[mapguide-commits] r9475 - in sandbox/jng/common_decouple_v3: . Common/Renderers Common/Stylization Server/src/Services/Kml Server/src/Services/Mapping Server/src/Services/Rendering
svn_mapguide at osgeo.org
Tue Feb 5 05:44:22 PST 2019
Author: jng
Date: 2019-02-05 05:44:22 -0800 (Tue, 05 Feb 2019)
New Revision: 9475
Added:
sandbox/jng/common_decouple_v3/Common/Renderers/RenderersSlim.vcxproj
sandbox/jng/common_decouple_v3/Common/Renderers/RenderersSlim.vcxproj.filters
sandbox/jng/common_decouple_v3/Common/Stylization/FdoExpressionEvaluator.cpp
sandbox/jng/common_decouple_v3/Common/Stylization/FdoExpressionEvaluator.h
sandbox/jng/common_decouple_v3/Common/Stylization/FdoExpressionEvaluatorFactory.cpp
sandbox/jng/common_decouple_v3/Common/Stylization/FdoExpressionEvaluatorFactory.h
sandbox/jng/common_decouple_v3/Common/Stylization/RS_FdoFeatureReader.h
sandbox/jng/common_decouple_v3/Common/Stylization/RS_Types.h
sandbox/jng/common_decouple_v3/Common/Stylization/SE_ExpressionEvaluator.h
sandbox/jng/common_decouple_v3/Common/Stylization/SE_ExpressionEvaluatorFactory.h
sandbox/jng/common_decouple_v3/Common/Renderers/AGGRenderer.cpp
sandbox/jng/common_decouple_v3/Common/Renderers/AGGRenderer.h
sandbox/jng/common_decouple_v3/Common/Renderers/Renderers.vcxproj
sandbox/jng/common_decouple_v3/Common/Stylization/DefaultStylizer.cpp
sandbox/jng/common_decouple_v3/Common/Stylization/DefaultStylizer.h
sandbox/jng/common_decouple_v3/Common/Stylization/ExpressionHelper.cpp
sandbox/jng/common_decouple_v3/Common/Stylization/GeometryAdapter.cpp
sandbox/jng/common_decouple_v3/Common/Stylization/GeometryAdapter.h
sandbox/jng/common_decouple_v3/Common/Stylization/LabelRendererLocal.cpp
sandbox/jng/common_decouple_v3/Common/Stylization/LineBuffer.h
sandbox/jng/common_decouple_v3/Common/Stylization/PointAdapter.cpp
sandbox/jng/common_decouple_v3/Common/Stylization/PointAdapter.h
sandbox/jng/common_decouple_v3/Common/Stylization/PolygonAdapter.cpp
sandbox/jng/common_decouple_v3/Common/Stylization/PolygonAdapter.h
sandbox/jng/common_decouple_v3/Common/Stylization/PolylineAdapter.cpp
sandbox/jng/common_decouple_v3/Common/Stylization/PolylineAdapter.h
sandbox/jng/common_decouple_v3/Common/Stylization/RS_FeatureReader.h
sandbox/jng/common_decouple_v3/Common/Stylization/RasterAdapter.cpp
sandbox/jng/common_decouple_v3/Common/Stylization/RasterAdapter.h
sandbox/jng/common_decouple_v3/Common/Stylization/SE_ExpressionBase.cpp
sandbox/jng/common_decouple_v3/Common/Stylization/SE_ExpressionBase.h
sandbox/jng/common_decouple_v3/Common/Stylization/SE_LineBuffer.cpp
sandbox/jng/common_decouple_v3/Common/Stylization/SE_LineRenderer.cpp
sandbox/jng/common_decouple_v3/Common/Stylization/SE_PositioningAlgorithms.cpp
sandbox/jng/common_decouple_v3/Common/Stylization/SE_Renderer.cpp
sandbox/jng/common_decouple_v3/Common/Stylization/SE_StyleVisitor.cpp
sandbox/jng/common_decouple_v3/Common/Stylization/SE_SymbolDefProxies.cpp
sandbox/jng/common_decouple_v3/Common/Stylization/SE_SymbolDefProxies.h
sandbox/jng/common_decouple_v3/Common/Stylization/Stylization.vcxproj
sandbox/jng/common_decouple_v3/Common/Stylization/Stylization.vcxproj.filters
sandbox/jng/common_decouple_v3/Common/Stylization/StylizationDefs.h
sandbox/jng/common_decouple_v3/Common/Stylization/StylizationEngine.cpp
sandbox/jng/common_decouple_v3/Common/Stylization/StylizationEngine.h
sandbox/jng/common_decouple_v3/Common/Stylization/StylizationUtil.cpp
sandbox/jng/common_decouple_v3/Common/Stylization/StylizationUtil.h
sandbox/jng/common_decouple_v3/Common/Stylization/Stylizer.h
sandbox/jng/common_decouple_v3/Server/src/Services/Kml/ServerKmlService.cpp
sandbox/jng/common_decouple_v3/Server/src/Services/Mapping/MappingUtil.cpp
sandbox/jng/common_decouple_v3/Server/src/Services/Mapping/RSMgFeatureReader.h
sandbox/jng/common_decouple_v3/Server/src/Services/Rendering/FeaturePropRenderer.cpp
sandbox/jng/common_decouple_v3/Server/src/Services/Rendering/ServerRenderingService.cpp
Merged revision(s) 9356-9358 from sandbox/jng/common_decouple_v2:
Merged revision(s) 9351-9352 from sandbox/jng/common_decouple:
Add a RenderersSlim project that decouples DWF Toolkit and GD (renderer) from the Renderers project. A new WITH_DWF preprocessor symbol is used to #ifdef out DWF-related things from the AGGRenderer. The existing Renderers project defines this symbol. RenderersSlim does not.
Use UnicodeString::WideCharToMultiByte in the absence of DWFCore::DWFString::EncodeUTF8
Re-work decoupling FDO from the Stylization Engine (vs how I did it previously on the stylization_refactor sandbox):
- Use GeometryType/Dimensionality/GeometryComponentType everywhere instead of FdoGeometryType/FdoDimensionality/FdoGeometryComponentType
- Typedef FdoInt8/16/32/64/DateTime as RS_Int8/16/32/64/DateTime respectively
- Add RS_FdoFeatureReader (that inherits from RS_FeatureReader) to provide the GetInternalReader method. Update all existing implementations to inherit from RS_FdoFeatureReader instead.
- Add SE_ExpressionEvaluator abstract class that provides services for evaluating expressions
- Add SE_ExpressionEvaluatorFactory abstract class that can construct SE_ExpressionEvaluator instances
- Replace usages of FdoExpressionEngine with SE_ExpressionEvaluator
- Replace usages of FdoExpression with MdfString
- Add FDO implementation of:
- SE_ExpressionEvaluator (FdoExpressionEvaluator)
- This does all the interaction with the FDO expression engine and the caching of Fdo filters and expressions
- SE_ExpressionEvaluatorFactory (FdoExpressionEvaluatorFactory)
- This creates FdoExpressionEvaluator instances
- Ensure all consumers in the MapGuide Server pass down a FdoExpressionEvaluatorFactory where required.
Don't #ifdef out the methods in AGGRenderer.h just #ifdef out their method implementations.
Index: sandbox/jng/common_decouple_v3
--- sandbox/jng/common_decouple_v3 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3 2019-02-05 13:44:22 UTC (rev 9475)
Property changes on: sandbox/jng/common_decouple_v3
___________________________________________________________________
Modified: svn:mergeinfo
## -11,6 +11,8 ##
/sandbox/jng/clean_json:8818-9180
/sandbox/jng/cmake_v2:9259-9317
/sandbox/jng/cmdline:9199-9217
+/sandbox/jng/common_decouple:9351-9352,9354
+/sandbox/jng/common_decouple_v2:9356-9358
/sandbox/jng/convenience_apis:8262-8268,8271-8363
/sandbox/jng/coordsys_mapagent:9231-9254
/sandbox/jng/createruntimemap:7486-7555
Modified: sandbox/jng/common_decouple_v3/Common/Renderers/AGGRenderer.cpp
--- sandbox/jng/common_decouple_v3/Common/Renderers/AGGRenderer.cpp 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Renderers/AGGRenderer.cpp 2019-02-05 13:44:22 UTC (rev 9475)
@@ -30,9 +30,10 @@
#include "ConvertUTF.h"
#include "UnicodeString.h"
#include "AGGFillPatterns.h"
+#ifdef WITH_DWF
#include "AGGW2DRewriter.h"
#include "whiptk/whip_toolkit.h"
+#endif
#include "LabelRenderer.h"
#include "LabelRendererLocal.h"
@@ -39,7 +40,7 @@
#include "SymbolTrans.h"
#include "agg_context.h"
+#ifdef WITH_DWF
#include "dwfcore/File.h"
#include "dwfcore/String.h"
#include "dwfcore/Exception.h"
@@ -61,15 +62,16 @@
#include "DWFRSInputStream.h"
#include "RSDWFInputStream.h"
+#endif
#include "SE_SymbolDefProxies.h"
#include "RenderUtil.h"
+#ifdef WITH_DWF
using namespace DWFToolkit;
using namespace DWFCore;
+#endif
#define ROUND(x) (int)((x) + 0.5)
#define SYMBOL_BITMAP_SIZE 128
@@ -1485,13 +1487,20 @@
if (cxt->last_font != font)
// convert font path to utf8
+#ifdef WITH_DWF
size_t lenf = font->m_filename.length();
size_t lenbytesf = lenf * 4 + 1;
char* futf8 = (char*)alloca(lenbytesf);
DWFCore::DWFString::EncodeUTF8(font->m_filename.c_str(), lenf * sizeof(wchar_t), futf8, lenbytesf);
// load the font
bool res = cxt->feng.load_font(futf8, 0, glyph_type);
+#else
+ std::string mbFont;
+ UnicodeString::WideCharToMultiByte(font->m_filename.c_str(), mbFont);
+ // load the font
+ bool res = cxt->feng.load_font(mbFont.c_str(), 0, glyph_type);
+#endif
cxt->feng.char_map(FT_ENCODING_UNICODE);
if (!res)
@@ -1606,12 +1615,18 @@
if (c()->last_font != font)
+#ifdef WITH_DWF
+ bool res1 = c()->feng.load_font(futf8, 0, agg::glyph_ren_agg_gray8);
+#else
+ bool res1 = c()->feng.load_font(mbFont.c_str(), 0, agg::glyph_ren_agg_gray8);
+#endif
- bool res1 = c()->feng.load_font(futf8, 0, agg::glyph_ren_agg_gray8);
c()->feng.char_map(FT_ENCODING_UNICODE);
if (!res1)
@@ -2769,6 +2784,7 @@
const RS_String& passwd,
const RS_String& w2dfilter)
+#ifdef WITH_DWF
try
if (in->available() == 0)
@@ -2882,12 +2898,13 @@
catch (DWFException&)
+#endif
void AGGRenderer::AddW2DContent(RS_InputStream* in, CSysTransformer* xformer, const RS_String& w2dfilter)
+#ifdef WITH_DWF
WT_Result result;
// initialize state variables, which are needed by W2D rewriter callbacks
@@ -2924,6 +2941,7 @@
// clear the output image if we set it in this function
if (!m_bIsSymbolW2D)
m_imw2d = NULL;
+#endif
@@ -2930,6 +2948,7 @@
void AGGRenderer::SetActions(WT_File& file)
+#ifdef WITH_DWF
file.set_stream_open_action (agr_open);
file.set_stream_close_action(agr_close);
file.set_stream_read_action (agr_read);
@@ -3006,6 +3025,7 @@
file.set_gouraud_polytriangle_action(agr_process_gouraudPolytriangle);
file.set_gouraud_polyline_action(agr_process_gouraudPolyline);
+#endif
@@ -3029,6 +3049,7 @@
int numpts,
bool checkInBounds)
+#ifdef WITH_DWF
// This transformer may have been modified if a Viewport
// opcode was encountered in the source W2D. This is needed for
// support for symbols from ACAD, which do not use the
@@ -3130,6 +3151,9 @@
return spLB.release();
+#else
+ return NULL;
+#endif
@@ -3139,8 +3163,9 @@
// of the destination DWF or be much larger, we need to take that scaling
// into account when carrying over things like line weight, font height,
// etc. This helper function determines and applies that scale.
-double AGGRenderer::ScaleW2DNumber(WT_File& file, WT_Integer32 number)
+double AGGRenderer::ScaleW2DNumber(WT_File& file, long number)
+#ifdef WITH_DWF
WT_Matrix xform = file.desired_rendition().drawing_info().units().dwf_to_application_adjoint_transform();
double scale1 = 1.0 / xform(0, 0); // div because we need inverse
@@ -3162,6 +3187,9 @@
dDstSpace *= m_xform.x0;
return dDstSpace;
+#else
+ return 0.0;
+#endif
@@ -3168,6 +3196,7 @@
void AGGRenderer::UpdateSymbolTrans(WT_File& /*file*/, WT_Viewport& viewport)
+#ifdef WITH_DWF
_ASSERT(m_xformer);
RS_Bounds alternate_extent(0.0, 0.0, -1.0, -1.0);
@@ -3234,6 +3263,7 @@
m_bHaveViewport = true;
+#endif
@@ -3243,4 +3273,4 @@
//// END of DWF Rewrite and related code
\ No newline at end of file
Modified: sandbox/jng/common_decouple_v3/Common/Renderers/AGGRenderer.h
--- sandbox/jng/common_decouple_v3/Common/Renderers/AGGRenderer.h 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Renderers/AGGRenderer.h 2019-02-05 13:44:22 UTC (rev 9475)
@@ -304,7 +304,6 @@
//image or to a temporary cached symbol image in case we are
//processing a symbol from the library
agg_context* m_imw2d;
// map/layer/feature info
RS_MapUIInfo* m_mapInfo;
RS_LayerUIInfo* m_layerInfo;
@@ -339,12 +338,10 @@
int numpts,
bool checkInBounds);
/*Do not export from DLL*/ double ScaleW2DNumber(WT_File& file, long number);
private:
void AddW2DContent(RS_InputStream* in, CSysTransformer* xformer, const RS_String& w2dfilter);
void SetActions(WT_File& file);
//State variables for when DWFRenderer is used to keep
//information during DWF rewriting process for symbols
Modified: sandbox/jng/common_decouple_v3/Common/Renderers/Renderers.vcxproj
--- sandbox/jng/common_decouple_v3/Common/Renderers/Renderers.vcxproj 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Renderers/Renderers.vcxproj 2019-02-05 13:44:22 UTC (rev 9475)
@@ -96,7 +96,7 @@
<AdditionalOptions>$(USRCFLAGS) %(AdditionalOptions)</AdditionalOptions>
<Optimization>Disabled</Optimization>
<AdditionalIncludeDirectories>..\MdfModel;..\Stylization;..\..\Oem\FDO\inc;..\..\Oem\FDO\inc\ExpressionEngine;..\..\Oem\DWFTK\develop\global\src;..\..\Oem\DWFTK\develop\global\src\dwf;..\..\Oem\gd\gd;..\..\Oem\gd\freetype\include;..\..\Oem\agg-2.4\include;..\..\Oem\agg-2.4\font_freetype;..\..\Oem\gd\lpng;..\..\Oem\gd\zlib;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
- <PreprocessorDefinitions>WIN32;_DEBUG;_WINDOWS;_USRDLL;RENDERERS_EXPORTS;DWFCORE_STATIC;DWFTK_STATIC;DWFTK_USE_DWFCORE_ZLIB;DWFTK_BUILD_EXPAT;WHIP_STATIC_LIB;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <PreprocessorDefinitions>WIN32;WITH_DWF;_DEBUG;_WINDOWS;_USRDLL;RENDERERS_EXPORTS;DWFCORE_STATIC;DWFTK_STATIC;DWFTK_USE_DWFCORE_ZLIB;DWFTK_BUILD_EXPAT;WHIP_STATIC_LIB;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
<ExceptionHandling>Async</ExceptionHandling>
<BasicRuntimeChecks>EnableFastChecks</BasicRuntimeChecks>
<RuntimeLibrary>MultiThreadedDebugDLL</RuntimeLibrary>
@@ -125,7 +125,7 @@
@@ -155,7 +155,7 @@
<FavorSizeOrSpeed>Speed</FavorSizeOrSpeed>
<OmitFramePointers>true</OmitFramePointers>
<AdditionalIncludeDirectories>..\MdfModel;..\Stylization;..\..\Oem\FDO\inc;..\..\Oem\DWFTK\develop\global\src;..\..\Oem\DWFTK\develop\global\src\dwf;..\..\Oem\gd\gd;..\..\Oem\gd\freetype\include;..\..\Oem\agg-2.4\include;..\..\Oem\gd\lpng;..\..\Oem\agg-2.4\font_freetype;..\..\Oem\gd\zlib;..\..\Oem\FDO\inc\ExpressionEngine;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
- <PreprocessorDefinitions>WIN32;NDEBUG;_WINDOWS;_USRDLL;RENDERERS_EXPORTS;DWFCORE_STATIC;DWFTK_STATIC;DWFTK_USE_DWFCORE_ZLIB;DWFTK_BUILD_EXPAT;WHIP_STATIC_LIB;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <PreprocessorDefinitions>WIN32;WITH_DWF;NDEBUG;_WINDOWS;_USRDLL;RENDERERS_EXPORTS;DWFCORE_STATIC;DWFTK_STATIC;DWFTK_USE_DWFCORE_ZLIB;DWFTK_BUILD_EXPAT;WHIP_STATIC_LIB;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
<RuntimeLibrary>MultiThreadedDLL</RuntimeLibrary>
<EnableEnhancedInstructionSet>NotSet</EnableEnhancedInstructionSet>
@@ -190,7 +190,7 @@
Copied: sandbox/jng/common_decouple_v3/Common/Renderers/RenderersSlim.vcxproj (from rev 9358, sandbox/jng/common_decouple_v2/Common/Renderers/RenderersSlim.vcxproj)
--- sandbox/jng/common_decouple_v3/Common/Renderers/RenderersSlim.vcxproj (rev 0)
+++ sandbox/jng/common_decouple_v3/Common/Renderers/RenderersSlim.vcxproj 2019-02-05 13:44:22 UTC (rev 9475)
@@ -0,0 +1,296 @@
+<?xml version="1.0" encoding="utf-8"?>
+<Project DefaultTargets="Build" ToolsVersion="14.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+ <ItemGroup Label="ProjectConfigurations">
+ <ProjectConfiguration Include="Debug|Win32">
+ <Configuration>Debug</Configuration>
+ <Platform>Win32</Platform>
+ </ProjectConfiguration>
+ <ProjectConfiguration Include="Debug|x64">
+ <Platform>x64</Platform>
+ <ProjectConfiguration Include="Release|Win32">
+ <Configuration>Release</Configuration>
+ <ProjectConfiguration Include="Release|x64">
+ </ItemGroup>
+ <PropertyGroup Label="Globals">
+ <ProjectGuid>{A9BBBE56-1F77-426B-8EFE-6DDACC9F4991}</ProjectGuid>
+ <RootNamespace>Renderers</RootNamespace>
+ <Keyword>Win32Proj</Keyword>
+ <ProjectName>RenderersSlim</ProjectName>
+ </PropertyGroup>
+ <Import Project="$(VCTargetsPath)\Microsoft.Cpp.Default.props" />
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" Label="Configuration">
+ <ConfigurationType>DynamicLibrary</ConfigurationType>
+ <CharacterSet>Unicode</CharacterSet>
+ <PlatformToolset>v140</PlatformToolset>
+ </PropertyGroup>
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" Label="Configuration">
+ </PropertyGroup>
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|x64'" Label="Configuration">
+ </PropertyGroup>
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" Label="Configuration">
+ </PropertyGroup>
+ <Import Project="$(VCTargetsPath)\Microsoft.Cpp.props" />
+ <ImportGroup Label="ExtensionSettings">
+ </ImportGroup>
+ <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" Label="PropertySheets">
+ <Import Project="$(UserRootDir)\Microsoft.Cpp.$(Platform).user.props" Condition="exists('$(UserRootDir)\Microsoft.Cpp.$(Platform).user.props')" Label="LocalAppDataPlatform" />
+ </ImportGroup>
+ <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" Label="PropertySheets">
+ </ImportGroup>
+ <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Release|x64'" Label="PropertySheets">
+ </ImportGroup>
+ <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" Label="PropertySheets">
+ </ImportGroup>
+ <PropertyGroup Label="UserMacros" />
+ <PropertyGroup>
+ <_ProjectFileVersion>10.0.40219.1</_ProjectFileVersion>
+ <OutDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">..\bin\$(Configuration)\</OutDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">..\obj\$(Configuration)\Renderers\</IntDir>
+ <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">true</LinkIncremental>
+ <OutDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">..\bin\$(Configuration)64\</OutDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">..\obj\$(Configuration)64\Renderers\</IntDir>
+ <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">true</LinkIncremental>
+ <OutDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">..\bin\$(Configuration)\</OutDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">..\obj\$(Configuration)\Renderers\</IntDir>
+ <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">false</LinkIncremental>
+ <OutDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">..\bin\$(Configuration)64\</OutDir>
+ <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">..\obj\$(Configuration)64\Renderers\</IntDir>
+ <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Release|x64'">false</LinkIncremental>
+ <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">AllRules.ruleset</CodeAnalysisRuleSet>
+ <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" />
+ <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" />
+ <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">AllRules.ruleset</CodeAnalysisRuleSet>
+ <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" />
+ <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" />
+ <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">AllRules.ruleset</CodeAnalysisRuleSet>
+ <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" />
+ <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" />
+ <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Release|x64'">AllRules.ruleset</CodeAnalysisRuleSet>
+ <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Release|x64'" />
+ <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Release|x64'" />
+ <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">MgRenderersd</TargetName>
+ <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">MgRenderersd</TargetName>
+ <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|x64'">MgRenderers</TargetName>
+ <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">MgRenderers</TargetName>
+ </PropertyGroup>
+ <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">
+ <ClCompile>
+ <AdditionalOptions>$(USRCFLAGS) %(AdditionalOptions)</AdditionalOptions>
+ <Optimization>Disabled</Optimization>
+ <AdditionalIncludeDirectories>..\MdfModel;..\Stylization;..\..\Oem\FDO\inc;..\..\Oem\FDO\inc\ExpressionEngine;..\..\Oem\gd\gd;..\..\Oem\gd\freetype\include;..\..\Oem\agg-2.4\include;..\..\Oem\agg-2.4\font_freetype;..\..\Oem\gd\lpng;..\..\Oem\gd\zlib;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
+ <PreprocessorDefinitions>WIN32;_DEBUG;_WINDOWS;_USRDLL;RENDERERS_EXPORTS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <ExceptionHandling>Async</ExceptionHandling>
+ <BasicRuntimeChecks>EnableFastChecks</BasicRuntimeChecks>
+ <RuntimeLibrary>MultiThreadedDebugDLL</RuntimeLibrary>
+ <WarningLevel>Level4</WarningLevel>
+ <DebugInformationFormat>ProgramDatabase</DebugInformationFormat>
+ <MultiProcessorCompilation>true</MultiProcessorCompilation>
+ </ClCompile>
+ <Link>
+ <AdditionalDependencies>zlibd.lib;gd.lib;freetype235_D.lib;libpngd.lib;%(AdditionalDependencies)</AdditionalDependencies>
+ <OutputFile>$(OutDir)MgRenderersd.dll</OutputFile>
+ <AdditionalLibraryDirectories>..\..\Oem\gd\build\win32\gd\$(Configuration);..\..\Oem\gd\freetype\objs\$(Configuration);..\..\Oem\gd\lpng\projects\vs\$(Configuration);..\..\Oem\gd\lpng\projects\vs\$(Configuration)\ZLib;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
+ <GenerateDebugInformation>true</GenerateDebugInformation>
+ <ProgramDatabaseFile>$(OutDir)MgRenderersd.pdb</ProgramDatabaseFile>
+ <SubSystem>Windows</SubSystem>
+ <RandomizedBaseAddress>false</RandomizedBaseAddress>
+ <DataExecutionPrevention>
+ </DataExecutionPrevention>
+ <ImportLibrary>..\lib\$(Configuration)\MgRenderersd.lib</ImportLibrary>
+ <TargetMachine>MachineX86</TargetMachine>
+ <ForceFileOutput>
+ </ForceFileOutput>
+ </Link>
+ </ItemDefinitionGroup>
+ <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">
+ <ClCompile>
+ </ClCompile>
+ <Link>
+ <AdditionalLibraryDirectories>..\..\Oem\gd\build\win32\gd\$(Configuration)64;..\..\Oem\gd\freetype\objs\$(Configuration)64;..\..\Oem\gd\lpng\projects\vs\$(Configuration)64;..\..\Oem\gd\lpng\projects\vs\$(Configuration)64\ZLib;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
+ <ImportLibrary>..\lib\$(Configuration)64\MgRenderersd.lib</ImportLibrary>
+ <TargetMachine>MachineX64</TargetMachine>
+ <ForceFileOutput>
+ </Link>
+ <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">
+ <ClCompile>
+ <Optimization>MaxSpeed</Optimization>
+ <InlineFunctionExpansion>AnySuitable</InlineFunctionExpansion>
+ <IntrinsicFunctions>true</IntrinsicFunctions>
+ <FavorSizeOrSpeed>Speed</FavorSizeOrSpeed>
+ <OmitFramePointers>true</OmitFramePointers>
+ <AdditionalIncludeDirectories>..\MdfModel;..\Stylization;..\..\Oem\FDO\inc;..\..\Oem\gd\gd;..\..\Oem\gd\freetype\include;..\..\Oem\agg-2.4\include;..\..\Oem\gd\lpng;..\..\Oem\agg-2.4\font_freetype;..\..\Oem\gd\zlib;..\..\Oem\FDO\inc\ExpressionEngine;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
+ <PreprocessorDefinitions>WIN32;NDEBUG;_WINDOWS;_USRDLL;RENDERERS_EXPORTS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <RuntimeLibrary>MultiThreadedDLL</RuntimeLibrary>
+ <EnableEnhancedInstructionSet>NotSet</EnableEnhancedInstructionSet>
+ </ClCompile>
+ <Link>
+ <AdditionalDependencies>zlib.lib;gd.lib;freetype235.lib;libpng.lib;%(AdditionalDependencies)</AdditionalDependencies>
+ <OutputFile>$(OutDir)MgRenderers.dll</OutputFile>
+ <AdditionalLibraryDirectories>..\..\Oem\gd\build\win32\gd\$(Configuration);..\..\Oem\gd\freetype\objs\$(Configuration);..\..\Oem\gd\lpng\projects\vs\$(Configuration);..\..\Oem\gd\lpng\projects\vs\$(Configuration)\ZLib%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
+ <ProgramDatabaseFile>$(OutDir)MgRenderers.pdb</ProgramDatabaseFile>
+ <OptimizeReferences>true</OptimizeReferences>
+ <EnableCOMDATFolding>true</EnableCOMDATFolding>
+ <ImportLibrary>..\lib\$(Configuration)\MgRenderers.lib</ImportLibrary>
+ <ForceFileOutput>
+ </Link>
+ <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Release|x64'">
+ <ClCompile>
+ </ClCompile>
+ <Link>
+ <ImportLibrary>..\lib\$(Configuration)64\MgRenderers.lib</ImportLibrary>
+ <ForceFileOutput>
+ </Link>
+ <ItemGroup>
+ <ClCompile Include="GDUtils.cpp" />
+ <ClCompile Include="MapQuantization.cpp" />
+ <ClCompile Include="RS_ByteData.cpp" />
+ <ClCompile Include="SymbolTrans.cpp" />
+ <ClCompile Include="UTFGridContent.cpp" />
+ <ClCompile Include="UTFGridRenderer.cpp" />
+ <ClCompile Include="ObservationMesh.cpp" />
+ <ClCompile Include="KmlContent.cpp" />
+ <ClCompile Include="KmlIconStyle.cpp" />
+ <ClCompile Include="KmlLineStyle.cpp" />
+ <ClCompile Include="KmlPolyStyle.cpp" />
+ <ClCompile Include="KmlRenderer.cpp" />
+ <ClCompile Include="FontManager.cpp" />
+ <ClCompile Include="..\..\Oem\agg-2.4\src\agg_curves.cpp">
+ <DisableSpecificWarnings Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">4505;%(DisableSpecificWarnings)</DisableSpecificWarnings>
+ <DisableSpecificWarnings Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">4505;%(DisableSpecificWarnings)</DisableSpecificWarnings>
+ <DisableSpecificWarnings Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">4505;%(DisableSpecificWarnings)</DisableSpecificWarnings>
+ <DisableSpecificWarnings Condition="'$(Configuration)|$(Platform)'=='Release|x64'">4505;%(DisableSpecificWarnings)</DisableSpecificWarnings>
+ </ClCompile>
+ <ClCompile Include="..\..\Oem\agg-2.4\font_freetype\agg_font_freetype.cpp">
+ <DisableSpecificWarnings Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">4100;4244;4267;4512;%(DisableSpecificWarnings)</DisableSpecificWarnings>
+ <DisableSpecificWarnings Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">4100;4244;4267;4512;%(DisableSpecificWarnings)</DisableSpecificWarnings>
+ <DisableSpecificWarnings Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">4100;4244;4267;4512;%(DisableSpecificWarnings)</DisableSpecificWarnings>
+ <DisableSpecificWarnings Condition="'$(Configuration)|$(Platform)'=='Release|x64'">4100;4244;4267;4512;%(DisableSpecificWarnings)</DisableSpecificWarnings>
+ </ClCompile>
+ <ClCompile Include="..\..\Oem\agg-2.4\src\agg_line_aa_basics.cpp" />
+ <ClCompile Include="..\..\Oem\agg-2.4\src\agg_line_profile_aa.cpp" />
+ <ClCompile Include="..\..\Oem\agg-2.4\src\agg_sqrt_tables.cpp" />
+ <ClCompile Include="..\..\Oem\agg-2.4\src\agg_trans_affine.cpp" />
+ <ClCompile Include="..\..\Oem\agg-2.4\src\agg_vcgen_contour.cpp" />
+ <ClCompile Include="..\..\Oem\agg-2.4\src\agg_vcgen_stroke.cpp" />
+ <ClCompile Include="AGGFillPatterns.cpp" />
+ <ClCompile Include="AGGImageIO.cpp" />
+ <ClCompile Include="AGGRenderer.cpp" />
+ <ClCompile Include="CriticalSection.cpp" />
+ <ClCompile Include="RenderUtil.cpp" />
+ </ItemGroup>
+ <ItemGroup>
+ <ClInclude Include="agg_utfgrid_context.h" />
+ <ClInclude Include="GDUtils.h" />
+ <ClInclude Include="MapQuantization.h" />
+ <ClInclude Include="MapUTFGrid.h" />
+ <ClInclude Include="RS_ByteData.h" />
+ <ClInclude Include="SymbolTrans.h" />
+ <ClInclude Include="UTFGridContent.h" />
+ <ClInclude Include="UTFGridRenderer.h" />
+ <ClInclude Include="ObservationMesh.h" />
+ <ClInclude Include="KmlContent.h" />
+ <ClInclude Include="KmlIconStyle.h" />
+ <ClInclude Include="KmlLineStyle.h" />
+ <ClInclude Include="KmlPolyStyle.h" />
+ <ClInclude Include="KmlRenderer.h" />
+ <ClInclude Include="FontManager.h" />
+ <ClInclude Include="agg_context.h" />
+ <ClInclude Include="agg_mg_overloads.h" />
+ <ClInclude Include="AGGFillPatterns.h" />
+ <ClInclude Include="AGGImageIO.h" />
+ <ClInclude Include="AGGRenderer.h" />
+ <ClInclude Include="CriticalSection.h" />
+ <ClInclude Include="Renderers.h" />
+ <ClInclude Include="RenderUtil.h" />
+ <ClInclude Include="stdafx.h" />
+ </ItemGroup>
+ <ItemGroup>
+ <ResourceCompile Include="Renderers.rc" />
+ </ItemGroup>
+ <ItemGroup>
+ <ProjectReference Include="..\MdfModel\MDFModel.vcxproj">
+ <Project>{c50254f2-654a-48de-af5b-20605aef8d10}</Project>
+ </ProjectReference>
+ <ProjectReference Include="..\Stylization\Stylization.vcxproj">
+ <Project>{341d5463-186e-49ba-b942-3d3be28d65c0}</Project>
+ <ReferenceOutputAssembly>false</ReferenceOutputAssembly>
+ </ItemGroup>
+ <Import Project="$(VCTargetsPath)\Microsoft.Cpp.targets" />
+ <ImportGroup Label="ExtensionTargets">
+ </ImportGroup>
+</Project>
Copied: sandbox/jng/common_decouple_v3/Common/Renderers/RenderersSlim.vcxproj.filters (from rev 9358, sandbox/jng/common_decouple_v2/Common/Renderers/RenderersSlim.vcxproj.filters)
--- sandbox/jng/common_decouple_v3/Common/Renderers/RenderersSlim.vcxproj.filters (rev 0)
+++ sandbox/jng/common_decouple_v3/Common/Renderers/RenderersSlim.vcxproj.filters 2019-02-05 13:44:22 UTC (rev 9475)
@@ -0,0 +1,160 @@
+<Project ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+ <ItemGroup>
+ <Filter Include="CSTransformers">
+ <UniqueIdentifier>{b08c2fd6-9fea-4ce3-9ecf-006822957739}</UniqueIdentifier>
+ </Filter>
+ <Filter Include="Mesh">
+ <UniqueIdentifier>{f451c1e3-40e1-4a05-a00e-22d2a2bd70fe}</UniqueIdentifier>
+ </Filter>
+ <Filter Include="KmlRenderer">
+ <UniqueIdentifier>{1cba4c6e-438e-46f2-a8c6-a343cdd191db}</UniqueIdentifier>
+ </Filter>
+ <Filter Include="FontEngine">
+ <UniqueIdentifier>{dcbd7b18-5be9-4904-a9c6-07792d3fcfdf}</UniqueIdentifier>
+ </Filter>
+ <Filter Include="AGGRenderer">
+ <UniqueIdentifier>{737455e1-014f-4212-b295-d535728637bc}</UniqueIdentifier>
+ </Filter>
+ <Filter Include="UTFGridRenderer">
+ <UniqueIdentifier>{139cab4d-e977-4ad2-8526-73e40cb9dde1}</UniqueIdentifier>
+ </Filter>
+ </ItemGroup>
+ <ItemGroup>
+ <ClCompile Include="SymbolTrans.cpp">
+ <Filter>CSTransformers</Filter>
+ </ClCompile>
+ <ClCompile Include="ObservationMesh.cpp">
+ <Filter>Mesh</Filter>
+ </ClCompile>
+ <ClCompile Include="KmlContent.cpp">
+ <Filter>KmlRenderer</Filter>
+ </ClCompile>
+ <ClCompile Include="KmlIconStyle.cpp">
+ </ClCompile>
+ <ClCompile Include="KmlLineStyle.cpp">
+ </ClCompile>
+ <ClCompile Include="KmlPolyStyle.cpp">
+ </ClCompile>
+ <ClCompile Include="KmlRenderer.cpp">
+ </ClCompile>
+ <ClCompile Include="FontManager.cpp">
+ <Filter>FontEngine</Filter>
+ </ClCompile>
+ <Filter>AGGRenderer</Filter>
+ </ClCompile>
+ </ClCompile>
+ <ClCompile Include="..\..\Oem\agg-2.4\src\agg_line_aa_basics.cpp">
+ </ClCompile>
+ <ClCompile Include="..\..\Oem\agg-2.4\src\agg_line_profile_aa.cpp">
+ </ClCompile>
+ <ClCompile Include="..\..\Oem\agg-2.4\src\agg_sqrt_tables.cpp">
+ </ClCompile>
+ <ClCompile Include="..\..\Oem\agg-2.4\src\agg_trans_affine.cpp">
+ </ClCompile>
+ <ClCompile Include="..\..\Oem\agg-2.4\src\agg_vcgen_contour.cpp">
+ </ClCompile>
+ <ClCompile Include="..\..\Oem\agg-2.4\src\agg_vcgen_stroke.cpp">
+ </ClCompile>
+ <ClCompile Include="AGGFillPatterns.cpp">
+ </ClCompile>
+ <ClCompile Include="AGGImageIO.cpp">
+ </ClCompile>
+ <ClCompile Include="AGGRenderer.cpp">
+ </ClCompile>
+ <ClCompile Include="UTFGridRenderer.cpp">
+ <Filter>UTFGridRenderer</Filter>
+ </ClCompile>
+ <ClCompile Include="UTFGridContent.cpp">
+ </ClCompile>
+ <ClCompile Include="RS_ByteData.cpp">
+ </ClCompile>
+ </ItemGroup>
+ <ItemGroup>
+ <ClInclude Include="SymbolTrans.h">
+ </ClInclude>
+ <ClInclude Include="ObservationMesh.h">
+ </ClInclude>
+ <ClInclude Include="KmlContent.h">
+ </ClInclude>
+ <ClInclude Include="KmlIconStyle.h">
+ </ClInclude>
+ <ClInclude Include="KmlLineStyle.h">
+ </ClInclude>
+ <ClInclude Include="KmlPolyStyle.h">
+ </ClInclude>
+ <ClInclude Include="KmlRenderer.h">
+ </ClInclude>
+ <ClInclude Include="FontManager.h">
+ </ClInclude>
+ <ClInclude Include="agg_context.h">
+ </ClInclude>
+ <ClInclude Include="agg_mg_overloads.h">
+ </ClInclude>
+ <ClInclude Include="AGGFillPatterns.h">
+ </ClInclude>
+ <ClInclude Include="AGGImageIO.h">
+ </ClInclude>
+ <ClInclude Include="AGGRenderer.h">
+ </ClInclude>
+ <ClInclude Include="UTFGridRenderer.h">
+ </ClInclude>
+ <ClInclude Include="UTFGridContent.h">
+ </ClInclude>
+ <ClInclude Include="agg_utfgrid_context.h">
+ </ClInclude>
+ <ClInclude Include="MapUTFGrid.h">
+ </ClInclude>
+ <ClInclude Include="RS_ByteData.h">
+ </ClInclude>
+ </ItemGroup>
+ <ItemGroup>
+ </ItemGroup>
+</Project>
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/DefaultStylizer.cpp
--- sandbox/jng/common_decouple_v3/Common/Stylization/DefaultStylizer.cpp 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/DefaultStylizer.cpp 2019-02-05 13:44:22 UTC (rev 9475)
@@ -27,7 +27,7 @@
#include "ElevationSettings.h"
#include "FeatureTypeStyleVisitor.h"
#include "StylizationEngine.h"
-#include "ExpressionHelper.h"
+#include "SE_ExpressionEvaluatorFactory.h"
#ifdef _DEBUG
#include <cstdio>
#endif
@@ -63,6 +63,7 @@
void DefaultStylizer::StylizeVectorLayer(MdfModel::VectorLayerDefinition* layer,
Renderer* renderer,
RS_FeatureReader* features,
+ SE_ExpressionEvaluatorFactory* evFactory,
double mapScale,
CancelStylization cancel,
@@ -101,7 +102,7 @@
// composite type styles are handled by the new style engine
if (foundComposite)
- m_styleEngine->StylizeVectorLayer(layer, scaleRange, (SE_Renderer*)renderer, features, xformer, cancel, userData);
+ m_styleEngine->StylizeVectorLayer(layer, scaleRange, evFactory, (SE_Renderer*)renderer, features, xformer, cancel, userData);
else
@@ -148,7 +149,7 @@
// draw even if we are not drawing the actual geometry
if (maxStyles == 0)
- nFeatures = StylizeVLHelper(layer, scaleRange, renderer, features, true, xformer, cancel, userData);
+ nFeatures = StylizeVLHelper(layer, scaleRange, renderer, features, evFactory, true, xformer, cancel, userData);
else
@@ -181,7 +182,7 @@
syms->Adopt(syms2->GetAt(i));
- nFeatures += StylizeVLHelper(layer, scaleRange, renderer, features, i==0, xformer, cancel, userData);
+ nFeatures += StylizeVLHelper(layer, scaleRange, renderer, features, evFactory, i==0, xformer, cancel, userData);
// clear line style from each rule in the layer definition
for (int m=0; m<rules->GetCount(); ++m)
@@ -216,7 +217,7 @@
else
// composite line style separation not required
#ifdef _DEBUG
@@ -234,12 +235,13 @@
void DefaultStylizer::StylizeWatermark(Renderer* renderer,
MdfModel::WatermarkDefinition* watermark,
int drawWidth,
int drawHeight,
int saveWidth,
int saveHeight)
- m_styleEngine->StylizeWatermark((SE_Renderer*)renderer, watermark, drawWidth, drawHeight, saveWidth, saveHeight);
+ m_styleEngine->StylizeWatermark((SE_Renderer*)renderer, watermark, evFactory, drawWidth, drawHeight, saveWidth, saveHeight);
m_styleEngine->ClearCache();
@@ -249,6 +251,7 @@
MdfModel::VectorScaleRange* scaleRange,
Renderer* renderer,
bool initialPass,
@@ -311,12 +314,12 @@
// ignore Z values if the renderer doesn't need them
bool ignoreZ = !renderer->SupportsZ();
- // create an expression engine with our custom functions
- // NOTE: We must create a new engine for each call to StylizeVLHelper. The
- // engine stores a weak reference to the RS_FeatureReader's internal
+ // create an expression evaluator with our custom functions
+ // NOTE: We must create a new evaluator for each call to StylizeVLHelper. The
+ // evaluator stores a weak reference to the RS_FeatureReader's internal
// FdoIFeatureReader, and this internal reader is different for each
// call to StylizeVLHelper.
- FdoPtr<FdoExpressionEngine> exec = ExpressionHelper::GetExpressionEngine(renderer, features);
+ std::auto_ptr<SE_ExpressionEvaluator> exec(evFactory->CreateEvaluator(renderer, features));
// main loop over feature data
int nFeatures = 0;
@@ -326,7 +329,7 @@
++nFeatures;
#endif
- LineBuffer* lb = LineBufferPool::NewLineBuffer(&m_lbPool, 8, FdoDimensionality_Z, ignoreZ);
+ LineBuffer* lb = LineBufferPool::NewLineBuffer(&m_lbPool, 8, Dimensionality_Z, ignoreZ);
if (!lb)
continue;
@@ -364,7 +367,7 @@
for (int i=0; i<ftsc->GetCount(); ++i)
MdfModel::FeatureTypeStyle* fts = ftsc->GetAt(i);
- adapter->Stylize(renderer, features, initialPass, exec, lb, fts, lrTip, lrUrl, elevSettings);
+ adapter->Stylize(renderer, features, initialPass, exec.get(), lb, fts, lrTip, lrUrl, elevSettings);
@@ -383,6 +386,7 @@
void DefaultStylizer::StylizeGridLayer(MdfModel::GridLayerDefinition* layer,
Renderer* renderer,
CSysTransformer* layer2mapxformer,
double mapScale,
@@ -409,7 +413,7 @@
renderer->SetBufferPool(&m_lbPool);
// find the FeatureTypeStyle
MdfModel::GridColorStyle* gcs = range->GetColorStyle();
@@ -428,7 +432,7 @@
// at this point raster is in the raster layer's cs
if (m_pRasterAdapter)
- m_pRasterAdapter->Stylize(renderer, features, true, exec, raster, gcs, gss, NULL, NULL, NULL, layer2mapxformer);
+ m_pRasterAdapter->Stylize(renderer, features, true, exec.get(), raster, gcs, gss, NULL, NULL, NULL, layer2mapxformer);
// need to free returned raster
delete raster;
@@ -466,7 +470,7 @@
// WARNING: given pointer to the new stylizer will be destroyed
// by the stylizer (in its destructor)
-void DefaultStylizer::SetGeometryAdapter(FdoGeometryType type, GeometryAdapter* stylizer)
+void DefaultStylizer::SetGeometryAdapter(GeometryType type, GeometryAdapter* stylizer)
GeometryAdapter* old = (GeometryAdapter*)m_hGeomStylizers[type];
delete old;
@@ -487,35 +491,35 @@
// otherwise need to create one based on the geometry type
switch (geomType)
- case FdoGeometryType_LineString:
- m_hGeomStylizers[FdoGeometryType_LineString] = new PolylineAdapter(&m_lbPool);
+ case GeometryType_LineString:
+ m_hGeomStylizers[GeometryType_LineString] = new PolylineAdapter(&m_lbPool);
break;
- case FdoGeometryType_MultiLineString:
- m_hGeomStylizers[FdoGeometryType_MultiLineString] = new PolylineAdapter(&m_lbPool);
+ case GeometryType_MultiLineString:
+ m_hGeomStylizers[GeometryType_MultiLineString] = new PolylineAdapter(&m_lbPool);
break;
- case FdoGeometryType_CurveString:
- m_hGeomStylizers[FdoGeometryType_CurveString] = new PolylineAdapter(&m_lbPool);
+ case GeometryType_CurveString:
+ m_hGeomStylizers[GeometryType_CurveString] = new PolylineAdapter(&m_lbPool);
break;
- case FdoGeometryType_MultiCurveString:
- m_hGeomStylizers[FdoGeometryType_MultiCurveString] = new PolylineAdapter(&m_lbPool);
+ case GeometryType_MultiCurveString:
+ m_hGeomStylizers[GeometryType_MultiCurveString] = new PolylineAdapter(&m_lbPool);
break;
- case FdoGeometryType_Polygon:
- m_hGeomStylizers[FdoGeometryType_Polygon] = new PolygonAdapter(&m_lbPool);
+ case GeometryType_Polygon:
+ m_hGeomStylizers[GeometryType_Polygon] = new PolygonAdapter(&m_lbPool);
break;
- case FdoGeometryType_MultiPolygon:
- m_hGeomStylizers[FdoGeometryType_MultiPolygon] = new PolygonAdapter(&m_lbPool);
+ case GeometryType_MultiPolygon:
+ m_hGeomStylizers[GeometryType_MultiPolygon] = new PolygonAdapter(&m_lbPool);
break;
- case FdoGeometryType_CurvePolygon:
- m_hGeomStylizers[FdoGeometryType_CurvePolygon] = new PolygonAdapter(&m_lbPool);
+ case GeometryType_CurvePolygon:
+ m_hGeomStylizers[GeometryType_CurvePolygon] = new PolygonAdapter(&m_lbPool);
break;
- case FdoGeometryType_MultiCurvePolygon:
- m_hGeomStylizers[FdoGeometryType_MultiCurvePolygon] = new PolygonAdapter(&m_lbPool);
+ case GeometryType_MultiCurvePolygon:
+ m_hGeomStylizers[GeometryType_MultiCurvePolygon] = new PolygonAdapter(&m_lbPool);
break;
- case FdoGeometryType_Point:
- m_hGeomStylizers[FdoGeometryType_Point] = new PointAdapter(&m_lbPool);
+ case GeometryType_Point:
+ m_hGeomStylizers[GeometryType_Point] = new PointAdapter(&m_lbPool);
break;
- case FdoGeometryType_MultiPoint:
- m_hGeomStylizers[FdoGeometryType_MultiPoint] = new PointAdapter(&m_lbPool);
+ case GeometryType_MultiPoint:
+ m_hGeomStylizers[GeometryType_MultiPoint] = new PointAdapter(&m_lbPool);
break;
default :
break;
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/DefaultStylizer.h
--- sandbox/jng/common_decouple_v3/Common/Stylization/DefaultStylizer.h 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/DefaultStylizer.h 2019-02-05 13:44:22 UTC (rev 9475)
@@ -40,6 +40,7 @@
STYLIZATION_API virtual void StylizeVectorLayer(MdfModel::VectorLayerDefinition* layer,
Renderer* renderer,
double mapScale,
@@ -48,6 +49,7 @@
STYLIZATION_API virtual void StylizeGridLayer(MdfModel::GridLayerDefinition* layer,
Renderer* renderer,
double mapScale,
@@ -61,12 +63,13 @@
STYLIZATION_API virtual void StylizeWatermark(Renderer* renderer,
int drawWidth,
int drawHeight,
int saveWidth,
int saveHeight);
- STYLIZATION_API virtual void SetGeometryAdapter(FdoGeometryType type, GeometryAdapter* stylizer);
+ STYLIZATION_API virtual void SetGeometryAdapter(GeometryType type, GeometryAdapter* stylizer);
STYLIZATION_API virtual bool HasValidScaleRange(MdfModel::VectorLayerDefinition* layer,
double mapScale);
@@ -78,6 +81,7 @@
Renderer* renderer,
bool initialPass,
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/ExpressionHelper.cpp
--- sandbox/jng/common_decouple_v3/Common/Stylization/ExpressionHelper.cpp 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/ExpressionHelper.cpp 2019-02-05 13:44:22 UTC (rev 9475)
@@ -35,11 +35,9 @@
#include "ExpressionFunctionLookup.h"
#include "ExpressionFunctionRange.h"
+#include "RS_FdoFeatureReader.h"
-#include "RS_FeatureReader.h"
const RS_String s_Empty(L"");
@@ -115,11 +113,13 @@
// defined by stylization.
FdoExpressionEngine* ExpressionHelper::GetExpressionEngine(Renderer* renderer, RS_FeatureReader* reader)
+ RS_FdoFeatureReader* frdr = dynamic_cast<RS_FdoFeatureReader*>(reader);
// get the user-defined functions
FdoPtr<FdoExpressionEngineFunctionCollection> userDefinedFunctions = ExpressionHelper::GetExpressionEngineFunctions(renderer, reader);
// create the engine
- FdoPtr<FdoIFeatureReader> fdoReader = reader? reader->GetInternalReader() : NULL;
+ FdoPtr<FdoIFeatureReader> fdoReader = frdr ? frdr->GetInternalReader() : NULL;
FdoPtr<FdoClassDefinition> classDef = fdoReader? fdoReader->GetClassDefinition() : FdoClass::Create();
FdoExpressionEngine* exec = FdoExpressionEngine::Create(fdoReader, classDef, userDefinedFunctions);
Copied: sandbox/jng/common_decouple_v3/Common/Stylization/FdoExpressionEvaluator.cpp (from rev 9358, sandbox/jng/common_decouple_v2/Common/Stylization/FdoExpressionEvaluator.cpp)
--- sandbox/jng/common_decouple_v3/Common/Stylization/FdoExpressionEvaluator.cpp (rev 0)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/FdoExpressionEvaluator.cpp 2019-02-05 13:44:22 UTC (rev 9475)
@@ -0,0 +1,436 @@
+// Copyright (C) 2007-2018 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#include "Stylization.h"
+#include "RendererStyles.h"
+#include "ExpressionHelper.h"
+#include "FdoExpressionEvaluator.h"
+FdoExpressionEvaluator::FdoExpressionEvaluator(Renderer * renderer, RS_FeatureReader * reader)
+ m_exec = ExpressionHelper::GetExpressionEngine(renderer, reader);
+FdoExpressionEvaluator::~FdoExpressionEvaluator()
+ // free up cached fdo filters
+ for (std::map<const void*, FdoFilter*>::iterator iter = m_hFilterCache.begin();
+ iter != m_hFilterCache.end(); ++iter)
+ if (iter->second)
+ iter->second->Release();
+ m_hFilterCache.clear();
+ // free up cached fdo expressions
+ for (std::map<const void*, FdoExpression*>::iterator iter = m_hExpressionCache.begin();
+ iter != m_hExpressionCache.end(); ++iter)
+ if (iter->second)
+ m_hExpressionCache.clear();
+ m_exec = NULL;
+bool FdoExpressionEvaluator::EvalInt32(const MdfModel::MdfString& exprstr, int& res, bool bSuppressErrors)
+ // darn, it must be an expression, so evaluate it
+ if (!m_exec)
+ // hmmm... we can't eval as expression, what to do?
+ _ASSERT(false);
+ return false;
+ FdoExpression* expr = ObtainFdoExpression(&exprstr);
+ // make sure we have a parsed expression
+ if (!expr)
+ _ASSERT(false);
+ return false;
+ try
+ FdoPtr<FdoLiteralValue> lval = m_exec->Evaluate(expr);
+ res = ExpressionHelper::GetAsInt32(lval.p);
+ return true;
+ catch (FdoException* e)
+ if (bSuppressErrors)
+ e->Release();
+ else
+ ProcessStylizerException(e, __LINE__, __WFILE__);
+ catch (...)
+ return false;
+bool FdoExpressionEvaluator::EvalBoolean(const MdfModel::MdfString& exprstr, bool& res, bool bSuppressErrors)
+ // check for boolean constants first...
+ const wchar_t* sb = exprstr.c_str();
+ if (_wcsnicmp(sb, L"true", 5) == 0)
+ // value was constant, return true
+ res = true;
+ return true;
+ if (_wcsnicmp(sb, L"false", 6) == 0)
+ res = false;
+ return true;
+ if (!m_exec)
+ _ASSERT(false);
+ return false;
+ if (!expr)
+ _ASSERT(false);
+ return false;
+ // and then hope evaluation succeeds
+ try
+ res = ExpressionHelper::GetAsBoolean(lval.p);
+ e->Release();
+ else
+ catch (...)
+ // value was expression, so not cacheable
+ return false;
+bool FdoExpressionEvaluator::EvalDouble(const MdfModel::MdfString& exprstr, double& res, bool bSuppressErrors)
+ // TODO: needs an expression processor argument to eval expressions
+ const wchar_t* sd = exprstr.c_str();
+ double d = 0.0;
+ // We will look if there is any other stuff behind any numeric data in
+ // order to detect if we are dealing with just a number or an expression.
+ // For example "100 + stuff" would successfully parse a number, yet it
+ // is not just a number.
+ wchar_t* tmp = (wchar_t*)alloca((wcslen(sd)+1)*sizeof(wchar_t));
+ *tmp = L'\0';
+ int status = swscanf(sd, L"%lf%s", &d, tmp);
+ if (status == 1 || (status && !wcslen(tmp)))
+ // value is constant
+ res = d;
+ return true;
+ // try to evaluate as expression if it was not constant
+ if (!m_exec)
+ _ASSERT(false);
+ return false;
+ if (!expr)
+ _ASSERT(false);
+ return false;
+ try
+ res = ExpressionHelper::GetAsDouble(lval.p);
+ e->Release();
+ else
+ catch (...)
+ // if we are here, the value was not constant so it is not cacheable
+ return false;
+bool FdoExpressionEvaluator::EvalString(const MdfModel::MdfString& exprstr, RS_String& res, bool bSuppressErrors)
+ if (!m_exec)
+ // no execution engine... spit the string back out
+ _ASSERT(false);
+ res = exprstr;
+ return false;
+ // TODO: need a scheme to check if a string is a constant expression
+ // so that we can cache it instead of evaluating every time
+ if (!expr)
+ // this should not happen...
+ res = exprstr;
+ return false;
+ // try-catch the expression evaluation - I think we want
+ // a silent failure here...
+ try
+ const wchar_t* str = ExpressionHelper::GetAsString(lval.p);
+ res = str? str : L"";
+ e->Release();
+ else
+ catch (...)
+ // not cacheable
+ return false;
+bool FdoExpressionEvaluator::EvalColor(const MdfModel::MdfString& exprstr, RS_Color& rscolor, bool bSuppressErrors)
+ // string is in the form "AARRGGBB"
+ const wchar_t* scolor = exprstr.c_str();
+ size_t len = wcslen(scolor);
+ unsigned int color = 0;
+ bool isConst = false;
+ // try to check if the expression is constant
+ int status = 0;
+ if (len == 0)
+ // error or a color was not set
+ // use transparent black which indicates "not set"
+ rscolor = RS_Color(RS_Color::EMPTY_COLOR_RGBA);
+ return true;
+ else if (len == 8)
+ status = swscanf(scolor, L"%8X", &color);
+ else if (len == 6)
+ status = swscanf(scolor, L"%6X", &color);
+ // there was no alpha specified in the constant string, add it
+ color |= 0xFF000000;
+ if (status != 1)
+ // if not constant try to evaluate as expression
+ if (!m_exec)
+ _ASSERT(false);
+ rscolor = RS_Color(0x000000FF);
+ return true;
+ if (!expr)
+ _ASSERT(false);
+ return false;
+ try
+ color = (unsigned int)ExpressionHelper::GetAsInt32(lval.p);
+ e->Release();
+ else
+ return false;
+ catch (...)
+ return false;
+ else
+ isConst = true;
+ rscolor.alpha() = color >> 24;
+ rscolor.red() = (color >> 16) & 0xFF;
+ rscolor.green() = (color >> 8) & 0xFF;
+ rscolor.blue() = color & 0xFF;
+ return isConst;
+bool FdoExpressionEvaluator::ExecFilter(const MdfModel::MdfString* pExprstr, bool bSuppressErrors)
+ // TODO: we use pointers to the MDF strings for caching -
+ // this may be risky but all caching in the stylizer is
+ // based on the MDF pointer staying the same throughout the
+ // stylization process
+ // empty expression - no filter
+ // pass trivially
+ if (pExprstr->empty())
+ return true;
+ // get from cache
+ FdoFilter* filter = m_hFilterCache[pExprstr];
+ // if in cache, return existing
+ // NOTE: do not addref, it is not needed
+ if (!filter)
+ try
+ // otherwise parse and cache it
+ filter = FdoFilter::Parse(pExprstr->c_str());
+ m_hFilterCache[pExprstr] = filter;
+ e->Release();
+ else
+ filter = NULL;
+ // no filter means pass in this case
+ if (!filter)
+ return true;
+ // m_exec should be set in the Stylize call
+ // of the inheriting geometry adapter
+ _ASSERT(m_exec);
+ bool res = false;
+ try
+ res = m_exec->ProcessFilter(filter);
+ e->Release();
+ else
+ return res;
+void FdoExpressionEvaluator::ProcessStylizerException(FdoException* exception, int line, wchar_t* file)
+// parses and caches an FDO filter from a pointer to an MDF string.
+// Once cached, the filter will be reused next time the same expression
+// is asked for.
+FdoExpression* FdoExpressionEvaluator::ObtainFdoExpression(const MdfModel::MdfString* pExprstr)
+ return NULL;
+ // get from cache
+ FdoExpression* expr = m_hExpressionCache[pExprstr];
+ if (expr)
+ return expr;
+ try
+ expr = FdoExpression::Parse(pExprstr->c_str());
+ m_hExpressionCache[pExprstr] = expr;
+ expr = NULL;
+ return expr;
Copied: sandbox/jng/common_decouple_v3/Common/Stylization/FdoExpressionEvaluator.h (from rev 9358, sandbox/jng/common_decouple_v2/Common/Stylization/FdoExpressionEvaluator.h)
--- sandbox/jng/common_decouple_v3/Common/Stylization/FdoExpressionEvaluator.h (rev 0)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/FdoExpressionEvaluator.h 2019-02-05 13:44:22 UTC (rev 9475)
@@ -0,0 +1,47 @@
+#ifndef FDO_EXPRESSIONEVALUATOR_H_
+#define FDO_EXPRESSIONEVALUATOR_H_
+#include "Renderer.h"
+#include "SE_ExpressionEvaluator.h"
+class FdoExpressionEvaluator : public SE_ExpressionEvaluator
+public:
+ FdoExpressionEvaluator(Renderer* renderer, RS_FeatureReader* reader);
+ virtual ~FdoExpressionEvaluator();
+ STYLIZATION_API virtual bool EvalInt32(const MdfModel::MdfString& exprstr, int& res, bool bSuppressErrors);
+ STYLIZATION_API virtual bool EvalBoolean(const MdfModel::MdfString& exprstr, bool& res, bool bSuppressErrors);
+ STYLIZATION_API virtual bool EvalDouble(const MdfModel::MdfString& exprstr, double& res, bool bSuppressErrors);
+ STYLIZATION_API virtual bool EvalString(const MdfModel::MdfString& exprstr, RS_String& res, bool bSuppressErrors);
+ STYLIZATION_API virtual bool EvalColor(const MdfModel::MdfString& exprstr, RS_Color& color, bool bSuppressErrors);
+ STYLIZATION_API virtual bool ExecFilter(const MdfModel::MdfString* pExprstr, bool bSuppressErrors);
+private:
+ FdoExpression* ObtainFdoExpression(const MdfModel::MdfString* pExprstr);
+ void ProcessStylizerException(FdoException* exception, int line, wchar_t* file);
+ FdoPtr<FdoExpressionEngine> m_exec;
+ // FdoFilter cache
+ std::map<const void*, FdoFilter*> m_hFilterCache;
+ // FdoExpression cache
+ std::map<const void*, FdoExpression*> m_hExpressionCache;
+#endif
Copied: sandbox/jng/common_decouple_v3/Common/Stylization/FdoExpressionEvaluatorFactory.cpp (from rev 9358, sandbox/jng/common_decouple_v2/Common/Stylization/FdoExpressionEvaluatorFactory.cpp)
--- sandbox/jng/common_decouple_v3/Common/Stylization/FdoExpressionEvaluatorFactory.cpp (rev 0)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/FdoExpressionEvaluatorFactory.cpp 2019-02-05 13:44:22 UTC (rev 9475)
@@ -0,0 +1,23 @@
+#include "FdoExpressionEvaluatorFactory.h"
+STYLIZATION_API SE_ExpressionEvaluator * FdoExpressionEvaluatorFactory::CreateEvaluator(Renderer * renderer, RS_FeatureReader * reader)
+ return new FdoExpressionEvaluator(renderer, reader);
Copied: sandbox/jng/common_decouple_v3/Common/Stylization/FdoExpressionEvaluatorFactory.h (from rev 9358, sandbox/jng/common_decouple_v2/Common/Stylization/FdoExpressionEvaluatorFactory.h)
--- sandbox/jng/common_decouple_v3/Common/Stylization/FdoExpressionEvaluatorFactory.h (rev 0)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/FdoExpressionEvaluatorFactory.h 2019-02-05 13:44:22 UTC (rev 9475)
@@ -0,0 +1,29 @@
+#ifndef FDO_EXPRESSIONEVALUATORFACTORY_H_
+#define FDO_EXPRESSIONEVALUATORFACTORY_H_
+class FdoExpressionEvaluatorFactory : public SE_ExpressionEvaluatorFactory
+public:
+ STYLIZATION_API virtual SE_ExpressionEvaluator* CreateEvaluator(Renderer* renderer, RS_FeatureReader* reader);
+#endif
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/GeometryAdapter.cpp
--- sandbox/jng/common_decouple_v3/Common/Stylization/GeometryAdapter.cpp 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/GeometryAdapter.cpp 2019-02-05 13:44:22 UTC (rev 9475)
@@ -21,8 +21,8 @@
#include "SymbolVisitor.h"
#include "SLDSymbols.h"
extern void ProcessStylizerException(FdoException* exception, int line, wchar_t* file);
@@ -86,31 +86,8 @@
return false;
- FdoExpression* expr = ObtainFdoExpression(&exprstr);
- // make sure we have a parsed expression
- if (!expr)
- _ASSERT(false);
- return false;
- try
- FdoPtr<FdoLiteralValue> lval = m_exec->Evaluate(expr);
- res = ExpressionHelper::GetAsBoolean(lval.p);
- catch (FdoException* e)
- ProcessStylizerException(e, __LINE__, __WFILE__);
- catch (...)
- // value was expression, so not cacheable
- return false;
+ return m_exec->EvalBoolean(exprstr, res);
@@ -146,31 +123,8 @@
return false;
- if (!expr)
- _ASSERT(false);
- return false;
- try
- res = ExpressionHelper::GetAsDouble(lval.p);
- catch (...)
- // if we are here, the value was not constant so it is not cacheable
- return false;
+ return m_exec->EvalDouble(exprstr, res);
@@ -187,33 +141,7 @@
- if (!expr)
- // this should not happen...
- res = exprstr;
- return false;
- // try-catch the expression evaluation - I think we want
- // a silent failure here...
- try
- const wchar_t* str = ExpressionHelper::GetAsString(lval.p);
- res = str? str : L"";
- catch (...)
- // not cacheable
- return false;
+ return m_exec->EvalString(exprstr, res);
@@ -260,31 +188,7 @@
return true;
- if (!expr)
- _ASSERT(false);
- rscolor = RS_Color(0x000000FF);
- return false;
- try
- color = (unsigned int)ExpressionHelper::GetAsInt32(lval.p);
- return false;
- catch (...)
- return false;
+ return m_exec->EvalColor(exprstr, rscolor);
else
@@ -679,7 +583,7 @@
void GeometryAdapter::Stylize(Renderer* /*renderer*/,
RS_FeatureReader* /*features*/,
bool /*initialPass*/,
- FdoExpressionEngine* /*exec*/,
+ SE_ExpressionEvaluator* /*exec*/,
LineBuffer* /*lb*/,
MdfModel::FeatureTypeStyle* /*style*/,
const MdfModel::MdfString* /*tooltip*/,
@@ -721,7 +625,7 @@
// Parses and caches an FDO filter from a pointer to an MDF string.
// is asked for. Also executes the filter and returns failure or success.
-bool GeometryAdapter::ExecFdoFilter(const MdfModel::MdfString* pExprstr)
+bool GeometryAdapter::ExecFilter(const MdfModel::MdfString* pExprstr)
@@ -733,88 +637,14 @@
return true;
- // get from cache
- FdoFilter* filter = m_hFilterCache[pExprstr];
- // if in cache, return existing
- // NOTE: do not addref, it is not needed
- if (!filter)
- try
- // otherwise parse and cache it
- filter = FdoFilter::Parse(pExprstr->c_str());
- m_hFilterCache[pExprstr] = filter;
- filter = NULL;
- // no filter means pass in this case
- if (!filter)
- return true;
_ASSERT(m_exec);
- bool res = false;
- try
- res = m_exec->ProcessFilter(filter);
- return res;
+ return m_exec->ExecFilter(pExprstr);
-// parses and caches an FDO filter from a pointer to an MDF string.
-// Once cached, the filter will be reused next time the same expression
-// is asked for.
-FdoExpression* GeometryAdapter::ObtainFdoExpression(const MdfModel::MdfString* pExprstr)
- // TODO: we use pointers to the MDF strings for caching -
- // this may be risky but all caching in the stylizer is
- // based on the MDF pointer staying the same throughout the
- // stylization process
- // empty expression - no filter
- if (pExprstr->empty())
- return NULL;
- // get from cache
- FdoExpression* expr = m_hExpressionCache[pExprstr];
- if (expr)
- return expr;
- try
- expr = FdoExpression::Parse(pExprstr->c_str());
- m_hExpressionCache[pExprstr] = expr;
- expr = NULL;
- return expr;
bool GeometryAdapter::GetElevationParams(RS_ElevationSettings* elevSettings,
double& zOffset, double& zExtrusion,
RS_ElevationType& elevType)
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/GeometryAdapter.h
--- sandbox/jng/common_decouple_v3/Common/Stylization/GeometryAdapter.h 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/GeometryAdapter.h 2019-02-05 13:44:22 UTC (rev 9475)
@@ -22,6 +22,7 @@
+class SE_ExpressionEvaluator;
class LineBuffer;
class LineBufferPool;
@@ -60,7 +61,7 @@
STYLIZATION_API virtual void Stylize(Renderer* renderer,
bool initialPass,
- FdoExpressionEngine* exec,
+ SE_ExpressionEvaluator* exec,
LineBuffer* lb,
MdfModel::FeatureTypeStyle* style,
const MdfModel::MdfString* tooltip = NULL,
@@ -78,8 +79,7 @@
Renderer* renderer,
LineBuffer* lb);
- STYLIZATION_API bool ExecFdoFilter(const MdfModel::MdfString* pExprstr);
- STYLIZATION_API FdoExpression* ObtainFdoExpression(const MdfModel::MdfString* pExprstr);
+ STYLIZATION_API bool ExecFilter(const MdfModel::MdfString* pExprstr);
protected:
STYLIZATION_API bool GetElevationParams(RS_ElevationSettings* elevationSettings,
@@ -88,7 +88,7 @@
double GetClipOffset(RS_LineStroke& lineStroke, double mapScale);
- FdoExpressionEngine* m_exec;
+ SE_ExpressionEvaluator* m_exec;
LineBufferPool* m_lbPool;
// BOGUS:
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/LabelRendererLocal.cpp
--- sandbox/jng/common_decouple_v3/Common/Stylization/LabelRendererLocal.cpp 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/LabelRendererLocal.cpp 2019-02-05 13:44:22 UTC (rev 9475)
@@ -95,11 +95,11 @@
BeginOverpostGroup(type, true, exclude);
// get the geometry type
- int geomType = (path != NULL)? path->geom_type() : FdoGeometryType_None;
+ int geomType = (path != NULL)? path->geom_type() : GeometryType_None;
// in the case of linear geometry we'll label along the path, so prepare
// for that (transform to screen space, group into stitch groups)
- if (geomType == FdoGeometryType_LineString || geomType == FdoGeometryType_MultiLineString)
+ if (geomType == GeometryType_LineString || geomType == GeometryType_MultiLineString)
// indicate that the current group will be labeled along the path
m_labelGroups.back().m_algo = laCurve;
@@ -177,7 +177,7 @@
offset += lblpathpts;
- else if (geomType == FdoGeometryType_Polygon || geomType == FdoGeometryType_MultiPolygon)
+ else if (geomType == GeometryType_Polygon || geomType == GeometryType_MultiPolygon)
// we only expect one label info per polygon to be passed in from stylization
_ASSERT(nlabels == 1);
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/LineBuffer.h
--- sandbox/jng/common_decouple_v3/Common/Stylization/LineBuffer.h 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/LineBuffer.h 2019-02-05 13:44:22 UTC (rev 9475)
@@ -86,43 +86,6 @@
ctAGF = 4
- //Matches the FGF enumeration FdoDimensionality
- enum Dimensionality
- /// X and Y dimensions are present.
- Dimensionality_XY = 0,
- /// Z dimension is present.
- Dimensionality_Z = 1,
- /// M ('measure') dimension is present.
- Dimensionality_M = 2
- //Matches the FGF enumeration FdoGeometryType
- enum GeometryType
- GeometryType_None = 0,
- GeometryType_Point = 1,
- GeometryType_LineString = 2,
- GeometryType_Polygon = 3,
- GeometryType_MultiPoint = 4,
- GeometryType_MultiLineString = 5,
- GeometryType_MultiPolygon = 6,
- GeometryType_MultiGeometry = 7,
- GeometryType_CurveString = 10,
- GeometryType_CurvePolygon = 11,
- GeometryType_MultiCurveString = 12,
- GeometryType_MultiCurvePolygon = 13
- //Matches FdoGeometryComponentType
- enum GeometryComponentType
- GeometryComponentType_LinearRing = 129,
- GeometryComponentType_CircularArcSegment = 130,
- GeometryComponentType_LineStringSegment = 131,
- GeometryComponentType_Ring = 132
STYLIZATION_API LineBuffer(int size, int dimensionality = Dimensionality_XY, bool bIgnoreZ = true);
STYLIZATION_API virtual ~LineBuffer();
@@ -300,7 +263,7 @@
STYLIZATION_API LineBufferPool();
STYLIZATION_API virtual ~LineBufferPool();
- STYLIZATION_API static LineBuffer* NewLineBuffer(LineBufferPool* pool, int requestSize, int dimensionality = LineBuffer::Dimensionality_XY, bool bIgnoreZ = true);
+ STYLIZATION_API static LineBuffer* NewLineBuffer(LineBufferPool* pool, int requestSize, int dimensionality = Dimensionality_XY, bool bIgnoreZ = true);
STYLIZATION_API static void FreeLineBuffer(LineBufferPool* pool, LineBuffer* lb);
private:
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/PointAdapter.cpp
--- sandbox/jng/common_decouple_v3/Common/Stylization/PointAdapter.cpp 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/PointAdapter.cpp 2019-02-05 13:44:22 UTC (rev 9475)
@@ -20,8 +20,8 @@
#include "PointAdapter.h"
#include "LineBuffer.h"
PointAdapter::PointAdapter(LineBufferPool* lbp) : GeometryAdapter(lbp)
@@ -46,7 +46,7 @@
void PointAdapter::Stylize(Renderer* renderer,
bool initialPass,
LineBuffer* geometry,
const MdfModel::MdfString* tooltip,
@@ -72,7 +72,7 @@
rule = static_cast<MdfModel::PointRule*>(prc->GetAt(i));
// apply any filter on the rule - if it fails move to the next rule
- if (!ExecFdoFilter(&rule->GetFilter()))
+ if (!ExecFilter(&rule->GetFilter()))
// don't stylize with failed rule
rule = NULL;
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/PointAdapter.h
--- sandbox/jng/common_decouple_v3/Common/Stylization/PointAdapter.h 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/PointAdapter.h 2019-02-05 13:44:22 UTC (rev 9475)
@@ -29,7 +29,7 @@
bool initialPass,
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/PolygonAdapter.cpp
--- sandbox/jng/common_decouple_v3/Common/Stylization/PolygonAdapter.cpp 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/PolygonAdapter.cpp 2019-02-05 13:44:22 UTC (rev 9475)
@@ -20,8 +20,8 @@
#include "PolygonAdapter.h"
PolygonAdapter::PolygonAdapter(LineBufferPool* lbp) : GeometryAdapter(lbp)
@@ -46,7 +46,7 @@
void PolygonAdapter::Stylize(Renderer* renderer,
bool initialPass,
@@ -72,7 +72,7 @@
rule = static_cast<MdfModel::AreaRule*>(arc->GetAt(i));
rule = NULL;
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/PolygonAdapter.h
--- sandbox/jng/common_decouple_v3/Common/Stylization/PolygonAdapter.h 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/PolygonAdapter.h 2019-02-05 13:44:22 UTC (rev 9475)
@@ -29,7 +29,7 @@
bool initialPass,
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/PolylineAdapter.cpp
--- sandbox/jng/common_decouple_v3/Common/Stylization/PolylineAdapter.cpp 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/PolylineAdapter.cpp 2019-02-05 13:44:22 UTC (rev 9475)
@@ -54,7 +54,7 @@
void PolylineAdapter::Stylize(Renderer* renderer,
bool initialPass,
@@ -80,7 +80,7 @@
rule = static_cast<MdfModel::LineRule*>(lrc->GetAt(i));
rule = NULL;
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/PolylineAdapter.h
--- sandbox/jng/common_decouple_v3/Common/Stylization/PolylineAdapter.h 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/PolylineAdapter.h 2019-02-05 13:44:22 UTC (rev 9475)
@@ -29,7 +29,7 @@
bool initialPass,
Copied: sandbox/jng/common_decouple_v3/Common/Stylization/RS_FdoFeatureReader.h (from rev 9358, sandbox/jng/common_decouple_v2/Common/Stylization/RS_FdoFeatureReader.h)
--- sandbox/jng/common_decouple_v3/Common/Stylization/RS_FdoFeatureReader.h (rev 0)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/RS_FdoFeatureReader.h 2019-02-05 13:44:22 UTC (rev 9475)
@@ -0,0 +1,29 @@
+// Copyright (C) 2004-2018 by Autodesk, Inc.
+#ifndef RS_FDO_FEATURE_READER_H_
+#define RS_FDO_FEATURE_READER_H_
+#include "RS_FeatureReader.h"
+// Defines a feature data reader interface with access to the internal FDO feature reader
+class RS_FdoFeatureReader : public RS_FeatureReader
+public:
+ virtual FdoIFeatureReader* GetInternalReader() = 0;
+#endif
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/RS_FeatureReader.h
--- sandbox/jng/common_decouple_v3/Common/Stylization/RS_FeatureReader.h 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/RS_FeatureReader.h 2019-02-05 13:44:22 UTC (rev 9475)
@@ -21,7 +21,7 @@
#include "CSysTransformer.h"
#include "RS_Raster.h"
-#include <Fdo.h>
+#include "RS_Types.h"
// Defines a feature data reader interface.
class RS_FeatureReader
@@ -33,13 +33,13 @@
virtual bool IsNull (const wchar_t* propertyName) = 0;
virtual bool GetBoolean (const wchar_t* propertyName) = 0;
- virtual FdoInt8 GetByte (const wchar_t* propertyName) = 0;
- virtual FdoDateTime GetDateTime (const wchar_t* propertyName) = 0;
+ virtual RS_Int8 GetByte (const wchar_t* propertyName) = 0;
+ virtual RS_DateTime GetDateTime (const wchar_t* propertyName) = 0;
virtual float GetSingle (const wchar_t* propertyName) = 0;
virtual double GetDouble (const wchar_t* propertyName) = 0;
- virtual FdoInt16 GetInt16 (const wchar_t* propertyName) = 0;
- virtual FdoInt32 GetInt32 (const wchar_t* propertyName) = 0;
- virtual FdoInt64 GetInt64 (const wchar_t* propertyName) = 0;
+ virtual RS_Int16 GetInt16 (const wchar_t* propertyName) = 0;
+ virtual RS_Int32 GetInt32 (const wchar_t* propertyName) = 0;
+ virtual RS_Int64 GetInt64 (const wchar_t* propertyName) = 0;
virtual const wchar_t* GetString (const wchar_t* propertyName) = 0;
virtual LineBuffer* GetGeometry (const wchar_t* propertyName, LineBuffer* lb, CSysTransformer* xformer) = 0;
virtual RS_Raster* GetRaster (const wchar_t* propertyName) = 0;
@@ -52,8 +52,6 @@
virtual const wchar_t* GetRasterPropName() = 0;
virtual const wchar_t* const* GetIdentPropNames(int& count) = 0;
virtual const wchar_t* const* GetPropNames (int& count) = 0;
- virtual FdoIFeatureReader* GetInternalReader() = 0;
#endif
Copied: sandbox/jng/common_decouple_v3/Common/Stylization/RS_Types.h (from rev 9358, sandbox/jng/common_decouple_v2/Common/Stylization/RS_Types.h)
--- sandbox/jng/common_decouple_v3/Common/Stylization/RS_Types.h (rev 0)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/RS_Types.h 2019-02-05 13:44:22 UTC (rev 9475)
@@ -0,0 +1,28 @@
+#ifndef RS_TYPES_H_
+#define RS_TYPES_H_
+#include "Fdo.h"
+typedef FdoInt8 RS_Int8;
+typedef FdoInt16 RS_Int16;
+typedef FdoInt32 RS_Int32;
+typedef FdoInt64 RS_Int64;
+typedef FdoDateTime RS_DateTime;
+#endif
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/RasterAdapter.cpp
--- sandbox/jng/common_decouple_v3/Common/Stylization/RasterAdapter.cpp 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/RasterAdapter.cpp 2019-02-05 13:44:22 UTC (rev 9475)
@@ -22,6 +22,7 @@
#include "GridData.h"
#include "GridStylizer.h"
#include "TransformMesh.h"
RasterAdapter::RasterAdapter(LineBufferPool* lbp) : GeometryAdapter(lbp)
@@ -42,7 +43,7 @@
void RasterAdapter::Stylize(Renderer* renderer,
bool initialPass,
RS_Raster* raster,
MdfModel::GridColorStyle* style,
MdfModel::GridSurfaceStyle* surfStyle,
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/RasterAdapter.h
--- sandbox/jng/common_decouple_v3/Common/Stylization/RasterAdapter.h 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/RasterAdapter.h 2019-02-05 13:44:22 UTC (rev 9475)
@@ -20,6 +20,7 @@
#include "GeometryAdapter.h"
class GridData;
class GridStylizer;
@@ -32,7 +33,7 @@
bool initialPass,
RS_Raster* raster,
MdfModel::GridSurfaceStyle* surfStyle = NULL,
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/SE_ExpressionBase.cpp
--- sandbox/jng/common_decouple_v3/Common/Stylization/SE_ExpressionBase.cpp 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/SE_ExpressionBase.cpp 2019-02-05 13:44:22 UTC (rev 9475)
@@ -134,7 +134,7 @@
void SE_ExpressionBase::ParseColorExpression(const MdfModel::MdfString& exprstr, SE_Color& val, unsigned int defaultValue)
// set to schema default
- val.expression = NULL;
+ val.expression = L"";
val.defValue.argb = defaultValue;
// process any parameters in the expression
@@ -169,16 +169,7 @@
return;
- // We have an expression - parse it using FDO. If the parse
- // call fails then the value stays at the default.
- try
- val.expression = FdoExpression::Parse(cstr);
+ val.expression = cstr;
@@ -185,7 +176,7 @@
void SE_ExpressionBase::ParseDoubleExpression(const MdfModel::MdfString& exprstr, SE_Double& val, const double defaultValue)
val.defValue = defaultValue;
@@ -220,16 +211,7 @@
return;
- try
@@ -236,7 +218,7 @@
void SE_ExpressionBase::ParseIntegerExpression(const MdfModel::MdfString& exprstr, SE_Integer& val, const int defaultValue)
@@ -271,16 +253,7 @@
return;
- try
@@ -287,7 +260,7 @@
void SE_ExpressionBase::ParseBooleanExpression(const MdfModel::MdfString& exprstr, SE_Boolean& val, const bool defaultValue)
@@ -322,16 +295,7 @@
return;
- try
@@ -390,7 +354,7 @@
void SE_ExpressionBase::ParseStringExpression(const MdfModel::MdfString& exprstr, SE_String& val, const wchar_t* defaultValue, const wchar_t* allowedValues)
// set to default - we set the value later on
const wchar_t* defValue = ReplaceParameters(exprstr);
@@ -424,14 +388,5 @@
return;
- try
- val.expression = FdoExpression::Parse(str);
+ val.expression = str;
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/SE_ExpressionBase.h
--- sandbox/jng/common_decouple_v3/Common/Stylization/SE_ExpressionBase.h 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/SE_ExpressionBase.h 2019-02-05 13:44:22 UTC (rev 9475)
@@ -19,7 +19,7 @@
#define SE_EXPRESSIONBASE_H_
#include <map>
#include <string>
@@ -56,26 +56,22 @@
unsigned int argb;
} value; //g++ doesn't like nameless structs, otherwise things would be far cleaner
- FdoExpression* expression;
+ MdfModel::MdfString expression;
- SE_INLINE SE_Color() : expression(NULL) { defValue.argb = 0; value.argb = 0; }
- ~SE_Color() { if (expression) expression->Release(); }
+ SE_INLINE SE_Color() { defValue.argb = 0; value.argb = 0; }
+ ~SE_Color() { }
// Retrieve argb color
- SE_INLINE unsigned int evaluate(FdoExpressionEngine* exec)
+ SE_INLINE unsigned int evaluate(SE_ExpressionEvaluator* exec)
- if (expression)
+ if (!expression.empty())
- value.argb = defValue.argb;
- try
- FdoPtr<FdoLiteralValue> lval = exec->Evaluate(expression);
- value.argb = (unsigned int)ExpressionHelper::GetAsInt32(lval.p);
+ RS_Color color = RS_Color::FromARGB(defValue.argb);
+ exec->EvalColor(expression, color);
+ value.argb = color.argb();
- e->Release();
// return the value
@@ -84,7 +80,7 @@
SE_INLINE bool empty()
- return defValue.argb == 0 && value.argb == 0 && expression == NULL;
+ return defValue.argb == 0 && value.argb == 0 && expression.empty();
SE_INLINE void operator=(SE_Color& c)
@@ -91,7 +87,7 @@
defValue.argb = c.defValue.argb;
value.argb = c.value.argb;
- expression = FDO_SAFE_ADDREF(c.expression);
+ expression = c.expression;
@@ -101,25 +97,18 @@
double defValue;
double value;
- SE_INLINE SE_Double() : defValue(0.0), value(0.0), expression(NULL) { }
- ~SE_Double() { if (expression) expression->Release(); }
+ SE_INLINE SE_Double() : defValue(0.0), value(0.0) { }
+ ~SE_Double() { }
- SE_INLINE double evaluate(FdoExpressionEngine* exec)
+ SE_INLINE double evaluate(SE_ExpressionEvaluator* exec)
- if (expression)
- value = defValue;
- try
- value = ExpressionHelper::GetAsDouble(lval.p);
- e->Release();
+ double d = defValue;
+ exec->EvalDouble(expression, d);
+ value = d;
// return the value
@@ -130,7 +119,7 @@
defValue = d.defValue;
value = d.value;
- expression = FDO_SAFE_ADDREF(d.expression);
+ expression = d.expression;
@@ -140,25 +129,18 @@
int defValue;
int value;
- SE_INLINE SE_Integer() : defValue(0), value(0), expression(NULL) { }
- ~SE_Integer() { if (expression) expression->Release(); }
+ SE_INLINE SE_Integer() : defValue(0), value(0) { }
+ ~SE_Integer() { }
- SE_INLINE int evaluate(FdoExpressionEngine* exec)
+ SE_INLINE int evaluate(SE_ExpressionEvaluator* exec)
- if (expression)
- value = defValue;
- try
- value = ExpressionHelper::GetAsInt32(lval.p);
- e->Release();
+ int i = defValue;
+ exec->EvalInt32(expression, i);
+ value = i;
// return the value
@@ -169,7 +151,7 @@
defValue = i.defValue;
value = i.value;
- expression = FDO_SAFE_ADDREF(i.expression);
+ expression = i.expression;
@@ -179,25 +161,18 @@
bool defValue;
bool value;
- SE_INLINE SE_Boolean() : defValue(false), value(false), expression(NULL) { }
- ~SE_Boolean() { if (expression) expression->Release(); }
+ SE_INLINE SE_Boolean() : defValue(false), value(false) { }
+ ~SE_Boolean() { }
- SE_INLINE bool evaluate(FdoExpressionEngine* exec)
+ SE_INLINE bool evaluate(SE_ExpressionEvaluator* exec)
- if (expression)
- value = defValue;
- try
- value = ExpressionHelper::GetAsBoolean(lval.p);
- e->Release();
+ bool b = defValue;
+ exec->EvalBoolean(expression, b);
+ value = b;
// return the value
@@ -208,7 +183,7 @@
defValue = b.defValue;
value = b.value;
- expression = FDO_SAFE_ADDREF(b.expression);
+ expression = b.expression;
@@ -218,15 +193,13 @@
wchar_t* defValue;
wchar_t* value;
- SE_INLINE SE_String() : defValue(NULL), value(NULL), expression(NULL) { }
+ SE_INLINE SE_String() : defValue(NULL), value(NULL) { }
~SE_String()
delete[] value;
delete[] defValue;
- if (expression)
- expression->Release();
void setDefValue(wchar_t* newDefValue)
@@ -260,29 +233,23 @@
return sEmpty;
- SE_INLINE const wchar_t* evaluate(FdoExpressionEngine* exec)
+ SE_INLINE const wchar_t* evaluate(SE_ExpressionEvaluator* exec)
- if (expression)
delete[] value;
value = NULL;
- try
+ RS_String str;
+ exec->EvalString(expression, str);
+ if (!str.empty())
- const wchar_t* newValue = ExpressionHelper::GetAsString(lval.p);
- if (newValue)
- // the expression was successfully evaluated - update the value
- size_t len = wcslen(newValue) + 1;
- value = new wchar_t[len];
- wcscpy(value, newValue);
+ // the expression was successfully evaluated - update the value
+ size_t len = str.length() + 1;
+ value = new wchar_t[len];
+ const wchar_t* src = str.c_str();
+ wcscpy(value, src);
- e->Release();
// return the value
@@ -327,7 +294,7 @@
else
value = NULL;
- expression = FDO_SAFE_ADDREF(s.expression);
+ expression = s.expression;
Copied: sandbox/jng/common_decouple_v3/Common/Stylization/SE_ExpressionEvaluator.h (from rev 9358, sandbox/jng/common_decouple_v2/Common/Stylization/SE_ExpressionEvaluator.h)
--- sandbox/jng/common_decouple_v3/Common/Stylization/SE_ExpressionEvaluator.h (rev 0)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/SE_ExpressionEvaluator.h 2019-02-05 13:44:22 UTC (rev 9475)
@@ -0,0 +1,35 @@
+#ifndef SE_EXPRESSIONEVALUATOR_H_
+#define SE_EXPRESSIONEVALUATOR_H_
+public:
+ STYLIZATION_API virtual bool EvalInt32(const MdfModel::MdfString& exprstr, int& res, bool bSuppressErrors = false) = 0;
+ STYLIZATION_API virtual bool EvalBoolean(const MdfModel::MdfString& exprstr, bool& res, bool bSuppressErrors = false) = 0;
+ STYLIZATION_API virtual bool EvalDouble(const MdfModel::MdfString& exprstr, double& res, bool bSuppressErrors = false) = 0;
+ STYLIZATION_API virtual bool EvalString(const MdfModel::MdfString& exprstr, RS_String& res, bool bSuppressErrors = false) = 0;
+ STYLIZATION_API virtual bool EvalColor(const MdfModel::MdfString& exprstr, RS_Color& color, bool bSuppressErrors = false) = 0;
+ STYLIZATION_API virtual bool ExecFilter(const MdfModel::MdfString* pExprstr, bool bSuppressErrors = false) = 0;
+#endif
\ No newline at end of file
Copied: sandbox/jng/common_decouple_v3/Common/Stylization/SE_ExpressionEvaluatorFactory.h (from rev 9358, sandbox/jng/common_decouple_v2/Common/Stylization/SE_ExpressionEvaluatorFactory.h)
--- sandbox/jng/common_decouple_v3/Common/Stylization/SE_ExpressionEvaluatorFactory.h (rev 0)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/SE_ExpressionEvaluatorFactory.h 2019-02-05 13:44:22 UTC (rev 9475)
@@ -0,0 +1,33 @@
+#ifndef SE_EXPRESSIONEVALUATORFACTORY_H_
+#define SE_EXPRESSIONEVALUATORFACTORY_H_
+class Renderer;
+class RS_FeatureReader;
+class SE_ExpressionEvaluatorFactory
+public:
+ STYLIZATION_API virtual SE_ExpressionEvaluator* CreateEvaluator(Renderer* renderer, RS_FeatureReader* reader) = 0;
+#endif
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/SE_LineBuffer.cpp
--- sandbox/jng/common_decouple_v3/Common/Stylization/SE_LineBuffer.cpp 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/SE_LineBuffer.cpp 2019-02-05 13:44:22 UTC (rev 9475)
@@ -301,7 +301,7 @@
- m_xf_buf->SetGeometryType(LineBuffer::GeometryType_LineString);
+ m_xf_buf->SetGeometryType(GeometryType_LineString);
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/SE_LineRenderer.cpp
--- sandbox/jng/common_decouple_v3/Common/Stylization/SE_LineRenderer.cpp 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/SE_LineRenderer.cpp 2019-02-05 13:44:22 UTC (rev 9475)
@@ -269,7 +269,7 @@
SE_RenderPolyline* pl = (SE_RenderPolyline*)primitive;
// create the chopped up LineBuffer for this primitive
- choppedBuffers[cur_prim] = LineBufferPool::NewLineBuffer(lbp, 128, FdoDimensionality_XY, true);
+ choppedBuffers[cur_prim] = LineBufferPool::NewLineBuffer(lbp, 128, Dimensionality_XY, true);
ChopLineBuffer(pl->geometry->xf_buffer(), choppedBuffers[cur_prim]);
// update rendering attributes to account for the selection mode - it's
@@ -291,7 +291,7 @@
SE_RenderText* tp = (SE_RenderText*)primitive;
- choppedBuffers[cur_prim] = LineBufferPool::NewLineBuffer(lbp, 1, FdoDimensionality_XY, true);
+ choppedBuffers[cur_prim] = LineBufferPool::NewLineBuffer(lbp, 1, Dimensionality_XY, true);
choppedBuffers[cur_prim]->MoveTo(tp->position[0], tp->position[1]);
@@ -309,7 +309,7 @@
SE_RenderRaster* rp = (SE_RenderRaster*)primitive;
choppedBuffers[cur_prim]->MoveTo(rp->position[0], rp->position[1]);
// raster primitive don't have any rendering attributes that need to be
@@ -323,7 +323,7 @@
// this will be our work buffer
- LineBuffer geom(maxChoppedSize, FdoDimensionality_XY, true);
+ LineBuffer geom(maxChoppedSize, Dimensionality_XY, true);
// for each contour
for (int cur_contour=0; cur_contour<geometry->cntr_count(); ++cur_contour)
@@ -1643,7 +1643,7 @@
if (geometry.point_type(0) != (unsigned char)LineBuffer::stMoveTo)
return NULL;
- LineBuffer* ret = LineBufferPool::NewLineBuffer(lbp, geometry.point_count(), FdoDimensionality_XY, true);
+ LineBuffer* ret = LineBufferPool::NewLineBuffer(lbp, geometry.point_count(), Dimensionality_XY, true);
std::auto_ptr<LineBuffer> spRetLB(ret);
ret->SetGeometryType(geometry.geom_type());
@@ -1713,7 +1713,7 @@
return NULL;
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/SE_PositioningAlgorithms.cpp
--- sandbox/jng/common_decouple_v3/Common/Stylization/SE_PositioningAlgorithms.cpp 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/SE_PositioningAlgorithms.cpp 2019-02-05 13:44:22 UTC (rev 9475)
@@ -178,8 +178,8 @@
// eight surrounding labeling only applies to point feature geometry
switch (geometry->geom_type())
break;
default:
@@ -466,10 +466,10 @@
// path labeling only applies to linestring feature geometry
break;
default:
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/SE_Renderer.cpp
--- sandbox/jng/common_decouple_v3/Common/Stylization/SE_Renderer.cpp 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/SE_Renderer.cpp 2019-02-05 13:44:22 UTC (rev 9475)
@@ -201,10 +201,10 @@
switch (featGeom->geom_type())
double x0, y0;
featGeom->Centroid(LineBuffer::ctLine, &x0, &y0, &angleRad);
@@ -271,8 +271,8 @@
// can't apply a line style to point geometry types
return;
@@ -344,12 +344,12 @@
// can't apply an area style to point and linestring geometry types
return;
Property changes on: sandbox/jng/common_decouple_v3/Common/Stylization/SE_Renderer.cpp
___________________________________________________________________
Modified: svn:mergeinfo
## -1,6 +1,7 ##
/branches/2.4/MgDev/Common/Stylization/SE_Renderer.cpp:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/branches/2.6/MgDev/Common/Stylization/SE_Renderer.cpp:8340
/sandbox/adsk/2.4j/Common/Stylization/SE_Renderer.cpp:6327-6445
+/sandbox/jng/common_decouple_v2/Common/Stylization/SE_Renderer.cpp:9356-9358
/sandbox/jng/createruntimemap/Common/Stylization/SE_Renderer.cpp:7486-7555
/sandbox/rfc94/Common/Stylization/SE_Renderer.cpp:5099-5163
/trunk/MgDev/Common/Stylization/SE_Renderer.cpp:6250-6326
\ No newline at end of property
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/SE_StyleVisitor.cpp
--- sandbox/jng/common_decouple_v3/Common/Stylization/SE_StyleVisitor.cpp 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/SE_StyleVisitor.cpp 2019-02-05 13:44:22 UTC (rev 9475)
@@ -55,10 +55,10 @@
ParseDoubleExpression(pointUsage.GetOriginOffsetY(), style->originOffset[1], 0.0);
// set flag if all properties are constant
- style->cacheable = !(style->angleDeg.expression
- || style->angleControl.expression
- || style->originOffset[0].expression
- || style->originOffset[1].expression);
+ style->cacheable = !(!style->angleDeg.expression.empty()
+ || !style->angleControl.expression.empty()
+ || !style->originOffset[0].expression.empty()
+ || !style->originOffset[1].expression.empty());
return style;
@@ -95,22 +95,22 @@
- || style->unitsControl.expression
- || style->vertexControl.expression
- || style->startOffset.expression
- || style->endOffset.expression
- || style->repeat.expression
- || style->vertexAngleLimit.expression
- || style->vertexJoin.expression
- || style->vertexMiterLimit.expression
- || style->dpWeight.expression
- || style->dpColor.expression
- || style->dpWeightScalable.expression
- || style->dpCap.expression
- || style->dpJoin.expression
- || style->dpMiterLimit.expression);
+ || !style->unitsControl.expression.empty()
+ || !style->vertexControl.expression.empty()
+ || !style->startOffset.expression.empty()
+ || !style->endOffset.expression.empty()
+ || !style->repeat.expression.empty()
+ || !style->vertexAngleLimit.expression.empty()
+ || !style->vertexJoin.expression.empty()
+ || !style->vertexMiterLimit.expression.empty()
+ || !style->dpWeight.expression.empty()
+ || !style->dpColor.expression.empty()
+ || !style->dpWeightScalable.expression.empty()
+ || !style->dpCap.expression.empty()
+ || !style->dpJoin.expression.empty()
+ || !style->dpMiterLimit.expression.empty());
return style;
@@ -130,15 +130,15 @@
ParseDoubleExpression(areaUsage.GetBufferWidth(), style->bufferWidth, 0.0);
- || style->originControl.expression
- || style->clippingControl.expression
- || style->origin[0].expression
- || style->origin[1].expression
- || style->repeat[0].expression
- || style->repeat[1].expression
- || style->bufferWidth.expression);
+ || !style->originControl.expression.empty()
+ || !style->clippingControl.expression.empty()
+ || !style->origin[0].expression.empty()
+ || !style->origin[1].expression.empty()
+ || !style->repeat[0].expression.empty()
+ || !style->repeat[1].expression.empty()
+ || !style->bufferWidth.expression.empty());
return style;
@@ -667,15 +667,15 @@
if (primitive->color.value.argb == 0)
primitive->color.value.comps.a = 255;
- primitive->cacheable = !(primitive->weight.expression
- || primitive->color.expression
- || primitive->weightScalable.expression
- || primitive->cap.expression
- || primitive->join.expression
- || primitive->miterLimit.expression
- || primitive->resizeControl.expression
- || primitive->scaleX.expression
- || primitive->scaleY.expression);
+ primitive->cacheable = !(!primitive->weight.expression.empty()
+ || !primitive->color.expression.empty()
+ || !primitive->weightScalable.expression.empty()
+ || !primitive->cap.expression.empty()
+ || !primitive->join.expression.empty()
+ || !primitive->miterLimit.expression.empty()
+ || !primitive->resizeControl.expression.empty()
+ || !primitive->scaleX.expression.empty()
+ || !primitive->scaleY.expression.empty());
else
@@ -694,16 +694,16 @@
ParseDoubleExpression(path.GetScaleY(), primitive->scaleY, 1.0);
ParseStringExpression(path.GetResizeControl(), primitive->resizeControl, GraphicElement::sResizeControlDefault, GraphicElement::sResizeControlValues);
- || primitive->fill.expression
+ || !primitive->fill.expression.empty()
@@ -745,7 +745,7 @@
ParseStringExpression(image.GetResourceId(), primitive->pngResourceId, image.GetResourceId().c_str());
ParseStringExpression(image.GetLibraryItemName(), primitive->pngResourceName, image.GetLibraryItemName().c_str());
- if (primitive->pngResourceId.expression == NULL && primitive->pngResourceName.expression == NULL) // constant path
+ if (primitive->pngResourceId.expression.empty() && primitive->pngResourceName.expression.empty()) // constant path
// if we have non-empty resource ID then use it, otherwise
// use the ID of any parent symbol definition
@@ -771,13 +771,13 @@
ParseBooleanExpression(image.GetSizeScalable(), primitive->sizeScalable, true);
ParseStringExpression(image.GetResizeControl(), primitive->resizeControl, GraphicElement::sResizeControlDefault, GraphicElement::sResizeControlValues);
- primitive->cacheable = !(primitive->position[0].expression
- || primitive->position[1].expression
- || primitive->extent[0].expression
- || primitive->extent[1].expression
- || primitive->angleDeg.expression
- || primitive->sizeScalable.expression
- || primitive->resizeControl.expression)
+ primitive->cacheable = !(!primitive->position[0].expression.empty()
+ || !primitive->position[1].expression.empty()
+ || !primitive->extent[0].expression.empty()
+ || !primitive->extent[1].expression.empty()
+ || !primitive->angleDeg.expression.empty()
+ || !primitive->sizeScalable.expression.empty()
+ || !primitive->resizeControl.expression.empty())
&& primitive->imageData.data;
@@ -821,31 +821,31 @@
ParseDoubleExpression(frame->GetOffsetY(), primitive->frameOffset[1], 0.0);
- primitive->cacheable = !(primitive->content.expression
- || primitive->fontName.expression
- || primitive->height.expression
- || primitive->position[0].expression
- || primitive->lineSpacing.expression
- || primitive->heightScalable.expression
- || primitive->bold.expression
- || primitive->italic.expression
- || primitive->underlined.expression
- || primitive->overlined.expression
- || primitive->obliqueAngle.expression
- || primitive->trackSpacing.expression
- || primitive->hAlignment.expression
- || primitive->vAlignment.expression
- || primitive->justification.expression
- || primitive->textColor.expression
- || primitive->ghostColor.expression
- || primitive->frameLineColor.expression
- || primitive->frameFillColor.expression
- || primitive->frameOffset[0].expression
- || primitive->frameOffset[1].expression
- || primitive->markup.expression
- || primitive->resizeControl.expression);
+ primitive->cacheable = !(!primitive->content.expression.empty()
+ || !primitive->fontName.expression.empty()
+ || !primitive->height.expression.empty()
+ || !primitive->position[0].expression.empty()
+ || !primitive->lineSpacing.expression.empty()
+ || !primitive->heightScalable.expression.empty()
+ || !primitive->bold.expression.empty()
+ || !primitive->italic.expression.empty()
+ || !primitive->underlined.expression.empty()
+ || !primitive->overlined.expression.empty()
+ || !primitive->obliqueAngle.expression.empty()
+ || !primitive->trackSpacing.expression.empty()
+ || !primitive->hAlignment.expression.empty()
+ || !primitive->vAlignment.expression.empty()
+ || !primitive->justification.expression.empty()
+ || !primitive->textColor.expression.empty()
+ || !primitive->ghostColor.expression.empty()
+ || !primitive->frameLineColor.expression.empty()
+ || !primitive->frameFillColor.expression.empty()
+ || !primitive->frameOffset[0].expression.empty()
+ || !primitive->frameOffset[1].expression.empty()
+ || !primitive->markup.expression.empty()
+ || !primitive->resizeControl.expression.empty());
@@ -925,16 +925,16 @@
ParseDoubleExpression(box->GetPositionY(), m_style->resizePosition[1], 0.0);
ParseStringExpression(box->GetGrowControl(), m_style->growControl, ResizeBox::sGrowControlDefault, ResizeBox::sGrowControlValues);
- m_style->cacheable &= !(m_style->resizeSize[0].expression
- || m_style->resizeSize[1].expression
- || m_style->resizePosition[0].expression
- || m_style->resizePosition[1].expression
- || m_style->growControl.expression);
+ m_style->cacheable &= !(!m_style->resizeSize[0].expression.empty()
+ || !m_style->resizeSize[1].expression.empty()
+ || !m_style->resizePosition[0].expression.empty()
+ || !m_style->resizePosition[1].expression.empty()
+ || !m_style->growControl.expression.empty());
// the symbol instance scales also affect the evaluated style
- m_style->cacheable &= !(m_symbolInstance->scale[0].expression
- || m_symbolInstance->scale[1].expression);
+ m_style->cacheable &= !(!m_symbolInstance->scale[0].expression.empty()
+ || !m_symbolInstance->scale[1].expression.empty());
m_symbolInstance->styles.push_back(m_style);
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/SE_SymbolDefProxies.cpp
--- sandbox/jng/common_decouple_v3/Common/Stylization/SE_SymbolDefProxies.cpp 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/SE_SymbolDefProxies.cpp 2019-02-05 13:44:22 UTC (rev 9475)
@@ -340,8 +340,8 @@
ret->resizeControl = SE_ResizeControl_AdjustToResizeBox;
else // default is ResizeNone
ret->resizeControl = SE_ResizeControl_ResizeNone;
- if(NULL != content.expression)
- ret->expression = content.expression->ToString();
+ if (!content.expression.empty())
+ ret->expression = content.expression;
ret->content = contentStr;
ret->position[0] = position[0].evaluate(ctx->exec);
ret->position[1] = position[1].evaluate(ctx->exec);
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/SE_SymbolDefProxies.h
--- sandbox/jng/common_decouple_v3/Common/Stylization/SE_SymbolDefProxies.h 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/SE_SymbolDefProxies.h 2019-02-05 13:44:22 UTC (rev 9475)
@@ -37,7 +37,7 @@
public:
RS_FontEngine* fonte;
SE_Matrix* xform;
- FdoExpressionEngine* exec;
+ SE_ExpressionEvaluator* exec;
SE_SymbolManager* resources;
double mm2su;
double mm2sud; // number of screen units per mm device
@@ -286,16 +286,11 @@
std::vector<SE_SymbolInstance*> symbolInstances;
RS_String legendLabel; // no expressions on this guy?
- FdoFilter* filter;
+ MdfModel::MdfString filter;
- SE_Rule() : filter(NULL)
+ SE_Rule() {}
~SE_Rule()
- if (filter)
- filter->Release();
for (std::vector<SE_SymbolInstance*>::iterator iter = symbolInstances.begin(); iter != symbolInstances.end(); ++iter)
delete *iter;
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/Stylization.vcxproj
--- sandbox/jng/common_decouple_v3/Common/Stylization/Stylization.vcxproj 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/Stylization.vcxproj 2019-02-05 13:44:22 UTC (rev 9475)
@@ -235,6 +235,8 @@
<ClCompile Include="ExpressionFunctionSession.cpp" />
<ClCompile Include="ExpressionFunctionUrlEncode.cpp" />
<ClCompile Include="ExpressionHelper.cpp" />
+ <ClCompile Include="FdoExpressionEvaluator.cpp" />
+ <ClCompile Include="FdoExpressionEvaluatorFactory.cpp" />
<ClCompile Include="LineBuffer.cpp" />
<ClCompile Include="Matrix3D.cpp" />
<ClCompile Include="Point2D.cpp" />
@@ -325,11 +327,17 @@
<ClInclude Include="ExpressionHelper.h" />
<ClInclude Include="Bounds.h" />
<ClInclude Include="DataValueStack.h" />
+ <ClInclude Include="FdoExpressionEvaluator.h" />
+ <ClInclude Include="FdoExpressionEvaluatorFactory.h" />
<ClInclude Include="LineBuffer.h" />
<ClInclude Include="Matrix3D.h" />
<ClInclude Include="Point2D.h" />
<ClInclude Include="Point3D.h" />
<ClInclude Include="PolygonUtils.h" />
+ <ClInclude Include="RS_FdoFeatureReader.h" />
+ <ClInclude Include="RS_Types.h" />
+ <ClInclude Include="SE_ExpressionEvaluator.h" />
+ <ClInclude Include="SE_ExpressionEvaluatorFactory.h" />
<ClInclude Include="Vector2D.h" />
<ClInclude Include="Vector3D.h" />
<ClInclude Include="CSysTransformer.h" />
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/Stylization.vcxproj.filters
--- sandbox/jng/common_decouple_v3/Common/Stylization/Stylization.vcxproj.filters 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/Stylization.vcxproj.filters 2019-02-05 13:44:22 UTC (rev 9475)
@@ -25,6 +25,9 @@
<Filter Include="Shared">
<UniqueIdentifier>{b9f208c0-414d-4567-84e7-1d2c1439bc00}</UniqueIdentifier>
</Filter>
+ <Filter Include="FdoImpl">
+ <UniqueIdentifier>{9579ad35-429e-45c2-a0a6-63f3dc66bd9a}</UniqueIdentifier>
+ </Filter>
</ItemGroup>
<ItemGroup>
<ClCompile Include="ExpressionFunctionArgb.cpp">
@@ -283,6 +286,12 @@
<ClCompile Include="ExpressionFunctionMapScale.cpp">
<Filter>ExpressionEngine</Filter>
</ClCompile>
+ <ClCompile Include="FdoExpressionEvaluator.cpp">
+ <Filter>FdoImpl</Filter>
+ </ClCompile>
+ <ClCompile Include="FdoExpressionEvaluatorFactory.cpp">
+ </ClCompile>
</ItemGroup>
<ItemGroup>
<ClInclude Include="ExpressionFunctionArgb.h">
@@ -608,6 +617,24 @@
<ClInclude Include="ExpressionFunctionMapScale.h">
</ClInclude>
+ <ClInclude Include="RS_Types.h">
+ <Filter>Interfaces</Filter>
+ </ClInclude>
+ <ClInclude Include="RS_FdoFeatureReader.h">
+ </ClInclude>
+ <ClInclude Include="SE_ExpressionEvaluator.h">
+ <Filter>StyleEngine</Filter>
+ </ClInclude>
+ <ClInclude Include="SE_ExpressionEvaluatorFactory.h">
+ </ClInclude>
+ <ClInclude Include="FdoExpressionEvaluator.h">
+ </ClInclude>
+ <ClInclude Include="FdoExpressionEvaluatorFactory.h">
+ </ClInclude>
</ItemGroup>
<ItemGroup>
<ResourceCompile Include="Stylization.rc" />
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/StylizationDefs.h
--- sandbox/jng/common_decouple_v3/Common/Stylization/StylizationDefs.h 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/StylizationDefs.h 2019-02-05 13:44:22 UTC (rev 9475)
@@ -30,6 +30,43 @@
#include <limits>
#include <climits>
+//Matches the FGF enumeration FdoDimensionality
+enum Dimensionality
+ /// X and Y dimensions are present.
+ Dimensionality_XY = 0,
+ /// Z dimension is present.
+ Dimensionality_Z = 1,
+ /// M ('measure') dimension is present.
+ Dimensionality_M = 2
+//Matches the FGF enumeration FdoGeometryType
+enum GeometryType
+ GeometryType_None = 0,
+ GeometryType_Point = 1,
+ GeometryType_LineString = 2,
+ GeometryType_Polygon = 3,
+ GeometryType_MultiPoint = 4,
+ GeometryType_MultiLineString = 5,
+ GeometryType_MultiPolygon = 6,
+ GeometryType_MultiGeometry = 7,
+ GeometryType_CurveString = 10,
+ GeometryType_CurvePolygon = 11,
+ GeometryType_MultiCurveString = 12,
+ GeometryType_MultiCurvePolygon = 13
+//Matches FdoGeometryComponentType
+enum GeometryComponentType
+ GeometryComponentType_LinearRing = 129,
+ GeometryComponentType_CircularArcSegment = 130,
+ GeometryComponentType_LineStringSegment = 131,
+ GeometryComponentType_Ring = 132
// frequently used constants
const double M_PI180 = (M_PI / 180.0);
const double M_180PI = (180.0 / M_PI);
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/StylizationEngine.cpp
--- sandbox/jng/common_decouple_v3/Common/Stylization/StylizationEngine.cpp 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/StylizationEngine.cpp 2019-02-05 13:44:22 UTC (rev 9475)
@@ -24,6 +24,7 @@
#include "SE_PositioningAlgorithms.h"
#include "SE_SymbolDefProxies.h"
#include "FeatureTypeStyleVisitor.h"
+#include "SE_ExpressionEvaluatorFactory.h"
#include <algorithm>
#include <functional>
@@ -57,6 +58,7 @@
// possibilities to avoid filter execution on subsequent passes
void StylizationEngine::StylizeVectorLayer(MdfModel::VectorLayerDefinition* layer,
MdfModel::VectorScaleRange* range,
+ SE_ExpressionEvaluatorFactory* evFactory,
SE_Renderer* se_renderer,
RS_FeatureReader* reader,
CSysTransformer* xformer,
@@ -122,12 +124,12 @@
if (numPasses > 1)
reader->Reset();
- // create an expression engine with our custom functions
- // NOTE: We must create a new engine with each rendering pass. The engine
+ // create an expression evaluator with our custom functions
+ // NOTE: We must create a new evaluator with each rendering pass. The evaluator
// stores a weak reference to the RS_FeatureReader's internal
// FdoIFeatureReader, and this internal reader is different for each
// pass.
- FdoPtr<FdoExpressionEngine> exec = ExpressionHelper::GetExpressionEngine(se_renderer, reader);
+ std::auto_ptr<SE_ExpressionEvaluator> exec(evFactory->CreateEvaluator(se_renderer, reader));
while (reader->ReadNext())
@@ -136,7 +138,7 @@
nFeatures++;
#endif
- LineBuffer* lb = LineBufferPool::NewLineBuffer(m_pool, 8, FdoDimensionality_Z, ignoreZ);
+ LineBuffer* lb = LineBufferPool::NewLineBuffer(m_pool, 8, Dimensionality_Z, ignoreZ);
if (!lb)
continue;
@@ -168,7 +170,7 @@
for (size_t i=0; i<numTypeStyles; ++i)
bool initialPass = (i == 0 && instanceRenderingPass == 0 && symbolRenderingPass == 0);
- Stylize(reader, exec, lb, compTypeStyles[i], &seTip, &seUrl, NULL,
+ Stylize(reader, exec.get(), lb, compTypeStyles[i], &seTip, &seUrl, NULL,
initialPass, instanceRenderingPass, symbolRenderingPass,
nextInstanceRenderingPass, nextSymbolRenderingPass);
@@ -242,6 +244,7 @@
void StylizationEngine::StylizeWatermark(SE_Renderer* se_renderer,
WatermarkDefinition* watermark,
int drawWidth, int drawHeight,
int saveWidth, int saveHeight)
@@ -455,12 +458,13 @@
++numPasses;
// pass.
- FdoPtr<FdoExpressionEngine> exec = ExpressionHelper::GetExpressionEngine(se_renderer, NULL);
+ std::auto_ptr<SE_ExpressionEvaluator> spExec(evFactory->CreateEvaluator(se_renderer, NULL));
+ SE_ExpressionEvaluator* exec = spExec.get();
std::auto_ptr<LineBuffer> spLB;
size_t nPos = watermarkPosList.size();
@@ -467,7 +471,7 @@
for (size_t posIx=0; posIx<nPos; posIx+=2)
//Get geometry
- LineBuffer* lb = LineBufferPool::NewLineBuffer(m_pool, 8, FdoDimensionality_Z);
+ LineBuffer* lb = LineBufferPool::NewLineBuffer(m_pool, 8, Dimensionality_Z);
spLB.reset(lb);
lb->MoveTo(watermarkPosList[posIx], watermarkPosList[posIx+1]);
// tell line buffer the current drawing scale (used for arc tessellation)
@@ -749,7 +753,7 @@
void StylizationEngine::Stylize(RS_FeatureReader* reader,
CompositeTypeStyle* style,
SE_String* seTip,
@@ -777,17 +781,9 @@
CompositeRule* r = static_cast<CompositeRule*>(rulecoll->GetAt(i));
const MdfString& filterstr = r->GetFilter();
- rulecache[i].filter = NULL;
if (!filterstr.empty())
- try
- rulecache[i].filter = FdoFilter::Parse(filterstr.c_str());
+ rulecache[i].filter = filterstr;
rulecache[i].legendLabel= r->GetLegendLabel();
@@ -800,13 +796,13 @@
SE_Rule* rule = NULL;
for (int i=0; i<nRules; ++i)
- bool match = (rules[i].filter == NULL);
+ bool match = (rules[i].filter.empty());
if (!match)
try
- match = exec->ProcessFilter(rules[i].filter);
+ match = exec->ExecFilter(&rules[i].filter);
@@ -826,9 +822,9 @@
// we found a valid rule - send a StartFeature notification
RS_String rs_tip, rs_url;
- if (seTip->expression || wcslen(seTip->getValue()) > 0)
+ if (!seTip->expression.empty() || wcslen(seTip->getValue()) > 0)
rs_tip = seTip->evaluate(exec);
- if (seUrl->expression || wcslen(seUrl->getValue()) > 0)
+ if (!seUrl->expression.empty() || wcslen(seUrl->getValue()) > 0)
rs_url = seUrl->evaluate(exec);
RS_String& rs_thm = rule->legendLabel;
m_serenderer->StartFeature(reader, initialPass, rs_tip.empty()? NULL : &rs_tip, rs_url.empty()? NULL : &rs_url, rs_thm.empty()? NULL : &rs_thm);
@@ -965,29 +961,29 @@
- case FdoGeometryType_Point:
- case FdoGeometryType_MultiPoint:
+ case GeometryType_Point:
+ case GeometryType_MultiPoint:
if (sym->geomContext != SymbolInstance::gcPoint)
continue;
break;
- case FdoGeometryType_LineString:
- case FdoGeometryType_MultiLineString:
- case FdoGeometryType_CurveString:
- case FdoGeometryType_MultiCurveString:
+ case GeometryType_LineString:
+ case GeometryType_MultiLineString:
+ case GeometryType_CurveString:
+ case GeometryType_MultiCurveString:
if (sym->geomContext != SymbolInstance::gcLineString)
continue;
break;
- case FdoGeometryType_Polygon:
- case FdoGeometryType_MultiPolygon:
- case FdoGeometryType_CurvePolygon:
- case FdoGeometryType_MultiCurvePolygon:
+ case GeometryType_Polygon:
+ case GeometryType_MultiPolygon:
+ case GeometryType_CurvePolygon:
+ case GeometryType_MultiCurvePolygon:
if (sym->geomContext != SymbolInstance::gcPolygon)
continue;
break;
-// case FdoGeometryType_MultiGeometry:
+// case GeometryType_MultiGeometry:
// continue;
// break;
@@ -1134,29 +1130,29 @@
continue;
break;
continue;
break;
continue;
break;
// continue;
// break;
@@ -1246,7 +1242,7 @@
// to them does not display in the map region. This method computes the
// required clip offset for the supplied style. The value returned is in
// screen units.
-double StylizationEngine::GetClipOffset(SE_SymbolInstance* sym, SE_Style* style, FdoExpressionEngine* exec, double mm2suX, double mm2suY)
+double StylizationEngine::GetClipOffset(SE_SymbolInstance* sym, SE_Style* style, SE_ExpressionEvaluator* exec, double mm2suX, double mm2suY)
double clipOffsetSU = 0.0;
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/StylizationEngine.h
--- sandbox/jng/common_decouple_v3/Common/Stylization/StylizationEngine.h 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/StylizationEngine.h 2019-02-05 13:44:22 UTC (rev 9475)
@@ -29,6 +29,8 @@
class SE_BufferPool;
class SE_StyleVisitor;
class SE_ApplyContext;
+class SE_ExpressionEvaluatorFactory;
class RS_ElevationSettings;
class LineBuffer;
@@ -63,6 +65,7 @@
// Stylizes the supplied layer using all composite type styles in the given scale.
void StylizeVectorLayer(MdfModel::VectorLayerDefinition* layer,
@@ -72,6 +75,7 @@
//Stylize the supplied watermark
void StylizeWatermark(SE_Renderer* se_renderer,
int drawWidth,
int drawHeight,
int saveWidth,
@@ -79,7 +83,7 @@
// Stylizes the current feature on the reader using the supplied composite type style.
void Stylize(RS_FeatureReader* reader,
SE_String* seTip,
@@ -95,7 +99,7 @@
private:
void LayoutCustomLabel(const wchar_t* positioningAlgo, SE_ApplyContext* applyCtx, SE_RenderStyle* rstyle, double mm2su);
- double GetClipOffset(SE_SymbolInstance* sym, SE_Style* style, FdoExpressionEngine* exec, double mm2suX, double mm2suY);
+ double GetClipOffset(SE_SymbolInstance* sym, SE_Style* style, SE_ExpressionEvaluator* exec, double mm2suX, double mm2suY);
private:
SE_Renderer* m_serenderer;
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/StylizationUtil.cpp
--- sandbox/jng/common_decouple_v3/Common/Stylization/StylizationUtil.cpp 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/StylizationUtil.cpp 2019-02-05 13:44:22 UTC (rev 9475)
@@ -23,6 +23,7 @@
#include "SE_StyleVisitor.h"
#include "SE_BufferPool.h"
#include <cmath>
@@ -91,7 +92,8 @@
int themeCategory,
FeatureTypeStyle* fts,
SE_Renderer* pSERenderer,
- SE_SymbolManager* sman)
+ SE_SymbolManager* sman,
+ SE_ExpressionEvaluatorFactory* evFactory)
if (!fts)
return;
@@ -136,7 +138,7 @@
// render the symbolization
CompositeSymbolization* csym = rule->GetSymbolization();
- StylizationUtil::RenderCompositeSymbolization(csym, pSERenderer, sman, 0.0, 0.0, imgWidth, imgHeight);
+ StylizationUtil::RenderCompositeSymbolization(csym, pSERenderer, sman, evFactory, 0.0, 0.0, imgWidth, imgHeight);
break;
@@ -508,6 +510,7 @@
void StylizationUtil::RenderCompositeSymbolization(CompositeSymbolization* csym,
double x, double y,
double width, double height)
@@ -518,114 +521,115 @@
visitor.Convert(symbolInstances, csym);
- FdoPtr<FdoExpressionEngine> exec = ExpressionHelper::GetExpressionEngine(pSERenderer, NULL);
+ std::auto_ptr<SE_ExpressionEvaluator> spExec(evFactory->CreateEvaluator(pSERenderer, NULL));
+ // step 1 - get the preview bounds for the symbolization
- // step 1 - get the preview bounds for the symbolization
+ RS_Bounds symBounds(DBL_MAX, DBL_MAX, -DBL_MAX, -DBL_MAX);
+ GetCompositeSymbolizationPreviewBounds(symbolInstances, pSERenderer, sman, exec, symBounds);
- RS_Bounds symBounds(DBL_MAX, DBL_MAX, -DBL_MAX, -DBL_MAX);
- GetCompositeSymbolizationPreviewBounds(symbolInstances, pSERenderer, sman, exec, symBounds);
+ // step 2 - bounds processing
- // step 2 - bounds processing
+ if (!symBounds.IsValid())
+ return;
- if (!symBounds.IsValid())
- return;
+ double mm2sud = pSERenderer->GetScreenUnitsPerMillimeterDevice();
+ double mm2suw = pSERenderer->GetScreenUnitsPerMillimeterWorld();
+ double drawingScale = pSERenderer->GetDrawingScale();
+ bool yUp = pSERenderer->YPointsUp();
- double mm2sud = pSERenderer->GetScreenUnitsPerMillimeterDevice();
- double mm2suw = pSERenderer->GetScreenUnitsPerMillimeterWorld();
- double drawingScale = pSERenderer->GetDrawingScale();
- bool yUp = pSERenderer->YPointsUp();
+ // check for degenerate bounds
+ if (symBounds.width() == 0.0 && symBounds.height() == 0.0)
+ // make the bounds have the same width and height as the image
+ symBounds.minx -= 0.5 * width / drawingScale;
+ symBounds.maxx += 0.5 * width / drawingScale;
+ symBounds.miny -= 0.5 * height / drawingScale;
+ symBounds.maxy += 0.5 * height / drawingScale;
- // check for degenerate bounds
- if (symBounds.width() == 0.0 && symBounds.height() == 0.0)
- // make the bounds have the same width and height as the image
- symBounds.minx -= 0.5 * width / drawingScale;
- symBounds.maxx += 0.5 * width / drawingScale;
- symBounds.miny -= 0.5 * height / drawingScale;
- symBounds.maxy += 0.5 * height / drawingScale;
+ // make the aspect ratio of the symbol bounds match that of the supplied
+ // rectangle - this is needed to properly center the symbol in the rectangle
+ double arDisplay = width / height;
+ if (symBounds.width() > symBounds.height() * arDisplay)
+ double dHeight = symBounds.width() / arDisplay - symBounds.height();
+ symBounds.miny -= 0.5*dHeight;
+ symBounds.maxy += 0.5*dHeight;
+ else
+ double dWidth = symBounds.height() * arDisplay - symBounds.width();
+ symBounds.minx -= 0.5*dWidth;
+ symBounds.maxx += 0.5*dWidth;
- // make the aspect ratio of the symbol bounds match that of the supplied
- // rectangle - this is needed to properly center the symbol in the rectangle
- double arDisplay = width / height;
- if (symBounds.width() > symBounds.height() * arDisplay)
- double dHeight = symBounds.width() / arDisplay - symBounds.height();
- symBounds.miny -= 0.5*dHeight;
- symBounds.maxy += 0.5*dHeight;
- else
- double dWidth = symBounds.height() * arDisplay - symBounds.width();
- symBounds.minx -= 0.5*dWidth;
- symBounds.maxx += 0.5*dWidth;
+ // make the bounds slightly larger to avoid having missing pixels at the edges
+ double w = symBounds.width();
+ double h = symBounds.height();
+ symBounds.minx -= 0.00001*w;
+ symBounds.miny -= 0.00001*h;
+ symBounds.maxx += 0.00001*w;
+ symBounds.maxy += 0.00001*h;
- // make the bounds slightly larger to avoid having missing pixels at the edges
- double w = symBounds.width();
- double h = symBounds.height();
- symBounds.minx -= 0.00001*w;
- symBounds.miny -= 0.00001*h;
- symBounds.maxx += 0.00001*w;
- symBounds.maxy += 0.00001*h;
+ // step 3 - pre-draw preparation
- // step 3 - pre-draw preparation
+ // From the bounds we can compute how much to scale and translate the symbols so
+ // that they fill the supplied rectangle. We could then apply the scaling and
+ // translation directly to the current world-to-screen transform, and if we drew
+ // the currently evaluated symbols using it they would fill the supplied rectangle.
- // From the bounds we can compute how much to scale and translate the symbols so
- // that they fill the supplied rectangle. We could then apply the scaling and
- // translation directly to the current world-to-screen transform, and if we drew
- // the currently evaluated symbols using it they would fill the supplied rectangle.
+ // The problem is that any text heights, line weights, and image sizes in the
+ // currently evaluated symbols are not adjusted when we draw using this updated
+ // transform. To fix this we need to re-evaluate the symbols using a transform
+ // which includes the scale factor from the updated world-to-screen transform.
+ // Borrowing the notation from StylizationEngine::Stylize we have:
+ // [T_fe] [S_mm] [T_si] [R_pu] [S_si] [T_pu] {Geom}
+ // We'll add an additional scale factor [S_a] and translation [T_a] (point symbols
+ // only) as follows:
+ // [T_a] [T_fe] [S_a] [S_mm] [T_si] [R_pu] [S_si] [T_pu] {Geom}
+ // Reworking this then gives:
+ // [T_a] [T_fe] [T_si*] [R_pu*] [T_pu*] [S_a] [S_mm] [S_si] {Geom}
+ // where:
+ // T_si* = symbol instance insertion offset, using offsets scaled by S_a and S_mm
+ // R_pu* = point usage rotation, with angle accounting for y-up or y-down
+ // T_pu* = point usage origin offset, using offsets scaled by S_a, S_mm, and S_si
- // The problem is that any text heights, line weights, and image sizes in the
- // currently evaluated symbols are not adjusted when we draw using this updated
- // transform. To fix this we need to re-evaluate the symbols using a transform
- // which includes the scale factor from the updated world-to-screen transform.
- // Borrowing the notation from StylizationEngine::Stylize we have:
- // [T_fe] [S_mm] [T_si] [R_pu] [S_si] [T_pu] {Geom}
- // We'll add an additional scale factor [S_a] and translation [T_a] (point symbols
- // only) as follows:
- // [T_a] [T_fe] [S_a] [S_mm] [T_si] [R_pu] [S_si] [T_pu] {Geom}
- // Reworking this then gives:
- // [T_a] [T_fe] [T_si*] [R_pu*] [T_pu*] [S_a] [S_mm] [S_si] {Geom}
- // where:
- // T_si* = symbol instance insertion offset, using offsets scaled by S_a and S_mm
- // R_pu* = point usage rotation, with angle accounting for y-up or y-down
- // T_pu* = point usage origin offset, using offsets scaled by S_a, S_mm, and S_si
+ // compute the scale factor we need to apply to the symbols to ensure they fully
+ // display in the preview
+ double scaleF = width / (drawingScale * symBounds.width());
- // compute the scale factor we need to apply to the symbols to ensure they fully
- // display in the preview
- double scaleF = width / (drawingScale * symBounds.width());
+ // step 4 - re-evaluate and draw all the symbol instances
- // step 4 - re-evaluate and draw all the symbol instances
+ for (std::vector<SE_SymbolInstance*>::const_iterator iter = symbolInstances.begin(); iter != symbolInstances.end(); ++iter)
+ // one per symbol instance
+ SE_SymbolInstance* sym = *iter;
- for (std::vector<SE_SymbolInstance*>::const_iterator iter = symbolInstances.begin(); iter != symbolInstances.end(); ++iter)
- // one per symbol instance
- SE_SymbolInstance* sym = *iter;
+ // skip labels
+ if (sym->drawLast.evaluate(exec))
+ continue;
- // skip labels
- if (sym->drawLast.evaluate(exec))
- continue;
- // get the actual amount to scale the symbol instance
- double scale = scaleF;
- switch (sym->geomContext)
+ // get the actual amount to scale the symbol instance
+ double scale = scaleF;
+ switch (sym->geomContext)
case SymbolInstance::gcPolygon:
// in the case of polygon data don't scale down the area symbols
@@ -634,52 +638,52 @@
break;
- double mm2suX = (sym->sizeContext == MappingUnits)? mm2suw : mm2sud;
- double mm2suY = yUp? mm2suX : -mm2suX;
+ double mm2suX = (sym->sizeContext == MappingUnits) ? mm2suw : mm2sud;
+ double mm2suY = yUp ? mm2suX : -mm2suX;
- // this time we scale by [S_si], [S_mm], and [S_a]
- SE_Matrix xformScale;
- xformScale.scale(sym->scale[0].evaluate(exec),
- sym->scale[1].evaluate(exec));
- xformScale.scale(mm2suX, mm2suY);
- xformScale.scale(scale, scale);
+ // this time we scale by [S_si], [S_mm], and [S_a]
+ SE_Matrix xformScale;
+ xformScale.scale(sym->scale[0].evaluate(exec),
+ sym->scale[1].evaluate(exec));
+ xformScale.scale(mm2suX, mm2suY);
+ xformScale.scale(scale, scale);
- // initialize the style evaluation context
- // NOTE: do not adjust the mm2su values by the scale factor
- SE_EvalContext evalCtx;
- evalCtx.exec = exec;
- evalCtx.mm2su = mm2suX;
- evalCtx.mm2sud = mm2sud;
- evalCtx.mm2suw = mm2suw;
- evalCtx.px2su = pSERenderer->GetScreenUnitsPerPixel();
- evalCtx.pool = pool;
- evalCtx.fonte = pSERenderer->GetRSFontEngine();
- evalCtx.xform = &xformScale;
- evalCtx.resources = sman;
+ // initialize the style evaluation context
+ // NOTE: do not adjust the mm2su values by the scale factor
+ SE_EvalContext evalCtx;
+ evalCtx.exec = exec;
+ evalCtx.mm2su = mm2suX;
+ evalCtx.mm2sud = mm2sud;
+ evalCtx.mm2suw = mm2suw;
+ evalCtx.px2su = pSERenderer->GetScreenUnitsPerPixel();
+ evalCtx.pool = pool;
+ evalCtx.fonte = pSERenderer->GetRSFontEngine();
+ evalCtx.xform = &xformScale;
+ evalCtx.resources = sman;
- // initialize the style application context
- SE_Matrix xform;
- SE_ApplyContext applyCtx;
- applyCtx.geometry = NULL; // gets set below
- applyCtx.renderer = pSERenderer;
- applyCtx.xform = &xform;
- applyCtx.sizeContext = sym->sizeContext;
+ // initialize the style application context
+ SE_Matrix xform;
+ SE_ApplyContext applyCtx;
+ applyCtx.geometry = NULL; // gets set below
+ applyCtx.renderer = pSERenderer;
+ applyCtx.xform = &xform;
+ applyCtx.sizeContext = sym->sizeContext;
- for (std::vector<SE_Style*>::const_iterator siter = sym->styles.begin(); siter != sym->styles.end(); ++siter)
- // have one style per simple symbol definition
- SE_Style* style = *siter;
+ for (std::vector<SE_Style*>::const_iterator siter = sym->styles.begin(); siter != sym->styles.end(); ++siter)
+ // have one style per simple symbol definition
+ SE_Style* style = *siter;
- // since the render styles are cached we need to reset these before
- // re-evaluating the style
- style->reset();
- style->evaluate(&evalCtx);
+ // since the render styles are cached we need to reset these before
+ // re-evaluating the style
+ style->reset();
+ style->evaluate(&evalCtx);
- SE_RenderStyle* rStyle = style->rstyle;
- switch (rStyle->type)
+ SE_RenderStyle* rStyle = style->rstyle;
+ switch (rStyle->type)
case SE_RenderStyle_Point:
// don't call style->apply() since we do some special processing
@@ -699,7 +703,7 @@
// get the translation matrix which centers the symbol in the image rectangle
SE_Matrix xformTrans;
xformTrans.translate(mapCtrX, mapCtrY);
- xformTrans.translate(-symCtrX, yUp? -symCtrY : symCtrY);
+ xformTrans.translate(-symCtrX, yUp ? -symCtrY : symCtrY);
// point usage offset (already scaled by [S_si], [S_mm], and [S_a])
SE_Matrix xformStyle;
@@ -713,7 +717,7 @@
// symbol instance offset - must scale this by [S_mm], and [S_a]
xformStyle.translate(sym->absOffset[0].evaluate(exec) * mm2suX * scale,
- sym->absOffset[1].evaluate(exec) * mm2suY * scale);
+ sym->absOffset[1].evaluate(exec) * mm2suY * scale);
// factor the translation into the transform and draw the symbol
xformStyle.premultiply(xformTrans);
@@ -728,28 +732,28 @@
LineBuffer lb(5);
- case SymbolInstance::gcUnspecified:
- case SymbolInstance::gcLineString:
- // a horizontal line centered vertically in the preview image
- lb.SetGeometryType(FdoGeometryType_LineString);
- lb.MoveTo(x , y + 0.5*height);
- lb.LineTo(x + width, y + 0.5*height);
- break;
+ case SymbolInstance::gcUnspecified:
+ case SymbolInstance::gcLineString:
+ // a horizontal line centered vertically in the preview image
+ lb.SetGeometryType(GeometryType_LineString);
+ lb.MoveTo(x, y + 0.5*height);
+ lb.LineTo(x + width, y + 0.5*height);
+ break;
- case SymbolInstance::gcPolygon:
- // a rectangle around the border of the preview image
- lb.MoveTo(x , y );
- lb.LineTo(x + width, y );
- lb.LineTo(x + width, y + height);
- lb.LineTo(x , y + height);
- lb.Close();
- break;
+ case SymbolInstance::gcPolygon:
+ // a rectangle around the border of the preview image
+ lb.MoveTo(x, y);
+ lb.LineTo(x + width, y);
+ lb.LineTo(x + width, y + height);
+ lb.LineTo(x, y + height);
+ lb.Close();
+ break;
// if the the line style uses parametric units control reconfigure
// it so you just get one symbol at the middle
@@ -773,11 +777,11 @@
// set the preview geometry to a rectangle filling the preview image
LineBuffer lb(5);
- lb.SetGeometryType(FdoGeometryType_Polygon);
+ lb.SetGeometryType(GeometryType_Polygon);
+ lb.MoveTo(x, y);
lb.Close();
// just apply the style to the preview geometry
@@ -788,10 +792,10 @@
default:
break;
// step 5 - final clean up
@@ -810,7 +814,7 @@
void StylizationUtil::GetCompositeSymbolizationPreviewBounds(std::vector<SE_SymbolInstance*> symbolInstances,
- FdoExpressionEngine* exec,
+ SE_ExpressionEvaluator* exec,
RS_Bounds& bounds)
// make sure we have symbol instances
@@ -974,7 +978,8 @@
// the resource file) in order for this method to work.
RS_Bounds StylizationUtil::GetCompositeSymbolizationBounds(CompositeSymbolization* csym,
SE_BufferPool* pool = pSERenderer->GetBufferPool();
SE_StyleVisitor visitor(sman, pool);
@@ -983,11 +988,11 @@
+ std::auto_ptr<SE_ExpressionEvaluator> exec(evFactory->CreateEvaluator(pSERenderer, NULL));
// calculate bounds - symbol geometries cannot use expressions, so no expression engine is needed
- GetCompositeSymbolizationBoundsInternal(symbolInstances, pSERenderer, sman, exec, symBounds);
+ GetCompositeSymbolizationBoundsInternal(symbolInstances, pSERenderer, sman, exec.get(), symBounds);
// clean up
@@ -1005,7 +1010,7 @@
void StylizationUtil::GetCompositeSymbolizationBoundsInternal(std::vector<SE_SymbolInstance*> symbolInstances,
RS_Bounds& bounds)
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/StylizationUtil.h
--- sandbox/jng/common_decouple_v3/Common/Stylization/StylizationUtil.h 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/StylizationUtil.h 2019-02-05 13:44:22 UTC (rev 9475)
@@ -27,6 +27,8 @@
class Renderer;
class SE_Renderer;
class SE_SymbolManager;
+class SE_ExpressionEvaluator;
struct SE_SymbolInstance;
// Provides helper methods for:
@@ -39,7 +41,7 @@
static bool ParseDouble(const MdfString& valstr, double& val);
static void DrawStylePreview(int imgWidth, int imgHeight, int themeCategory, FeatureTypeStyle* fts,
- SE_Renderer* pSERenderer, SE_SymbolManager* sman);
+ SE_Renderer* pSERenderer, SE_SymbolManager* sman, SE_ExpressionEvaluatorFactory* evFactory);
static void RenderPointSymbolization(PointSymbolization2D* psym,
@@ -60,12 +62,14 @@
static void RenderCompositeSymbolization(CompositeSymbolization* csym,
double x, double y,
double width, double height);
static RS_Bounds GetCompositeSymbolizationBounds(CompositeSymbolization* csym,
- SE_SymbolManager* sman);
+ SE_ExpressionEvaluatorFactory* evFactory);
static double GetMaxMappingSpaceLineWidth(FeatureTypeStyle* fts, int themeCategory);
@@ -73,13 +77,13 @@
static void GetCompositeSymbolizationBoundsInternal(std::vector<SE_SymbolInstance*> symbolInstances,
RS_Bounds& bounds);
static void GetCompositeSymbolizationPreviewBounds(std::vector<SE_SymbolInstance*> symbolInstances,
RS_Bounds& bounds);
Modified: sandbox/jng/common_decouple_v3/Common/Stylization/Stylizer.h
--- sandbox/jng/common_decouple_v3/Common/Stylization/Stylizer.h 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Common/Stylization/Stylizer.h 2019-02-05 13:44:22 UTC (rev 9475)
@@ -28,6 +28,8 @@
class GeometryAdapter;
class CSysTransformer;
///<summary>
///Stylization interrupt callback -- return true to cancel stylization
///</summary>
@@ -48,6 +50,7 @@
virtual void StylizeVectorLayer(MdfModel::VectorLayerDefinition* layer,
Renderer* renderer,
RS_FeatureReader* features,
double mapScale,
CancelStylization cancel,
@@ -60,6 +63,7 @@
virtual void StylizeGridLayer(MdfModel::GridLayerDefinition* layer,
Renderer* renderer,
double mapScale,
@@ -80,6 +84,7 @@
///</summary>
virtual void StylizeWatermark(Renderer* renderer,
MdfModel::WatermarkDefinition* watermark,
int drawWidth,
int drawHeight,
int saveWidth,
@@ -88,7 +93,7 @@
///<summary>
/// Allows a user to set a custom stylization object for a given geometry type.
///</summary>
- virtual void SetGeometryAdapter(FdoGeometryType type, GeometryAdapter* stylizer) = 0;
+ virtual void SetGeometryAdapter(GeometryType type, GeometryAdapter* stylizer) = 0;
STYLIZATION_API static MdfModel::VectorScaleRange* FindScaleRange(MdfModel::VectorScaleRangeCollection& src, double mapScale);
STYLIZATION_API static MdfModel::GridScaleRange* FindScaleRange(MdfModel::GridScaleRangeCollection& src, double mapScale);
Modified: sandbox/jng/common_decouple_v3/Server/src/Services/Kml/ServerKmlService.cpp
--- sandbox/jng/common_decouple_v3/Server/src/Services/Kml/ServerKmlService.cpp 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Server/src/Services/Kml/ServerKmlService.cpp 2019-02-05 13:44:22 UTC (rev 9475)
@@ -28,6 +28,7 @@
#include "Bounds.h"
#include "MgCSTrans.h"
#include "SAX2Parser.h"
+#include "FdoExpressionEvaluatorFactory.h"
//Zip support from DWF toolkit
#include "dwfcore/ZipFileDescriptor.h"
@@ -492,7 +493,8 @@
SEMgSymbolManager sman(m_svcResource);
DefaultStylizer stylizer(&sman);
renderer.StartLayer(&layerInfo, &fcInfo);
- stylizer.StylizeVectorLayer(vl, &renderer, rsReader, csTrans, scale, NULL, NULL);
+ FdoExpressionEvaluatorFactory evFactory;
+ stylizer.StylizeVectorLayer(vl, &renderer, rsReader, &evFactory, csTrans, scale, NULL, NULL);
renderer.EndLayer();
Modified: sandbox/jng/common_decouple_v3/Server/src/Services/Mapping/MappingUtil.cpp
--- sandbox/jng/common_decouple_v3/Server/src/Services/Mapping/MappingUtil.cpp 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Server/src/Services/Mapping/MappingUtil.cpp 2019-02-05 13:44:22 UTC (rev 9475)
@@ -33,6 +33,8 @@
#include "TransformCache.h"
#include "CacheManager.h"
//For logging
@@ -380,6 +382,7 @@
// Cache coordinate system transforms for the life of the
// stylization operation.
TransformCacheMap transformCache;
// Get the layers' resource content in a single request by adding them to a collection
for (int i = layers->GetCount()-1; i >= 0; i--)
@@ -581,7 +584,7 @@
// stylize into output format
dr->StartLayer(&layerInfo, &fcinfo);
- ds->StylizeVectorLayer(vl, dr, rsReader, xformer, scale, NULL, NULL);
+ ds->StylizeVectorLayer(vl, dr, rsReader, &evFactory, xformer, scale, NULL, NULL);
dr->EndLayer();
// color extraction for RFC60 only when needed
@@ -749,7 +752,7 @@
//stylize grid layer
- ds->StylizeGridLayer(gl, dr, rsReader, xformer, scale, NULL, NULL);
+ ds->StylizeGridLayer(gl, dr, rsReader, &evFactory, xformer, scale, NULL, NULL);
dr->EndLayer();
@@ -1223,8 +1226,9 @@
RSMgSymbolManager rs_sman(svcResource);
er.SetSymbolManager(&rs_sman);
// draw the preview
- StylizationUtil::DrawStylePreview(imgWidth, imgHeight, themeCategory, fts, &er, &se_sman);
+ StylizationUtil::DrawStylePreview(imgWidth, imgHeight, themeCategory, fts, &er, &se_sman, &evFactory);
auto_ptr<RS_ByteData> data;
data.reset(er.Save(format, imgWidth, imgHeight));
Property changes on: sandbox/jng/common_decouple_v3/Server/src/Services/Mapping/MappingUtil.cpp
## -3,6 +3,7 ##
/sandbox/adsk/2.4j/Server/src/Services/Mapping/MappingUtil.cpp:6327-6535
/sandbox/adsk/3.1n/Server/src/Services/Mapping/MappingUtil.cpp:8942
/sandbox/jng/clean_json/Server/src/Services/Mapping/MappingUtil.cpp:8818-9180
+/sandbox/jng/common_decouple_v2/Server/src/Services/Mapping/MappingUtil.cpp:9356-9358
/sandbox/jng/createruntimemap/Server/src/Services/Mapping/MappingUtil.cpp:7486-7555
/sandbox/jng/ogc/Server/src/Services/Mapping/MappingUtil.cpp:9240-9255
/sandbox/rfc94/Server/src/Services/Mapping/MappingUtil.cpp:5099-5163
Modified: sandbox/jng/common_decouple_v3/Server/src/Services/Mapping/RSMgFeatureReader.h
--- sandbox/jng/common_decouple_v3/Server/src/Services/Mapping/RSMgFeatureReader.h 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Server/src/Services/Mapping/RSMgFeatureReader.h 2019-02-05 13:44:22 UTC (rev 9475)
@@ -18,7 +18,7 @@
#ifndef RSMGFEATUREREADER_H
#define RSMGFEATUREREADER_H
-#include "RS_FeatureReader.h"
+#include "RS_FdoFeatureReader.h"
struct PropertyStub
@@ -34,7 +34,7 @@
class RS_InputStream;
//RS_FeatureReader implementation based on an MgFeatureReader
-class MG_SERVER_MAPPING_API RSMgFeatureReader : public RS_FeatureReader
+class MG_SERVER_MAPPING_API RSMgFeatureReader : public RS_FdoFeatureReader
public:
RSMgFeatureReader(MgFeatureReader* reader, MgFeatureService* svcFeature, MgResourceIdentifier* featResId, MgFeatureQueryOptions* options, const STRING& geomPropName);
Modified: sandbox/jng/common_decouple_v3/Server/src/Services/Rendering/FeaturePropRenderer.cpp
--- sandbox/jng/common_decouple_v3/Server/src/Services/Rendering/FeaturePropRenderer.cpp 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Server/src/Services/Rendering/FeaturePropRenderer.cpp 2019-02-05 13:44:22 UTC (rev 9475)
@@ -95,10 +95,11 @@
featureProps->Add(boundingBoxProperty);
+ RS_FdoFeatureReader* frdr = dynamic_cast<RS_FdoFeatureReader*>(feature);
//Add geometry if we're instructed to capture it
- if (m_bCaptureGeometry)
+ if (m_bCaptureGeometry && NULL != frdr)
- FdoPtr<FdoIFeatureReader> fr = feature->GetInternalReader();
+ FdoPtr<FdoIFeatureReader> fr = frdr->GetInternalReader();
const FdoString* geomName = m_fcInfo->geometry().c_str();
Ptr<MgGeometryProperty> geomProp = new MgGeometryProperty();
//Not using geometry prop name here as we want to specially denote the designated geometry value
Modified: sandbox/jng/common_decouple_v3/Server/src/Services/Rendering/ServerRenderingService.cpp
--- sandbox/jng/common_decouple_v3/Server/src/Services/Rendering/ServerRenderingService.cpp 2019-02-05 13:29:44 UTC (rev 9474)
+++ sandbox/jng/common_decouple_v3/Server/src/Services/Rendering/ServerRenderingService.cpp 2019-02-05 13:44:22 UTC (rev 9475)
@@ -31,6 +31,7 @@
#include "Box2D.h"
#include <cmath>
// Profile
@@ -1929,7 +1930,8 @@
selRenderer->StartLayer(&layerinfo, &fcinfo);
//Pass current layer xformer to renderer so it can transform any bbox data
selRenderer->SetLayerToMapTransform(xformer);
- ds.StylizeVectorLayer(vl, selRenderer, rsrdr.get(), NULL, scale, StylizeThatMany, selRenderer);
+ ds.StylizeVectorLayer(vl, selRenderer, rsrdr.get(), &evFactory, NULL, scale, StylizeThatMany, selRenderer);
// Clear the readers in case they are reused below
rdr = NULL;
@@ -1996,7 +1998,7 @@
rdr = m_svcFeature->SelectFeatures(featResId, vl->GetFeatureName(), options);
rsrdr.reset(new RSMgFeatureReader(rdr, m_svcFeature, featResId, options, vl->GetGeometry()));
selRenderer->PointTest(true);
- ds.StylizeVectorLayer(vl, selRenderer, rsrdr.get(), xformer, scale, StylizeThatMany, selRenderer);
+ ds.StylizeVectorLayer(vl, selRenderer, rsrdr.get(), &evFactory, xformer, scale, StylizeThatMany, selRenderer);
rdr = NULL;
@@ -2315,6 +2317,7 @@
pPRWsResult->SetRenderTime(MgTimerUtil::GetTime());
for (int i=watermarkInstances.GetCount()-1; i>=0; i--)
WatermarkInstance* instance = watermarkInstances.GetAt(i);
@@ -2359,7 +2362,7 @@
wdef->AdoptAppearance(instance->OrphanAppearanceOverride());
- ds->StylizeWatermark(dr, wdef, drawWidth, drawHeight, saveWidth, saveHeight);
+ ds->StylizeWatermark(dr, wdef, &evFactory, drawWidth, drawHeight, saveWidth, saveHeight);
if(NULL != pPRWsResult)
More information about the mapguide-commits
