[mapguide-commits] r9595 - trunk/MgDev/Common/MapGuideCommon/Controller
svn_mapguide at osgeo.org
Thu Aug 29 05:29:56 PDT 2019
Author: jng
Date: 2019-08-29 05:29:56 -0700 (Thu, 29 Aug 2019)
New Revision: 9595
trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp
When rendering a selection key for a QUERYMAPFEATURES 4.0.0 request, make sure identity properties are part of the explicit property list when making the feature query
Fixes #2806
Modified: trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp
--- trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp 2019-08-19 22:23:19 UTC (rev 9594)
+++ trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp 2019-08-29 12:29:56 UTC (rev 9595)
@@ -539,6 +539,21 @@
if (!propNames->Contains(selLayer->GetFeatureGeometryName()))
propNames->Add(selLayer->GetFeatureGeometryName()); //Don't forget geometry
+ if (bIncludeSelectionKey)
+ //Need to make sure identity properties are part of the explicit property list
+ MgLayerBase::IdPropertyList propList = selLayer->GetIdPropertyList();
+ MgLayerBase::IdPropertyList::iterator idIter;
+ for (idIter = propList.begin(); idIter != propList.end(); ++idIter)
+ if (!propNames->Contains(idIter->name))
+ propNames->Add(idIter->name);
xmlOut.append(L"</LayerMetadata>\n");
Ptr<MgReader> reader = selectionSet->GetSelectedFeatures(selLayer, selLayer->GetFeatureClassName(), propNames);
while (reader->ReadNext())
More information about the mapguide-commits
