[mapguide-commits] r9370 - in branches/3.1/MgDev: . Common/PlatformBase/Services Server/src/UnitTesting
svn_mapguide at osgeo.org
Wed Mar 14 09:59:13 PDT 2018
Author: jng
Date: 2018-03-14 09:59:13 -0700 (Wed, 14 Mar 2018)
New Revision: 9370
branches/3.1/MgDev/
branches/3.1/MgDev/Common/PlatformBase/Services/FeatureReader.cpp
branches/3.1/MgDev/Server/src/UnitTesting/TestFeatureService.cpp
branches/3.1/MgDev/Server/src/UnitTesting/TestFeatureService.h
Merged revision(s) 9369 from trunk/MgDev:
Don't throw on bad property name in GetPropertyIndex, just return -1. This is the expected contract that other reader types already fulfil. Why should MgFeatureReader be an exception?
Fixes #2480
Index: branches/3.1/MgDev
--- branches/3.1/MgDev 2018-03-14 16:55:55 UTC (rev 9369)
+++ branches/3.1/MgDev 2018-03-14 16:59:13 UTC (rev 9370)
Property changes on: branches/3.1/MgDev
___________________________________________________________________
Modified: svn:mergeinfo
## -15,4 +15,4 ##
/sandbox/jng/tiling:8174-8208
/sandbox/jng/v30:8212-8227
/sandbox/rfc94:5099-5163
-/trunk/MgDev:8955-8956,8969,8980-8981,8986,8996,9000,9004-9006,9010,9018-9021,9034,9038,9042,9094,9106-9107,9147,9339-9343,9353,9360,9363
\ No newline at end of property
+/trunk/MgDev:8955-8956,8969,8980-8981,8986,8996,9000,9004-9006,9010,9018-9021,9034,9038,9042,9094,9106-9107,9147,9339-9343,9353,9360,9363,9369
Modified: branches/3.1/MgDev/Common/PlatformBase/Services/FeatureReader.cpp
--- branches/3.1/MgDev/Common/PlatformBase/Services/FeatureReader.cpp 2018-03-14 16:55:55 UTC (rev 9369)
+++ branches/3.1/MgDev/Common/PlatformBase/Services/FeatureReader.cpp 2018-03-14 16:59:13 UTC (rev 9370)
@@ -68,18 +68,7 @@
Ptr<MgPropertyDefinitionCollection> propDefCol = classDef->GetProperties();
CHECKNULL((MgPropertyDefinitionCollection*)propDefCol, L"MgFeatureReader.GetPropertyIndex");
- INT32 index = propDefCol->IndexOf(propertyName);
- if (-1 != index)
- return index;
- else
- MgStringCollection args;
- args.Add(propertyName);
- throw new MgObjectNotFoundException(L"MgFeatureReader.GetPropertyIndex", __LINE__, __WFILE__, NULL, L"MgNoNameForObject", &args);
- return -1; // to suppress compiler warning.
+ return propDefCol->IndexOf(propertyName);
Modified: branches/3.1/MgDev/Server/src/UnitTesting/TestFeatureService.cpp
--- branches/3.1/MgDev/Server/src/UnitTesting/TestFeatureService.cpp 2018-03-14 16:55:55 UTC (rev 9369)
+++ branches/3.1/MgDev/Server/src/UnitTesting/TestFeatureService.cpp 2018-03-14 16:59:13 UTC (rev 9370)
@@ -3731,4 +3731,54 @@
qClassName += L":";
qClassName += theClass->GetName();
return qClassName;
+/// Test Case Description:
+/// This test case exercises getting indices of invalid property names from
+/// the feature reader
+void TestFeatureService::TestCase_FeatureReader_GetPropertyIndex_BadProp()
+ try
+ MgServiceManager* serviceManager = MgServiceManager::GetInstance();
+ if (serviceManager == 0)
+ throw new MgNullReferenceException(L"TestFeatureService.TestCase_FeatureReader_GetPropertyIndex_BadProp", __LINE__, __WFILE__, NULL, L"", NULL);
+ Ptr<MgFeatureService> pService = dynamic_cast<MgFeatureService*>(serviceManager->RequestService(MgServiceType::FeatureService));
+ if (pService == 0)
+ throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_FeatureReader_GetPropertyIndex_BadProp", __LINE__, __WFILE__, NULL, L"", NULL);
+ Ptr<MgResourceIdentifier> resource = new MgResourceIdentifier();
+ STRING className = L"";
+ Ptr<MgFeatureQueryOptions> options = new MgFeatureQueryOptions();
+ CPPUNIT_ASSERT_THROW_MG(pService->SelectFeatures(resource, className, options), MgInvalidArgumentException*);
+ resource = new MgResourceIdentifier(L"Library://UnitTests/Data/Sheboygan_Parcels.FeatureSource");
+ className = L"Parcels";
+ Ptr<MgFeatureReader> reader = pService->SelectFeatures(resource, className, options);
+ CPPUNIT_ASSERT(reader->GetPropertyIndex(L"IDontExist") < 0);
+ reader->Close();
+ catch (MgException* e)
+ STRING message = e->GetDetails(TEST_LOCALE);
+ SAFE_RELEASE(e);
+ CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+ catch (FdoException* e)
+ FDO_SAFE_RELEASE(e);
+ CPPUNIT_FAIL("FdoException occurred");
+ catch (...)
+ throw;
\ No newline at end of file
Modified: branches/3.1/MgDev/Server/src/UnitTesting/TestFeatureService.h
--- branches/3.1/MgDev/Server/src/UnitTesting/TestFeatureService.h 2018-03-14 16:55:55 UTC (rev 9369)
+++ branches/3.1/MgDev/Server/src/UnitTesting/TestFeatureService.h 2018-03-14 16:59:13 UTC (rev 9370)
@@ -69,6 +69,7 @@
CPPUNIT_TEST(TestCase_JoinFdoFeatures);
CPPUNIT_TEST(TestCase_BenchmarkSqliteJoin);
CPPUNIT_TEST(TestCase_BenchmarkSqliteAggregateJoin);
+ CPPUNIT_TEST(TestCase_FeatureReader_GetPropertyIndex_BadProp);
CPPUNIT_TEST(TestEnd); // This must be the very last unit test
CPPUNIT_TEST_SUITE_END();
@@ -124,6 +125,7 @@
void TestCase_JoinFdoFeatures();
void TestCase_BenchmarkSqliteJoin();
void TestCase_BenchmarkSqliteAggregateJoin();
+ void TestCase_FeatureReader_GetPropertyIndex_BadProp();
private:
STRING CreateTestDataStore(MgFeatureService* svcFeature, CREFSTRING provider, MgResourceIdentifier* fsId);
More information about the mapguide-commits
