[mapguide-commits] r9516 - in sandbox/jng/v4: Common/CoordinateSystem Common/Foundation Common/Geometry Common/Geometry/Buffer Common/Geometry/Spatial Common/Renderers Common/Stylization Server/src/Services/Feature
svn_mapguide at osgeo.org
Wed May 29 04:26:20 PDT 2019
Author: jng
Date: 2019-05-29 04:26:19 -0700 (Wed, 29 May 2019)
New Revision: 9516
sandbox/jng/v4/Common/CoordinateSystem/CoordSysUtil.h
sandbox/jng/v4/Common/Foundation/FoundationDefs.h
sandbox/jng/v4/Common/Geometry/Buffer/FloatTransform.cpp
sandbox/jng/v4/Common/Geometry/Buffer/MgBuffer.cpp
sandbox/jng/v4/Common/Geometry/GeometryCommon.h
sandbox/jng/v4/Common/Geometry/Spatial/MathUtility.cpp
sandbox/jng/v4/Common/Geometry/Spatial/MathUtility.h
sandbox/jng/v4/Common/Renderers/stdafx.h
sandbox/jng/v4/Common/Stylization/PointAdapter.cpp
sandbox/jng/v4/Common/Stylization/PolygonAdapter.cpp
sandbox/jng/v4/Common/Stylization/PolylineAdapter.cpp
sandbox/jng/v4/Common/Stylization/SE_AreaPositioning.cpp
sandbox/jng/v4/Common/Stylization/SE_PositioningAlgorithms.cpp
sandbox/jng/v4/Common/Stylization/stdafx.h
sandbox/jng/v4/Server/src/Services/Feature/FeatureNumericFunctions.cpp
RFC 172: Use std::isnan() and std::isinf()
Modified: sandbox/jng/v4/Common/CoordinateSystem/CoordSysUtil.h
--- sandbox/jng/v4/Common/CoordinateSystem/CoordSysUtil.h 2019-05-29 10:58:08 UTC (rev 9515)
+++ sandbox/jng/v4/Common/CoordinateSystem/CoordSysUtil.h 2019-05-29 11:26:19 UTC (rev 9516)
@@ -47,13 +47,6 @@
// Represent NAN for double
#define DoubleNan std::numeric_limits<double>::quiet_NaN()
-// Checks whether value is NAN or not
-#ifdef _WIN32
-#define IsDoubleNan(x) _isnan(x)
-#else
-#define IsDoubleNan(x) isnan(x)
-#endif
#ifndef _WIN32
#define wmemcpy memcpy
#endif
Modified: sandbox/jng/v4/Common/Foundation/FoundationDefs.h
--- sandbox/jng/v4/Common/Foundation/FoundationDefs.h 2019-05-29 10:58:08 UTC (rev 9515)
+++ sandbox/jng/v4/Common/Foundation/FoundationDefs.h 2019-05-29 11:26:19 UTC (rev 9516)
@@ -39,7 +39,6 @@
#define _stricmp strcasecmp
#define _strnicmp strncasecmp
- #define _isnan isnan
#define _finite finite
#endif
Modified: sandbox/jng/v4/Common/Geometry/Buffer/FloatTransform.cpp
--- sandbox/jng/v4/Common/Geometry/Buffer/FloatTransform.cpp 2019-05-29 10:58:08 UTC (rev 9515)
+++ sandbox/jng/v4/Common/Geometry/Buffer/FloatTransform.cpp 2019-05-29 11:26:19 UTC (rev 9516)
@@ -55,7 +55,7 @@
if ( doubleExtent.Height() != 0.0)
aspect = doubleExtent.Width() / doubleExtent.Height();
- if ( IsDoubleNan( aspect ) )
+ if ( std::isnan( aspect ) )
aspect = 1.0;
if (aspect >= 1.0)
Modified: sandbox/jng/v4/Common/Geometry/Buffer/MgBuffer.cpp
--- sandbox/jng/v4/Common/Geometry/Buffer/MgBuffer.cpp 2019-05-29 10:58:08 UTC (rev 9515)
+++ sandbox/jng/v4/Common/Geometry/Buffer/MgBuffer.cpp 2019-05-29 11:26:19 UTC (rev 9516)
@@ -77,7 +77,7 @@
MgGeometryCollection* MgBuffer::CreateBuffer(MgGeometryCollection* geometries, double offset, bool merge)
// check parameters
- if ( geometries == NULL || IsDoubleNan( offset ) || fabs(offset) > DoubleMaxValue )
+ if ( geometries == NULL || std::isnan( offset ) || fabs(offset) > DoubleMaxValue )
return NULL;
Ptr<MgGeometryCollection> geomCol;
Modified: sandbox/jng/v4/Common/Geometry/GeometryCommon.h
--- sandbox/jng/v4/Common/Geometry/GeometryCommon.h 2019-05-29 10:58:08 UTC (rev 9515)
+++ sandbox/jng/v4/Common/Geometry/GeometryCommon.h 2019-05-29 11:26:19 UTC (rev 9516)
@@ -183,13 +183,6 @@
-#ifdef _WIN32
-#else
-#endif
#define GEOMETRY_SEP " "
#define POINT_SEPARATOR L", "
Modified: sandbox/jng/v4/Common/Geometry/Spatial/MathUtility.cpp
--- sandbox/jng/v4/Common/Geometry/Spatial/MathUtility.cpp 2019-05-29 10:58:08 UTC (rev 9515)
+++ sandbox/jng/v4/Common/Geometry/Spatial/MathUtility.cpp 2019-05-29 11:26:19 UTC (rev 9516)
@@ -17,6 +17,7 @@
#include "Foundation.h"
#include "MathUtility.h"
+#include <cmath>
using namespace std;
@@ -35,11 +36,7 @@
bool MgMathUtility::IsNan(double n)
-#ifdef _WIN32
- return _isnan(n);
-#else
- return isnan(n);
-#endif
+ return std::isnan(n);
Modified: sandbox/jng/v4/Common/Geometry/Spatial/MathUtility.h
--- sandbox/jng/v4/Common/Geometry/Spatial/MathUtility.h 2019-05-29 10:58:08 UTC (rev 9515)
+++ sandbox/jng/v4/Common/Geometry/Spatial/MathUtility.h 2019-05-29 11:26:19 UTC (rev 9516)
@@ -19,7 +19,6 @@
#define MgMathUtility_H
#include <limits> // For quiet_NaN()
-#include <float.h> // For _isnan()
#ifdef _WIN32
// For M_PI in math.h on Windows (doesn't seem to work though).
#define _USE_MATH_DEFINES
Modified: sandbox/jng/v4/Common/Renderers/stdafx.h
--- sandbox/jng/v4/Common/Renderers/stdafx.h 2019-05-29 10:58:08 UTC (rev 9515)
+++ sandbox/jng/v4/Common/Renderers/stdafx.h 2019-05-29 11:26:19 UTC (rev 9516)
@@ -37,7 +37,6 @@
typedef unsigned long DWORD;
#define _wcsnicmp wcsncasecmp
#define _wcsicmp wcscasecmp
-#define _isnan isnan
#endif //_WIN32
Modified: sandbox/jng/v4/Common/Stylization/PointAdapter.cpp
--- sandbox/jng/v4/Common/Stylization/PointAdapter.cpp 2019-05-29 10:58:08 UTC (rev 9515)
+++ sandbox/jng/v4/Common/Stylization/PointAdapter.cpp 2019-05-29 11:26:19 UTC (rev 9516)
@@ -20,8 +20,8 @@
#include "PointAdapter.h"
#include "LineBuffer.h"
#include "FeatureTypeStyleVisitor.h"
+#include <cmath>
PointAdapter::PointAdapter(LineBufferPool* lbp) : GeometryAdapter(lbp)
@@ -207,7 +207,7 @@
// multi should work for simple polygons also
lb->Centroid(LineBuffer::ctPoint, &cx, &cy, &dummy);
- if (!_isnan(cx) && !_isnan(cy))
+ if (!std::isnan(cx) && !std::isnan(cy))
// if there was no point symbol, the label is the symbol,
// so we send without overposting and at the center point
Modified: sandbox/jng/v4/Common/Stylization/PolygonAdapter.cpp
--- sandbox/jng/v4/Common/Stylization/PolygonAdapter.cpp 2019-05-29 10:58:08 UTC (rev 9515)
+++ sandbox/jng/v4/Common/Stylization/PolygonAdapter.cpp 2019-05-29 11:26:19 UTC (rev 9516)
@@ -20,8 +20,8 @@
#include "PolygonAdapter.h"
+#include <cmath>
PolygonAdapter::PolygonAdapter(LineBufferPool* lbp) : GeometryAdapter(lbp)
@@ -232,7 +232,7 @@
// multi should work for simple polygons too
lb->Centroid(LineBuffer::ctArea, &cx, &cy, &dummy);
AddLabel(cx, cy, 0.0, false, label, RS_OverpostType_AllFit, true, renderer, lb);
Modified: sandbox/jng/v4/Common/Stylization/PolylineAdapter.cpp
--- sandbox/jng/v4/Common/Stylization/PolylineAdapter.cpp 2019-05-29 10:58:08 UTC (rev 9515)
+++ sandbox/jng/v4/Common/Stylization/PolylineAdapter.cpp 2019-05-29 11:26:19 UTC (rev 9516)
@@ -20,8 +20,8 @@
#include "PolylineAdapter.h"
+#include <cmath>
PolylineAdapter::PolylineAdapter(LineBufferPool* lbp) : GeometryAdapter(lbp)
@@ -288,7 +288,7 @@
// multi should work for simple polylines too
lb->Centroid(LineBuffer::ctLine, &cx, &cy, &slope_rad);
AddLabel(cx, cy, slope_rad, true, label, RS_OverpostType_AllFit, true, renderer, label->GetSymbol()->IsAdvancedPlacement()? lb : NULL);
Modified: sandbox/jng/v4/Common/Stylization/SE_AreaPositioning.cpp
--- sandbox/jng/v4/Common/Stylization/SE_AreaPositioning.cpp 2019-05-29 10:58:08 UTC (rev 9515)
+++ sandbox/jng/v4/Common/Stylization/SE_AreaPositioning.cpp 2019-05-29 11:26:19 UTC (rev 9516)
@@ -17,8 +17,8 @@
#include "stdafx.h"
#include "SE_AreaPositioning.h"
+#include <cmath>
// Initializes the area positioning class for iteration over the geometry.
SE_AreaPositioning::SE_AreaPositioning(LineBuffer* geom, SE_RenderAreaStyle* style, double w2sAngleRad)
@@ -57,7 +57,7 @@
geom->Centroid(LineBuffer::ctArea, &m_base_pt.x, &m_base_pt.y, &slope);
// if we can't compute the centroid then just set the base point to the origin
- if (_isnan(m_base_pt.x) || _isnan(m_base_pt.y))
+ if (std::isnan(m_base_pt.x) || std::isnan(m_base_pt.y))
m_base_pt.x = 0.0;
m_base_pt.y = 0.0;
Modified: sandbox/jng/v4/Common/Stylization/SE_PositioningAlgorithms.cpp
--- sandbox/jng/v4/Common/Stylization/SE_PositioningAlgorithms.cpp 2019-05-29 10:58:08 UTC (rev 9515)
+++ sandbox/jng/v4/Common/Stylization/SE_PositioningAlgorithms.cpp 2019-05-29 11:26:19 UTC (rev 9516)
@@ -23,8 +23,8 @@
#include "RS_FontEngine.h"
#include "RS_FeatureReader.h"
#include "SE_SymbolDefProxies.h"
+#include <cmath>
// Recomputes the bounds of an SE_RenderStyle that contains a text
// whose alignment we have messed with.
void UpdateStyleBounds(SE_RenderStyle* st, SE_Renderer* se_renderer)
@@ -141,7 +141,7 @@
// don't add a label if we can't compute the centroid
- if (_isnan(cx) || _isnan(cy))
+ if (std::isnan(cx) || std::isnan(cy))
return;
// need to convert centroid to screen units
@@ -206,7 +206,7 @@
geometry->Centroid(LineBuffer::ctPoint, &cx, &cy, NULL);
return;
se_renderer->WorldToScreenPoint(cx, cy, cx, cy);
Modified: sandbox/jng/v4/Common/Stylization/stdafx.h
--- sandbox/jng/v4/Common/Stylization/stdafx.h 2019-05-29 10:58:08 UTC (rev 9515)
+++ sandbox/jng/v4/Common/Stylization/stdafx.h 2019-05-29 11:26:19 UTC (rev 9516)
@@ -33,6 +33,4 @@
#endif
Modified: sandbox/jng/v4/Server/src/Services/Feature/FeatureNumericFunctions.cpp
--- sandbox/jng/v4/Server/src/Services/Feature/FeatureNumericFunctions.cpp 2019-05-29 10:58:08 UTC (rev 9515)
+++ sandbox/jng/v4/Server/src/Services/Feature/FeatureNumericFunctions.cpp 2019-05-29 11:26:19 UTC (rev 9516)
@@ -689,29 +689,12 @@
bool MgFeatureNumericFunctions::IsInf(double x)
- bool isInfinity = false;
-#ifdef _WIN32
- int code = _fpclass(x);
- if ((code == _FPCLASS_NINF) || (code == _FPCLASS_PINF))
- isInfinity = true;
-#else
- isInfinity = isinf(x);
-#endif
- return isInfinity;
+ return std::isinf(x);
bool MgFeatureNumericFunctions::IsNan(double x)
- bool isNan = false;
-#ifdef _WIN32
- isNan = _isnan(x);
-#else
- isNan = isnan(x);
-#endif
- return isNan;
+ return std::isnan(x);
// Calculate Standard Deviation for the values
More information about the mapguide-commits
