[mapguide-commits] r9501 - in sandbox/jng/tiling_v2: Server/src/PostBuild Server/src/UnitTesting UnitTest/TestData/TileService
svn_mapguide at osgeo.org
Fri May 3 06:04:33 PDT 2019
Author: jng
Date: 2019-05-03 06:04:33 -0700 (Fri, 03 May 2019)
New Revision: 9501
Added:
sandbox/jng/tiling_v2/UnitTest/TestData/TileService/UT_BaseMap_OrigSize.tsd
sandbox/jng/tiling_v2/Server/src/PostBuild/PostBuild.mak
sandbox/jng/tiling_v2/Server/src/UnitTesting/TestTileService.cpp
Refine default provider metatile test to use starting col/row that is guaranteed to span multiple physical folders. This is a better reliable check to ensure the correct sub-tile paths from a metatile is correct.
Also in this test render the individual 16 tiles to allow for easy manual comparison against the metatile result.
Modified: sandbox/jng/tiling_v2/Server/src/PostBuild/PostBuild.mak
--- sandbox/jng/tiling_v2/Server/src/PostBuild/PostBuild.mak 2019-05-03 12:33:01 UTC (rev 9500)
+++ sandbox/jng/tiling_v2/Server/src/PostBuild/PostBuild.mak 2019-05-03 13:04:33 UTC (rev 9501)
@@ -166,6 +166,7 @@
..\..\bin\UnitTestFiles\UT_BaseMap.mdf \
..\..\bin\UnitTestFiles\UT_BaseMap.tsd \
..\..\bin\UnitTestFiles\UT_XYZ.tsd \
+ ..\..\bin\UnitTestFiles\UT_BaseMap_OrigSize.tsd \
..\..\bin\UnitTestFiles\UT_BaseMap_Metatiled.tsd \
..\..\bin\UnitTestFiles\UT_XYZ_Metatiled.tsd \
..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf \
@@ -445,6 +446,7 @@
@@ -724,6 +726,7 @@
@@ -1003,6 +1006,7 @@
@@ -1155,6 +1159,7 @@
if EXIST ..\..\bin\UnitTestFiles\UT_BaseMap.mdf del /F ..\..\bin\UnitTestFiles\UT_BaseMap.mdf
if EXIST ..\..\bin\UnitTestFiles\UT_BaseMap.tsd del /F ..\..\bin\UnitTestFiles\UT_BaseMap.tsd
if EXIST ..\..\bin\UnitTestFiles\UT_XYZ.tsd del /F ..\..\bin\UnitTestFiles\UT_XYZ.tsd
+ if EXIST ..\..\bin\UnitTestFiles\UT_BaseMap_OrigSize.tsd del /F ..\..\bin\UnitTestFiles\UT_BaseMap_OrigSize.tsd
if EXIST ..\..\bin\UnitTestFiles\UT_BaseMap_Metatiled.tsd del /F ..\..\bin\UnitTestFiles\UT_BaseMap_Metatiled.tsd
if EXIST ..\..\bin\UnitTestFiles\UT_XYZ_Metatiled.tsd del /F ..\..\bin\UnitTestFiles\UT_XYZ_Metatiled.tsd
if EXIST ..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf del /F ..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf
@@ -1302,6 +1307,7 @@
@@ -1449,6 +1455,7 @@
@@ -1594,6 +1601,7 @@
@@ -1866,6 +1874,7 @@
@@ -2138,6 +2147,7 @@
@@ -2410,6 +2420,7 @@
@@ -2682,6 +2693,7 @@
@@ -2827,6 +2839,7 @@
@@ -2967,6 +2980,7 @@
@@ -3107,6 +3121,7 @@
@@ -3245,6 +3260,7 @@
@@ -3395,6 +3411,7 @@
"..\..\..\UnitTest\TestData\TileService\UT_BaseMap.mdf" :
"..\..\..\UnitTest\TestData\TileService\UT_BaseMap.tsd" :
"..\..\..\UnitTest\TestData\TileService\UT_XYZ.tsd" :
+"..\..\..\UnitTest\TestData\TileService\UT_BaseMap_OrigSize.tsd" :
"..\..\..\UnitTest\TestData\TileService\UT_BaseMap_Metatiled.tsd" :
"..\..\..\UnitTest\TestData\TileService\UT_XYZ_Metatiled.tsd" :
"..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSet.mdf" :
@@ -3665,6 +3682,10 @@
if NOT EXIST ..\..\bin\UnitTestFiles\nul mkdir ..\..\bin\UnitTestFiles
if EXIST "..\..\..\UnitTest\TestData\TileService\UT_XYZ.tsd" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_XYZ.tsd" ..\..\bin\UnitTestFiles\
+..\..\bin\UnitTestFiles\UT_BaseMap_OrigSize.tsd : "..\..\..\UnitTest\TestData\TileService\UT_BaseMap_OrigSize.tsd"
+ if NOT EXIST ..\..\bin\UnitTestFiles\nul mkdir ..\..\bin\UnitTestFiles
+ if EXIST "..\..\..\UnitTest\TestData\TileService\UT_BaseMap_OrigSize.tsd" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_BaseMap_OrigSize.tsd" ..\..\bin\UnitTestFiles\
..\..\bin\UnitTestFiles\UT_BaseMap_Metatiled.tsd : "..\..\..\UnitTest\TestData\TileService\UT_BaseMap_Metatiled.tsd"
if EXIST "..\..\..\UnitTest\TestData\TileService\UT_BaseMap_Metatiled.tsd" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_BaseMap_Metatiled.tsd" ..\..\bin\UnitTestFiles\
Modified: sandbox/jng/tiling_v2/Server/src/UnitTesting/TestTileService.cpp
--- sandbox/jng/tiling_v2/Server/src/UnitTesting/TestTileService.cpp 2019-05-03 12:33:01 UTC (rev 9500)
+++ sandbox/jng/tiling_v2/Server/src/UnitTesting/TestTileService.cpp 2019-05-03 13:04:33 UTC (rev 9501)
@@ -149,6 +149,11 @@
Ptr<MgByteReader> tsdrdr4 = tsdsrc4->GetReader();
m_svcResource->SetResource(tilesetres4, tsdrdr4, NULL);
+ Ptr<MgResourceIdentifier> tilesetres5 = new MgResourceIdentifier(L"Library://UnitTests/TileSets/Sheboygan_OrigSize.TileSetDefinition");
+ Ptr<MgByteSource> tsdsrc5 = new MgByteSource(L"../UnitTestFiles/UT_BaseMap_OrigSize.tsd", false);
+ Ptr<MgByteReader> tsdrdr5 = tsdsrc5->GetReader();
+ m_svcResource->SetResource(tilesetres5, tsdrdr5, NULL);
// publish the layer definitions
Ptr<MgResourceIdentifier> ldfres1 = new MgResourceIdentifier(L"Library://UnitTests/Layers/RoadCenterLines.LayerDefinition");
Ptr<MgByteSource> ldfsrc1 = new MgByteSource(L"../UnitTestFiles/UT_RoadCenterLines.ldf", false);
@@ -243,6 +248,9 @@
Ptr<MgResourceIdentifier> tilesetres4 = new MgResourceIdentifier(L"Library://UnitTests/TileSets/XYZ_Metatiled.TileSetDefinition");
m_svcResource->DeleteResource(tilesetres4);
+ m_svcResource->DeleteResource(tilesetres5);
// delete the layer definitions
m_svcResource->DeleteResource(ldfres1);
@@ -1745,18 +1753,28 @@
try
- INT32 col = 30;
- INT32 row = 31;
+ INT32 col = 28;
+ INT32 row = 29;
INT32 scale = 3;
Ptr<MgByteReader> tile;
Ptr<MgResourceIdentifier> tsId;
- tsId = new MgResourceIdentifier(L"Library://UnitTests/TileSets/Sheboygan.TileSetDefinition");
+ tsId = new MgResourceIdentifier(L"Library://UnitTests/TileSets/Sheboygan_OrigSize.TileSetDefinition");
m_svcTile->ClearCache(tsId);
tile = m_svcTile->GetTile(tsId, L"BaseLayers", col, row, scale);
tile->ToFile(L"../UnitTestFiles/GetMetatileSingle_Baseline.png");
+ INT32 metaTileFactor = 4;
+ //Render full 4x4 tiles to check we're generating the same file paths from metatile
+ for (INT32 x = col; x < col + metaTileFactor; x++)
+ for (INT32 y = row; y < row + metaTileFactor; y++)
+ tile = m_svcTile->GetTile(tsId, L"BaseLayers", x, y, scale);
Ptr<MgMap> map = CreateMapLinked(L"MetaTileBaseline");
map->SetViewScale(3125);
Ptr<MgServerRenderingService> renderSvc = dynamic_cast<MgServerRenderingService*>(m_siteConnection->CreateService(MgServiceType::RenderingService));
@@ -1764,7 +1782,6 @@
MgFileUtil::CreateDirectory(L"../UnitTestFiles/GetMetatileSingle_Baseline");
- INT32 metaTileFactor = 4;
Ptr<MgMetatile> metaTile = renderSvc->RenderMetatile(map, L"BaseLayers", col, row, MgTileParameters::tileWidth, MgTileParameters::tileHeight, MgTileParameters::tileDPI, MgImageFormats::Png, MgConfigProperties::DefaultRenderingServicePropertyTileExtentOffset, metaTileFactor);
Ptr<MgByteReader> mtContent = metaTile->GetImage();
INT32 metaTileLen = mtContent->GetLength();
Added: sandbox/jng/tiling_v2/UnitTest/TestData/TileService/UT_BaseMap_OrigSize.tsd
--- sandbox/jng/tiling_v2/UnitTest/TestData/TileService/UT_BaseMap_OrigSize.tsd (rev 0)
+++ sandbox/jng/tiling_v2/UnitTest/TestData/TileService/UT_BaseMap_OrigSize.tsd 2019-05-03 13:04:33 UTC (rev 9501)
@@ -0,0 +1,59 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<TileSetDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="TileSetDefinition-3.0.0.xsd">
+ <TileStoreParameters>
+ <TileProvider>Default</TileProvider>
+ <Parameter>
+ <Name>TilePath</Name>
+ <Value>%MG_TILE_CACHE_PATH%</Value>
+ </Parameter>
+ <Parameter>
+ <Name>TileWidth</Name>
+ <Value>300</Value>
+ </Parameter>
+ <Parameter>
+ <Name>TileHeight</Name>
+ </Parameter>
+ <Parameter>
+ <Name>TileFormat</Name>
+ <Value>PNG</Value>
+ </Parameter>
+ <Parameter>
+ <Name>FiniteScaleList</Name>
+ <Value>200000,100000,50000,25000,12500,6250,3125,1562.5,781.25,390.625</Value>
+ </Parameter>
+ <Parameter>
+ <Name>CoordinateSystem</Name>
+ <Value>GEOGCS["LL84",DATUM["WGS 84",SPHEROID["WGS 84",6378137,298.25722293287],TOWGS84[0,0,0,0,0,0,0]],PRIMEM["Greenwich",0],UNIT["Degrees",0.01745329252]]</Value>
+ </Parameter>
+ </TileStoreParameters>
+ <Extents>
+ <MinX>-87.79786601383196</MinX>
+ <MaxX>-87.66452777186925</MaxX>
+ <MinY>43.6868578621819</MinY>
+ <MaxY>43.8037962206133</MaxY>
+ </Extents>
+ <BaseMapLayerGroup>
+ <Name>BaseLayers</Name>
+ <Visible>true</Visible>
+ <ShowInLegend>true</ShowInLegend>
+ <ExpandInLegend>true</ExpandInLegend>
+ <LegendLabel>Base Layers</LegendLabel>
+ <BaseMapLayer>
+ <Name>Parcels</Name>
+ <ResourceId>Library://UnitTests/Layers/Parcels.LayerDefinition</ResourceId>
+ <Selectable>true</Selectable>
+ <LegendLabel>Parcels</LegendLabel>
+ <ExpandInLegend>false</ExpandInLegend>
+ </BaseMapLayer>
+ <BaseMapLayer>
+ <Name>VotingDistricts</Name>
+ <ResourceId>Library://UnitTests/Layers/VotingDistricts.LayerDefinition</ResourceId>
+ <LegendLabel>Voting Districts</LegendLabel>
+ </BaseMapLayer>
+ </BaseMapLayerGroup>
+</TileSetDefinition>
More information about the mapguide-commits
