[mapguide-commits] r9451 - in trunk/MgDev: . Server/src/Core Web/src/ApacheAgent Web/src/HttpHandler Web/src/JavaApi Web/src/JavaApiEx Web/src/PhpApi Web/src/WebApp Web/src/WebSupport cmake/configs
svn_mapguide at osgeo.org
Fri Jan 11 08:14:03 PST 2019
Author: jng
Date: 2019-01-11 08:14:03 -0800 (Fri, 11 Jan 2019)
New Revision: 9451
trunk/MgDev/Server/src/Core/CMakeLists.txt
trunk/MgDev/Web/src/ApacheAgent/CMakeLists.txt
trunk/MgDev/Web/src/HttpHandler/CMakeLists.txt
trunk/MgDev/Web/src/JavaApi/CMakeLists.txt
trunk/MgDev/Web/src/JavaApiEx/CMakeLists.txt
trunk/MgDev/Web/src/PhpApi/CMakeLists.txt
trunk/MgDev/Web/src/WebApp/CMakeLists.txt
trunk/MgDev/Web/src/WebSupport/CMakeLists.txt
trunk/MgDev/cmake/configs/webconfig.ini.in
trunk/MgDev/cmake_linuxapt.sh
#2785: Ensure that web tier libs have RPATHS pointing back up to common libs and ensure absolute prefix is being stamped to webconfig.ini
Modified: trunk/MgDev/Server/src/Core/CMakeLists.txt
--- trunk/MgDev/Server/src/Core/CMakeLists.txt 2019-01-11 16:05:46 UTC (rev 9450)
+++ trunk/MgDev/Server/src/Core/CMakeLists.txt 2019-01-11 16:14:03 UTC (rev 9451)
@@ -83,18 +83,20 @@
########### BEGIN Development/Testing environment setup #############
file(GLOB_RECURSE UNIT_TEST_FILES "${MG_UNIT_TEST_DATA_DIR}/*.*")
file(COPY ${UNIT_TEST_FILES} DESTINATION ${CMAKE_CURRENT_BINARY_DIR}/../UnitTestFiles)
-file(COPY ${CMAKE_CURRENT_BINARY_DIR}/../UnitTestFiles/Shuttle.zip DESTINATION ${CMAKE_CURRENT_BINARY_DIR}/../UnitTestFiles/World.mgp)
+# Awkward, can't copy a file to a target file name
+file(COPY ${CMAKE_CURRENT_BINARY_DIR}/../UnitTestFiles/Shuttle.zip DESTINATION ${CMAKE_CURRENT_BINARY_DIR}/../UnitTestFilesTemp)
+file(RENAME ${CMAKE_CURRENT_BINARY_DIR}/../UnitTestFilesTemp/Shuttle.zip ${CMAKE_CURRENT_BINARY_DIR}/../UnitTestFiles/World.mgp)
# Symlink the built copy to facilitate inner loop testing/debugging
# The actual symlink installation is done in the UnitTesting CMakeLists.txt
execute_process(COMMAND ln -sf ${CMAKE_CURRENT_BINARY_DIR}/../UnitTesting/libMgUnitTesting.so ${CMAKE_CURRENT_BINARY_DIR}/libMgUnitTesting.so)
-set(ORIG_MG_INSTALL_SERVER_PREFIX "${MG_INSTALL_SERVER_PREFIX}")
-set(ORIG_MG_INSTALL_COORDSYS_PREFIX "${MG_INSTALL_COORDSYS_PREFIX}")
-set(MG_INSTALL_SERVER_PREFIX "${CMAKE_CURRENT_BINARY_DIR}")
-set(MG_INSTALL_COORDSYS_PREFIX "${MG_OEM_ROOT_BUILD_DIR}/CsMapLibrary/CsMap_Install/Dictionaries")
+set(ORIG_MG_INSTALL_SERVER_PREFIX_ABS "${MG_INSTALL_SERVER_PREFIX_ABS}")
+set(ORIG_MG_INSTALL_COORDSYS_PREFIX_ABS "${MG_INSTALL_COORDSYS_PREFIX_ABS}")
+set(MG_INSTALL_SERVER_PREFIX_ABS "${CMAKE_CURRENT_BINARY_DIR}")
+set(MG_INSTALL_COORDSYS_PREFIX_ABS "${MG_OEM_ROOT_BUILD_DIR}/CsMapLibrary/CsMap_Install/Dictionaries")
configure_file(${CMAKE_MODULE_PATH}/../configs/serverconfig.ini.in ${CMAKE_CURRENT_BINARY_DIR}/serverconfig.ini)
-set(MG_INSTALL_SERVER_PREFIX "${ORIG_MG_INSTALL_SERVER_PREFIX}")
-set(MG_INSTALL_COORDSYS_PREFIX "${ORIG_MG_INSTALL_COORDSYS_PREFIX}")
+set(MG_INSTALL_SERVER_PREFIX_ABS "${ORIG_MG_INSTALL_SERVER_PREFIX_ABS}")
+set(MG_INSTALL_COORDSYS_PREFIX_ABS "${ORIG_MG_INSTALL_COORDSYS_PREFIX_ABS}")
file(COPY ${MG_COMMON_DIR}/MapGuideCommon/Resources DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
file(COPY ${MG_COMMON_DIR}/Schema DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
Modified: trunk/MgDev/Web/src/ApacheAgent/CMakeLists.txt
--- trunk/MgDev/Web/src/ApacheAgent/CMakeLists.txt 2019-01-11 16:05:46 UTC (rev 9450)
+++ trunk/MgDev/Web/src/ApacheAgent/CMakeLists.txt 2019-01-11 16:14:03 UTC (rev 9451)
@@ -48,4 +48,11 @@
# Make sure this doesn't have the "lib" prefix
-set_target_properties(mod_mgmapagent${MG_VERSION_SUFFIX} PROPERTIES PREFIX "")
\ No newline at end of file
+set_target_properties(mod_mgmapagent${MG_VERSION_SUFFIX} PROPERTIES PREFIX "")
+# Set RPATH to avoid needing to use LD_LIBRARY_PATH in various configs
+if(MG_CPU EQUAL 64)
+ set_target_properties(mod_mgmapagent${MG_VERSION_SUFFIX} PROPERTIES INSTALL_RPATH "$ORIGIN:$ORIGIN/../../lib64")
+else(MG_CPU EQUAL 64)
+ set_target_properties(mod_mgmapagent${MG_VERSION_SUFFIX} PROPERTIES INSTALL_RPATH "$ORIGIN:$ORIGIN/../../lib")
+endif(MG_CPU EQUAL 64)
Modified: trunk/MgDev/Web/src/HttpHandler/CMakeLists.txt
--- trunk/MgDev/Web/src/HttpHandler/CMakeLists.txt 2019-01-11 16:05:46 UTC (rev 9450)
+++ trunk/MgDev/Web/src/HttpHandler/CMakeLists.txt 2019-01-11 16:14:03 UTC (rev 9451)
@@ -30,4 +30,11 @@
if (INTERNAL_JSON)
install(FILES ${MG_OEM_WORK_DIR}/jsoncpp/lib/liblib_json.so DESTINATION ${LIB_INSTALL_DIR})
-endif (INTERNAL_JSON)
+endif (INTERNAL_JSON)
+ set_target_properties(MgHttpHandler${MG_VERSION_SUFFIX} PROPERTIES INSTALL_RPATH "$ORIGIN:$ORIGIN/../../lib64")
+ set_target_properties(MgHttpHandler${MG_VERSION_SUFFIX} PROPERTIES INSTALL_RPATH "$ORIGIN:$ORIGIN/../../lib")
Modified: trunk/MgDev/Web/src/JavaApi/CMakeLists.txt
--- trunk/MgDev/Web/src/JavaApi/CMakeLists.txt 2019-01-11 16:05:46 UTC (rev 9450)
+++ trunk/MgDev/Web/src/JavaApi/CMakeLists.txt 2019-01-11 16:14:03 UTC (rev 9451)
@@ -86,4 +86,11 @@
file(COPY "java.i" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
file(COPY "getclassid.code" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
file(COPY "catchall.code" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
-file(COPY "org" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
+file(COPY "org" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
+ set_target_properties(MapGuideJavaApi${MG_VERSION_SUFFIX} PROPERTIES INSTALL_RPATH "$ORIGIN:$ORIGIN/../../lib64")
+ set_target_properties(MapGuideJavaApi${MG_VERSION_SUFFIX} PROPERTIES INSTALL_RPATH "$ORIGIN:$ORIGIN/../../lib")
Modified: trunk/MgDev/Web/src/JavaApiEx/CMakeLists.txt
--- trunk/MgDev/Web/src/JavaApiEx/CMakeLists.txt 2019-01-11 16:05:46 UTC (rev 9450)
+++ trunk/MgDev/Web/src/JavaApiEx/CMakeLists.txt 2019-01-11 16:14:03 UTC (rev 9451)
@@ -89,4 +89,11 @@
# Specific for JavaApiEx
-file(COPY "javaextensions.i" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
+file(COPY "javaextensions.i" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
+ set_target_properties(MapGuideJavaApiEx${MG_VERSION_SUFFIX} PROPERTIES INSTALL_RPATH "$ORIGIN:$ORIGIN/../../lib64")
+ set_target_properties(MapGuideJavaApiEx${MG_VERSION_SUFFIX} PROPERTIES INSTALL_RPATH "$ORIGIN:$ORIGIN/../../lib")
Modified: trunk/MgDev/Web/src/PhpApi/CMakeLists.txt
--- trunk/MgDev/Web/src/PhpApi/CMakeLists.txt 2019-01-11 16:05:46 UTC (rev 9450)
+++ trunk/MgDev/Web/src/PhpApi/CMakeLists.txt 2019-01-11 16:14:03 UTC (rev 9451)
@@ -76,4 +76,11 @@
file(COPY "php.i" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
-file(COPY "catchall.code" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
+file(COPY "catchall.code" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
+ set_target_properties(php_MapGuideApi${MG_VERSION_SUFFIX} PROPERTIES INSTALL_RPATH "$ORIGIN:$ORIGIN/../../lib64")
+ set_target_properties(php_MapGuideApi${MG_VERSION_SUFFIX} PROPERTIES INSTALL_RPATH "$ORIGIN:$ORIGIN/../../lib")
Modified: trunk/MgDev/Web/src/WebApp/CMakeLists.txt
--- trunk/MgDev/Web/src/WebApp/CMakeLists.txt 2019-01-11 16:05:46 UTC (rev 9450)
+++ trunk/MgDev/Web/src/WebApp/CMakeLists.txt 2019-01-11 16:14:03 UTC (rev 9451)
@@ -48,4 +48,11 @@
MgGeometry${MG_VERSION_SUFFIX}
MgPlatformBase${MG_VERSION_SUFFIX}
MgMapGuideCommon${MG_VERSION_SUFFIX}
+ set_target_properties(MgWebApp${MG_VERSION_SUFFIX} PROPERTIES INSTALL_RPATH "$ORIGIN:$ORIGIN/../../lib64")
+ set_target_properties(MgWebApp${MG_VERSION_SUFFIX} PROPERTIES INSTALL_RPATH "$ORIGIN:$ORIGIN/../../lib")
Modified: trunk/MgDev/Web/src/WebSupport/CMakeLists.txt
--- trunk/MgDev/Web/src/WebSupport/CMakeLists.txt 2019-01-11 16:05:46 UTC (rev 9450)
+++ trunk/MgDev/Web/src/WebSupport/CMakeLists.txt 2019-01-11 16:14:03 UTC (rev 9451)
@@ -18,4 +18,11 @@
MgFoundation${MG_VERSION_SUFFIX}
+ set_target_properties(MgWebSupport${MG_VERSION_SUFFIX} PROPERTIES INSTALL_RPATH "$ORIGIN:$ORIGIN/../../lib64")
+ set_target_properties(MgWebSupport${MG_VERSION_SUFFIX} PROPERTIES INSTALL_RPATH "$ORIGIN:$ORIGIN/../../lib")
Modified: trunk/MgDev/cmake/configs/webconfig.ini.in
--- trunk/MgDev/cmake/configs/webconfig.ini.in 2019-01-11 16:05:46 UTC (rev 9450)
+++ trunk/MgDev/cmake/configs/webconfig.ini.in 2019-01-11 16:14:03 UTC (rev 9451)
@@ -61,7 +61,7 @@
MentorDictionaryPath = @MG_INSTALL_COORDSYS_PREFIX_ABS@
ResourcesPath = @MG_WWWROOT_ABS@/Resources/
TcpIpMtu = 1460
-TempPath = @MG_WWWROOT_ABS@/Temp/
+TempPath = @MG_INSTALL_WEB_PREFIX_ABS@/Temp/
FailoverRetryTime = 1
[AdministrativeConnectionProperties]
Modified: trunk/MgDev/cmake_linuxapt.sh
--- trunk/MgDev/cmake_linuxapt.sh 2019-01-11 16:05:46 UTC (rev 9450)
+++ trunk/MgDev/cmake_linuxapt.sh 2019-01-11 16:14:03 UTC (rev 9451)
@@ -226,6 +226,9 @@
ant deploy -Ddeploy.home=${MG_INSTALL_WEB_PREFIX}/www/fusion
chown daemon:daemon "${MG_INSTALL_WEB_PREFIX}/www/fusion/lib/tcpdf/cache"
cp -R "${SOURCE_DIR}/Oem/fusionMG/templates" "${MG_INSTALL_WEB_PREFIX}/www/fusion"
+# Since we're here, set up the temp dir and chown that as well
+mkdir -p "${MG_INSTALL_WEB_PREFIX}/Temp"
+chown daemon:daemon "${MG_INSTALL_WEB_PREFIX}/Temp"
cp -f "$OEM_WORK_DIR/env_vars.stage1.sh" "$OEM_WORK_DIR/env_vars.sh"
# append vars to setup script
More information about the mapguide-commits
