[mapguide-commits] r9593 - trunk/MgDev/Oem/LinuxApt
svn_mapguide at osgeo.org
Fri Aug 16 08:28:42 PDT 2019
Author: jng
Date: 2019-08-16 08:28:42 -0700 (Fri, 16 Aug 2019)
New Revision: 9593
trunk/MgDev/Oem/LinuxApt/CMakeLists.txt
Fix incorrect tomcat tarball reference
Modified: trunk/MgDev/Oem/LinuxApt/CMakeLists.txt
--- trunk/MgDev/Oem/LinuxApt/CMakeLists.txt 2019-08-07 12:10:44 UTC (rev 9592)
+++ trunk/MgDev/Oem/LinuxApt/CMakeLists.txt 2019-08-16 15:28:42 UTC (rev 9593)
@@ -19,7 +19,7 @@
install(FILES ${CMAKE_CURRENT_BINARY_DIR}/tomcat.conf DESTINATION ${MG_INSTALL_WEB_PREFIX}/apache2/conf/mapguide COMPONENT ${MG_COMPONENT})
file(MAKE_DIRECTORY ${CMAKE_CURRENT_BINARY_DIR}/tomcat)
- execute_process(COMMAND tar -zxf ${CMAKE_CURRENT_SOURCE_DIR}/apache-tomcat-7.0.82.tar.gz -C ${CMAKE_CURRENT_BINARY_DIR}/tomcat --strip-components=1)
+ execute_process(COMMAND tar -zxf ${CMAKE_CURRENT_SOURCE_DIR}/apache-tomcat-7.0.92.tar.gz -C ${CMAKE_CURRENT_BINARY_DIR}/tomcat --strip-components=1)
configure_file(${CMAKE_MODULE_PATH}/../configs/mapguide.xml.in ${CMAKE_CURRENT_BINARY_DIR}/tomcat/conf/Catalina/localhost/mapguide.xml)
# Don't overwrite startup.sh in the CMAKE_CURRENT_BINARY_DIR as the subseqent install will do the same thing
More information about the mapguide-commits
