[mapguide-commits] r9462 - trunk/MgDev/Common/Renderers
svn_mapguide at osgeo.org
Mon Jan 21 07:30:07 PST 2019
Author: jng
Date: 2019-01-21 07:30:06 -0800 (Mon, 21 Jan 2019)
New Revision: 9462
trunk/MgDev/Common/Renderers/AGGImageIO.cpp
#2792: Fix up libpng usage in AGGImageIO if libpng >= 1.4.0
Modified: trunk/MgDev/Common/Renderers/AGGImageIO.cpp
--- trunk/MgDev/Common/Renderers/AGGImageIO.cpp 2019-01-21 14:15:31 UTC (rev 9461)
+++ trunk/MgDev/Common/Renderers/AGGImageIO.cpp 2019-01-21 15:30:06 UTC (rev 9462)
@@ -32,6 +32,12 @@
#include "MapQuantization.h"
#include <assert.h>
+//Polyfill some libpng typedefs if libpng >= 1.4.0
+#if (PNG_LIBPNG_VER >= 10400)
+#define png_infopp_NULL NULL
+#define int_p_NULL NULL
+#endif
#ifdef _DEBUG_PNG8
#define myassert(COND,L,F) if (!(COND)){ printf("(%d) failed assertion in %d %s", GetCurrentThreadId(), L,F); throw new exception(); }
#else
@@ -470,7 +476,13 @@
/* Expand grayscale images to the full 8 bits from 1, 2, or 4 bits/pixel */
if (color_type == PNG_COLOR_TYPE_GRAY && bit_depth < 8)
- png_set_gray_1_2_4_to_8(png_ptr);
+ png_set_expand_gray_1_2_4_to_8(png_ptr);
+#else
+ png_set_gray_1_2_4_to_8(png_ptr);
+#endif
/* Expand paletted or RGB images with transparency to full alpha channels
* so the data will be available as RGBA quartets.
More information about the mapguide-commits
