[mapguide-commits] r9473 - in trunk/MgDev: . Common Common/Renderers Server/src/Core
svn_mapguide at osgeo.org
Sun Feb 3 09:04:47 PST 2019
Author: jng
Date: 2019-02-03 09:04:47 -0800 (Sun, 03 Feb 2019)
New Revision: 9473
trunk/MgDev/CMakeLists.txt
trunk/MgDev/Common/CMakeLists.txt
trunk/MgDev/Common/Renderers/CMakeLists.txt
trunk/MgDev/Server/src/Core/CMakeLists.txt
trunk/MgDev/cmake_bootstrap.sh
#2795: Get CMake build working with a fully built Oem tree
- Add check for librt as on distros with an older libc (eg. CentOS 6.x) define clock_gettime() here instead of in libc. If librt is indeed required, set NEED_LIBRT=1 which is a hint to affected projects to link in librt
- Rework cmake_bootstrap.sh to make install cppunit/libjpeg/libpng/freetype/zlib in the standard location (/usr/local) instead of trying to be smart and installing it to a local directory under the OEM build area.
- This requires an additional potential freetype include path to be specified for Renderers and ServerCore
Modified: trunk/MgDev/CMakeLists.txt
--- trunk/MgDev/CMakeLists.txt 2019-02-03 10:27:04 UTC (rev 9472)
+++ trunk/MgDev/CMakeLists.txt 2019-02-03 17:04:47 UTC (rev 9473)
@@ -57,6 +57,7 @@
include(CheckIncludeFile)
include(CheckCXXSourceCompiles)
include(CheckLibraryExists)
+include(CheckSymbolExists)
include(ExternalProject)
set(MG_VERSION_MAJOR 3)
@@ -217,6 +218,17 @@
message(STATUS "Xerces does not appear to typedef XMLCh to char16_t")
endif (XERCES_USES_CHAR16_T)
+set (NEED_LIBRT 0)
+CHECK_LIBRARY_EXISTS(rt clock_gettime "time.h" HAVE_CLOCK_GETTIME)
+if (NOT HAVE_CLOCK_GETTIME)
+ set(CMAKE_EXTRA_INCLUDE_FILES time.h)
+ CHECK_FUNCTION_EXISTS(clock_gettime HAVE_CLOCK_GETTIME)
+ SET(CMAKE_EXTRA_INCLUDE_FILES)
+else (NOT HAVE_CLOCK_GETTIME)
+ message(STATUS "Found clock_gettime in librt")
+ set (NEED_LIBRT 1)
+endif (NOT HAVE_CLOCK_GETTIME)
add_subdirectory(BuildTools)
add_subdirectory(Oem)
add_subdirectory(Common)
Modified: trunk/MgDev/Common/CMakeLists.txt
--- trunk/MgDev/Common/CMakeLists.txt 2019-02-03 10:27:04 UTC (rev 9472)
+++ trunk/MgDev/Common/CMakeLists.txt 2019-02-03 17:04:47 UTC (rev 9473)
@@ -1,6 +1,10 @@
# NOTE: Not applied for server tier projects except for mgserver main executable
if( CMAKE_COMPILER_IS_GNUCXX )
- set ( CMAKE_SHARED_LINKER_FLAGS "-Wl,--as-needed -Wl,--no-undefined -lc ${CMAKE_SHARED_LINKER_FLAGS}")
+ if (NEED_LIBRT)
+ set ( CMAKE_SHARED_LINKER_FLAGS "-Wl,--no-as-needed -Wl,--no-undefined -lc -lrt ${CMAKE_SHARED_LINKER_FLAGS}")
+ else (NEED_LIBRT)
+ set ( CMAKE_SHARED_LINKER_FLAGS "-Wl,--as-needed -Wl,--no-undefined -lc ${CMAKE_SHARED_LINKER_FLAGS}")
+ endif (NEED_LIBRT)
endif( CMAKE_COMPILER_IS_GNUCXX )
# On ubuntu at least, the system installed ACE does not define this (required by us)
Modified: trunk/MgDev/Common/Renderers/CMakeLists.txt
--- trunk/MgDev/Common/Renderers/CMakeLists.txt 2019-02-03 10:27:04 UTC (rev 9472)
+++ trunk/MgDev/Common/Renderers/CMakeLists.txt 2019-02-03 17:04:47 UTC (rev 9473)
@@ -2,6 +2,7 @@
include_directories(${GD_INCLUDE_DIR}
${FREETYPE_INCLUDE_DIRS}
+ ${FREETYPE_INCLUDE_DIRS}/freetype2
${PNG_INCLUDE_DIRS}
${FDO_INCLUDE_DIR}
${FDO_INCLUDE_DIR}/ExpressionEngine
Modified: trunk/MgDev/Server/src/Core/CMakeLists.txt
--- trunk/MgDev/Server/src/Core/CMakeLists.txt 2019-02-03 10:27:04 UTC (rev 9472)
+++ trunk/MgDev/Server/src/Core/CMakeLists.txt 2019-02-03 17:04:47 UTC (rev 9473)
@@ -6,6 +6,7 @@
${ACE_INCLUDE_DIR}
${XERCESC_INCLUDE_DIR}
${DBXML_INCLUDE_DIR}
${FDO_INCLUDE_DIR}
@@ -80,6 +81,10 @@
MgRenderers${MG_VERSION_SUFFIX}
+if (NEED_LIBRT)
+ target_link_libraries(mgserver rt)
+endif (NEED_LIBRT)
########### BEGIN Development/Testing environment setup #############
file(GLOB_RECURSE UNIT_TEST_FILES "${MG_UNIT_TEST_DATA_DIR}/*.*")
file(COPY ${UNIT_TEST_FILES} DESTINATION ${CMAKE_CURRENT_BINARY_DIR}/../UnitTestFiles)
Modified: trunk/MgDev/cmake_bootstrap.sh
--- trunk/MgDev/cmake_bootstrap.sh 2019-02-03 10:27:04 UTC (rev 9472)
+++ trunk/MgDev/cmake_bootstrap.sh 2019-02-03 17:04:47 UTC (rev 9473)
@@ -148,9 +148,6 @@
echo "Created OEM working dir at: $OEM_WORK_DIR"
fi
-OEM_INSTALL_STAGE="${OEM_WORK_DIR}/install"
-mkdir -p "$OEM_INSTALL_STAGE"
if [ "$INTERNAL_ACE" = "1" ]; then
echo "Building ACE (internal)"
cp -Rf "${SOURCE_DIR}/Oem/ACE" "${OEM_WORK_DIR}/ACE"
@@ -181,7 +178,7 @@
autoconf
automake --add-missing --copy --force-missing
# -ldl is to prevent undefined reference to dlsym/dlopen/dlclose
- sh ./configure --enable-silent-rules --prefix="${OEM_INSTALL_STAGE}/cppunit" LDFLAGS="-ldl"
+ sh ./configure --enable-silent-rules LDFLAGS="-ldl"
make && make install
check_build
fi
@@ -193,9 +190,9 @@
if [ "$USE_CCACHE" = "1" ]; then
# Aliasing CC=ccache gcc breaks the gcc check in this configure script that
# would've inserted the required -fPIC flag. So specify manually
- CFLAGS="-O3 -fPIC" sh ./configure --prefix="${OEM_INSTALL_STAGE}/zlib"
+ CFLAGS="-O3 -fPIC" sh ./configure
else
- sh ./configure --prefix="${OEM_INSTALL_STAGE}/zlib"
+ sh ./configure
fi
check_build
@@ -204,18 +201,15 @@
echo "Building libpng (internal)"
cp -Rf "${SOURCE_DIR}/Oem/gd/lpng" "${OEM_WORK_DIR}/gd/lpng"
cd "${OEM_WORK_DIR}/gd/lpng" || exit
- # Need to ensure these directories exist first for our custom prefix to work
- mkdir -p "${OEM_INSTALL_STAGE}/libpng"
- mkdir -p "${OEM_INSTALL_STAGE}/libpng/usr/local"
cp scripts/makefile.std makefile
if [ $BUILD_CPU -eq 64 ]; then
#Inject -fPIC to CFLAGS for 64-bit
sed 's/^CFLAGS=/CFLAGS= -fPIC -m64 /g' makefile > makefile64
- make -fmakefile64 DESTDIR="${OEM_INSTALL_STAGE}/libpng"
- make -fmakefile64 DESTDIR="${OEM_INSTALL_STAGE}/libpng" install
+ make -fmakefile64
+ make -fmakefile64 install
check_build
else
- make && make DESTDIR="${OEM_INSTALL_STAGE}/libpng" install
+ make && make install
check_build
fi
fi
@@ -223,30 +217,26 @@
echo "Building libjpeg (internal)"
cp -Rf "${SOURCE_DIR}/Oem/gd/jpeg" "${OEM_WORK_DIR}/gd/jpeg"
cd "${OEM_WORK_DIR}/gd/jpeg" || exit
- mkdir -p "${OEM_INSTALL_STAGE}/libjpeg/bin"
- mkdir -p "${OEM_INSTALL_STAGE}/libjpeg/man/man1"
+ # This directory must exist in order for make install to work
+ mkdir -p /usr/local/man/man1
# A jconfig.h that is not modifed by ./configure will trip up make, so nuke it first
rm -f jconfig.h
- sh ./configure --enable-static --disable-shared --prefix="${OEM_INSTALL_STAGE}/libjpeg"
+ sh ./configure --enable-static --disable-shared
#--with-pic does nothing (probably ancient configure script), so do some sed trickery
#to inject this flag. Know a better way? Enlighten us :)
sed 's/^CFLAGS=/CFLAGS= -fPIC -m64 /g' Makefile > Makefile64
make -fMakefile64
check_build
- make -fMakefile64 install
+ make -fMakefile64 install-lib
check_build
else
make
check_build
make install
check_build
fi
- # Make some symlinks so that PHP can work with this
- ln -s "${OEM_WORK_DIR}/gd/jpeg" "${OEM_INSTALL_STAGE}/libjpeg/include"
- ln -s "${OEM_WORK_DIR}/gd/jpeg/.libs" "${OEM_INSTALL_STAGE}/libjpeg/lib"
fi
if [ "$INTERNAL_FREETYPE" = "1" ]; then
echo "Building freetype (internal)"
@@ -253,9 +243,9 @@
cp -Rf "${SOURCE_DIR}/Oem/gd/freetype" "${OEM_WORK_DIR}/gd/freetype"
cd "${OEM_WORK_DIR}/gd/freetype" || exit
- sh ./configure --enable-static --disable-shared --with-pic --prefix="${OEM_INSTALL_STAGE}/freetype"
+ sh ./configure --enable-static --disable-shared --with-pic
else
- sh ./configure --enable-static --disable-shared --prefix="${OEM_INSTALL_STAGE}/freetype"
fi
check_build
@@ -284,15 +274,10 @@
cp -Rf "${SOURCE_DIR}/Oem/gd/gd" "${OEM_WORK_DIR}/gd/gd"
cd "${OEM_WORK_DIR}/gd/gd" || exit
- echo "Running gd configure with: --enable-static --disable-shared --without-fontconfig --enable-silent-rules --with-jpeg=${PHP_JPEG_DIR} --with-png=${PHP_PNG_DIR} --with-freetype=${PHP_FREETYPE_DIR} --with-pic --prefix=${OEM_INSTALL_STAGE}/gd"
- sh ./configure --enable-static --disable-shared --without-fontconfig --enable-silent-rules --with-jpeg="${PHP_JPEG_DIR}" --with-png="${PHP_PNG_DIR}" --with-freetype="${PHP_FREETYPE_DIR}" --with-pic --prefix="${OEM_INSTALL_STAGE}/gd"
+ sh ./configure --enable-static --disable-shared --without-fontconfig --with-jpeg=/usr/local --with-pic
else
- echo "Running gd configure with: --enable-static --disable-shared --without-fontconfig --enable-silent-rules --with-jpeg=${PHP_JPEG_DIR} --with-png=${PHP_PNG_DIR} --with-freetype=${PHP_FREETYPE_DIR} --prefix=${OEM_INSTALL_STAGE}/gd"
- sh ./configure --enable-static --disable-shared --without-fontconfig --enable-silent-rules --with-jpeg="${PHP_JPEG_DIR}" --with-png="${PHP_PNG_DIR}" --with-freetype="${PHP_FREETYPE_DIR}" --prefix="${OEM_INSTALL_STAGE}/gd"
fi
- #--with-png does not add the libpng include path to CPPFLAGS (???)
- #So sed patch this path in
- sed -i "s|^CPPFLAGS =|CPPFLAGS = -I$PHP_PNG_DIR/include/libpng |g" Makefile
check_build
fi
More information about the mapguide-commits
