[mapguide-commits] r9526 - sandbox/jng/mvt/Common/Renderers
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri May 31 07:10:44 PDT 2019
Author: jng
Date: 2019-05-31 07:10:44 -0700 (Fri, 31 May 2019)
New Revision: 9526
   sandbox/jng/mvt/Common/Renderers/MVTRenderer.cpp
   sandbox/jng/mvt/Common/Renderers/MVTRenderer.h
pimpl-ize MVTRenderer so vtzero headers don't leak out to consumers
Modified: sandbox/jng/mvt/Common/Renderers/MVTRenderer.cpp
--- sandbox/jng/mvt/Common/Renderers/MVTRenderer.cpp	2019-05-31 13:06:39 UTC (rev 9525)
+++ sandbox/jng/mvt/Common/Renderers/MVTRenderer.cpp	2019-05-31 14:10:44 UTC (rev 9526)
@@ -18,6 +18,7 @@
 #include "MVTRenderer.h"
 #include "RS_FeatureReader.h"
 #include "UnicodeString.h"
+#include <vtzero/builder.hpp>
 // =========================== MVTRenderer overview =============================== //
@@ -28,7 +29,7 @@
 //  - Create a new vtzero::layer_builder instance on every StartLayer(). Push any
 //    current instance to the internal list for cleanup
-//  - Clear and fill the internal property map on every StartFeature() call
+//  - Stash the RS_FeatureReader pointer on every StartFeature() call (we need this for writing properties)
 //  - For every ProcessXXX() call
 //    - Create a vtzero::feature_builder instance
 //    - Write the line buffer coordinates to this builder
@@ -42,11 +43,189 @@
+struct MVTRenderer::MVTImpl {
+    MVTImpl(MVTRenderer* parent)
+        : m_tileBuilder(new vtzero::tile_builder())
+        , m_activeLayerBuilder(nullptr)
+        , m_parent(parent)
+    ~MVTImpl()
+        for (auto lb : m_prevLayerBuilder)
+            delete lb;
+        m_prevLayerBuilder.clear();
+        delete m_tileBuilder;
+    void SetActiveLayerBuilder(const std::string& name)
+        m_activeLayerBuilder = new vtzero::layer_builder(*m_tileBuilder, name);
+    void ClearActiveLayerBuilder()
+        m_prevLayerBuilder.push_back(m_activeLayerBuilder);
+        m_activeLayerBuilder = nullptr;
+    static void AddActiveFeatureProperties(RS_FeatureReader* activeFeature, vtzero::feature_builder* builder)
+        int count;
+        auto propNames = activeFeature->GetPropNames(count);
+        for (int i = 0; i < count; i++)
+            auto name = propNames[i];
+            std::string mbName;
+            UnicodeString::WideCharToMultiByte(name, mbName);
+            auto propType = activeFeature->GetPropertyType(name);
+            switch (propType)
+            case FdoDataType_Boolean:
+                builder->add_property(mbName, vtzero::bool_value_type(activeFeature->GetBoolean(name)));
+                break;
+            case FdoDataType_Byte:
+                builder->add_property(mbName, vtzero::int_value_type(activeFeature->GetByte(name)));
+                break;
+            case FdoDataType_DateTime:
+                auto dt = activeFeature->GetAsString(name);
+                std::string sDt;
+                UnicodeString::WideCharToMultiByte(dt, sDt);
+                builder->add_property(mbName, vtzero::string_value_type(sDt));
+                break;
+            case FdoDataType_Decimal:
+            case FdoDataType_Double:
+                builder->add_property(mbName, vtzero::double_value_type(activeFeature->GetDouble(name)));
+                break;
+            case FdoDataType_Int16:
+                builder->add_property(mbName, vtzero::int_value_type(activeFeature->GetInt16(name)));
+                break;
+            case FdoDataType_Int32:
+                builder->add_property(mbName, vtzero::int_value_type(activeFeature->GetInt32(name)));
+                break;
+            case FdoDataType_Int64:
+                builder->add_property(mbName, vtzero::int_value_type(activeFeature->GetInt64(name)));
+                break;
+            case FdoDataType_Single:
+                builder->add_property(mbName, vtzero::float_value_type(activeFeature->GetSingle(name)));
+                break;
+            case FdoDataType_String:
+                auto s = activeFeature->GetString(name);
+                std::string sVal;
+                UnicodeString::WideCharToMultiByte(s, sVal);
+                builder->add_property(mbName, vtzero::string_value_type(sVal));
+                break;
+            case FdoDataType_BLOB: //Not handled
+            case FdoDataType_CLOB:
+                break;
+    void ProcessPolygon(RS_FeatureReader* activeFeature, LineBuffer * lb)
+        vtzero::polygon_feature_builder builder(*m_activeLayerBuilder);
+        if (lb->cntr_count() == 1)
+            auto numPoints = lb->point_count();
+            builder.add_ring(numPoints);
+            for (auto i = 0; i < numPoints; i++)
+                auto x = lb->x_coord(i);
+                auto y = lb->y_coord(i);
+                double tx;
+                double ty;
+                m_parent->WorldToScreenPoint(x, y, tx, ty);
+                builder.set_point(static_cast<int>(tx), static_cast<int>(ty));
+        else //MultiPolygon
+        AddActiveFeatureProperties(activeFeature, &builder);
+        builder.commit();
+    void ProcessPolyline(RS_FeatureReader* activeFeature, LineBuffer * lb)
+        vtzero::linestring_feature_builder builder(*m_activeLayerBuilder);
+            auto numPoints = lb->cntr_size(0);
+            auto pointOffset = lb->contour_start_point(0);
+                auto x = lb->x_coord(i + pointOffset);
+                auto y = lb->y_coord(i + pointOffset);
+                double tx;
+                double ty;
+        else //MultiLineString
+        builder.commit();
+    void ProcessMarker(RS_FeatureReader* activeFeature, LineBuffer * lb)
+        vtzero::point_feature_builder builder(*m_activeLayerBuilder);
+        if (lb->point_count() == 1)
+            auto x = lb->x_coord(0);
+            auto y = lb->y_coord(0);
+            double tx;
+            double ty;
+        else //MultiPoint
+        builder.commit();
+    void GetMVTContent(std::string& buffer)
+        m_tileBuilder->serialize(buffer);
+private:
+    vtzero::tile_builder* m_tileBuilder;
+    vtzero::layer_builder* m_activeLayerBuilder;
+    std::vector<vtzero::layer_builder*> m_prevLayerBuilder;
+    MVTRenderer* m_parent;
 const int MVT_SIZE = 4096;
 MVTRenderer::MVTRenderer()
-    : m_tileBuilder(new vtzero::tile_builder())
-    , m_activeLayerBuilder(nullptr)
+    : m_impl(new MVTRenderer::MVTImpl(this)) //MVTImpl only stashes this pointer in its ctor, nothing is called on it yet
     , m_mapInfo(nullptr)
     , m_layerInfo(nullptr)
     , m_fcInfo(nullptr)
@@ -57,14 +236,7 @@
 MVTRenderer::~MVTRenderer()
-    for (auto lb : m_prevLayerBuilder)
-        delete lb;
-    m_prevLayerBuilder.clear();
-    delete m_tileBuilder;
 //Called by the stylizer when rendering is about to begin on the map
 void MVTRenderer::StartMap(RS_MapUIInfo * mapInfo, RS_Bounds & extents, double mapScale, double dpi, double metersPerUnit, CSysTransformer * xformToLL)
@@ -122,7 +294,7 @@
     std::string name;
     UnicodeString::WideCharToMultiByte(m_layerInfo->name().c_str(), name);
-    m_activeLayerBuilder = new vtzero::layer_builder(*m_tileBuilder, name);
+    m_impl->SetActiveLayerBuilder(name);
 //Called by the stylizer when rendering is about to begin on the map for the layer indicated by StartLayer()
@@ -132,8 +304,7 @@
     m_layerInfo = nullptr;
     m_fcInfo = nullptr;
-    m_prevLayerBuilder.push_back(m_activeLayerBuilder);
-    m_activeLayerBuilder = nullptr;
+    m_impl->ClearActiveLayerBuilder();
 //Called by the stylizer when rendering is about to begin on the map for the given feature
@@ -145,61 +316,13 @@
 //Entry point for polygon rendering. Perform any pre-rendering operations.
 void MVTRenderer::ProcessPolygon(LineBuffer * lb, RS_FillStyle & fill)
-    vtzero::polygon_feature_builder builder(*m_activeLayerBuilder);
-    if (lb->cntr_count() == 1)
-        auto numPoints = lb->point_count();
-        builder.add_ring(numPoints);
-        for (auto i = 0; i < numPoints; i++)
-            auto x = lb->x_coord(i);
-            auto y = lb->y_coord(i);
-            double tx;
-            double ty;
-            WorldToScreenPoint(x, y, tx, ty);
-            builder.set_point(static_cast<int>(tx), static_cast<int>(ty));
-    else //MultiPolygon
-    AddActiveFeatureProperties(&builder);
-    builder.commit();
+    m_impl->ProcessPolygon(m_activeFeature, lb);
 //Entry point for polyline rendering. Perform any pre-rendering operations.
 void MVTRenderer::ProcessPolyline(LineBuffer * lb, RS_LineStroke & lsym)
-    vtzero::linestring_feature_builder builder(*m_activeLayerBuilder);
-        auto numPoints = lb->cntr_size(0);
-        auto pointOffset = lb->contour_start_point(0);
-            auto x = lb->x_coord(i + pointOffset);
-            auto y = lb->y_coord(i + pointOffset);
-            double tx;
-            double ty;
-    else //MultiLineString
-    builder.commit();
+    m_impl->ProcessPolyline(m_activeFeature, lb);
 //Entry point for raster/image rendering. Perform any pre-rendering operations.
@@ -213,26 +336,7 @@
 //Entry point for marker rendering. Perform any pre-rendering operations.
 void MVTRenderer::ProcessMarker(LineBuffer * lb, RS_MarkerDef & mdef, bool allowOverpost, RS_Bounds * bounds)
-    vtzero::point_feature_builder builder(*m_activeLayerBuilder);
-    if (lb->point_count() == 1)
-        auto x = lb->x_coord(0);
-        auto y = lb->y_coord(0);
-        double tx;
-        double ty;
-    else //MultiPoint
-    builder.commit();
+    m_impl->ProcessMarker(m_activeFeature, lb);
 //Entry point for label group rendering.
@@ -406,62 +510,5 @@
 void MVTRenderer::GetMVTContent(std::string& buffer)
-    m_tileBuilder->serialize(buffer);
-void MVTRenderer::AddActiveFeatureProperties(vtzero::feature_builder* builder)
-    int count;
-    auto propNames = m_activeFeature->GetPropNames(count);
-    for (int i = 0; i < count; i++)
-        auto name = propNames[i];
-        std::string mbName;
-        UnicodeString::WideCharToMultiByte(name, mbName);
-        auto propType = m_activeFeature->GetPropertyType(name);
-        switch (propType)
-        case FdoDataType_Boolean:
-            builder->add_property(mbName, vtzero::bool_value_type(m_activeFeature->GetBoolean(name)));
-            break;
-        case FdoDataType_Byte:
-            builder->add_property(mbName, vtzero::int_value_type(m_activeFeature->GetByte(name)));
-            break;
-        case FdoDataType_DateTime:
-            auto dt = m_activeFeature->GetAsString(name);
-            std::string sDt;
-            UnicodeString::WideCharToMultiByte(dt, sDt);
-            builder->add_property(mbName, vtzero::string_value_type(sDt));
-            break;
-        case FdoDataType_Decimal:
-        case FdoDataType_Double:
-            builder->add_property(mbName, vtzero::double_value_type(m_activeFeature->GetDouble(name)));
-            break;
-        case FdoDataType_Int16:
-            builder->add_property(mbName, vtzero::int_value_type(m_activeFeature->GetInt16(name)));
-            break;
-        case FdoDataType_Int32:
-            builder->add_property(mbName, vtzero::int_value_type(m_activeFeature->GetInt32(name)));
-            break;
-        case FdoDataType_Int64:
-            builder->add_property(mbName, vtzero::int_value_type(m_activeFeature->GetInt64(name)));
-            break;
-        case FdoDataType_Single:
-            builder->add_property(mbName, vtzero::float_value_type(m_activeFeature->GetSingle(name)));
-            break;
-        case FdoDataType_String:
-            auto s = m_activeFeature->GetString(name);
-            std::string sVal;
-            UnicodeString::WideCharToMultiByte(s, sVal);
-            builder->add_property(mbName, vtzero::string_value_type(sVal));
-            break;
-        case FdoDataType_BLOB: //Not handled
-        case FdoDataType_CLOB:
-            break;
+    m_impl->GetMVTContent(buffer);
\ No newline at end of file
Modified: sandbox/jng/mvt/Common/Renderers/MVTRenderer.h
--- sandbox/jng/mvt/Common/Renderers/MVTRenderer.h	2019-05-31 13:06:39 UTC (rev 9525)
+++ sandbox/jng/mvt/Common/Renderers/MVTRenderer.h	2019-05-31 14:10:44 UTC (rev 9526)
@@ -20,7 +20,6 @@
 #include "Renderers.h"
 #include "SE_Renderer.h"
-#include <vtzero/builder.hpp>
 #include <vector>
 // A renderer that produces Mapbox Vector Tiles (MVT)
@@ -74,13 +73,11 @@
     RENDERERS_API void GetMVTContent(std::string& buffer);
 private:
-    void AddActiveFeatureProperties(vtzero::feature_builder* builder);
+    struct MVTImpl;
+    std::unique_ptr<MVTImpl> m_impl;
     RS_FeatureReader* m_activeFeature;
-    vtzero::tile_builder* m_tileBuilder;
-    vtzero::layer_builder* m_activeLayerBuilder;
-    std::vector<vtzero::layer_builder*> m_prevLayerBuilder;
     // map/layer/feature info
     RS_MapUIInfo* m_mapInfo;
     RS_LayerUIInfo* m_layerInfo;
More information about the mapguide-commits mailing list
