[mapguide-commits] r9543 - in sandbox/jng/tiling_v3: Server/src/PostBuild Server/src/UnitTesting UnitTest/TestData/TileService
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue Jun 11 06:44:35 PDT 2019
Author: jng
Date: 2019-06-11 06:44:35 -0700 (Tue, 11 Jun 2019)
New Revision: 9543
Added:
   sandbox/jng/tiling_v3/UnitTest/TestData/TileService/UT_LinkedTileSetXYZ.mdf
   sandbox/jng/tiling_v3/Server/src/PostBuild/PostBuild.mak
   sandbox/jng/tiling_v3/Server/src/UnitTesting/TestMappingService.cpp
Add CreateRuntimeMap test cases involving map definitionss that link to default and XYZ tile sets.
Modified: sandbox/jng/tiling_v3/Server/src/PostBuild/PostBuild.mak
--- sandbox/jng/tiling_v3/Server/src/PostBuild/PostBuild.mak	2019-06-11 13:29:07 UTC (rev 9542)
+++ sandbox/jng/tiling_v3/Server/src/PostBuild/PostBuild.mak	2019-06-11 13:44:35 UTC (rev 9543)
@@ -170,6 +170,7 @@
         ..\..\bin\UnitTestFiles\UT_BaseMap_Metatiled.tsd \
         ..\..\bin\UnitTestFiles\UT_XYZ_Metatiled.tsd \
         ..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf \
+        ..\..\bin\UnitTestFiles\UT_LinkedTileSetXYZ.mdf \
         ..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf \
         ..\..\bin\UnitTestFiles\UT_Parcels.fs \
         ..\..\bin\UnitTestFiles\UT_Parcels.ldf \
@@ -450,6 +451,7 @@
@@ -730,6 +732,7 @@
@@ -1010,6 +1013,7 @@
@@ -1163,6 +1167,7 @@
     if EXIST ..\..\bin\UnitTestFiles\UT_BaseMap_Metatiled.tsd       del /F ..\..\bin\UnitTestFiles\UT_BaseMap_Metatiled.tsd
     if EXIST ..\..\bin\UnitTestFiles\UT_XYZ_Metatiled.tsd           del /F ..\..\bin\UnitTestFiles\UT_XYZ_Metatiled.tsd
     if EXIST ..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf           del /F ..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf
+    if EXIST ..\..\bin\UnitTestFiles\UT_LinkedTileSetXYZ.mdf        del /F ..\..\bin\UnitTestFiles\UT_LinkedTileSetXYZ.mdf
     if EXIST ..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf        del /F ..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf
     if EXIST ..\..\bin\UnitTestFiles\UT_Parcels.fs                  del /F ..\..\bin\UnitTestFiles\UT_Parcels.fs
     if EXIST ..\..\bin\UnitTestFiles\UT_Parcels.ldf                 del /F ..\..\bin\UnitTestFiles\UT_Parcels.ldf
@@ -1311,6 +1316,7 @@
@@ -1459,6 +1465,7 @@
@@ -1605,6 +1612,7 @@
@@ -1878,6 +1886,7 @@
@@ -2151,6 +2160,7 @@
@@ -2424,6 +2434,7 @@
@@ -2697,6 +2708,7 @@
@@ -2843,6 +2855,7 @@
@@ -2984,6 +2997,7 @@
@@ -3125,6 +3139,7 @@
@@ -3264,6 +3279,7 @@
@@ -3415,6 +3431,7 @@
 "..\..\..\UnitTest\TestData\TileService\UT_BaseMap_Metatiled.tsd" :
 "..\..\..\UnitTest\TestData\TileService\UT_XYZ_Metatiled.tsd" :
 "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSet.mdf" :
+"..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSetXYZ.mdf" :
 "..\..\..\UnitTest\TestData\TileService\UT_StylizationFuncs.mdf" :
 "..\..\..\UnitTest\TestData\TileService\UT_Parcels.fs" :
 "..\..\..\UnitTest\TestData\TileService\UT_Parcels.ldf" :
@@ -3698,6 +3715,10 @@
     if NOT EXIST ..\..\bin\UnitTestFiles\nul mkdir ..\..\bin\UnitTestFiles
     if EXIST "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSet.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSet.mdf" ..\..\bin\UnitTestFiles\
+..\..\bin\UnitTestFiles\UT_LinkedTileSetXYZ.mdf : "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSetXYZ.mdf"
+    if NOT EXIST ..\..\bin\UnitTestFiles\nul mkdir ..\..\bin\UnitTestFiles
+    if EXIST "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSetXYZ.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSetXYZ.mdf" ..\..\bin\UnitTestFiles\
 ..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf : "..\..\..\UnitTest\TestData\TileService\UT_StylizationFuncs.mdf"
     if EXIST "..\..\..\UnitTest\TestData\TileService\UT_StylizationFuncs.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_StylizationFuncs.mdf" ..\..\bin\UnitTestFiles\
Modified: sandbox/jng/tiling_v3/Server/src/UnitTesting/TestMappingService.cpp
--- sandbox/jng/tiling_v3/Server/src/UnitTesting/TestMappingService.cpp	2019-06-11 13:29:07 UTC (rev 9542)
+++ sandbox/jng/tiling_v3/Server/src/UnitTesting/TestMappingService.cpp	2019-06-11 13:44:35 UTC (rev 9543)
@@ -202,6 +202,11 @@
         Ptr<MgByteReader> mdfrdr2 = mdfsrc2->GetReader();
         m_svcResource->SetResource(mapres2, mdfrdr2, NULL);
+        Ptr<MgResourceIdentifier> mapres3 = new MgResourceIdentifier(L"Library://UnitTests/Maps/LinkedTileSetXYZ.MapDefinition");
+        Ptr<MgByteSource> mdfsrc3 = new MgByteSource(L"../UnitTestFiles/UT_LinkedTileSetXYZ.mdf", false);
+        Ptr<MgByteReader> mdfrdr3 = mdfsrc3->GetReader();
+        m_svcResource->SetResource(mapres3, mdfrdr3, NULL);
         Ptr<MgResourceIdentifier> tilesetres1 = new MgResourceIdentifier(L"Library://UnitTests/TileSets/Sheboygan.TileSetDefinition");
         Ptr<MgByteSource> tsdsrc1 = new MgByteSource(L"../UnitTestFiles/UT_BaseMap.tsd", false);
         Ptr<MgByteReader> tsdrdr1 = tsdsrc1->GetReader();
@@ -291,6 +296,9 @@
         Ptr<MgResourceIdentifier> mapres2 = new MgResourceIdentifier(L"Library://UnitTests/Maps/LinkedTileSet.MapDefinition");
         m_svcResource->DeleteResource(mapres2);
+        m_svcResource->DeleteResource(mapres3);
         m_svcResource->DeleteResource(tilesetres1);
@@ -340,6 +348,8 @@
         //make a runtime map
         Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan.MapDefinition");
+        Ptr<MgResourceIdentifier> mdfLinkedRes = new MgResourceIdentifier(L"Library://UnitTests/Maps/LinkedTileSet.MapDefinition");
+        Ptr<MgResourceIdentifier> mdfLinkedXYZRes = new MgResourceIdentifier(L"Library://UnitTests/Maps/LinkedTileSetXYZ.MapDefinition");
         STRING format = MgImageFormats::Png;
         //call the API
         Ptr<MgByteReader> rtMap = m_svcMapping->CreateRuntimeMap(mdfres, L"UnitTestSheboygan1", m_session, format, 16, 16, 0, 25, schemaVersion);
@@ -426,6 +436,14 @@
             rtMap = m_svcMapping->CreateRuntimeMap(tsdRes, L"UnitTestSheboygan7", m_session, format, 32, 32, (1 | 2 | 4), 25, schemaVersion);
             sink = new MgByteSink(rtMap);
             sink->ToFile(L"../UnitTestFiles/RuntimeMapFromTileSetLayersAndGroupsWithIconsAndFeatureSourcePNG832x32" + suffix + L".xml");
+            rtMap = m_svcMapping->CreateRuntimeMap(mdfLinkedRes, L"UnitTestSheboygan8", m_session, format, 32, 32, (1 | 2 | 4), 25, schemaVersion);
+            sink = new MgByteSink(rtMap);
+            sink->ToFile(L"../UnitTestFiles/RuntimeMapFromLinkedTileSetLayersAndGroupsWithIconsAndFeatureSourcePNG832x32" + suffix + L".xml");
+            rtMap = m_svcMapping->CreateRuntimeMap(mdfLinkedXYZRes, L"UnitTestSheboygan9", m_session, format, 32, 32, (1 | 2 | 4), 25, schemaVersion);
+            sink->ToFile(L"../UnitTestFiles/RuntimeMapFromLinkedXYZTileSetLayersAndGroupsWithIconsAndFeatureSourcePNG832x32" + suffix + L".xml");
     catch(MgException* e)
Added: sandbox/jng/tiling_v3/UnitTest/TestData/TileService/UT_LinkedTileSetXYZ.mdf
--- sandbox/jng/tiling_v3/UnitTest/TestData/TileService/UT_LinkedTileSetXYZ.mdf	                        (rev 0)
+++ sandbox/jng/tiling_v3/UnitTest/TestData/TileService/UT_LinkedTileSetXYZ.mdf	2019-06-11 13:44:35 UTC (rev 9543)
@@ -0,0 +1,25 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<MapDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="MapDefinition-3.0.0.xsd" version="3.0.0">
+  <Name>Base Map linked to Tile Set</Name>
+  <CoordinateSystem>PROJCS["WGS84.PseudoMercator",GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137.000,298.25722293]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Popular Visualisation Pseudo Mercator"],PARAMETER["false_easting",0.000],PARAMETER["false_northing",0.000],PARAMETER["central_meridian",0.00000000000000],UNIT["Meter",1.00000000000000]]</CoordinateSystem>
+  <Extents>
+    <MinX>-9773613.7373958</MinX>
+    <MaxX>-9758770.5921973</MaxX>
+    <MinY>5417109.9090669</MinY>
+    <MaxY>5435129.2308673</MaxY>
+  </Extents>
+  <BackgroundColor>FFF7E1D2</BackgroundColor>
+  <MapLayer>
+    <Name>RoadCenterLines</Name>
+    <ResourceId>Library://UnitTests/Layers/RoadCenterLines.LayerDefinition</ResourceId>
+    <Selectable>false</Selectable>
+    <ShowInLegend>true</ShowInLegend>
+    <LegendLabel>Road CenterLines</LegendLabel>
+    <ExpandInLegend>false</ExpandInLegend>
+    <Visible>true</Visible>
+    <Group></Group>
+  </MapLayer>
+  <TileSetSource>
+    <ResourceId>Library://UnitTests/TileSets/XYZ.TileSetDefinition</ResourceId>
+  </TileSetSource>
+</MapDefinition>
More information about the mapguide-commits mailing list
