[mapguide-commits] r9484 - branches/3.1/MgDev/Web/src/HttpHandler
svn_mapguide at osgeo.org
Thu Mar 21 15:05:08 PDT 2019
Author: jng
Date: 2019-03-21 15:05:08 -0700 (Thu, 21 Mar 2019)
New Revision: 9484
Added:
branches/3.1/MgDev/Web/src/HttpHandler/LimitingReader.h
#2789: Add missing file
Added: branches/3.1/MgDev/Web/src/HttpHandler/LimitingReader.h
--- branches/3.1/MgDev/Web/src/HttpHandler/LimitingReader.h (rev 0)
+++ branches/3.1/MgDev/Web/src/HttpHandler/LimitingReader.h 2019-03-21 22:05:08 UTC (rev 9484)
@@ -0,0 +1,155 @@
+// Copyright (C) 2004-2019 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#ifndef LIMITING_FEATURE_READER_H
+#define LIMITING_FEATURE_READER_H
+#include "PlatformBase.h"
+class MgLimitingReader : public MgReader
+public:
+ MgLimitingReader(MgReader* inner, INT32 limit)
+ m_inner = SAFE_ADDREF(inner);
+ m_read = 0;
+ m_limit = limit;
+ virtual ~MgLimitingReader()
+ m_inner = NULL;
+ // Inherited via MgReader
+ virtual void Dispose()
+ delete this;
+ virtual bool ReadNext()
+ bool bRet = m_inner->ReadNext();
+ if (bRet)
+ m_read++;
+ if (m_read > m_limit) //Reached limit
+ return false;
+ return bRet;
+ virtual INT32 GetPropertyCount() { return m_inner->GetPropertyCount(); }
+ virtual STRING GetPropertyName(INT32 index) { return m_inner->GetPropertyName(index); }
+ virtual INT32 GetPropertyType(CREFSTRING propertyName) { return m_inner->GetPropertyType(propertyName); }
+ virtual INT32 GetPropertyType(INT32 index) { return m_inner->GetPropertyType(index); }
+ virtual bool IsNull(CREFSTRING propertyName) { return m_inner->IsNull(propertyName); }
+ virtual bool GetBoolean(CREFSTRING propertyName) { return m_inner->GetBoolean(propertyName); }
+ virtual BYTE GetByte(CREFSTRING propertyName) { return m_inner->GetByte(propertyName); }
+ virtual MgDateTime * GetDateTime(CREFSTRING propertyName) { return m_inner->GetDateTime(propertyName); }
+ virtual float GetSingle(CREFSTRING propertyName) { return m_inner->GetSingle(propertyName); }
+ virtual double GetDouble(CREFSTRING propertyName) { return m_inner->GetDouble(propertyName); }
+ virtual INT16 GetInt16(CREFSTRING propertyName) { return m_inner->GetInt16(propertyName); }
+ virtual INT32 GetInt32(CREFSTRING propertyName) { return m_inner->GetInt32(propertyName); }
+ virtual INT64 GetInt64(CREFSTRING propertyName) { return m_inner->GetInt64(propertyName); }
+ virtual STRING GetString(CREFSTRING propertyName) { return m_inner->GetString(propertyName); }
+ virtual MgByteReader * GetBLOB(CREFSTRING propertyName) { return m_inner->GetBLOB(propertyName); }
+ virtual MgByteReader * GetCLOB(CREFSTRING propertyName) { return m_inner->GetCLOB(propertyName); }
+ virtual MgByteReader * GetGeometry(CREFSTRING propertyName) { return m_inner->GetGeometry(propertyName); }
+ virtual MgRaster * GetRaster(CREFSTRING propertyName) { return m_inner->GetRaster(propertyName); }
+ virtual INT32 GetPropertyIndex(CREFSTRING propertyName) { return m_inner->GetPropertyIndex(propertyName); }
+ virtual bool IsNull(INT32 index) { return m_inner->IsNull(index); }
+ virtual bool GetBoolean(INT32 index) { return m_inner->GetBoolean(index); }
+ virtual BYTE GetByte(INT32 index) { return m_inner->GetByte(index); }
+ virtual MgDateTime * GetDateTime(INT32 index) { return m_inner->GetDateTime(index); }
+ virtual float GetSingle(INT32 index) { return m_inner->GetSingle(index); }
+ virtual double GetDouble(INT32 index) { return m_inner->GetDouble(index); }
+ virtual INT16 GetInt16(INT32 index) { return m_inner->GetInt16(index); }
+ virtual INT32 GetInt32(INT32 index) { return m_inner->GetInt32(index); }
+ virtual INT64 GetInt64(INT32 index) { return m_inner->GetInt64(index); }
+ virtual STRING GetString(INT32 index) { return m_inner->GetString(index); }
+ virtual MgByteReader * GetBLOB(INT32 index) { return m_inner->GetBLOB(index); }
+ virtual MgByteReader * GetCLOB(INT32 index) { return m_inner->GetCLOB(index); }
+ virtual MgByteReader * GetGeometry(INT32 index) { return m_inner->GetGeometry(index); }
+ virtual MgRaster * GetRaster(INT32 index) { return m_inner->GetRaster(index); }
+ virtual void Close() { m_inner->Close(); }
+ virtual INT32 GetReaderType() { return m_inner->GetReaderType(); };
+ virtual string GetBodyElementName() { return m_inner->GetBodyElementName(); }
+ virtual void ResponseStartUtf8(string & str) { return m_inner->ResponseStartUtf8(str); }
+ virtual void ResponseEndUtf8(string & str) { return m_inner->ResponseEndUtf8(str); }
+ virtual void BodyStartUtf8(string & str) { return m_inner->BodyStartUtf8(str); }
+ virtual void BodyEndUtf8(string & str) { return m_inner->BodyEndUtf8(str); }
+ virtual void HeaderToStringUtf8(string & str) { return m_inner->HeaderToStringUtf8(str); }
+ virtual void CurrentToStringUtf8(string & str) { return m_inner->CurrentToStringUtf8(str); }
+ virtual const wchar_t * GetString(CREFSTRING propertyName, INT32 & length) { return m_inner->GetString(propertyName, length); }
+ virtual void Serialize(MgStream * stream) { m_inner->Serialize(stream); }
+ virtual void Deserialize(MgStream * stream) { m_inner->Deserialize(stream); }
+ virtual MgByteReader * ToXml() { return m_inner->ToXml(); }
+ virtual std::string GetResponseElementName() { return m_inner->GetResponseElementName(); }
+private:
+ Ptr<MgReader> m_inner;
+ INT32 m_limit;
+ INT32 m_read;
+#endif
\ No newline at end of file
More information about the mapguide-commits
