[mapguide-commits] r9387 - branches/3.1/MgDev/Web/src/WebSupport
svn_mapguide at osgeo.org
Mon May 7 07:51:36 PDT 2018
Author: jng
Date: 2018-05-07 07:51:36 -0700 (Mon, 07 May 2018)
New Revision: 9387
branches/3.1/MgDev/Web/src/WebSupport/InitializeWebTier.cpp
#2780: Support MentorUserDictionaryPath in webconfig.ini as well. This is needed for the web tier to pick up any user dictionaries that the server tier only currently is aware of, as it supports this property in serverconfig.ini
Modified: branches/3.1/MgDev/Web/src/WebSupport/InitializeWebTier.cpp
--- branches/3.1/MgDev/Web/src/WebSupport/InitializeWebTier.cpp 2018-05-03 14:13:19 UTC (rev 9386)
+++ branches/3.1/MgDev/Web/src/WebSupport/InitializeWebTier.cpp 2018-05-07 14:51:36 UTC (rev 9387)
@@ -76,6 +76,9 @@
STRING mentorDictPath;
config->GetStringValue(MgConfigProperties::GeneralPropertiesSection, MgConfigProperties::GeneralPropertyMentorDictionaryPath, mentorDictPath, MgConfigProperties::DefaultGeneralPropertyMentorDictionaryPath);
+ STRING mentorUserDictPath;
+ config->GetStringValue(MgConfigProperties::GeneralPropertiesSection, MgConfigProperties::GeneralPropertyMentorUserDictionaryPath, mentorUserDictPath, MgConfigProperties::DefaultGeneralPropertyMentorUserDictionaryPath);
//Check catalog
if (NULL == csCatalog.p)
@@ -88,6 +91,12 @@
MgFileUtil::AppendSlashToEndOfPath(mentorDictPath);
csCatalog->SetDictionaryDir(mentorDictPath);
+ if (!mentorUserDictPath.empty())
+ MgFileUtil::AppendSlashToEndOfPath(mentorUserDictPath);
+ csCatalog->SetUserDictionaryDir(mentorUserDictPath);
//Check lib status
LibraryStatus status = csCatalog->GetLibraryStatus();
More information about the mapguide-commits
