[mapguide-commits] r9546 - in sandbox/jng/mvt/Common: CoordinateSystem Geometry Geometry/Spatial
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Jun 12 09:00:27 PDT 2019
Author: jng
Date: 2019-06-12 09:00:27 -0700 (Wed, 12 Jun 2019)
New Revision: 9546
Added:
   sandbox/jng/mvt/Common/Geometry/Spatial/SpatialUtilities.h
Removed:
   sandbox/jng/mvt/Common/Geometry/Spatial/SpatialUtility.h
   sandbox/jng/mvt/Common/CoordinateSystem/CoordSysGrids.cpp
   sandbox/jng/mvt/Common/CoordinateSystem/CoordSysMgrsZone.cpp
   sandbox/jng/mvt/Common/Geometry/ArcSegment.cpp
   sandbox/jng/mvt/Common/Geometry/GeosUtil.cpp
   sandbox/jng/mvt/Common/Geometry/Spatial/SpatialUtility.cpp
   sandbox/jng/mvt/Common/Geometry/Spatial/SpatialUtilityCircularArc.cpp
Rename SpatialUtility.h to SpatialUtilities.h to avoid collision with FDO's spatial utility header of the same name (and same relative path!)
Fix all affected usages.
Modified: sandbox/jng/mvt/Common/CoordinateSystem/CoordSysGrids.cpp
--- sandbox/jng/mvt/Common/CoordinateSystem/CoordSysGrids.cpp	2019-06-12 13:40:15 UTC (rev 9545)
+++ sandbox/jng/mvt/Common/CoordinateSystem/CoordSysGrids.cpp	2019-06-12 16:00:27 UTC (rev 9546)
@@ -20,7 +20,7 @@
 #include "CoordSysUtil.h"
 #include "CriticalSection.h"
 #include "Spatial/MathUtility.h"
-#include "Spatial/SpatialUtility.h"
+#include "Spatial/SpatialUtilities.h"
 #include "CoordSys.h"
 #include "CoordSysGrids.h"
Modified: sandbox/jng/mvt/Common/CoordinateSystem/CoordSysMgrsZone.cpp
--- sandbox/jng/mvt/Common/CoordinateSystem/CoordSysMgrsZone.cpp	2019-06-12 13:40:15 UTC (rev 9545)
+++ sandbox/jng/mvt/Common/CoordinateSystem/CoordSysMgrsZone.cpp	2019-06-12 16:00:27 UTC (rev 9546)
@@ -21,7 +21,7 @@
 #include "CriticalSection.h"    //for SmartCriticalClass
 #include "CoordSysOneGrid.h"
 #include "CoordSysMgrsZone.h"
Modified: sandbox/jng/mvt/Common/Geometry/ArcSegment.cpp
--- sandbox/jng/mvt/Common/Geometry/ArcSegment.cpp	2019-06-12 13:40:15 UTC (rev 9545)
+++ sandbox/jng/mvt/Common/Geometry/ArcSegment.cpp	2019-06-12 16:00:27 UTC (rev 9546)
@@ -16,7 +16,7 @@
 #include "GeometryCommon.h"
 // Construct a MgArcSegment object
Modified: sandbox/jng/mvt/Common/Geometry/GeosUtil.cpp
--- sandbox/jng/mvt/Common/Geometry/GeosUtil.cpp	2019-06-12 13:40:15 UTC (rev 9545)
+++ sandbox/jng/mvt/Common/Geometry/GeosUtil.cpp	2019-06-12 16:00:27 UTC (rev 9546)
@@ -25,7 +25,7 @@
 #include "Buffer/buffer.h"
 #include "GeosUtil.h"
 #include "GeometryExceptionDef.h"
 #include "GeometricEntityType.h"
 using namespace geos;
Copied: sandbox/jng/mvt/Common/Geometry/Spatial/SpatialUtilities.h (from rev 9545, sandbox/jng/mvt/Common/Geometry/Spatial/SpatialUtility.h)
--- sandbox/jng/mvt/Common/Geometry/Spatial/SpatialUtilities.h	                        (rev 0)
+++ sandbox/jng/mvt/Common/Geometry/Spatial/SpatialUtilities.h	2019-06-12 16:00:27 UTC (rev 9546)
@@ -0,0 +1,380 @@
+//  Copyright (C) 2004-2011 by Autodesk, Inc.
+//  This library is free software; you can redistribute it and/or
+//  modify it under the terms of version 2.1 of the GNU Lesser
+//  General Public License as published by the Free Software Foundation.
+//  This library is distributed in the hope that it will be useful,
+//  but WITHOUT ANY WARRANTY; without even the implied warranty of
+//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+//  Lesser General Public License for more details.
+//  You should have received a copy of the GNU Lesser General Public
+//  License along with this library; if not, write to the Free Software
+//  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
+#ifndef MgSpatialUtilities_H
+#define MgSpatialUtilities_H
+// NOTE: This header has been renamed to avoid collison with FDO's spatial utility header
+// of the same name and relative path!
+/// \cond INTERNAL
+/// \brief
+/// Spatial utility class.
+class MgSpatialUtility
+public:
+    /// Converts arcs to linestrings
+    static MgGeometry* TesselateCurve(MgGeometry* curve);
+    static MgGeometryComponent* TesselateGeometryComponent(MgGeometryComponent* curve);
+    /// \brief
+    /// Approximates a geometry, which may contain parametric curve components,
+    /// with a geometry that only contains straight, linear components.
+    /// \remarks
+    /// If the given geometry does not require approximation, this method returns
+    /// the input geometry, and thus avoids unnecessary object creation.
+    /// Tolerances are in same units as the geometry's ordinates.
+    /// If the given tolerances are both zero, a tesselated geometry is produced,
+    /// wherein arcs are represented using only their three defining positions.
+    /// Math performed is all in implicit Cartesian (rectilinear) coordinate system.
+    /// Measurement ("M") ordinates of interpolated positions undergo linear
+    /// interpolation from an arc's start position to end position (possibly disregarding
+    /// an "M" ordinate in the arc's mid position).
+    /// Unless the arc is too short for any interpolation, the "mid" point parameter
+    /// used to define arcs is not guaranteed to appear among interpolated points.
+    /// \param geometry
+    /// Input Geometry to approximate
+    /// \param maxSpacing
+    /// Input Maximum length of each line segment used to approximate parametric curves. Ignored if zero.
+    /// \param maxOffset
+    /// Input Maximum distance that a line segment may be from the curve that it approximates (error tolerance). Ignored if zero.
+    /// \param geometryFactory
+    /// Input Geometry factory for the creation of the approximated geometry.
+    /// \return
+    /// Returns An approximation of the given geometry.
+    static MgGeometry * ApproximateGeometryWithLineStrings(
+        MgGeometry * geometry,
+        double maxSpacing,
+        double maxOffset,
+        MgGeometryFactory* geometryFactory);
+    static bool ArePositionsEqualXYZ(
+        MgCoordinate * p1,
+        MgCoordinate * p2);
+    static bool ArePositionsEqualXY(
+    static double DistanceBetweenPositionsXYZ(
+    static double DistanceBetweenPositionsXY(
+    /// Unit normal from plane defined by vectors p1p2 to p2p3 using right-hand rule.
+    /// This will return (0,0,0) for parallel vectors (collinear points) or zero-length
+    /// vectors.
+    static MgCoordinate * UnitNormalVector(
+        MgCoordinate * p2,
+        MgCoordinate * p3);
+    static void AppendPositionToDistinctCollection(
+        MgCoordinateCollection * distinctPositions,
+        MgCoordinate * positionToAppend);
+    /// Return a new point with the location of the given point after rotation
+    /// about the given axis and center.
+    /// This method assumes that the involved data has XYZ dimensionality.
+    /// <p><b>Note:</b> "axisVector" must be a unit normal to the plane of rotation.
+    static MgCoordinate * RotatePosition(
+        MgCoordinate * position,
+        double angle,
+        MgCoordinate * axisVector,
+        MgCoordinate * center,
+        bool includeM,
+        double m);
+    static MgLinearRing* CurveRingToLinearRing(MgCurveRing* curveRing, double maxSpacing, double maxOffset);
+    static MgLinearSegment* ArcSegmentToLinearSegment(MgArcSegment* segment, double maxSpacing, double maxOffset);
+    /// <summary>
+    /// Extracts the greatest magnitude of the all the coordinates in a
+    /// coordinate collection.  Return value is always positive.
+    /// </summary>
+    /// <param name="coordinteIterator">
+    /// An iterator dervied from the target coordinate collection.
+    /// </param>
+    /// <returns>
+    /// Returns a positive value which is the largest magnitude of all
+    /// ordinates in the collection.
+    /// </returns>
+    /// <remarks>
+    /// Intended to be used to determine a suitable tolerance value for such
+    /// things as coordinate comparisons.
+    /// </remarks>
+    static double GreatestMagnitude (MgCoordinateIterator* coordinateIterator);
+    /// <summary>
+    /// Computes the intersection of two 2D line segments.  Intersection point,
+    /// if any, is returned in the provided result coordinate which (of course)
+    /// must already exist.  All point arguments are expected (not required)
+    /// to be MgCoordinateXY objects.
+    /// </summary>
+    /// <param name="result">
+    /// The calculated intersection point is returned in this variable which,
+    /// of course, must exist.  Coordinates of <c>result</c> remain unaltered
+    /// if an intersection does not exist.  Only X and Y are returned.
+    /// </param>
+    /// <param name="seg1From">
+    /// The initial point of the first line segment.
+    /// </param>
+    /// <param name="seg1To">
+    /// The end point of the first line segment.
+    /// </param>
+    /// <param name="seg2From">
+    /// The initial point of the second line segment.
+    /// </param>
+    /// <param name="seg2To">
+    /// The end point of the second line segment.
+    /// </param>
+    /// <param name="magnitude">
+    /// A value which represents the greatest coordinate value in the dataset
+    /// being processed.  Used to calculate an appropriate "fuzzy" value for
+    /// coordinate comparisions, etc.
+    /// </param>
+    /// <returns>
+    /// Return status of the intersection of the two segments as a bit map of
+    /// values as defined in <c>SpatialUtilityStatus.h</c>
+    /// </returns>
+    /// <remarks>
+    /// In determining if the intersection point resides on a line, an intersection
+    /// point identical to the 'to' point is considered on the line, but an
+    /// intersection point identical to the 'from' point is _NOT_ considered to be
+    /// on the line.  Such a convention is necessary to avoid the appearance
+    /// of two intersections when indeed there is only one when processing a
+    /// a line string, for example.
+    /// </remarks>
+    /// <exception cref="MgNullReferenceException">
+    /// Thrown if any argument is null
+    /// </exception>
+    static INT32 SegmentIntersection (MgCoordinate* result,MgCoordinate* seg1From,
+                                                           MgCoordinate* seg1To,
+                                                           MgCoordinate* seg2From,
+                                                           MgCoordinate* seg2To,
+                                                           double magnitude = 1.0E+10);
+    /// <summary>
+    /// Returns a collection of coordinates with all of the intersection points of
+    /// the provided segment with the polygon provided by the first argument.
+    /// </summary>
+    /// <param name="polyItr">
+    /// An iterator of the closed ring to which the provided segment is
+    /// intersected.
+    /// </param>
+    /// <param name="segFrom">
+    /// The initial point of the line segment to be intersected with the provided
+    /// closed ring.
+    /// </param>
+    /// <param name="segTo">
+    /// The ending point of the line segment to be intersected with the provided
+    /// closed ring.
+    /// </param>
+    /// <returns>
+    /// A new collection of <c>MgCoordinateXYM</c> points, one such point for each
+    /// intersection is returned.  This collection can be, and often is, an empty
+    /// collection.  A null pointer is never returned.<para>
+    /// The X and Y ordinates of each point in the returned collection represent
+    /// the actual location of the intersection.  The M ordinate will carry, as
+    /// a double, the status of the intersection as returned by the
+    /// <c>SegmentIntersection</c> function.
+    /// </returns>
+    static MgCoordinateCollection* PolySegIntersection (MgCoordinateIterator* polyItr,
+                                                        MgCoordinate* segFrom,
+                                                        MgCoordinate* segTo);
+    /// <summary>
+    /// Adds a coordinate to a coordinate collection such that the resulting
+    /// collection represents a collection of points in sequence from the
+    /// provided base point.
+    /// </summary>
+    /// <param name="collection">
+    /// The coordinate collection to which the <c>newPoint</c> is to be added.
+    /// </param>
+    /// <param name="newPoint">
+    /// The point to be added to the provided collection.
+    /// </param>
+    /// <param name="basePoint">
+    /// The base point which is used to order the collection.
+    /// </param>
+    /// <returns>
+    /// the index at which the insertion occurred.
+    /// </returns>
+    /// <remarks>
+    /// The purpose of this function is serve as a helper for the PolySegIntersection
+    /// function.  It enables PolySegIntersection to return a point collection such
+    /// that the points in the collection present an orderly sequence of points from
+    /// the provided base point.  Thus, if the original line segment provided to
+    /// PolySegIntersection proceeded in the south to north direction, the point
+    /// collection returned would also be returned in that order; regardless of the
+    /// shape of the polygon or the direction in which it proceeds.<para>
+    /// The determination as to the insertion point of <c>newPoint</c> is based solely
+    /// on the X and Y ordinates of <c>newPoint</c> and the points which already
+    /// exist in the provided collection.  The type of <c>newPoint</c> and the points
+    /// in the collection is immaterial.
+    /// </remarks>
+    static INT32 AddToCoordinateCollection (MgCoordinateCollection* collection,MgCoordinate* newPoint,
+        MgCoordinate* basePoint);
+    /// <summary>
+    /// Determines if the provided point is inside (or actually on) the closed
+    /// ring provided by the <c>polyItr</c> argument.
+    /// </summary>
+    /// An iterator of the closed ring which is the subject polygon.
+    /// </param>
+    /// <param name="queryPoint">
+    /// The 2D point whose status is to be determined.
+    /// </param>
+    /// <returns>
+    /// Returns zero if the query point is outside the closed ring, +1 if the
+    /// query point is precisely on the closed ring (per MgMathUtility::DblCmp),
+    /// or +2 if the query point is inside the closed ring.
+    /// </returns>
+    /// <remarks>
+    /// Currently, this function calculates the envelope of the provided closed
+    /// ring in order to determine a point which is known to be outside of the
+    /// closed ring.  An overloaded function which accepts a point known to be
+    /// outside the closed ring which is a lot faster is also available.
+    /// </remarks>
+    static INT32 PointIsInPolygon (MgCoordinateIterator* polyItr,MgCoordinate* queryPoint);
+    /// <summary>
+    /// Determines a point guaranteed to be ouside the provided polygon.
+    /// </summary>
+    /// </param>
+    /// <returns>
+    /// Returns an <c>MgCoordinateXY</c> point which is guaranteed to be ooutside
+    /// the provided polygon.
+    /// </returns>
+    static MgCoordinate* PointOutsidePolygon (MgCoordinateIterator* polyItr);
+    /// <summary>
+    /// </summary>
+    /// </param>
+    /// <param name="outsidePoint">
+    /// A 2D point which is known to be outside of the provided polygon.  Can
+    /// be obtained from <c>PointOutsidePolygon</c>.
+    /// </param>
+    /// <returns>
+    /// </returns>
+    /// <remarks>
+    /// This function requires that the calling module supply a point known to
+    /// be outside the polygon.  Thus, higher performance can be obtained when
+    /// multiple queries against the same polygon are required.
+    /// </remarks>
+    static INT32 PointIsInPolygon (MgCoordinateIterator* polyItr,MgCoordinate* outsidePoint,
+        MgCoordinate* queryPoint);
+    /// <summary>
+    /// Clips a line string to an arbitrary polygon returning a collection of line
+    /// strings which represent the portions of the provided line string which are
+    /// inside the provided closed ring.
+    /// </summary>
+    /// An iterator to the closed ring to which the provided line string is to be
+    /// clipped.
+    /// </param>
+    /// <param name="lineItr">
+    /// An iterator for the line string which is to be clipped.
+    /// </param>
+    /// <param name="includeCollinear">
+    /// A true value indicates that segments, and/or portions of segments,
+    /// of the line string to be clipped which are collinear with the clipping
+    /// boundary are to be considered to be inside the clipping boundary.  A
+    /// false value causes collinear segments (or portions thereof) to be
+    /// outside the clipping boundary and thus excluded from the returned
+    /// line string collection.
+    /// </param>
+    /// <returns>
+    /// A collection of line string objects which represents the portions of the
+    /// provided line string which are inside of the provided closed ring.  This
+    /// collection may be empty; a null pointer is never returned.
+    /// </returns>
+    static MgLineStringCollection* ClipStringToPolygon (MgCoordinateIterator* polyItr,
+                                                        MgCoordinateIterator* lineItr,
+                                                        bool includeCollinear = false);
+protected:
+    MgSpatialUtility() {};
+    ~MgSpatialUtility() {};
+    static void AppendLinearizedCurveSegmentsToDistinctCollection(
+        MgCurveSegmentCollection * curveSegments,
+        double maxOffset);
+    static void AppendPositionsToDistinctCollection(
+        MgCoordinateCollection * positionsToAppend);
+    // Values which are stored in the M member of the internally used point
+    // collection; i.e. the status of each point relative to the clip ploygon.
+    static const INT32 StringPointNotDetermined = 0;
+    static const INT32 StringPointIsOutside     = 1;
+    static const INT32 StringPointIsOnBoundary  = 2;
+    static const INT32 StringPointIsInside      = 3;
+    // Values which are stored in the Z member of the internally used point
+    // collection; i.e. the status of each segment relative to the clip
+    // ploygon.  The value stored refers to the segment which starts at
+    // the point in which the segment status is stored.
+    static const INT32 StringSegNotDetermined = 0;
+    static const INT32 StringSegIsOutside     = 1;
+    static const INT32 StringSegIsCollinear   = 2;
+    static const INT32 StringSegIsInside      = 3;
+    static MgCoordinateCollection* StringClipPhaseOne (MgCoordinateIterator* lineString,
+                                                       MgCoordinateIterator* itrPolygon);
+    static void StringClipPhaseTwo (MgCoordinateIterator* lineString,MgCoordinateIterator* itrPolygon);
+    static void StringClipPhaseThree (MgCoordinateIterator* lineString,MgCoordinateIterator* itrPolygon);
+    static MgLineStringCollection* StringClipPhaseFour (MgCoordinateIterator* lineString,bool collinear = false,
+        bool outside = false);
+/// \endcond
+#endif
Modified: sandbox/jng/mvt/Common/Geometry/Spatial/SpatialUtility.cpp
--- sandbox/jng/mvt/Common/Geometry/Spatial/SpatialUtility.cpp	2019-06-12 13:40:15 UTC (rev 9545)
+++ sandbox/jng/mvt/Common/Geometry/Spatial/SpatialUtility.cpp	2019-06-12 16:00:27 UTC (rev 9546)
@@ -19,7 +19,7 @@
 #include "MathUtility.h"
 #include "SpatialUtilityCircularArc.h"
-#include "SpatialUtility.h"
+#include "SpatialUtilities.h"
 #include "SpatialUtilityStatus.h"
 #define EPSILON 1e-10
Deleted: sandbox/jng/mvt/Common/Geometry/Spatial/SpatialUtility.h
--- sandbox/jng/mvt/Common/Geometry/Spatial/SpatialUtility.h	2019-06-12 13:40:15 UTC (rev 9545)
+++ sandbox/jng/mvt/Common/Geometry/Spatial/SpatialUtility.h	2019-06-12 16:00:27 UTC (rev 9546)
@@ -1,377 +0,0 @@
-//  Copyright (C) 2004-2011 by Autodesk, Inc.
-//  This library is free software; you can redistribute it and/or
-//  modify it under the terms of version 2.1 of the GNU Lesser
-//  General Public License as published by the Free Software Foundation.
-//  This library is distributed in the hope that it will be useful,
-//  but WITHOUT ANY WARRANTY; without even the implied warranty of
-//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
-//  Lesser General Public License for more details.
-//  You should have received a copy of the GNU Lesser General Public
-//  License along with this library; if not, write to the Free Software
-//  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
-#ifndef MgSpatialUtility_H
-#define MgSpatialUtility_H
-/// \cond INTERNAL
-/// \brief
-/// Spatial utility class.
-class MgSpatialUtility
-public:
-    /// Converts arcs to linestrings
-    static MgGeometry* TesselateCurve(MgGeometry* curve);
-    static MgGeometryComponent* TesselateGeometryComponent(MgGeometryComponent* curve);
-    /// \brief
-    /// Approximates a geometry, which may contain parametric curve components,
-    /// with a geometry that only contains straight, linear components.
-    /// \remarks
-    /// If the given geometry does not require approximation, this method returns
-    /// the input geometry, and thus avoids unnecessary object creation.
-    /// Tolerances are in same units as the geometry's ordinates.
-    /// If the given tolerances are both zero, a tesselated geometry is produced,
-    /// wherein arcs are represented using only their three defining positions.
-    /// Math performed is all in implicit Cartesian (rectilinear) coordinate system.
-    /// Measurement ("M") ordinates of interpolated positions undergo linear
-    /// interpolation from an arc's start position to end position (possibly disregarding
-    /// an "M" ordinate in the arc's mid position).
-    /// Unless the arc is too short for any interpolation, the "mid" point parameter
-    /// used to define arcs is not guaranteed to appear among interpolated points.
-    /// \param geometry
-    /// Input Geometry to approximate
-    /// \param maxSpacing
-    /// Input Maximum length of each line segment used to approximate parametric curves. Ignored if zero.
-    /// \param maxOffset
-    /// Input Maximum distance that a line segment may be from the curve that it approximates (error tolerance). Ignored if zero.
-    /// \param geometryFactory
-    /// Input Geometry factory for the creation of the approximated geometry.
-    /// \return
-    /// Returns An approximation of the given geometry.
-    static MgGeometry * ApproximateGeometryWithLineStrings(
-        MgGeometry * geometry,
-        double maxSpacing,
-        double maxOffset,
-        MgGeometryFactory* geometryFactory);
-    static bool ArePositionsEqualXYZ(
-        MgCoordinate * p1,
-        MgCoordinate * p2);
-    static bool ArePositionsEqualXY(
-    static double DistanceBetweenPositionsXYZ(
-    static double DistanceBetweenPositionsXY(
-    /// Unit normal from plane defined by vectors p1p2 to p2p3 using right-hand rule.
-    /// This will return (0,0,0) for parallel vectors (collinear points) or zero-length
-    /// vectors.
-    static MgCoordinate * UnitNormalVector(
-        MgCoordinate * p2,
-        MgCoordinate * p3);
-    static void AppendPositionToDistinctCollection(
-        MgCoordinateCollection * distinctPositions,
-        MgCoordinate * positionToAppend);
-    /// Return a new point with the location of the given point after rotation
-    /// about the given axis and center.
-    /// This method assumes that the involved data has XYZ dimensionality.
-    /// <p><b>Note:</b> "axisVector" must be a unit normal to the plane of rotation.
-    static MgCoordinate * RotatePosition(
-        MgCoordinate * position,
-        double angle,
-        MgCoordinate * axisVector,
-        MgCoordinate * center,
-        bool includeM,
-        double m);
-    static MgLinearRing* CurveRingToLinearRing(MgCurveRing* curveRing, double maxSpacing, double maxOffset);
-    static MgLinearSegment* ArcSegmentToLinearSegment(MgArcSegment* segment, double maxSpacing, double maxOffset);
-    /// <summary>
-    /// Extracts the greatest magnitude of the all the coordinates in a
-    /// coordinate collection.  Return value is always positive.
-    /// </summary>
-    /// <param name="coordinteIterator">
-    /// An iterator dervied from the target coordinate collection.
-    /// </param>
-    /// <returns>
-    /// Returns a positive value which is the largest magnitude of all
-    /// ordinates in the collection.
-    /// </returns>
-    /// <remarks>
-    /// Intended to be used to determine a suitable tolerance value for such
-    /// things as coordinate comparisons.
-    /// </remarks>
-    static double GreatestMagnitude (MgCoordinateIterator* coordinateIterator);
-    /// <summary>
-    /// Computes the intersection of two 2D line segments.  Intersection point,
-    /// if any, is returned in the provided result coordinate which (of course)
-    /// must already exist.  All point arguments are expected (not required)
-    /// to be MgCoordinateXY objects.
-    /// </summary>
-    /// <param name="result">
-    /// The calculated intersection point is returned in this variable which,
-    /// of course, must exist.  Coordinates of <c>result</c> remain unaltered
-    /// if an intersection does not exist.  Only X and Y are returned.
-    /// </param>
-    /// <param name="seg1From">
-    /// The initial point of the first line segment.
-    /// </param>
-    /// <param name="seg1To">
-    /// The end point of the first line segment.
-    /// </param>
-    /// <param name="seg2From">
-    /// The initial point of the second line segment.
-    /// </param>
-    /// <param name="seg2To">
-    /// The end point of the second line segment.
-    /// </param>
-    /// <param name="magnitude">
-    /// A value which represents the greatest coordinate value in the dataset
-    /// being processed.  Used to calculate an appropriate "fuzzy" value for
-    /// coordinate comparisions, etc.
-    /// </param>
-    /// <returns>
-    /// Return status of the intersection of the two segments as a bit map of
-    /// values as defined in <c>SpatialUtilityStatus.h</c>
-    /// </returns>
-    /// <remarks>
-    /// In determining if the intersection point resides on a line, an intersection
-    /// point identical to the 'to' point is considered on the line, but an
-    /// intersection point identical to the 'from' point is _NOT_ considered to be
-    /// on the line.  Such a convention is necessary to avoid the appearance
-    /// of two intersections when indeed there is only one when processing a
-    /// a line string, for example.
-    /// </remarks>
-    /// <exception cref="MgNullReferenceException">
-    /// Thrown if any argument is null
-    /// </exception>
-    static INT32 SegmentIntersection (MgCoordinate* result,MgCoordinate* seg1From,
-                                                           MgCoordinate* seg1To,
-                                                           MgCoordinate* seg2From,
-                                                           MgCoordinate* seg2To,
-                                                           double magnitude = 1.0E+10);
-    /// <summary>
-    /// Returns a collection of coordinates with all of the intersection points of
-    /// the provided segment with the polygon provided by the first argument.
-    /// </summary>
-    /// <param name="polyItr">
-    /// An iterator of the closed ring to which the provided segment is
-    /// intersected.
-    /// </param>
-    /// <param name="segFrom">
-    /// The initial point of the line segment to be intersected with the provided
-    /// closed ring.
-    /// </param>
-    /// <param name="segTo">
-    /// The ending point of the line segment to be intersected with the provided
-    /// closed ring.
-    /// </param>
-    /// <returns>
-    /// A new collection of <c>MgCoordinateXYM</c> points, one such point for each
-    /// intersection is returned.  This collection can be, and often is, an empty
-    /// collection.  A null pointer is never returned.<para>
-    /// The X and Y ordinates of each point in the returned collection represent
-    /// the actual location of the intersection.  The M ordinate will carry, as
-    /// a double, the status of the intersection as returned by the
-    /// <c>SegmentIntersection</c> function.
-    /// </returns>
-    static MgCoordinateCollection* PolySegIntersection (MgCoordinateIterator* polyItr,
-                                                        MgCoordinate* segFrom,
-                                                        MgCoordinate* segTo);
-    /// <summary>
-    /// Adds a coordinate to a coordinate collection such that the resulting
-    /// collection represents a collection of points in sequence from the
-    /// provided base point.
-    /// </summary>
-    /// <param name="collection">
-    /// The coordinate collection to which the <c>newPoint</c> is to be added.
-    /// </param>
-    /// <param name="newPoint">
-    /// The point to be added to the provided collection.
-    /// </param>
-    /// <param name="basePoint">
-    /// The base point which is used to order the collection.
-    /// </param>
-    /// <returns>
-    /// the index at which the insertion occurred.
-    /// </returns>
-    /// <remarks>
-    /// The purpose of this function is serve as a helper for the PolySegIntersection
-    /// function.  It enables PolySegIntersection to return a point collection such
-    /// that the points in the collection present an orderly sequence of points from
-    /// the provided base point.  Thus, if the original line segment provided to
-    /// PolySegIntersection proceeded in the south to north direction, the point
-    /// collection returned would also be returned in that order; regardless of the
-    /// shape of the polygon or the direction in which it proceeds.<para>
-    /// The determination as to the insertion point of <c>newPoint</c> is based solely
-    /// on the X and Y ordinates of <c>newPoint</c> and the points which already
-    /// exist in the provided collection.  The type of <c>newPoint</c> and the points
-    /// in the collection is immaterial.
-    /// </remarks>
-    static INT32 AddToCoordinateCollection (MgCoordinateCollection* collection,MgCoordinate* newPoint,
-        MgCoordinate* basePoint);
-    /// <summary>
-    /// Determines if the provided point is inside (or actually on) the closed
-    /// ring provided by the <c>polyItr</c> argument.
-    /// </summary>
-    /// An iterator of the closed ring which is the subject polygon.
-    /// </param>
-    /// <param name="queryPoint">
-    /// The 2D point whose status is to be determined.
-    /// </param>
-    /// <returns>
-    /// Returns zero if the query point is outside the closed ring, +1 if the
-    /// query point is precisely on the closed ring (per MgMathUtility::DblCmp),
-    /// or +2 if the query point is inside the closed ring.
-    /// </returns>
-    /// <remarks>
-    /// Currently, this function calculates the envelope of the provided closed
-    /// ring in order to determine a point which is known to be outside of the
-    /// closed ring.  An overloaded function which accepts a point known to be
-    /// outside the closed ring which is a lot faster is also available.
-    /// </remarks>
-    static INT32 PointIsInPolygon (MgCoordinateIterator* polyItr,MgCoordinate* queryPoint);
-    /// <summary>
-    /// Determines a point guaranteed to be ouside the provided polygon.
-    /// </summary>
-    /// </param>
-    /// <returns>
-    /// Returns an <c>MgCoordinateXY</c> point which is guaranteed to be ooutside
-    /// the provided polygon.
-    /// </returns>
-    static MgCoordinate* PointOutsidePolygon (MgCoordinateIterator* polyItr);
-    /// <summary>
-    /// </summary>
-    /// </param>
-    /// <param name="outsidePoint">
-    /// A 2D point which is known to be outside of the provided polygon.  Can
-    /// be obtained from <c>PointOutsidePolygon</c>.
-    /// </param>
-    /// <returns>
-    /// </returns>
-    /// <remarks>
-    /// This function requires that the calling module supply a point known to
-    /// be outside the polygon.  Thus, higher performance can be obtained when
-    /// multiple queries against the same polygon are required.
-    /// </remarks>
-    static INT32 PointIsInPolygon (MgCoordinateIterator* polyItr,MgCoordinate* outsidePoint,
-        MgCoordinate* queryPoint);
-    /// <summary>
-    /// Clips a line string to an arbitrary polygon returning a collection of line
-    /// strings which represent the portions of the provided line string which are
-    /// inside the provided closed ring.
-    /// </summary>
-    /// An iterator to the closed ring to which the provided line string is to be
-    /// clipped.
-    /// </param>
-    /// <param name="lineItr">
-    /// An iterator for the line string which is to be clipped.
-    /// </param>
-    /// <param name="includeCollinear">
-    /// A true value indicates that segments, and/or portions of segments,
-    /// of the line string to be clipped which are collinear with the clipping
-    /// boundary are to be considered to be inside the clipping boundary.  A
-    /// false value causes collinear segments (or portions thereof) to be
-    /// outside the clipping boundary and thus excluded from the returned
-    /// line string collection.
-    /// </param>
-    /// <returns>
-    /// A collection of line string objects which represents the portions of the
-    /// provided line string which are inside of the provided closed ring.  This
-    /// collection may be empty; a null pointer is never returned.
-    /// </returns>
-    static MgLineStringCollection* ClipStringToPolygon (MgCoordinateIterator* polyItr,
-                                                        MgCoordinateIterator* lineItr,
-                                                        bool includeCollinear = false);
-protected:
-    MgSpatialUtility() {};
-    ~MgSpatialUtility() {};
-    static void AppendLinearizedCurveSegmentsToDistinctCollection(
-        MgCurveSegmentCollection * curveSegments,
-        double maxOffset);
-    static void AppendPositionsToDistinctCollection(
-        MgCoordinateCollection * positionsToAppend);
-    // Values which are stored in the M member of the internally used point
-    // collection; i.e. the status of each point relative to the clip ploygon.
-    static const INT32 StringPointNotDetermined = 0;
-    static const INT32 StringPointIsOutside     = 1;
-    static const INT32 StringPointIsOnBoundary  = 2;
-    static const INT32 StringPointIsInside      = 3;
-    // Values which are stored in the Z member of the internally used point
-    // collection; i.e. the status of each segment relative to the clip
-    // ploygon.  The value stored refers to the segment which starts at
-    // the point in which the segment status is stored.
-    static const INT32 StringSegNotDetermined = 0;
-    static const INT32 StringSegIsOutside     = 1;
-    static const INT32 StringSegIsCollinear   = 2;
-    static const INT32 StringSegIsInside      = 3;
-    static MgCoordinateCollection* StringClipPhaseOne (MgCoordinateIterator* lineString,
-                                                       MgCoordinateIterator* itrPolygon);
-    static void StringClipPhaseTwo (MgCoordinateIterator* lineString,MgCoordinateIterator* itrPolygon);
-    static void StringClipPhaseThree (MgCoordinateIterator* lineString,MgCoordinateIterator* itrPolygon);
-    static MgLineStringCollection* StringClipPhaseFour (MgCoordinateIterator* lineString,bool collinear = false,
-        bool outside = false);
-/// \endcond
-#endif
Modified: sandbox/jng/mvt/Common/Geometry/Spatial/SpatialUtilityCircularArc.cpp
--- sandbox/jng/mvt/Common/Geometry/Spatial/SpatialUtilityCircularArc.cpp	2019-06-12 13:40:15 UTC (rev 9545)
+++ sandbox/jng/mvt/Common/Geometry/Spatial/SpatialUtilityCircularArc.cpp	2019-06-12 16:00:27 UTC (rev 9546)
@@ -16,7 +16,7 @@
More information about the mapguide-commits mailing list
