOF
-rm -f conftest.$ac_objext conftest$ac_exeext
-esac
- (eval "$ac_link") 2>conftest.er1
- ac_status=$?
- } && test -s conftest$ac_exeext &&
- $as_test_x conftest$ac_exeext; then
- eval "$as_ac_var=yes"
-else
- eval "$as_ac_var=no"
-fi
-rm -f core conftest.err conftest.$ac_objext conftest_ipa8_conftest.oo \
- conftest$ac_exeext conftest.$ac_ext
-fi
-ac_res=`eval echo '${'$as_ac_var'}'`
-if test `eval echo '${'$as_ac_var'}'` = yes; then
+do :
+ ac_fn_c_check_func "$LINENO" "strftime" "ac_cv_func_strftime"
+if test "x$ac_cv_func_strftime" = xyes; then :
-#define `echo "HAVE_$ac_func" | $as_tr_cpp` 1
+#define HAVE_STRFTIME 1
_ACEOF
else
# strftime is in -lintl on SCO UNIX.
-{ echo "$as_me:$LINENO: checking for strftime in -lintl" >&5
-echo $ECHO_N "checking for strftime in -lintl... $ECHO_C" >&6; }
-if test "${ac_cv_lib_intl_strftime+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for strftime in -lintl" >&5
+$as_echo_n "checking for strftime in -lintl... " >&6; }
+if ${ac_cv_lib_intl_strftime+:} false; then :
else
ac_check_lib_save_LIBS=$LIBS
LIBS="-lintl $LIBS"
-/* confdefs.h. */
-_ACEOF
+cat confdefs.h - <<_ACEOF >conftest.$ac_ext
@@ -23003,42 +20932,19 @@
return 0;
_ACEOF
-esac
- ac_status=$?
ac_cv_lib_intl_strftime=yes
else
- ac_cv_lib_intl_strftime=no
+ ac_cv_lib_intl_strftime=no
fi
+rm -f core conftest.err conftest.$ac_objext \
+ conftest$ac_exeext conftest.$ac_ext
LIBS=$ac_check_lib_save_LIBS
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_lib_intl_strftime" >&5
-echo "${ECHO_T}$ac_cv_lib_intl_strftime" >&6; }
-if test $ac_cv_lib_intl_strftime = yes; then
-#define HAVE_STRFTIME 1
-_ACEOF
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_intl_strftime" >&5
+$as_echo "$ac_cv_lib_intl_strftime" >&6; }
+if test "x$ac_cv_lib_intl_strftime" = xyes; then :
+ $as_echo "#define HAVE_STRFTIME 1" >>confdefs.h
LIBS="-lintl $LIBS"
fi
@@ -23046,19 +20952,15 @@
fi
done
-{ echo "$as_me:$LINENO: checking for working strtod" >&5
-echo $ECHO_N "checking for working strtod... $ECHO_C" >&6; }
-if test "${ac_cv_func_strtod+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for working strtod" >&5
+$as_echo_n "checking for working strtod... " >&6; }
+if ${ac_cv_func_strtod+:} false; then :
else
ac_cv_func_strtod=no
else
-/* confdefs.h. */
-_ACEOF
@@ -23091,42 +20993,18 @@
_ACEOF
-esac
- ac_status=$?
-esac
- ac_status=$?
ac_cv_func_strtod=yes
else
-ac_cv_func_strtod=no
+ ac_cv_func_strtod=no
fi
fi
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_func_strtod" >&5
-echo "${ECHO_T}$ac_cv_func_strtod" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_func_strtod" >&5
+$as_echo "$ac_cv_func_strtod" >&6; }
if test $ac_cv_func_strtod = no; then
*" strtod.$ac_objext "* ) ;;
@@ -23134,101 +21012,20 @@
esac
-{ echo "$as_me:$LINENO: checking for pow" >&5
-echo $ECHO_N "checking for pow... $ECHO_C" >&6; }
-if test "${ac_cv_func_pow+set}" = set; then
-else
-/* confdefs.h. */
-_ACEOF
-/* Define pow to an innocuous variant, in case <limits.h> declares pow.
-#define pow innocuous_pow
+ac_fn_c_check_func "$LINENO" "pow" "ac_cv_func_pow"
+if test "x$ac_cv_func_pow" = xyes; then :
- which can conflict with char pow (); below.
-#ifdef __STDC__
-#else
-#endif
-#undef pow
-#ifdef __cplusplus
-extern "C"
-#endif
-char pow ();
-#if defined __stub_pow || defined __stub___pow
-choke me
-#endif
-int
-main ()
-return pow ();
- return 0;
-_ACEOF
-esac
- ac_status=$?
- ac_cv_func_pow=yes
-else
- ac_cv_func_pow=no
fi
-fi
-{ echo "$as_me:$LINENO: result: $ac_cv_func_pow" >&5
-echo "${ECHO_T}$ac_cv_func_pow" >&6; }
if test $ac_cv_func_pow = no; then
- { echo "$as_me:$LINENO: checking for pow in -lm" >&5
-echo $ECHO_N "checking for pow in -lm... $ECHO_C" >&6; }
-if test "${ac_cv_lib_m_pow+set}" = set; then
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking for pow in -lm" >&5
+$as_echo_n "checking for pow in -lm... " >&6; }
+if ${ac_cv_lib_m_pow+:} false; then :
else
LIBS="-lm $LIBS"
-/* confdefs.h. */
-_ACEOF
@@ -23246,149 +21043,35 @@
return 0;
_ACEOF
-esac
- ac_status=$?
ac_cv_lib_m_pow=yes
else
- ac_cv_lib_m_pow=no
+ ac_cv_lib_m_pow=no
fi
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_lib_m_pow" >&5
-echo "${ECHO_T}$ac_cv_lib_m_pow" >&6; }
-if test $ac_cv_lib_m_pow = yes; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_m_pow" >&5
+$as_echo "$ac_cv_lib_m_pow" >&6; }
+if test "x$ac_cv_lib_m_pow" = xyes; then :
POW_LIB=-lm
else
- { echo "$as_me:$LINENO: WARNING: cannot find library containing definition of pow" >&5
-echo "$as_me: WARNING: cannot find library containing definition of pow" >&2;}
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: cannot find library containing definition of pow" >&5
+$as_echo "$as_me: WARNING: cannot find library containing definition of pow" >&2;}
fi
fi
fi
for ac_func in floor gettimeofday localtime_r memset pow sqrt strcasecmp strchr strdup strerror strstr strtoul
-do
-else
-/* confdefs.h. */
-_ACEOF
-#ifdef __STDC__
-#else
-#endif
-#undef $ac_func
-#ifdef __cplusplus
-extern "C"
-#endif
-char $ac_func ();
-choke me
-#endif
-int
-main ()
- return 0;
-_ACEOF
-esac
- ac_status=$?
-else
-fi
-fi
+do :
+ as_ac_var=`$as_echo "ac_cv_func_$ac_func" | $as_tr_sh`
+ac_fn_c_check_func "$LINENO" "$ac_func" "$as_ac_var"
+if eval test \"x\$"$as_ac_var"\" = x"yes"; then :
+#define `$as_echo "HAVE_$ac_func" | $as_tr_cpp` 1
_ACEOF
fi
@@ -23413,9 +21096,7 @@
if test "$db_cv_java" = "yes"; then
# Java requires shared libraries.
if test `$LIBTOOL_PROG --config | grep build_libtool_libs | grep no` 2>/dev/null; then
- { { echo "$as_me:$LINENO: error: Java requires shared libraries" >&5
-echo "$as_me: error: Java requires shared libraries" >&2;}
+ as_fn_error $? "Java requires shared libraries" "$LINENO" 5
fi
@@ -23424,10 +21105,10 @@
do
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-if test "${ac_cv_prog_JAVAC+set}" = set; then
+if ${ac_cv_prog_JAVAC+:} false; then :
else
if test -n "$JAVAC"; then
ac_cv_prog_JAVAC="$JAVAC" # Let the user override the test.
@@ -23437,25 +21118,25 @@
do
IFS=$as_save_IFS
ac_cv_prog_JAVAC="$ac_prog"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
JAVAC=$ac_cv_prog_JAVAC
- { echo "$as_me:$LINENO: result: $JAVAC" >&5
-echo "${ECHO_T}$JAVAC" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $JAVAC" >&5
+$as_echo "$JAVAC" >&6; }
else
- { echo "$as_me:$LINENO: result: no" >&5
-echo "${ECHO_T}no" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
+$as_echo "no" >&6; }
fi
@@ -23467,10 +21148,10 @@
do
else
@@ -23480,25 +21161,25 @@
do
IFS=$as_save_IFS
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
else
fi
@@ -23507,42 +21188,38 @@
test -n "$JAVAC" || JAVAC="$JAVAPREFIX"
fi
-test "x$JAVAC" = x && { { echo "$as_me:$LINENO: error: no acceptable Java compiler found in \$PATH" >&5
-echo "$as_me: error: no acceptable Java compiler found in \$PATH" >&2;}
+test "x$JAVAC" = x && as_fn_error $? "no acceptable Java compiler found in \$PATH" "$LINENO" 5
-{ echo "$as_me:$LINENO: checking if $JAVAC works" >&5
-echo $ECHO_N "checking if $JAVAC works... $ECHO_C" >&6; }
-if test "${ac_cv_prog_javac_works+set}" = set; then
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if $JAVAC works" >&5
+$as_echo_n "checking if $JAVAC works... " >&6; }
+if ${ac_cv_prog_javac_works+:} false; then :
else
JAVA_TEST=Test.java
CLASS_TEST=Test.class
cat << \EOF > $JAVA_TEST
-/* #line 23523 "configure" */
+/* #line 21202 "configure" */
public class Test {
EOF
if { ac_try='$JAVAC $JAVACFLAGS $JAVA_TEST'
- { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+ { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$ac_try\""; } >&5
(eval $ac_try) 2>&5
ac_status=$?
- (exit $ac_status); }; } >/dev/null 2>&1; then
+ $as_echo "$as_me:${as_lineno-$LINENO}: \$? = $ac_status" >&5
+ test $ac_status = 0; }; } >/dev/null 2>&1; then
ac_cv_prog_javac_works=yes
else
- { { echo "$as_me:$LINENO: error: The Java compiler $JAVAC failed (see config.log, check the CLASSPATH?)" >&5
-echo "$as_me: error: The Java compiler $JAVAC failed (see config.log, check the CLASSPATH?)" >&2;}
+ as_fn_error $? "The Java compiler $JAVAC failed (see config.log, check the CLASSPATH?)" "$LINENO" 5
echo "configure: failed program was:" >&5
cat $JAVA_TEST >&5
fi
rm -f $JAVA_TEST $CLASS_TEST
fi
-{ echo "$as_me:$LINENO: result: $ac_cv_prog_javac_works" >&5
-echo "${ECHO_T}$ac_cv_prog_javac_works" >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_prog_javac_works" >&5
+$as_echo "$ac_cv_prog_javac_works" >&6; }
@@ -23551,10 +21228,10 @@
do
-if test "${ac_cv_prog_JAR+set}" = set; then
+if ${ac_cv_prog_JAR+:} false; then :
else
if test -n "$JAR"; then
ac_cv_prog_JAR="$JAR" # Let the user override the test.
@@ -23564,25 +21241,25 @@
do
IFS=$as_save_IFS
ac_cv_prog_JAR="$ac_prog"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
JAR=$ac_cv_prog_JAR
- { echo "$as_me:$LINENO: result: $JAR" >&5
-echo "${ECHO_T}$JAR" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $JAR" >&5
+$as_echo "$JAR" >&6; }
else
fi
@@ -23594,10 +21271,10 @@
do
else
@@ -23607,25 +21284,25 @@
do
IFS=$as_save_IFS
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
fi
fi
JAR=$ac_cv_prog_JAR
else
fi
@@ -23634,23 +21311,19 @@
test -n "$JAR" || JAR="$JAVAPREFIX"
fi
-test "x$JAR" = x && { { echo "$as_me:$LINENO: error: no acceptable jar program found in \$PATH" >&5
-echo "$as_me: error: no acceptable jar program found in \$PATH" >&2;}
+test "x$JAR" = x && as_fn_error $? "no acceptable jar program found in \$PATH" "$LINENO" 5
JNI_INCLUDE_DIRS=""
-test "x$JAVAC" = x && { { echo "$as_me:$LINENO: error: '$JAVAC' undefined" >&5
-echo "$as_me: error: '$JAVAC' undefined" >&2;}
+test "x$JAVAC" = x && as_fn_error $? "'$JAVAC' undefined" "$LINENO" 5
# Extract the first word of "$JAVAC", so it can be a program name with args.
set dummy $JAVAC; ac_word=$2
-if test "${ac_cv_path__ACJNI_JAVAC+set}" = set; then
+if ${ac_cv_path__ACJNI_JAVAC+:} false; then :
else
case $_ACJNI_JAVAC in
@@ -23662,14 +21335,14 @@
do
IFS=$as_save_IFS
ac_cv_path__ACJNI_JAVAC="$as_dir/$ac_word$ac_exec_ext"
break 2
fi
done
-done
+ done
IFS=$as_save_IFS
test -z "$ac_cv_path__ACJNI_JAVAC" && ac_cv_path__ACJNI_JAVAC="$JAVAC"
@@ -23678,41 +21351,37 @@
fi
_ACJNI_JAVAC=$ac_cv_path__ACJNI_JAVAC
if test -n "$_ACJNI_JAVAC"; then
- { echo "$as_me:$LINENO: result: $_ACJNI_JAVAC" >&5
-echo "${ECHO_T}$_ACJNI_JAVAC" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $_ACJNI_JAVAC" >&5
+$as_echo "$_ACJNI_JAVAC" >&6; }
else
fi
-test ! -x "$_ACJNI_JAVAC" && { { echo "$as_me:$LINENO: error: $JAVAC could not be found in path" >&5
-echo "$as_me: error: $JAVAC could not be found in path" >&2;}
-{ echo "$as_me:$LINENO: checking absolute path of $JAVAC" >&5
-echo $ECHO_N "checking absolute path of $JAVAC... $ECHO_C" >&6; }
+test ! -x "$_ACJNI_JAVAC" && as_fn_error $? "$JAVAC could not be found in path" "$LINENO" 5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking absolute path of $JAVAC" >&5
+$as_echo_n "checking absolute path of $JAVAC... " >&6; }
case "$_ACJNI_JAVAC" in
-/*) { echo "$as_me:$LINENO: result: $_ACJNI_JAVAC" >&5
-echo "${ECHO_T}$_ACJNI_JAVAC" >&6; };;
-*) { { echo "$as_me:$LINENO: error: $_ACJNI_JAVAC is not an absolute path name" >&5
-echo "$as_me: error: $_ACJNI_JAVAC is not an absolute path name" >&2;}
- { (exit 1); exit 1; }; };;
+/*) { $as_echo "$as_me:${as_lineno-$LINENO}: result: $_ACJNI_JAVAC" >&5
+$as_echo "$_ACJNI_JAVAC" >&6; };;
+*) as_fn_error $? "$_ACJNI_JAVAC is not an absolute path name" "$LINENO" 5;;
esac
# find the include directory relative to the javac executable
_cur=""$_ACJNI_JAVAC""
while ls -ld "$_cur" 2>/dev/null | grep " -> " >/dev/null; do
- { echo "$as_me:$LINENO: checking symlink for $_cur" >&5
-echo $ECHO_N "checking symlink for $_cur... $ECHO_C" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking symlink for $_cur" >&5
+$as_echo_n "checking symlink for $_cur... " >&6; }
_slink=`ls -ld "$_cur" | sed 's/.* -> //'`
case "$_slink" in
/*) _cur="$_slink";;
# 'X' avoids triggering unwanted echo options.
*) _cur=`echo "X$_cur" | sed -e 's/^X//' -e 's:[^/]*$::'`"$_slink";;
esac
- { echo "$as_me:$LINENO: result: $_cur" >&5
-echo "${ECHO_T}$_cur" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $_cur" >&5
+$as_echo "$_cur" >&6; }
done
_ACJNI_FOLLOWED="$_cur"
@@ -23789,8 +21458,8 @@
# Set SOSUFFIX and friends
- { echo "$as_me:$LINENO: checking MODSUFFIX from libtool" >&5
-echo $ECHO_N "checking MODSUFFIX from libtool... $ECHO_C" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking MODSUFFIX from libtool" >&5
+$as_echo_n "checking MODSUFFIX from libtool... " >&6; }
module=yes
versuffix=""
@@ -23802,17 +21471,17 @@
if test "$_SOSUFFIX_MESSAGE" = ""; then
_SOSUFFIX_MESSAGE=yes
- { echo "$as_me:$LINENO: WARNING: libtool may not know about this architecture." >&5
-echo "$as_me: WARNING: libtool may not know about this architecture." >&2;}
- { echo "$as_me:$LINENO: WARNING: assuming $_SUFFIX suffix for dynamic libraries." >&5
-echo "$as_me: WARNING: assuming $_SUFFIX suffix for dynamic libraries." >&2;}
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: libtool may not know about this architecture." >&5
+$as_echo "$as_me: WARNING: libtool may not know about this architecture." >&2;}
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: assuming $_SUFFIX suffix for dynamic libraries." >&5
+$as_echo "$as_me: WARNING: assuming $_SUFFIX suffix for dynamic libraries." >&2;}
fi
fi
fi
MODSUFFIX=$_SOSUFFIX
- { echo "$as_me:$LINENO: result: $MODSUFFIX" >&5
-echo "${ECHO_T}$MODSUFFIX" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $MODSUFFIX" >&5
+$as_echo "$MODSUFFIX" >&6; }
@@ -23838,14 +21507,12 @@
if test "$db_cv_tcl" = "yes"; then
- { { echo "$as_me:$LINENO: error: Tcl requires shared libraries" >&5
-echo "$as_me: error: Tcl requires shared libraries" >&2;}
+ as_fn_error $? "Tcl requires shared libraries" "$LINENO" 5
fi
- if test "${ac_cv_c_tclconfig+set}" = set; then
+ if ${ac_cv_c_tclconfig+:} false; then :
else
@@ -23854,9 +21521,7 @@
if test -f "${with_tclconfig}/tclConfig.sh" ; then
ac_cv_c_tclconfig=`(cd ${with_tclconfig}; pwd)`
else
- { { echo "$as_me:$LINENO: error: ${with_tclconfig} directory doesn't contain tclConfig.sh" >&5
-echo "$as_me: error: ${with_tclconfig} directory doesn't contain tclConfig.sh" >&2;}
+ as_fn_error $? "${with_tclconfig} directory doesn't contain tclConfig.sh" "$LINENO" 5
fi
fi
@@ -23876,32 +21541,28 @@
if test x"${ac_cv_c_tclconfig}" = x ; then
TCL_BIN_DIR="# no Tcl configs found"
- { { echo "$as_me:$LINENO: error: can't find Tcl configuration definitions" >&5
-echo "$as_me: error: can't find Tcl configuration definitions" >&2;}
+ as_fn_error $? "can't find Tcl configuration definitions" "$LINENO" 5
else
TCL_BIN_DIR=${ac_cv_c_tclconfig}
fi
- { echo "$as_me:$LINENO: checking for existence of $TCL_BIN_DIR/tclConfig.sh" >&5
-echo $ECHO_N "checking for existence of $TCL_BIN_DIR/tclConfig.sh... $ECHO_C" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking for existence of $TCL_BIN_DIR/tclConfig.sh" >&5
+$as_echo_n "checking for existence of $TCL_BIN_DIR/tclConfig.sh... " >&6; }
if test -f "$TCL_BIN_DIR/tclConfig.sh" ; then
- { echo "$as_me:$LINENO: result: loading" >&5
-echo "${ECHO_T}loading" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: loading" >&5
+$as_echo "loading" >&6; }
. $TCL_BIN_DIR/tclConfig.sh
else
- { echo "$as_me:$LINENO: result: file not found" >&5
-echo "${ECHO_T}file not found" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: file not found" >&5
+$as_echo "file not found" >&6; }
fi
# DB requires at least version 8.4.
if test ${TCL_MAJOR_VERSION} -lt 8 \
-o ${TCL_MAJOR_VERSION} -eq 8 -a ${TCL_MINOR_VERSION} -lt 4; then
- { { echo "$as_me:$LINENO: error: Berkeley DB requires Tcl version 8.4 or better." >&5
-echo "$as_me: error: Berkeley DB requires Tcl version 8.4 or better." >&2;}
+ as_fn_error $? "Berkeley DB requires Tcl version 8.4 or better." "$LINENO" 5
fi
# The eval is required to do substitution (for example, the TCL_DBGX
@@ -23940,24 +21601,19 @@
# Test that zlib actually runs
if test "$db_cv_compression" != "no"; then
- { echo "$as_me:$LINENO: checking if a zlib test program runs" >&5
-echo $ECHO_N "checking if a zlib test program runs... $ECHO_C" >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking if a zlib test program runs" >&5
+$as_echo_n "checking if a zlib test program runs... " >&6; }
OLD_CFLAGS="$CFLAGS"
CFLAGS="$zlib_include"
OLD_LIBS="$LIBS"
LIBS="$zlib_lib $zlib_library"
- { { echo "$as_me:$LINENO: error: cannot run test program while cross compiling
-See \`config.log' for more details." >&5
-echo "$as_me: error: cannot run test program while cross compiling
-See \`config.log' for more details." >&2;}
+ { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
+$as_echo "$as_me: error: in \`$ac_pwd':" >&2;}
+as_fn_error $? "cannot run test program while cross compiling
+See \`config.log' for more details" "$LINENO" 5; }
else
-/* confdefs.h. */
-_ACEOF
#include "zlib.h"
int main()
@@ -23969,53 +21625,29 @@
return compress(dest, &destLen, src, srcLen);
_ACEOF
-esac
- ac_status=$?
-esac
- ac_status=$?
else
-{ echo "$as_me:$LINENO: result: no" >&5
zlib_lib=""
zlib_library=""
zlib_include=""
db_cv_compression="no"
fi
fi
CFLAGS="$OLD_CFLAGS"
LIBS="$OLD_LIBS"
fi
# Patch libtool to not use rpath if required
if test "$db_cv_rpath" = "no"; then
- { echo "$as_me:$LINENO: result: Patching libtool to not use rpath." >&5
-echo "${ECHO_T}Patching libtool to not use rpath." >&6; }
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: Patching libtool to not use rpath." >&5
+$as_echo "Patching libtool to not use rpath." >&6; }
sed < libtool > libtool-2 \
's/^hardcode_libdir_flag_spec.*$'/'hardcode_libdir_flag_spec=" -D__LIBTOOL_NO_RPATH__ "/'
mv libtool-2 libtool
@@ -24051,12 +21683,13 @@
case $ac_val in #(
*${as_nl}*)
case $ac_var in #(
- *_cv_*) { echo "$as_me:$LINENO: WARNING: Cache variable $ac_var contains a newline." >&5
-echo "$as_me: WARNING: Cache variable $ac_var contains a newline." >&2;} ;;
+ *_cv_*) { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: cache variable $ac_var contains a newline" >&5
+$as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
esac
case $ac_var in #(
_ | IFS | as_nl) ;; #(
- *) $as_unset $ac_var ;;
+ BASH_ARGV | BASH_SOURCE) eval $ac_var= ;; #(
+ *) { eval $ac_var=; unset $ac_var;} ;;
esac ;;
esac
done
@@ -24064,8 +21697,8 @@
(set) 2>&1 |
case $as_nl`(ac_space=' '; set) 2>&1` in #(
*${as_nl}ac_space=\ *)
- # `set' does not quote correctly, so add quotes (double-quote
- # substitution turns \\\\ into \\, and sed turns \\ into \).
+ # `set' does not quote correctly, so add quotes: double-quote
+ # substitution turns \\\\ into \\, and sed turns \\ into \.
sed -n \
"s/'/'\\\\''/g;
s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='\\2'/p"
@@ -24087,13 +21720,24 @@
:end' >>confcache
if diff "$cache_file" confcache >/dev/null 2>&1; then :; else
if test -w "$cache_file"; then
- test "x$cache_file" != "x/dev/null" &&
- { echo "$as_me:$LINENO: updating cache $cache_file" >&5
-echo "$as_me: updating cache $cache_file" >&6;}
- cat confcache >$cache_file
+ if test "x$cache_file" != "x/dev/null"; then
+ { $as_echo "$as_me:${as_lineno-$LINENO}: updating cache $cache_file" >&5
+$as_echo "$as_me: updating cache $cache_file" >&6;}
+ if test ! -f "$cache_file" || test -h "$cache_file"; then
+ cat confcache >"$cache_file"
+ else
+ case $cache_file in #(
+ mv -f confcache "$cache_file"$$ &&
+ mv -f "$cache_file"$$ "$cache_file" ;; #(
+ mv -f confcache "$cache_file" ;;
+ esac
+ fi
+ fi
else
- { echo "$as_me:$LINENO: not updating unwritable cache $cache_file" >&5
-echo "$as_me: not updating unwritable cache $cache_file" >&6;}
+ { $as_echo "$as_me:${as_lineno-$LINENO}: not updating unwritable cache $cache_file" >&5
+$as_echo "$as_me: not updating unwritable cache $cache_file" >&6;}
fi
fi
rm -f confcache
@@ -24106,14 +21750,15 @@
ac_libobjs=
ac_ltlibobjs=
+U=
for ac_i in : $LIBOBJS; do test "x$ac_i" = x: && continue
# 1. Remove the extension, and $U if already installed.
ac_script='s/\$U\././;s/\.o$//;s/\.obj$//'
- ac_i=`echo "$ac_i" | sed "$ac_script"`
+ ac_i=`$as_echo "$ac_i" | sed "$ac_script"`
# 2. Prepend LIBOBJDIR. When used with automake>=1.10 LIBOBJDIR
# will be set to the directory where LIBOBJS objects are built.
- ac_libobjs="$ac_libobjs \${LIBOBJDIR}$ac_i\$U.$ac_objext"
- ac_ltlibobjs="$ac_ltlibobjs \${LIBOBJDIR}$ac_i"'$U.lo'
+ as_fn_append ac_libobjs " \${LIBOBJDIR}$ac_i\$U.$ac_objext"
+ as_fn_append ac_ltlibobjs " \${LIBOBJDIR}$ac_i"'$U.lo'
done
LIBOBJS=$ac_libobjs
@@ -24121,61 +21766,42 @@
if test -z "${BUILD_TCL_TRUE}" && test -z "${BUILD_TCL_FALSE}"; then
- { { echo "$as_me:$LINENO: error: conditional \"BUILD_TCL\" was never defined.
-Usually this means the macro was only invoked conditionally." >&5
-echo "$as_me: error: conditional \"BUILD_TCL\" was never defined.
-Usually this means the macro was only invoked conditionally." >&2;}
+ as_fn_error $? "conditional \"BUILD_TCL\" was never defined.
+Usually this means the macro was only invoked conditionally." "$LINENO" 5
fi
if test -z "${BUILD_JAVA_TRUE}" && test -z "${BUILD_JAVA_FALSE}"; then
- { { echo "$as_me:$LINENO: error: conditional \"BUILD_JAVA\" was never defined.
-echo "$as_me: error: conditional \"BUILD_JAVA\" was never defined.
+ as_fn_error $? "conditional \"BUILD_JAVA\" was never defined.
fi
if test -z "${BUILD_TEST_TRUE}" && test -z "${BUILD_TEST_FALSE}"; then
- { { echo "$as_me:$LINENO: error: conditional \"BUILD_TEST\" was never defined.
-echo "$as_me: error: conditional \"BUILD_TEST\" was never defined.
+ as_fn_error $? "conditional \"BUILD_TEST\" was never defined.
fi
if test -z "${USE_COMPRESSION_TRUE}" && test -z "${USE_COMPRESSION_FALSE}"; then
- { { echo "$as_me:$LINENO: error: conditional \"USE_COMPRESSION\" was never defined.
-echo "$as_me: error: conditional \"USE_COMPRESSION\" was never defined.
+ as_fn_error $? "conditional \"USE_COMPRESSION\" was never defined.
fi
if test -z "${AMDEP_TRUE}" && test -z "${AMDEP_FALSE}"; then
- { { echo "$as_me:$LINENO: error: conditional \"AMDEP\" was never defined.
-echo "$as_me: error: conditional \"AMDEP\" was never defined.
+ as_fn_error $? "conditional \"AMDEP\" was never defined.
fi
if test -z "${am__fastdepCC_TRUE}" && test -z "${am__fastdepCC_FALSE}"; then
- { { echo "$as_me:$LINENO: error: conditional \"am__fastdepCC\" was never defined.
-echo "$as_me: error: conditional \"am__fastdepCC\" was never defined.
+ as_fn_error $? "conditional \"am__fastdepCC\" was never defined.
fi
if test -z "${am__fastdepCXX_TRUE}" && test -z "${am__fastdepCXX_FALSE}"; then
- { { echo "$as_me:$LINENO: error: conditional \"am__fastdepCXX\" was never defined.
-echo "$as_me: error: conditional \"am__fastdepCXX\" was never defined.
+ as_fn_error $? "conditional \"am__fastdepCXX\" was never defined.
fi
-: ${CONFIG_STATUS=./config.status}
+: "${CONFIG_STATUS=./config.status}"
+ac_write_fail=0
ac_clean_files_save=$ac_clean_files
ac_clean_files="$ac_clean_files $CONFIG_STATUS"
-{ echo "$as_me:$LINENO: creating $CONFIG_STATUS" >&5
-echo "$as_me: creating $CONFIG_STATUS" >&6;}
-cat >$CONFIG_STATUS <<_ACEOF
+{ $as_echo "$as_me:${as_lineno-$LINENO}: creating $CONFIG_STATUS" >&5
+$as_echo "$as_me: creating $CONFIG_STATUS" >&6;}
+as_write_fail=0
+cat >$CONFIG_STATUS <<_ASEOF || as_write_fail=1
#! $SHELL
# Generated by $as_me.
# Run this file to recreate the current configuration.
@@ -24185,59 +21811,79 @@
debug=false
ac_cs_recheck=false
ac_cs_silent=false
SHELL=\${CONFIG_SHELL-$SHELL}
-_ACEOF
+export SHELL
+_ASEOF
+cat >>$CONFIG_STATUS <<\_ASEOF || as_write_fail=1
+## M4sh Initialization. ##
-cat >>$CONFIG_STATUS <<\_ACEOF
-## M4sh Initialization. ##
# Be more Bourne compatible
DUALCASE=1; export DUALCASE # for MKS sh
-if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
+if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then :
emulate sh
NULLCMD=:
- # Zsh 3.x and 4.x performs word splitting on ${1+"$@"}, which
+ # Pre-4.2 versions of Zsh do word splitting on ${1+"$@"}, which
# is contrary to our usage. Disable this feature.
alias -g '${1+"$@"}'='"$@"'
setopt NO_GLOB_SUBST
else
- case `(set -o) 2>/dev/null` in
- *posix*) set -o posix ;;
+ case `(set -o) 2>/dev/null` in #(
+ *posix*) :
+ set -o posix ;; #(
esac
fi
-# PATH needs CR
-# Avoid depending upon Character Ranges.
-as_cr_letters='abcdefghijklmnopqrstuvwxyz'
-as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
-as_cr_Letters=$as_cr_letters$as_cr_LETTERS
-as_cr_digits='0123456789'
-as_cr_alnum=$as_cr_Letters$as_cr_digits
-# The user is always right.
-if test "${PATH_SEPARATOR+set}" != set; then
- echo "#! /bin/sh" >conf$$.sh
- echo "exit 0" >>conf$$.sh
- chmod +x conf$$.sh
- if (PATH="/nonexistent;."; conf$$.sh) >/dev/null 2>&1; then
- PATH_SEPARATOR=';'
+as_nl='
+export as_nl
+# Printing a long string crashes Solaris 7 /usr/bin/printf.
+as_echo='\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\'
+as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo
+as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo$as_echo
+# Prefer a ksh shell builtin over an external printf program on Solaris,
+# but without wasting forks for bash or zsh.
+if test -z "$BASH_VERSION$ZSH_VERSION" \
+ && (test "X`print -r -- $as_echo`" = "X$as_echo") 2>/dev/null; then
+ as_echo='print -r --'
+ as_echo_n='print -rn --'
+elif (test "X`printf %s $as_echo`" = "X$as_echo") 2>/dev/null; then
+ as_echo='printf %s\n'
+ as_echo_n='printf %s'
+else
+ if test "X`(/usr/ucb/echo -n -n $as_echo) 2>/dev/null`" = "X-n $as_echo"; then
+ as_echo_body='eval /usr/ucb/echo -n "$1$as_nl"'
+ as_echo_n='/usr/ucb/echo -n'
else
- PATH_SEPARATOR=:
+ as_echo_body='eval expr "X$1" : "X\\(.*\\)"'
+ as_echo_n_body='eval
+ arg=$1;
+ case $arg in #(
+ *"$as_nl"*)
+ expr "X$arg" : "X\\(.*\\)$as_nl";
+ arg=`expr "X$arg" : ".*$as_nl\\(.*\\)"`;;
+ esac;
+ expr "X$arg" : "X\\(.*\\)" | tr -d "$as_nl"
+ export as_echo_n_body
+ as_echo_n='sh -c $as_echo_n_body as_echo'
fi
- rm -f conf$$.sh
+ export as_echo_body
+ as_echo='sh -c $as_echo_body as_echo'
fi
-# Support unset when possible.
-if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then
- as_unset=unset
-else
- as_unset=false
+# The user is always right.
+if test "${PATH_SEPARATOR+set}" != set; then
+ PATH_SEPARATOR=:
+ (PATH='/bin;/bin'; FPATH=$PATH; sh -c :) >/dev/null 2>&1 && {
+ (PATH='/bin:/bin'; FPATH=$PATH; sh -c :) >/dev/null 2>&1 ||
+ PATH_SEPARATOR=';'
fi
@@ -24246,20 +21892,19 @@
# there to prevent editors from complaining about space-tab.
# (If _AS_PATH_WALK were called with IFS unset, it would disable word
# splitting by setting IFS to empty value.)
-as_nl='
IFS=" "" $as_nl"
# Find who we are. Look in the path if we contain no directory separator.
-case $0 in
+as_myself=
+case $0 in #((
*[\\/]* ) as_myself=$0 ;;
*) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
for as_dir in $PATH
do
IFS=$as_save_IFS
test -z "$as_dir" && as_dir=.
- test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
-done
+ test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
+ done
IFS=$as_save_IFS
@@ -24270,32 +21915,111 @@
as_myself=$0
fi
if test ! -f "$as_myself"; then
- echo "$as_myself: error: cannot find myself; rerun with an absolute file name" >&2
+ $as_echo "$as_myself: error: cannot find myself; rerun with an absolute file name" >&2
+ exit 1
fi
-# Work around bugs in pre-3.0 UWIN ksh.
-for as_var in ENV MAIL MAILPATH
-do ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var
+# Unset variables that we do not need and which cause bugs (e.g. in
+# pre-3.0 UWIN ksh). But do not cause bugs in bash 2.01; the "|| exit 1"
+# suppresses any "Segmentation fault" message there. '((' could
+# trigger a bug in pdksh 5.2.14.
+for as_var in BASH_ENV ENV MAIL MAILPATH
+do eval test x\${$as_var+set} = xset \
+ && ( (unset $as_var) || exit 1) >/dev/null 2>&1 && unset $as_var || :
done
PS1='$ '
PS2='> '
PS4='+ '
# NLS nuisances.
-for as_var in \
- LANG LANGUAGE LC_ADDRESS LC_ALL LC_COLLATE LC_CTYPE LC_IDENTIFICATION \
- LC_MEASUREMENT LC_MESSAGES LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER \
- LC_TELEPHONE LC_TIME
-do
- if (set +x; test -z "`(eval $as_var=C; export $as_var) 2>&1`"); then
- eval $as_var=C; export $as_var
- else
- ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var
+LC_ALL=C
+export LC_ALL
+LANGUAGE=C
+export LANGUAGE
+# CDPATH.
+(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
+# as_fn_error STATUS ERROR [LINENO LOG_FD]
+# Output "`basename $0`: error: ERROR" to stderr. If LINENO and LOG_FD are
+# provided, also output the error to LOG_FD, referencing LINENO. Then exit the
+# script with STATUS, using 1 if that was 0.
+as_fn_error ()
+ as_status=$1; test $as_status -eq 0 && as_status=1
+ if test "$4"; then
+ as_lineno=${as_lineno-"$3"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
+ $as_echo "$as_me:${as_lineno-$LINENO}: error: $2" >&$4
fi
-done
+ $as_echo "$as_me: error: $2" >&2
+ as_fn_exit $as_status
+} # as_fn_error
-# Required to use basename.
+# as_fn_set_status STATUS
+# Set $? to STATUS, without forking.
+as_fn_set_status ()
+ return $1
+} # as_fn_set_status
+# as_fn_exit STATUS
+# Exit the shell with STATUS, even in a "trap 0" or "set -e" context.
+as_fn_exit ()
+ set +e
+ as_fn_set_status $1
+ exit $1
+} # as_fn_exit
+# as_fn_unset VAR
+# Portably unset VAR.
+as_fn_unset ()
+ { eval $1=; unset $1;}
+as_unset=as_fn_unset
+# as_fn_append VAR VALUE
+# Append the text in VALUE to the end of the definition contained in VAR. Take
+# advantage of any shell optimizations that allow amortized linear growth over
+# repeated appends, instead of the typical quadratic growth present in naive
+# implementations.
+if (eval "as_var=1; as_var+=2; test x\$as_var = x12") 2>/dev/null; then :
+ eval 'as_fn_append ()
+ eval $1+=\$2
+else
+ as_fn_append ()
+ eval $1=\$$1\$2
+fi # as_fn_append
+# as_fn_arith ARG...
+# Perform arithmetic evaluation on the ARGs, and store the result in the
+# global $as_val. Take advantage of shells that can avoid forks. The arguments
+# must be portable across $(()) and expr.
+if (eval "test \$(( 1 + 1 )) = 2") 2>/dev/null; then :
+ eval 'as_fn_arith ()
+ as_val=$(( $* ))
+else
+ as_fn_arith ()
+ as_val=`expr "$@" || test $? -eq 1`
+fi # as_fn_arith
if expr a : '\(a\)' >/dev/null 2>&1 &&
test "X`expr 00001 : '.*\(...\)'`" = X001; then
as_expr=expr
@@ -24309,13 +22033,17 @@
as_basename=false
fi
+if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then
+ as_dirname=dirname
+else
+ as_dirname=false
+fi
-# Name of the executable.
as_me=`$as_basename -- "$0" ||
$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
X"$0" : 'X\(//\)$' \| \
X"$0" : 'X\(/\)' \| . 2>/dev/null ||
-echo X/"$0" |
+$as_echo X/"$0" |
sed '/^.*\/\([^/][^/]*\)\/*$/{
s//\1/
q
@@ -24330,132 +22058,119 @@
s/.*/./; q'`
-# CDPATH.
-$as_unset CDPATH
+# Avoid depending upon Character Ranges.
+as_cr_letters='abcdefghijklmnopqrstuvwxyz'
+as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
+as_cr_Letters=$as_cr_letters$as_cr_LETTERS
+as_cr_digits='0123456789'
+as_cr_alnum=$as_cr_Letters$as_cr_digits
- as_lineno_1=$LINENO
- as_lineno_2=$LINENO
- test "x$as_lineno_1" != "x$as_lineno_2" &&
- test "x`expr $as_lineno_1 + 1`" = "x$as_lineno_2" || {
- # Create $as_me.lineno as a copy of $as_myself, but with $LINENO
- # uniformly replaced by the line number. The first 'sed' inserts a
- # line-number line after each line using $LINENO; the second 'sed'
- # does the real work. The second script uses 'N' to pair each
- # line-number line with the line containing $LINENO, and appends
- # trailing '-' during substitution so that $LINENO is not a special
- # case at line end.
- # (Raja R Harinath suggested sed '=', and Paul Eggert wrote the
- # scripts with optimization help from Paolo Bonzini. Blame Lee
- # E. McMahon (1931-1989) for sed's syntax. :-)
- sed -n '
- p
- /[$]LINENO/=
- ' <$as_myself |
- sed '
- s/[$]LINENO.*/&-/
- t lineno
- b
- :lineno
- N
- :loop
- s/[$]LINENO\([^'$as_cr_alnum'_].*\n\)\(.*\)/\2\1\2/
- t loop
- s/-\n.*//
- ' >$as_me.lineno &&
- chmod +x "$as_me.lineno" ||
- { echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2
- # Don't try to exec as it changes $[0], causing all sort of problems
- # (the dirname of $[0] is not the place where we might find the
- # original and so on. Autoconf is especially sensitive to this).
- . "./$as_me.lineno"
- # Exit status is that of the last command.
- exit
-if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then
- as_dirname=dirname
-else
- as_dirname=false
-fi
ECHO_C= ECHO_N= ECHO_T=
-case `echo -n x` in
+case `echo -n x` in #(((((
-n*)
- case `echo 'x\c'` in
+ case `echo 'xy\c'` in
*c*) ECHO_T=' ';; # ECHO_T is single tab character.
- *) ECHO_C='\c';;
+ xy) ECHO_C='\c';;
+ *) echo `echo ksh88 bug on AIX 6.1` > /dev/null
+ ECHO_T=' ';;
esac;;
ECHO_N='-n';;
esac
-if expr a : '\(a\)' >/dev/null 2>&1 &&
- test "X`expr 00001 : '.*\(...\)'`" = X001; then
- as_expr=expr
-else
- as_expr=false
-fi
rm -f conf$$ conf$$.exe conf$$.file
if test -d conf$$.dir; then
rm -f conf$$.dir/conf$$.file
else
rm -f conf$$.dir
- mkdir conf$$.dir
+ mkdir conf$$.dir 2>/dev/null
fi
-echo >conf$$.file
-if ln -s conf$$.file conf$$ 2>/dev/null; then
- as_ln_s='ln -s'
- # ... but there are two gotchas:
- # 1) On MSYS, both `ln -s file dir' and `ln file dir' fail.
- # 2) DJGPP < 2.04 has no symlinks; `ln -s' creates a wrapper executable.
- # In both cases, we have to default to `cp -p'.
- ln -s conf$$.file conf$$.dir 2>/dev/null && test ! -f conf$$.exe ||
- as_ln_s='cp -p'
-elif ln conf$$.file conf$$ 2>/dev/null; then
- as_ln_s=ln
+if (echo >conf$$.file) 2>/dev/null; then
+ if ln -s conf$$.file conf$$ 2>/dev/null; then
+ as_ln_s='ln -s'
+ # ... but there are two gotchas:
+ # 1) On MSYS, both `ln -s file dir' and `ln file dir' fail.
+ # 2) DJGPP < 2.04 has no symlinks; `ln -s' creates a wrapper executable.
+ # In both cases, we have to default to `cp -pR'.
+ ln -s conf$$.file conf$$.dir 2>/dev/null && test ! -f conf$$.exe ||
+ as_ln_s='cp -pR'
+ elif ln conf$$.file conf$$ 2>/dev/null; then
+ as_ln_s=ln
+ else
+ as_ln_s='cp -pR'
+ fi
else
- as_ln_s='cp -p'
+ as_ln_s='cp -pR'
fi
rm -f conf$$ conf$$.exe conf$$.dir/conf$$.file conf$$.file
rmdir conf$$.dir 2>/dev/null
+# as_fn_mkdir_p
+# Create "$as_dir" as a directory, including parents if necessary.
+as_fn_mkdir_p ()
+ case $as_dir in #(
+ -*) as_dir=./$as_dir;;
+ esac
+ test -d "$as_dir" || eval $as_mkdir_p || {
+ as_dirs=
+ while :; do
+ *\'*) as_qdir=`$as_echo "$as_dir" | sed "s/'/'\\\\\\\\''/g"`;; #'(
+ *) as_qdir=$as_dir;;
+ esac
+ as_dirs="'$as_qdir' $as_dirs"
+ as_dir=`$as_dirname -- "$as_dir" ||
+$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
+ X"$as_dir" : 'X\(//\)[^/]' \| \
+ X"$as_dir" : 'X\(//\)$' \| \
+ X"$as_dir" : 'X\(/\)' \| . 2>/dev/null ||
+$as_echo X"$as_dir" |
+ sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{
+ s//\1/
+ q
+ /^X\(\/\/\)[^/].*/{
+ s//\1/
+ q
+ /^X\(\/\/\)$/{
+ s//\1/
+ q
+ /^X\(\/\).*/{
+ s//\1/
+ q
+ s/.*/./; q'`
+ test -d "$as_dir" && break
+ done
+ test -z "$as_dirs" || eval "mkdir $as_dirs"
+ } || test -d "$as_dir" || as_fn_error $? "cannot create directory $as_dir"
+} # as_fn_mkdir_p
if mkdir -p . 2>/dev/null; then
- as_mkdir_p=:
+ as_mkdir_p='mkdir -p "$as_dir"'
else
test -d ./-p && rmdir ./-p
as_mkdir_p=false
fi
-if test -x / >/dev/null 2>&1; then
- as_test_x='test -x'
-else
- if ls -dL / >/dev/null 2>&1; then
- as_ls_L_option=L
- else
- as_ls_L_option=
- fi
- as_test_x='
- eval sh -c '\''
- if test -d "$1"; then
- test -d "$1/.";
- else
- case $1 in
- -*)set "./$1";;
- esac;
- case `ls -ld'$as_ls_L_option' "$1" 2>/dev/null` in
- ???[sx]*):;;*)false;;esac;fi
- '\'' sh
-fi
-as_executable_p=$as_test_x
+# as_fn_executable_p FILE
+# Test if FILE is an executable regular file.
+as_fn_executable_p ()
+ test -f "$1" && test -x "$1"
+} # as_fn_executable_p
+as_test_x='test -x'
+as_executable_p=as_fn_executable_p
# Sed expression to map a string onto a valid CPP name.
as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
@@ -24464,13 +22179,19 @@
exec 6>&1
+## Main body of $CONFIG_STATUS script. ##
+_ASEOF
+test $as_write_fail = 0 && chmod +x $CONFIG_STATUS || ac_write_fail=1
-# Save the log message, to keep $[0] and so on meaningful, and to
+cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
+# Save the log message, to keep $0 and so on meaningful, and to
# report actual input values of CONFIG_FILES etc. instead of their
# values after options handling.
ac_log="
This file was extended by Berkeley DB XML $as_me 2.5.16, which was
-generated by GNU Autoconf 2.61. Invocation command line was
+generated by GNU Autoconf 2.69. Invocation command line was
CONFIG_FILES = $CONFIG_FILES
CONFIG_HEADERS = $CONFIG_HEADERS
@@ -24483,7 +22204,16 @@
_ACEOF
-cat >>$CONFIG_STATUS <<_ACEOF
+case $ac_config_files in *"
+"*) set x $ac_config_files; shift; ac_config_files=$*;;
+esac
+case $ac_config_headers in *"
+"*) set x $ac_config_headers; shift; ac_config_headers=$*;;
+esac
+cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
# Files that config.status was made for.
config_files="$ac_config_files"
config_headers="$ac_config_headers"
@@ -24491,22 +22221,25 @@
_ACEOF
ac_cs_usage="\
-\`$as_me' instantiates files from templates according to the
-current configuration.
+\`$as_me' instantiates files and other configuration actions
+from templates according to the current configuration. Unless the files
+and actions are specified as TAGs, all are instantiated by default.
-Usage: $0 [OPTIONS] [FILE]...
+Usage: $0 [OPTION]... [TAG]...
-h, --help print this help, then exit
-V, --version print version number and configuration settings, then exit
- -q, --quiet do not print progress messages
+ --config print configuration, then exit
+ -q, --quiet, --silent
+ do not print progress messages
-d, --debug don't remove temporary files
--recheck update $as_me by reconfiguring in the same conditions
- --file=FILE[:TEMPLATE]
- instantiate the configuration file FILE
- --header=FILE[:TEMPLATE]
- instantiate the configuration header FILE
+ --file=FILE[:TEMPLATE]
+ instantiate the configuration file FILE
+ --header=FILE[:TEMPLATE]
+ instantiate the configuration header FILE
Configuration files:
$config_files
@@ -24517,16 +22250,17 @@
Configuration commands:
$config_commands
-Report bugs to <bug-autoconf at gnu.org>."
+Report bugs to <Oracle Technology Network Berkeley DB XML forum>."
_ACEOF
+ac_cs_config="`$as_echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`"
ac_cs_version="\\
Berkeley DB XML config.status 2.5.16
-configured by $0, generated by GNU Autoconf 2.61,
- with options \\"`echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`\\"
+configured by $0, generated by GNU Autoconf 2.69,
+ with options \\"\$ac_cs_config\\"
-Copyright (C) 2006 Free Software Foundation, Inc.
+Copyright (C) 2012 Free Software Foundation, Inc.
This config.status script is free software; the Free Software Foundation
gives unlimited permission to copy, distribute and modify it."
@@ -24534,20 +22268,26 @@
srcdir='$srcdir'
INSTALL='$INSTALL'
MKDIR_P='$MKDIR_P'
+AWK='$AWK'
+test -n "\$AWK" || AWK=awk
_ACEOF
-# If no file are specified by the user, then we need to provide default
-# value. By we need to know if files were specified by the user.
+# The default lists apply if the user does not specify any file.
ac_need_defaults=:
while test $# != 0
do
case $1 in
ac_option=`expr "X$1" : 'X\([^=]*\)='`
ac_optarg=`expr "X$1" : 'X[^=]*=\(.*\)'`
ac_shift=:
+ ac_option=`expr "X$1" : 'X\([^=]*\)='`
+ ac_optarg=
+ ac_shift=:
ac_option=$1
ac_optarg=$2
@@ -24560,34 +22300,41 @@
-recheck | --recheck | --rechec | --reche | --rech | --rec | --re | --r)
ac_cs_recheck=: ;;
--version | --versio | --versi | --vers | --ver | --ve | --v | -V )
- echo "$ac_cs_version"; exit ;;
+ $as_echo "$ac_cs_version"; exit ;;
+ --config | --confi | --conf | --con | --co | --c )
+ $as_echo "$ac_cs_config"; exit ;;
--debug | --debu | --deb | --de | --d | -d )
debug=: ;;
--file | --fil | --fi | --f )
$ac_shift
- CONFIG_FILES="$CONFIG_FILES $ac_optarg"
+ case $ac_optarg in
+ *\'*) ac_optarg=`$as_echo "$ac_optarg" | sed "s/'/'\\\\\\\\''/g"` ;;
+ '') as_fn_error $? "missing file argument" ;;
+ esac
+ as_fn_append CONFIG_FILES " '$ac_optarg'"
ac_need_defaults=false;;
--header | --heade | --head | --hea )
$ac_shift
- CONFIG_HEADERS="$CONFIG_HEADERS $ac_optarg"
+ esac
+ as_fn_append CONFIG_HEADERS " '$ac_optarg'"
--he | --h)
# Conflict between --help and --header
- { echo "$as_me: error: ambiguous option: $1
-Try \`$0 --help' for more information." >&2
+ as_fn_error $? "ambiguous option: \`$1'
+Try \`$0 --help' for more information.";;
--help | --hel | -h )
- echo "$ac_cs_usage"; exit ;;
+ $as_echo "$ac_cs_usage"; exit ;;
-q | -quiet | --quiet | --quie | --qui | --qu | --q \
| -silent | --silent | --silen | --sile | --sil | --si | --s)
ac_cs_silent=: ;;
# This is an error.
- -*) { echo "$as_me: error: unrecognized option: $1
- { (exit 1); exit 1; }; } ;;
+ -*) as_fn_error $? "unrecognized option: \`$1'
+Try \`$0 --help' for more information." ;;
- *) ac_config_targets="$ac_config_targets $1"
+ *) as_fn_append ac_config_targets " $1"
ac_need_defaults=false ;;
esac
@@ -24602,27 +22349,29 @@
fi
_ACEOF
if \$ac_cs_recheck; then
- echo "running CONFIG_SHELL=$SHELL $SHELL $0 "$ac_configure_args \$ac_configure_extra_args " --no-create --no-recursion" >&6
- CONFIG_SHELL=$SHELL
+ set X $SHELL '$0' $ac_configure_args \$ac_configure_extra_args --no-create --no-recursion
+ shift
+ \$as_echo "running CONFIG_SHELL=$SHELL \$*" >&6
+ CONFIG_SHELL='$SHELL'
export CONFIG_SHELL
- exec $SHELL "$0"$ac_configure_args \$ac_configure_extra_args --no-create --no-recursion
+ exec "\$@"
fi
_ACEOF
exec 5>>config.log
echo
sed 'h;s/./-/g;s/^.../## /;s/...$/ ##/;p;x;p;x' <<_ASBOX
## Running $as_me. ##
_ASBOX
- echo "$ac_log"
+ $as_echo "$ac_log"
} >&5
_ACEOF
# INIT-COMMANDS
@@ -24630,7 +22379,7 @@
_ACEOF
# Handling of arguments.
for ac_config_target in $ac_config_targets
@@ -24643,9 +22392,7 @@
"$srcdir/src/python/setup.py") CONFIG_FILES="$CONFIG_FILES $srcdir/src/python/setup.py:$srcdir/src/python/setup.py.in" ;;
"$srcdir/src/perl/config") CONFIG_FILES="$CONFIG_FILES $srcdir/src/perl/config:$srcdir/src/perl/config.in" ;;
- *) { { echo "$as_me:$LINENO: error: invalid argument: $ac_config_target" >&5
-echo "$as_me: error: invalid argument: $ac_config_target" >&2;}
+ *) as_fn_error $? "invalid argument: \`$ac_config_target'" "$LINENO" 5;;
esac
done
@@ -24668,307 +22415,302 @@
# after its creation but before its name has been assigned to `$tmp'.
$debug ||
- tmp=
+ tmp= ac_tmp=
trap 'exit_status=$?
- { test -z "$tmp" || test ! -d "$tmp" || rm -fr "$tmp"; } && exit $exit_status
+ : "${ac_tmp:=$tmp}"
+ { test ! -d "$ac_tmp" || rm -fr "$ac_tmp"; } && exit $exit_status
' 0
- trap '{ (exit 1); exit 1; }' 1 2 13 15
+ trap 'as_fn_exit 1' 1 2 13 15
# Create a (secure) tmp directory for tmp files.
tmp=`(umask 077 && mktemp -d "./confXXXXXX") 2>/dev/null` &&
- test -n "$tmp" && test -d "$tmp"
+ test -d "$tmp"
tmp=./conf$$-$RANDOM
(umask 077 && mkdir "$tmp")
- echo "$me: cannot create a temporary directory in ." >&2
+} || as_fn_error $? "cannot create a temporary directory in ." "$LINENO" 5
+ac_tmp=$tmp
-# Set up the sed scripts for CONFIG_FILES section.
-# No need to generate the scripts if there are no CONFIG_FILES.
-# This happens for instance when ./config.status config.h
+# Set up the scripts for CONFIG_FILES section.
+# No need to generate them if there are no CONFIG_FILES.
+# This happens for instance with `./config.status config.h'.
if test -n "$CONFIG_FILES"; then
-_ACEOF
-ac_delim='%!_!# '
-for ac_last_try in false false false false false :; do
- cat >conf$$subs.sed <<_ACEOF
-SHELL!$SHELL$ac_delim
-PATH_SEPARATOR!$PATH_SEPARATOR$ac_delim
-PACKAGE_NAME!$PACKAGE_NAME$ac_delim
-PACKAGE_TARNAME!$PACKAGE_TARNAME$ac_delim
-PACKAGE_VERSION!$PACKAGE_VERSION$ac_delim
-PACKAGE_STRING!$PACKAGE_STRING$ac_delim
-PACKAGE_BUGREPORT!$PACKAGE_BUGREPORT$ac_delim
-exec_prefix!$exec_prefix$ac_delim
-prefix!$prefix$ac_delim
-program_transform_name!$program_transform_name$ac_delim
-bindir!$bindir$ac_delim
-sbindir!$sbindir$ac_delim
-libexecdir!$libexecdir$ac_delim
-datarootdir!$datarootdir$ac_delim
-datadir!$datadir$ac_delim
-sysconfdir!$sysconfdir$ac_delim
-sharedstatedir!$sharedstatedir$ac_delim
-localstatedir!$localstatedir$ac_delim
-includedir!$includedir$ac_delim
-oldincludedir!$oldincludedir$ac_delim
-docdir!$docdir$ac_delim
-infodir!$infodir$ac_delim
-htmldir!$htmldir$ac_delim
-dvidir!$dvidir$ac_delim
-pdfdir!$pdfdir$ac_delim
-psdir!$psdir$ac_delim
-libdir!$libdir$ac_delim
-localedir!$localedir$ac_delim
-mandir!$mandir$ac_delim
-DEFS!$DEFS$ac_delim
-ECHO_C!$ECHO_C$ac_delim
-ECHO_N!$ECHO_N$ac_delim
-ECHO_T!$ECHO_T$ac_delim
-LIBS!$LIBS$ac_delim
-build_alias!$build_alias$ac_delim
-host_alias!$host_alias$ac_delim
-target_alias!$target_alias$ac_delim
-INSTALL_PROGRAM!$INSTALL_PROGRAM$ac_delim
-INSTALL_SCRIPT!$INSTALL_SCRIPT$ac_delim
-INSTALL_DATA!$INSTALL_DATA$ac_delim
-am__isrc!$am__isrc$ac_delim
-CYGPATH_W!$CYGPATH_W$ac_delim
-PACKAGE!$PACKAGE$ac_delim
-VERSION!$VERSION$ac_delim
-ACLOCAL!$ACLOCAL$ac_delim
-AUTOCONF!$AUTOCONF$ac_delim
-AUTOMAKE!$AUTOMAKE$ac_delim
-AUTOHEADER!$AUTOHEADER$ac_delim
-MAKEINFO!$MAKEINFO$ac_delim
-install_sh!$install_sh$ac_delim
-STRIP!$STRIP$ac_delim
-INSTALL_STRIP_PROGRAM!$INSTALL_STRIP_PROGRAM$ac_delim
-mkdir_p!$mkdir_p$ac_delim
-AWK!$AWK$ac_delim
-SET_MAKE!$SET_MAKE$ac_delim
-am__leading_dot!$am__leading_dot$ac_delim
-AMTAR!$AMTAR$ac_delim
-am__tar!$am__tar$ac_delim
-am__untar!$am__untar$ac_delim
-build!$build$ac_delim
-build_cpu!$build_cpu$ac_delim
-build_vendor!$build_vendor$ac_delim
-build_os!$build_os$ac_delim
-host!$host$ac_delim
-host_cpu!$host_cpu$ac_delim
-host_vendor!$host_vendor$ac_delim
-host_os!$host_os$ac_delim
-DBXML_VERSION_MAJOR!$DBXML_VERSION_MAJOR$ac_delim
-DBXML_VERSION_MINOR!$DBXML_VERSION_MINOR$ac_delim
-DBXML_VERSION_PATCH!$DBXML_VERSION_PATCH$ac_delim
-DBXML_VERSION_STRING!$DBXML_VERSION_STRING$ac_delim
-DB_TCLLIB!$DB_TCLLIB$ac_delim
-DB_TEST_PATH!$DB_TEST_PATH$ac_delim
-DB_UTIL_PATH!$DB_UTIL_PATH$ac_delim
-DB_DIR!$DB_DIR$ac_delim
-berkeleydb_include!$berkeleydb_include$ac_delim
-berkeleydb_lib!$berkeleydb_lib$ac_delim
-berkeleydb_library!$berkeleydb_library$ac_delim
-berkeleydb_jar!$berkeleydb_jar$ac_delim
-XQILLA_DIR!$XQILLA_DIR$ac_delim
-xqilla_include!$xqilla_include$ac_delim
-xqilla_lib!$xqilla_lib$ac_delim
-XERCES_DIR!$XERCES_DIR$ac_delim
-xerces_include!$xerces_include$ac_delim
-xerces_include_dir!$xerces_include_dir$ac_delim
-xerces_lib!$xerces_lib$ac_delim
-JUNIT_JAR!$JUNIT_JAR$ac_delim
-zlib_include!$zlib_include$ac_delim
-zlib_lib!$zlib_lib$ac_delim
-zlib_library!$zlib_library$ac_delim
-BUILD_TCL_TRUE!$BUILD_TCL_TRUE$ac_delim
-BUILD_TCL_FALSE!$BUILD_TCL_FALSE$ac_delim
-BUILD_JAVA_TRUE!$BUILD_JAVA_TRUE$ac_delim
-BUILD_JAVA_FALSE!$BUILD_JAVA_FALSE$ac_delim
-BUILD_TEST_TRUE!$BUILD_TEST_TRUE$ac_delim
-BUILD_TEST_FALSE!$BUILD_TEST_FALSE$ac_delim
-USE_COMPRESSION_TRUE!$USE_COMPRESSION_TRUE$ac_delim
-_ACEOF
- if test `sed -n "s/.*$ac_delim\$/X/p" conf$$subs.sed | grep -c X` = 97; then
- break
- elif $ac_last_try; then
- { { echo "$as_me:$LINENO: error: could not make $CONFIG_STATUS" >&5
-echo "$as_me: error: could not make $CONFIG_STATUS" >&2;}
- else
- ac_delim="$ac_delim!$ac_delim _$ac_delim!! "
- fi
-done
-ac_eof=`sed -n '/^CEOF[0-9]*$/s/CEOF/0/p' conf$$subs.sed`
-if test -n "$ac_eof"; then
- ac_eof=`echo "$ac_eof" | sort -nru | sed 1q`
- ac_eof=`expr $ac_eof + 1`
+ac_cr=`echo X | tr X '\015'`
+# On cygwin, bash can eat \r inside `` if the user requested igncr.
+# But we know of no other shell where ac_cr would be empty at this
+# point, so we can use a bashism as a fallback.
+if test "x$ac_cr" = x; then
+ eval ac_cr=\$\'\\r\'
fi
+ac_cs_awk_cr=`$AWK 'BEGIN { print "a\rb" }' </dev/null 2>/dev/null`
+if test "$ac_cs_awk_cr" = "a${ac_cr}b"; then
+ ac_cs_awk_cr='\\r'
+else
+ ac_cs_awk_cr=$ac_cr
+fi
-cat >"\$tmp/subs-1.sed" <<\CEOF$ac_eof
-/@[a-zA-Z_][a-zA-Z_0-9]*@/!b
+echo 'BEGIN {' >"$ac_tmp/subs1.awk" &&
_ACEOF
-sed '
-s/[,\\&]/\\&/g; s/@/@|#_!!_#|/g
-s/^/s,@/; s/!/@,|#_!!_#|/
-:n
-t n
-s/'"$ac_delim"'$/,g/; t
-s/$/\\/; p
-N; s/^.*\n//; s/[,\\&]/\\&/g; s/@/@|#_!!_#|/g; b n
-' >>$CONFIG_STATUS <conf$$subs.sed
-rm -f conf$$subs.sed
-CEOF$ac_eof
-_ACEOF
+ echo "cat >conf$$subs.awk <<_ACEOF" &&
+ echo "$ac_subst_vars" | sed 's/.*/&!$&$ac_delim/' &&
+ echo "_ACEOF"
+} >conf$$subs.sh ||
+ as_fn_error $? "could not make $CONFIG_STATUS" "$LINENO" 5
+ac_delim_num=`echo "$ac_subst_vars" | grep -c '^'`
ac_delim='%!_!# '
-USE_COMPRESSION_FALSE!$USE_COMPRESSION_FALSE$ac_delim
-CC!$CC$ac_delim
-CFLAGS!$CFLAGS$ac_delim
-LDFLAGS!$LDFLAGS$ac_delim
-CPPFLAGS!$CPPFLAGS$ac_delim
-ac_ct_CC!$ac_ct_CC$ac_delim
-EXEEXT!$EXEEXT$ac_delim
-OBJEXT!$OBJEXT$ac_delim
-DEPDIR!$DEPDIR$ac_delim
-am__include!$am__include$ac_delim
-am__quote!$am__quote$ac_delim
-AMDEP_TRUE!$AMDEP_TRUE$ac_delim
-AMDEP_FALSE!$AMDEP_FALSE$ac_delim
-AMDEPBACKSLASH!$AMDEPBACKSLASH$ac_delim
-CCDEPMODE!$CCDEPMODE$ac_delim
-am__fastdepCC_TRUE!$am__fastdepCC_TRUE$ac_delim
-am__fastdepCC_FALSE!$am__fastdepCC_FALSE$ac_delim
-CXX!$CXX$ac_delim
-CXXFLAGS!$CXXFLAGS$ac_delim
-ac_ct_CXX!$ac_ct_CXX$ac_delim
-CXXDEPMODE!$CXXDEPMODE$ac_delim
-am__fastdepCXX_TRUE!$am__fastdepCXX_TRUE$ac_delim
-am__fastdepCXX_FALSE!$am__fastdepCXX_FALSE$ac_delim
-SED!$SED$ac_delim
-GREP!$GREP$ac_delim
-EGREP!$EGREP$ac_delim
-LN_S!$LN_S$ac_delim
-ECHO!$ECHO$ac_delim
-AR!$AR$ac_delim
-RANLIB!$RANLIB$ac_delim
-DSYMUTIL!$DSYMUTIL$ac_delim
-NMEDIT!$NMEDIT$ac_delim
-CPP!$CPP$ac_delim
-CXXCPP!$CXXCPP$ac_delim
-F77!$F77$ac_delim
-FFLAGS!$FFLAGS$ac_delim
-ac_ct_F77!$ac_ct_F77$ac_delim
-LIBTOOL!$LIBTOOL$ac_delim
-LIBOBJS!$LIBOBJS$ac_delim
-POW_LIB!$POW_LIB$ac_delim
-JAVAC!$JAVAC$ac_delim
-JAR!$JAR$ac_delim
-_ACJNI_JAVAC!$_ACJNI_JAVAC$ac_delim
-JAVACFLAGS!$JAVACFLAGS$ac_delim
-SWIGCPPFLAGS!$SWIGCPPFLAGS$ac_delim
-JAVA_INCLUDE_SPEC!$JAVA_INCLUDE_SPEC$ac_delim
-MODSUFFIX!$MODSUFFIX$ac_delim
-JAVA_LIBRARY_EXTENSION!$JAVA_LIBRARY_EXTENSION$ac_delim
-LIBJSO_LIBS!$LIBJSO_LIBS$ac_delim
-LIBTSO_MODSUFFIX!$LIBTSO_MODSUFFIX$ac_delim
-LIBTSO_LIBS!$LIBTSO_LIBS$ac_delim
-TCL_LIBRARY_EXTENSION!$TCL_LIBRARY_EXTENSION$ac_delim
-TCL_BIN_DIR!$TCL_BIN_DIR$ac_delim
-TCL_INCLUDE_SPEC!$TCL_INCLUDE_SPEC$ac_delim
-TCL_LIB_FILE!$TCL_LIB_FILE$ac_delim
-TCL_SRC_DIR!$TCL_SRC_DIR$ac_delim
-TCL_TCLSH!$TCL_TCLSH$ac_delim
-LTLIBOBJS!$LTLIBOBJS$ac_delim
-_ACEOF
+ . ./conf$$subs.sh ||
- if test `sed -n "s/.*$ac_delim\$/X/p" conf$$subs.sed | grep -c X` = 58; then
+ ac_delim_n=`sed -n "s/.*$ac_delim\$/X/p" conf$$subs.awk | grep -c X`
+ if test $ac_delim_n = $ac_delim_num; then
break
else
fi
done
+rm -f conf$$subs.sh
-fi
+cat >>"\$ac_tmp/subs1.awk" <<\\_ACAWK &&
+_ACEOF
+sed -n '
+h
+s/^/S["/; s/!.*/"]=/
+p
+g
+s/^[^!]*!//
+:repl
+t repl
+s/'"$ac_delim"'$//
+t delim
+:nl
+h
+s/\(.\{148\}\)..*/\1/
+t more1
+s/["\\]/\\&/g; s/^/"/; s/$/\\n"\\/
+p
+n
+b repl
+:more1
+s/["\\]/\\&/g; s/^/"/; s/$/"\\/
+p
+g
+s/.\{148\}//
+t nl
+:delim
+h
+t more2
+s/["\\]/\\&/g; s/^/"/; s/$/"/
+p
+b
+:more2
+p
+g
+s/.\{148\}//
+t delim
+' <conf$$subs.awk | sed '
+ N
+ s/\n//
+' >>$CONFIG_STATUS || ac_write_fail=1
+rm -f conf$$subs.awk
+_ACAWK
+cat >>"\$ac_tmp/subs1.awk" <<_ACAWK &&
+ for (key in S) S_is_set[key] = 1
+ FS = ""
-cat >"\$tmp/subs-2.sed" <<\CEOF$ac_eof
-/@[a-zA-Z_][a-zA-Z_0-9]*@/!b end
+ line = $ 0
+ nfields = split(line, field, "@")
+ substed = 0
+ len = length(field[1])
+ for (i = 2; i < nfields; i++) {
+ key = field[i]
+ keylen = length(key)
+ if (S_is_set[key]) {
+ value = S[key]
+ line = substr(line, 1, len) "" value "" substr(line, len + keylen + 3)
+ len += length(value) + length(field[++i])
+ substed = 1
+ } else
+ len += 1 + keylen
+ print line
+_ACAWK
_ACEOF
-sed '
-:n
-t n
-s/$/\\/; p
-:end
-s/|#_!!_#|//g
-CEOF$ac_eof
+if sed "s/$ac_cr//" < /dev/null > /dev/null 2>&1; then
+ sed "s/$ac_cr\$//; s/$ac_cr/$ac_cs_awk_cr/g"
+else
+ cat
+fi < "$ac_tmp/subs1.awk" > "$ac_tmp/subs.awk" \
+ || as_fn_error $? "could not setup config files machinery" "$LINENO" 5
_ACEOF
-# VPATH may cause trouble with some makes, so we remove $(srcdir),
-# ${srcdir} and @srcdir@ from VPATH if srcdir is ".", strip leading and
+# VPATH may cause trouble with some makes, so we remove sole $(srcdir),
+# ${srcdir} and @srcdir@ entries from VPATH if srcdir is ".", strip leading and
# trailing colons and then remove the whole line if VPATH becomes empty
# (actually we leave an empty line to preserve line numbers).
if test "x$srcdir" = x.; then
- ac_vpsub='/^[ ]*VPATH[ ]*=/{
-s/:*\$(srcdir):*/:/
-s/:*\${srcdir}:*/:/
-s/:*@srcdir@:*/:/
-s/^\([^=]*=[ ]*\):*/\1/
+ ac_vpsub='/^[ ]*VPATH[ ]*=[ ]*/{
+h
+s///
+s/^/:/
+s/[ ]*$/:/
+s/:\$(srcdir):/:/g
+s/:\${srcdir}:/:/g
+s/:@srcdir@:/:/g
+s/^:*//
s/:*$//
+x
+s/\(=[ ]*\).*/\1/
+G
+s/\n//
s/^[^=]*=[ ]*$//
fi
fi # test -n "$CONFIG_FILES"
+# Set up the scripts for CONFIG_HEADERS section.
+# No need to generate them if there are no CONFIG_HEADERS.
+# This happens for instance with `./config.status Makefile'.
+if test -n "$CONFIG_HEADERS"; then
+cat >"$ac_tmp/defines.awk" <<\_ACAWK ||
+BEGIN {
+_ACEOF
-for ac_tag in :F $CONFIG_FILES :H $CONFIG_HEADERS :C $CONFIG_COMMANDS
+# Transform confdefs.h into an awk script `defines.awk', embedded as
+# here-document in config.status, that substitutes the proper values into
+# config.h.in to produce config.h.
+# Create a delimiter string that does not exist in confdefs.h, to ease
+# handling of long lines.
+ac_delim='%!_!# '
+for ac_last_try in false false :; do
+ ac_tt=`sed -n "/$ac_delim/p" confdefs.h`
+ if test -z "$ac_tt"; then
+ break
+ elif $ac_last_try; then
+ as_fn_error $? "could not make $CONFIG_HEADERS" "$LINENO" 5
+ else
+ ac_delim="$ac_delim!$ac_delim _$ac_delim!! "
+ fi
+done
+# For the awk script, D is an array of macro values keyed by name,
+# likewise P contains macro parameters if any. Preserve backslash
+# newline sequences.
+ac_word_re=[_$as_cr_Letters][_$as_cr_alnum]*
+sed -n '
+s/.\{148\}/&'"$ac_delim"'/g
+t rset
+:rset
+s/^[ ]*#[ ]*define[ ][ ]*/ /
+t def
+d
+:def
+s/\\$//
+t bsnl
+s/["\\]/\\&/g
+s/^ \('"$ac_word_re"'\)\(([^()]*)\)[ ]*\(.*\)/P["\1"]="\2"\
+D["\1"]=" \3"/p
+s/^ \('"$ac_word_re"'\)[ ]*\(.*\)/D["\1"]=" \2"/p
+d
+:bsnl
+s/["\\]/\\&/g
+D["\1"]=" \3\\\\\\n"\\/p
+t cont
+s/^ \('"$ac_word_re"'\)[ ]*\(.*\)/D["\1"]=" \2\\\\\\n"\\/p
+t cont
+d
+:cont
+n
+t clear
+:clear
+s/\\$//
+t bsnlc
+s/["\\]/\\&/g; s/^/"/; s/$/"/p
+d
+:bsnlc
+s/["\\]/\\&/g; s/^/"/; s/$/\\\\\\n"\\/p
+b cont
+' <confdefs.h | sed '
+s/'"$ac_delim"'/"\\\
+"/g' >>$CONFIG_STATUS || ac_write_fail=1
+ for (key in D) D_is_set[key] = 1
+ FS = ""
+/^[\t ]*#[\t ]*(define|undef)[\t ]+$ac_word_re([\t (]|\$)/ {
+ line = \$ 0
+ split(line, arg, " ")
+ if (arg[1] == "#") {
+ defundef = arg[2]
+ mac1 = arg[3]
+ } else {
+ defundef = substr(arg[1], 2)
+ mac1 = arg[2]
+ split(mac1, mac2, "(") #)
+ macro = mac2[1]
+ prefix = substr(line, 1, index(line, defundef) - 1)
+ if (D_is_set[macro]) {
+ # Preserve the white space surrounding the "#".
+ print prefix "define", macro P[macro] D[macro]
+ next
+ } else {
+ # Replace #undef with comments. This is necessary, for example,
+ # in the case of _POSIX_SOURCE, which is predefined and required
+ # on some systems where configure will not decide to define it.
+ if (defundef == "undef") {
+ print "/*", prefix defundef, macro, "*/"
+ next
+{ print }
+_ACAWK
+_ACEOF
+ as_fn_error $? "could not setup config headers machinery" "$LINENO" 5
+fi # test -n "$CONFIG_HEADERS"
+eval set X " :F $CONFIG_FILES :H $CONFIG_HEADERS :C $CONFIG_COMMANDS"
+shift
+for ac_tag
do
case $ac_tag in
:[FHLC]) ac_mode=$ac_tag; continue;;
esac
case $ac_mode$ac_tag in
:[FHL]*:*);;
- :L* | :C*:*) { { echo "$as_me:$LINENO: error: Invalid tag $ac_tag." >&5
-echo "$as_me: error: Invalid tag $ac_tag." >&2;}
+ :L* | :C*:*) as_fn_error $? "invalid tag \`$ac_tag'" "$LINENO" 5;;
:[FH]-) ac_tag=-:-;;
:[FH]*) ac_tag=$ac_tag:$ac_tag.in;;
esac
@@ -24987,7 +22729,7 @@
for ac_f
do
case $ac_f in
- -) ac_f="$tmp/stdin";;
+ -) ac_f="$ac_tmp/stdin";;
*) # Look for the file first in the build tree, then in the source tree
# (if the path is not absolute). The absolute path cannot be DOS-style,
# because $ac_f cannot contain `:'.
@@ -24996,26 +22738,34 @@
[\\/$]*) false;;
*) test -f "$srcdir/$ac_f" && ac_f="$srcdir/$ac_f";;
esac ||
- { { echo "$as_me:$LINENO: error: cannot find input file: $ac_f" >&5
-echo "$as_me: error: cannot find input file: $ac_f" >&2;}
+ as_fn_error 1 "cannot find input file: \`$ac_f'" "$LINENO" 5;;
esac
- ac_file_inputs="$ac_file_inputs $ac_f"
+ case $ac_f in *\'*) ac_f=`$as_echo "$ac_f" | sed "s/'/'\\\\\\\\''/g"`;; esac
+ as_fn_append ac_file_inputs " '$ac_f'"
done
# Let's still pretend it is `configure' which instantiates (i.e., don't
# use $as_me), people would be surprised to read:
# /* config.h. Generated by config.status. */
- configure_input="Generated from "`IFS=:
- echo $* | sed 's|^[^:]*/||;s|:[^:]*/|, |g'`" by configure."
+ configure_input='Generated from '`
+ $as_echo "$*" | sed 's|^[^:]*/||;s|:[^:]*/|, |g'
+ `' by configure.'
if test x"$ac_file" != x-; then
configure_input="$ac_file. $configure_input"
- { echo "$as_me:$LINENO: creating $ac_file" >&5
-echo "$as_me: creating $ac_file" >&6;}
+ { $as_echo "$as_me:${as_lineno-$LINENO}: creating $ac_file" >&5
+$as_echo "$as_me: creating $ac_file" >&6;}
fi
+ # Neutralize special characters interpreted by sed in replacement strings.
+ case $configure_input in #(
+ ac_sed_conf_input=`$as_echo "$configure_input" |
+ sed 's/[\\\\&|]/\\\\&/g'`;; #(
+ *) ac_sed_conf_input=$configure_input;;
+ esac
case $ac_tag in
- *:-:* | *:-) cat >"$tmp/stdin";;
+ *:-:* | *:-) cat >"$ac_tmp/stdin" \
+ || as_fn_error $? "could not create $ac_file" "$LINENO" 5 ;;
esac
esac
@@ -25025,7 +22775,7 @@
X"$ac_file" : 'X\(//\)[^/]' \| \
X"$ac_file" : 'X\(//\)$' \| \
X"$ac_file" : 'X\(/\)' \| . 2>/dev/null ||
-echo X"$ac_file" |
+$as_echo X"$ac_file" |
s//\1/
q
@@ -25043,55 +22793,15 @@
q
s/.*/./; q'`
- { as_dir="$ac_dir"
- case $as_dir in #(
- -*) as_dir=./$as_dir;;
- esac
- test -d "$as_dir" || { $as_mkdir_p && mkdir -p "$as_dir"; } || {
- as_dirs=
- while :; do
- *\'*) as_qdir=`echo "$as_dir" | sed "s/'/'\\\\\\\\''/g"`;; #(
- *) as_qdir=$as_dir;;
- esac
- as_dirs="'$as_qdir' $as_dirs"
- as_dir=`$as_dirname -- "$as_dir" ||
-$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$as_dir" : 'X\(//\)[^/]' \| \
- X"$as_dir" : 'X\(//\)$' \| \
- X"$as_dir" : 'X\(/\)' \| . 2>/dev/null ||
-echo X"$as_dir" |
- sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{
- s//\1/
- q
- /^X\(\/\/\)[^/].*/{
- s//\1/
- q
- /^X\(\/\/\)$/{
- s//\1/
- q
- /^X\(\/\).*/{
- s//\1/
- q
- s/.*/./; q'`
- test -d "$as_dir" && break
- done
- test -z "$as_dirs" || eval "mkdir $as_dirs"
- } || test -d "$as_dir" || { { echo "$as_me:$LINENO: error: cannot create directory $as_dir" >&5
-echo "$as_me: error: cannot create directory $as_dir" >&2;}
- { (exit 1); exit 1; }; }; }
+ as_dir="$ac_dir"; as_fn_mkdir_p
ac_builddir=.
case "$ac_dir" in
.) ac_dir_suffix= ac_top_builddir_sub=. ac_top_build_prefix= ;;
- ac_dir_suffix=/`echo "$ac_dir" | sed 's,^\.[\\/],,'`
+ ac_dir_suffix=/`$as_echo "$ac_dir" | sed 's|^\.[\\/]||'`
# A ".." for each directory in $ac_dir_suffix.
- ac_top_builddir_sub=`echo "$ac_dir_suffix" | sed 's,/[^\\/]*,/..,g;s,/,,'`
+ ac_top_builddir_sub=`$as_echo "$ac_dir_suffix" | sed 's|/[^\\/]*|/..|g;s|/||'`
case $ac_top_builddir_sub in
"") ac_top_builddir_sub=. ac_top_build_prefix= ;;
*) ac_top_build_prefix=$ac_top_builddir_sub/ ;;
@@ -25136,12 +22846,12 @@
esac
_ACEOF
# If the template does not know about datarootdir, expand it.
# FIXME: This hack should be removed a few years after 2.60.
ac_datarootdir_hack=; ac_datarootdir_seen=
-case `sed -n '/datarootdir/ {
+ac_sed_dataroot='
+/datarootdir/ {
p
q
@@ -25149,36 +22859,37 @@
/@docdir@/p
/@infodir@/p
/@localedir@/p
-/@mandir@/p
-' $ac_file_inputs` in
+/@mandir@/p'
+case `eval "sed -n \"\$ac_sed_dataroot\" $ac_file_inputs"` in
*datarootdir*) ac_datarootdir_seen=yes;;
*@datadir@*|*@docdir@*|*@infodir@*|*@localedir@*|*@mandir@*)
- { echo "$as_me:$LINENO: WARNING: $ac_file_inputs seems to ignore the --datarootdir setting" >&5
-echo "$as_me: WARNING: $ac_file_inputs seems to ignore the --datarootdir setting" >&2;}
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $ac_file_inputs seems to ignore the --datarootdir setting" >&5
+$as_echo "$as_me: WARNING: $ac_file_inputs seems to ignore the --datarootdir setting" >&2;}
_ACEOF
ac_datarootdir_hack='
s&@datadir@&$datadir&g
s&@docdir@&$docdir&g
s&@infodir@&$infodir&g
s&@localedir@&$localedir&g
s&@mandir@&$mandir&g
- s&\\\${datarootdir}&$datarootdir&g' ;;
+ s&\\\${datarootdir}&$datarootdir&g' ;;
esac
_ACEOF
# Neutralize VPATH when `$srcdir' = `.'.
# Shell code in configure.ac might set extrasub.
# FIXME: do we really want to maintain this feature?
- sed "$ac_vpsub
+ac_sed_extra="$ac_vpsub
$extrasub
_ACEOF
:t
-s&@configure_input@&$configure_input&;t t
+s|@configure_input@|$ac_sed_conf_input|;t t
s&@top_builddir@&$ac_top_builddir_sub&;t t
+s&@top_build_prefix@&$ac_top_build_prefix&;t t
s&@srcdir@&$ac_srcdir&;t t
s&@abs_srcdir@&$ac_abs_srcdir&;t t
s&@top_srcdir@&$ac_top_srcdir&;t t
@@ -25189,121 +22900,51 @@
s&@INSTALL@&$ac_INSTALL&;t t
s&@MKDIR_P@&$ac_MKDIR_P&;t t
$ac_datarootdir_hack
-" $ac_file_inputs | sed -f "$tmp/subs-1.sed" | sed -f "$tmp/subs-2.sed" >$tmp/out
+eval sed \"\$ac_sed_extra\" "$ac_file_inputs" | $AWK -f "$ac_tmp/subs.awk" \
+ >$ac_tmp/out || as_fn_error $? "could not create $ac_file" "$LINENO" 5
test -z "$ac_datarootdir_hack$ac_datarootdir_seen" &&
- { ac_out=`sed -n '/\${datarootdir}/p' "$tmp/out"`; test -n "$ac_out"; } &&
- { ac_out=`sed -n '/^[ ]*datarootdir[ ]*:*=/p' "$tmp/out"`; test -z "$ac_out"; } &&
- { echo "$as_me:$LINENO: WARNING: $ac_file contains a reference to the variable \`datarootdir'
-which seems to be undefined. Please make sure it is defined." >&5
-echo "$as_me: WARNING: $ac_file contains a reference to the variable \`datarootdir'
-which seems to be undefined. Please make sure it is defined." >&2;}
+ { ac_out=`sed -n '/\${datarootdir}/p' "$ac_tmp/out"`; test -n "$ac_out"; } &&
+ { ac_out=`sed -n '/^[ ]*datarootdir[ ]*:*=/p' \
+ "$ac_tmp/out"`; test -z "$ac_out"; } &&
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $ac_file contains a reference to the variable \`datarootdir'
+which seems to be undefined. Please make sure it is defined" >&5
+$as_echo "$as_me: WARNING: $ac_file contains a reference to the variable \`datarootdir'
+which seems to be undefined. Please make sure it is defined" >&2;}
- rm -f "$tmp/stdin"
+ rm -f "$ac_tmp/stdin"
case $ac_file in
- -) cat "$tmp/out"; rm -f "$tmp/out";;
- *) rm -f "$ac_file"; mv "$tmp/out" $ac_file;;
- esac
+ -) cat "$ac_tmp/out" && rm -f "$ac_tmp/out";;
+ *) rm -f "$ac_file" && mv "$ac_tmp/out" "$ac_file";;
+ esac \
:H)
# CONFIG_HEADER
-_ACEOF
-# Transform confdefs.h into a sed script `conftest.defines', that
-# substitutes the proper values into config.h.in to produce config.h.
-rm -f conftest.defines conftest.tail
-# First, append a space to every undef/define line, to ease matching.
-echo 's/$/ /' >conftest.defines
-# Then, protect against being on the right side of a sed subst, or in
-# an unquoted here document, in config.status. If some macros were
-# called several times there might be several #defines for the same
-# symbol, which is useless. But do not sort them, since the last
-# AC_DEFINE must be honored.
-ac_word_re=[_$as_cr_Letters][_$as_cr_alnum]*
-# These sed commands are passed to sed as "A NAME B PARAMS C VALUE D", where
-# NAME is the cpp macro being defined, VALUE is the value it is being given.
-# PARAMS is the parameter list in the macro definition--in most cases, it's
-# just an empty string.
-ac_dA='s,^\\([ #]*\\)[^ ]*\\([ ]*'
-ac_dB='\\)[ (].*,\\1define\\2'
-ac_dC=' '
-ac_dD=' ,'
-uniq confdefs.h |
- sed -n '
- t rset
- :rset
- s/^[ ]*#[ ]*define[ ][ ]*//
- t ok
- d
- :ok
- s/[\\&,]/\\&/g
- s/^\('"$ac_word_re"'\)\(([^()]*)\)[ ]*\(.*\)/ '"$ac_dA"'\1'"$ac_dB"'\2'"${ac_dC}"'\3'"$ac_dD"'/p
- s/^\('"$ac_word_re"'\)[ ]*\(.*\)/'"$ac_dA"'\1'"$ac_dB$ac_dC"'\2'"$ac_dD"'/p
- ' >>conftest.defines
-# Remove the space that was appended to ease matching.
-# Then replace #undef with comments. This is necessary, for
-# example, in the case of _POSIX_SOURCE, which is predefined and required
-# on some systems where configure will not decide to define it.
-# (The regexp can be short, since the line contains either #define or #undef.)
-echo 's/ $//
-s,^[ #]*u.*,/* & */,' >>conftest.defines
-# Break up conftest.defines:
-ac_max_sed_lines=50
-# First sed command is: sed -f defines.sed $ac_file_inputs >"$tmp/out1"
-# Second one is: sed -f defines.sed "$tmp/out1" >"$tmp/out2"
-# Third one will be: sed -f defines.sed "$tmp/out2" >"$tmp/out1"
-# et cetera.
-ac_in='$ac_file_inputs'
-ac_out='"$tmp/out1"'
-ac_nxt='"$tmp/out2"'
-while :
-do
- # Write a here document:
- cat >>$CONFIG_STATUS <<_ACEOF
- # First, check the format of the line:
- cat >"\$tmp/defines.sed" <<\\CEOF
-/^[ ]*#[ ]*undef[ ][ ]*$ac_word_re[ ]*\$/b def
-/^[ ]*#[ ]*define[ ][ ]*$ac_word_re[( ]/b def
-b
-:def
-_ACEOF
- sed ${ac_max_sed_lines}q conftest.defines >>$CONFIG_STATUS
- echo 'CEOF
- sed -f "$tmp/defines.sed"' "$ac_in >$ac_out" >>$CONFIG_STATUS
- ac_in=$ac_out; ac_out=$ac_nxt; ac_nxt=$ac_in
- sed 1,${ac_max_sed_lines}d conftest.defines >conftest.tail
- grep . conftest.tail >/dev/null || break
- rm -f conftest.defines
- mv conftest.tail conftest.defines
-done
-echo "ac_result=$ac_in" >>$CONFIG_STATUS
- echo "/* $configure_input */" >"$tmp/config.h"
- cat "$ac_result" >>"$tmp/config.h"
- if diff $ac_file "$tmp/config.h" >/dev/null 2>&1; then
- { echo "$as_me:$LINENO: $ac_file is unchanged" >&5
-echo "$as_me: $ac_file is unchanged" >&6;}
+ $as_echo "/* $configure_input */" \
+ && eval '$AWK -f "$ac_tmp/defines.awk"' "$ac_file_inputs"
+ } >"$ac_tmp/config.h" \
+ if diff "$ac_file" "$ac_tmp/config.h" >/dev/null 2>&1; then
+ { $as_echo "$as_me:${as_lineno-$LINENO}: $ac_file is unchanged" >&5
+$as_echo "$as_me: $ac_file is unchanged" >&6;}
else
- rm -f $ac_file
- mv "$tmp/config.h" $ac_file
+ rm -f "$ac_file"
+ mv "$ac_tmp/config.h" "$ac_file" \
fi
else
- cat "$ac_result"
+ && eval '$AWK -f "$ac_tmp/defines.awk"' "$ac_file_inputs" \
+ || as_fn_error $? "could not create -" "$LINENO" 5
fi
- rm -f "$tmp/out12"
-# Compute $ac_file's index in $config_headers.
-_am_arg=$ac_file
+# Compute "$ac_file"'s index in $config_headers.
+_am_arg="$ac_file"
_am_stamp_count=1
for _am_header in $config_headers :; do
case $_am_header in
@@ -25318,7 +22959,7 @@
X"$_am_arg" : 'X\(//\)[^/]' \| \
X"$_am_arg" : 'X\(//\)$' \| \
X"$_am_arg" : 'X\(/\)' \| . 2>/dev/null ||
-echo X"$_am_arg" |
+$as_echo X"$_am_arg" |
s//\1/
q
@@ -25338,8 +22979,8 @@
s/.*/./; q'`/stamp-h$_am_stamp_count
- :C) { echo "$as_me:$LINENO: executing $ac_file commands" >&5
-echo "$as_me: executing $ac_file commands" >&6;}
+ :C) { $as_echo "$as_me:${as_lineno-$LINENO}: executing $ac_file commands" >&5
+$as_echo "$as_me: executing $ac_file commands" >&6;}
esac
@@ -25361,7 +23002,7 @@
X"$mf" : 'X\(//\)[^/]' \| \
X"$mf" : 'X\(//\)$' \| \
X"$mf" : 'X\(/\)' \| . 2>/dev/null ||
-echo X"$mf" |
+$as_echo X"$mf" |
s//\1/
q
@@ -25405,7 +23046,7 @@
X"$file" : 'X\(//\)[^/]' \| \
X"$file" : 'X\(//\)$' \| \
X"$file" : 'X\(/\)' \| . 2>/dev/null ||
-echo X"$file" |
+$as_echo X"$file" |
s//\1/
q
@@ -25423,47 +23064,7 @@
q
s/.*/./; q'`
- { as_dir=$dirpart/$fdir
- esac
- as_dirs=
- while :; do
- esac
-echo X"$as_dir" |
- s//\1/
- q
- s//\1/
- q
- /^X\(\/\/\)$/{
- s//\1/
- q
- /^X\(\/\).*/{
- s//\1/
- q
- s/.*/./; q'`
- done
+ as_dir=$dirpart/$fdir; as_fn_mkdir_p
# echo "creating $dirpart/$file"
echo '# dummy' > "$dirpart/$file"
done
@@ -25474,12 +23075,14 @@
done # for ac_tag
-{ (exit 0); exit 0; }
+as_fn_exit 0
_ACEOF
-chmod +x $CONFIG_STATUS
ac_clean_files=$ac_clean_files_save
+test $ac_write_fail = 0 ||
+ as_fn_error $? "write failure creating $CONFIG_STATUS" "$LINENO" 5
# configure is writing to config.log, and then calls config.status.
# config.status does its own redirection, appending to config.log.
# Unfortunately, on DOS this fails, as config.log is still kept open
@@ -25498,6 +23101,10 @@
exec 5>>config.log
# Use ||, not &&, to avoid exiting from the if with $? = 1, which
# would make configure fail if this is the last instruction.
- $ac_cs_success || { (exit 1); exit 1; }
+ $ac_cs_success || as_fn_exit 1
fi
+if test -n "$ac_unrecognized_opts" && test "$enable_option_checking" != no; then
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: unrecognized options: $ac_unrecognized_opts" >&5
+$as_echo "$as_me: WARNING: unrecognized options: $ac_unrecognized_opts" >&2;}
+fi
Modified: sandbox/jng/cmake_v2/Oem/dbxml/dbxml/dist/aclocal/options.ac
--- sandbox/jng/cmake_v2/Oem/dbxml/dbxml/dist/aclocal/options.ac 2018-01-05 11:44:27 UTC (rev 9278)
+++ sandbox/jng/cmake_v2/Oem/dbxml/dbxml/dist/aclocal/options.ac 2018-01-05 13:35:40 UTC (rev 9279)
@@ -228,13 +228,20 @@
elif test `ls $with_xerces/src/libxerces-c.* 2>/dev/null | wc -l` -gt 0 ; then
xerces_lib="$with_xerces/src"
else
- if test "$xerces_source_tree" = "yes" -a "$xerces_version_major" -ge "3"; then
- xerces_lib="$with_xerces/src"
+ # For distros like Ubuntu there are extra places to check for non-source-tree xerces assuming --with-xerces=/usr was given
+ # NOTE: Surely one would've have both 32 and 64 bit versions of this library installed ... right?
+ if test "$xerces_source_tree" = "no" -a `ls $with_xerces/lib/i386-linux-gnu/libxerces-c.* 2>/dev/null | wc -l` -gt 0 ; then
+ xerces_lib="$with_xerces/lib/i386-linux-gnu"
+ elif test "$xerces_source_tree" = "no" -a `ls $with_xerces/lib/x86_64-linux-gnu/libxerces-c.* 2>/dev/null | wc -l` -gt 0 ; then
+ xerces_lib="$with_xerces/lib/x86_64-linux-gnu"
else
- xerces_lib="$with_xerces/lib"
+ if test "$xerces_source_tree" = "yes" -a "$xerces_version_major" -ge "3"; then
+ xerces_lib="$with_xerces/src"
+ else
+ xerces_lib="$with_xerces/lib"
+ fi
+ AC_MSG_WARN([Unable to find the Xerces-C library. Guessed path is $xerces_lib.])
fi
- AC_MSG_WARN([Unable to find the Xerces-C library. Guessed path is $xerces_lib.])
fi
XERCES_DIR=$with_xerces
Modified: sandbox/jng/cmake_v2/Oem/dbxml/xqilla/configure
--- sandbox/jng/cmake_v2/Oem/dbxml/xqilla/configure 2018-01-05 11:44:27 UTC (rev 9278)
+++ sandbox/jng/cmake_v2/Oem/dbxml/xqilla/configure 2018-01-05 13:35:40 UTC (rev 9279)
@@ -1,11 +1,11 @@
#! /bin/sh
# Guess values for system-dependent variables and create Makefiles.
-# Generated by GNU Autoconf 2.64 for XQilla 2.2.4.
+# Generated by GNU Autoconf 2.69 for XQilla 2.2.4.
-# Copyright (C) 1992, 1993, 1994, 1995, 1996, 1998, 1999, 2000, 2001,
-# 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009 Free Software
-# Foundation, Inc.
+# Copyright (C) 1992-1996, 1998-2012 Free Software Foundation, Inc.
# This configure script is free software; the Free Software Foundation
# gives unlimited permission to copy, distribute and modify it.
@@ -87,6 +87,7 @@
IFS=" "" $as_nl"
+as_myself=
case $0 in #((
@@ -131,6 +132,31 @@
# CDPATH.
+# Use a proper internal environment variable to ensure we don't fall
+ # into an infinite loop, continuously re-executing ourselves.
+ if test x"${_as_can_reexec}" != xno && test "x$CONFIG_SHELL" != x; then
+ _as_can_reexec=no; export _as_can_reexec;
+ # We cannot yet assume a decent shell, so we have to provide a
+# neutralization value for shells without unset; and this also
+# works around shells that cannot unset nonexistent variables.
+# Preserve -v and -x to the replacement shell.
+BASH_ENV=/dev/null
+ENV=/dev/null
+(unset BASH_ENV) >/dev/null 2>&1 && unset BASH_ENV ENV
+case $- in # ((((
+ *v*x* | *x*v* ) as_opts=-vx ;;
+ *v* ) as_opts=-v ;;
+ *x* ) as_opts=-x ;;
+ * ) as_opts= ;;
+esac
+exec $CONFIG_SHELL $as_opts "$as_myself" ${1+"$@"}
+# Admittedly, this is quite paranoid, since all the known shells bail
+# out after a failed `exec'.
+$as_echo "$0: could not re-execute with $CONFIG_SHELL" >&2
+as_fn_exit 255
+ fi
+ # We don't want this to propagate to other subprocesses.
+ { _as_can_reexec=; unset _as_can_reexec;}
if test "x$CONFIG_SHELL" = x; then
as_bourne_compatible="if test -n \"\${ZSH_VERSION+set}\" && (emulate sh) >/dev/null 2>&1; then :
emulate sh
@@ -164,7 +190,8 @@
else
exitcode=1; echo positional parameters were not saved.
fi
-test x\$exitcode = x0 || exit 1"
+test x\$exitcode = x0 || exit 1
+test -x / || exit 1"
as_suggested=" as_lineno_1=";as_suggested=$as_suggested$LINENO;as_suggested=$as_suggested" as_lineno_1a=\$LINENO
as_lineno_2=";as_suggested=$as_suggested$LINENO;as_suggested=$as_suggested" as_lineno_2a=\$LINENO
eval 'test \"x\$as_lineno_1'\$as_run'\" != \"x\$as_lineno_2'\$as_run'\" &&
@@ -209,14 +236,25 @@
if test "x$CONFIG_SHELL" != x; then :
- # We cannot yet assume a decent shell, so we have to provide a
- # neutralization value for shells without unset; and this also
- # works around shells that cannot unset nonexistent variables.
- BASH_ENV=/dev/null
- ENV=/dev/null
- (unset BASH_ENV) >/dev/null 2>&1 && unset BASH_ENV ENV
- export CONFIG_SHELL
- exec "$CONFIG_SHELL" "$as_myself" ${1+"$@"}
+ export CONFIG_SHELL
+BASH_ENV=/dev/null
+ENV=/dev/null
+case $- in # ((((
+ * ) as_opts= ;;
+esac
+exit 255
fi
if test x$as_have_required = xno; then :
@@ -314,10 +352,18 @@
done
- } || test -d "$as_dir" || as_fn_error "cannot create directory $as_dir"
} # as_fn_mkdir_p
@@ -354,19 +400,19 @@
fi # as_fn_arith
-# as_fn_error ERROR [LINENO LOG_FD]
-# script with status $?, using 1 if that was 0.
as_fn_error ()
- as_status=$?; test $as_status -eq 0 && as_status=1
- if test "$3"; then
- as_lineno=${as_lineno-"$2"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
- $as_echo "$as_me:${as_lineno-$LINENO}: error: $1" >&$3
fi
- $as_echo "$as_me: error: $1" >&2
} # as_fn_error
@@ -439,6 +485,10 @@
{ $as_echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2; as_fn_exit 1; }
+ # If we had to re-execute with $CONFIG_SHELL, we're ensured to have
+ # already done that, so ensure we don't try to do so again and fall
+ # in an infinite loop. This has already happened in practice.
@@ -473,16 +523,16 @@
- as_ln_s='cp -p'
+ as_ln_s='cp -pR'
as_ln_s=ln
else
- as_ln_s='cp -p'
+ as_ln_s='cp -pR'
fi
else
- as_ln_s='cp -p'
+ as_ln_s='cp -pR'
fi
@@ -494,28 +544,8 @@
as_mkdir_p=false
fi
-else
- as_ls_L_option=L
- else
- as_ls_L_option=
- fi
- as_test_x='
- eval sh -c '\''
- test -d "$1/.";
- else
- case $1 in #(
- -*)set "./$1";;
- esac;
- case `ls -ld'$as_ls_L_option' "$1" 2>/dev/null` in #((
- '\'' sh
-fi
@@ -673,10 +703,11 @@
-exec 7<&0 </dev/null 6>&1
+test -n "$DJDIR" || exec 7<&0 </dev/null
+exec 6>&1
# Name of the host.
-# hostname on some systems (SVR3.2, Linux) returns a bogus exit status,
+# hostname on some systems (SVR3.2, old GNU/Linux) returns a bogus exit status,
# so uname gets run too.
ac_hostname=`(hostname || uname -n) 2>/dev/null | sed 1q`
@@ -973,8 +1004,9 @@
fi
case $ac_option in
- *=*) ac_optarg=`expr "X$ac_option" : '[^=]*=\(.*\)'` ;;
- *) ac_optarg=yes ;;
+ *=?*) ac_optarg=`expr "X$ac_option" : '[^=]*=\(.*\)'` ;;
+ *=) ac_optarg= ;;
+ *) ac_optarg=yes ;;
esac
# Accept the important Cygnus configure options, so we can diagnose typos.
@@ -1019,7 +1051,7 @@
ac_useropt=`expr "x$ac_option" : 'x-*disable-\(.*\)'`
# Reject names that are not valid shell variable names.
expr "x$ac_useropt" : ".*[^-+._$as_cr_alnum]" >/dev/null &&
- as_fn_error "invalid feature name: $ac_useropt"
+ as_fn_error $? "invalid feature name: $ac_useropt"
ac_useropt_orig=$ac_useropt
ac_useropt=`$as_echo "$ac_useropt" | sed 's/[-+.]/_/g'`
case $ac_user_opts in
@@ -1045,7 +1077,7 @@
ac_useropt=`expr "x$ac_option" : 'x-*enable-\([^=]*\)'`
@@ -1249,7 +1281,7 @@
ac_useropt=`expr "x$ac_option" : 'x-*with-\([^=]*\)'`
- as_fn_error "invalid package name: $ac_useropt"
+ as_fn_error $? "invalid package name: $ac_useropt"
@@ -1265,7 +1297,7 @@
ac_useropt=`expr "x$ac_option" : 'x-*without-\(.*\)'`
@@ -1295,8 +1327,8 @@
| --x-librar=* | --x-libra=* | --x-libr=* | --x-lib=* | --x-li=* | --x-l=*)
x_libraries=$ac_optarg ;;
- -*) as_fn_error "unrecognized option: \`$ac_option'
+ -*) as_fn_error $? "unrecognized option: \`$ac_option'
+Try \`$0 --help' for more information"
@@ -1304,7 +1336,7 @@
case $ac_envvar in #(
'' | [0-9]* | *[!_$as_cr_alnum]* )
- as_fn_error "invalid variable name: \`$ac_envvar'" ;;
+ as_fn_error $? "invalid variable name: \`$ac_envvar'" ;;
esac
eval $ac_envvar=\$ac_optarg
export $ac_envvar ;;
@@ -1314,7 +1346,7 @@
$as_echo "$as_me: WARNING: you should use --build, --host, --target" >&2
expr "x$ac_option" : ".*[^-._$as_cr_alnum]" >/dev/null &&
$as_echo "$as_me: WARNING: invalid host type: $ac_option" >&2
- : ${build_alias=$ac_option} ${host_alias=$ac_option} ${target_alias=$ac_option}
+ : "${build_alias=$ac_option} ${host_alias=$ac_option} ${target_alias=$ac_option}"
esac
@@ -1322,13 +1354,13 @@
if test -n "$ac_prev"; then
ac_option=--`echo $ac_prev | sed 's/_/-/g'`
- as_fn_error "missing argument to $ac_option"
+ as_fn_error $? "missing argument to $ac_option"
fi
if test -n "$ac_unrecognized_opts"; then
case $enable_option_checking in
no) ;;
- fatal) as_fn_error "unrecognized options: $ac_unrecognized_opts" ;;
+ fatal) as_fn_error $? "unrecognized options: $ac_unrecognized_opts" ;;
*) $as_echo "$as_me: WARNING: unrecognized options: $ac_unrecognized_opts" >&2 ;;
esac
fi
@@ -1351,7 +1383,7 @@
[\\/$]* | ?:[\\/]* ) continue;;
NONE | '' ) case $ac_var in *prefix ) continue;; esac;;
esac
- as_fn_error "expected an absolute directory name for --$ac_var: $ac_val"
+ as_fn_error $? "expected an absolute directory name for --$ac_var: $ac_val"
done
# There might be people who depend on the old broken behavior: `$host'
@@ -1365,8 +1397,6 @@
if test "x$host_alias" != x; then
if test "x$build_alias" = x; then
cross_compiling=maybe
- $as_echo "$as_me: WARNING: If you wanted to set the --build type, don't use --host.
- If a cross compiler is detected then cross compile mode will be used." >&2
elif test "x$build_alias" != "x$host_alias"; then
cross_compiling=yes
fi
@@ -1381,9 +1411,9 @@
ac_pwd=`pwd` && test -n "$ac_pwd" &&
ac_ls_di=`ls -di .` &&
ac_pwd_ls_di=`cd "$ac_pwd" && ls -di .` ||
- as_fn_error "working directory cannot be determined"
+ as_fn_error $? "working directory cannot be determined"
test "X$ac_ls_di" = "X$ac_pwd_ls_di" ||
- as_fn_error "pwd does not report name of working directory"
+ as_fn_error $? "pwd does not report name of working directory"
# Find the source files, if location was not specified.
@@ -1422,11 +1452,11 @@
fi
if test ! -r "$srcdir/$ac_unique_file"; then
test "$ac_srcdir_defaulted" = yes && srcdir="$ac_confdir or .."
- as_fn_error "cannot find sources ($ac_unique_file) in $srcdir"
+ as_fn_error $? "cannot find sources ($ac_unique_file) in $srcdir"
fi
ac_msg="sources are in $srcdir, but \`cd $srcdir' does not work"
ac_abs_confdir=`(
- cd "$srcdir" && test -r "./$ac_unique_file" || as_fn_error "$ac_msg"
+ cd "$srcdir" && test -r "./$ac_unique_file" || as_fn_error $? "$ac_msg"
pwd)`
# When building in place, set srcdir=.
if test "$ac_abs_confdir" = "$ac_pwd"; then
@@ -1466,7 +1496,7 @@
--help=short display options specific to this package
--help=recursive display the short help of all the included packages
-V, --version display version information and exit
- -q, --quiet, --silent do not print \`checking...' messages
+ -q, --quiet, --silent do not print \`checking ...' messages
--cache-file=FILE cache test results in FILE [disabled]
-C, --config-cache alias for \`--cache-file=config.cache'
-n, --no-create do not create output files
@@ -1560,14 +1590,15 @@
LDFLAGS linker flags, e.g. -L<lib dir> if you have libraries in a
nonstandard directory <lib dir>
LIBS libraries to pass to the linker, e.g. -l<library>
- CPPFLAGS C/C++/Objective C preprocessor flags, e.g. -I<include dir> if
+ CPPFLAGS (Objective) C/C++ preprocessor flags, e.g. -I<include dir> if
you have headers in a nonstandard directory <include dir>
CC C compiler command
CFLAGS C compiler flags
CPP C preprocessor
CXXCPP C++ preprocessor
- YACC The `Yet Another C Compiler' implementation to use. Defaults to
- the first program found out of: `bison -y', `byacc', `yacc'.
+ YACC The `Yet Another Compiler Compiler' implementation to use.
+ Defaults to the first program found out of: `bison -y', `byacc',
+ `yacc'.
YFLAGS The list of arguments that will be passed by default to $YACC.
This script will default YFLAGS to the empty string to avoid a
default value of `-d' given by some make applications.
@@ -1639,9 +1670,9 @@
if $ac_init_version; then
cat <<\_ACEOF
XQilla configure 2.2.4
-generated by GNU Autoconf 2.64
-Copyright (C) 2009 Free Software Foundation, Inc.
_ACEOF
@@ -1685,8 +1716,8 @@
ac_retval=1
fi
- eval $as_lineno_stack; test "x$as_lineno_stack" = x && { as_lineno=; unset as_lineno;}
- return $ac_retval
+ eval $as_lineno_stack; ${as_lineno_stack:+:} unset as_lineno
+ as_fn_set_status $ac_retval
} # ac_fn_cxx_try_compile
@@ -1723,8 +1754,8 @@
ac_retval=1
fi
- return $ac_retval
} # ac_fn_c_try_compile
@@ -1755,7 +1786,7 @@
test ! -s conftest.err
} && test -s conftest$ac_exeext && {
test "$cross_compiling" = yes ||
- $as_test_x conftest$ac_exeext
+ test -x conftest$ac_exeext
}; then :
ac_retval=0
else
@@ -1769,8 +1800,8 @@
# interfere with the next link command; also delete a directory that is
# left behind by Apple's compiler. We do this before executing the actions.
rm -rf conftest.dSYM conftest_ipa8_conftest.oo
- return $ac_retval
} # ac_fn_c_try_link
@@ -1783,7 +1814,7 @@
as_lineno=${as_lineno-"$1"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $2" >&5
$as_echo_n "checking for $2... " >&6; }
-if { as_var=$3; eval "test \"\${$as_var+set}\" = set"; }; then :
+if eval \${$3+:} false; then :
$as_echo_n "(cached) " >&6
else
cat confdefs.h - <<_ACEOF >conftest.$ac_ext
@@ -1801,7 +1832,7 @@
eval ac_res=\$$3
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_res" >&5
$as_echo "$ac_res" >&6; }
} # ac_fn_c_check_header_compile
@@ -1826,7 +1857,7 @@
mv -f conftest.er1 conftest.err
fi
$as_echo "$as_me:${as_lineno-$LINENO}: \$? = $ac_status" >&5
- test $ac_status = 0; } >/dev/null && {
+ test $ac_status = 0; } > conftest.i && {
test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" ||
}; then :
@@ -1837,8 +1868,8 @@
ac_retval=1
fi
- return $ac_retval
} # ac_fn_c_try_cpp
@@ -1879,8 +1910,8 @@
ac_retval=$ac_status
fi
- return $ac_retval
} # ac_fn_c_try_run
@@ -1892,7 +1923,7 @@
else
@@ -1947,7 +1978,7 @@
eval ac_res=\$$3
} # ac_fn_c_check_func
@@ -1972,7 +2003,7 @@
fi
test -z "$ac_cxx_preproc_warn_flag$ac_cxx_werror_flag" ||
}; then :
@@ -1983,8 +2014,8 @@
ac_retval=1
fi
- return $ac_retval
} # ac_fn_cxx_try_cpp
@@ -2015,7 +2046,7 @@
}; then :
ac_retval=0
else
@@ -2029,11 +2060,65 @@
- return $ac_retval
} # ac_fn_cxx_try_link
+# ac_fn_c_check_type LINENO TYPE VAR INCLUDES
+# Tests whether TYPE exists after having included INCLUDES, setting cache
+# variable VAR accordingly.
+ac_fn_c_check_type ()
+ as_lineno=${as_lineno-"$1"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking for $2" >&5
+$as_echo_n "checking for $2... " >&6; }
+ $as_echo_n "(cached) " >&6
+else
+ eval "$3=no"
+ cat confdefs.h - <<_ACEOF >conftest.$ac_ext
+/* end confdefs.h. */
+$4
+int
+main ()
+if (sizeof ($2))
+ return 0;
+ return 0;
+_ACEOF
+if ac_fn_c_try_compile "$LINENO"; then :
+$4
+int
+main ()
+if (sizeof (($2)))
+ return 0;
+ return 0;
+_ACEOF
+else
+ eval "$3=yes"
+fi
+rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
+fi
+fi
+eval ac_res=\$$3
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_res" >&5
+$as_echo "$ac_res" >&6; }
+} # ac_fn_c_check_type
# ac_fn_c_check_header_mongrel LINENO HEADER VAR INCLUDES
# Tests whether HEADER exists, giving a warning if it cannot be compiled using
@@ -2042,10 +2127,10 @@
ac_fn_c_check_header_mongrel ()
- if { as_var=$3; eval "test \"\${$as_var+set}\" = set"; }; then :
+ if eval \${$3+:} false; then :
fi
eval ac_res=\$$3
@@ -2081,7 +2166,7 @@
else
ac_header_preproc=no
fi
-rm -f conftest.err conftest.$ac_ext
+rm -f conftest.err conftest.i conftest.$ac_ext
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_header_preproc" >&5
$as_echo "$ac_header_preproc" >&6; }
@@ -2108,7 +2193,7 @@
esac
else
eval "$3=\$ac_header_compiler"
@@ -2117,69 +2202,15 @@
fi
} # ac_fn_c_check_header_mongrel
-# ac_fn_c_check_type LINENO TYPE VAR INCLUDES
-# Tests whether TYPE exists after having included INCLUDES, setting cache
-# variable VAR accordingly.
-ac_fn_c_check_type ()
- as_lineno=${as_lineno-"$1"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for $2" >&5
-$as_echo_n "checking for $2... " >&6; }
- $as_echo_n "(cached) " >&6
-else
- eval "$3=no"
- cat confdefs.h - <<_ACEOF >conftest.$ac_ext
-/* end confdefs.h. */
-$4
-int
-main ()
-if (sizeof ($2))
- return 0;
- return 0;
-_ACEOF
-if ac_fn_c_try_compile "$LINENO"; then :
-$4
-int
-main ()
-if (sizeof (($2)))
- return 0;
- return 0;
-_ACEOF
-else
- eval "$3=yes"
-fi
-rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
-fi
-fi
-eval ac_res=\$$3
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_res" >&5
-$as_echo "$ac_res" >&6; }
-} # ac_fn_c_check_type
cat >config.log <<_ACEOF
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by XQilla $as_me 2.2.4, which was
-generated by GNU Autoconf 2.64. Invocation command line was
$ $0 $@
@@ -2289,11 +2320,9 @@
echo
- cat <<\_ASBOX
+ $as_echo "## ---------------- ##
## Cache variables. ##
-_ASBOX
echo
# The following way of writing the cache mishandles newlines in values,
@@ -2327,11 +2356,9 @@
echo
- cat <<\_ASBOX
+ $as_echo "## ----------------- ##
## Output variables. ##
-_ASBOX
echo
for ac_var in $ac_subst_vars
do
@@ -2344,11 +2371,9 @@
echo
if test -n "$ac_subst_files"; then
- cat <<\_ASBOX
+ $as_echo "## ------------------- ##
## File substitutions. ##
-_ASBOX
echo
for ac_var in $ac_subst_files
do
@@ -2362,11 +2387,9 @@
fi
if test -s confdefs.h; then
- cat <<\_ASBOX
+ $as_echo "## ----------- ##
## confdefs.h. ##
-_ASBOX
echo
cat confdefs.h
echo
@@ -2421,7 +2444,12 @@
ac_site_file1=NONE
ac_site_file2=NONE
if test -n "$CONFIG_SITE"; then
- ac_site_file1=$CONFIG_SITE
+ # We do not want a PATH search for config.site.
+ case $CONFIG_SITE in #((
+ -*) ac_site_file1=./$CONFIG_SITE;;
+ */*) ac_site_file1=$CONFIG_SITE;;
+ *) ac_site_file1=./$CONFIG_SITE;;
+ esac
elif test "x$prefix" != xNONE; then
ac_site_file1=$prefix/share/config.site
ac_site_file2=$prefix/etc/config.site
@@ -2432,18 +2460,22 @@
for ac_site_file in "$ac_site_file1" "$ac_site_file2"
do
test "x$ac_site_file" = xNONE && continue
- if test -r "$ac_site_file"; then
+ if test /dev/null != "$ac_site_file" && test -r "$ac_site_file"; then
{ $as_echo "$as_me:${as_lineno-$LINENO}: loading site script $ac_site_file" >&5
$as_echo "$as_me: loading site script $ac_site_file" >&6;}
sed 's/^/| /' "$ac_site_file" >&5
- . "$ac_site_file"
+ . "$ac_site_file" \
+ || { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
+$as_echo "$as_me: error: in \`$ac_pwd':" >&2;}
+as_fn_error $? "failed to load site script $ac_site_file
+See \`config.log' for more details" "$LINENO" 5; }
fi
done
if test -r "$cache_file"; then
- # Some versions of bash will fail to source /dev/null (special
- # files actually), so we avoid doing that.
- if test -f "$cache_file"; then
+ # Some versions of bash will fail to source /dev/null (special files
+ # actually), so we avoid doing that. DJGPP emulates it as a regular file.
+ if test /dev/null != "$cache_file" && test -f "$cache_file"; then
{ $as_echo "$as_me:${as_lineno-$LINENO}: loading cache $cache_file" >&5
$as_echo "$as_me: loading cache $cache_file" >&6;}
case $cache_file in
@@ -2515,7 +2547,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: error: changes in the environment can compromise the build" >&5
$as_echo "$as_me: error: changes in the environment can compromise the build" >&2;}
- as_fn_error "run \`make distclean' and/or \`rm $cache_file' and start over" "$LINENO" 5
+ as_fn_error $? "run \`make distclean' and/or \`rm $cache_file' and start over" "$LINENO" 5
fi
## Main body of script. ##
@@ -2530,16 +2562,22 @@
ac_aux_dir=
for ac_dir in autotools "$srcdir"/autotools; do
- for ac_t in install-sh install.sh shtool; do
- if test -f "$ac_dir/$ac_t"; then
- ac_aux_dir=$ac_dir
- ac_install_sh="$ac_aux_dir/$ac_t -c"
- break 2
- fi
- done
+ if test -f "$ac_dir/install-sh"; then
+ ac_aux_dir=$ac_dir
+ ac_install_sh="$ac_aux_dir/install-sh -c"
+ break
+ elif test -f "$ac_dir/install.sh"; then
+ ac_install_sh="$ac_aux_dir/install.sh -c"
+ break
+ elif test -f "$ac_dir/shtool"; then
+ ac_install_sh="$ac_aux_dir/shtool install -c"
+ break
+ fi
done
if test -z "$ac_aux_dir"; then
- as_fn_error "cannot find install-sh, install.sh, or shtool in autotools \"$srcdir\"/autotools" "$LINENO" 5
+ as_fn_error $? "cannot find install-sh, install.sh, or shtool in autotools \"$srcdir\"/autotools" "$LINENO" 5
fi
# These three variables are undocumented and unsupported,
@@ -2553,27 +2591,27 @@
# Make sure we can run config.sub.
$SHELL "$ac_aux_dir/config.sub" sun4 >/dev/null 2>&1 ||
- as_fn_error "cannot run $SHELL $ac_aux_dir/config.sub" "$LINENO" 5
+ as_fn_error $? "cannot run $SHELL $ac_aux_dir/config.sub" "$LINENO" 5
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking build system type" >&5
$as_echo_n "checking build system type... " >&6; }
-if test "${ac_cv_build+set}" = set; then :
+if ${ac_cv_build+:} false; then :
else
ac_build_alias=$build_alias
test "x$ac_build_alias" = x &&
ac_build_alias=`$SHELL "$ac_aux_dir/config.guess"`
- as_fn_error "cannot guess build type; you must specify one" "$LINENO" 5
+ as_fn_error $? "cannot guess build type; you must specify one" "$LINENO" 5
ac_cv_build=`$SHELL "$ac_aux_dir/config.sub" $ac_build_alias` ||
- as_fn_error "$SHELL $ac_aux_dir/config.sub $ac_build_alias failed" "$LINENO" 5
+ as_fn_error $? "$SHELL $ac_aux_dir/config.sub $ac_build_alias failed" "$LINENO" 5
fi
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_build" >&5
$as_echo "$ac_cv_build" >&6; }
case $ac_cv_build in
-*) as_fn_error "invalid value of canonical build" "$LINENO" 5;;
+*) as_fn_error $? "invalid value of canonical build" "$LINENO" 5;;
esac
build=$ac_cv_build
ac_save_IFS=$IFS; IFS='-'
@@ -2591,14 +2629,14 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking host system type" >&5
$as_echo_n "checking host system type... " >&6; }
-if test "${ac_cv_host+set}" = set; then :
+if ${ac_cv_host+:} false; then :
else
if test "x$host_alias" = x; then
ac_cv_host=$ac_cv_build
else
ac_cv_host=`$SHELL "$ac_aux_dir/config.sub" $host_alias` ||
- as_fn_error "$SHELL $ac_aux_dir/config.sub $host_alias failed" "$LINENO" 5
+ as_fn_error $? "$SHELL $ac_aux_dir/config.sub $host_alias failed" "$LINENO" 5
fi
fi
@@ -2606,7 +2644,7 @@
$as_echo "$ac_cv_host" >&6; }
case $ac_cv_host in
-*) as_fn_error "invalid value of canonical host" "$LINENO" 5;;
+*) as_fn_error $? "invalid value of canonical host" "$LINENO" 5;;
esac
host=$ac_cv_host
@@ -2624,14 +2662,14 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking target system type" >&5
$as_echo_n "checking target system type... " >&6; }
-if test "${ac_cv_target+set}" = set; then :
+if ${ac_cv_target+:} false; then :
else
if test "x$target_alias" = x; then
ac_cv_target=$ac_cv_host
else
ac_cv_target=`$SHELL "$ac_aux_dir/config.sub" $target_alias` ||
- as_fn_error "$SHELL $ac_aux_dir/config.sub $target_alias failed" "$LINENO" 5
+ as_fn_error $? "$SHELL $ac_aux_dir/config.sub $target_alias failed" "$LINENO" 5
fi
fi
@@ -2639,7 +2677,7 @@
$as_echo "$ac_cv_target" >&6; }
case $ac_cv_target in
-*) as_fn_error "invalid value of canonical target" "$LINENO" 5;;
+*) as_fn_error $? "invalid value of canonical target" "$LINENO" 5;;
esac
target=$ac_cv_target
@@ -2680,7 +2718,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for a BSD-compatible install" >&5
$as_echo_n "checking for a BSD-compatible install... " >&6; }
if test -z "$INSTALL"; then
-if test "${ac_cv_path_install+set}" = set; then :
+if ${ac_cv_path_install+:} false; then :
else
as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
@@ -2700,7 +2738,7 @@
# by default.
for ac_prog in ginstall scoinst install; do
for ac_exec_ext in '' $ac_executable_extensions; do
- if { test -f "$as_dir/$ac_prog$ac_exec_ext" && $as_test_x "$as_dir/$ac_prog$ac_exec_ext"; }; then
+ if as_fn_executable_p "$as_dir/$ac_prog$ac_exec_ext"; then
if test $ac_prog = install &&
grep dspmsg "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
# AIX install. It has an incompatible calling convention.
@@ -2767,11 +2805,11 @@
case `pwd` in
*[\\\"\#\$\&\'\`$am_lf]*)
- as_fn_error "unsafe absolute working directory name" "$LINENO" 5;;
+ as_fn_error $? "unsafe absolute working directory name" "$LINENO" 5;;
esac
case $srcdir in
*[\\\"\#\$\&\'\`$am_lf\ \ ]*)
- as_fn_error "unsafe srcdir value: \`$srcdir'" "$LINENO" 5;;
+ as_fn_error $? "unsafe srcdir value: \`$srcdir'" "$LINENO" 5;;
esac
# Do `set' in a subshell so we don't clobber the current shell's
@@ -2793,7 +2831,7 @@
# if, for instance, CONFIG_SHELL is bash and it inherits a
# broken ls alias from the environment. This has actually
# happened. Such a system could not be considered "sane".
- as_fn_error "ls -t appears to fail. Make sure there is not a broken
+ as_fn_error $? "ls -t appears to fail. Make sure there is not a broken
alias in your environment" "$LINENO" 5
fi
@@ -2803,7 +2841,7 @@
# Ok.
else
- as_fn_error "newly created file is older than distributed files!
+ as_fn_error $? "newly created file is older than distributed files!
Check your system clock" "$LINENO" 5
fi
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
@@ -2857,7 +2895,7 @@
set dummy ${ac_tool_prefix}strip; ac_word=$2
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $ac_word" >&5
$as_echo_n "checking for $ac_word... " >&6; }
-if test "${ac_cv_prog_STRIP+set}" = set; then :
+if ${ac_cv_prog_STRIP+:} false; then :
else
if test -n "$STRIP"; then
@@ -2869,7 +2907,7 @@
IFS=$as_save_IFS
test -z "$as_dir" && as_dir=.
- if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then
+ if as_fn_executable_p "$as_dir/$ac_word$ac_exec_ext"; then
ac_cv_prog_STRIP="${ac_tool_prefix}strip"
$as_echo "$as_me:${as_lineno-$LINENO}: found $as_dir/$ac_word$ac_exec_ext" >&5
break 2
@@ -2897,7 +2935,7 @@
set dummy strip; ac_word=$2
-if test "${ac_cv_prog_ac_ct_STRIP+set}" = set; then :
+if ${ac_cv_prog_ac_ct_STRIP+:} false; then :
else
if test -n "$ac_ct_STRIP"; then
@@ -2909,7 +2947,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_STRIP="strip"
break 2
@@ -2950,7 +2988,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for a thread-safe mkdir -p" >&5
$as_echo_n "checking for a thread-safe mkdir -p... " >&6; }
if test -z "$MKDIR_P"; then
- if test "${ac_cv_path_mkdir+set}" = set; then :
+ if ${ac_cv_path_mkdir+:} false; then :
else
@@ -2960,7 +2998,7 @@
for ac_prog in mkdir gmkdir; do
- { test -f "$as_dir/$ac_prog$ac_exec_ext" && $as_test_x "$as_dir/$ac_prog$ac_exec_ext"; } || continue
+ as_fn_executable_p "$as_dir/$ac_prog$ac_exec_ext" || continue
case `"$as_dir/$ac_prog$ac_exec_ext" --version 2>&1` in #(
'mkdir (GNU coreutils) '* | \
'mkdir (coreutils) '* | \
@@ -2975,6 +3013,7 @@
fi
+ test -d ./--version && rmdir ./--version
MKDIR_P="$ac_cv_path_mkdir -p"
else
@@ -2982,7 +3021,6 @@
# value for MKDIR_P within a source directory, because that will
# break other packages using the cache if that directory is
# removed, or if the value is a relative name.
- test -d ./--version && rmdir ./--version
MKDIR_P="$ac_install_sh -d"
fi
fi
@@ -3001,7 +3039,7 @@
set dummy $ac_prog; ac_word=$2
-if test "${ac_cv_prog_AWK+set}" = set; then :
+if ${ac_cv_prog_AWK+:} false; then :
else
if test -n "$AWK"; then
@@ -3013,7 +3051,7 @@
IFS=$as_save_IFS
ac_cv_prog_AWK="$ac_prog"
break 2
@@ -3041,7 +3079,7 @@
$as_echo_n "checking whether ${MAKE-make} sets \$(MAKE)... " >&6; }
set x ${MAKE-make}
ac_make=`$as_echo "$2" | sed 's/+/p/g; s/[^a-zA-Z0-9_]/_/g'`
-if { as_var=ac_cv_prog_make_${ac_make}_set; eval "test \"\${$as_var+set}\" = set"; }; then :
+if eval \${ac_cv_prog_make_${ac_make}_set+:} false; then :
else
cat >conftest.make <<\_ACEOF
@@ -3049,7 +3087,7 @@
all:
@echo '@@@%%%=$(MAKE)=@@@%%%'
_ACEOF
-# GNU make sometimes prints "make[1]: Entering...", which would confuse us.
+# GNU make sometimes prints "make[1]: Entering ...", which would confuse us.
case `${MAKE-make} -f conftest.make 2>/dev/null` in
eval ac_cv_prog_make_${ac_make}_set=yes;;
@@ -3083,7 +3121,7 @@
am__isrc=' -I$(srcdir)'
# test to see if srcdir already configured
if test -f $srcdir/config.status; then
- as_fn_error "source directory already configured; run \"make distclean\" there first" "$LINENO" 5
+ as_fn_error $? "source directory already configured; run \"make distclean\" there first" "$LINENO" 5
fi
fi
@@ -3276,7 +3314,7 @@
xerces_source_tree="yes"
else
- as_fn_error "Unable to find the Xerces-C include directory." "$LINENO" 5
+ as_fn_error $? "Unable to find the Xerces-C include directory." "$LINENO" 5
fi
# Work out the Xerces-C version
@@ -3289,7 +3327,7 @@
$as_echo "$xerces_version" >&6; }
if test "$xerces_version_major" -lt "3" -a "$xerces_source_tree" = "no"; then
- as_fn_error "For Xerces-C versions before 3.0 the source tree is required to build XQilla. You must specify the path to the Xerces-C source tree using --with-xerces." "$LINENO" 5
+ as_fn_error $? "For Xerces-C versions before 3.0 the source tree is required to build XQilla. You must specify the path to the Xerces-C source tree using --with-xerces." "$LINENO" 5
fi
# Find the library
@@ -3298,14 +3336,21 @@
else
else
+ else
+ fi
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: Unable to find the Xerces-C library. Guessed path is $xerces_lib." >&5
+$as_echo "$as_me: WARNING: Unable to find the Xerces-C library. Guessed path is $xerces_lib." >&2;}
fi
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: Unable to find the Xerces-C library. Guessed path is $xerces_lib." >&5
-$as_echo "$as_me: WARNING: Unable to find the Xerces-C library. Guessed path is $xerces_lib." >&2;}
fi
@@ -3410,7 +3455,7 @@
set dummy $ac_tool_prefix$ac_prog; ac_word=$2
-if test "${ac_cv_prog_CXX+set}" = set; then :
+if ${ac_cv_prog_CXX+:} false; then :
else
if test -n "$CXX"; then
@@ -3422,7 +3467,7 @@
IFS=$as_save_IFS
ac_cv_prog_CXX="$ac_tool_prefix$ac_prog"
break 2
@@ -3454,7 +3499,7 @@
-if test "${ac_cv_prog_ac_ct_CXX+set}" = set; then :
+if ${ac_cv_prog_ac_ct_CXX+:} false; then :
else
if test -n "$ac_ct_CXX"; then
@@ -3466,7 +3511,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_CXX="$ac_prog"
break 2
@@ -3524,32 +3569,30 @@
... rest of stderr output deleted ...
10q' conftest.err >conftest.er1
cat conftest.er1 >&5
- rm -f conftest.er1 conftest.err
fi
+ rm -f conftest.er1 conftest.err
done
-#include <stdio.h>
int
main ()
-FILE *f = fopen ("conftest.out", "w");
- return ferror (f) || fclose (f) != 0;
return 0;
_ACEOF
ac_clean_files_save=$ac_clean_files
-ac_clean_files="$ac_clean_files a.out a.out.dSYM a.exe b.out conftest.out"
+ac_clean_files="$ac_clean_files a.out a.out.dSYM a.exe b.out"
# Try to create an executable without -o first, disregard a.out.
# It will help us diagnose broken compilers, and finding out an intuition
# of exeext.
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for C++ compiler default output file name" >&5
-$as_echo_n "checking for C++ compiler default output file name... " >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the C++ compiler works" >&5
+$as_echo_n "checking whether the C++ compiler works... " >&6; }
ac_link_default=`$as_echo "$ac_link" | sed 's/ -o *conftest[^ ]*//'`
# The possible output files:
@@ -3611,62 +3654,28 @@
else
ac_file=''
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_file" >&5
-$as_echo "$ac_file" >&6; }
if test -z "$ac_file"; then :
- $as_echo "$as_me: failed program was:" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
+$as_echo "no" >&6; }
+$as_echo "$as_me: failed program was:" >&5
sed 's/^/| /' conftest.$ac_ext >&5
-{ as_fn_set_status 77
-as_fn_error "C++ compiler cannot create executables
-See \`config.log' for more details." "$LINENO" 5; }; }
+as_fn_error 77 "C++ compiler cannot create executables
+else
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
+$as_echo "yes" >&6; }
fi
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for C++ compiler default output file name" >&5
+$as_echo_n "checking for C++ compiler default output file name... " >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_file" >&5
+$as_echo "$ac_file" >&6; }
ac_exeext=$ac_cv_exeext
-# Check that the compiler produces executables we can run. If not, either
-# the compiler is broken, or we cross compile.
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the C++ compiler works" >&5
-$as_echo_n "checking whether the C++ compiler works... " >&6; }
-# If not cross compiling, check that we can run a simple program.
-if test "$cross_compiling" != yes; then
- if { ac_try='./$ac_file'
- { { case "(($ac_try" in
- *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
- *) ac_try_echo=$ac_try;;
-esac
-eval ac_try_echo="\"\$as_me:${as_lineno-$LINENO}: $ac_try_echo\""
-$as_echo "$ac_try_echo"; } >&5
- (eval "$ac_try") 2>&5
- ac_status=$?
- $as_echo "$as_me:${as_lineno-$LINENO}: \$? = $ac_status" >&5
- test $ac_status = 0; }; }; then
- cross_compiling=no
- else
- if test "$cross_compiling" = maybe; then
- cross_compiling=yes
- else
- { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
-$as_echo "$as_me: error: in \`$ac_pwd':" >&2;}
-as_fn_error "cannot run C++ compiled programs.
-If you meant to cross compile, use \`--host'.
- fi
- fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
-$as_echo "yes" >&6; }
-rm -f -r a.out a.out.dSYM a.exe conftest$ac_cv_exeext b.out conftest.out
+rm -f -r a.out a.out.dSYM a.exe conftest$ac_cv_exeext b.out
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether we are cross compiling" >&5
-$as_echo_n "checking whether we are cross compiling... " >&6; }
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $cross_compiling" >&5
-$as_echo "$cross_compiling" >&6; }
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for suffix of executables" >&5
$as_echo_n "checking for suffix of executables... " >&6; }
if { { ac_try="$ac_link"
@@ -3696,19 +3705,78 @@
else
-as_fn_error "cannot compute suffix of executables: cannot compile and link
+as_fn_error $? "cannot compute suffix of executables: cannot compile and link
fi
-rm -f conftest$ac_cv_exeext
+rm -f conftest conftest$ac_cv_exeext
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_exeext" >&5
$as_echo "$ac_cv_exeext" >&6; }
rm -f conftest.$ac_ext
EXEEXT=$ac_cv_exeext
ac_exeext=$EXEEXT
+cat confdefs.h - <<_ACEOF >conftest.$ac_ext
+#include <stdio.h>
+int
+main ()
+FILE *f = fopen ("conftest.out", "w");
+ return ferror (f) || fclose (f) != 0;
+ return 0;
+_ACEOF
+ac_clean_files="$ac_clean_files conftest.out"
+# Check that the compiler produces executables we can run. If not, either
+# the compiler is broken, or we cross compile.
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether we are cross compiling" >&5
+$as_echo_n "checking whether we are cross compiling... " >&6; }
+if test "$cross_compiling" != yes; then
+ { { ac_try="$ac_link"
+case "(($ac_try" in
+ *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
+ *) ac_try_echo=$ac_try;;
+esac
+eval ac_try_echo="\"\$as_me:${as_lineno-$LINENO}: $ac_try_echo\""
+$as_echo "$ac_try_echo"; } >&5
+ (eval "$ac_link") 2>&5
+ ac_status=$?
+ $as_echo "$as_me:${as_lineno-$LINENO}: \$? = $ac_status" >&5
+ if { ac_try='./conftest$ac_cv_exeext'
+ { { case "(($ac_try" in
+esac
+ (eval "$ac_try") 2>&5
+ ac_status=$?
+ test $ac_status = 0; }; }; then
+ cross_compiling=no
+ else
+ if test "$cross_compiling" = maybe; then
+ cross_compiling=yes
+ else
+ { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
+as_fn_error $? "cannot run C++ compiled programs.
+If you meant to cross compile, use \`--host'.
+ fi
+ fi
+fi
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $cross_compiling" >&5
+$as_echo "$cross_compiling" >&6; }
+rm -f conftest.$ac_ext conftest$ac_cv_exeext conftest.out
+ac_clean_files=$ac_clean_files_save
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for suffix of object files" >&5
$as_echo_n "checking for suffix of object files... " >&6; }
-if test "${ac_cv_objext+set}" = set; then :
+if ${ac_cv_objext+:} false; then :
else
@@ -3748,8 +3816,8 @@
-as_fn_error "cannot compute suffix of object files: cannot compile
+as_fn_error $? "cannot compute suffix of object files: cannot compile
fi
rm -f conftest.$ac_cv_objext conftest.$ac_ext
fi
@@ -3759,7 +3827,7 @@
ac_objext=$OBJEXT
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether we are using the GNU C++ compiler" >&5
$as_echo_n "checking whether we are using the GNU C++ compiler... " >&6; }
-if test "${ac_cv_cxx_compiler_gnu+set}" = set; then :
+if ${ac_cv_cxx_compiler_gnu+:} false; then :
else
@@ -3796,7 +3864,7 @@
ac_save_CXXFLAGS=$CXXFLAGS
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether $CXX accepts -g" >&5
$as_echo_n "checking whether $CXX accepts -g... " >&6; }
-if test "${ac_cv_prog_cxx_g+set}" = set; then :
+if ${ac_cv_prog_cxx_g+:} false; then :
else
ac_save_cxx_werror_flag=$ac_cxx_werror_flag
@@ -3882,7 +3950,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking dependency style of $depcc" >&5
$as_echo_n "checking dependency style of $depcc... " >&6; }
-if test "${am_cv_CXX_dependencies_compiler_type+set}" = set; then :
+if ${am_cv_CXX_dependencies_compiler_type+:} false; then :
else
if test -z "$AMDEP_TRUE" && test -f "$am_depcomp"; then
@@ -4216,7 +4284,7 @@
else
@@ -4228,7 +4296,7 @@
IFS=$as_save_IFS
break 2
@@ -4260,7 +4328,7 @@
else
@@ -4272,7 +4340,7 @@
IFS=$as_save_IFS
break 2
@@ -4330,15 +4398,15 @@
fi
done
else
@@ -4375,7 +4443,7 @@
else
@@ -4461,7 +4529,7 @@
else
@@ -4594,7 +4662,7 @@
set dummy ${ac_tool_prefix}gcc; ac_word=$2
-if test "${ac_cv_prog_CC+set}" = set; then :
+if ${ac_cv_prog_CC+:} false; then :
else
if test -n "$CC"; then
@@ -4606,7 +4674,7 @@
IFS=$as_save_IFS
ac_cv_prog_CC="${ac_tool_prefix}gcc"
break 2
@@ -4634,7 +4702,7 @@
set dummy gcc; ac_word=$2
-if test "${ac_cv_prog_ac_ct_CC+set}" = set; then :
+if ${ac_cv_prog_ac_ct_CC+:} false; then :
else
if test -n "$ac_ct_CC"; then
@@ -4646,7 +4714,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_CC="gcc"
break 2
@@ -4687,7 +4755,7 @@
set dummy ${ac_tool_prefix}cc; ac_word=$2
else
@@ -4699,7 +4767,7 @@
IFS=$as_save_IFS
ac_cv_prog_CC="${ac_tool_prefix}cc"
break 2
@@ -4727,7 +4795,7 @@
set dummy cc; ac_word=$2
else
@@ -4740,7 +4808,7 @@
IFS=$as_save_IFS
if test "$as_dir/$ac_word$ac_exec_ext" = "/usr/ucb/cc"; then
ac_prog_rejected=yes
continue
@@ -4786,7 +4854,7 @@
else
@@ -4798,7 +4866,7 @@
IFS=$as_save_IFS
ac_cv_prog_CC="$ac_tool_prefix$ac_prog"
break 2
@@ -4830,7 +4898,7 @@
else
@@ -4842,7 +4910,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_CC="$ac_prog"
break 2
@@ -4884,8 +4952,8 @@
test -z "$CC" && { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
-as_fn_error "no acceptable C compiler found in \$PATH
+as_fn_error $? "no acceptable C compiler found in \$PATH
# Provide some information about the compiler.
$as_echo "$as_me:${as_lineno-$LINENO}: checking for C compiler version" >&5
@@ -4906,15 +4974,15 @@
fi
done
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether we are using the GNU C compiler" >&5
$as_echo_n "checking whether we are using the GNU C compiler... " >&6; }
-if test "${ac_cv_c_compiler_gnu+set}" = set; then :
+if ${ac_cv_c_compiler_gnu+:} false; then :
else
@@ -4951,7 +5019,7 @@
ac_save_CFLAGS=$CFLAGS
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether $CC accepts -g" >&5
$as_echo_n "checking whether $CC accepts -g... " >&6; }
-if test "${ac_cv_prog_cc_g+set}" = set; then :
+if ${ac_cv_prog_cc_g+:} false; then :
else
ac_save_c_werror_flag=$ac_c_werror_flag
@@ -5029,7 +5097,7 @@
fi
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $CC option to accept ISO C89" >&5
$as_echo_n "checking for $CC option to accept ISO C89... " >&6; }
-if test "${ac_cv_prog_cc_c89+set}" = set; then :
+if ${ac_cv_prog_cc_c89+:} false; then :
else
ac_cv_prog_cc_c89=no
@@ -5038,8 +5106,7 @@
#include <stdarg.h>
#include <stdio.h>
-#include <sys/types.h>
-#include <sys/stat.h>
+struct stat;
/* Most of the following tests are stolen from RCS 5.7's src/conf.sh. */
struct buf { int x; };
FILE * (*rcsopen) (struct buf *, struct stat *, int);
@@ -5128,7 +5195,7 @@
-if test "${am_cv_CC_dependencies_compiler_type+set}" = set; then :
+if ${am_cv_CC_dependencies_compiler_type+:} false; then :
else
@@ -5278,7 +5345,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for a sed that does not truncate output" >&5
$as_echo_n "checking for a sed that does not truncate output... " >&6; }
-if test "${ac_cv_path_SED+set}" = set; then :
+if ${ac_cv_path_SED+:} false; then :
else
ac_script=s/aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa/bbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbb/
@@ -5298,7 +5365,7 @@
for ac_prog in sed gsed; do
ac_path_SED="$as_dir/$ac_prog$ac_exec_ext"
- { test -f "$ac_path_SED" && $as_test_x "$ac_path_SED"; } || continue
+ as_fn_executable_p "$ac_path_SED" || continue
# Check for GNU ac_path_SED and select it if it is found.
# Check for GNU $ac_path_SED
case `"$ac_path_SED" --version 2>&1` in
@@ -5333,7 +5400,7 @@
done
IFS=$as_save_IFS
if test -z "$ac_cv_path_SED"; then
- as_fn_error "no acceptable sed could be found in \$PATH" "$LINENO" 5
+ as_fn_error $? "no acceptable sed could be found in \$PATH" "$LINENO" 5
fi
else
ac_cv_path_SED=$SED
@@ -5360,7 +5427,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for grep that handles long lines and -e" >&5
$as_echo_n "checking for grep that handles long lines and -e... " >&6; }
-if test "${ac_cv_path_GREP+set}" = set; then :
+if ${ac_cv_path_GREP+:} false; then :
else
if test -z "$GREP"; then
@@ -5374,7 +5441,7 @@
for ac_prog in grep ggrep; do
ac_path_GREP="$as_dir/$ac_prog$ac_exec_ext"
- { test -f "$ac_path_GREP" && $as_test_x "$ac_path_GREP"; } || continue
+ as_fn_executable_p "$ac_path_GREP" || continue
# Check for GNU ac_path_GREP and select it if it is found.
# Check for GNU $ac_path_GREP
case `"$ac_path_GREP" --version 2>&1` in
@@ -5409,7 +5476,7 @@
done
IFS=$as_save_IFS
if test -z "$ac_cv_path_GREP"; then
- as_fn_error "no acceptable grep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" "$LINENO" 5
+ as_fn_error $? "no acceptable grep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" "$LINENO" 5
fi
else
ac_cv_path_GREP=$GREP
@@ -5423,7 +5490,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for egrep" >&5
$as_echo_n "checking for egrep... " >&6; }
-if test "${ac_cv_path_EGREP+set}" = set; then :
+if ${ac_cv_path_EGREP+:} false; then :
else
if echo a | $GREP -E '(a|b)' >/dev/null 2>&1
@@ -5440,7 +5507,7 @@
for ac_prog in egrep; do
ac_path_EGREP="$as_dir/$ac_prog$ac_exec_ext"
- { test -f "$ac_path_EGREP" && $as_test_x "$ac_path_EGREP"; } || continue
+ as_fn_executable_p "$ac_path_EGREP" || continue
# Check for GNU ac_path_EGREP and select it if it is found.
# Check for GNU $ac_path_EGREP
case `"$ac_path_EGREP" --version 2>&1` in
@@ -5475,7 +5542,7 @@
done
IFS=$as_save_IFS
if test -z "$ac_cv_path_EGREP"; then
- as_fn_error "no acceptable egrep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" "$LINENO" 5
+ as_fn_error $? "no acceptable egrep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" "$LINENO" 5
fi
else
ac_cv_path_EGREP=$EGREP
@@ -5490,7 +5557,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for fgrep" >&5
$as_echo_n "checking for fgrep... " >&6; }
-if test "${ac_cv_path_FGREP+set}" = set; then :
+if ${ac_cv_path_FGREP+:} false; then :
else
if echo 'ab*c' | $GREP -F 'ab*c' >/dev/null 2>&1
@@ -5507,7 +5574,7 @@
for ac_prog in fgrep; do
ac_path_FGREP="$as_dir/$ac_prog$ac_exec_ext"
- { test -f "$ac_path_FGREP" && $as_test_x "$ac_path_FGREP"; } || continue
+ as_fn_executable_p "$ac_path_FGREP" || continue
# Check for GNU ac_path_FGREP and select it if it is found.
# Check for GNU $ac_path_FGREP
case `"$ac_path_FGREP" --version 2>&1` in
@@ -5542,7 +5609,7 @@
done
IFS=$as_save_IFS
if test -z "$ac_cv_path_FGREP"; then
- as_fn_error "no acceptable fgrep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" "$LINENO" 5
+ as_fn_error $? "no acceptable fgrep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" "$LINENO" 5
fi
else
ac_cv_path_FGREP=$FGREP
@@ -5621,7 +5688,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for non-GNU ld" >&5
$as_echo_n "checking for non-GNU ld... " >&6; }
fi
-if test "${lt_cv_path_LD+set}" = set; then :
+if ${lt_cv_path_LD+:} false; then :
else
if test -z "$LD"; then
@@ -5658,10 +5725,10 @@
fi
-test -z "$LD" && as_fn_error "no acceptable ld found in \$PATH" "$LINENO" 5
+test -z "$LD" && as_fn_error $? "no acceptable ld found in \$PATH" "$LINENO" 5
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if the linker ($LD) is GNU ld" >&5
$as_echo_n "checking if the linker ($LD) is GNU ld... " >&6; }
-if test "${lt_cv_prog_gnu_ld+set}" = set; then :
+if ${lt_cv_prog_gnu_ld+:} false; then :
else
# I'd rather use --version here, but apparently some GNU lds only accept -v.
@@ -5688,7 +5755,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for BSD- or MS-compatible name lister (nm)" >&5
$as_echo_n "checking for BSD- or MS-compatible name lister (nm)... " >&6; }
-if test "${lt_cv_path_NM+set}" = set; then :
+if ${lt_cv_path_NM+:} false; then :
else
if test -n "$NM"; then
@@ -5748,7 +5815,7 @@
-if test "${ac_cv_prog_DUMPBIN+set}" = set; then :
+if ${ac_cv_prog_DUMPBIN+:} false; then :
else
if test -n "$DUMPBIN"; then
@@ -5760,7 +5827,7 @@
IFS=$as_save_IFS
ac_cv_prog_DUMPBIN="$ac_tool_prefix$ac_prog"
break 2
@@ -5792,7 +5859,7 @@
-if test "${ac_cv_prog_ac_ct_DUMPBIN+set}" = set; then :
+if ${ac_cv_prog_ac_ct_DUMPBIN+:} false; then :
else
if test -n "$ac_ct_DUMPBIN"; then
@@ -5804,7 +5871,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_DUMPBIN="$ac_prog"
break 2
@@ -5855,18 +5922,18 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking the name lister ($NM) interface" >&5
$as_echo_n "checking the name lister ($NM) interface... " >&6; }
-if test "${lt_cv_nm_interface+set}" = set; then :
+if ${lt_cv_nm_interface+:} false; then :
else
lt_cv_nm_interface="BSD nm"
echo "int some_variable = 0;" > conftest.$ac_ext
- (eval echo "\"\$as_me:5863: $ac_compile\"" >&5)
+ (eval echo "\"\$as_me:5930: $ac_compile\"" >&5)
(eval "$ac_compile" 2>conftest.err)
cat conftest.err >&5
- (eval echo "\"\$as_me:5866: $NM \\\"conftest.$ac_objext\\\"\"" >&5)
+ (eval echo "\"\$as_me:5933: $NM \\\"conftest.$ac_objext\\\"\"" >&5)
(eval "$NM \"conftest.$ac_objext\"" 2>conftest.err > conftest.out)
- (eval echo "\"\$as_me:5869: output\"" >&5)
+ (eval echo "\"\$as_me:5936: output\"" >&5)
cat conftest.out >&5
if $GREP 'External.*some_variable' conftest.out > /dev/null; then
lt_cv_nm_interface="MS dumpbin"
@@ -5890,7 +5957,7 @@
# find the maximum length of command line arguments
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking the maximum length of command line arguments" >&5
$as_echo_n "checking the maximum length of command line arguments... " >&6; }
-if test "${lt_cv_sys_max_cmd_len+set}" = set; then :
+if ${lt_cv_sys_max_cmd_len+:} false; then :
else
i=0
@@ -6082,7 +6149,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $LD option to reload object files" >&5
$as_echo_n "checking for $LD option to reload object files... " >&6; }
-if test "${lt_cv_ld_reload_flag+set}" = set; then :
+if ${lt_cv_ld_reload_flag+:} false; then :
else
lt_cv_ld_reload_flag='-r'
@@ -6118,7 +6185,7 @@
set dummy ${ac_tool_prefix}objdump; ac_word=$2
-if test "${ac_cv_prog_OBJDUMP+set}" = set; then :
+if ${ac_cv_prog_OBJDUMP+:} false; then :
else
if test -n "$OBJDUMP"; then
@@ -6130,7 +6197,7 @@
IFS=$as_save_IFS
ac_cv_prog_OBJDUMP="${ac_tool_prefix}objdump"
break 2
@@ -6158,7 +6225,7 @@
set dummy objdump; ac_word=$2
-if test "${ac_cv_prog_ac_ct_OBJDUMP+set}" = set; then :
+if ${ac_cv_prog_ac_ct_OBJDUMP+:} false; then :
else
if test -n "$ac_ct_OBJDUMP"; then
@@ -6170,7 +6237,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_OBJDUMP="objdump"
break 2
@@ -6217,7 +6284,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking how to recognize dependent libraries" >&5
$as_echo_n "checking how to recognize dependent libraries... " >&6; }
-if test "${lt_cv_deplibs_check_method+set}" = set; then :
+if ${lt_cv_deplibs_check_method+:} false; then :
else
lt_cv_file_magic_cmd='$MAGIC_CMD'
@@ -6433,7 +6500,7 @@
set dummy ${ac_tool_prefix}ar; ac_word=$2
-if test "${ac_cv_prog_AR+set}" = set; then :
+if ${ac_cv_prog_AR+:} false; then :
else
if test -n "$AR"; then
@@ -6445,7 +6512,7 @@
IFS=$as_save_IFS
ac_cv_prog_AR="${ac_tool_prefix}ar"
break 2
@@ -6473,7 +6540,7 @@
set dummy ar; ac_word=$2
-if test "${ac_cv_prog_ac_ct_AR+set}" = set; then :
+if ${ac_cv_prog_ac_ct_AR+:} false; then :
else
if test -n "$ac_ct_AR"; then
@@ -6485,7 +6552,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_AR="ar"
break 2
@@ -6538,7 +6605,7 @@
else
@@ -6550,7 +6617,7 @@
IFS=$as_save_IFS
break 2
@@ -6578,7 +6645,7 @@
else
@@ -6590,7 +6657,7 @@
IFS=$as_save_IFS
break 2
@@ -6637,7 +6704,7 @@
set dummy ${ac_tool_prefix}ranlib; ac_word=$2
-if test "${ac_cv_prog_RANLIB+set}" = set; then :
+if ${ac_cv_prog_RANLIB+:} false; then :
else
if test -n "$RANLIB"; then
@@ -6649,7 +6716,7 @@
IFS=$as_save_IFS
ac_cv_prog_RANLIB="${ac_tool_prefix}ranlib"
break 2
@@ -6677,7 +6744,7 @@
set dummy ranlib; ac_word=$2
-if test "${ac_cv_prog_ac_ct_RANLIB+set}" = set; then :
+if ${ac_cv_prog_ac_ct_RANLIB+:} false; then :
else
if test -n "$ac_ct_RANLIB"; then
@@ -6689,7 +6756,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_RANLIB="ranlib"
break 2
@@ -6794,7 +6861,7 @@
# Check for command to grab the raw symbol name followed by C symbol from nm.
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking command to parse $NM output from $compiler object" >&5
$as_echo_n "checking command to parse $NM output from $compiler object... " >&6; }
-if test "${lt_cv_sys_global_symbol_pipe+set}" = set; then :
+if ${lt_cv_sys_global_symbol_pipe+:} false; then :
else
@@ -7072,7 +7139,7 @@
*-*-irix6*)
# Find out which ABI we are using.
- echo '#line 7075 "configure"' > conftest.$ac_ext
+ echo '#line 7142 "configure"' > conftest.$ac_ext
if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$ac_compile\""; } >&5
(eval $ac_compile) 2>&5
ac_status=$?
@@ -7166,7 +7233,7 @@
CFLAGS="$CFLAGS -belf"
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the C compiler needs -belf" >&5
$as_echo_n "checking whether the C compiler needs -belf... " >&6; }
-if test "${lt_cv_cc_needs_belf+set}" = set; then :
+if ${lt_cv_cc_needs_belf+:} false; then :
else
ac_ext=c
@@ -7242,7 +7309,7 @@
set dummy ${ac_tool_prefix}dsymutil; ac_word=$2
-if test "${ac_cv_prog_DSYMUTIL+set}" = set; then :
+if ${ac_cv_prog_DSYMUTIL+:} false; then :
else
if test -n "$DSYMUTIL"; then
@@ -7254,7 +7321,7 @@
IFS=$as_save_IFS
ac_cv_prog_DSYMUTIL="${ac_tool_prefix}dsymutil"
break 2
@@ -7282,7 +7349,7 @@
set dummy dsymutil; ac_word=$2
-if test "${ac_cv_prog_ac_ct_DSYMUTIL+set}" = set; then :
+if ${ac_cv_prog_ac_ct_DSYMUTIL+:} false; then :
else
if test -n "$ac_ct_DSYMUTIL"; then
@@ -7294,7 +7361,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_DSYMUTIL="dsymutil"
break 2
@@ -7334,7 +7401,7 @@
set dummy ${ac_tool_prefix}nmedit; ac_word=$2
-if test "${ac_cv_prog_NMEDIT+set}" = set; then :
+if ${ac_cv_prog_NMEDIT+:} false; then :
else
if test -n "$NMEDIT"; then
@@ -7346,7 +7413,7 @@
IFS=$as_save_IFS
ac_cv_prog_NMEDIT="${ac_tool_prefix}nmedit"
break 2
@@ -7374,7 +7441,7 @@
set dummy nmedit; ac_word=$2
-if test "${ac_cv_prog_ac_ct_NMEDIT+set}" = set; then :
+if ${ac_cv_prog_ac_ct_NMEDIT+:} false; then :
else
if test -n "$ac_ct_NMEDIT"; then
@@ -7386,7 +7453,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_NMEDIT="nmedit"
break 2
@@ -7426,7 +7493,7 @@
set dummy ${ac_tool_prefix}lipo; ac_word=$2
-if test "${ac_cv_prog_LIPO+set}" = set; then :
+if ${ac_cv_prog_LIPO+:} false; then :
else
if test -n "$LIPO"; then
@@ -7438,7 +7505,7 @@
IFS=$as_save_IFS
ac_cv_prog_LIPO="${ac_tool_prefix}lipo"
break 2
@@ -7466,7 +7533,7 @@
set dummy lipo; ac_word=$2
-if test "${ac_cv_prog_ac_ct_LIPO+set}" = set; then :
+if ${ac_cv_prog_ac_ct_LIPO+:} false; then :
else
if test -n "$ac_ct_LIPO"; then
@@ -7478,7 +7545,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_LIPO="lipo"
break 2
@@ -7518,7 +7585,7 @@
set dummy ${ac_tool_prefix}otool; ac_word=$2
-if test "${ac_cv_prog_OTOOL+set}" = set; then :
+if ${ac_cv_prog_OTOOL+:} false; then :
else
if test -n "$OTOOL"; then
@@ -7530,7 +7597,7 @@
IFS=$as_save_IFS
ac_cv_prog_OTOOL="${ac_tool_prefix}otool"
break 2
@@ -7558,7 +7625,7 @@
set dummy otool; ac_word=$2
-if test "${ac_cv_prog_ac_ct_OTOOL+set}" = set; then :
+if ${ac_cv_prog_ac_ct_OTOOL+:} false; then :
else
if test -n "$ac_ct_OTOOL"; then
@@ -7570,7 +7637,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_OTOOL="otool"
break 2
@@ -7610,7 +7677,7 @@
set dummy ${ac_tool_prefix}otool64; ac_word=$2
-if test "${ac_cv_prog_OTOOL64+set}" = set; then :
+if ${ac_cv_prog_OTOOL64+:} false; then :
else
if test -n "$OTOOL64"; then
@@ -7622,7 +7689,7 @@
IFS=$as_save_IFS
ac_cv_prog_OTOOL64="${ac_tool_prefix}otool64"
break 2
@@ -7650,7 +7717,7 @@
set dummy otool64; ac_word=$2
-if test "${ac_cv_prog_ac_ct_OTOOL64+set}" = set; then :
+if ${ac_cv_prog_ac_ct_OTOOL64+:} false; then :
else
if test -n "$ac_ct_OTOOL64"; then
@@ -7662,7 +7729,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_OTOOL64="otool64"
break 2
@@ -7725,7 +7792,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for -single_module linker flag" >&5
$as_echo_n "checking for -single_module linker flag... " >&6; }
-if test "${lt_cv_apple_cc_single_mod+set}" = set; then :
+if ${lt_cv_apple_cc_single_mod+:} false; then :
else
lt_cv_apple_cc_single_mod=no
@@ -7754,7 +7821,7 @@
$as_echo "$lt_cv_apple_cc_single_mod" >&6; }
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for -exported_symbols_list linker flag" >&5
$as_echo_n "checking for -exported_symbols_list linker flag... " >&6; }
-if test "${lt_cv_ld_exported_symbols_list+set}" = set; then :
+if ${lt_cv_ld_exported_symbols_list+:} false; then :
else
lt_cv_ld_exported_symbols_list=no
@@ -7831,7 +7898,7 @@
CPP=
fi
if test -z "$CPP"; then
- if test "${ac_cv_prog_CPP+set}" = set; then :
+ if ${ac_cv_prog_CPP+:} false; then :
else
# Double quotes because CPP needs to be expanded
@@ -7861,7 +7928,7 @@
# Broken: fails on valid input.
continue
fi
# OK, works on sane cases. Now check whether nonexistent headers
# can be detected and how.
@@ -7877,11 +7944,11 @@
ac_preproc_ok=:
break
fi
done
# Because of `break', _AC_PREPROC_IFELSE's cleaning code was skipped.
+rm -f conftest.i conftest.err conftest.$ac_ext
if $ac_preproc_ok; then :
break
fi
@@ -7920,7 +7987,7 @@
continue
fi
@@ -7936,18 +8003,18 @@
ac_preproc_ok=:
break
fi
done
else
-as_fn_error "C preprocessor \"$CPP\" fails sanity check
+as_fn_error $? "C preprocessor \"$CPP\" fails sanity check
fi
ac_ext=c
@@ -7959,7 +8026,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for ANSI C header files" >&5
$as_echo_n "checking for ANSI C header files... " >&6; }
-if test "${ac_cv_header_stdc+set}" = set; then :
+if ${ac_cv_header_stdc+:} false; then :
else
@@ -8076,8 +8143,7 @@
as_ac_Header=`$as_echo "ac_cv_header_$ac_header" | $as_tr_sh`
ac_fn_c_check_header_compile "$LINENO" "$ac_header" "$as_ac_Header" "$ac_includes_default
-eval as_val=\$$as_ac_Header
- if test "x$as_val" = x""yes; then :
+if eval test \"x\$"$as_ac_Header"\" = x"yes"; then :
cat >>confdefs.h <<_ACEOF
#define `$as_echo "HAVE_$ac_header" | $as_tr_cpp` 1
_ACEOF
@@ -8091,7 +8157,7 @@
do :
ac_fn_c_check_header_compile "$LINENO" "dlfcn.h" "ac_cv_header_dlfcn_h" "$ac_includes_default
-if test "x$ac_cv_header_dlfcn_h" = x""yes; then :
+if test "x$ac_cv_header_dlfcn_h" = xyes; then :
#define HAVE_DLFCN_H 1
_ACEOF
@@ -8118,7 +8184,7 @@
else
@@ -8130,7 +8196,7 @@
IFS=$as_save_IFS
break 2
@@ -8162,7 +8228,7 @@
else
@@ -8174,7 +8240,7 @@
IFS=$as_save_IFS
break 2
@@ -8232,15 +8298,15 @@
fi
done
else
@@ -8277,7 +8343,7 @@
else
@@ -8363,7 +8429,7 @@
else
@@ -8497,7 +8563,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking how to run the C++ preprocessor" >&5
$as_echo_n "checking how to run the C++ preprocessor... " >&6; }
if test -z "$CXXCPP"; then
- if test "${ac_cv_prog_CXXCPP+set}" = set; then :
+ if ${ac_cv_prog_CXXCPP+:} false; then :
else
# Double quotes because CXXCPP needs to be expanded
@@ -8527,7 +8593,7 @@
continue
fi
@@ -8543,11 +8609,11 @@
ac_preproc_ok=:
break
fi
done
break
fi
@@ -8586,7 +8652,7 @@
continue
fi
@@ -8602,11 +8668,11 @@
ac_preproc_ok=:
break
fi
done
else
@@ -8801,7 +8867,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for objdir" >&5
$as_echo_n "checking for objdir... " >&6; }
-if test "${lt_cv_objdir+set}" = set; then :
+if ${lt_cv_objdir+:} false; then :
else
rm -f .libs 2>/dev/null
@@ -8909,7 +8975,7 @@
if test "$file_magic_cmd" = '$MAGIC_CMD'; then
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for ${ac_tool_prefix}file" >&5
$as_echo_n "checking for ${ac_tool_prefix}file... " >&6; }
-if test "${lt_cv_path_MAGIC_CMD+set}" = set; then :
+if ${lt_cv_path_MAGIC_CMD+:} false; then :
else
case $MAGIC_CMD in
@@ -8975,7 +9041,7 @@
if test -n "$ac_tool_prefix"; then
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for file" >&5
$as_echo_n "checking for file... " >&6; }
else
case $MAGIC_CMD in
@@ -9112,7 +9178,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if $compiler supports -fno-rtti -fno-exceptions" >&5
$as_echo_n "checking if $compiler supports -fno-rtti -fno-exceptions... " >&6; }
-if test "${lt_cv_prog_compiler_rtti_exceptions+set}" = set; then :
+if ${lt_cv_prog_compiler_rtti_exceptions+:} false; then :
else
lt_cv_prog_compiler_rtti_exceptions=no
@@ -9128,11 +9194,11 @@
-e 's:.*FLAGS}\{0,1\} :&$lt_compiler_flag :; t' \
-e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
-e 's:$: $lt_compiler_flag:'`
- (eval echo "\"\$as_me:9131: $lt_compile\"" >&5)
+ (eval echo "\"\$as_me:9197: $lt_compile\"" >&5)
(eval "$lt_compile" 2>conftest.err)
ac_status=$?
- echo "$as_me:9135: \$? = $ac_status" >&5
+ echo "$as_me:9201: \$? = $ac_status" >&5
if (exit $ac_status) && test -s "$ac_outfile"; then
# The compiler can only warn and ignore the option if not recognized
# So say no if there are warnings other than the usual output.
@@ -9451,7 +9517,7 @@
if test -n "$lt_prog_compiler_pic"; then
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if $compiler PIC flag $lt_prog_compiler_pic works" >&5
$as_echo_n "checking if $compiler PIC flag $lt_prog_compiler_pic works... " >&6; }
-if test "${lt_cv_prog_compiler_pic_works+set}" = set; then :
+if ${lt_cv_prog_compiler_pic_works+:} false; then :
else
lt_cv_prog_compiler_pic_works=no
@@ -9467,11 +9533,11 @@
- (eval echo "\"\$as_me:9470: $lt_compile\"" >&5)
+ (eval echo "\"\$as_me:9536: $lt_compile\"" >&5)
ac_status=$?
- echo "$as_me:9474: \$? = $ac_status" >&5
+ echo "$as_me:9540: \$? = $ac_status" >&5
@@ -9510,7 +9576,7 @@
wl=$lt_prog_compiler_wl eval lt_tmp_static_flag=\"$lt_prog_compiler_static\"
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if $compiler static flag $lt_tmp_static_flag works" >&5
$as_echo_n "checking if $compiler static flag $lt_tmp_static_flag works... " >&6; }
-if test "${lt_cv_prog_compiler_static_works+set}" = set; then :
+if ${lt_cv_prog_compiler_static_works+:} false; then :
else
lt_cv_prog_compiler_static_works=no
@@ -9553,7 +9619,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if $compiler supports -c -o file.$ac_objext" >&5
$as_echo_n "checking if $compiler supports -c -o file.$ac_objext... " >&6; }
-if test "${lt_cv_prog_compiler_c_o+set}" = set; then :
+if ${lt_cv_prog_compiler_c_o+:} false; then :
else
lt_cv_prog_compiler_c_o=no
@@ -9572,11 +9638,11 @@
- (eval echo "\"\$as_me:9575: $lt_compile\"" >&5)
+ (eval echo "\"\$as_me:9641: $lt_compile\"" >&5)
(eval "$lt_compile" 2>out/conftest.err)
ac_status=$?
cat out/conftest.err >&5
- echo "$as_me:9579: \$? = $ac_status" >&5
+ echo "$as_me:9645: \$? = $ac_status" >&5
if (exit $ac_status) && test -s out/conftest2.$ac_objext
then
@@ -9608,7 +9674,7 @@
else
@@ -9627,11 +9693,11 @@
- (eval echo "\"\$as_me:9630: $lt_compile\"" >&5)
+ (eval echo "\"\$as_me:9696: $lt_compile\"" >&5)
ac_status=$?
- echo "$as_me:9634: \$? = $ac_status" >&5
+ echo "$as_me:9700: \$? = $ac_status" >&5
then
@@ -11752,7 +11818,7 @@
# if libdl is installed we need to link against it
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for dlopen in -ldl" >&5
$as_echo_n "checking for dlopen in -ldl... " >&6; }
-if test "${ac_cv_lib_dl_dlopen+set}" = set; then :
+if ${ac_cv_lib_dl_dlopen+:} false; then :
else
ac_check_lib_save_LIBS=$LIBS
@@ -11786,7 +11852,7 @@
fi
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_dl_dlopen" >&5
$as_echo "$ac_cv_lib_dl_dlopen" >&6; }
-if test "x$ac_cv_lib_dl_dlopen" = x""yes; then :
+if test "x$ac_cv_lib_dl_dlopen" = xyes; then :
lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-ldl"
else
@@ -11800,12 +11866,12 @@
ac_fn_c_check_func "$LINENO" "shl_load" "ac_cv_func_shl_load"
-if test "x$ac_cv_func_shl_load" = x""yes; then :
+if test "x$ac_cv_func_shl_load" = xyes; then :
lt_cv_dlopen="shl_load"
else
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for shl_load in -ldld" >&5
$as_echo_n "checking for shl_load in -ldld... " >&6; }
-if test "${ac_cv_lib_dld_shl_load+set}" = set; then :
+if ${ac_cv_lib_dld_shl_load+:} false; then :
else
@@ -11839,16 +11905,16 @@
fi
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_dld_shl_load" >&5
$as_echo "$ac_cv_lib_dld_shl_load" >&6; }
-if test "x$ac_cv_lib_dld_shl_load" = x""yes; then :
+if test "x$ac_cv_lib_dld_shl_load" = xyes; then :
lt_cv_dlopen="shl_load" lt_cv_dlopen_libs="-ldld"
else
ac_fn_c_check_func "$LINENO" "dlopen" "ac_cv_func_dlopen"
-if test "x$ac_cv_func_dlopen" = x""yes; then :
+if test "x$ac_cv_func_dlopen" = xyes; then :
else
else
@@ -11882,12 +11948,12 @@
fi
else
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for dlopen in -lsvld" >&5
$as_echo_n "checking for dlopen in -lsvld... " >&6; }
-if test "${ac_cv_lib_svld_dlopen+set}" = set; then :
+if ${ac_cv_lib_svld_dlopen+:} false; then :
else
@@ -11921,12 +11987,12 @@
fi
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_svld_dlopen" >&5
$as_echo "$ac_cv_lib_svld_dlopen" >&6; }
-if test "x$ac_cv_lib_svld_dlopen" = x""yes; then :
+if test "x$ac_cv_lib_svld_dlopen" = xyes; then :
lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-lsvld"
else
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for dld_link in -ldld" >&5
$as_echo_n "checking for dld_link in -ldld... " >&6; }
-if test "${ac_cv_lib_dld_dld_link+set}" = set; then :
+if ${ac_cv_lib_dld_dld_link+:} false; then :
else
@@ -11960,7 +12026,7 @@
fi
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_dld_dld_link" >&5
$as_echo "$ac_cv_lib_dld_dld_link" >&6; }
-if test "x$ac_cv_lib_dld_dld_link" = x""yes; then :
+if test "x$ac_cv_lib_dld_dld_link" = xyes; then :
lt_cv_dlopen="dld_link" lt_cv_dlopen_libs="-ldld"
fi
@@ -12001,7 +12067,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether a program can dlopen itself" >&5
$as_echo_n "checking whether a program can dlopen itself... " >&6; }
-if test "${lt_cv_dlopen_self+set}" = set; then :
+if ${lt_cv_dlopen_self+:} false; then :
else
if test "$cross_compiling" = yes; then :
@@ -12010,7 +12076,7 @@
lt_dlunknown=0; lt_dlno_uscore=1; lt_dlneed_uscore=2
lt_status=$lt_dlunknown
cat > conftest.$ac_ext <<_LT_EOF
-#line 12013 "configure"
+#line 12079 "configure"
#include "confdefs.h"
#if HAVE_DLFCN_H
@@ -12097,7 +12163,7 @@
wl=$lt_prog_compiler_wl eval LDFLAGS=\"\$LDFLAGS $lt_prog_compiler_static\"
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether a statically linked program can dlopen itself" >&5
$as_echo_n "checking whether a statically linked program can dlopen itself... " >&6; }
-if test "${lt_cv_dlopen_self_static+set}" = set; then :
+if ${lt_cv_dlopen_self_static+:} false; then :
else
@@ -12106,7 +12172,7 @@
-#line 12109 "configure"
+#line 12175 "configure"
#if HAVE_DLFCN_H
@@ -12484,7 +12550,7 @@
fi
else
@@ -12521,10 +12587,10 @@
fi
else
@@ -14046,7 +14112,7 @@
if test -n "$lt_prog_compiler_pic_CXX"; then
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if $compiler PIC flag $lt_prog_compiler_pic_CXX works" >&5
$as_echo_n "checking if $compiler PIC flag $lt_prog_compiler_pic_CXX works... " >&6; }
-if test "${lt_cv_prog_compiler_pic_works_CXX+set}" = set; then :
+if ${lt_cv_prog_compiler_pic_works_CXX+:} false; then :
else
lt_cv_prog_compiler_pic_works_CXX=no
@@ -14062,11 +14128,11 @@
- (eval echo "\"\$as_me:14065: $lt_compile\"" >&5)
+ (eval echo "\"\$as_me:14131: $lt_compile\"" >&5)
ac_status=$?
- echo "$as_me:14069: \$? = $ac_status" >&5
+ echo "$as_me:14135: \$? = $ac_status" >&5
@@ -14102,7 +14168,7 @@
wl=$lt_prog_compiler_wl_CXX eval lt_tmp_static_flag=\"$lt_prog_compiler_static_CXX\"
-if test "${lt_cv_prog_compiler_static_works_CXX+set}" = set; then :
+if ${lt_cv_prog_compiler_static_works_CXX+:} false; then :
else
lt_cv_prog_compiler_static_works_CXX=no
@@ -14142,7 +14208,7 @@
-if test "${lt_cv_prog_compiler_c_o_CXX+set}" = set; then :
+if ${lt_cv_prog_compiler_c_o_CXX+:} false; then :
else
lt_cv_prog_compiler_c_o_CXX=no
@@ -14161,11 +14227,11 @@
- (eval echo "\"\$as_me:14164: $lt_compile\"" >&5)
+ (eval echo "\"\$as_me:14230: $lt_compile\"" >&5)
ac_status=$?
- echo "$as_me:14168: \$? = $ac_status" >&5
+ echo "$as_me:14234: \$? = $ac_status" >&5
then
@@ -14194,7 +14260,7 @@
else
@@ -14213,11 +14279,11 @@
- (eval echo "\"\$as_me:14216: $lt_compile\"" >&5)
+ (eval echo "\"\$as_me:14282: $lt_compile\"" >&5)
ac_status=$?
- echo "$as_me:14220: \$? = $ac_status" >&5
+ echo "$as_me:14286: \$? = $ac_status" >&5
then
@@ -15192,7 +15258,7 @@
CPP=
fi
else
@@ -15222,7 +15288,7 @@
continue
fi
@@ -15238,11 +15304,11 @@
ac_preproc_ok=:
break
fi
done
break
fi
@@ -15281,7 +15347,7 @@
continue
fi
@@ -15297,18 +15363,18 @@
ac_preproc_ok=:
break
fi
done
else
fi
ac_ext=c
@@ -15333,7 +15399,7 @@
set x ${MAKE-make}
else
@@ -15341,7 +15407,7 @@
all:
_ACEOF
@@ -15366,7 +15432,7 @@
-if test "${ac_cv_prog_YACC+set}" = set; then :
+if ${ac_cv_prog_YACC+:} false; then :
else
if test -n "$YACC"; then
@@ -15378,7 +15444,7 @@
IFS=$as_save_IFS
ac_cv_prog_YACC="$ac_prog"
break 2
@@ -15409,7 +15475,7 @@
-if test "${ac_cv_prog_LEX+set}" = set; then :
+if ${ac_cv_prog_LEX+:} false; then :
else
if test -n "$LEX"; then
@@ -15421,7 +15487,7 @@
IFS=$as_save_IFS
ac_cv_prog_LEX="$ac_prog"
break 2
@@ -15453,7 +15519,8 @@
b { REJECT; }
c { yymore (); }
d { yyless (1); }
-e { yyless (input () != 0); }
+e { /* IRIX 6.5 flex 2.5.4 underquotes its yyless argument. */
+ yyless ((input () != 0)); }
f { unput (yytext[0]); }
. { BEGIN INITIAL; }
@@ -15479,7 +15546,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking lex output file root" >&5
$as_echo_n "checking lex output file root... " >&6; }
-if test "${ac_cv_prog_lex_root+set}" = set; then :
+if ${ac_cv_prog_lex_root+:} false; then :
else
@@ -15488,7 +15555,7 @@
elif test -f lexyy.c; then
ac_cv_prog_lex_root=lexyy
else
- as_fn_error "cannot find output from $LEX; giving up" "$LINENO" 5
+ as_fn_error $? "cannot find output from $LEX; giving up" "$LINENO" 5
fi
fi
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_prog_lex_root" >&5
@@ -15498,7 +15565,7 @@
if test -z "${LEXLIB+set}"; then
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking lex library" >&5
$as_echo_n "checking lex library... " >&6; }
-if test "${ac_cv_lib_lex+set}" = set; then :
+if ${ac_cv_lib_lex+:} false; then :
else
@@ -15528,7 +15595,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether yytext is a pointer" >&5
$as_echo_n "checking whether yytext is a pointer... " >&6; }
-if test "${ac_cv_prog_lex_yytext_pointer+set}" = set; then :
+if ${ac_cv_prog_lex_yytext_pointer+:} false; then :
else
# POSIX says lex can declare yytext either as a pointer or an array; the
@@ -15539,7 +15606,8 @@
LIBS="$LEXLIB $ac_save_LIBS"
-#define YYTEXT_POINTER 1
+ #define YYTEXT_POINTER 1
`cat $LEX_OUTPUT_ROOT.c`
_ACEOF
if ac_fn_c_try_link "$LINENO"; then :
@@ -15602,7 +15670,7 @@
# Checks for libraries.
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for pthread_create in -lpthread" >&5
$as_echo_n "checking for pthread_create in -lpthread... " >&6; }
-if test "${ac_cv_lib_pthread_pthread_create+set}" = set; then :
+if ${ac_cv_lib_pthread_pthread_create+:} false; then :
else
@@ -15636,7 +15704,7 @@
fi
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_pthread_pthread_create" >&5
$as_echo "$ac_cv_lib_pthread_pthread_create" >&6; }
-if test "x$ac_cv_lib_pthread_pthread_create" = x""yes; then :
+if test "x$ac_cv_lib_pthread_pthread_create" = xyes; then :
#define HAVE_LIBPTHREAD 1
_ACEOF
@@ -15647,7 +15715,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for connect in -lsocket" >&5
$as_echo_n "checking for connect in -lsocket... " >&6; }
-if test "${ac_cv_lib_socket_connect+set}" = set; then :
+if ${ac_cv_lib_socket_connect+:} false; then :
else
@@ -15681,7 +15749,7 @@
fi
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_socket_connect" >&5
$as_echo "$ac_cv_lib_socket_connect" >&6; }
-if test "x$ac_cv_lib_socket_connect" = x""yes; then :
+if test "x$ac_cv_lib_socket_connect" = xyes; then :
#define HAVE_LIBSOCKET 1
_ACEOF
@@ -15692,7 +15760,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for gethostbyname in -lnsl" >&5
$as_echo_n "checking for gethostbyname in -lnsl... " >&6; }
-if test "${ac_cv_lib_nsl_gethostbyname+set}" = set; then :
+if ${ac_cv_lib_nsl_gethostbyname+:} false; then :
else
@@ -15726,7 +15794,7 @@
fi
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_nsl_gethostbyname" >&5
$as_echo "$ac_cv_lib_nsl_gethostbyname" >&6; }
-if test "x$ac_cv_lib_nsl_gethostbyname" = x""yes; then :
+if test "x$ac_cv_lib_nsl_gethostbyname" = xyes; then :
#define HAVE_LIBNSL 1
_ACEOF
@@ -15737,11 +15805,22 @@
# Checks for header files.
+ac_fn_c_check_type "$LINENO" "size_t" "ac_cv_type_size_t" "$ac_includes_default"
+if test "x$ac_cv_type_size_t" = xyes; then :
+else
+cat >>confdefs.h <<_ACEOF
+#define size_t unsigned int
+_ACEOF
+fi
# The Ultrix 4.2 mips builtin alloca declared by alloca.h only works
# for constant arguments. Useless!
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for working alloca.h" >&5
$as_echo_n "checking for working alloca.h... " >&6; }
-if test "${ac_cv_working_alloca_h+set}" = set; then :
+if ${ac_cv_working_alloca_h+:} false; then :
else
@@ -15774,7 +15853,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for alloca" >&5
$as_echo_n "checking for alloca... " >&6; }
-if test "${ac_cv_func_alloca_works+set}" = set; then :
+if ${ac_cv_func_alloca_works+:} false; then :
else
@@ -15793,7 +15872,7 @@
#pragma alloca
# else
# ifndef alloca /* predefined by HP cc +Olibcalls */
-char *alloca ();
+void *alloca (size_t);
# endif
# endif
# endif
@@ -15837,7 +15916,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether \`alloca.c' needs Cray hooks" >&5
$as_echo_n "checking whether \`alloca.c' needs Cray hooks... " >&6; }
-if test "${ac_cv_os_cray+set}" = set; then :
+if ${ac_cv_os_cray+:} false; then :
else
@@ -15864,8 +15943,7 @@
for ac_func in _getb67 GETB67 getb67; do
as_ac_var=`$as_echo "ac_cv_func_$ac_func" | $as_tr_sh`
ac_fn_c_check_func "$LINENO" "$ac_func" "$as_ac_var"
-eval as_val=\$$as_ac_var
+if eval test \"x\$"$as_ac_var"\" = x"yes"; then :
#define CRAY_STACKSEG_END $ac_func
@@ -15879,7 +15957,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking stack direction for C alloca" >&5
$as_echo_n "checking stack direction for C alloca... " >&6; }
-if test "${ac_cv_c_stack_direction+set}" = set; then :
+if ${ac_cv_c_stack_direction+:} false; then :
else
@@ -15889,23 +15967,20 @@
int
-find_stack_direction ()
+find_stack_direction (int *addr, int depth)
- static char *addr = 0;
- auto char dummy;
- if (addr == 0)
- addr = &dummy;
- return find_stack_direction ();
- else
- return (&dummy > addr) ? 1 : -1;
+ int dir, dummy = 0;
+ if (! addr)
+ addr = &dummy;
+ *addr = addr < &dummy ? 1 : addr == &dummy ? 0 : -1;
+ dir = depth ? find_stack_direction (addr, depth - 1) : 0;
+ return dir + dummy;
int
-main ()
+main (int argc, char **argv)
- return find_stack_direction () < 0;
+ return find_stack_direction (0, argc + !argv + 20) < 0;
_ACEOF
if ac_fn_c_try_run "$LINENO"; then :
@@ -15929,7 +16004,7 @@
else
@@ -16043,8 +16118,7 @@
do :
ac_fn_c_check_header_mongrel "$LINENO" "$ac_header" "$as_ac_Header" "$ac_includes_default"
_ACEOF
@@ -16057,84 +16131,66 @@
# Checks for typedefs, structures, and compiler characteristics.
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for stdbool.h that conforms to C99" >&5
$as_echo_n "checking for stdbool.h that conforms to C99... " >&6; }
-if test "${ac_cv_header_stdbool_h+set}" = set; then :
+if ${ac_cv_header_stdbool_h+:} false; then :
else
-#include <stdbool.h>
-#ifndef bool
- "error: bool is not defined"
-#endif
-#ifndef false
- "error: false is not defined"
-#endif
-#if false
- "error: false is not 0"
-#endif
-#ifndef true
- "error: true is not defined"
-#endif
-#if true != 1
- "error: true is not 1"
-#endif
-#ifndef __bool_true_false_are_defined
- "error: __bool_true_false_are_defined is not defined"
-#endif
+ #include <stdbool.h>
+ #ifndef bool
+ "error: bool is not defined"
+ #endif
+ #ifndef false
+ "error: false is not defined"
+ #endif
+ #if false
+ "error: false is not 0"
+ #endif
+ #ifndef true
+ "error: true is not defined"
+ #endif
+ #if true != 1
+ "error: true is not 1"
+ #endif
+ #ifndef __bool_true_false_are_defined
+ "error: __bool_true_false_are_defined is not defined"
+ #endif
- struct s { _Bool s: 1; _Bool t; } s;
+ struct s { _Bool s: 1; _Bool t; } s;
- char a[true == 1 ? 1 : -1];
- char b[false == 0 ? 1 : -1];
- char c[__bool_true_false_are_defined == 1 ? 1 : -1];
- char d[(bool) 0.5 == true ? 1 : -1];
- bool e = &s;
- char f[(_Bool) 0.0 == false ? 1 : -1];
- char g[true];
- char h[sizeof (_Bool)];
- char i[sizeof s.t];
- enum { j = false, k = true, l = false * true, m = true * 256 };
- /* The following fails for
- HP aC++/ANSI C B3910B A.05.55 [Dec 04 2003]. */
- _Bool n[m];
- char o[sizeof n == m * sizeof n[0] ? 1 : -1];
- char p[-1 - (_Bool) 0 < 0 && -1 - (bool) 0 < 0 ? 1 : -1];
-# if defined __xlc__ || defined __GNUC__
- /* Catch a bug in IBM AIX xlc compiler version 6.0.0.0
- reported by James Lemley on 2005-10-05; see
- http://lists.gnu.org/archive/html/bug-coreutils/2005-10/msg00086.html
- This test is not quite right, since xlc is allowed to
- reject this program, as the initializer for xlcbug is
- not one of the forms that C requires support for.
- However, doing the test right would require a runtime
- test, and that would make cross-compilation harder.
- Let us hope that IBM fixes the xlc bug, and also adds
- support for this kind of constant expression. In the
- meantime, this test will reject xlc, which is OK, since
- our stdbool.h substitute should suffice. We also test
- this with GCC, where it should work, to detect more
- quickly whether someone messes up the test in the
- future. */
- char digs[] = "0123456789";
- int xlcbug = 1 / (&(digs + 5)[-2 + (bool) 1] == &digs[4] ? 1 : -1);
-# endif
- /* Catch a bug in an HP-UX C compiler. See
- http://gcc.gnu.org/ml/gcc-patches/2003-12/msg02303.html
- http://lists.gnu.org/archive/html/bug-coreutils/2005-11/msg00161.html
- _Bool q = true;
- _Bool *pq = &q;
+ char a[true == 1 ? 1 : -1];
+ char b[false == 0 ? 1 : -1];
+ char c[__bool_true_false_are_defined == 1 ? 1 : -1];
+ char d[(bool) 0.5 == true ? 1 : -1];
+ /* See body of main program for 'e'. */
+ char f[(_Bool) 0.0 == false ? 1 : -1];
+ char g[true];
+ char h[sizeof (_Bool)];
+ char i[sizeof s.t];
+ enum { j = false, k = true, l = false * true, m = true * 256 };
+ /* The following fails for
+ HP aC++/ANSI C B3910B A.05.55 [Dec 04 2003]. */
+ _Bool n[m];
+ char o[sizeof n == m * sizeof n[0] ? 1 : -1];
+ char p[-1 - (_Bool) 0 < 0 && -1 - (bool) 0 < 0 ? 1 : -1];
+ /* Catch a bug in an HP-UX C compiler. See
+ http://gcc.gnu.org/ml/gcc-patches/2003-12/msg02303.html
+ http://lists.gnu.org/archive/html/bug-coreutils/2005-11/msg00161.html
+ _Bool q = true;
+ _Bool *pq = &q;
int
main ()
- *pq |= q;
- *pq |= ! q;
- /* Refer to every declared value, to avoid compiler optimizations. */
- return (!a + !b + !c + !d + !e + !f + !g + !h + !i + !!j + !k + !!l
- + !m + !n + !o + !p + !q + !pq);
+ bool e = &s;
+ *pq |= q;
+ *pq |= ! q;
+ /* Refer to every declared value, to avoid compiler optimizations. */
+ return (!a + !b + !c + !d + !e + !f + !g + !h + !i + !!j + !k + !!l
+ + !m + !n + !o + !p + !q + !pq);
return 0;
@@ -16149,8 +16205,8 @@
fi
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_header_stdbool_h" >&5
$as_echo "$ac_cv_header_stdbool_h" >&6; }
-ac_fn_c_check_type "$LINENO" "_Bool" "ac_cv_type__Bool" "$ac_includes_default"
-if test "x$ac_cv_type__Bool" = x""yes; then :
+ ac_fn_c_check_type "$LINENO" "_Bool" "ac_cv_type__Bool" "$ac_includes_default"
+if test "x$ac_cv_type__Bool" = xyes; then :
#define HAVE__BOOL 1
@@ -16159,6 +16215,7 @@
fi
if test $ac_cv_header_stdbool_h = yes; then
$as_echo "#define HAVE_STDBOOL_H 1" >>confdefs.h
@@ -16167,7 +16224,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for an ANSI C-conforming const" >&5
$as_echo_n "checking for an ANSI C-conforming const... " >&6; }
-if test "${ac_cv_c_const+set}" = set; then :
+if ${ac_cv_c_const+:} false; then :
$as_echo_n "(cached) " >&6
else
@@ -16176,11 +16233,11 @@
int
main ()
-/* FIXME: Include the comments suggested by Paul. */
#ifndef __cplusplus
- /* Ultrix mips cc rejects this. */
+ /* Ultrix mips cc rejects this sort of thing. */
typedef int charset[2];
- const charset cs;
+ const charset cs = { 0, 0 };
/* SunOS 4.1.1 cc rejects this. */
char const *const *pcpcc;
char **ppc;
@@ -16197,8 +16254,9 @@
++pcpcc;
ppc = (char**) pcpcc;
pcpcc = (char const *const *) ppc;
- { /* SCO 3.2v4 cc rejects this. */
- char *t;
+ { /* SCO 3.2v4 cc rejects this sort of thing. */
+ char tx;
+ char *t = &tx;
char const *s = 0 ? (char *) 0 : (char const *) 0;
*t++ = 0;
@@ -16214,10 +16272,10 @@
iptr p = 0;
++p;
- { /* AIX XL C 1.02.0.0 rejects this saying
+ { /* AIX XL C 1.02.0.0 rejects this sort of thing, saying
"k.c", line 2.27: 1506-025 (S) Operand must be a modifiable lvalue. */
- struct s { int j; const int *ap[3]; };
- struct s *b; b->j = 5;
+ struct s { int j; const int *ap[3]; } bx;
+ struct s *b = &bx; b->j = 5;
{ /* ULTRIX-32 V3.1 (Rev 9) vcc rejects this */
const int foo = 10;
@@ -16247,7 +16305,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for inline" >&5
$as_echo_n "checking for inline... " >&6; }
-if test "${ac_cv_c_inline+set}" = set; then :
+if ${ac_cv_c_inline+:} false; then :
else
ac_cv_c_inline=no
@@ -16288,7 +16346,7 @@
esac
-if test "x$ac_cv_type_size_t" = x""yes; then :
else
@@ -16300,7 +16358,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether time.h and sys/time.h may both be included" >&5
$as_echo_n "checking whether time.h and sys/time.h may both be included... " >&6; }
-if test "${ac_cv_header_time+set}" = set; then :
+if ${ac_cv_header_time+:} false; then :
else
@@ -16335,7 +16393,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether struct tm is in sys/time.h or time.h" >&5
$as_echo_n "checking whether struct tm is in sys/time.h or time.h... " >&6; }
-if test "${ac_cv_struct_tm+set}" = set; then :
+if ${ac_cv_struct_tm+:} false; then :
else
@@ -16369,7 +16427,7 @@
fi
ac_fn_c_check_type "$LINENO" "ptrdiff_t" "ac_cv_type_ptrdiff_t" "$ac_includes_default"
-if test "x$ac_cv_type_ptrdiff_t" = x""yes; then :
+if test "x$ac_cv_type_ptrdiff_t" = xyes; then :
#define HAVE_PTRDIFF_T 1
@@ -16382,7 +16440,7 @@
# Checks for library functions.
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for error_at_line" >&5
$as_echo_n "checking for error_at_line... " >&6; }
-if test "${ac_cv_lib_error_at_line+set}" = set; then :
+if ${ac_cv_lib_error_at_line+:} false; then :
else
@@ -16423,8 +16481,7 @@
_ACEOF
@@ -16444,8 +16501,7 @@
do :
#define `$as_echo "HAVE_$ac_func" | $as_tr_cpp` 1
_ACEOF
@@ -16459,7 +16515,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for working mktime" >&5
$as_echo_n "checking for working mktime... " >&6; }
-if test "${ac_cv_func_working_mktime+set}" = set; then :
+if ${ac_cv_func_working_mktime+:} false; then :
else
@@ -16497,8 +16553,8 @@
static time_t time_t_min;
/* Values we'll use to set the TZ environment variable. */
-static char *tz_strings[] = {
- (char *) 0, "TZ=GMT0", "TZ=JST-9",
+static const char *tz_strings[] = {
+ (const char *) 0, "TZ=GMT0", "TZ=JST-9",
"TZ=EST+3EDT+2,M10.1.0/00:00:00,M2.3.0/00:00:00"
#define N_STRINGS (sizeof (tz_strings) / sizeof (tz_strings[0]))
@@ -16515,7 +16571,7 @@
instead of "TZ=America/Vancouver" in order to detect the bug even
on systems that don't support the Olson extension, or don't have the
full zoneinfo tables installed. */
- putenv ("TZ=PST8PDT,M4.1.0,M10.5.0");
+ putenv ((char*) "TZ=PST8PDT,M4.1.0,M10.5.0");
tm.tm_year = 98;
tm.tm_mon = 3;
@@ -16528,16 +16584,14 @@
static int
-mktime_test1 (now)
- time_t now;
+mktime_test1 (time_t now)
struct tm *lt;
return ! (lt = localtime (&now)) || mktime (lt) == now;
static int
-mktime_test (now)
- time_t now;
+mktime_test (time_t now)
return (mktime_test1 (now)
&& mktime_test1 ((time_t) (time_t_max - now))
@@ -16561,8 +16615,7 @@
static int
-bigtime_test (j)
- int j;
+bigtime_test (int j)
struct tm tm;
time_t now;
@@ -16606,7 +16659,7 @@
t = mktime (&tm);
@@ -16641,7 +16694,7 @@
for (i = 0; i < N_STRINGS; i++)
if (tz_strings[i])
- putenv (tz_strings[i]);
+ putenv ((char*) tz_strings[i]);
for (t = 0; t <= time_t_max - delta; t += delta)
if (! mktime_test (t))
@@ -16687,8 +16740,7 @@
do :
_ACEOF
@@ -16763,10 +16815,21 @@
:end' >>confcache
if diff "$cache_file" confcache >/dev/null 2>&1; then :; else
if test -w "$cache_file"; then
- test "x$cache_file" != "x/dev/null" &&
+ if test "x$cache_file" != "x/dev/null"; then
{ $as_echo "$as_me:${as_lineno-$LINENO}: updating cache $cache_file" >&5
$as_echo "$as_me: updating cache $cache_file" >&6;}
- cat confcache >$cache_file
+ if test ! -f "$cache_file" || test -h "$cache_file"; then
+ cat confcache >"$cache_file"
+ else
+ case $cache_file in #(
+ mv -f confcache "$cache_file"$$ &&
+ mv -f "$cache_file"$$ "$cache_file" ;; #(
+ mv -f confcache "$cache_file" ;;
+ esac
+ fi
+ fi
else
{ $as_echo "$as_me:${as_lineno-$LINENO}: not updating unwritable cache $cache_file" >&5
$as_echo "$as_me: not updating unwritable cache $cache_file" >&6;}
@@ -16782,6 +16845,7 @@
ac_libobjs=
ac_ltlibobjs=
+U=
for ac_i in : $LIBOBJS; do test "x$ac_i" = x: && continue
# 1. Remove the extension, and $U if already installed.
ac_script='s/\$U\././;s/\.o$//;s/\.obj$//'
@@ -16805,35 +16869,35 @@
fi
if test -z "${MAINTAINER_MODE_TRUE}" && test -z "${MAINTAINER_MODE_FALSE}"; then
- as_fn_error "conditional \"MAINTAINER_MODE\" was never defined.
+ as_fn_error $? "conditional \"MAINTAINER_MODE\" was never defined.
Usually this means the macro was only invoked conditionally." "$LINENO" 5
fi
if test -z "${BUILD_DOM_SAMPLES_TRUE}" && test -z "${BUILD_DOM_SAMPLES_FALSE}"; then
- as_fn_error "conditional \"BUILD_DOM_SAMPLES\" was never defined.
+ as_fn_error $? "conditional \"BUILD_DOM_SAMPLES\" was never defined.
fi
if test -z "${AMDEP_TRUE}" && test -z "${AMDEP_FALSE}"; then
- as_fn_error "conditional \"AMDEP\" was never defined.
+ as_fn_error $? "conditional \"AMDEP\" was never defined.
fi
if test -z "${am__fastdepCXX_TRUE}" && test -z "${am__fastdepCXX_FALSE}"; then
- as_fn_error "conditional \"am__fastdepCXX\" was never defined.
+ as_fn_error $? "conditional \"am__fastdepCXX\" was never defined.
fi
fi
if test -z "${am__fastdepCC_TRUE}" && test -z "${am__fastdepCC_FALSE}"; then
- as_fn_error "conditional \"am__fastdepCC\" was never defined.
+ as_fn_error $? "conditional \"am__fastdepCC\" was never defined.
fi
fi
-: ${CONFIG_STATUS=./config.status}
+: "${CONFIG_STATUS=./config.status}"
ac_write_fail=0
ac_clean_files="$ac_clean_files $CONFIG_STATUS"
@@ -16934,6 +16998,7 @@
IFS=" "" $as_nl"
# Find who we are. Look in the path if we contain no directory separator.
+as_myself=
case $0 in #((
*[\\/]* ) as_myself=$0 ;;
*) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
@@ -16979,19 +17044,19 @@
(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
-# as_fn_error ERROR [LINENO LOG_FD]
+# as_fn_error STATUS ERROR [LINENO LOG_FD]
# Output "`basename $0`: error: ERROR" to stderr. If LINENO and LOG_FD are
# provided, also output the error to LOG_FD, referencing LINENO. Then exit the
-# script with status $?, using 1 if that was 0.
+# script with STATUS, using 1 if that was 0.
as_fn_error ()
- as_status=$?; test $as_status -eq 0 && as_status=1
- if test "$3"; then
- as_lineno=${as_lineno-"$2"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
- $as_echo "$as_me:${as_lineno-$LINENO}: error: $1" >&$3
+ as_status=$1; test $as_status -eq 0 && as_status=1
+ if test "$4"; then
+ as_lineno=${as_lineno-"$3"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
+ $as_echo "$as_me:${as_lineno-$LINENO}: error: $2" >&$4
fi
- $as_echo "$as_me: error: $1" >&2
+ $as_echo "$as_me: error: $2" >&2
as_fn_exit $as_status
} # as_fn_error
@@ -17129,16 +17194,16 @@
# ... but there are two gotchas:
# 1) On MSYS, both `ln -s file dir' and `ln file dir' fail.
# 2) DJGPP < 2.04 has no symlinks; `ln -s' creates a wrapper executable.
- # In both cases, we have to default to `cp -p'.
+ # In both cases, we have to default to `cp -pR'.
ln -s conf$$.file conf$$.dir 2>/dev/null && test ! -f conf$$.exe ||
- as_ln_s='cp -p'
+ as_ln_s='cp -pR'
elif ln conf$$.file conf$$ 2>/dev/null; then
as_ln_s=ln
else
- as_ln_s='cp -p'
+ as_ln_s='cp -pR'
fi
else
- as_ln_s='cp -p'
+ as_ln_s='cp -pR'
fi
rm -f conf$$ conf$$.exe conf$$.dir/conf$$.file conf$$.file
rmdir conf$$.dir 2>/dev/null
@@ -17187,7 +17252,7 @@
test -d "$as_dir" && break
done
test -z "$as_dirs" || eval "mkdir $as_dirs"
- } || test -d "$as_dir" || as_fn_error "cannot create directory $as_dir"
+ } || test -d "$as_dir" || as_fn_error $? "cannot create directory $as_dir"
} # as_fn_mkdir_p
@@ -17198,29 +17263,17 @@
as_mkdir_p=false
fi
-if test -x / >/dev/null 2>&1; then
- as_test_x='test -x'
-else
- if ls -dL / >/dev/null 2>&1; then
- as_ls_L_option=L
- else
- as_ls_L_option=
- fi
- as_test_x='
- eval sh -c '\''
- if test -d "$1"; then
- test -d "$1/.";
- else
- case $1 in #(
- -*)set "./$1";;
- esac;
- case `ls -ld'$as_ls_L_option' "$1" 2>/dev/null` in #((
- ???[sx]*):;;*)false;;esac;fi
- '\'' sh
-fi
-as_executable_p=$as_test_x
+# as_fn_executable_p FILE
+# Test if FILE is an executable regular file.
+as_fn_executable_p ()
+ test -f "$1" && test -x "$1"
+} # as_fn_executable_p
+as_test_x='test -x'
+as_executable_p=as_fn_executable_p
# Sed expression to map a string onto a valid CPP name.
as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
@@ -17241,7 +17294,7 @@
# values after options handling.
ac_log="
This file was extended by XQilla $as_me 2.2.4, which was
-generated by GNU Autoconf 2.64. Invocation command line was
+generated by GNU Autoconf 2.69. Invocation command line was
CONFIG_FILES = $CONFIG_FILES
CONFIG_HEADERS = $CONFIG_HEADERS
@@ -17281,6 +17334,7 @@
-h, --help print this help, then exit
-V, --version print version number and configuration settings, then exit
+ --config print configuration, then exit
-q, --quiet, --silent
do not print progress messages
-d, --debug don't remove temporary files
@@ -17303,12 +17357,13 @@
_ACEOF
cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
+ac_cs_config="`$as_echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`"
ac_cs_version="\\
XQilla config.status 2.2.4
-configured by $0, generated by GNU Autoconf 2.64,
- with options \\"`$as_echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`\\"
+configured by $0, generated by GNU Autoconf 2.69,
+ with options \\"\$ac_cs_config\\"
-Copyright (C) 2009 Free Software Foundation, Inc.
+Copyright (C) 2012 Free Software Foundation, Inc.
This config.status script is free software; the Free Software Foundation
gives unlimited permission to copy, distribute and modify it."
@@ -17326,11 +17381,16 @@
while test $# != 0
do
case $1 in
ac_option=`expr "X$1" : 'X\([^=]*\)='`
ac_optarg=`expr "X$1" : 'X[^=]*=\(.*\)'`
ac_shift=:
+ ac_option=`expr "X$1" : 'X\([^=]*\)='`
+ ac_optarg=
+ ac_shift=:
ac_option=$1
ac_optarg=$2
@@ -17344,12 +17404,15 @@
ac_cs_recheck=: ;;
--version | --versio | --versi | --vers | --ver | --ve | --v | -V )
$as_echo "$ac_cs_version"; exit ;;
+ --config | --confi | --conf | --con | --co | --c )
+ $as_echo "$ac_cs_config"; exit ;;
--debug | --debu | --deb | --de | --d | -d )
debug=: ;;
--file | --fil | --fi | --f )
$ac_shift
case $ac_optarg in
*\'*) ac_optarg=`$as_echo "$ac_optarg" | sed "s/'/'\\\\\\\\''/g"` ;;
+ '') as_fn_error $? "missing file argument" ;;
esac
as_fn_append CONFIG_FILES " '$ac_optarg'"
ac_need_defaults=false;;
@@ -17362,7 +17425,7 @@
--he | --h)
# Conflict between --help and --header
- as_fn_error "ambiguous option: \`$1'
+ as_fn_error $? "ambiguous option: \`$1'
Try \`$0 --help' for more information.";;
--help | --hel | -h )
$as_echo "$ac_cs_usage"; exit ;;
@@ -17371,7 +17434,7 @@
ac_cs_silent=: ;;
# This is an error.
- -*) as_fn_error "unrecognized option: \`$1'
+ -*) as_fn_error $? "unrecognized option: \`$1'
Try \`$0 --help' for more information." ;;
*) as_fn_append ac_config_targets " $1"
@@ -17391,7 +17454,7 @@
_ACEOF
if \$ac_cs_recheck; then
- set X '$SHELL' '$0' $ac_configure_args \$ac_configure_extra_args --no-create --no-recursion
+ set X $SHELL '$0' $ac_configure_args \$ac_configure_extra_args --no-create --no-recursion
shift
\$as_echo "running CONFIG_SHELL=$SHELL \$*" >&6
CONFIG_SHELL='$SHELL'
@@ -17782,7 +17845,7 @@
"Makefile") CONFIG_FILES="$CONFIG_FILES Makefile" ;;
"include/Makefile") CONFIG_FILES="$CONFIG_FILES include/Makefile" ;;
- *) as_fn_error "invalid argument: \`$ac_config_target'" "$LINENO" 5;;
+ *) as_fn_error $? "invalid argument: \`$ac_config_target'" "$LINENO" 5;;
esac
done
@@ -17805,9 +17868,10 @@
# after its creation but before its name has been assigned to `$tmp'.
$debug ||
- tmp=
+ tmp= ac_tmp=
trap 'exit_status=$?
- { test -z "$tmp" || test ! -d "$tmp" || rm -fr "$tmp"; } && exit $exit_status
+ : "${ac_tmp:=$tmp}"
+ { test ! -d "$ac_tmp" || rm -fr "$ac_tmp"; } && exit $exit_status
' 0
trap 'as_fn_exit 1' 1 2 13 15
@@ -17815,12 +17879,13 @@
tmp=`(umask 077 && mktemp -d "./confXXXXXX") 2>/dev/null` &&
- test -n "$tmp" && test -d "$tmp"
+ test -d "$tmp"
tmp=./conf$$-$RANDOM
(umask 077 && mkdir "$tmp")
-} || as_fn_error "cannot create a temporary directory in ." "$LINENO" 5
+} || as_fn_error $? "cannot create a temporary directory in ." "$LINENO" 5
+ac_tmp=$tmp
# Set up the scripts for CONFIG_FILES section.
# No need to generate them if there are no CONFIG_FILES.
@@ -17837,12 +17902,12 @@
fi
ac_cs_awk_cr=`$AWK 'BEGIN { print "a\rb" }' </dev/null 2>/dev/null`
if test "$ac_cs_awk_cr" = "a${ac_cr}b"; then
- ac_cs_awk_cr='\r'
+ ac_cs_awk_cr='\\r'
else
ac_cs_awk_cr=$ac_cr
fi
-echo 'BEGIN {' >"$tmp/subs1.awk" &&
+echo 'BEGIN {' >"$ac_tmp/subs1.awk" &&
_ACEOF
@@ -17851,18 +17916,18 @@
echo "$ac_subst_vars" | sed 's/.*/&!$&$ac_delim/' &&
echo "_ACEOF"
} >conf$$subs.sh ||
- as_fn_error "could not make $CONFIG_STATUS" "$LINENO" 5
-ac_delim_num=`echo "$ac_subst_vars" | grep -c '$'`
+ as_fn_error $? "could not make $CONFIG_STATUS" "$LINENO" 5
+ac_delim_num=`echo "$ac_subst_vars" | grep -c '^'`
ac_delim='%!_!# '
for ac_last_try in false false false false false :; do
. ./conf$$subs.sh ||
ac_delim_n=`sed -n "s/.*$ac_delim\$/X/p" conf$$subs.awk | grep -c X`
if test $ac_delim_n = $ac_delim_num; then
break
elif $ac_last_try; then
else
ac_delim="$ac_delim!$ac_delim _$ac_delim!! "
fi
@@ -17870,7 +17935,7 @@
rm -f conf$$subs.sh
-cat >>"\$tmp/subs1.awk" <<\\_ACAWK &&
+cat >>"\$ac_tmp/subs1.awk" <<\\_ACAWK &&
_ACEOF
sed -n '
h
@@ -17884,7 +17949,7 @@
t delim
:nl
h
-s/\(.\{148\}\).*/\1/
+s/\(.\{148\}\)..*/\1/
t more1
s/["\\]/\\&/g; s/^/"/; s/$/\\n"\\/
p
@@ -17898,7 +17963,7 @@
t nl
:delim
h
t more2
s/["\\]/\\&/g; s/^/"/; s/$/"/
p
@@ -17918,7 +17983,7 @@
rm -f conf$$subs.awk
_ACAWK
-cat >>"\$tmp/subs1.awk" <<_ACAWK &&
+cat >>"\$ac_tmp/subs1.awk" <<_ACAWK &&
for (key in S) S_is_set[key] = 1
FS = ""
@@ -17950,21 +18015,29 @@
sed "s/$ac_cr\$//; s/$ac_cr/$ac_cs_awk_cr/g"
else
cat
-fi < "$tmp/subs1.awk" > "$tmp/subs.awk" \
- || as_fn_error "could not setup config files machinery" "$LINENO" 5
+fi < "$ac_tmp/subs1.awk" > "$ac_tmp/subs.awk" \
+ || as_fn_error $? "could not setup config files machinery" "$LINENO" 5
_ACEOF
-# VPATH may cause trouble with some makes, so we remove $(srcdir),
-# ${srcdir} and @srcdir@ from VPATH if srcdir is ".", strip leading and
+# VPATH may cause trouble with some makes, so we remove sole $(srcdir),
+# ${srcdir} and @srcdir@ entries from VPATH if srcdir is ".", strip leading and
# trailing colons and then remove the whole line if VPATH becomes empty
# (actually we leave an empty line to preserve line numbers).
if test "x$srcdir" = x.; then
- ac_vpsub='/^[ ]*VPATH[ ]*=/{
-s/:*\$(srcdir):*/:/
-s/:*\${srcdir}:*/:/
-s/:*@srcdir@:*/:/
-s/^\([^=]*=[ ]*\):*/\1/
+ ac_vpsub='/^[ ]*VPATH[ ]*=[ ]*/{
+h
+s///
+s/^/:/
+s/[ ]*$/:/
+s/:\$(srcdir):/:/g
+s/:\${srcdir}:/:/g
+s/:@srcdir@:/:/g
+s/^:*//
s/:*$//
+x
+s/\(=[ ]*\).*/\1/
+G
+s/\n//
s/^[^=]*=[ ]*$//
fi
@@ -17976,7 +18049,7 @@
# No need to generate them if there are no CONFIG_HEADERS.
# This happens for instance with `./config.status Makefile'.
if test -n "$CONFIG_HEADERS"; then
-cat >"$tmp/defines.awk" <<\_ACAWK ||
+cat >"$ac_tmp/defines.awk" <<\_ACAWK ||
BEGIN {
_ACEOF
@@ -17988,11 +18061,11 @@
# handling of long lines.
ac_delim='%!_!# '
for ac_last_try in false false :; do
- ac_t=`sed -n "/$ac_delim/p" confdefs.h`
- if test -z "$ac_t"; then
+ ac_tt=`sed -n "/$ac_delim/p" confdefs.h`
+ if test -z "$ac_tt"; then
break
- as_fn_error "could not make $CONFIG_HEADERS" "$LINENO" 5
+ as_fn_error $? "could not make $CONFIG_HEADERS" "$LINENO" 5
else
fi
@@ -18077,7 +18150,7 @@
_ACAWK
_ACEOF
cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
- as_fn_error "could not setup config headers machinery" "$LINENO" 5
+ as_fn_error $? "could not setup config headers machinery" "$LINENO" 5
fi # test -n "$CONFIG_HEADERS"
@@ -18090,7 +18163,7 @@
esac
case $ac_mode$ac_tag in
:[FHL]*:*);;
- :L* | :C*:*) as_fn_error "invalid tag \`$ac_tag'" "$LINENO" 5;;
+ :L* | :C*:*) as_fn_error $? "invalid tag \`$ac_tag'" "$LINENO" 5;;
:[FH]-) ac_tag=-:-;;
:[FH]*) ac_tag=$ac_tag:$ac_tag.in;;
esac
@@ -18109,7 +18182,7 @@
for ac_f
do
case $ac_f in
- -) ac_f="$tmp/stdin";;
+ -) ac_f="$ac_tmp/stdin";;
*) # Look for the file first in the build tree, then in the source tree
# (if the path is not absolute). The absolute path cannot be DOS-style,
# because $ac_f cannot contain `:'.
@@ -18118,7 +18191,7 @@
[\\/$]*) false;;
*) test -f "$srcdir/$ac_f" && ac_f="$srcdir/$ac_f";;
esac ||
- as_fn_error "cannot find input file: \`$ac_f'" "$LINENO" 5;;
+ as_fn_error 1 "cannot find input file: \`$ac_f'" "$LINENO" 5;;
esac
case $ac_f in *\'*) ac_f=`$as_echo "$ac_f" | sed "s/'/'\\\\\\\\''/g"`;; esac
as_fn_append ac_file_inputs " '$ac_f'"
@@ -18144,8 +18217,8 @@
esac
case $ac_tag in
- *:-:* | *:-) cat >"$tmp/stdin" \
- || as_fn_error "could not create $ac_file" "$LINENO" 5 ;;
+ *:-:* | *:-) cat >"$ac_tmp/stdin" \
+ || as_fn_error $? "could not create $ac_file" "$LINENO" 5 ;;
esac
esac
@@ -18281,23 +18354,24 @@
s&@MKDIR_P@&$ac_MKDIR_P&;t t
$ac_datarootdir_hack
-eval sed \"\$ac_sed_extra\" "$ac_file_inputs" | $AWK -f "$tmp/subs.awk" >$tmp/out \
+eval sed \"\$ac_sed_extra\" "$ac_file_inputs" | $AWK -f "$ac_tmp/subs.awk" \
+ >$ac_tmp/out || as_fn_error $? "could not create $ac_file" "$LINENO" 5
test -z "$ac_datarootdir_hack$ac_datarootdir_seen" &&
- { ac_out=`sed -n '/\${datarootdir}/p' "$tmp/out"`; test -n "$ac_out"; } &&
- { ac_out=`sed -n '/^[ ]*datarootdir[ ]*:*=/p' "$tmp/out"`; test -z "$ac_out"; } &&
+ { ac_out=`sed -n '/\${datarootdir}/p' "$ac_tmp/out"`; test -n "$ac_out"; } &&
+ { ac_out=`sed -n '/^[ ]*datarootdir[ ]*:*=/p' \
+ "$ac_tmp/out"`; test -z "$ac_out"; } &&
{ $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $ac_file contains a reference to the variable \`datarootdir'
-which seems to be undefined. Please make sure it is defined." >&5
+which seems to be undefined. Please make sure it is defined" >&5
$as_echo "$as_me: WARNING: $ac_file contains a reference to the variable \`datarootdir'
-which seems to be undefined. Please make sure it is defined." >&2;}
+which seems to be undefined. Please make sure it is defined" >&2;}
- rm -f "$tmp/stdin"
+ rm -f "$ac_tmp/stdin"
case $ac_file in
- -) cat "$tmp/out" && rm -f "$tmp/out";;
- *) rm -f "$ac_file" && mv "$tmp/out" "$ac_file";;
+ -) cat "$ac_tmp/out" && rm -f "$ac_tmp/out";;
+ *) rm -f "$ac_file" && mv "$ac_tmp/out" "$ac_file";;
esac \
:H)
@@ -18306,21 +18380,21 @@
if test x"$ac_file" != x-; then
$as_echo "/* $configure_input */" \
- && eval '$AWK -f "$tmp/defines.awk"' "$ac_file_inputs"
- } >"$tmp/config.h" \
- if diff "$ac_file" "$tmp/config.h" >/dev/null 2>&1; then
+ && eval '$AWK -f "$ac_tmp/defines.awk"' "$ac_file_inputs"
+ } >"$ac_tmp/config.h" \
+ if diff "$ac_file" "$ac_tmp/config.h" >/dev/null 2>&1; then
{ $as_echo "$as_me:${as_lineno-$LINENO}: $ac_file is unchanged" >&5
$as_echo "$as_me: $ac_file is unchanged" >&6;}
else
rm -f "$ac_file"
- mv "$tmp/config.h" "$ac_file" \
+ mv "$ac_tmp/config.h" "$ac_file" \
fi
else
- && eval '$AWK -f "$tmp/defines.awk"' "$ac_file_inputs" \
- || as_fn_error "could not create -" "$LINENO" 5
+ && eval '$AWK -f "$ac_tmp/defines.awk"' "$ac_file_inputs" \
+ || as_fn_error $? "could not create -" "$LINENO" 5
fi
# Compute "$ac_file"'s index in $config_headers.
_am_arg="$ac_file"
@@ -19272,7 +19346,7 @@
ac_clean_files=$ac_clean_files_save
test $ac_write_fail = 0 ||
- as_fn_error "write failure creating $CONFIG_STATUS" "$LINENO" 5
+ as_fn_error $? "write failure creating $CONFIG_STATUS" "$LINENO" 5
# configure is writing to config.log, and then calls config.status.
@@ -19293,7 +19367,7 @@
exec 5>>config.log
# Use ||, not &&, to avoid exiting from the if with $? = 1, which
# would make configure fail if this is the last instruction.
- $ac_cs_success || as_fn_exit $?
+ $ac_cs_success || as_fn_exit 1
fi
if test -n "$ac_unrecognized_opts" && test "$enable_option_checking" != no; then
{ $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: unrecognized options: $ac_unrecognized_opts" >&5
Modified: sandbox/jng/cmake_v2/Oem/dbxml/xqilla/configure.in
--- sandbox/jng/cmake_v2/Oem/dbxml/xqilla/configure.in 2018-01-05 11:44:27 UTC (rev 9278)
+++ sandbox/jng/cmake_v2/Oem/dbxml/xqilla/configure.in 2018-01-05 13:35:40 UTC (rev 9279)
@@ -120,13 +120,20 @@
elif test `ls $with_xerces/src/libxerces-c.* 2>/dev/null | wc -l` -gt 0 ; then
xerces_lib="$with_xerces/src"
else
- if test "$xerces_source_tree" = "yes" -a "$xerces_version_major" -ge "3"; then
- xerces_lib="$with_xerces/src"
+ # For distros like Ubuntu there are extra places to check for non-source-tree xerces assuming --with-xerces=/usr was given
+ # NOTE: Surely one would've have both 32 and 64 bit versions of this library installed ... right?
+ if test "$xerces_source_tree" = "no" -a `ls $with_xerces/lib/i386-linux-gnu/libxerces-c.* 2>/dev/null | wc -l` -gt 0 ; then
+ xerces_lib="$with_xerces/lib/i386-linux-gnu"
+ elif test "$xerces_source_tree" = "no" -a `ls $with_xerces/lib/x86_64-linux-gnu/libxerces-c.* 2>/dev/null | wc -l` -gt 0 ; then
+ xerces_lib="$with_xerces/lib/x86_64-linux-gnu"
else
- xerces_lib="$with_xerces/lib"
+ if test "$xerces_source_tree" = "yes" -a "$xerces_version_major" -ge "3"; then
+ xerces_lib="$with_xerces/src"
+ else
+ xerces_lib="$with_xerces/lib"
+ fi
+ AC_MSG_WARN([Unable to find the Xerces-C library. Guessed path is $xerces_lib.])
fi
- AC_MSG_WARN([Unable to find the Xerces-C library. Guessed path is $xerces_lib.])
fi
AC_SUBST(xerces_include)
More information about the mapguide-commits
